* Measurement data measured by REW V5.31.3
* Source: C:\____Datas\__Mesures\mesures ailleurs\xtof\simu filtrage 4V rephase\impulseSub.wav
* Format: Imported Impulse Response, 96000.0 Hz sampling
* Dated: 17 janv. 2026 09:28:08
* REW Settings:
*  C-weighting compensation: Off
*  Target level: 75.0 dB
* Note: Impulse Response imported from C:\____Datas\__Mesures\mesures ailleurs\xtof\simu filtrage 4V rephase\impulseSub.wav 16384 samples (170,7 ms) of 32-bit PCM data at 96 kHz
* Measurement: impulseSub
* Smoothing: None
* Frequency Step: 0.7324218 Hz
* Start Frequency: 20.0 Hz
* Freq(Hz) SPL(dB) Phase(degrees)
19.775389 116.858 -40.5897
20.507811 116.851 -42.1472
21.240232 116.844 -43.7101
21.972654 116.837 -45.2786
22.705076 116.829 -46.8527
23.437498 116.820 -48.4327
24.169920 116.810 -50.0185
24.902341 116.800 -51.6103
25.634763 116.789 -53.2081
26.367185 116.777 -54.8120
27.099607 116.764 -56.4220
27.832029 116.750 -58.0381
28.564451 116.735 -59.6604
29.296872 116.719 -61.2890
30.029294 116.702 -62.9237
30.761716 116.684 -64.5646
31.494138 116.664 -66.2116
32.226560 116.643 -67.8647
32.958981 116.621 -69.5240
33.691403 116.598 -71.1892
34.423825 116.574 -72.8603
35.156247 116.547 -74.5373
35.888669 116.520 -76.2200
36.621090 116.491 -77.9083
37.353512 116.460 -79.6021
38.085934 116.428 -81.3012
38.818356 116.394 -83.0055
39.550778 116.358 -84.7148
40.283200 116.321 -86.4289
41.015621 116.281 -88.1476
41.748043 116.240 -89.8707
42.480465 116.197 -91.5979
43.212887 116.152 -93.3291
43.945309 116.106 -95.0640
44.677730 116.057 -96.8023
45.410152 116.006 -98.5437
46.142574 115.953 -100.2880
46.874996 115.898 -102.0348
47.607418 115.840 -103.7839
48.339840 115.781 -105.5349
49.072261 115.719 -107.2874
49.804683 115.655 -109.0412
50.537105 115.589 -110.7959
51.269527 115.521 -112.5512
52.001949 115.450 -114.3066
52.734370 115.377 -116.0618
53.466792 115.301 -117.8164
54.199214 115.224 -119.5701
54.931636 115.144 -121.3225
55.664058 115.061 -123.0731
56.396479 114.976 -124.8216
57.128901 114.889 -126.5675
57.861323 114.799 -128.3106
58.593745 114.707 -130.0503
59.326167 114.613 -131.7862
60.058589 114.516 -133.5181
60.791010 114.416 -135.2454
61.523432 114.315 -136.9679
62.255854 114.211 -138.6850
62.988276 114.104 -140.3964
63.720698 113.996 -142.1017
64.453119 113.885 -143.8006
65.185541 113.772 -145.4926
65.917963 113.656 -147.1774
66.650385 113.538 -148.8546
67.382807 113.418 -150.5240
68.115229 113.296 -152.1850
68.847650 113.172 -153.8374
69.580072 113.045 -155.4810
70.312494 112.916 -157.1152
71.044916 112.786 -158.7399
71.777338 112.653 -160.3547
72.509759 112.518 -161.9594
73.242181 112.382 -163.5537
73.974603 112.243 -165.1372
74.707025 112.103 -166.7099
75.439447 111.960 -168.2713
76.171869 111.816 -169.8213
76.904290 111.671 -171.3597
77.636712 111.523 -172.8862
78.369134 111.374 -174.4008
79.101556 111.223 -175.9031
79.833978 111.071 -177.3931
80.566399 110.917 -178.8705
81.298821 110.762 179.6648
82.031243 110.605 178.2129
82.763665 110.448 176.7739
83.496087 110.288 175.3480
84.228508 110.128 173.9352
84.960930 109.966 172.5356
85.693352 109.803 171.1493
86.425774 109.639 169.7764
87.158196 109.474 168.4168
87.890618 109.308 167.0708
88.623039 109.140 165.7382
89.355461 108.972 164.4191
90.087883 108.803 163.1136
90.820305 108.633 161.8216
91.552727 108.463 160.5431
92.285148 108.291 159.2781
93.017570 108.119 158.0266
93.749992 107.947 156.7886
94.482414 107.773 155.5640
95.214836 107.599 154.3528
95.947258 107.425 153.1548
96.679679 107.250 151.9702
97.412101 107.074 150.7988
98.144523 106.898 149.6405
98.876945 106.722 148.4953
99.609367 106.545 147.3630
100.341788 106.368 146.2437
101.074210 106.191 145.1372
101.806632 106.013 144.0434
102.539054 105.836 142.9622
103.271476 105.658 141.8935
104.003897 105.480 140.8372
104.736319 105.301 139.7932
105.468741 105.123 138.7615
106.201163 104.944 137.7418
106.933585 104.766 136.7341
107.666007 104.587 135.7382
108.398428 104.409 134.7540
109.130850 104.230 133.7815
109.863272 104.052 132.8204
110.595694 103.874 131.8708
111.328116 103.695 130.9323
112.060537 103.517 130.0049
112.792959 103.339 129.0886
113.525381 103.161 128.1831
114.257803 102.984 127.2883
114.990225 102.806 126.4041
115.722647 102.629 125.5304
116.455068 102.452 124.6671
117.187490 102.275 123.8139
117.919912 102.098 122.9709
118.652334 101.922 122.1378
119.384756 101.746 121.3145
120.117177 101.570 120.5009
120.849599 101.395 119.6969
121.582021 101.220 118.9023
122.314443 101.045 118.1171
123.046865 100.871 117.3411
123.779287 100.697 116.5742
124.511708 100.523 115.8162
125.244130 100.350 115.0670
125.976552 100.177 114.3265
126.708974 100.005 113.5947
127.441396 99.833 112.8713
128.173817 99.661 112.1562
128.906239 99.490 111.4494
129.638661 99.319 110.7507
130.371083 99.149 110.0601
131.103505 98.979 109.3773
131.835926 98.810 108.7023
132.568348 98.641 108.0350
133.300770 98.473 107.3753
134.033192 98.305 106.7230
134.765614 98.137 106.0780
135.498036 97.970 105.4404
136.230457 97.804 104.8098
136.962879 97.638 104.1863
137.695301 97.472 103.5698
138.427723 97.307 102.9601
139.160145 97.142 102.3571
139.892566 96.978 101.7607
140.624988 96.815 101.1710
141.357410 96.652 100.5877
142.089832 96.489 100.0107
142.822254 96.327 99.4401
143.554676 96.166 98.8755
144.287097 96.005 98.3171
145.019519 95.844 97.7648
145.751941 95.684 97.2183
146.484363 95.525 96.6777
147.216785 95.366 96.1427
147.949206 95.208 95.6135
148.681628 95.050 95.0899
149.414050 94.892 94.5718
150.146472 94.735 94.0591
150.878894 94.579 93.5518
151.611315 94.423 93.0497
152.343737 94.268 92.5529
153.076159 94.113 92.0612
153.808581 93.959 91.5745
154.541003 93.805 91.0928
155.273425 93.652 90.6161
156.005846 93.500 90.1441
156.738268 93.348 89.6770
157.470690 93.196 89.2146
158.203112 93.045 88.7568
158.935534 92.894 88.3036
159.667955 92.744 87.8550
160.400377 92.595 87.4108
161.132799 92.446 86.9709
161.865221 92.297 86.5354
162.597643 92.149 86.1042
163.330065 92.002 85.6772
164.062486 91.855 85.2544
164.794908 91.708 84.8357
165.527330 91.562 84.4210
166.259752 91.417 84.0103
166.992174 91.272 83.6035
167.724595 91.127 83.2006
168.457017 90.983 82.8016
169.189439 90.840 82.4062
169.921861 90.697 82.0147
170.654283 90.554 81.6268
171.386705 90.413 81.2426
172.119126 90.271 80.8619
172.851548 90.130 80.4847
173.583970 89.990 80.1110
174.316392 89.850 79.7408
175.048814 89.710 79.3740
175.781235 89.571 79.0105
176.513657 89.432 78.6502
177.246079 89.294 78.2933
177.978501 89.157 77.9396
178.710923 89.020 77.5890
179.443344 88.883 77.2416
180.175766 88.747 76.8972
180.908188 88.611 76.5559
181.640610 88.476 76.2177
182.373032 88.341 75.8824
183.105454 88.206 75.5500
183.837875 88.073 75.2206
184.570297 87.939 74.8940
185.302719 87.806 74.5703
186.035141 87.674 74.2493
186.767563 87.541 73.9311
187.499984 87.410 73.6156
188.232406 87.279 73.3028
188.964828 87.148 72.9927
189.697250 87.018 72.6853
190.429672 86.888 72.3804
191.162094 86.758 72.0781
191.894515 86.629 71.7783
192.626937 86.501 71.4810
193.359359 86.373 71.1862
194.091781 86.245 70.8938
194.824203 86.118 70.6038
195.556624 85.991 70.3162
196.289046 85.864 70.0310
197.021468 85.738 69.7480
197.753890 85.613 69.4674
198.486312 85.487 69.1891
199.218733 85.363 68.9129
199.951155 85.238 68.6390
200.683577 85.114 68.3673
201.415999 84.991 68.0976
202.148421 84.868 67.8302
202.880843 84.745 67.5648
203.613264 84.623 67.3016
204.345686 84.501 67.0404
205.078108 84.379 66.7812
205.810530 84.258 66.5240
206.542952 84.137 66.2689
207.275373 84.017 66.0157
208.007795 83.897 65.7645
208.740217 83.777 65.5152
209.472639 83.658 65.2678
210.205061 83.539 65.0223
210.937483 83.421 64.7786
211.669904 83.302 64.5368
212.402326 83.185 64.2968
213.134748 83.067 64.0587
213.867170 82.950 63.8223
214.599592 82.834 63.5876
215.332013 82.718 63.3547
216.064435 82.602 63.1235
216.796857 82.486 62.8941
217.529279 82.371 62.6663
218.261701 82.256 62.4402
218.994123 82.142 62.2157
219.726544 82.028 61.9928
220.458966 81.914 61.7715
221.191388 81.801 61.5518
221.923810 81.688 61.3338
222.656232 81.575 61.1172
223.388653 81.463 60.9022
224.121075 81.351 60.6887
224.853497 81.239 60.4767
225.585919 81.128 60.2662
226.318341 81.017 60.0572
227.050762 80.906 59.8497
227.783184 80.796 59.6436
228.515606 80.686 59.4389
229.248028 80.576 59.2357
229.980450 80.467 59.0339
230.712872 80.358 58.8335
231.445293 80.249 58.6345
232.177715 80.141 58.4369
232.910137 80.033 58.2405
233.642559 79.925 58.0456
234.374981 79.818 57.8519
235.107402 79.711 57.6596
235.839824 79.604 57.4685
236.572246 79.498 57.2788
237.304668 79.392 57.0903
238.037090 79.286 56.9030
238.769512 79.180 56.7170
239.501933 79.075 56.5322
240.234355 78.970 56.3486
240.966777 78.866 56.1663
241.699199 78.761 55.9850
242.431621 78.657 55.8049
243.164042 78.554 55.6261
243.896464 78.450 55.4484
244.628886 78.347 55.2718
245.361308 78.245 55.0964
246.093730 78.142 54.9221
246.826151 78.040 54.7489
247.558573 77.938 54.5768
248.290995 77.836 54.4059
249.023417 77.735 54.2360
249.755839 77.634 54.0672
250.488261 77.533 53.8995
251.220682 77.433 53.7329
251.953104 77.332 53.5672
252.685526 77.232 53.4027
253.417948 77.133 53.2392
254.150370 77.033 53.0767
254.882791 76.934 52.9152
255.615213 76.836 52.7547
256.347635 76.737 52.5951
257.080057 76.639 52.4366
257.812479 76.541 52.2790
258.544901 76.443 52.1223
259.277322 76.346 51.9666
260.009744 76.248 51.8118
260.742166 76.151 51.6579
261.474588 76.055 51.5050
262.207010 75.958 51.3529
262.939431 75.862 51.2018
263.671853 75.766 51.0515
264.404275 75.671 50.9021
265.136697 75.575 50.7537
265.869119 75.480 50.6061
266.601541 75.385 50.4594
267.333962 75.291 50.3136
268.066384 75.196 50.1686
268.798806 75.102 50.0246
269.531228 75.008 49.8813
270.263650 74.914 49.7389
270.996071 74.821 49.5974
271.728493 74.728 49.4567
272.460915 74.635 49.3168
273.193337 74.542 49.1777
273.925759 74.450 49.0394
274.658180 74.358 48.9020
275.390602 74.266 48.7653
276.123024 74.174 48.6293
276.855446 74.083 48.4941
277.587868 73.992 48.3596
278.320290 73.901 48.2257
279.052711 73.810 48.0927
279.785133 73.719 47.9604
280.517555 73.629 47.8287
281.249977 73.539 47.6978
281.982399 73.449 47.5675
282.714820 73.360 47.4379
283.447242 73.270 47.3091
284.179664 73.181 47.1808
284.912086 73.092 47.0533
285.644508 73.003 46.9265
286.376930 72.915 46.8004
287.109351 72.827 46.6751
287.841773 72.739 46.5504
288.574195 72.651 46.4264
289.306617 72.563 46.3032
290.039039 72.476 46.1806
290.771460 72.388 46.0588
291.503882 72.301 45.9376
292.236304 72.215 45.8171
292.968726 72.128 45.6973
293.701148 72.042 45.5781
294.433569 71.955 45.4596
295.165991 71.870 45.3418
295.898413 71.784 45.2245
296.630835 71.698 45.1079
297.363257 71.613 44.9919
298.095679 71.528 44.8765
298.828100 71.443 44.7617
299.560522 71.358 44.6474
300.292944 71.274 44.5337
301.025366 71.190 44.4205
301.757788 71.106 44.3079
302.490209 71.022 44.1957
303.222631 70.938 44.0843
303.955053 70.855 43.9732
304.687475 70.771 43.8628
305.419897 70.688 43.7529
306.152319 70.605 43.6436
306.884740 70.523 43.5347
307.617162 70.440 43.4264
308.349584 70.358 43.3187
309.082006 70.276 43.2116
309.814428 70.194 43.1051
310.546849 70.112 42.9991
311.279271 70.031 42.8936
312.011693 69.949 42.7887
312.744115 69.868 42.6844
313.476537 69.787 42.5806
314.208959 69.706 42.4774
314.941380 69.626 42.3745
315.673802 69.545 42.2724
316.406224 69.465 42.1707
317.138646 69.385 42.0694
317.871068 69.305 41.9686
318.603489 69.225 41.8685
319.335911 69.146 41.7687
320.068333 69.066 41.6693
320.800755 68.987 41.5703
321.533177 68.908 41.4718
322.265598 68.830 41.3738
322.998020 68.751 41.2762
323.730442 68.673 41.1790
324.462864 68.594 41.0823
325.195286 68.516 40.9860
325.927708 68.438 40.8900
326.660129 68.361 40.7948
327.392551 68.283 40.6997
328.124973 68.206 40.6055
328.857395 68.128 40.5115
329.589817 68.051 40.4179
330.322238 67.974 40.3248
331.054660 67.897 40.2322
331.787082 67.821 40.1401
332.519504 67.744 40.0485
333.251926 67.668 39.9574
333.984348 67.592 39.8666
334.716769 67.516 39.7763
335.449191 67.440 39.6864
336.181613 67.365 39.5969
336.914035 67.289 39.5078
337.646457 67.214 39.4193
338.378878 67.139 39.3309
339.111300 67.064 39.2430
339.843722 66.990 39.1554
340.576144 66.915 39.0681
341.308566 66.840 38.9813
342.040987 66.766 38.8947
342.773409 66.692 38.8085
343.505831 66.618 38.7227
344.238253 66.544 38.6371
344.970675 66.471 38.5521
345.703097 66.397 38.4674
346.435518 66.324 38.3829
347.167940 66.250 38.2991
347.900362 66.177 38.2155
348.632784 66.105 38.1324
349.365206 66.032 38.0497
350.097627 65.959 37.9672
350.830049 65.887 37.8852
351.562471 65.814 37.8037
352.294893 65.742 37.7226
353.027315 65.670 37.6420
353.759737 65.598 37.5615
354.492158 65.526 37.4817
355.224580 65.455 37.4021
355.957002 65.383 37.3227
356.689424 65.312 37.2438
357.421846 65.241 37.1650
358.154267 65.170 37.0869
358.886689 65.099 37.0089
359.619111 65.029 36.9311
360.351533 64.958 36.8537
361.083955 64.888 36.7765
361.816377 64.818 36.6995
362.548798 64.747 36.6228
363.281220 64.678 36.5465
364.013642 64.608 36.4705
364.746064 64.538 36.3948
365.478486 64.468 36.3189
366.210907 64.399 36.2438
366.943329 64.330 36.1692
367.675751 64.260 36.0945
368.408173 64.191 36.0202
369.140595 64.122 35.9465
369.873016 64.054 35.8733
370.605438 63.985 35.8004
371.337860 63.917 35.7272
372.070282 63.848 35.6550
372.802704 63.780 35.5831
373.535126 63.712 35.5113
374.267547 63.644 35.4400
374.999969 63.576 35.3690
375.732391 63.508 35.2984
376.464813 63.441 35.2280
377.197235 63.373 35.1575
377.929656 63.306 35.0877
378.662078 63.239 35.0177
379.394500 63.172 34.9479
380.126922 63.105 34.8785
380.859344 63.039 34.8095
381.591766 62.972 34.7411
382.324187 62.905 34.6725
383.056609 62.839 34.6033
383.789031 62.773 34.5353
384.521453 62.707 34.4671
385.253875 62.641 34.3991
385.986296 62.575 34.3313
386.718718 62.509 34.2641
387.451140 62.443 34.1967
388.183562 62.378 34.1302
388.915984 62.312 34.0632
389.648405 62.247 33.9971
390.380827 62.182 33.9315
391.113249 62.117 33.8658
391.845671 62.052 33.8008
392.578093 61.987 33.7364
393.310515 61.922 33.6721
394.042936 61.857 33.6082
394.775358 61.793 33.5441
395.507780 61.728 33.4809
396.240202 61.664 33.4179
396.972624 61.600 33.3549
397.705045 61.536 33.2923
398.437467 61.472 33.2302
399.169889 61.409 33.1685
399.902311 61.345 33.1066
400.634733 61.281 33.0444
401.367155 61.218 32.9832
402.099576 61.155 32.9215
402.831998 61.092 32.8604
403.564420 61.029 32.7987
404.296842 60.966 32.7379
405.029264 60.903 32.6770
405.761685 60.841 32.6166
406.494107 60.778 32.5557
407.226529 60.716 32.4957
407.958951 60.653 32.4353
408.691373 60.591 32.3753
409.423795 60.529 32.3154
410.156216 60.467 32.2564
410.888638 60.405 32.1973
411.621060 60.343 32.1386
412.353482 60.281 32.0796
413.085904 60.220 32.0211
413.818325 60.158 31.9631
414.550747 60.097 31.9053
415.283169 60.035 31.8477
416.015591 59.974 31.7903
416.748013 59.913 31.7333
417.480434 59.852 31.6766
418.212856 59.791 31.6198
418.945278 59.731 31.5634
419.677700 59.670 31.5070
420.410122 59.609 31.4510
421.142544 59.549 31.3951
421.874965 59.489 31.3392
422.607387 59.429 31.2828
423.339809 59.369 31.2276
424.072231 59.308 31.1720
424.804653 59.249 31.1172
425.537074 59.189 31.0620
426.269496 59.129 31.0073
427.001918 59.070 30.9525
427.734340 59.010 30.8980
428.466762 58.951 30.8432
429.199184 58.891 30.7893
429.931605 58.832 30.7357
430.664027 58.773 30.6821
431.396449 58.714 30.6286
432.128871 58.655 30.5759
432.861293 58.596 30.5230
433.593714 58.537 30.4701
434.326136 58.479 30.4181
435.058558 58.420 30.3656
435.790980 58.362 30.3141
436.523402 58.304 30.2621
437.255823 58.245 30.2104
437.988245 58.187 30.1593
438.720667 58.129 30.1079
439.453089 58.071 30.0565
440.185511 58.014 30.0055
440.917933 57.956 29.9544
441.650354 57.898 29.9039
442.382776 57.841 29.8531
443.115198 57.784 29.8024
443.847620 57.726 29.7524
444.580042 57.669 29.7022
445.312463 57.612 29.6516
446.044885 57.555 29.6014
446.777307 57.498 29.5512
447.509729 57.441 29.5021
448.242151 57.384 29.4525
448.974573 57.327 29.4030
449.706994 57.271 29.3546
450.439416 57.214 29.3058
451.171838 57.158 29.2567
451.904260 57.101 29.2084
452.636682 57.045 29.1594
453.369103 56.989 29.1124
454.101525 56.933 29.0644
454.833947 56.877 29.0168
455.566369 56.821 28.9703
456.298791 56.765 28.9230
457.031213 56.710 28.8754
457.763634 56.654 28.8279
458.496056 56.599 28.7811
459.228478 56.543 28.7356
459.960900 56.488 28.6884
460.693322 56.433 28.6416
461.425743 56.378 28.5959
462.158165 56.322 28.5497
462.890587 56.268 28.5033
463.623009 56.213 28.4566
464.355431 56.158 28.4102
465.087852 56.103 28.3656
465.820274 56.049 28.3193
466.552696 55.994 28.2733
467.285118 55.940 28.2286
468.017540 55.885 28.1829
468.749962 55.831 28.1376
469.482383 55.777 28.0921
470.214805 55.722 28.0467
470.947227 55.668 28.0034
471.679649 55.614 27.9585
472.412071 55.560 27.9144
473.144492 55.507 27.8710
473.876914 55.453 27.8274
474.609336 55.399 27.7834
475.341758 55.346 27.7395
476.074180 55.292 27.6953
476.806602 55.239 27.6535
477.539023 55.185 27.6104
478.271445 55.132 27.5671
479.003867 55.079 27.5253
479.736289 55.026 27.4824
480.468711 54.973 27.4391
481.201132 54.920 27.3967
481.933554 54.868 27.3538
482.665976 54.815 27.3121
483.398398 54.762 27.2693
484.130820 54.710 27.2266
484.863241 54.657 27.1849
485.595663 54.605 27.1428
486.328085 54.552 27.1002
487.060507 54.500 27.0580
487.792929 54.448 27.0162
488.525351 54.396 26.9752
489.257772 54.344 26.9335
489.990194 54.292 26.8925
490.722616 54.240 26.8513
491.455038 54.188 26.8099
492.187460 54.136 26.7696
492.919881 54.084 26.7289
493.652303 54.033 26.6882
494.384725 53.981 26.6494
495.117147 53.930 26.6091
495.849569 53.878 26.5695
496.581991 53.827 26.5301
497.314412 53.776 26.4910
498.046834 53.725 26.4518
498.779256 53.674 26.4130
499.511678 53.622 26.3739
500.244100 53.572 26.3357
500.976521 53.521 26.2968
501.708943 53.470 26.2581
502.441365 53.420 26.2199
503.173787 53.369 26.1815
503.906209 53.319 26.1427
504.638631 53.268 26.1044
505.371052 53.218 26.0659
506.103474 53.168 26.0274
506.835896 53.118 25.9895
507.568318 53.068 25.9510
508.300740 53.018 25.9128
509.033161 52.968 25.8752
509.765583 52.918 25.8369
510.498005 52.868 25.7988
511.230427 52.818 25.7607
511.962849 52.768 25.7231
512.695270 52.719 25.6852
513.427692 52.669 25.6479
514.160114 52.620 25.6100
514.892536 52.570 25.5728
515.624958 52.521 25.5353
516.357380 52.471 25.4986
517.089801 52.422 25.4614
517.822223 52.373 25.4249
518.554645 52.324 25.3875
519.287067 52.275 25.3517
520.019489 52.226 25.3149
520.751910 52.177 25.2786
521.484332 52.128 25.2426
522.216754 52.079 25.2073
522.949176 52.031 25.1714
523.681598 51.982 25.1353
524.414020 51.934 25.0995
525.146441 51.885 25.0644
525.878863 51.837 25.0286
526.611285 51.788 24.9932
527.343707 51.740 24.9586
528.076129 51.692 24.9234
528.808550 51.644 24.8887
529.540972 51.596 24.8525
530.273394 51.548 24.8184
531.005816 51.500 24.7832
531.738238 51.452 24.7491
532.470659 51.404 24.7141
533.203081 51.356 24.6796
533.935503 51.309 24.6452
534.667925 51.261 24.6111
535.400347 51.214 24.5764
536.132769 51.166 24.5426
536.865190 51.119 24.5087
537.597612 51.071 24.4740
538.330034 51.024 24.4396
539.062456 50.977 24.4065
539.794878 50.929 24.3730
540.527299 50.882 24.3400
541.259721 50.836 24.3063
541.992143 50.788 24.2718
542.724565 50.742 24.2394
543.456987 50.695 24.2053
544.189409 50.648 24.1719
544.921830 50.601 24.1396
545.654252 50.554 24.1057
546.386674 50.508 24.0745
547.119096 50.461 24.0408
547.851518 50.415 24.0079
548.583939 50.368 23.9756
549.316361 50.322 23.9424
550.048783 50.276 23.9097
550.781205 50.229 23.8782
551.513627 50.183 23.8462
552.246049 50.137 23.8140
552.978470 50.091 23.7816
553.710892 50.045 23.7501
554.443314 49.999 23.7184
555.175736 49.953 23.6863
555.908158 49.908 23.6539
556.640579 49.862 23.6224
557.373001 49.816 23.5912
558.105423 49.771 23.5601
558.837845 49.725 23.5276
559.570267 49.679 23.4973
560.302688 49.634 23.4656
561.035110 49.589 23.4351
561.767532 49.543 23.4037
562.499954 49.498 23.3729
563.232376 49.453 23.3428
563.964798 49.408 23.3127
564.697219 49.363 23.2812
565.429641 49.317 23.2506
566.162063 49.272 23.2203
566.894485 49.228 23.1901
567.626907 49.183 23.1595
568.359328 49.138 23.1292
569.091750 49.093 23.0989
569.824172 49.049 23.0703
570.556594 49.004 23.0403
571.289016 48.959 23.0094
572.021438 48.915 22.9806
572.753859 48.870 22.9486
573.486281 48.826 22.9197
574.218703 48.782 22.8907
574.951125 48.737 22.8604
575.683547 48.693 22.8308
576.415968 48.649 22.8016
577.148390 48.605 22.7726
577.880812 48.561 22.7441
578.613234 48.517 22.7140
579.345656 48.473 22.6844
580.078077 48.429 22.6564
580.810499 48.385 22.6281
581.542921 48.341 22.5984
582.275343 48.297 22.5698
583.007765 48.254 22.5415
583.740187 48.210 22.5125
584.472608 48.166 22.4854
585.205030 48.123 22.4572
585.937452 48.080 22.4281
586.669874 48.036 22.4004
587.402296 47.993 22.3732
588.134717 47.950 22.3434
588.867139 47.906 22.3163
589.599561 47.863 22.2876
590.331983 47.820 22.2592
591.064405 47.777 22.2329
591.796827 47.734 22.2046
592.529248 47.691 22.1769
593.261670 47.648 22.1488
593.994092 47.605 22.1218
594.726514 47.563 22.0936
595.458936 47.520 22.0660
596.191357 47.477 22.0368
596.923779 47.435 22.0103
597.656201 47.392 21.9840
598.388623 47.349 21.9564
599.121045 47.307 21.9293
599.853467 47.264 21.9022
600.585888 47.222 21.8754
601.318310 47.180 21.8497
602.050732 47.137 21.8215
602.783154 47.095 21.7959
603.515576 47.053 21.7697
604.247997 47.011 21.7429
604.980419 46.969 21.7167
605.712841 46.927 21.6908
606.445263 46.885 21.6651
607.177685 46.843 21.6384
607.910106 46.802 21.6113
608.642528 46.760 21.5855
609.374950 46.718 21.5600
610.107372 46.677 21.5327
610.839794 46.635 21.5061
611.572216 46.594 21.4782
612.304637 46.552 21.4524
613.037059 46.511 21.4253
613.769481 46.469 21.3977
614.501903 46.428 21.3715
615.234325 46.387 21.3440
615.966746 46.345 21.3162
616.699168 46.304 21.2889
617.431590 46.263 21.2621
618.164012 46.221 21.2352
618.896434 46.180 21.2084
619.628856 46.138 21.1817
620.361277 46.097 21.1560
621.093699 46.056 21.1306
621.826121 46.015 21.1053
622.558543 45.974 21.0802
623.290965 45.933 21.0565
624.023386 45.892 21.0309
624.755808 45.851 21.0081
625.488230 45.810 20.9820
626.220652 45.769 20.9597
626.953074 45.728 20.9359
627.685495 45.688 20.9120
628.417917 45.647 20.8896
629.150339 45.607 20.8664
629.882761 45.566 20.8431
630.615183 45.526 20.8212
631.347605 45.486 20.7955
632.080026 45.446 20.7746
632.812448 45.406 20.7498
633.544870 45.365 20.7263
634.277292 45.326 20.7012
635.009714 45.285 20.6777
635.742135 45.246 20.6542
636.474557 45.206 20.6297
637.206979 45.166 20.6041
637.939401 45.126 20.5803
638.671823 45.086 20.5561
639.404245 45.047 20.5328
640.136666 45.007 20.5073
640.869088 44.967 20.4836
641.601510 44.927 20.4595
642.333932 44.888 20.4347
643.066354 44.848 20.4119
643.798775 44.808 20.3876
644.531197 44.769 20.3645
645.263619 44.729 20.3408
645.996041 44.690 20.3187
646.728463 44.651 20.2953
647.460885 44.611 20.2709
648.193306 44.572 20.2475
648.925728 44.533 20.2253
649.658150 44.493 20.2033
650.390572 44.455 20.1813
651.122994 44.415 20.1571
651.855415 44.376 20.1338
652.587837 44.337 20.1122
653.320259 44.298 20.0880
654.052681 44.259 20.0664
654.785103 44.221 20.0409
655.517524 44.182 20.0189
656.249946 44.143 19.9963
656.982368 44.104 19.9740
657.714790 44.065 19.9493
658.447212 44.026 19.9295
659.179634 43.988 19.9061
659.912055 43.949 19.8839
660.644477 43.910 19.8605
661.376899 43.872 19.8391
662.109321 43.833 19.8181
662.841743 43.795 19.7970
663.574164 43.757 19.7743
664.306586 43.718 19.7518
665.039008 43.680 19.7327
665.771430 43.642 19.7104
666.503852 43.603 19.6912
667.236274 43.565 19.6687
667.968695 43.527 19.6459
668.701117 43.489 19.6273
669.433539 43.451 19.6055
670.165961 43.413 19.5826
670.898383 43.376 19.5615
671.630804 43.338 19.5378
672.363226 43.300 19.5198
673.095648 43.262 19.4965
673.828070 43.225 19.4747
674.560492 43.187 19.4530
675.292913 43.149 19.4310
676.025335 43.112 19.4094
676.757757 43.074 19.3860
677.490179 43.037 19.3658
678.222601 42.999 19.3434
678.955023 42.961 19.3223
679.687444 42.924 19.3010
680.419866 42.886 19.2791
681.152288 42.849 19.2593
681.884710 42.811 19.2407
682.617132 42.774 19.2173
683.349553 42.737 19.1984
684.081975 42.699 19.1780
684.814397 42.662 19.1587
685.546819 42.625 19.1395
686.279241 42.588 19.1191
687.011663 42.551 19.0998
687.744084 42.514 19.0798
688.476506 42.477 19.0594
689.208928 42.441 19.0399
689.941350 42.404 19.0217
690.673772 42.367 18.9991
691.406193 42.331 18.9784
692.138615 42.294 18.9590
692.871037 42.258 18.9379
693.603459 42.221 18.9147
694.335881 42.184 18.8926
695.068303 42.148 18.8693
695.800724 42.111 18.8514
696.533146 42.075 18.8292
697.265568 42.039 18.8066
697.997990 42.002 18.7858
698.730412 41.965 18.7679
699.462833 41.929 18.7451
700.195255 41.892 18.7256
700.927677 41.856 18.7041
701.660099 41.819 18.6848
702.392521 41.783 18.6650
703.124942 41.746 18.6424
703.857364 41.710 18.6203
704.589786 41.673 18.6033
705.322208 41.638 18.5854
706.054630 41.601 18.5652
706.787052 41.565 18.5483
707.519473 41.529 18.5294
708.251895 41.494 18.5109
708.984317 41.458 18.4915
709.716739 41.422 18.4720
710.449161 41.387 18.4520
711.181582 41.351 18.4346
711.914004 41.316 18.4130
712.646426 41.280 18.3936
713.378848 41.244 18.3730
714.111270 41.209 18.3494
714.843692 41.173 18.3307
715.576113 41.138 18.3104
716.308535 41.102 18.2897
717.040957 41.066 18.2679
717.773379 41.031 18.2474
718.505801 40.995 18.2266
719.238222 40.959 18.2064
719.970644 40.923 18.1877
720.703066 40.888 18.1683
721.435488 40.852 18.1485
722.167910 40.816 18.1295
722.900331 40.781 18.1110
723.632753 40.745 18.0967
724.365175 40.709 18.0756
725.097597 40.674 18.0601
725.830019 40.638 18.0453
726.562441 40.603 18.0310
727.294862 40.568 18.0157
728.027284 40.533 18.0006
728.759706 40.499 17.9855
729.492128 40.463 17.9688
730.224550 40.429 17.9526
730.956971 40.395 17.9384
731.689393 40.360 17.9209
732.421815 40.325 17.9041
733.154237 40.291 17.8909
733.886659 40.256 17.8697
734.619081 40.222 17.8542
735.351502 40.188 17.8361
736.083924 40.153 17.8196
736.816346 40.119 17.7985
737.548768 40.085 17.7832
738.281190 40.050 17.7627
739.013611 40.016 17.7477
739.746033 39.982 17.7250
740.478455 39.947 17.7062
741.210877 39.913 17.6885
741.943299 39.878 17.6732
742.675721 39.845 17.6520
743.408142 39.810 17.6349
744.140564 39.776 17.6152
744.872986 39.742 17.6003
745.605408 39.708 17.5797
746.337830 39.674 17.5623
747.070251 39.639 17.5446
747.802673 39.606 17.5260
748.535095 39.572 17.5106
749.267517 39.537 17.4901
749.999939 39.504 17.4747
750.732360 39.470 17.4574
751.464782 39.436 17.4432
752.197204 39.403 17.4204
752.929626 39.368 17.4060
753.662048 39.334 17.3876
754.394470 39.300 17.3702
755.126891 39.266 17.3536
755.859313 39.232 17.3361
756.591735 39.200 17.3168
757.324157 39.166 17.3007
758.056579 39.132 17.2840
758.789000 39.098 17.2676
759.521422 39.065 17.2521
760.253844 39.031 17.2352
760.986266 38.998 17.2200
761.718688 38.964 17.2051
762.451110 38.930 17.1935
763.183531 38.896 17.1754
763.915953 38.864 17.1615
764.648375 38.830 17.1495
765.380797 38.797 17.1345
766.113219 38.764 17.1146
766.845640 38.732 17.1006
767.578062 38.699 17.0839
768.310484 38.666 17.0662
769.042906 38.633 17.0487
769.775328 38.600 17.0350
770.507749 38.568 17.0181
771.240171 38.535 17.0011
771.972593 38.502 16.9800
772.705015 38.469 16.9606
773.437437 38.437 16.9446
774.169859 38.404 16.9220
774.902280 38.371 16.8995
775.634702 38.338 16.8817
776.367124 38.305 16.8645
777.099546 38.272 16.8441
777.831968 38.239 16.8262
778.564389 38.206 16.8098
779.296811 38.173 16.7943
780.029233 38.140 16.7778
780.761655 38.107 16.7595
781.494077 38.074 16.7500
782.226499 38.041 16.7306
782.958920 38.008 16.7185
783.691342 37.975 16.7059
784.423764 37.943 16.6901
785.156186 37.910 16.6799
785.888608 37.878 16.6664
786.621029 37.845 16.6513
787.353451 37.814 16.6390
788.085873 37.781 16.6279
788.818295 37.749 16.6084
789.550717 37.717 16.5946
790.283139 37.685 16.5781
791.015560 37.653 16.5624
791.747982 37.622 16.5464
792.480404 37.590 16.5292
793.212826 37.559 16.5159
793.945248 37.526 16.4968
794.677669 37.493 16.4753
795.410091 37.463 16.4615
796.142513 37.429 16.4421
796.874935 37.398 16.4260
797.607357 37.368 16.4138
798.339778 37.335 16.3955
799.072200 37.303 16.3795
799.804622 37.271 16.3625
800.537044 37.238 16.3470
801.269466 37.205 16.3326
802.001888 37.174 16.3241
802.734309 37.142 16.3090
803.466731 37.111 16.2898
804.199153 37.078 16.2778
804.931575 37.047 16.2689
805.663997 37.015 16.2531
806.396418 36.984 16.2408
807.128840 36.952 16.2266
807.861262 36.921 16.2134
808.593684 36.889 16.2004
809.326106 36.859 16.1871
810.058528 36.826 16.1727
810.790949 36.796 16.1609
811.523371 36.765 16.1437
812.255793 36.734 16.1307
812.988215 36.702 16.1168
813.720637 36.671 16.0975
814.453058 36.640 16.0812
815.185480 36.609 16.0647
815.917902 36.577 16.0503
816.650324 36.546 16.0317
817.382746 36.515 16.0153
818.115167 36.484 15.9969
818.847589 36.452 15.9922
819.580011 36.420 15.9718
820.312433 36.390 15.9547
821.044855 36.358 15.9395
821.777277 36.327 15.9269
822.509698 36.296 15.9139
823.242120 36.264 15.9009
823.974542 36.233 15.8846
824.706964 36.202 15.8782
825.439386 36.172 15.8680
826.171807 36.140 15.8558
826.904229 36.110 15.8416
827.636651 36.079 15.8312
828.369073 36.049 15.8202
829.101495 36.018 15.8086
829.833917 35.988 15.7930
830.566338 35.958 15.7848
831.298760 35.927 15.7743
832.031182 35.897 15.7595
832.763604 35.867 15.7429
833.496026 35.837 15.7325
834.228447 35.807 15.7164
834.960869 35.777 15.6991
835.693291 35.746 15.6854
836.425713 35.717 15.6758
837.158135 35.686 15.6595
837.890557 35.655 15.6425
838.622978 35.625 15.6251
839.355400 35.594 15.6093
840.087822 35.565 15.5940
840.820244 35.535 15.5852
841.552666 35.504 15.5690
842.285087 35.474 15.5555
843.017509 35.444 15.5449
843.749931 35.413 15.5253
844.482353 35.382 15.5078
845.214775 35.352 15.4980
845.947196 35.322 15.4807
846.679618 35.293 15.4669
847.412040 35.263 15.4519
848.144462 35.234 15.4410
848.876884 35.204 15.4243
849.609306 35.173 15.4077
850.341727 35.143 15.3912
851.074149 35.113 15.3779
851.806571 35.083 15.3634
852.538993 35.053 15.3477
853.271415 35.023 15.3267
854.003836 34.993 15.3165
854.736258 34.963 15.3005
855.468680 34.932 15.2856
856.201102 34.903 15.2690
856.933524 34.872 15.2618
857.665946 34.843 15.2467
858.398367 34.813 15.2332
859.130789 34.782 15.2208
859.863211 34.753 15.2123
860.595633 34.723 15.2008
861.328055 34.693 15.1946
862.060476 34.663 15.1827
862.792898 34.634 15.1771
863.525320 34.605 15.1613
864.257742 34.576 15.1523
864.990164 34.546 15.1413
865.722585 34.519 15.1293
866.455007 34.489 15.1228
867.187429 34.460 15.1107
867.919851 34.431 15.0989
868.652273 34.403 15.0901
869.384695 34.373 15.0689
870.117116 34.345 15.0559
870.849538 34.316 15.0388
871.581960 34.288 15.0214
872.314382 34.258 15.0050
873.046804 34.229 14.9888
873.779225 34.200 14.9706
874.511647 34.171 14.9534
875.244069 34.141 14.9342
875.976491 34.112 14.9185
876.708913 34.082 14.9024
877.441335 34.052 14.8857
878.173756 34.023 14.8722
878.906178 33.993 14.8565
879.638600 33.963 14.8468
880.371022 33.934 14.8323
881.103444 33.905 14.8227
881.835865 33.875 14.8126
882.568287 33.846 14.8033
883.300709 33.818 14.7888
884.033131 33.788 14.7858
884.765553 33.759 14.7829
885.497975 33.730 14.7791
886.230396 33.702 14.7671
886.962818 33.673 14.7505
887.695240 33.645 14.7385
888.427662 33.616 14.7305
889.160084 33.589 14.7153
889.892505 33.561 14.7045
890.624927 33.532 14.7001
891.357349 33.504 14.6914
892.089771 33.477 14.6703
892.822193 33.448 14.6622
893.554614 33.419 14.6425
894.287036 33.390 14.6277
895.019458 33.363 14.6063
895.751880 33.334 14.5936
896.484302 33.305 14.5815
897.216724 33.276 14.5720
897.949145 33.248 14.5582
898.681567 33.218 14.5445
899.413989 33.190 14.5356
900.146411 33.161 14.5218
900.878833 33.132 14.5118
901.611254 33.103 14.5042
902.343676 33.075 14.4988
903.076098 33.045 14.4913
903.808520 33.018 14.4855
904.540942 32.990 14.4720
905.273364 32.961 14.4631
906.005785 32.934 14.4559
906.738207 32.906 14.4421
907.470629 32.879 14.4363
908.203051 32.851 14.4272
908.935473 32.824 14.4177
909.667894 32.796 14.4032
910.400316 32.769 14.3921
911.132738 32.741 14.3813
911.865160 32.714 14.3700
912.597582 32.686 14.3356
913.330003 32.660 14.3344
914.062425 32.632 14.3203
914.794847 32.605 14.3054
915.527269 32.578 14.2858
916.259691 32.549 14.2767
916.992113 32.520 14.2610
917.724534 32.492 14.2482
918.456956 32.464 14.2287
919.189378 32.435 14.2257
919.921800 32.408 14.2089
920.654222 32.379 14.1992
921.386643 32.351 14.1916
922.119065 32.323 14.1829
922.851487 32.294 14.1765
923.583909 32.267 14.1678
924.316331 32.239 14.1594
925.048753 32.211 14.1536
925.781174 32.183 14.1443
926.513596 32.156 14.1427
927.246018 32.129 14.1334
927.978440 32.102 14.1231
928.710862 32.076 14.1156
929.443283 32.049 14.1027
930.175705 32.020 14.0925
930.908127 31.995 14.0828
931.640549 31.969 14.0732
932.372971 31.943 14.0598
933.105393 31.916 14.0452
933.837814 31.888 14.0373
934.570236 31.861 14.0214
935.302658 31.834 14.0051
936.035080 31.807 13.9849
936.767502 31.780 13.9764
937.499923 31.753 13.9595
938.232345 31.727 13.9426
938.964767 31.699 13.9271
939.697189 31.672 13.9173
940.429611 31.644 13.9090
941.162032 31.617 13.9027
941.894454 31.589 13.8795
942.626876 31.562 13.8761
943.359298 31.535 13.8632
944.091720 31.508 13.8466
944.824142 31.481 13.8412
945.556563 31.455 13.8251
946.288985 31.428 13.8168
947.021407 31.401 13.8063
947.753829 31.374 13.7960
948.486251 31.348 13.7875
949.218672 31.321 13.7656
949.951094 31.294 13.7590
950.683516 31.268 13.7456
951.415938 31.240 13.7291
952.148360 31.214 13.7188
952.880782 31.186 13.7020
953.613203 31.158 13.6935
954.345625 31.132 13.6843
955.078047 31.105 13.6676
955.810469 31.077 13.6588
956.542891 31.049 13.6482
957.275312 31.022 13.6436
958.007734 30.996 13.6285
958.740156 30.968 13.6193
959.472578 30.939 13.6186
960.205000 30.914 13.6105
960.937422 30.887 13.6034
961.669843 30.860 13.5959
962.402265 30.832 13.5880
963.134687 30.808 13.5916
963.867109 30.781 13.5894
964.599531 30.755 13.5791
965.331952 30.728 13.5763
966.064374 30.704 13.5693
966.796796 30.678 13.5623
967.529218 30.653 13.5538
968.261640 30.628 13.5498
968.994061 30.603 13.5343
969.726483 30.577 13.5162
970.458905 30.552 13.5124
971.191327 30.527 13.4974
971.923749 30.501 13.4832
972.656171 30.475 13.4678
973.388592 30.450 13.4521
974.121014 30.424 13.4378
974.853436 30.396 13.4200
975.585858 30.371 13.4008
976.318280 30.344 13.3875
977.050701 30.317 13.3831
977.783123 30.292 13.3682
978.515545 30.264 13.3505
979.247967 30.237 13.3375
979.980389 30.210 13.3292
980.712811 30.185 13.3246
981.445232 30.158 13.3193
982.177654 30.131 13.3136
982.910076 30.104 13.3096
983.642498 30.079 13.3009
984.374920 30.052 13.2914
985.107341 30.026 13.2870
985.839763 30.001 13.2838
986.572185 29.976 13.2739
987.304607 29.950 13.2699
988.037029 29.926 13.2639
988.769450 29.900 13.2578
989.501872 29.875 13.2378
990.234294 29.850 13.2315
990.966716 29.824 13.2158
991.699138 29.800 13.2103
992.431560 29.774 13.1899
993.163981 29.749 13.1711
993.896403 29.723 13.1652
994.628825 29.699 13.1499
995.361247 29.672 13.1302
996.093669 29.646 13.1228
996.826090 29.621 13.1057
997.558512 29.596 13.0908
998.290934 29.569 13.0872
999.023356 29.543 13.0708
999.755778 29.516 13.0654
1000.488200 29.491 13.0607
1001.220621 29.465 13.0479
1001.953043 29.439 13.0387
1002.685465 29.413 13.0381
1003.417887 29.388 13.0317
1004.150309 29.362 13.0216
1004.882730 29.336 13.0153
1005.615152 29.311 13.0110
1006.347574 29.286 13.0166
1007.079996 29.262 13.0012
1007.812418 29.236 12.9907
1008.544840 29.210 12.9867
1009.277261 29.186 12.9838
1010.009683 29.162 12.9648
1010.742105 29.136 12.9599
1011.474527 29.113 12.9474
1012.206949 29.087 12.9382
1012.939370 29.062 12.9176
1013.671792 29.038 12.9099
1014.404214 29.013 12.8942
1015.136636 28.989 12.8781
1015.869058 28.963 12.8710
1016.601479 28.937 12.8551
1017.333901 28.913 12.8505
1018.066323 28.887 12.8289
1018.798745 28.861 12.8220
1019.531167 28.837 12.8113
1020.263589 28.812 12.7988
1020.996010 28.787 12.7908
1021.728432 28.761 12.7860
1022.460854 28.735 12.7815
1023.193276 28.711 12.7798
1023.925698 28.687 12.7657
1024.658119 28.661 12.7565
1025.390541 28.635 12.7571
1026.122963 28.611 12.7522
1026.855385 28.586 12.7371
1027.587807 28.563 12.7323
1028.320229 28.538 12.7217
1029.052650 28.515 12.7162
1029.785072 28.489 12.7153
1030.517494 28.465 12.6963
1031.249916 28.441 12.6879
1031.982338 28.417 12.6832
1032.714759 28.394 12.6708
1033.447181 28.369 12.6537
1034.179603 28.345 12.6425
1034.912025 28.320 12.6237
1035.644447 28.296 12.6143
1036.376868 28.269 12.6057
1037.109290 28.246 12.5916
1037.841712 28.220 12.5828
1038.574134 28.196 12.5679
1039.306556 28.170 12.5676
1040.038978 28.145 12.5542
1040.771399 28.121 12.5427
1041.503821 28.095 12.5284
1042.236243 28.070 12.5222
1042.968665 28.046 12.5166
1043.701087 28.022 12.5024
1044.433508 27.997 12.4923
1045.165930 27.972 12.4982
1045.898352 27.947 12.4862
1046.630774 27.924 12.4780
1047.363196 27.899 12.4609
1048.095618 27.874 12.4548
1048.828039 27.850 12.4526
1049.560461 27.828 12.4422
1050.292883 27.802 12.4360
1051.025305 27.778 12.4211
1051.757727 27.754 12.4227
1052.490148 27.730 12.4050
1053.222570 27.707 12.4015
1053.954992 27.681 12.3861
1054.687414 27.656 12.3790
1055.419836 27.632 12.3800
1056.152258 27.610 12.3683
1056.884679 27.583 12.3561
1057.617101 27.558 12.3588
1058.349523 27.534 12.3448
1059.081945 27.511 12.3376
1059.814367 27.485 12.3423
1060.546788 27.462 12.3251
1061.279210 27.436 12.3264
1062.011632 27.411 12.3148
1062.744054 27.389 12.3185
1063.476476 27.366 12.3199
1064.208897 27.343 12.3022
1064.941319 27.318 12.2968
1065.673741 27.294 12.3005
1066.406163 27.272 12.2946
1067.138585 27.249 12.2872
1067.871007 27.224 12.2746
1068.603428 27.202 12.2695
1069.335850 27.180 12.2653
1070.068272 27.158 12.2551
1070.800694 27.134 12.2422
1071.533116 27.109 12.2283
1072.265537 27.088 12.2163
1072.997959 27.065 12.1910
1073.730381 27.041 12.1863
1074.462803 27.019 12.1801
1075.195225 26.994 12.1649
1075.927647 26.970 12.1328
1076.660068 26.947 12.1377
1077.392490 26.923 12.1113
1078.124912 26.899 12.1104
1078.857334 26.875 12.0874
1079.589756 26.850 12.0828
1080.322177 26.824 12.0683
1081.054599 26.802 12.0706
1081.787021 26.778 12.0466
1082.519443 26.752 12.0475
1083.251865 26.729 12.0391
1083.984286 26.705 12.0280
1084.716708 26.680 12.0223
1085.449130 26.657 12.0204
1086.181552 26.634 12.0165
1086.913974 26.609 12.0153
1087.646396 26.585 11.9890
1088.378817 26.561 11.9966
1089.111239 26.539 12.0039
1089.843661 26.515 11.9911
1090.576083 26.491 11.9822
1091.308505 26.467 11.9862
1092.040926 26.446 11.9709
1092.773348 26.421 11.9802
1093.505770 26.399 11.9597
1094.238192 26.376 11.9618
1094.970614 26.352 11.9554
1095.703036 26.331 11.9482
1096.435457 26.307 11.9252
1097.167879 26.284 11.9207
1097.900301 26.262 11.9171
1098.632723 26.239 11.9230
1099.365145 26.215 11.8987
1100.097566 26.194 11.8936
1100.829988 26.171 11.8887
1101.562410 26.148 11.8821
1102.294832 26.125 11.8574
1103.027254 26.103 11.8596
1103.759676 26.079 11.8477
1104.492097 26.058 11.8334
1105.224519 26.033 11.8257
1105.956941 26.010 11.8192
1106.689363 25.988 11.8154
1107.421785 25.963 11.8079
1108.154206 25.941 11.7942
1108.886628 25.918 11.7987
1109.619050 25.895 11.7694
1110.351472 25.872 11.7657
1111.083894 25.848 11.7462
1111.816315 25.825 11.7467
1112.548737 25.803 11.7449
1113.281159 25.779 11.7354
1114.013581 25.756 11.7195
1114.746003 25.733 11.7206
1115.478425 25.712 11.7023
1116.210846 25.689 11.7107
1116.943268 25.664 11.6956
1117.675690 25.643 11.6940
1118.408112 25.620 11.6923
1119.140534 25.597 11.6729
1119.872955 25.572 11.6663
1120.605377 25.552 11.6729
1121.337799 25.527 11.6577
1122.070221 25.508 11.6481
1122.802643 25.483 11.6369
1123.535065 25.461 11.6209
1124.267486 25.438 11.6198
1124.999908 25.416 11.6084
1125.732330 25.392 11.5992
1126.464752 25.370 11.5844
1127.197174 25.347 11.5867
1127.929595 25.326 11.5778
1128.662017 25.301 11.5808
1129.394439 25.280 11.5638
1130.126861 25.256 11.5441
1130.859283 25.232 11.5482
1131.591704 25.211 11.5479
1132.324126 25.188 11.5431
1133.056548 25.164 11.5228
1133.788970 25.144 11.5303
1134.521392 25.117 11.5134
1135.253814 25.096 11.5150
1135.986235 25.075 11.4971
1136.718657 25.050 11.4951
1137.451079 25.029 11.5011
1138.183501 25.005 11.5040
1138.915923 24.984 11.4812
1139.648344 24.964 11.4731
1140.380766 24.938 11.4713
1141.113188 24.920 11.4674
1141.845610 24.897 11.4664
1142.578032 24.874 11.4564
1143.310454 24.850 11.4636
1144.042875 24.829 11.4456
1144.775297 24.806 11.4429
1145.507719 24.784 11.4172
1146.240141 24.764 11.4291
1146.972563 24.741 11.4258
1147.704984 24.719 11.4241
1148.437406 24.697 11.4097
1149.169828 24.675 11.3994
1149.902250 24.653 11.3976
1150.634672 24.631 11.3965
1151.367094 24.610 11.3749
1152.099515 24.587 11.3784
1152.831937 24.566 11.3838
1153.564359 24.544 11.3712
1154.296781 24.522 11.3604
1155.029203 24.504 11.3488
1155.761624 24.481 11.3382
1156.494046 24.458 11.3380
1157.226468 24.438 11.3149
1157.958890 24.412 11.3221
1158.691312 24.395 11.3198
1159.423733 24.372 11.3007
1160.156155 24.348 11.2826
1160.888577 24.328 11.2871
1161.620999 24.307 11.2778
1162.353421 24.283 11.2626
1163.085843 24.263 11.2546
1163.818264 24.239 11.2516
1164.550686 24.219 11.2377
1165.283108 24.196 11.2386
1166.015530 24.176 11.2175
1166.747952 24.154 11.2349
1167.480373 24.133 11.2009
1168.212795 24.108 11.2047
1168.945217 24.087 11.1848
1169.677639 24.068 11.1909
1170.410061 24.045 11.1781
1171.142483 24.023 11.1862
1171.874904 24.002 11.1733
1172.607326 23.981 11.1624
1173.339748 23.959 11.1570
1174.072170 23.939 11.1541
1174.804592 23.915 11.1274
1175.537013 23.893 11.1337
1176.269435 23.877 11.1080
1177.001857 23.853 11.0984
1177.734279 23.834 11.0853
1178.466701 23.812 11.0653
1179.199122 23.791 11.0557
1179.931544 23.767 11.0538
1180.663966 23.746 11.0104
1181.396388 23.724 11.0221
1182.128810 23.703 11.0067
1182.861232 23.677 10.9807
1183.593653 23.655 10.9717
1184.326075 23.635 10.9717
1185.058497 23.611 10.9592
1185.790919 23.586 10.9604
1186.523341 23.562 10.9368
1187.255762 23.540 10.9489
1187.988184 23.517 10.9400
1188.720606 23.495 10.9440
1189.453028 23.472 10.9447
1190.185450 23.450 10.9602
1190.917872 23.428 10.9569
1191.650293 23.404 10.9679
1192.382715 23.383 10.9718
1193.115137 23.365 10.9706
1193.847559 23.343 10.9819
1194.579981 23.320 10.9958
1195.312402 23.301 10.9889
1196.044824 23.283 10.9857
1196.777246 23.262 10.9823
1197.509668 23.246 10.9955
1198.242090 23.222 10.9899
1198.974512 23.206 10.9841
1199.706933 23.187 10.9613
1200.439355 23.167 10.9606
1201.171777 23.149 10.9327
1201.904199 23.129 10.9200
1202.636621 23.107 10.8861
1203.369042 23.086 10.8885
1204.101464 23.066 10.8579
1204.833886 23.046 10.8558
1205.566308 23.027 10.8263
1206.298730 23.003 10.7948
1207.031151 22.980 10.7862
1207.763573 22.960 10.7770
1208.495995 22.936 10.7557
1209.228417 22.911 10.7540
1209.960839 22.891 10.7300
1210.693261 22.869 10.7292
1211.425682 22.844 10.7190
1212.158104 22.823 10.7303
1212.890526 22.797 10.7251
1213.622948 22.778 10.7111
1214.355370 22.754 10.7171
1215.087791 22.734 10.7217
1215.820213 22.712 10.7299
1216.552635 22.692 10.7238
1217.285057 22.669 10.7264
1218.017479 22.650 10.7285
1218.749901 22.630 10.7263
1219.482322 22.611 10.7157
1220.214744 22.592 10.7212
1220.947166 22.571 10.7120
1221.679588 22.551 10.7144
1222.412010 22.534 10.6832
1223.144431 22.513 10.6800
1223.876853 22.494 10.6694
1224.609275 22.472 10.6614
1225.341697 22.452 10.6449
1226.074119 22.428 10.6411
1226.806540 22.409 10.6357
1227.538962 22.386 10.6065
1228.271384 22.367 10.6127
1229.003806 22.346 10.5797
1229.736228 22.324 10.5914
1230.468650 22.302 10.5802
1231.201071 22.282 10.5632
1231.933493 22.259 10.5588
1232.665915 22.239 10.5532
1233.398337 22.216 10.5635
1234.130759 22.197 10.5527
1234.863180 22.175 10.5438
1235.595602 22.155 10.5538
1236.328024 22.134 10.5536
1237.060446 22.114 10.5475
1237.792868 22.093 10.5530
1238.525290 22.074 10.5495
1239.257711 22.052 10.5543
1239.990133 22.033 10.5405
1240.722555 22.012 10.5438
1241.454977 21.993 10.5475
1242.187399 21.972 10.5438
1242.919820 21.951 10.5433
1243.652242 21.928 10.5479
1244.384664 21.913 10.5283
1245.117086 21.892 10.5295
1245.849508 21.871 10.5242
1246.581930 21.850 10.5004
1247.314351 21.831 10.4982
1248.046773 21.809 10.4945
1248.779195 21.791 10.4783
1249.511617 21.769 10.4995
1250.244039 21.752 10.4819
1250.976460 21.731 10.4717
1251.708882 21.714 10.4662
1252.441304 21.690 10.4365
1253.173726 21.669 10.4408
1253.906148 21.653 10.4408
1254.638569 21.632 10.4313
1255.370991 21.612 10.4230
1256.103413 21.593 10.4279
1256.835835 21.571 10.4167
1257.568257 21.555 10.4005
1258.300679 21.532 10.3830
1259.033100 21.515 10.3724
1259.765522 21.494 10.3832
1260.497944 21.473 10.3590
1261.230366 21.451 10.3654
1261.962788 21.435 10.3315
1262.695209 21.414 10.3224
1263.427631 21.393 10.3024
1264.160053 21.371 10.2938
1264.892475 21.351 10.2856
1265.624897 21.330 10.2910
1266.357319 21.310 10.2748
1267.089740 21.288 10.2865
1267.822162 21.267 10.2706
1268.554584 21.248 10.2694
1269.287006 21.227 10.2498
1270.019428 21.203 10.2539
1270.751849 21.185 10.2373
1271.484271 21.165 10.2535
1272.216693 21.143 10.2287
1272.949115 21.125 10.2432
1273.681537 21.104 10.2416
1274.413958 21.084 10.2413
1275.146380 21.068 10.2086
1275.878802 21.045 10.2040
1276.611224 21.028 10.2037
1277.343646 21.007 10.2018
1278.076068 20.986 10.1833
1278.808489 20.968 10.1838
1279.540911 20.947 10.1371
1280.273333 20.930 10.1401
1281.005755 20.907 10.1232
1281.738177 20.885 10.1221
1282.470598 20.867 10.0708
1283.203020 20.843 10.0860
1283.935442 20.820 10.0743
1284.667864 20.800 10.0831
1285.400286 20.778 10.0546
1286.132708 20.756 10.0621
1286.865129 20.732 10.0517
1287.597551 20.712 10.0724
1288.329973 20.693 10.0455
1289.062395 20.672 10.0815
1289.794817 20.651 10.0925
1290.527238 20.634 10.1238
1291.259660 20.612 10.0986
1291.992082 20.591 10.1270
1292.724504 20.573 10.1406
1293.456926 20.552 10.1522
1294.189348 20.534 10.1589
1294.921769 20.518 10.1709
1295.654191 20.498 10.1586
1296.386613 20.484 10.1920
1297.119035 20.467 10.1670
1297.851457 20.450 10.1855
1298.583878 20.432 10.1656
1299.316300 20.415 10.1427
1300.048722 20.398 10.1396
1300.781144 20.381 10.1048
1301.513566 20.360 10.0919
1302.245987 20.343 10.0801
1302.978409 20.323 10.0364
1303.710831 20.305 10.0262
1304.443253 20.285 10.0128
1305.175675 20.266 9.9939
1305.908097 20.243 9.9485
1306.640518 20.227 9.9435
1307.372940 20.206 9.9240
1308.105362 20.184 9.9275
1308.837784 20.161 9.9001
1309.570206 20.137 9.8922
1310.302627 20.114 9.8945
1311.035049 20.096 9.8994
1311.767471 20.074 9.9023
1312.499893 20.053 9.8967
1313.232315 20.031 9.9057
1313.964737 20.010 9.9133
1314.697158 19.991 9.9174
1315.429580 19.971 9.9254
1316.162002 19.950 9.9366
1316.894424 19.930 9.9520
1317.626846 19.912 9.9547
1318.359267 19.896 9.9440
1319.091689 19.878 9.9552
1319.824111 19.866 9.9341
1320.556533 19.845 9.9366
1321.288955 19.828 9.9406
1322.021376 19.805 9.9240
1322.753798 19.788 9.9329
1323.486220 19.770 9.9070
1324.218642 19.755 9.8707
1324.951064 19.731 9.8835
1325.683486 19.716 9.8566
1326.415907 19.693 9.8619
1327.148329 19.676 9.8427
1327.880751 19.654 9.8395
1328.613173 19.635 9.8317
1329.345595 19.611 9.8369
1330.078016 19.594 9.8397
1330.810438 19.574 9.8172
1331.542860 19.557 9.8226
1332.275282 19.534 9.8123
1333.007704 19.515 9.8088
1333.740126 19.495 9.8060
1334.472547 19.478 9.8321
1335.204969 19.458 9.8113
1335.937391 19.440 9.8130
1336.669813 19.421 9.8024
1337.402235 19.408 9.7880
1338.134656 19.385 9.8022
1338.867078 19.369 9.8037
1339.599500 19.349 9.7936
1340.331922 19.333 9.8025
1341.064344 19.317 9.7836
1341.796766 19.296 9.7653
1342.529187 19.277 9.7885
1343.261609 19.264 9.7410
1343.994031 19.242 9.7629
1344.726453 19.226 9.7427
1345.458875 19.205 9.7389
1346.191296 19.187 9.7341
1346.923718 19.170 9.7300
1347.656140 19.150 9.7106
1348.388562 19.129 9.7021
1349.120984 19.113 9.6766
1349.853405 19.091 9.6923
1350.585827 19.074 9.6766
1351.318249 19.056 9.6426
1352.050671 19.038 9.6609
1352.783093 19.017 9.6565
1353.515515 19.000 9.6160
1354.247936 18.981 9.6219
1354.980358 18.967 9.5846
1355.712780 18.940 9.6185
1356.445202 18.927 9.5851
1357.177624 18.906 9.5897
1357.910045 18.892 9.5535
1358.642467 18.870 9.5465
1359.374889 18.850 9.5278
1360.107311 18.830 9.5379
1360.839733 18.809 9.4943
1361.572155 18.787 9.5184
1362.304576 18.770 9.4686
1363.036998 18.747 9.4890
1363.769420 18.728 9.4788
1364.501842 18.711 9.4634
1365.234264 18.687 9.4662
1365.966685 18.669 9.4746
1366.699107 18.647 9.4504
1367.431529 18.627 9.4476
1368.163951 18.609 9.4467
1368.896373 18.586 9.4746
1369.628794 18.568 9.4774
1370.361216 18.548 9.4784
1371.093638 18.529 9.4821
1371.826060 18.512 9.4905
1372.558482 18.490 9.4718
1373.290904 18.475 9.5168
1374.023325 18.456 9.5092
1374.755747 18.437 9.4879
1375.488169 18.421 9.4731
1376.220591 18.404 9.5185
1376.953013 18.388 9.4729
1377.685434 18.368 9.4882
1378.417856 18.352 9.4515
1379.150278 18.333 9.4543
1379.882700 18.315 9.4510
1380.615122 18.298 9.4460
1381.347544 18.281 9.4135
1382.079965 18.255 9.4390
1382.812387 18.235 9.4030
1383.544809 18.216 9.4170
1384.277231 18.195 9.3735
1385.009653 18.179 9.4120
1385.742074 18.155 9.3929
1386.474496 18.134 9.4105
1387.206918 18.118 9.4119
1387.939340 18.097 9.4272
1388.671762 18.079 9.4231
1389.404184 18.062 9.4307
1390.136605 18.040 9.4352
1390.869027 18.028 9.4579
1391.601449 18.009 9.4638
1392.333871 17.992 9.4684
1393.066293 17.977 9.5052
1393.798714 17.961 9.4916
1394.531136 17.948 9.4894
1395.263558 17.934 9.5179
1395.995980 17.915 9.4963
1396.728402 17.906 9.4926
1397.460823 17.888 9.4739
1398.193245 17.869 9.4786
1398.925667 17.857 9.4373
1399.658089 17.842 9.4140
1400.390511 17.820 9.4014
1401.122933 17.801 9.3681
1401.855354 17.782 9.3152
1402.587776 17.769 9.3411
1403.320198 17.751 9.2759
1404.052620 17.735 9.2723
1404.785042 17.709 9.2537
1405.517463 17.690 9.2052
1406.249885 17.677 9.1998
1406.982307 17.657 9.1880
1407.714729 17.636 9.1771
1408.447151 17.616 9.1678
1409.179573 17.593 9.1755
1409.911994 17.579 9.1902
1410.644416 17.556 9.1774
1411.376838 17.540 9.1693
1412.109260 17.522 9.1816
1412.841682 17.496 9.1945
1413.574103 17.476 9.1937
1414.306525 17.458 9.1918
1415.038947 17.442 9.1795
1415.771369 17.429 9.1942
1416.503791 17.410 9.2014
1417.236212 17.391 9.2045
1417.968634 17.375 9.2092
1418.701056 17.363 9.1976
1419.433478 17.342 9.1666
1420.165900 17.324 9.1517
1420.898322 17.311 9.1597
1421.630743 17.289 9.1335
1422.363165 17.274 9.1052
1423.095587 17.252 9.1221
1423.828009 17.234 9.0994
1424.560431 17.216 9.1178
1425.292852 17.195 9.0902
1426.025274 17.176 9.0846
1426.757696 17.161 9.0530
1427.490118 17.143 9.0762
1428.222540 17.118 9.0586
1428.954962 17.099 9.0969
1429.687383 17.081 9.1158
1430.419805 17.062 9.1312
1431.152227 17.032 9.1530
1431.884649 17.023 9.1426
1432.617071 17.008 9.1390
1433.349492 16.995 9.1754
1434.081914 16.977 9.1713
1434.814336 16.962 9.1437
1435.546758 16.943 9.1506
1436.279180 16.926 9.1296
1437.011602 16.912 9.1409
1437.744023 16.897 9.1152
1438.476445 16.878 9.1133
1439.208867 16.864 9.0989
1439.941289 16.849 9.1044
1440.673711 16.827 9.0515
1441.406132 16.808 9.0743
1442.138554 16.795 9.0353
1442.870976 16.771 9.0358
1443.603398 16.758 8.9630
1444.335820 16.747 8.9473
1445.068241 16.715 9.0190
1445.800663 16.701 8.9795
1446.533085 16.681 8.9708
1447.265507 16.661 8.9888
1447.997929 16.645 8.9721
1448.730351 16.613 8.9471
1449.462772 16.609 8.9403
1450.195194 16.583 8.9716
1450.927616 16.569 8.9833
1451.660038 16.543 8.9783
1452.392460 16.538 8.9916
1453.124881 16.512 9.1033
1453.857303 16.500 9.0374
1454.589725 16.478 9.1124
1455.322147 16.459 9.0802
1456.054569 16.455 9.0676
1456.786991 16.437 8.9935
1457.519412 16.412 9.0474
1458.251834 16.403 9.0342
1458.984256 16.379 9.0114
1459.716678 16.367 9.0128
1460.449100 16.355 9.0178
1461.181521 16.327 8.9998
1461.913943 16.307 9.0027
1462.646365 16.294 8.9280
1463.378787 16.281 8.9357
1464.111209 16.257 8.9166
1464.843630 16.249 8.9727
1465.576052 16.216 8.9974
1466.308474 16.204 8.9795
1467.040896 16.185 8.9409
1467.773318 16.162 8.9620
1468.505740 16.148 8.9741
1469.238161 16.130 8.9787
1469.970583 16.115 8.9515
1470.703005 16.097 8.9297
1471.435427 16.085 9.0108
1472.167849 16.065 9.1001
1472.900270 16.052 8.9977
1473.632692 16.030 9.0267
1474.365114 16.020 9.0043
1475.097536 16.000 9.0217
1475.829958 15.995 9.0370
1476.562380 15.974 8.9546
1477.294801 15.965 9.0043
1478.027223 15.946 9.0009
1478.759645 15.929 8.9078
1479.492067 15.919 8.9426
1480.224489 15.899 8.9009
1480.956910 15.876 8.9157
1481.689332 15.868 8.8596
1482.421754 15.845 8.8156
1483.154176 15.826 8.8828
1483.886598 15.813 8.8257
1484.619020 15.793 8.7852
1485.351441 15.765 8.8607
1486.083863 15.751 8.8239
1486.816285 15.735 8.8171
1487.548707 15.719 8.8231
1488.281129 15.712 8.8175
1489.013550 15.685 8.8020
1489.745972 15.669 8.8270
1490.478394 15.660 8.7984
1491.210816 15.641 8.8365
1491.943238 15.629 8.7961
1492.675659 15.611 8.8117
1493.408081 15.594 8.7885
1494.140503 15.576 8.7693
1494.872925 15.561 8.7850
1495.605347 15.552 8.7137
1496.337769 15.532 8.7750
1497.070190 15.528 8.6824
1497.802612 15.507 8.6512
1498.535034 15.477 8.6605
1499.267456 15.469 8.5996
1499.999878 15.449 8.6000
1500.732299 15.435 8.5005
1501.464721 15.405 8.5070
1502.197143 15.388 8.5154
1502.929565 15.371 8.4331
1503.661987 15.339 8.4602
1504.394409 15.329 8.4402
1505.126830 15.303 8.4358
1505.859252 15.282 8.4667
1506.591674 15.261 8.3982
1507.324096 15.235 8.4926
1508.056518 15.219 8.4587
1508.788939 15.198 8.5021
1509.521361 15.167 8.5087
1510.253783 15.154 8.5182
1510.986205 15.138 8.5486
1511.718627 15.127 8.6083
1512.451048 15.107 8.5945
1513.183470 15.087 8.5939
1513.915892 15.082 8.6639
1514.648314 15.065 8.6317
1515.380736 15.039 8.6185
1516.113158 15.042 8.6555
1516.845579 15.018 8.6604
1517.578001 15.002 8.7076
1518.310423 14.999 8.6389
1519.042845 14.975 8.6509
1519.775267 14.959 8.5797
1520.507688 14.943 8.6292
1521.240110 14.914 8.6720
1521.972532 14.916 8.6158
1522.704954 14.895 8.5491
1523.437376 14.863 8.6185
1524.169798 14.852 8.5666
1524.902219 14.840 8.6431
1525.634641 14.808 8.6234
1526.367063 14.798 8.6835
1527.099485 14.774 8.6199
1527.831907 14.771 8.6490
1528.564328 14.743 8.6561
1529.296750 14.729 8.7261
1530.029172 14.705 8.6843
1530.761594 14.696 8.7072
1531.494016 14.687 8.6876
1532.226438 14.673 8.7531
1532.958859 14.660 8.7280
1533.691281 14.655 8.7207
1534.423703 14.644 8.7840
1535.156125 14.623 8.6945
1535.888547 14.610 8.7072
1536.620968 14.603 8.6879
1537.353390 14.589 8.6442
1538.085812 14.579 8.6935
1538.818234 14.563 8.6038
1539.550656 14.542 8.5951
1540.283077 14.533 8.5114
1541.015499 14.522 8.4785
1541.747921 14.496 8.4415
1542.480343 14.488 8.4496
1543.212765 14.454 8.4536
1543.945187 14.448 8.3433
1544.677608 14.430 8.2983
1545.410030 14.405 8.3289
1546.142452 14.386 8.3557
1546.874874 14.357 8.2820
1547.607296 14.322 8.2990
1548.339717 14.310 8.2319
1549.072139 14.296 8.3193
1549.804561 14.273 8.2662
1550.536983 14.255 8.3746
1551.269405 14.237 8.3312
1552.001827 14.212 8.3835
1552.734248 14.195 8.3605
1553.466670 14.183 8.4393
1554.199092 14.169 8.4255
1554.931514 14.152 8.4037
1555.663936 14.148 8.5012
1556.396357 14.122 8.4402
1557.128779 14.113 8.4708
1557.861201 14.098 8.4644
1558.593623 14.083 8.4990
1559.326045 14.069 8.4478
1560.058466 14.065 8.4518
1560.790888 14.048 8.4128
1561.523310 14.038 8.4191
1562.255732 14.017 8.4124
1562.988154 14.005 8.3501
1563.720576 13.981 8.4303
1564.452997 13.971 8.3776
1565.185419 13.944 8.3209
1565.917841 13.924 8.3381
1566.650263 13.911 8.3219
1567.382685 13.900 8.2929
1568.115106 13.882 8.3510
1568.847528 13.860 8.2768
1569.579950 13.844 8.3193
1570.312372 13.818 8.2565
1571.044794 13.803 8.2974
1571.777216 13.788 8.2899
1572.509637 13.774 8.3452
1573.242059 13.762 8.2991
1573.974481 13.741 8.3445
1574.706903 13.729 8.3545
1575.439325 13.715 8.3607
1576.171746 13.703 8.3022
1576.904168 13.690 8.2893
1577.636590 13.673 8.2701
1578.369012 13.654 8.2899
1579.101434 13.642 8.2395
1579.833856 13.632 8.2491
1580.566277 13.615 8.2064
1581.298699 13.603 8.2200
1582.031121 13.587 8.1757
1582.763543 13.578 8.1926
1583.495965 13.556 8.1109
1584.228386 13.547 8.0994
1584.960808 13.517 8.0820
1585.693230 13.494 8.1113
1586.425652 13.482 8.0459
1587.158074 13.460 8.1091
1587.890495 13.434 8.0826
1588.622917 13.411 8.0785
1589.355339 13.392 8.1328
1590.087761 13.382 8.0936
1590.820183 13.375 8.0566
1591.552605 13.354 8.0690
1592.285026 13.330 8.1016
1593.017448 13.326 8.0964
1593.749870 13.307 8.1343
1594.482292 13.297 8.1735
1595.214714 13.297 8.1296
1595.947135 13.270 8.1526
1596.679557 13.254 8.1236
1597.411979 13.251 8.1412
1598.144401 13.233 8.1351
1598.876823 13.218 8.1029
1599.609245 13.207 8.0820
1600.341666 13.180 8.1360
1601.074088 13.164 8.0780
1601.806510 13.145 8.0692
1602.538932 13.131 8.0547
1603.271354 13.112 8.0732
1604.003775 13.097 8.0508
1604.736197 13.079 8.0176
1605.468619 13.061 8.0221
1606.201041 13.056 7.9835
1606.933463 13.033 7.9821
1607.665884 13.014 7.9637
1608.398306 12.997 8.0114
1609.130728 12.980 8.0192
1609.863150 12.961 8.0170
1610.595572 12.948 8.0060
1611.327994 12.928 8.0039
1612.060415 12.914 8.0308
1612.792837 12.901 8.0118
1613.525259 12.884 8.0518
1614.257681 12.867 8.0405
1614.990103 12.856 7.9790
1615.722524 12.832 8.0938
1616.454946 12.824 8.0511
1617.187368 12.810 8.0229
1617.919790 12.798 8.0797
1618.652212 12.781 8.0977
1619.384634 12.768 8.0414
1620.117055 12.742 8.0818
1620.849477 12.738 8.0818
1621.581899 12.717 8.0723
1622.314321 12.706 8.0389
1623.046743 12.689 8.0535
1623.779164 12.675 8.0248
1624.511586 12.655 8.0195
1625.244008 12.634 8.0536
1625.976430 12.617 8.0242
1626.708852 12.606 8.0019
1627.441274 12.590 7.9957
1628.173695 12.577 7.9717
1628.906117 12.558 8.0028
1629.638539 12.545 7.9943
1630.370961 12.530 8.0095
1631.103383 12.512 8.0409
1631.835804 12.495 8.0233
1632.568226 12.487 8.0240
1633.300648 12.465 8.0217
1634.033070 12.461 7.9940
1634.765492 12.442 7.9464
1635.497913 12.432 7.9468
1636.230335 12.412 7.8709
1636.962757 12.396 7.9096
1637.695179 12.378 7.9156
1638.427601 12.363 7.8599
1639.160023 12.351 7.8937
1639.892444 12.330 7.8240
1640.624866 12.319 7.7841
1641.357288 12.307 7.7317
1642.089710 12.280 7.7129
1642.822132 12.269 7.6857
1643.554553 12.243 7.7181
1644.286975 12.230 7.6923
1645.019397 12.207 7.7101
1645.751819 12.187 7.6616
1646.484241 12.166 7.6941
1647.216663 12.150 7.7263
1647.949084 12.129 7.7301
1648.681506 12.105 7.8047
1649.413928 12.080 7.7900
1650.146350 12.071 7.8398
1650.878772 12.054 7.8583
1651.611193 12.032 7.8831
1652.343615 12.019 7.9106
1653.076037 12.012 7.8881
1653.808459 11.997 7.9482
1654.540881 11.987 8.0077
1655.273302 11.974 8.0452
1656.005724 11.966 8.0253
1656.738146 11.952 8.0630
1657.470568 11.941 8.0419
1658.202990 11.933 8.1000
1658.935412 11.924 8.0793
1659.667833 11.911 8.0525
1660.400255 11.906 8.0439
1661.132677 11.892 8.0259
1661.865099 11.875 7.9439
1662.597521 11.871 7.9738
1663.329942 11.854 7.9228
1664.062364 11.852 7.9177
1664.794786 11.839 7.8431
1665.527208 11.825 7.8138
1666.259630 11.803 7.7824
1666.992052 11.792 7.7750
1667.724473 11.777 7.6953
1668.456895 11.754 7.7084
1669.189317 11.736 7.6752
1669.921739 11.714 7.6735
1670.654161 11.695 7.6300
1671.386582 11.680 7.6373
1672.119004 11.665 7.6331
1672.851426 11.639 7.6870
1673.583848 11.615 7.6517
1674.316270 11.604 7.6713
1675.048692 11.587 7.6834
1675.781113 11.560 7.6702
1676.513535 11.543 7.6915
1677.245957 11.525 7.6868
1677.978379 11.509 7.8095
1678.710801 11.499 7.7444
1679.443222 11.484 7.7496
1680.175644 11.474 7.8633
1680.908066 11.456 7.8011
1681.640488 11.458 7.7947
1682.372910 11.447 7.7573
1683.105331 11.433 7.7133
1683.837753 11.426 7.7688
1684.570175 11.404 7.7661
1685.302597 11.383 7.7565
1686.035019 11.383 7.7097
1686.767441 11.357 7.7268
1687.499862 11.341 7.6394
1688.232284 11.321 7.5998
1688.964706 11.295 7.5963
1689.697128 11.290 7.5495
1690.429550 11.279 7.5491
1691.161971 11.245 7.5188
1691.894393 11.230 7.5540
1692.626815 11.207 7.5315
1693.359237 11.188 7.5194
1694.091659 11.168 7.4572
1694.824081 11.154 7.4951
1695.556502 11.141 7.5076
1696.288924 11.114 7.5435
1697.021346 11.098 7.5676
1697.753768 11.091 7.5706
1698.486190 11.074 7.6180
1699.218611 11.044 7.6281
1699.951033 11.025 7.7209
1700.683455 11.012 7.7264
1701.415877 11.009 7.8018
1702.148299 10.994 7.8044
1702.880720 10.977 7.7778
1703.613142 10.973 7.8367
1704.345564 10.962 7.8829
1705.077986 10.958 7.8749
1705.810408 10.944 7.8843
1706.542830 10.928 7.8587
1707.275251 10.926 7.8597
1708.007673 10.914 7.8140
1708.740095 10.894 7.8239
1709.472517 10.898 7.7778
1710.204939 10.881 7.7469
1710.937360 10.861 7.6981
1711.669782 10.849 7.6853
1712.402204 10.829 7.5930
1713.134626 10.820 7.5762
1713.867048 10.801 7.5063
1714.599470 10.781 7.5184
1715.331891 10.775 7.4764
1716.064313 10.747 7.4825
1716.796735 10.726 7.4843
1717.529157 10.702 7.5008
1718.261579 10.681 7.4764
1718.994000 10.684 7.4573
1719.726422 10.656 7.4927
1720.458844 10.639 7.5364
1721.191266 10.627 7.5457
1721.923688 10.608 7.5720
1722.656110 10.597 7.6349
1723.388531 10.585 7.6406
1724.120953 10.567 7.6553
1724.853375 10.569 7.6570
1725.585797 10.552 7.7034
1726.318219 10.538 7.7201
1727.050640 10.538 7.6865
1727.783062 10.529 7.6340
1728.515484 10.515 7.6693
1729.247906 10.496 7.6669
1729.980328 10.486 7.6584
1730.712749 10.486 7.5686
1731.445171 10.472 7.5220
1732.177593 10.458 7.5538
1732.910015 10.448 7.4335
1733.642437 10.429 7.4101
1734.374859 10.405 7.3961
1735.107280 10.387 7.4146
1735.839702 10.366 7.3462
1736.572124 10.354 7.2899
1737.304546 10.329 7.2340
1738.036968 10.310 7.2528
1738.769389 10.296 7.2170
1739.501811 10.274 7.2213
1740.234233 10.245 7.2727
1740.966655 10.222 7.2435
1741.699077 10.203 7.2228
1742.431499 10.191 7.2134
1743.163920 10.172 7.2865
1743.896342 10.148 7.2995
1744.628764 10.128 7.2564
1745.361186 10.116 7.3073
1746.093608 10.097 7.4336
1746.826029 10.087 7.4795
1747.558451 10.062 7.5055
1748.290873 10.060 7.4774
1749.023295 10.037 7.5197
1749.755717 10.031 7.6049
1750.488138 10.021 7.5764
1751.220560 10.013 7.5492
1751.952982 10.005 7.5579
1752.685404 9.993 7.6396
1753.417826 9.980 7.6556
1754.150248 9.968 7.5670
1754.882669 9.956 7.6216
1755.615091 9.951 7.6837
1756.347513 9.947 7.5520
1757.079935 9.928 7.5440
1757.812357 9.913 7.5820
1758.544778 9.903 7.5702
1759.277200 9.892 7.6133
1760.009622 9.881 7.4845
1760.742044 9.862 7.5138
1761.474466 9.854 7.5149
1762.206888 9.844 7.3805
1762.939309 9.823 7.3725
1763.671731 9.809 7.3948
1764.404153 9.798 7.3595
1765.136575 9.774 7.3975
1765.868997 9.758 7.2222
1766.601418 9.747 7.2300
1767.333840 9.734 7.2472
1768.066262 9.703 7.1741
1768.798684 9.690 7.1592
1769.531106 9.676 7.1686
1770.263528 9.651 7.1544
1770.995949 9.633 7.2012
1771.728371 9.612 7.1379
1772.460793 9.596 7.1816
1773.193215 9.577 7.1742
1773.925637 9.559 7.1166
1774.658058 9.537 7.1478
1775.390480 9.512 7.3248
1776.122902 9.507 7.3442
1776.855324 9.495 7.4431
1777.587746 9.470 7.3949
1778.320167 9.457 7.4585
1779.052589 9.458 7.4377
1779.785011 9.443 7.5141
1780.517433 9.432 7.4918
1781.249855 9.431 7.6254
1781.982277 9.426 7.6843
1782.714698 9.420 7.6652
1783.447120 9.403 7.6826
1784.179542 9.396 7.7103
1784.911964 9.398 7.5995
1785.644386 9.382 7.5690
1786.376807 9.371 7.5430
1787.109229 9.362 7.5413
1787.841651 9.369 7.5095
1788.574073 9.354 7.4590
1789.306495 9.335 7.3887
1790.038917 9.330 7.3231
1790.771338 9.312 7.3028
1791.503760 9.274 7.2500
1792.236182 9.258 7.1898
1792.968604 9.256 7.1691
1793.701026 9.228 7.0645
1794.433447 9.209 7.0881
1795.165869 9.173 7.0120
1795.898291 9.163 7.0887
1796.630713 9.143 7.1116
1797.363135 9.108 7.1415
1798.095556 9.090 7.0816
1798.827978 9.069 7.1281
1799.560400 9.062 7.1823
1800.292822 9.048 7.2500
1801.025244 9.016 7.2927
1801.757666 9.020 7.4271
1802.490087 9.013 7.3456
1803.222509 8.989 7.4123
1803.954931 8.979 7.4850
1804.687353 8.974 7.5327
1805.419775 8.986 7.5021
1806.152196 8.983 7.5044
1806.884618 8.967 7.5264
1807.617040 8.956 7.5184
1808.349462 8.952 7.4799
1809.081884 8.939 7.4928
1809.814306 8.937 7.4298
1810.546727 8.930 7.3504
1811.279149 8.920 7.2770
1812.011571 8.916 7.2078
1812.743993 8.879 7.2206
1813.476415 8.883 7.1260
1814.208836 8.863 7.0689
1814.941258 8.828 7.0955
1815.673680 8.816 7.0588
1816.406102 8.798 6.9232
1817.138524 8.776 6.9744
1817.870946 8.766 6.9855
1818.603367 8.733 7.0045
1819.335789 8.727 6.9391
1820.068211 8.705 6.9082
1820.800633 8.670 7.0018
1821.533055 8.650 7.0179
1822.265476 8.646 7.0507
1822.997898 8.634 6.9838
1823.730320 8.628 7.0598
1824.462742 8.605 7.1240
1825.195164 8.598 7.0885
1825.927585 8.593 7.1447
1826.660007 8.579 7.1374
1827.392429 8.558 7.1586
1828.124851 8.573 7.1420
1828.857273 8.570 7.0199
1829.589695 8.547 7.0386
1830.322116 8.541 7.0539
1831.054538 8.530 6.9844
1831.786960 8.506 7.0016
1832.519382 8.497 6.9224
1833.251804 8.477 6.8695
1833.984225 8.467 6.7493
1834.716647 8.447 6.7899
1835.449069 8.425 6.7561
1836.181491 8.405 6.6892
1836.913913 8.379 6.6976
1837.646335 8.372 6.6644
1838.378756 8.342 6.7622
1839.111178 8.313 6.7526
1839.843600 8.290 6.6454
1840.576022 8.268 6.7651
1841.308444 8.246 6.7433
1842.040865 8.224 6.7756
1842.773287 8.209 6.8685
1843.505709 8.190 6.9254
1844.238131 8.176 6.9805
1844.970553 8.161 7.0555
1845.702974 8.139 7.1007
1846.435396 8.135 7.1100
1847.167818 8.126 7.1323
1847.900240 8.119 7.3065
1848.632662 8.114 7.1582
1849.365084 8.102 7.1903
1850.097505 8.087 7.2686
1850.829927 8.089 7.3611
1851.562349 8.076 7.1417
1852.294771 8.068 7.1772
1853.027193 8.052 7.1965
1853.759614 8.048 7.1928
1854.492036 8.031 7.1512
1855.224458 8.035 7.1706
1855.956880 8.004 7.1714
1856.689302 8.011 7.1434
1857.421724 7.991 7.0372
1858.154145 7.969 7.0491
1858.886567 7.970 7.0154
1859.618989 7.948 7.1107
1860.351411 7.930 7.0571
1861.083833 7.919 6.9954
1861.816254 7.914 7.0749
1862.548676 7.900 7.0062
1863.281098 7.896 7.0453
1864.013520 7.878 6.9996
1864.745942 7.867 6.9553
1865.478364 7.851 6.9611
1866.210785 7.833 6.9316
1866.943207 7.821 6.9074
1867.675629 7.804 7.0105
1868.408051 7.796 7.0057
1869.140473 7.758 6.8470
1869.872894 7.750 6.9526
1870.605316 7.733 6.9680
1871.337738 7.719 6.9089
1872.070160 7.718 6.8879
1872.802582 7.705 6.8992
1873.535003 7.657 6.9205
1874.267425 7.668 6.8791
1874.999847 7.644 6.8621
1875.732269 7.617 6.7922
1876.464691 7.603 6.8628
1877.197113 7.603 6.9113
1877.929534 7.572 6.8416
1878.661956 7.575 6.9282
1879.394378 7.567 6.9330
1880.126800 7.551 7.0587
1880.859222 7.533 6.9087
1881.591643 7.500 6.9788
1882.324065 7.496 7.0237
1883.056487 7.477 7.0179
1883.788909 7.465 7.0021
1884.521331 7.454 7.0113
1885.253753 7.450 6.9812
1885.986174 7.442 6.9769
1886.718596 7.422 7.0037
1887.451018 7.428 6.9252
1888.183440 7.416 7.0109
1888.915862 7.394 6.9723
1889.648283 7.387 7.0292
1890.380705 7.369 6.9284
1891.113127 7.348 6.9485
1891.845549 7.356 7.0406
1892.577971 7.326 7.0201
1893.310392 7.318 7.0543
1894.042814 7.306 6.9537
1894.775236 7.294 6.9568
1895.507658 7.274 7.0117
1896.240080 7.259 6.9616
1896.972502 7.257 7.0682
1897.704923 7.250 6.9602
1898.437345 7.227 6.9733
1899.169767 7.216 7.0773
1899.902189 7.210 7.1690
1900.634611 7.197 7.1252
1901.367032 7.177 7.0566
1902.099454 7.174 7.0356
1902.831876 7.172 7.0464
1903.564298 7.163 6.9316
1904.296720 7.160 7.0917
1905.029142 7.134 6.9344
1905.761563 7.129 7.0581
1906.493985 7.124 6.8751
1907.226407 7.106 6.9352
1907.958829 7.095 6.9183
1908.691251 7.090 6.8134
1909.423672 7.071 6.7635
1910.156094 7.053 6.7557
1910.888516 7.029 6.7068
1911.620938 7.019 6.6454
1912.353360 6.986 6.6495
1913.085782 6.980 6.6461
1913.818203 6.963 6.7150
1914.550625 6.943 6.6473
1915.283047 6.924 6.6562
1916.015469 6.898 6.6454
1916.747891 6.883 6.6248
1917.480312 6.874 6.6539
1918.212734 6.860 6.6133
1918.945156 6.845 6.7854
1919.677578 6.826 6.8606
1920.410000 6.818 6.8499
1921.142421 6.802 6.8516
1921.874843 6.787 6.8665
1922.607265 6.764 6.9199
1923.339687 6.778 6.8776
1924.072109 6.753 6.7615
1924.804531 6.748 6.8339
1925.536952 6.752 6.8365
1926.269374 6.734 6.8350
1927.001796 6.724 6.7572
1927.734218 6.713 6.8165
1928.466640 6.696 6.7704
1929.199061 6.682 6.6146
1929.931483 6.668 6.6418
1930.663905 6.643 6.6558
1931.396327 6.631 6.5723
1932.128749 6.604 6.5367
1932.861171 6.589 6.5497
1933.593592 6.587 6.5438
1934.326014 6.563 6.6196
1935.058436 6.533 6.4216
1935.790858 6.517 6.6100
1936.523280 6.496 6.5854
1937.255701 6.484 6.5715
1937.988123 6.468 6.6660
1938.720545 6.439 6.6649
1939.452967 6.432 6.6132
1940.185389 6.429 6.7836
1940.917810 6.415 6.8058
1941.650232 6.389 6.7322
1942.382654 6.392 6.8362
1943.115076 6.379 6.9692
1943.847498 6.375 6.9791
1944.579920 6.353 6.9482
1945.312341 6.353 7.0735
1946.044763 6.345 7.0512
1946.777185 6.338 7.0417
1947.509607 6.327 7.0371
1948.242029 6.329 7.0600
1948.974450 6.317 7.0145
1949.706872 6.309 7.0419
1950.439294 6.295 7.0087
1951.171716 6.286 6.9661
1951.904138 6.283 7.0297
1952.636560 6.275 6.9033
1953.368981 6.253 6.8775
1954.101403 6.248 6.9225
1954.833825 6.242 6.8779
1955.566247 6.223 6.7676
1956.298669 6.213 6.8902
1957.031090 6.193 6.8379
1957.763512 6.191 6.8430
1958.495934 6.155 6.7473
1959.228356 6.152 6.7945
1959.960778 6.130 6.7477
1960.693200 6.139 6.7156
1961.425621 6.122 6.6781
1962.158043 6.119 6.7028
1962.890465 6.091 6.7600
1963.622887 6.089 6.6873
1964.355309 6.077 6.6304
1965.087730 6.047 6.6882
1965.820152 6.040 6.5301
1966.552574 6.030 6.6313
1967.284996 6.017 6.5994
1968.017418 6.000 6.6032
1968.749839 5.976 6.5614
1969.482261 5.964 6.6180
1970.214683 5.943 6.5997
1970.947105 5.922 6.5575
1971.679527 5.917 6.5393
1972.411949 5.892 6.5617
1973.144370 5.872 6.5903
1973.876792 5.857 6.5895
1974.609214 5.841 6.6493
1975.341636 5.837 6.5643
1976.074058 5.815 6.6313
1976.806479 5.805 6.7048
1977.538901 5.797 6.6903
1978.271323 5.785 6.7352
1979.003745 5.768 6.7453
1979.736167 5.773 6.8237
1980.468589 5.751 6.8209
1981.201010 5.751 6.7490
1981.933432 5.725 6.7102
1982.665854 5.717 6.7477
1983.398276 5.705 6.7124
1984.130698 5.702 6.7198
1984.863119 5.697 6.7223
1985.595541 5.684 6.7500
1986.327963 5.662 6.6682
1987.060385 5.657 6.6757
1987.792807 5.648 6.6300
1988.525229 5.629 6.6415
1989.257650 5.622 6.5739
1989.990072 5.594 6.5391
1990.722494 5.593 6.5948
1991.454916 5.566 6.5990
1992.187338 5.563 6.6080
1992.919759 5.550 6.5898
1993.652181 5.533 6.5845
1994.384603 5.508 6.5933
1995.117025 5.513 6.5873
1995.849447 5.486 6.6059
1996.581868 5.486 6.6775
1997.314290 5.471 6.6341
1998.046712 5.446 6.6313
1998.779134 5.461 6.7244
1999.511556 5.445 6.5356
2000.243978 5.434 6.5674
2000.976399 5.427 6.5410
2001.708821 5.412 6.5187
2002.441243 5.392 6.5189
2003.173665 5.389 6.3939
2003.906087 5.374 6.3231
2004.638508 5.356 6.3083
2005.370930 5.338 6.2681
2006.103352 5.319 6.2352
2006.835774 5.304 6.2494
2007.568196 5.280 6.1745
2008.300618 5.257 6.1581
2009.033039 5.227 6.1607
2009.765461 5.220 6.2723
2010.497883 5.195 6.2798
2011.230305 5.164 6.2494
2011.962727 5.157 6.3567
2012.695148 5.127 6.2646
2013.427570 5.108 6.3826
2014.159992 5.093 6.5508
2014.892414 5.088 6.5543
2015.624836 5.068 6.5700
2016.357257 5.060 6.6012
2017.089679 5.041 6.5891
2017.822101 5.046 6.7670
2018.554523 5.038 6.8465
2019.286945 5.039 6.8623
2020.019367 5.031 6.8793
2020.751788 5.043 6.8733
2021.484210 5.034 6.8243
2022.216632 5.045 6.9148
2022.949054 5.041 6.7681
2023.681476 5.040 6.7225
2024.413897 5.040 6.6483
2025.146319 5.019 6.6481
2025.878741 5.021 6.5690
2026.611163 5.006 6.4276
2027.343585 4.988 6.4062
2028.076007 4.956 6.2642
2028.808428 4.939 6.2618
2029.540850 4.922 6.1583
2030.273272 4.894 6.1548
2031.005694 4.867 6.1472
2031.738116 4.842 6.1574
2032.470537 4.827 6.1659
2033.202959 4.792 6.2256
2033.935381 4.769 6.1588
2034.667803 4.740 6.2275
2035.400225 4.731 6.4075
2036.132647 4.694 6.4575
2036.865068 4.694 6.5632
2037.597490 4.693 6.6105
2038.329912 4.666 6.7808
2039.062334 4.662 6.8969
2039.794756 4.677 6.9949
2040.527177 4.669 7.0890
2041.259599 4.668 7.0656
2041.992021 4.667 7.1593
2042.724443 4.674 7.1315
2043.456865 4.680 7.1554
2044.189286 4.680 7.1017
2044.921708 4.693 7.1815
2045.654130 4.697 6.9514
2046.386552 4.671 6.9590
2047.118974 4.680 6.9948
2047.851396 4.675 6.7899
2048.583817 4.674 6.6492
2049.316239 4.659 6.7036
2050.048661 4.643 6.4705
2050.781083 4.630 6.5216
2051.513505 4.602 6.3527
2052.245926 4.591 6.3680
2052.978348 4.575 6.3320
2053.710770 4.547 6.2229
2054.443192 4.517 6.2490
2055.175614 4.510 6.2567
2055.908036 4.478 6.3070
2056.640457 4.477 6.1754
2057.372879 4.452 6.2971
2058.105301 4.429 6.2900
2058.837723 4.428 6.2065
2059.570145 4.405 6.4117
2060.302566 4.388 6.3540
2061.034988 4.397 6.3077
2061.767410 4.378 6.3873
2062.499832 4.375 6.3768
2063.232254 4.373 6.3143
2063.964675 4.348 6.2609
2064.697097 4.344 6.3632
2065.429519 4.338 6.3164
2066.161941 4.322 6.1619
2066.894363 4.328 6.1155
2067.626785 4.307 6.2350
2068.359206 4.287 6.0218
2069.091628 4.278 6.0157
2069.824050 4.234 6.0267
2070.556472 4.219 6.0223
2071.288894 4.191 5.8190
2072.021315 4.188 5.7474
2072.753737 4.172 5.7569
2073.486159 4.116 5.8244
2074.218581 4.112 5.7144
2074.951003 4.080 5.8948
2075.683425 4.064 6.0480
2076.415846 4.045 6.1097
2077.148268 4.030 6.0477
2077.880690 4.013 6.2274
2078.613112 3.995 6.2810
2079.345534 3.981 6.2277
2080.077955 3.977 6.4304
2080.810377 3.952 6.4359
2081.542799 3.945 6.5690
2082.275221 3.948 6.6439
2083.007643 3.954 6.7338
2083.740065 3.941 6.6951
2084.472486 3.945 6.6605
2085.204908 3.948 6.7418
2085.937330 3.941 6.7485
2086.669752 3.939 6.6926
2087.402174 3.926 6.6924
2088.134595 3.937 6.6214
2088.867017 3.920 6.6137
2089.599439 3.911 6.6263
2090.331861 3.894 6.4218
2091.064283 3.889 6.5605
2091.796704 3.891 6.4744
2092.529126 3.866 6.4220
2093.261548 3.844 6.3782
2093.993970 3.839 6.4478
2094.726392 3.813 6.3898
2095.458814 3.793 6.3263
2096.191235 3.793 6.3929
2096.923657 3.762 6.4537
2097.656079 3.761 6.4888
2098.388501 3.737 6.5229
2099.120923 3.728 6.4265
2099.853344 3.734 6.5013
2100.585766 3.718 6.5679
2101.318188 3.709 6.5428
2102.050610 3.696 6.5355
2102.783032 3.697 6.4819
2103.515454 3.672 6.4948
2104.247875 3.666 6.5670
2104.980297 3.680 6.5344
2105.712719 3.652 6.4280
2106.445141 3.655 6.4546
2107.177563 3.625 6.4805
2107.909984 3.626 6.2112
2108.642406 3.609 6.3540
2109.374828 3.595 6.3035
2110.107250 3.583 6.2690
2110.839672 3.571 6.2977
2111.572093 3.564 6.2577
2112.304515 3.542 6.3536
2113.036937 3.516 6.3702
2113.769359 3.514 6.2174
2114.501781 3.497 6.3322
2115.234203 3.478 6.3947
2115.966624 3.466 6.3826
2116.699046 3.456 6.5585
2117.431468 3.463 6.4220
2118.163890 3.434 6.5209
2118.896312 3.440 6.5341
2119.628733 3.413 6.3932
2120.361155 3.406 6.5500
2121.093577 3.402 6.4827
2121.825999 3.403 6.5527
2122.558421 3.404 6.5500
2123.290843 3.402 6.3507
2124.023264 3.388 6.3738
2124.755686 3.392 6.3467
2125.488108 3.365 6.2294
2126.220530 3.353 6.2220
2126.952952 3.353 6.1365
2127.685373 3.336 6.1910
2128.417795 3.328 6.0953
2129.150217 3.311 5.8643
2129.882639 3.286 5.9960
2130.615061 3.267 5.9293
2131.347483 3.226 5.8156
2132.079904 3.230 5.8157
2132.812326 3.200 5.8325
2133.544748 3.169 5.7964
2134.277170 3.156 5.9504
2135.009592 3.127 5.8784
2135.742013 3.112 6.0490
2136.474435 3.107 6.1036
2137.206857 3.077 6.0662
2137.939279 3.083 6.1235
2138.671701 3.060 6.1642
2139.404122 3.059 6.4130
2140.136544 3.073 6.3680
2140.868966 3.052 6.2706
2141.601388 3.049 6.4659
2142.333810 3.043 6.4855
2143.066232 3.035 6.3914
2143.798653 3.038 6.4418
2144.531075 3.034 6.3906
2145.263497 3.036 6.4103
2145.995919 3.043 6.2155
2146.728341 3.020 6.1671
2147.460762 3.023 6.1287
2148.193184 3.017 5.8822
2148.925606 2.979 5.8724
2149.658028 2.970 5.7449
2150.390450 2.957 5.8042
2151.122872 2.931 5.6938
2151.855293 2.920 5.7123
2152.587715 2.886 5.6560
2153.320137 2.870 5.6028
2154.052559 2.838 5.6773
2154.784981 2.801 5.6880
2155.517402 2.787 5.6346
2156.249824 2.763 5.7022
2156.982246 2.735 5.7512
2157.714668 2.749 5.8389
2158.447090 2.695 5.9221
2159.179511 2.682 5.9796
2159.911933 2.685 6.1465
2160.644355 2.666 6.2786
2161.376777 2.660 6.2225
2162.109199 2.674 6.3119
2162.841621 2.653 6.3445
2163.574042 2.683 6.2437
2164.306464 2.662 6.4060
2165.038886 2.676 6.3770
2165.771308 2.657 6.3992
2166.503730 2.645 6.3179
2167.236151 2.675 6.2985
2167.968573 2.629 6.3647
2168.700995 2.652 6.2479
2169.433417 2.645 6.0643
2170.165839 2.614 5.9590
2170.898261 2.621 6.0407
2171.630682 2.588 5.9078
2172.363104 2.586 5.8223
2173.095526 2.564 5.8926
2173.827948 2.515 5.6906
2174.560370 2.511 5.6791
2175.292791 2.481 5.7512
2176.025213 2.437 5.7877
2176.757635 2.424 5.7279
2177.490057 2.388 5.7650
2178.222479 2.385 5.9130
2178.954901 2.363 5.9403
2179.687322 2.343 6.0421
2180.419744 2.292 6.2000
2181.152166 2.313 6.2520
2181.884588 2.294 6.4712
2182.617010 2.314 6.5975
2183.349431 2.304 6.6177
2184.081853 2.289 6.8101
2184.814275 2.317 6.7600
2185.546697 2.294 6.8914
2186.279119 2.310 6.8942
2187.011540 2.302 6.7507
2187.743962 2.319 6.7343
2188.476384 2.332 6.8505
2189.208806 2.322 6.7954
2189.941228 2.319 6.6746
2190.673650 2.322 6.5796
2191.406071 2.334 6.4045
2192.138493 2.333 6.3052
2192.870915 2.351 6.0779
2193.603337 2.338 6.4201
2194.335759 2.292 5.8751
2195.068180 2.278 5.8550
2195.800602 2.255 5.8432
2196.533024 2.237 5.7572
2197.265446 2.205 5.3816
2197.997868 2.171 5.4742
2198.730290 2.177 5.4379
2199.462711 2.146 5.4644
2200.195133 2.078 5.3907
2200.927555 2.052 5.5073
2201.659977 2.055 5.7089
2202.392399 1.985 5.6036
2203.124820 1.959 5.8328
2203.857242 1.946 5.8820
2204.589664 1.923 5.8153
2205.322086 1.919 6.0148
2206.054508 1.928 6.1413
2206.786929 1.908 6.2474
2207.519351 1.886 6.3256
2208.251773 1.938 6.5570
2208.984195 1.904 6.5146
2209.716617 1.903 6.6741
2210.449039 1.894 6.6138
2211.181460 1.905 6.9465
2211.913882 1.942 6.9106
2212.646304 1.929 6.9216
2213.378726 1.969 6.8160
2214.111148 1.959 6.7454
2214.843569 1.950 6.6262
2215.575991 2.011 6.5084
2216.308413 1.977 6.3418
2217.040835 1.956 6.5397
2217.773257 1.969 6.2852
2218.505679 1.950 6.2196
2219.238100 1.947 6.1794
2219.970522 1.918 5.9991
2220.702944 1.900 5.7805
2221.435366 1.856 5.7347
2222.167788 1.892 5.5938
2222.900209 1.816 5.5056
2223.632631 1.787 5.2462
2224.365053 1.768 5.3319
2225.097475 1.782 5.4111
2225.829897 1.742 5.2617
2226.562319 1.725 5.2733
2227.294740 1.692 5.4410
2228.027162 1.671 5.3994
2228.759584 1.688 5.4230
2229.492006 1.650 5.4070
2230.224428 1.646 5.6486
2230.956849 1.607 5.5161
2231.689271 1.605 5.6761
2232.421693 1.589 5.5093
2233.154115 1.573 5.7520
2233.886537 1.560 5.7839
2234.618958 1.561 5.9304
2235.351380 1.570 5.8154
2236.083802 1.540 5.7881
2236.816224 1.567 5.8318
2237.548646 1.531 5.8708
2238.281068 1.526 5.9877
2239.013489 1.513 5.6906
2239.745911 1.485 5.7334
2240.478333 1.520 5.7628
2241.210755 1.454 5.7530
2241.943177 1.478 5.6382
2242.675598 1.489 6.0796
2243.408020 1.471 5.5557
2244.140442 1.408 5.5459
2244.872864 1.431 5.7576
2245.605286 1.415 5.5451
2246.337708 1.412 5.6248
2247.070129 1.347 5.5439
2247.802551 1.348 5.6234
2248.534973 1.341 5.7878
2249.267395 1.305 5.6313
2249.999817 1.287 5.6374
2250.732238 1.286 5.6176
2251.464660 1.253 5.7940
2252.197082 1.246 5.7751
2252.929504 1.209 5.7369
2253.661926 1.232 5.9237
2254.394347 1.183 5.9189
2255.126769 1.189 5.9329
2255.859191 1.170 6.0493
2256.591613 1.164 6.0972
2257.324035 1.163 6.3485
2258.056457 1.165 6.0566
2258.788878 1.139 6.5177
2259.521300 1.181 6.2700
2260.253722 1.166 6.3849
2260.986144 1.121 6.4381
2261.718566 1.112 6.3677
2262.450987 1.114 6.3246
2263.183409 1.119 6.3965
2263.915831 1.097 6.4779
2264.648253 1.085 6.3616
2265.380675 1.165 6.4359
2266.113097 1.117 6.3925
2266.845518 1.080 6.3263
2267.577940 1.079 6.3521
2268.310362 1.093 6.2631
2269.042784 1.079 6.2587
2269.775206 1.077 6.1902
2270.507627 1.088 6.4398
2271.240049 1.076 6.1653
2271.972471 1.053 6.1667
2272.704893 1.040 6.1968
2273.437315 1.030 6.1659
2274.169737 1.039 6.0754
2274.902158 1.036 5.9626
2275.634580 0.996 5.9420
2276.367002 0.985 6.0051
2277.099424 0.938 5.8948
2277.831846 0.939 5.7002
2278.564267 0.977 5.9426
2279.296689 0.908 5.6037
2280.029111 0.930 5.9540
2280.761533 0.896 5.7059
2281.493955 0.897 5.7435
2282.226376 0.928 5.7052
2282.958798 0.875 5.8609
2283.691220 0.866 5.8821
2284.423642 0.834 5.7279
2285.156064 0.851 5.8424
2285.888486 0.808 5.6932
2286.620907 0.788 5.6903
2287.353329 0.796 5.5288
2288.085751 0.814 5.5442
2288.818173 0.815 5.5721
2289.550595 0.809 5.6471
2290.283016 0.788 5.7090
2291.015438 0.770 5.6045
2291.747860 0.762 5.6814
2292.480282 0.757 5.3856
2293.212704 0.753 5.2133
2293.945126 0.744 5.5027
2294.677547 0.729 5.4418
2295.409969 0.742 5.0350
2296.142391 0.676 5.4264
2296.874813 0.660 4.9985
2297.607235 0.663 5.0618
2298.339656 0.614 4.9996
2299.072078 0.581 4.9208
2299.804500 0.582 4.9222
2300.536922 0.538 5.0769
2301.269344 0.498 5.3142
2302.001765 0.500 5.1078
2302.734187 0.470 5.0930
2303.466609 0.405 5.1980
2304.199031 0.416 5.2786
2304.931453 0.379 5.5132
2305.663875 0.389 5.5242
2306.396296 0.292 5.7289
2307.128718 0.324 5.9474
2307.861140 0.350 6.0420
2308.593562 0.344 6.1625
2309.325984 0.350 6.1406
2310.058405 0.376 6.4240
2310.790827 0.333 6.5281
2311.523249 0.369 6.6124
2312.255671 0.389 6.6428
2312.988093 0.441 6.4653
2313.720515 0.415 6.5128
2314.452936 0.434 6.4711
2315.185358 0.444 6.3623
2315.917780 0.434 6.5501
2316.650202 0.456 6.0607
2317.382624 0.463 6.0715
2318.115045 0.449 5.7703
2318.847467 0.443 5.6396
2319.579889 0.426 5.6766
2320.312311 0.417 5.3930
2321.044733 0.408 5.3473
2321.777155 0.361 5.1217
2322.509576 0.317 4.8337
2323.241998 0.313 4.9695
2323.974420 0.271 4.9009
2324.706842 0.246 4.8437
2325.439264 0.206 4.8475
2326.171685 0.151 4.8005
2326.904107 0.155 4.9402
2327.636529 0.145 4.8615
2328.368951 0.082 5.2123
2329.101373 0.076 4.9772
2329.833794 0.074 5.1468
2330.566216 0.042 5.4946
2331.298638 0.054 5.4667
2332.031060 0.029 5.6931
2332.763482 0.036 5.6951
2333.495904 0.039 5.9077
2334.228325 0.004 5.9406
2334.960747 0.046 6.1426
2335.693169 0.058 5.9901
2336.425591 0.048 5.8928
2337.158013 0.036 6.0125
2337.890434 0.061 5.9137
2338.622856 0.057 5.7460
2339.355278 0.042 5.7493
2340.087700 0.039 5.5797
2340.820122 0.044 5.4418
2341.552544 0.024 5.2401
2342.284965 -0.015 5.0324
2343.017387 -0.014 5.2992
2343.749809 -0.031 5.0343
2344.482231 -0.074 4.9119
2345.214653 -0.111 4.7909
2345.947074 -0.123 4.8718
2346.679496 -0.139 4.7681
2347.411918 -0.196 4.8512
2348.144340 -0.206 4.9006
2348.876762 -0.260 4.9333
2349.609183 -0.279 5.0610
2350.341605 -0.299 5.1404
2351.074027 -0.332 5.3332
2351.806449 -0.330 5.5114
2352.538871 -0.336 5.5001
2353.271293 -0.376 5.6519
2354.003714 -0.356 5.6694
2354.736136 -0.360 5.8828
2355.468558 -0.374 5.8633
2356.200980 -0.391 6.0443
2356.933402 -0.372 6.0697
2357.665823 -0.358 6.1191
2358.398245 -0.369 6.1218
2359.130667 -0.381 6.0869
2359.863089 -0.374 5.9508
2360.595511 -0.348 6.1525
2361.327933 -0.374 6.1730
2362.060354 -0.366 6.1473
2362.792776 -0.353 6.1876
2363.525198 -0.360 5.9994
2364.257620 -0.383 5.8621
2364.990042 -0.395 5.8930
2365.722463 -0.424 5.9388
2366.454885 -0.413 5.8686
2367.187307 -0.421 5.9494
2367.919729 -0.437 5.9998
2368.652151 -0.462 6.0526
2369.384573 -0.477 6.1118
2370.116994 -0.466 6.0286
2370.849416 -0.518 5.9221
2371.581838 -0.456 6.1197
2372.314260 -0.484 6.2579
2373.046682 -0.490 6.2599
2373.779103 -0.483 6.0298
2374.511525 -0.502 6.2925
2375.243947 -0.489 6.1736
2375.976369 -0.492 6.1432
2376.708791 -0.497 6.0429
2377.441212 -0.514 5.9029
2378.173634 -0.500 5.8741
2378.906056 -0.493 5.7893
2379.638478 -0.488 5.7776
2380.370900 -0.476 5.6199
2381.103322 -0.491 5.5356
2381.835743 -0.506 5.3649
2382.568165 -0.483 5.2626
2383.300587 -0.516 5.2998
2384.033009 -0.544 5.1710
2384.765431 -0.557 5.1382
2385.497852 -0.591 4.9288
2386.230274 -0.603 4.9564
2386.962696 -0.623 4.7705
2387.695118 -0.676 4.7620
2388.427540 -0.682 4.6550
2389.159962 -0.723 4.7445
2389.892383 -0.717 4.6122
2390.624805 -0.760 4.6951
2391.357227 -0.797 4.6475
2392.089649 -0.829 4.9602
2392.822071 -0.823 4.7399
2393.554492 -0.858 4.6569
2394.286914 -0.882 4.9162
2395.019336 -0.886 4.9438
2395.751758 -0.905 5.0236
2396.484180 -0.912 5.1530
2397.216601 -0.938 5.1440
2397.949023 -0.929 5.2760
2398.681445 -0.955 5.1447
2399.413867 -0.967 5.3734
2400.146289 -0.991 5.3026
2400.878711 -1.011 5.3223
2401.611132 -1.010 5.3761
2402.343554 -1.028 5.3899
2403.075976 -1.035 5.4763
2403.808398 -1.046 5.6498
2404.540820 -1.041 5.5642
2405.273241 -1.057 5.5095
2406.005663 -1.064 5.7112
2406.738085 -1.089 5.5045
2407.470507 -1.084 5.5526
2408.202929 -1.082 5.4950
2408.935351 -1.084 5.5602
2409.667772 -1.099 5.6104
2410.400194 -1.132 5.7166
2411.132616 -1.133 5.8229
2411.865038 -1.108 5.8745
2412.597460 -1.141 5.8123
2413.329881 -1.145 5.7529
2414.062303 -1.117 5.8161
2414.794725 -1.118 5.7453
2415.527147 -1.112 6.0692
2416.259569 -1.126 5.9116
2416.991991 -1.155 5.7047
2417.724412 -1.141 5.8878
2418.456834 -1.143 5.9612
2419.189256 -1.144 5.7085
2419.921678 -1.157 5.6949
2420.654100 -1.203 5.6226
2421.386521 -1.198 5.8539
2422.118943 -1.173 5.7230
2422.851365 -1.172 5.6672
2423.583787 -1.218 5.5468
2424.316209 -1.230 5.4644
2425.048630 -1.229 5.5391
2425.781052 -1.249 5.3757
2426.513474 -1.244 5.4414
2427.245896 -1.276 5.2979
2427.978318 -1.306 5.4395
2428.710740 -1.332 5.3135
2429.443161 -1.352 5.2586
2430.175583 -1.354 5.1969
2430.908005 -1.352 5.1081
2431.640427 -1.378 5.1437
2432.372849 -1.369 5.1542
2433.105270 -1.382 5.1244
2433.837692 -1.433 5.1285
2434.570114 -1.470 5.2893
2435.302536 -1.477 5.3376
2436.034958 -1.461 5.3371
2436.767380 -1.504 5.4232
2437.499801 -1.505 5.3651
2438.232223 -1.499 5.3582
2438.964645 -1.501 5.6910
2439.697067 -1.528 5.5751
2440.429489 -1.544 5.6108
2441.161910 -1.560 5.6814
2441.894332 -1.555 5.6741
2442.626754 -1.558 5.7966
2443.359176 -1.586 6.0658
2444.091598 -1.566 5.8296
2444.824019 -1.554 5.9390
2445.556441 -1.537 6.1591
2446.288863 -1.560 6.1908
2447.021285 -1.533 6.2904
2447.753707 -1.557 6.1726
2448.486129 -1.521 6.1007
2449.218550 -1.533 6.0955
2449.950972 -1.545 6.1673
2450.683394 -1.520 6.1499
2451.415816 -1.565 6.1954
2452.148238 -1.539 6.1097
2452.880659 -1.536 5.8876
2453.613081 -1.544 6.0602
2454.345503 -1.560 5.8390
2455.077925 -1.574 5.6225
2455.810347 -1.607 5.7095
2456.542769 -1.548 5.5378
2457.275190 -1.597 5.5631
2458.007612 -1.630 5.5138
2458.740034 -1.587 5.3049
2459.472456 -1.622 5.1136
2460.204878 -1.628 5.2312
2460.937299 -1.667 5.2009
2461.669721 -1.698 5.0776
2462.402143 -1.652 5.0103
2463.134565 -1.659 5.1086
2463.866987 -1.712 5.2681
2464.599409 -1.710 4.9534
2465.331830 -1.753 4.9930
2466.064252 -1.758 4.8739
2466.796674 -1.762 5.0344
2467.529096 -1.783 5.1165
2468.261518 -1.768 4.9688
2468.993939 -1.771 4.9260
2469.726361 -1.799 5.1207
2470.458783 -1.786 4.7106
2471.191205 -1.787 4.8118
2471.923627 -1.803 4.8307
2472.656048 -1.833 4.9073
2473.388470 -1.858 4.8123
2474.120892 -1.864 4.6384
2474.853314 -1.876 4.5201
2475.585736 -1.891 4.4755
2476.318158 -1.930 4.5828
2477.050579 -1.949 4.4288
2477.783001 -1.959 4.5142
2478.515423 -2.002 4.2744
2479.247845 -2.026 4.5305
2479.980267 -2.015 4.0758
2480.712688 -2.051 4.3876
2481.445110 -2.067 4.4324
2482.177532 -2.084 4.4037
2482.909954 -2.103 4.2963
2483.642376 -2.118 4.3683
2484.374798 -2.148 4.4178
2485.107219 -2.193 4.4426
2485.839641 -2.172 4.2233
2486.572063 -2.176 4.3016
2487.304485 -2.216 4.4238
2488.036907 -2.238 4.5061
2488.769328 -2.259 4.4613
2489.501750 -2.275 4.4017
2490.234172 -2.284 4.4609
2490.966594 -2.287 4.4603
2491.699016 -2.334 4.3032
2492.431437 -2.306 4.4502
2493.163859 -2.359 4.5964
2493.896281 -2.375 4.6880
2494.628703 -2.390 4.6732
2495.361125 -2.441 4.7443
2496.093547 -2.441 4.8351
2496.825968 -2.432 4.9484
2497.558390 -2.439 4.7688
2498.290812 -2.481 5.0668
2499.023234 -2.446 5.1616
2499.755656 -2.494 5.4249
2500.488077 -2.517 5.5713
2501.220499 -2.486 5.7853
2501.952921 -2.503 5.8932
2502.685343 -2.473 6.0488
2503.417765 -2.505 5.8683
2504.150187 -2.468 5.9802
2504.882608 -2.466 6.3434
2505.615030 -2.453 6.0984
2506.347452 -2.418 6.1780
2507.079874 -2.434 6.1542
2507.812296 -2.384 6.3397
2508.544717 -2.405 6.2776
2509.277139 -2.417 5.8765
2510.009561 -2.360 5.8519
2510.741983 -2.339 5.9205
2511.474405 -2.368 5.8192
2512.206827 -2.394 5.4763
2512.939248 -2.407 5.3997
2513.671670 -2.430 5.2421
2514.404092 -2.375 5.2018
2515.136514 -2.441 4.8776
2515.868936 -2.483 4.8605
2516.601357 -2.484 4.7959
2517.333779 -2.493 4.8739
2518.066201 -2.542 4.6808
2518.798623 -2.561 4.7924
2519.531045 -2.595 4.7424
2520.263466 -2.613 4.9976
2520.995888 -2.642 4.7875
2521.728310 -2.670 5.0563
2522.460732 -2.672 5.1325
2523.193154 -2.671 5.3333
2523.925576 -2.704 5.5576
2524.657997 -2.650 5.5372
2525.390419 -2.679 5.5671
2526.122841 -2.656 5.6461
2526.855263 -2.672 5.5472
2527.587685 -2.651 5.7355
2528.320106 -2.617 5.6751
2529.052528 -2.599 5.4331
2529.784950 -2.626 5.4641
2530.517372 -2.616 5.3444
2531.249794 -2.638 5.2697
2531.982216 -2.675 5.2411
2532.714637 -2.689 4.7168
2533.447059 -2.703 4.7877
2534.179481 -2.709 4.6484
2534.911903 -2.731 4.5684
2535.644325 -2.797 4.3746
2536.376746 -2.807 4.3592
2537.109168 -2.829 4.1885
2537.841590 -2.863 3.8275
2538.574012 -2.957 4.1409
2539.306434 -2.989 4.1655
2540.038855 -3.003 4.3049
2540.771277 -3.044 4.4584
2541.503699 -3.079 4.6545
2542.236121 -3.105 5.1091
2542.968543 -3.110 5.0198
2543.700965 -3.094 5.1738
2544.433386 -3.156 5.5623
2545.165808 -3.100 5.8002
2545.898230 -3.116 5.7391
2546.630652 -3.060 6.0267
2547.363074 -3.061 6.3530
2548.095495 -3.032 6.2860
2548.827917 -3.011 6.3802
2549.560339 -2.966 6.1783
2550.292761 -2.985 6.1278
2551.025183 -2.913 6.0305
2551.757605 -2.847 5.8961
2552.490026 -2.870 5.8583
2553.222448 -2.874 5.5605
2553.954870 -2.883 5.4512
2554.687292 -2.875 4.9531
2555.419714 -2.896 4.9608
2556.152135 -2.943 4.5385
2556.884557 -2.993 4.4224
2557.616979 -2.963 3.9596
2558.349401 -2.992 4.0187
2559.081823 -3.031 4.3075
2559.814245 -3.112 3.8020
2560.546666 -3.162 3.6932
2561.279088 -3.196 3.5385
2562.011510 -3.305 3.7709
2562.743932 -3.301 4.0488
2563.476354 -3.363 3.5891
2564.208775 -3.370 4.0588
2564.941197 -3.423 4.6231
2565.673619 -3.433 4.9161
2566.406041 -3.439 4.7711
2567.138463 -3.420 4.7028
2567.870884 -3.460 5.0214
2568.603306 -3.438 5.4458
2569.335728 -3.444 5.5425
2570.068150 -3.439 5.3961
2570.800572 -3.338 5.8431
2571.532994 -3.380 5.5824
2572.265415 -3.358 5.8138
2572.997837 -3.358 5.4033
2573.730259 -3.385 5.6078
2574.462681 -3.339 5.4721
2575.195103 -3.340 5.0826
2575.927524 -3.322 4.8995
2576.659946 -3.371 4.9935
2577.392368 -3.339 4.8776
2578.124790 -3.334 5.2595
2578.857212 -3.350 5.2809
2579.589634 -3.411 4.8726
2580.322055 -3.366 5.2864
2581.054477 -3.436 5.2030
2581.786899 -3.464 4.8567
2582.519321 -3.452 5.0055
2583.251743 -3.495 5.1130
2583.984164 -3.552 4.9167
2584.716586 -3.592 5.0428
2585.449008 -3.574 5.4750
2586.181430 -3.586 5.4911
2586.913852 -3.597 5.6299
2587.646273 -3.612 5.5714
2588.378695 -3.538 5.7886
2589.111117 -3.590 6.1060
2589.843539 -3.569 6.0691
2590.575961 -3.650 6.0122
2591.308383 -3.609 6.0502
2592.040804 -3.556 6.0394
2592.773226 -3.605 6.0135
2593.505648 -3.569 5.8511
2594.238070 -3.527 5.6295
2594.970492 -3.565 5.7206
2595.702913 -3.581 5.5002
2596.435335 -3.600 5.5716
2597.167757 -3.571 5.4791
2597.900179 -3.604 5.2505
2598.632601 -3.587 4.9067
2599.365023 -3.643 4.9891
2600.097444 -3.644 5.1106
2600.829866 -3.676 4.8505
2601.562288 -3.731 4.6904
2602.294710 -3.715 4.5708
2603.027132 -3.788 5.0029
2603.759553 -3.732 4.8046
2604.491975 -3.821 4.9213
2605.224397 -3.759 5.0502
2605.956819 -3.785 5.0861
2606.689241 -3.775 5.1046
2607.421663 -3.797 5.0587
2608.154084 -3.854 5.5527
2608.886506 -3.842 5.4863
2609.618928 -3.792 5.5131
2610.351350 -3.843 5.7916
2611.083772 -3.839 5.3575
2611.816193 -3.777 5.3907
2612.548615 -3.822 5.3388
2613.281037 -3.790 5.3171
2614.013459 -3.805 5.1154
2614.745881 -3.737 5.1940
2615.478302 -3.792 4.9519
2616.210724 -3.789 4.7476
2616.943146 -3.856 4.6901
2617.675568 -3.812 4.3256
2618.407990 -3.895 4.4587
2619.140412 -3.974 3.8923
2619.872833 -4.054 4.3561
2620.605255 -3.985 4.5209
2621.337677 -4.062 4.1993
2622.070099 -4.074 4.1170
2622.802521 -4.107 4.3253
2623.534942 -4.125 4.4088
2624.267364 -4.134 4.5186
2624.999786 -4.176 4.2766
2625.732208 -4.206 4.0939
2626.464630 -4.191 4.9353
2627.197052 -4.246 4.2650
2627.929473 -4.239 4.6821
2628.661895 -4.223 4.7598
2629.394317 -4.221 4.7573
2630.126739 -4.263 5.2223
2630.859161 -4.305 5.2533
2631.591582 -4.254 5.6764
2632.324004 -4.210 5.3685
2633.056426 -4.245 5.1586
2633.788848 -4.224 5.2061
2634.521270 -4.251 5.4888
2635.253691 -4.196 5.0324
2635.986113 -4.260 5.1545
2636.718535 -4.278 5.3865
2637.450957 -4.264 5.4054
2638.183379 -4.244 5.2490
2638.915801 -4.284 5.1252
2639.648222 -4.323 5.4637
2640.380644 -4.345 5.6001
2641.113066 -4.408 5.5594
2641.845488 -4.364 5.0692
2642.577910 -4.425 5.8420
2643.310331 -4.410 5.9370
2644.042753 -4.368 6.0677
2644.775175 -4.384 5.8445
2645.507597 -4.430 6.2899
2646.240019 -4.377 5.9322
2646.972441 -4.399 6.3938
2647.704862 -4.357 6.5122
2648.437284 -4.334 6.7180
2649.169706 -4.341 6.7263
2649.902128 -4.345 6.7711
2650.634550 -4.296 6.7679
2651.366971 -4.266 6.5757
2652.099393 -4.291 6.3862
2652.831815 -4.303 6.0276
2653.564237 -4.241 5.9434
2654.296659 -4.245 6.2316
2655.029081 -4.200 6.0889
2655.761502 -4.174 5.5582
2656.493924 -4.226 5.2070
2657.226346 -4.204 5.2266
2657.958768 -4.230 4.9326
2658.691190 -4.255 4.5102
2659.423611 -4.280 4.4368
2660.156033 -4.320 4.3940
2660.888455 -4.389 4.4071
2661.620877 -4.421 4.1409
2662.353299 -4.466 4.0128
2663.085720 -4.497 4.3299
2663.818142 -4.489 4.5284
2664.550564 -4.598 4.4094
2665.282986 -4.635 4.8804
2666.015408 -4.658 4.7379
2666.747830 -4.653 5.1348
2667.480251 -4.693 4.8317
2668.212673 -4.665 5.1006
2668.945095 -4.683 5.7386
2669.677517 -4.660 5.7576
2670.409939 -4.705 6.0330
2671.142360 -4.653 5.9256
2671.874782 -4.721 6.0717
2672.607204 -4.726 6.0282
2673.339626 -4.618 5.9760
2674.072048 -4.709 6.0604
2674.804470 -4.648 6.1444
2675.536891 -4.583 5.6629
2676.269313 -4.619 5.9578
2677.001735 -4.591 5.6260
2677.734157 -4.537 5.7177
2678.466579 -4.606 5.2784
2679.199000 -4.634 5.2923
2679.931422 -4.621 4.8094
2680.663844 -4.666 4.6152
2681.396266 -4.638 4.6576
2682.128688 -4.697 4.2883
2682.861109 -4.728 4.3622
2683.593531 -4.743 4.1444
2684.325953 -4.789 4.0908
2685.058375 -4.786 3.9878
2685.790797 -4.806 4.2666
2686.523219 -4.825 4.5443
2687.255640 -4.883 4.3964
2687.988062 -4.911 4.7308
2688.720484 -4.944 4.3353
2689.452906 -4.861 4.7604
2690.185328 -4.914 4.8156
2690.917749 -4.932 4.9199
2691.650171 -4.948 5.1228
2692.382593 -4.941 5.4395
2693.115015 -4.944 5.2112
2693.847437 -4.923 5.6320
2694.579859 -4.898 5.4384
2695.312280 -4.862 5.7407
2696.044702 -4.864 5.7796
2696.777124 -4.812 5.6068
2697.509546 -4.813 5.4272
2698.241968 -4.776 5.5235
2698.974389 -4.868 5.3260
2699.706811 -4.827 5.1405
2700.439233 -4.847 5.0549
2701.171655 -4.781 4.7562
2701.904077 -4.848 4.4895
2702.636499 -4.817 4.2815
2703.368920 -4.884 3.9236
2704.101342 -4.902 3.8054
2704.833764 -4.941 3.7891
2705.566186 -4.998 3.8462
2706.298608 -5.022 3.5577
2707.031029 -5.093 3.4106
2707.763451 -5.115 3.4641
2708.495873 -5.209 3.1676
2709.228295 -5.217 3.6453
2709.960717 -5.242 3.6484
2710.693138 -5.277 3.5570
2711.425560 -5.325 4.0026
2712.157982 -5.292 3.8394
2712.890404 -5.244 4.2432
2713.622826 -5.312 4.4595
2714.355248 -5.353 4.6094
2715.087669 -5.328 4.8755
2715.820091 -5.379 5.2340
2716.552513 -5.450 5.2085
2717.284935 -5.286 5.3748
2718.017357 -5.381 5.2623
2718.749778 -5.323 5.6145
2719.482200 -5.321 6.0441
2720.214622 -5.303 5.6716
2720.947044 -5.325 6.0883
2721.679466 -5.278 5.8996
2722.411888 -5.305 5.6953
2723.144309 -5.283 6.0250
2723.876731 -5.292 5.6003
2724.609153 -5.250 5.2316
2725.341575 -5.260 5.2840
2726.073997 -5.288 5.3571
2726.806418 -5.278 5.2529
2727.538840 -5.272 5.3001
2728.271262 -5.299 5.1669
2729.003684 -5.362 5.1677
2729.736106 -5.360 5.0536
2730.468527 -5.323 5.0642
2731.200949 -5.400 5.0128
2731.933371 -5.460 5.1454
2732.665793 -5.467 4.8683
2733.398215 -5.443 5.0249
2734.130637 -5.507 5.2507
2734.863058 -5.453 5.0390
2735.595480 -5.494 5.3915
2736.327902 -5.477 5.0524
2737.060324 -5.516 5.1361
2737.792746 -5.487 5.3581
2738.525167 -5.486 5.6918
2739.257589 -5.451 5.2815
2739.990011 -5.489 5.7311
2740.722433 -5.436 5.5151
2741.454855 -5.469 5.4847
2742.187277 -5.438 5.5593
2742.919698 -5.425 5.3141
2743.652120 -5.384 5.2747
2744.384542 -5.451 5.2772
2745.116964 -5.429 4.7854
2745.849386 -5.413 5.2181
2746.581807 -5.401 4.9210
2747.314229 -5.434 4.5287
2748.046651 -5.454 4.1522
2748.779073 -5.500 4.2486
2749.511495 -5.468 3.9381
2750.243917 -5.520 4.3497
2750.976338 -5.519 3.9114
2751.708760 -5.560 3.9482
2752.441182 -5.645 3.9973
2753.173604 -5.671 3.8602
2753.906026 -5.658 3.8751
2754.638447 -5.712 3.9291
2755.370869 -5.766 4.0096
2756.103291 -5.774 3.7878
2756.835713 -5.816 4.0189
2757.568135 -5.878 4.4016
2758.300556 -5.860 4.1959
2759.032978 -5.887 4.3658
2759.765400 -5.869 4.2218
2760.497822 -5.939 4.7595
2761.230244 -5.881 4.5977
2761.962666 -5.928 4.8761
2762.695087 -5.915 5.0801
2763.427509 -5.907 5.1931
2764.159931 -5.895 5.0182
2764.892353 -5.901 5.4190
2765.624775 -5.923 4.9632
2766.357196 -5.914 4.7566
2767.089618 -5.927 5.0193
2767.822040 -5.871 5.1751
2768.554462 -5.927 4.8887
2769.286884 -5.909 5.2975
2770.019306 -5.900 5.1436
2770.751727 -5.913 5.3907
2771.484149 -5.951 4.9262
2772.216571 -5.922 5.0288
2772.948993 -5.948 5.1246
2773.681415 -5.955 5.0175
2774.413836 -5.938 5.0633
2775.146258 -5.951 5.0790
2775.878680 -5.950 5.0775
2776.611102 -5.968 5.0016
2777.343524 -5.945 4.9750
2778.075945 -5.969 5.1191
2778.808367 -5.959 5.4786
2779.540789 -5.953 5.2804
2780.273211 -6.003 5.2324
2781.005633 -5.921 5.1110
2781.738055 -5.954 4.8387
2782.470476 -5.926 5.3618
2783.202898 -5.964 5.0050
2783.935320 -5.935 4.9231
2784.667742 -5.945 4.6473
2785.400164 -5.929 4.8591
2786.132585 -6.010 4.3989
2786.865007 -5.987 4.5774
2787.597429 -5.969 4.1675
2788.329851 -6.055 4.2907
2789.062273 -6.027 3.9594
2789.794695 -6.056 3.6168
2790.527116 -6.088 3.5125
2791.259538 -6.101 3.9963
2791.991960 -6.175 3.6225
2792.724382 -6.134 3.6893
2793.456804 -6.177 3.6760
2794.189225 -6.239 3.7866
2794.921647 -6.283 3.5833
2795.654069 -6.283 3.8326
2796.386491 -6.368 3.6919
2797.118913 -6.267 4.0312
2797.851335 -6.368 3.9133
2798.583756 -6.342 4.0712
2799.316178 -6.344 4.2328
2800.048600 -6.361 4.7825
2800.781022 -6.366 4.1688
2801.513444 -6.393 4.6665
2802.245865 -6.374 4.8312
2802.978287 -6.408 4.6632
2803.710709 -6.422 4.7708
2804.443131 -6.365 4.6274
2805.175553 -6.391 4.6097
2805.907974 -6.432 4.7549
2806.640396 -6.438 4.4271
2807.372818 -6.437 4.6181
2808.105240 -6.427 4.2159
2808.837662 -6.436 4.4650
2809.570084 -6.463 4.0986
2810.302505 -6.455 4.2776
2811.034927 -6.552 4.3999
2811.767349 -6.494 4.5310
2812.499771 -6.548 4.4008
2813.232193 -6.508 4.1487
2813.964614 -6.611 4.6544
2814.697036 -6.519 4.5519
2815.429458 -6.574 4.8538
2816.161880 -6.626 5.1256
2816.894302 -6.625 4.8219
2817.626724 -6.635 5.2161
2818.359145 -6.637 5.4147
2819.091567 -6.612 5.7411
2819.823989 -6.604 5.7401
2820.556411 -6.551 5.8142
2821.288833 -6.580 5.9371
2822.021254 -6.577 5.9502
2822.753676 -6.503 5.8448
2823.486098 -6.508 5.7155
2824.218520 -6.547 5.7078
2824.950942 -6.480 5.8901
2825.683363 -6.462 5.6622
2826.415785 -6.408 5.7869
2827.148207 -6.468 5.6708
2827.880629 -6.452 5.2180
2828.613051 -6.504 5.0253
2829.345473 -6.459 4.9604
2830.077894 -6.514 4.7799
2830.810316 -6.481 4.4866
2831.542738 -6.494 4.4537
2832.275160 -6.527 3.8169
2833.007582 -6.598 4.4064
2833.740003 -6.649 4.3491
2834.472425 -6.698 3.9975
2835.204847 -6.681 3.9532
2835.937269 -6.754 4.0626
2836.669691 -6.754 4.1016
2837.402113 -6.832 4.1395
2838.134534 -6.789 4.1425
2838.866956 -6.836 4.8478
2839.599378 -6.916 4.6404
2840.331800 -6.914 4.4121
2841.064222 -6.846 5.1619
2841.796643 -6.886 5.1009
2842.529065 -6.864 5.1837
2843.261487 -6.894 5.8539
2843.993909 -6.827 5.4780
2844.726331 -6.806 5.3823
2845.458753 -6.820 5.8138
2846.191174 -6.762 5.5116
2846.923596 -6.710 5.5322
2847.656018 -6.728 5.4413
2848.388440 -6.724 5.7349
2849.120862 -6.690 5.5244
2849.853283 -6.671 5.4730
2850.585705 -6.637 5.0221
2851.318127 -6.699 4.8469
2852.050549 -6.743 4.4879
2852.782971 -6.707 4.3334
2853.515392 -6.750 4.4066
2854.247814 -6.799 3.9471
2854.980236 -6.797 3.9021
2855.712658 -6.857 3.5736
2856.445080 -6.859 3.5532
2857.177502 -6.899 4.0413
2857.909923 -6.931 3.4934
2858.642345 -6.960 3.5255
2859.374767 -7.007 3.6486
2860.107189 -7.011 4.0818
2860.839611 -7.067 3.7767
2861.572032 -7.037 4.0959
2862.304454 -7.074 4.3231
2863.036876 -7.081 4.5300
2863.769298 -7.137 4.5120
2864.501720 -7.111 4.3256
2865.234142 -7.112 4.7876
2865.966563 -7.119 4.6533
2866.698985 -7.113 4.5950
2867.431407 -7.102 4.5688
2868.163829 -7.140 4.5623
2868.896251 -7.089 5.0853
2869.628672 -7.136 4.5608
2870.361094 -7.129 4.7621
2871.093516 -7.135 4.7687
2871.825938 -7.093 4.3909
2872.558360 -7.112 4.6493
2873.290781 -7.147 4.3317
2874.023203 -7.129 4.6852
2874.755625 -7.159 4.4124
2875.488047 -7.229 4.2866
2876.220469 -7.177 4.2932
2876.952891 -7.244 4.2537
2877.685312 -7.217 4.1879
2878.417734 -7.250 4.2957
2879.150156 -7.305 4.3445
2879.882578 -7.220 4.2466
2880.615000 -7.238 4.6288
2881.347421 -7.322 4.7257
2882.079843 -7.362 4.3011
2882.812265 -7.358 4.7998
2883.544687 -7.320 5.0034
2884.277109 -7.351 5.2758
2885.009531 -7.349 4.8729
2885.741952 -7.320 4.8225
2886.474374 -7.358 5.2460
2887.206796 -7.396 5.1132
2887.939218 -7.327 5.0514
2888.671640 -7.373 4.8888
2889.404061 -7.308 5.3387
2890.136483 -7.369 5.2681
2890.868905 -7.413 5.0087
2891.601327 -7.407 5.1428
2892.333749 -7.374 5.3741
2893.066171 -7.406 5.0682
2893.798592 -7.479 4.9783
2894.531014 -7.470 5.0259
2895.263436 -7.406 4.8717
2895.995858 -7.446 5.0516
2896.728280 -7.478 5.1162
2897.460701 -7.484 5.2200
2898.193123 -7.408 5.1802
2898.925545 -7.501 5.5073
2899.657967 -7.517 5.1711
2900.390389 -7.511 5.8065
2901.122810 -7.472 5.3772
2901.855232 -7.461 5.7874
2902.587654 -7.534 5.8415
2903.320076 -7.532 6.1505
2904.052498 -7.410 5.8906
2904.784920 -7.418 5.9176
2905.517341 -7.466 5.7637
2906.249763 -7.496 6.0089
2906.982185 -7.450 5.8895
2907.714607 -7.487 5.6373
2908.447029 -7.512 5.3848
2909.179450 -7.510 5.3030
2909.911872 -7.465 4.4884
2910.644294 -7.448 5.1675
2911.376716 -7.491 5.1031
2912.109138 -7.461 4.8809
2912.841560 -7.466 4.6566
2913.573981 -7.534 4.7446
2914.306403 -7.463 4.7635
2915.038825 -7.495 4.0591
2915.771247 -7.468 3.9847
2916.503669 -7.517 4.3118
2917.236090 -7.558 3.8713
2917.968512 -7.561 3.9390
2918.700934 -7.727 4.0964
2919.433356 -7.770 4.1146
2920.165778 -7.760 4.4314
2920.898199 -7.827 4.6305
2921.630621 -7.843 3.6918
2922.363043 -7.803 4.4602
2923.095465 -7.847 4.6650
2923.827887 -7.930 4.2830
2924.560309 -7.778 4.0492
2925.292730 -7.841 4.8291
2926.025152 -7.926 5.1827
2926.757574 -7.880 4.8915
2927.489996 -7.932 4.2424
2928.222418 -7.807 4.4799
2928.954839 -7.952 5.5460
2929.687261 -7.773 5.0138
2930.419683 -7.810 5.2898
2931.152105 -7.732 5.2158
2931.884527 -7.725 5.3408
2932.616949 -7.776 4.5062
2933.349370 -7.651 3.7859
2934.081792 -7.633 4.4868
2934.814214 -7.686 4.3765
2935.546636 -7.767 3.6718
2936.279058 -7.653 3.2551
2937.011479 -7.813 3.9293
2937.743901 -7.925 3.9636
2938.476323 -7.885 3.8149
2939.208745 -7.848 3.2319
2939.941167 -7.908 2.0898
2940.673589 -8.004 3.1610
2941.406010 -8.010 3.5707
2942.138432 -8.197 3.1792
2942.870854 -8.209 3.0862
2943.603276 -8.155 3.3067
2944.335698 -8.238 2.3478
2945.068119 -8.168 2.9294
2945.800541 -8.220 3.9062
2946.532963 -8.226 4.1298
2947.265385 -8.349 4.6203
2947.997807 -8.467 4.5350
2948.730228 -8.310 5.8759
2949.462650 -8.309 4.9086
2950.195072 -8.262 5.9377
2950.927494 -8.356 6.4580
2951.659916 -8.246 5.6115
2952.392338 -8.372 6.4427
2953.124759 -8.075 6.2016
2953.857181 -8.479 5.4181
2954.589603 -8.249 6.3163
2955.322025 -8.196 5.1061
2956.054447 -8.082 4.8408
2956.786868 -8.074 3.7454
2957.519290 -8.049 5.6180
2958.251712 -8.064 4.6653
2958.984134 -7.954 4.3307
2959.716556 -8.139 3.0215
2960.448978 -8.039 3.1164
2961.181399 -7.997 3.5912
2961.913821 -8.111 3.5839
2962.646243 -8.246 2.6384
2963.378665 -8.231 1.4819
2964.111087 -8.182 4.5767
2964.843508 -8.393 2.8915
2965.575930 -8.443 3.7244
2966.308352 -8.525 3.8958
2967.040774 -8.509 3.3005
2967.773196 -8.418 4.1984
2968.505617 -8.581 4.3733
2969.238039 -8.452 4.0786
2969.970461 -8.500 4.6962
2970.702883 -8.511 3.5713
2971.435305 -8.643 3.6448
2972.167727 -8.496 5.0056
2972.900148 -8.613 5.4014
2973.632570 -8.392 5.9463
2974.364992 -8.696 6.8519
2975.097414 -8.585 6.2109
2975.829836 -8.452 6.3734
2976.562257 -8.188 5.9586
2977.294679 -8.415 6.3414
2978.027101 -8.250 4.8433
2978.759523 -8.219 5.9657
2979.491945 -8.244 5.7198
2980.224367 -8.262 5.5923
2980.956788 -8.047 4.3882
2981.689210 -8.317 4.9789
2982.421632 -8.426 5.1285
2983.154054 -8.274 3.5167
2983.886476 -8.300 4.5807
2984.618897 -8.314 3.4455
2985.351319 -8.149 3.3416
2986.083741 -8.398 2.9937
2986.816163 -8.399 4.4856
2987.548585 -8.358 3.5616
2988.281007 -8.664 3.7528
2989.013428 -8.788 3.7260
2989.745850 -8.876 2.2162
2990.478272 -8.673 4.2366
2991.210694 -8.710 4.7876
2991.943116 -8.799 5.0125
2992.675537 -8.825 3.9618
2993.407959 -8.994 4.7380
2994.140381 -8.642 4.4602
2994.872803 -8.774 5.6366
2995.605225 -8.822 5.3154
2996.337646 -8.440 4.4702
2997.070068 -8.674 5.8702
2997.802490 -8.532 5.7355
2998.534912 -8.587 5.2719
2999.267334 -8.579 6.2729
2999.999756 -8.638 5.3174
3000.732177 -8.565 5.1658
3001.464599 -8.556 6.1658
3002.197021 -8.466 5.0134
3002.929443 -8.638 4.8342
3003.661865 -8.750 4.0121
3004.394286 -8.722 4.5433
3005.126708 -8.727 4.1094
3005.859130 -8.810 3.9148
3006.591552 -8.611 4.3423
3007.323974 -8.629 3.9727
3008.056396 -8.476 4.8214
3008.788817 -8.651 2.8082
3009.521239 -8.752 4.0239
3010.253661 -8.988 3.0205
3010.986083 -8.713 3.9647
3011.718505 -8.740 3.9548
3012.450926 -8.886 4.1499
3013.183348 -8.846 4.8627
3013.915770 -8.976 4.1086
3014.648192 -8.982 4.2292
3015.380614 -8.856 4.3867
3016.113036 -8.921 4.6049
3016.845457 -8.997 4.9430
3017.577879 -8.792 5.3589
3018.310301 -8.744 3.9954
3019.042723 -8.845 3.6276
3019.775145 -8.700 4.5955
3020.507566 -8.799 4.6316
3021.239988 -8.695 4.3037
3021.972410 -8.940 4.9283
3022.704832 -8.808 5.0781
3023.437254 -8.887 3.2780
3024.169675 -9.020 3.1462
3024.902097 -9.157 3.1816
3025.634519 -8.869 2.4520
3026.366941 -9.035 3.0308
3027.099363 -9.016 4.2673
3027.831785 -9.077 3.4592
3028.564206 -9.115 4.6055
3029.296628 -9.175 3.5657
3030.029050 -9.186 4.2975
3030.761472 -9.215 3.8602
3031.493894 -9.069 4.3223
3032.226315 -9.065 5.0807
3032.958737 -9.084 5.4190
3033.691159 -9.116 4.9727
3034.423581 -9.079 5.1455
3035.156003 -9.111 6.0099
3035.888425 -9.085 4.6819
3036.620846 -9.007 6.3815
3037.353268 -9.109 6.5311
3038.085690 -8.873 5.2867
3038.818112 -9.077 5.2825
3039.550534 -9.130 5.7064
3040.282955 -9.059 4.6907
3041.015377 -9.132 4.7797
3041.747799 -8.945 3.5560
3042.480221 -9.211 2.8923
3043.212643 -9.140 3.8088
3043.945064 -9.105 3.2432
3044.677486 -9.106 3.1521
3045.409908 -9.240 0.8477
3046.142330 -9.242 2.8967
3046.874752 -9.395 3.4704
3047.607174 -9.136 3.8309
3048.339595 -9.312 4.9462
3049.072017 -9.423 3.6486
3049.804439 -9.519 4.8357
3050.536861 -9.408 4.4487
3051.269283 -9.570 3.9811
3052.001704 -9.395 3.8222
3052.734126 -9.571 4.5583
3053.466548 -9.550 5.5696
3054.198970 -9.584 5.6196
3054.931392 -9.570 5.5314
3055.663814 -9.305 5.0215
3056.396235 -9.488 6.6432
3057.128657 -9.531 7.1840
3057.861079 -9.311 4.7665
3058.593501 -9.457 6.3885
3059.325923 -9.278 7.1906
3060.058344 -9.186 6.9922
3060.790766 -9.355 6.5428
3061.523188 -9.162 5.8748
3062.255610 -9.117 5.5360
3062.988032 -9.126 5.3057
3063.720454 -9.107 5.6866
3064.452875 -9.285 5.0178
3065.185297 -9.126 4.7600
3065.917719 -9.183 4.5043
3066.650141 -9.321 4.1511
3067.382563 -9.308 3.2959
3068.114984 -9.291 3.7991
3068.847406 -9.469 3.9774
3069.579828 -9.509 3.7985
3070.312250 -9.435 4.2918
3071.044672 -9.579 4.1855
3071.777093 -9.418 3.8304
3072.509515 -9.547 4.0143
3073.241937 -9.624 4.3016
3073.974359 -9.681 5.1198
3074.706781 -9.561 5.1469
3075.439203 -9.460 5.0908
3076.171624 -9.531 5.2892
3076.904046 -9.649 6.0063
3077.636468 -9.638 5.4927
3078.368890 -9.530 5.8456
3079.101312 -9.548 5.6251
3079.833733 -9.480 6.0908
3080.566155 -9.496 5.9819
3081.298577 -9.541 6.0219
3082.030999 -9.485 5.2924
3082.763421 -9.288 5.6735
3083.495843 -9.391 5.9021
3084.228264 -9.370 5.9650
3084.960686 -9.414 4.8379
3085.693108 -9.282 4.2804
3086.425530 -9.489 5.3182
3087.157952 -9.484 5.2488
3087.890373 -9.446 4.3908
3088.622795 -9.507 3.8488
3089.355217 -9.545 3.5665
3090.087639 -9.592 4.0991
3090.820061 -9.797 4.2071
3091.552482 -9.651 3.7429
3092.284904 -9.695 4.7138
3093.017326 -9.725 4.7148
3093.749748 -9.832 4.3226
3094.482170 -9.806 4.4449
3095.214592 -9.934 4.7394
3095.947013 -9.879 4.7861
3096.679435 -9.795 4.8027
3097.411857 -9.886 4.8638
3098.144279 -9.972 5.2025
3098.876701 -9.867 5.7892
3099.609122 -9.793 6.0770
3100.341544 -9.803 5.4305
3101.073966 -9.855 5.3318
3101.806388 -9.765 4.6533
3102.538810 -9.841 5.1651
3103.271232 -9.724 5.0458
3104.003653 -9.768 4.7299
3104.736075 -9.902 4.8755
3105.468497 -9.825 4.7966
3106.200919 -9.860 4.7444
3106.933341 -9.910 4.5592
3107.665762 -9.882 4.7471
3108.398184 -9.863 4.2856
3109.130606 -9.976 3.8370
3109.863028 -9.988 4.4483
3110.595450 -9.983 4.3178
3111.327872 -10.017 4.8538
3112.060293 -9.996 4.5992
3112.792715 -10.042 5.1244
3113.525137 -9.986 5.4604
3114.257559 -10.126 5.8311
3114.989981 -10.076 5.4949
3115.722402 -9.968 5.8083
3116.454824 -10.101 6.0674
3117.187246 -10.050 6.0270
3117.919668 -9.953 5.8085
3118.652090 -10.030 5.5857
3119.384511 -9.973 5.7491
3120.116933 -9.968 6.0938
3120.849355 -9.927 5.2745
3121.581777 -9.903 5.6392
3122.314199 -9.909 4.8490
3123.046621 -9.905 4.8983
3123.779042 -9.860 4.5322
3124.511464 -9.947 5.2967
3125.243886 -9.868 4.5372
3125.976308 -9.975 4.5366
3126.708730 -9.973 4.2106
3127.441151 -10.038 4.1661
3128.173573 -10.007 4.4155
3128.905995 -10.045 4.2069
3129.638417 -10.066 3.8607
3130.370839 -10.092 3.9954
3131.103261 -10.029 3.7358
3131.835682 -10.229 4.4097
3132.568104 -10.229 3.9285
3133.300526 -10.160 4.0873
3134.032948 -10.139 4.3706
3134.765370 -10.259 4.5096
3135.497791 -10.324 5.0601
3136.230213 -10.229 5.5342
3136.962635 -10.250 5.3374
3137.695057 -10.179 5.8091
3138.427479 -10.246 5.6830
3139.159900 -10.161 6.1726
3139.892322 -10.163 5.6462
3140.624744 -10.121 5.1439
3141.357166 -10.177 5.1664
3142.089588 -10.148 4.9839
3142.822010 -10.187 4.4537
3143.554431 -10.116 4.7931
3144.286853 -10.163 4.3541
3145.019275 -10.072 4.5272
3145.751697 -10.156 4.2692
3146.484119 -10.104 3.9703
3147.216540 -10.191 3.6869
3147.948962 -10.150 3.2011
3148.681384 -10.185 2.7798
3149.413806 -10.198 3.6590
3150.146228 -10.245 2.8854
3150.878650 -10.303 3.0365
3151.611071 -10.333 2.7692
3152.343493 -10.328 3.1588
3153.075915 -10.394 2.2539
3153.808337 -10.504 3.5056
3154.540759 -10.407 2.5660
3155.273180 -10.460 3.4304
3156.005602 -10.615 3.1155
3156.738024 -10.595 4.0829
3157.470446 -10.586 3.5006
3158.202868 -10.532 3.5865
3158.935290 -10.625 3.6911
3159.667711 -10.595 4.0232
3160.400133 -10.541 4.1471
3161.132555 -10.502 4.5310
3161.864977 -10.575 4.5204
3162.597399 -10.552 4.4890
3163.329820 -10.574 4.4075
3164.062242 -10.455 5.0384
3164.794664 -10.434 5.2573
3165.527086 -10.438 5.3484
3166.259508 -10.445 5.2538
3166.991929 -10.353 4.7216
3167.724351 -10.451 5.0650
3168.456773 -10.346 4.7944
3169.189195 -10.445 4.5223
3169.921617 -10.419 4.7253
3170.654039 -10.372 4.4479
3171.386460 -10.403 4.9853
3172.118882 -10.500 4.1274
3172.851304 -10.393 4.3849
3173.583726 -10.489 3.7273
3174.316148 -10.497 4.1694
3175.048569 -10.501 4.2859
3175.780991 -10.599 3.3451
3176.513413 -10.618 2.3760
3177.245835 -10.769 3.3671
3177.978257 -10.778 2.9730
3178.710679 -10.727 3.3818
3179.443100 -10.771 3.4410
3180.175522 -10.785 2.6041
3180.907944 -10.845 3.4045
3181.640366 -10.756 3.4989
3182.372788 -10.706 3.6593
3183.105209 -10.744 4.1125
3183.837631 -10.819 4.0876
3184.570053 -10.904 3.2742
3185.302475 -10.983 3.8745
3186.034897 -10.859 4.1841
3186.767318 -11.114 4.1911
3187.499740 -10.783 4.5784
3188.232162 -10.741 4.3165
3188.964584 -10.730 4.9519
3189.697006 -10.662 5.0249
3190.429428 -10.591 5.0614
3191.161849 -10.676 4.9177
3191.894271 -10.623 5.0271
3192.626693 -10.601 4.9233
3193.359115 -10.679 5.1057
3194.091537 -10.497 4.3777
3194.823958 -10.536 4.7248
3195.556380 -10.547 5.0361
3196.288802 -10.493 4.3322
3197.021224 -10.603 4.0909
3197.753646 -10.507 3.9871
3198.486068 -10.440 3.7747
3199.218489 -10.531 3.8168
3199.950911 -10.651 3.8283
3200.683333 -10.619 4.1679
3201.415755 -10.647 2.9045
3202.148177 -10.608 2.8799
3202.880598 -10.743 2.9189
3203.613020 -10.659 2.8516
3204.345442 -10.700 3.1469
3205.077864 -10.834 2.7098
3205.810286 -10.921 2.5430
3206.542708 -10.839 2.8260
3207.275129 -10.921 3.3385
3208.007551 -10.908 2.4793
3208.739973 -11.063 2.8296
3209.472395 -10.989 2.7986
3210.204817 -10.962 3.4491
3210.937238 -11.004 3.1156
3211.669660 -11.060 2.2948
3212.402082 -10.866 2.7876
3213.134504 -10.938 2.6875
3213.866926 -11.004 2.4045
3214.599347 -11.032 2.7958
3215.331769 -10.965 2.2607
3216.064191 -10.959 2.7162
3216.796613 -11.020 2.9327
3217.529035 -11.051 2.7833
3218.261457 -10.916 2.4358
3218.993878 -11.128 2.4830
3219.726300 -11.110 2.2686
3220.458722 -11.216 2.3800
3221.191144 -11.084 2.0115
3221.923566 -11.246 2.1162
3222.655987 -11.269 2.3156
3223.388409 -11.395 2.4497
3224.120831 -11.255 2.9723
3224.853253 -11.377 2.7828
3225.585675 -11.323 2.9943
3226.318097 -11.503 3.5975
3227.050518 -11.479 3.3806
3227.782940 -11.434 3.9191
3228.515362 -11.458 3.7615
3229.247784 -11.484 4.0056
3229.980206 -11.397 4.5812
3230.712627 -11.427 4.0454
3231.445049 -11.534 4.6995
3232.177471 -11.470 4.8639
3232.909893 -11.483 4.7981
3233.642315 -11.381 5.5232
3234.374736 -11.349 4.7832
3235.107158 -11.361 5.2650
3235.839580 -11.210 4.7902
3236.572002 -11.253 5.0714
3237.304424 -11.225 4.5416
3238.036846 -11.183 5.2052
3238.769267 -11.270 4.8969
3239.501689 -11.136 4.3022
3240.234111 -11.130 4.6210
3240.966533 -11.277 4.1146
3241.698955 -11.143 4.0303
3242.431376 -11.206 4.2254
3243.163798 -11.238 3.9868
3243.896220 -11.409 5.0325
3244.628642 -11.266 4.0448
3245.361064 -11.328 3.6232
3246.093486 -11.360 3.9543
3246.825907 -11.385 4.7081
3247.558329 -11.234 4.3704
3248.290751 -11.440 4.3801
3249.023173 -11.371 3.7405
3249.755595 -11.435 5.0385
3250.488016 -11.418 4.0331
3251.220438 -11.251 4.5101
3251.952860 -11.341 4.6283
3252.685282 -11.335 5.7408
3253.417704 -11.210 4.7118
3254.150126 -11.281 4.1541
3254.882547 -11.231 4.8969
3255.614969 -11.244 4.9929
3256.347391 -11.249 4.6399
3257.079813 -11.170 4.3061
3257.812235 -11.133 3.8296
3258.544656 -11.174 4.2439
3259.277078 -11.159 2.3655
3260.009500 -11.156 2.6873
3260.741922 -11.193 2.4344
3261.474344 -11.190 1.7622
3262.206765 -11.292 2.2304
3262.939187 -11.328 1.5132
3263.671609 -11.329 1.0150
3264.404031 -11.384 1.2430
3265.136453 -11.436 0.5731
3265.868875 -11.461 0.1990
3266.601296 -11.572 0.5302
3267.333718 -11.584 1.0765
3268.066140 -11.672 0.4602
3268.798562 -11.692 0.3440
3269.530984 -11.700 1.1281
3270.263405 -11.760 2.3768
3270.995827 -11.764 1.1248
3271.728249 -11.899 1.6878
3272.460671 -11.905 1.7702
3273.193093 -11.869 2.3661
3273.925515 -11.959 2.5662
3274.657936 -11.954 2.6033
3275.390358 -12.032 2.2285
3276.122780 -12.001 2.9330
3276.855202 -11.992 2.1182
3277.587624 -12.048 2.5090
3278.320045 -11.926 3.2762
3279.052467 -11.942 3.8874
3279.784889 -12.018 2.7822
3280.517311 -11.968 2.8707
3281.249733 -12.038 2.8235
3281.982154 -12.017 3.3684
3282.714576 -12.122 2.5718
3283.446998 -12.146 3.7471
3284.179420 -12.193 2.8359
3284.911842 -12.182 3.7053
3285.644264 -12.264 3.3529
3286.376685 -12.294 3.6169
3287.109107 -12.194 4.1236
3287.841529 -12.279 4.8907
3288.573951 -12.364 4.0087
3289.306373 -12.309 4.4040
3290.038794 -12.232 5.0521
3290.771216 -12.145 5.7463
3291.503638 -12.274 4.9235
3292.236060 -12.312 6.2028
3292.968482 -12.204 5.6061
3293.700904 -12.130 5.2801
3294.433325 -12.197 5.0833
3295.165747 -12.214 6.2067
3295.898169 -12.133 6.1493
3296.630591 -12.086 6.5255
3297.363013 -12.094 6.2363
3298.095434 -12.136 5.4024
3298.827856 -12.056 6.2368
3299.560278 -11.961 6.6368
3300.292700 -12.030 4.9941
3301.025122 -12.002 5.5471
3301.757544 -12.034 5.5379
3302.489965 -11.847 5.8634
3303.222387 -12.043 5.5599
3303.954809 -12.020 5.2750
3304.687231 -12.002 5.5013
3305.419653 -11.930 5.6380
3306.152074 -12.067 5.9119
3306.884496 -12.031 6.0253
3307.616918 -11.971 5.8501
3308.349340 -12.018 5.7462
3309.081762 -12.009 5.9217
3309.814183 -11.935 6.1030
3310.546605 -12.060 5.9099
3311.279027 -11.917 5.6171
3312.011449 -12.016 6.0009
3312.743871 -11.861 5.8542
3313.476293 -11.859 5.3555
3314.208714 -11.914 5.7789
3314.941136 -11.898 5.1238
3315.673558 -11.723 4.5779
3316.405980 -11.764 4.0848
3317.138402 -11.685 3.3291
3317.870823 -11.939 3.2202
3318.603245 -11.886 3.3361
3319.335667 -11.933 3.2048
3320.068089 -11.948 2.8007
3320.800511 -12.018 3.0104
3321.532933 -11.974 3.0378
3322.265354 -12.186 3.2633
3322.997776 -12.017 2.5071
3323.730198 -12.260 2.5884
3324.462620 -12.184 2.8528
3325.195042 -12.300 1.8785
3325.927463 -12.256 2.7878
3326.659885 -12.370 3.9580
3327.392307 -12.353 2.3483
3328.124729 -12.395 4.4207
3328.857151 -12.286 5.3413
3329.589572 -12.529 5.8156
3330.321994 -12.260 5.5678
3331.054416 -12.232 6.9060
3331.786838 -12.286 6.1414
3332.519260 -12.354 6.8538
3333.251682 -12.251 7.6393
3333.984103 -12.304 7.6913
3334.716525 -12.005 7.3691
3335.448947 -12.034 7.5153
3336.181369 -11.897 7.0962
3336.913791 -11.949 6.8264
3337.646212 -11.795 5.7557
3338.378634 -11.825 5.6356
3339.111056 -11.689 5.1959
3339.843478 -11.669 3.9453
3340.575900 -11.789 3.5173
3341.308322 -11.763 3.2503
3342.040743 -11.721 2.8276
3342.773165 -11.746 2.6232
3343.505587 -11.668 1.7264
3344.238009 -11.800 1.4516
3344.970431 -11.999 1.0437
3345.702852 -11.999 0.8051
3346.435274 -12.073 0.1100
3347.167696 -12.388 0.2299
3347.900118 -12.398 0.0433
3348.632540 -12.474 -0.3859
3349.364962 -12.523 -0.9269
3350.097383 -12.626 0.7066
3350.829805 -12.681 -0.3226
3351.562227 -12.649 0.3356
3352.294649 -12.772 0.6125
3353.027071 -12.891 2.3027
3353.759492 -12.903 2.2919
3354.491914 -12.861 2.4303
3355.224336 -12.824 3.3826
3355.956758 -12.926 3.8599
3356.689180 -12.829 4.2107
3357.421601 -12.818 5.0764
3358.154023 -12.908 4.6848
3358.886445 -12.835 5.9090
3359.618867 -12.621 5.6321
3360.351289 -12.597 5.5128
3361.083711 -12.535 5.0724
3361.816132 -12.571 6.1414
3362.548554 -12.553 4.5056
3363.280976 -12.578 5.2075
3364.013398 -12.448 3.9937
3364.745820 -12.438 5.4211
3365.478241 -12.418 3.8083
3366.210663 -12.484 3.3278
3366.943085 -12.495 3.6713
3367.675507 -12.436 3.1302
3368.407929 -12.524 2.3802
3369.140351 -12.449 1.2552
3369.872772 -12.609 0.9263
3370.605194 -12.865 2.4403
3371.337616 -12.999 0.5491
3372.070038 -12.895 2.5874
3372.802460 -12.955 2.1005
3373.534881 -13.002 2.4803
3374.267303 -13.237 2.7833
3374.999725 -13.283 2.4857
3375.732147 -13.464 1.9786
3376.464569 -13.211 4.3972
3377.196990 -13.583 3.0370
3377.929412 -13.410 4.0692
3378.661834 -13.438 4.7979
3379.394256 -13.360 5.5916
3380.126678 -13.279 5.0714
3380.859100 -13.121 6.5717
3381.591521 -13.221 6.2612
3382.323943 -13.068 8.2312
3383.056365 -13.175 8.0583
3383.788787 -13.114 7.9202
3384.521209 -13.073 7.0837
3385.253630 -12.900 7.6671
3385.986052 -12.834 6.8433
3386.718474 -12.875 6.9194
3387.450896 -12.733 5.8268
3388.183318 -12.494 7.4819
3388.915740 -12.553 5.1683
3389.648161 -12.556 4.8356
3390.380583 -12.482 4.0862
3391.113005 -12.467 3.9030
3391.845427 -12.599 4.2759
3392.577849 -12.647 3.3551
3393.310270 -12.599 3.2298
3394.042692 -12.587 3.0605
3394.775114 -12.716 2.4283
3395.507536 -12.799 2.5378
3396.239958 -13.013 2.8000
3396.972380 -12.939 2.5121
3397.704801 -13.142 2.3431
3398.437223 -13.252 1.4528
3399.169645 -13.342 2.7563
3399.902067 -13.161 3.4031
3400.634489 -13.315 4.6043
3401.366910 -13.286 4.0044
3402.099332 -13.289 5.1928
3402.831754 -13.261 5.5491
3403.564176 -13.416 5.4263
3404.296598 -13.243 5.5105
3405.029019 -13.185 6.3391
3405.761441 -13.069 5.4867
3406.493863 -13.175 6.0290
3407.226285 -12.990 6.7390
3407.958707 -13.009 5.8759
3408.691129 -13.109 6.5575
3409.423550 -12.949 6.8451
3410.155972 -12.893 5.6707
3410.888394 -12.851 5.1724
3411.620816 -12.677 5.6188
3412.353238 -12.858 5.3154
3413.085659 -12.823 4.5251
3413.818081 -12.781 3.3781
3414.550503 -12.954 3.0736
3415.282925 -12.839 3.1584
3416.015347 -12.927 3.0358
3416.747769 -13.058 2.8825
3417.480190 -12.952 2.8765
3418.212612 -13.123 3.0843
3418.945034 -13.199 2.4063
3419.677456 -13.225 2.8843
3420.409878 -13.292 3.9545
3421.142299 -13.247 3.5284
3421.874721 -13.377 4.5717
3422.607143 -13.515 5.4794
3423.339565 -13.368 2.8510
3424.071987 -13.655 5.9977
3424.804408 -13.429 5.6028
3425.536830 -13.520 4.7943
3426.269252 -13.490 5.6896
3427.001674 -13.449 5.4657
3427.734096 -13.333 5.5850
3428.466518 -13.424 6.9223
3429.198939 -13.220 5.7930
3429.931361 -13.163 6.6437
3430.663783 -13.145 6.2995
3431.396205 -13.255 6.3912
3432.128627 -13.139 6.4039
3432.861048 -13.057 7.0436
3433.593470 -13.138 6.2994
3434.325892 -13.157 5.2158
3435.058314 -13.101 4.1071
3435.790736 -13.169 4.2366
3436.523158 -13.157 3.5428
3437.255579 -13.331 3.4292
3437.988001 -13.135 3.4512
3438.720423 -13.104 4.0236
3439.452845 -13.244 3.0295
3440.185267 -13.272 2.5973
3440.917688 -13.237 2.2889
3441.650110 -13.280 3.1389
3442.382532 -13.236 2.2804
3443.114954 -13.386 2.4233
3443.847376 -13.389 2.4564
3444.579798 -13.495 2.7170
3445.312219 -13.424 2.9083
3446.044641 -13.501 3.6787
3446.777063 -13.377 2.3962
3447.509485 -13.287 3.6537
3448.241907 -13.604 2.3246
3448.974328 -13.558 3.4820
3449.706750 -13.424 3.7092
3450.439172 -13.476 2.9943
3451.171594 -13.643 2.4271
3451.904016 -13.606 2.6620
3452.636437 -13.677 1.7357
3453.368859 -13.641 2.3545
3454.101281 -13.817 2.5085
3454.833703 -14.001 3.6258
3455.566125 -13.886 2.9807
3456.298547 -13.757 3.4540
3457.030968 -14.015 2.4774
3457.763390 -14.093 4.1312
3458.495812 -14.030 3.9370
3459.228234 -14.016 5.0657
3459.960656 -14.139 5.3210
3460.693077 -14.209 5.8828
3461.425499 -14.024 6.0562
3462.157921 -14.052 6.9305
3462.890343 -13.913 7.1637
3463.622765 -13.928 7.3079
3464.355187 -13.938 6.7195
3465.087608 -13.665 7.3274
3465.820030 -13.853 7.6714
3466.552452 -13.679 8.5417
3467.284874 -13.486 7.3976
3468.017296 -13.454 7.3085
3468.749717 -13.317 6.5380
3469.482139 -13.060 5.9131
3470.214561 -13.304 4.9379
3470.946983 -12.883 5.3188
3471.679405 -13.085 4.5477
3472.411826 -13.143 4.2703
3473.144248 -13.134 3.0139
3473.876670 -13.099 2.6411
3474.609092 -13.204 2.0532
3475.341514 -13.224 2.0416
3476.073936 -13.361 1.3708
3476.806357 -13.288 0.2335
3477.538779 -13.329 0.0305
3478.271201 -13.479 1.0247
3479.003623 -13.483 -0.0201
3479.736045 -13.563 0.0441
3480.468466 -13.873 -0.1149
3481.200888 -13.919 1.4523
3481.933310 -14.137 1.4700
3482.665732 -14.015 1.7166
3483.398154 -14.192 2.6774
3484.130576 -14.196 3.4520
3484.862997 -14.237 3.2661
3485.595419 -14.029 3.0481
3486.327841 -14.159 4.0923
3487.060263 -14.246 4.2031
3487.792685 -14.159 5.2463
3488.525106 -14.020 5.1110
3489.257528 -14.115 5.6893
3489.989950 -14.034 4.8365
3490.722372 -13.879 4.9457
3491.454794 -13.885 5.1415
3492.187216 -13.888 5.1962
3492.919637 -13.879 4.5221
3493.652059 -14.028 3.7597
3494.384481 -13.976 2.7747
3495.116903 -13.883 3.8965
3495.849325 -13.835 3.8896
3496.581746 -13.911 2.6034
3497.314168 -13.931 2.1918
3498.046590 -14.003 3.3656
3498.779012 -13.966 3.2154
3499.511434 -14.071 3.2260
3500.243855 -14.041 3.1396
3500.976277 -14.004 2.9750
3501.708699 -14.119 3.3250
3502.441121 -14.079 3.3781
3503.173543 -14.160 2.8868
3503.905965 -14.091 4.2582
3504.638386 -14.137 4.9305
3505.370808 -14.162 3.8311
3506.103230 -14.046 4.0804
3506.835652 -14.056 4.2856
3507.568074 -14.039 4.9105
3508.300495 -14.066 4.7250
3509.032917 -14.133 4.6387
3509.765339 -14.058 4.4873
3510.497761 -14.091 4.9878
3511.230183 -14.101 4.2116
3511.962605 -14.046 4.5528
3512.695026 -13.866 4.5833
3513.427448 -13.945 3.8439
3514.159870 -14.257 2.9407
3514.892292 -14.025 4.1129
3515.624714 -14.220 3.5042
3516.357135 -14.447 2.8235
3517.089557 -14.488 3.9142
3517.821979 -14.533 1.9028
3518.554401 -14.549 3.1260
3519.286823 -14.422 3.6380
3520.019244 -14.544 3.2143
3520.751666 -14.528 3.6212
3521.484088 -14.576 4.6660
3522.216510 -14.738 4.7776
3522.948932 -14.671 5.0646
3523.681354 -14.947 4.8763
3524.413775 -14.739 5.5112
3525.146197 -14.568 5.6809
3525.878619 -14.699 6.0457
3526.611041 -14.710 5.9786
3527.343463 -14.518 6.6129
3528.075884 -14.248 6.6973
3528.808306 -14.272 6.6851
3529.540728 -14.320 6.5821
3530.273150 -13.999 7.1522
3531.005572 -13.993 6.1205
3531.737994 -14.057 6.3196
3532.470415 -14.154 6.1407
3533.202837 -14.007 4.8774
3533.935259 -13.998 4.6683
3534.667681 -13.879 4.6805
3535.400103 -14.003 3.9218
3536.132524 -13.970 4.1982
3536.864946 -13.948 3.3414
3537.597368 -14.126 2.6312
3538.329790 -14.089 2.4192
3539.062212 -14.116 2.9969
3539.794634 -14.244 1.9998
3540.527055 -14.307 2.9214
3541.259477 -14.528 3.2684
3541.991899 -14.429 2.5342
3542.724321 -14.542 1.5347
3543.456743 -14.641 1.9149
3544.189164 -14.770 3.1696
3544.921586 -14.612 3.4755
3545.654008 -14.832 3.4075
3546.386430 -14.630 4.2018
3547.118852 -14.779 4.4304
3547.851273 -14.752 4.4612
3548.583695 -14.840 4.3696
3549.316117 -14.691 4.8253
3550.048539 -14.798 5.2018
3550.780961 -14.674 4.4523
3551.513383 -14.645 3.9619
3552.245804 -14.745 4.4789
3552.978226 -14.619 4.9052
3553.710648 -14.699 4.2644
3554.443070 -14.540 4.8018
3555.175492 -14.546 4.0846
3555.907913 -14.597 4.4415
3556.640335 -14.351 4.5587
3557.372757 -14.435 4.7755
3558.105179 -14.350 4.3958
3558.837601 -14.430 3.6525
3559.570023 -14.431 3.1553
3560.302444 -14.620 2.5443
3561.034866 -14.516 3.5504
3561.767288 -14.605 2.5668
3562.499710 -14.483 3.6073
3563.232132 -14.542 5.0706
3563.964553 -14.574 3.8951
3564.696975 -14.682 4.2108
3565.429397 -14.692 4.3483
3566.161819 -14.760 3.7368
3566.894241 -14.731 3.8017
3567.626662 -14.760 4.2562
3568.359084 -14.755 4.2699
3569.091506 -14.692 4.5626
3569.823928 -14.674 4.4075
3570.556350 -14.583 5.0887
3571.288772 -14.778 4.5747
3572.021193 -14.738 4.7374
3572.753615 -14.686 5.7345
3573.486037 -14.803 5.4310
3574.218459 -14.608 4.9468
3574.950881 -14.756 4.8890
3575.683302 -14.711 5.1456
3576.415724 -14.704 5.1407
3577.148146 -14.695 4.7233
3577.880568 -14.819 4.3998
3578.612990 -14.655 3.9151
3579.345412 -14.625 4.3501
3580.077833 -14.690 3.1566
3580.810255 -14.664 3.9052
3581.542677 -14.740 2.7744
3582.275099 -14.788 2.4508
3583.007521 -14.739 2.6530
3583.739942 -14.881 2.7095
3584.472364 -14.978 2.3096
3585.204786 -14.906 2.1465
3585.937208 -14.961 1.5151
3586.669630 -14.990 1.0234
3587.402052 -14.961 2.2734
3588.134473 -15.128 1.8932
3588.866895 -15.091 1.8350
3589.599317 -15.292 2.7097
3590.331739 -15.313 2.6155
3591.064161 -15.283 4.1570
3591.796582 -15.382 3.4750
3592.529004 -15.359 4.9055
3593.261426 -15.367 5.3481
3593.993848 -15.408 4.6205
3594.726270 -15.369 5.1884
3595.458691 -15.392 6.2502
3596.191113 -15.342 6.6061
3596.923535 -15.181 7.3793
3597.655957 -15.294 7.2181
3598.388379 -15.151 8.2686
3599.120801 -15.049 7.4608
3599.853222 -14.949 7.4568
3600.585644 -14.817 7.4960
3601.318066 -14.828 7.1443
3602.050488 -14.842 6.3661
3602.782910 -14.703 6.6461
3603.515331 -14.783 5.2742
3604.247753 -14.706 5.4354
3604.980175 -14.675 4.3931
3605.712597 -14.701 3.5448
3606.445019 -14.886 3.4502
3607.177441 -14.857 3.3772
3607.909862 -14.813 2.0515
3608.642284 -15.033 2.4253
3609.374706 -15.016 1.2890
3610.107128 -15.047 0.9255
3610.839550 -15.052 0.7844
3611.571971 -15.285 1.4245
3612.304393 -15.398 0.6097
3613.036815 -15.593 2.2175
3613.769237 -15.559 1.6396
3614.501659 -15.648 2.9950
3615.234080 -15.810 2.9474
3615.966502 -15.766 4.5978
3616.698924 -15.957 4.7543
3617.431346 -15.747 4.9183
3618.163768 -15.738 7.1066
3618.896190 -15.728 8.0029
3619.628611 -15.671 7.9575
3620.361033 -15.342 8.5287
3621.093455 -15.409 8.2633
3621.825877 -15.179 9.3519
3622.558299 -15.176 9.3129
3623.290720 -15.069 8.9708
3624.023142 -15.021 8.8167
3624.755564 -14.970 9.6719
3625.487986 -14.880 7.9445
3626.220408 -14.771 7.1766
3626.952830 -14.771 7.1655
3627.685251 -14.644 6.8156
3628.417673 -14.743 5.4821
3629.150095 -14.860 5.6936
3629.882517 -14.857 4.4116
3630.614939 -14.827 4.3958
3631.347360 -14.794 4.4393
3632.079782 -14.939 2.7509
3632.812204 -15.238 2.9791
3633.544626 -15.273 2.8492
3634.277048 -15.360 2.4279
3635.009470 -15.363 2.8865
3635.741891 -15.594 3.3714
3636.474313 -15.547 4.6196
3637.206735 -15.606 4.3860
3637.939157 -15.630 4.5924
3638.671579 -15.716 5.8553
3639.404000 -15.415 5.7494
3640.136422 -15.571 5.9686
3640.868844 -15.514 6.3687
3641.601266 -15.459 7.3340
3642.333688 -15.214 6.6515
3643.066109 -15.456 8.2827
3643.798531 -15.172 6.7692
3644.530953 -15.053 7.7296
3645.263375 -14.751 7.3798
3645.995797 -14.783 7.0809
3646.728219 -14.795 5.9938
3647.460640 -14.726 6.0469
3648.193062 -14.747 5.8673
3648.925484 -14.773 5.2435
3649.657906 -14.698 3.7046
3650.390328 -14.983 4.0493
3651.122749 -14.879 2.1516
3651.855171 -15.010 2.4303
3652.587593 -14.956 2.3151
3653.320015 -15.167 2.0942
3654.052437 -15.010 1.7324
3654.784859 -15.271 1.5178
3655.517280 -15.130 1.1373
3656.249702 -15.455 1.3351
3656.982124 -15.370 1.1790
3657.714546 -15.525 1.6322
3658.446968 -15.614 1.8470
3659.179389 -15.757 2.8851
3659.911811 -15.469 2.5413
3660.644233 -15.592 3.6147
3661.376655 -15.549 3.0738
3662.109077 -15.529 3.2140
3662.841498 -15.599 3.3126
3663.573920 -15.451 4.2845
3664.306342 -15.655 4.9412
3665.038764 -15.441 4.8488
3665.771186 -15.463 4.3939
3666.503608 -15.287 4.7341
3667.236029 -15.332 4.6903
3667.968451 -15.413 4.2968
3668.700873 -15.396 2.5588
3669.433295 -15.280 3.1805
3670.165717 -15.359 2.2842
3670.898138 -15.378 2.1688
3671.630560 -15.228 1.2070
3672.362982 -15.419 0.9697
3673.095404 -15.447 1.4412
3673.827826 -15.498 1.9603
3674.560248 -15.574 0.4271
3675.292669 -15.652 1.3545
3676.025091 -15.556 3.0356
3676.757513 -15.764 3.0550
3677.489935 -15.783 0.0750
3678.222357 -15.785 2.4993
3678.954778 -15.972 2.0020
3679.687200 -15.877 2.9282
3680.419622 -15.919 4.4288
3681.152044 -15.920 3.2657
3681.884466 -15.906 4.0411
3682.616888 -15.866 4.8724
3683.349309 -15.739 4.7290
3684.081731 -15.863 4.3877
3684.814153 -15.828 5.0667
3685.546575 -15.658 4.1328
3686.278997 -15.708 4.0366
3687.011418 -15.830 4.4352
3687.743840 -15.711 4.1300
3688.476262 -15.643 3.9265
3689.208684 -15.597 2.9574
3689.941106 -15.630 3.5564
3690.673527 -15.873 3.6818
3691.405949 -15.808 4.3909
3692.138371 -15.965 1.3815
3692.870793 -15.767 2.2117
3693.603215 -15.854 2.4183
3694.335637 -15.914 2.1798
3695.068058 -16.037 3.2897
3695.800480 -16.127 2.9545
3696.532902 -16.017 3.7543
3697.265324 -16.109 3.8274
3697.997746 -16.206 4.0432
3698.730167 -16.123 4.7944
3699.462589 -16.240 5.5978
3700.195011 -16.307 6.1865
3700.927433 -15.970 5.7786
3701.659855 -15.721 5.9153
3702.392277 -15.863 5.8926
3703.124698 -15.716 4.2258
3703.857120 -15.706 4.7078
3704.589542 -15.686 4.4456
3705.321964 -15.430 4.6543
3706.054386 -15.518 3.8596
3706.786807 -15.490 2.9152
3707.519229 -15.400 4.1572
3708.251651 -15.798 2.2366
3708.984073 -15.658 0.5670
3709.716495 -15.643 0.9490
3710.448916 -15.496 0.4302
3711.181338 -15.784 0.5566
3711.913760 -15.774 -0.4705
3712.646182 -16.166 -0.7668
3713.378604 -15.903 -1.0162
3714.111026 -15.977 -1.3608
3714.843447 -16.246 0.1364
3715.575869 -16.630 -1.1154
3716.308291 -16.591 -0.4269
3717.040713 -16.755 0.0813
3717.773135 -16.332 0.5052
3718.505556 -16.886 0.2155
3719.237978 -16.466 2.0862
3719.970400 -16.518 0.7130
3720.702822 -16.634 3.9843
3721.435244 -16.718 2.7828
3722.167666 -16.617 2.5435
3722.900087 -16.323 4.8414
3723.632509 -16.391 5.4454
3724.364931 -16.414 2.5317
3725.097353 -16.176 4.8316
3725.829775 -16.212 4.2267
3726.562196 -15.746 5.3285
3727.294618 -15.757 4.9158
3728.027040 -15.708 5.1302
3728.759462 -15.980 4.5176
3729.491884 -15.816 3.3080
3730.224306 -15.612 1.3335
3730.956727 -15.771 -0.3760
3731.689149 -15.978 1.3943
3732.421571 -16.026 -1.6234
3733.153993 -16.267 -0.8129
3733.886415 -16.236 -0.1157
3734.618836 -16.415 -2.1381
3735.351258 -16.417 -1.6533
3736.083680 -16.713 -0.4714
3736.816102 -17.032 -0.4200
3737.548524 -17.018 -0.2156
3738.280945 -17.420 0.7909
3739.013367 -17.564 1.7557
3739.745789 -17.834 1.4685
3740.478211 -17.996 5.5417
3741.210633 -17.579 4.0587
3741.943055 -17.597 6.7886
3742.675476 -17.287 6.3041
3743.407898 -17.220 8.7954
3744.140320 -16.968 8.5157
3744.872742 -16.489 11.5847
3745.605164 -16.939 7.8519
3746.337585 -16.693 9.8981
3747.070007 -16.429 8.8416
3747.802429 -16.610 10.0240
3748.534851 -16.185 8.6204
3749.267273 -16.326 9.1960
3749.999695 -16.138 7.4332
3750.732116 -16.069 6.8431
3751.464538 -16.163 6.3380
3752.196960 -16.002 5.3903
3752.929382 -16.209 3.9962
3753.661804 -16.304 4.9103
3754.394225 -16.320 2.7324
3755.126647 -16.344 5.6666
3755.859069 -16.519 3.7221
3756.591491 -16.585 4.1946
3757.323913 -16.716 3.5016
3758.056334 -16.506 3.1323
3758.788756 -16.518 3.5320
3759.521178 -16.802 5.0725
3760.253600 -17.067 5.8143
3760.986022 -16.739 3.8768
3761.718444 -16.954 4.9440
3762.450865 -16.741 8.1064
3763.183287 -17.258 6.3549
3763.915709 -16.893 8.3690
3764.648131 -16.830 6.8247
3765.380553 -16.748 9.2292
3766.112974 -16.368 8.5691
3766.845396 -16.246 8.4535
3767.577818 -16.441 9.0544
3768.310240 -16.002 8.5897
3769.042662 -16.257 6.8790
3769.775084 -16.135 6.1508
3770.507505 -16.053 6.1598
3771.239927 -15.801 8.0914
3771.972349 -15.921 5.8486
3772.704771 -15.912 5.4230
3773.437193 -15.928 3.6348
3774.169614 -15.764 3.2175
3774.902036 -16.237 2.5836
3775.634458 -16.182 3.0479
3776.366880 -16.028 1.2726
3777.099302 -16.164 0.6769
3777.831724 -16.322 1.2200
3778.564145 -16.581 0.0175
3779.296567 -16.507 -1.8334
3780.028989 -16.793 1.8224
3780.761411 -16.996 0.9796
3781.493833 -16.610 1.5637
3782.226254 -16.938 -0.1357
3782.958676 -17.024 0.9238
3783.691098 -16.989 2.3723
3784.423520 -17.214 5.3368
3785.155942 -17.211 3.9208
3785.888363 -17.131 3.9148
3786.620785 -17.215 6.1430
3787.353207 -16.931 6.8761
3788.085629 -17.096 5.0621
3788.818051 -16.918 8.1675
3789.550473 -17.101 6.6305
3790.282894 -16.773 6.3325
3791.015316 -16.976 8.2190
3791.747738 -16.696 6.1649
3792.480160 -16.791 6.6853
3793.212582 -16.696 6.6195
3793.945003 -16.579 5.1094
3794.677425 -16.642 6.1351
3795.409847 -16.807 6.1981
3796.142269 -16.605 4.5093
3796.874691 -16.594 5.2389
3797.607113 -16.610 4.5139
3798.339534 -16.836 4.9596
3799.071956 -16.700 3.6080
3799.804378 -16.879 3.2975
3800.536800 -16.724 3.0122
3801.269222 -16.778 2.8160
3802.001643 -16.794 3.2084
3802.734065 -16.973 3.0532
3803.466487 -16.811 4.7422
3804.198909 -17.208 5.4939
3804.931331 -17.192 4.4637
3805.663752 -17.055 4.1795
3806.396174 -17.005 4.6817
3807.128596 -17.012 6.9915
3807.861018 -17.219 4.8760
3808.593440 -17.387 4.7142
3809.325862 -16.999 4.6526
3810.058283 -17.055 7.2091
3810.790705 -16.840 6.1405
3811.523127 -16.944 8.2310
3812.255549 -16.905 6.3076
3812.987971 -16.804 7.2440
3813.720392 -16.951 7.0741
3814.452814 -16.574 7.1046
3815.185236 -16.765 6.4603
3815.917658 -16.562 6.9414
3816.650080 -16.760 5.3970
3817.382502 -16.724 4.0323
3818.114923 -16.459 3.9138
3818.847345 -16.497 4.8969
3819.579767 -16.580 4.3897
3820.312189 -16.656 4.2646
3821.044611 -16.648 3.2936
3821.777032 -16.618 3.1898
3822.509454 -16.677 3.4116
3823.241876 -16.853 3.9274
3823.974298 -16.816 3.4290
3824.706720 -16.936 2.5587
3825.439142 -17.015 2.0602
3826.171563 -17.018 4.5534
3826.903985 -17.198 3.5659
3827.636407 -17.074 3.3345
3828.368829 -17.256 2.9479
3829.101251 -17.276 3.7524
3829.833672 -17.223 3.7866
3830.566094 -17.217 4.4189
3831.298516 -17.297 4.8705
3832.030938 -17.168 4.8423
3832.763360 -17.317 5.0637
3833.495781 -16.857 4.8209
3834.228203 -17.084 5.1031
3834.960625 -17.114 5.9609
3835.693047 -17.115 5.6436
3836.425469 -16.844 4.5774
3837.157891 -17.053 4.6904
3837.890312 -17.070 6.7804
3838.622734 -17.058 4.0262
3839.355156 -16.740 5.1326
3840.087578 -16.718 3.9573
3840.820000 -17.105 5.2146
3841.552421 -16.990 4.1550
3842.284843 -16.770 3.8076
3843.017265 -16.916 3.4264
3843.749687 -16.922 3.4161
3844.482109 -16.991 2.8365
3845.214531 -16.854 2.6779
3845.946952 -17.200 3.1727
3846.679374 -16.975 3.6640
3847.411796 -17.041 1.8434
3848.144218 -17.169 1.9894
3848.876640 -17.240 2.0098
3849.609061 -17.143 3.1714
3850.341483 -17.426 2.8623
3851.073905 -17.172 3.3674
3851.806327 -17.302 3.7067
3852.538749 -17.576 4.6207
3853.271170 -17.520 4.6102
3854.003592 -17.313 4.3360
3854.736014 -17.397 4.7054
3855.468436 -17.352 4.8726
3856.200858 -17.434 5.1765
3856.933280 -17.122 5.3256
3857.665701 -17.318 5.4427
3858.398123 -17.193 6.5289
3859.130545 -17.281 6.4116
3859.862967 -17.114 5.8470
3860.595389 -17.123 6.2957
3861.327810 -16.971 5.2936
3862.060232 -17.187 5.7319
3862.792654 -16.831 5.2609
3863.525076 -16.899 5.1772
3864.257498 -16.962 5.5807
3864.989920 -16.940 3.5150
3865.722341 -17.090 3.9152
3866.454763 -16.880 2.8024
3867.187185 -17.083 3.9810
3867.919607 -17.214 4.2941
3868.652029 -17.131 2.3661
3869.384450 -16.994 2.4510
3870.116872 -17.157 2.9954
3870.849294 -17.172 2.9999
3871.581716 -17.277 2.3132
3872.314138 -17.193 3.4515
3873.046560 -17.125 3.7106
3873.778981 -17.280 2.4082
3874.511403 -17.258 2.2990
3875.243825 -17.390 3.6274
3875.976247 -17.370 3.3527
3876.708669 -17.450 3.3633
3877.441090 -17.453 3.1138
3878.173512 -17.439 3.7428
3878.905934 -17.351 2.7719
3879.638356 -17.494 3.2009
3880.370778 -17.551 1.9844
3881.103199 -17.454 2.3689
3881.835621 -17.424 2.6767
3882.568043 -17.532 2.9161
3883.300465 -17.488 2.0223
3884.032887 -17.559 2.3667
3884.765309 -17.336 1.7852
3885.497730 -17.500 4.1832
3886.230152 -17.451 2.1156
3886.962574 -17.722 1.9158
3887.694996 -17.676 4.0192
3888.427418 -17.554 4.5342
3889.159839 -17.705 3.0699
3889.892261 -17.713 3.6949
3890.624683 -17.633 4.5101
3891.357105 -17.445 4.1847
3892.089527 -17.460 3.1067
3892.821949 -17.596 5.0085
3893.554370 -17.414 4.1833
3894.286792 -17.538 4.4584
3895.019214 -17.671 4.1968
3895.751636 -17.442 4.0175
3896.484058 -17.268 3.6001
3897.216479 -17.209 4.4864
3897.948901 -17.253 3.6730
3898.681323 -17.431 2.5697
3899.413745 -17.296 5.1467
3900.146167 -17.348 3.1863
3900.878588 -17.388 3.3752
3901.611010 -17.330 2.5726
3902.343432 -17.171 1.8315
3903.075854 -17.117 1.8417
3903.808276 -17.243 1.7152
3904.540698 -17.392 0.8441
3905.273119 -17.475 0.1757
3906.005541 -17.480 0.4165
3906.737963 -17.690 -0.1057
3907.470385 -17.711 -0.6837
3908.202807 -17.692 -0.2581
3908.935228 -17.815 0.0165
3909.667650 -18.090 -0.2525
3910.400072 -17.933 0.4088
3911.132494 -17.938 1.2724
3911.864916 -18.332 1.0820
3912.597338 -18.109 2.4612
3913.329759 -18.183 2.7421
3914.062181 -17.957 2.6194
3914.794603 -18.017 3.0736
3915.527025 -17.981 3.5203
3916.259447 -18.277 3.1641
3916.991868 -18.010 3.0153
3917.724290 -17.993 3.9408
3918.456712 -17.845 4.4155
3919.189134 -17.853 4.3376
3919.921556 -17.844 2.8247
3920.653978 -17.847 2.6949
3921.386399 -17.831 2.3584
3922.118821 -17.744 2.1761
3922.851243 -17.681 2.5825
3923.583665 -17.753 2.1257
3924.316087 -17.670 1.9526
3925.048508 -17.828 1.4011
3925.780930 -17.977 0.3005
3926.513352 -17.917 0.3020
3927.245774 -18.097 1.3398
3927.978196 -18.276 0.3843
3928.710617 -18.330 0.3308
3929.443039 -18.469 1.2015
3930.175461 -18.526 1.7494
3930.907883 -18.800 2.5316
3931.640305 -18.661 0.5015
3932.372727 -18.740 2.6677
3933.105148 -18.830 3.5781
3933.837570 -18.895 4.9893
3934.569992 -18.789 5.2667
3935.302414 -18.622 4.4689
3936.034836 -18.613 7.0265
3936.767257 -18.802 7.9697
3937.499679 -18.689 8.0166
3938.232101 -18.529 7.0723
3938.964523 -18.534 8.9438
3939.696945 -18.415 9.2642
3940.429367 -18.315 10.3365
3941.161788 -18.265 9.7830
3941.894210 -18.029 9.8777
3942.626632 -18.034 10.2159
3943.359054 -18.002 9.0287
3944.091476 -17.899 7.4735
3944.823897 -17.730 6.8192
3945.556319 -17.880 8.0447
3946.288741 -17.682 6.2122
3947.021163 -17.635 5.2551
3947.753585 -17.491 5.1672
3948.486006 -17.700 4.7438
3949.218428 -17.752 3.7714
3949.950850 -17.813 3.2911
3950.683272 -17.618 3.7487
3951.415694 -17.909 4.8591
3952.148116 -17.978 2.4395
3952.880537 -18.044 2.8037
3953.612959 -18.052 3.2611
3954.345381 -18.136 4.7949
3955.077803 -18.279 3.6352
3955.810225 -18.170 4.2946
3956.542646 -18.171 3.6154
3957.275068 -18.054 4.6560
3958.007490 -18.316 4.4188
3958.739912 -18.317 5.3306
3959.472334 -17.984 4.8691
3960.204756 -18.038 4.9784
3960.937177 -18.127 3.9579
3961.669599 -17.996 5.3588
3962.402021 -17.966 4.8329
3963.134443 -17.816 7.7092
3963.866865 -17.912 5.1936
3964.599286 -17.819 3.9268
3965.331708 -17.692 3.6576
3966.064130 -17.677 3.9990
3966.796552 -17.708 2.6934
3967.528974 -17.719 3.2551
3968.261396 -17.889 2.3053
3968.993817 -17.757 1.1145
3969.726239 -17.809 0.0792
3970.458661 -17.972 -0.9200
3971.191083 -17.877 -2.1451
3971.923505 -17.996 -1.0803
3972.655926 -18.238 -1.1908
3973.388348 -18.391 -1.8204
3974.120770 -18.270 -2.3308
3974.853192 -18.398 -0.1161
3975.585614 -18.623 -1.6127
3976.318035 -18.841 0.3860
3977.050457 -18.816 -0.6698
3977.782879 -18.878 0.5095
3978.515301 -19.225 1.6926
3979.247723 -19.183 1.4774
3979.980145 -19.328 1.9396
3980.712566 -19.063 3.6770
3981.444988 -19.228 2.6124
3982.177410 -19.426 3.8743
3982.909832 -19.446 5.4142
3983.642254 -19.122 6.0233
3984.374675 -19.262 7.8433
3985.107097 -19.219 8.2253
3985.839519 -19.067 9.2900
3986.571941 -18.902 9.0538
3987.304363 -18.888 9.3885
3988.036785 -18.692 9.5341
3988.769206 -18.672 9.0211
3989.501628 -18.360 9.7440
3990.234050 -18.335 9.4227
3990.966472 -18.511 10.0307
3991.698894 -18.278 9.9462
3992.431315 -18.075 9.2880
3993.163737 -18.137 8.0188
3993.896159 -17.935 7.7611
3994.628581 -18.058 6.8539
3995.361003 -18.026 6.6314
3996.093424 -18.005 7.5478
3996.825846 -18.083 6.2229
3997.558268 -18.040 5.0046
3998.290690 -17.823 4.4952
3999.023112 -17.917 5.5833
3999.755534 -17.948 4.9727
4000.487955 -17.879 3.4337
4001.220377 -17.825 3.2369
4001.952799 -18.041 3.3898
4002.685221 -17.937 2.6337
4003.417643 -17.907 2.4533
4004.150064 -17.944 1.1005
4004.882486 -18.126 1.9883
4005.614908 -17.997 0.9778
4006.347330 -18.277 0.6880
4007.079752 -18.079 -0.7065
4007.812174 -18.434 0.0083
4008.544595 -18.352 0.3082
4009.277017 -18.427 -0.5110
4010.009439 -18.328 -1.1328
4010.741861 -18.697 -0.5854
4011.474283 -18.630 -0.9771
4012.206704 -18.866 -1.0103
4012.939126 -18.816 -1.8143
4013.671548 -18.901 -0.9930
4014.403970 -18.940 -0.3826
4015.136392 -18.989 -0.3047
4015.868814 -19.267 -1.2236
4016.601235 -19.027 -0.2993
4017.333657 -19.206 1.0049
4018.066079 -19.582 1.2647
4018.798501 -19.629 0.4341
4019.530923 -19.228 1.6180
4020.263344 -19.241 2.0849
4020.995766 -19.528 1.3371
4021.728188 -19.325 2.8434
4022.460610 -19.553 4.3451
4023.193032 -19.249 4.9684
4023.925453 -19.403 5.8748
4024.657875 -19.292 4.7872
4025.390297 -19.430 6.4346
4026.122719 -19.142 5.7954
4026.855141 -19.136 7.6555
4027.587563 -19.201 6.8613
4028.319984 -19.002 6.4049
4029.052406 -18.829 6.6177
4029.784828 -18.996 7.9874
4030.517250 -18.936 5.5165
4031.249672 -18.601 5.9574
4031.982093 -18.485 5.5582
4032.714515 -18.425 4.9075
4033.446937 -18.547 3.6268
4034.179359 -18.499 3.4932
4034.911781 -18.495 3.1110
4035.644203 -18.486 2.7894
4036.376624 -18.633 0.2986
4037.109046 -18.649 1.3781
4037.841468 -18.668 2.1133
4038.573890 -18.834 1.7057
4039.306312 -18.857 0.3320
4040.038733 -19.012 2.2618
4040.771155 -18.892 0.9526
4041.503577 -19.330 1.4856
4042.235999 -19.410 2.0101
4042.968421 -19.121 2.8856
4043.700842 -19.290 2.4495
4044.433264 -19.506 3.2760
4045.165686 -19.419 2.7659
4045.898108 -19.251 4.0710
4046.630530 -19.428 7.0759
4047.362952 -19.278 6.1776
4048.095373 -19.339 5.7113
4048.827795 -19.178 7.1417
4049.560217 -19.182 5.7075
4050.292639 -19.074 7.9689
4051.025061 -19.043 7.4691
4051.757482 -18.800 7.3304
4052.489904 -18.711 5.1193
4053.222326 -18.664 6.9733
4053.954748 -18.782 5.4155
4054.687170 -18.719 4.4890
4055.419592 -18.594 3.6565
4056.152013 -18.607 3.6638
4056.884435 -18.701 2.8821
4057.616857 -18.551 3.3324
4058.349279 -18.786 3.2931
4059.081701 -18.591 2.2395
4059.814122 -18.893 1.7417
4060.546544 -18.842 2.2994
4061.278966 -19.124 0.4159
4062.011388 -19.129 0.4161
4062.743810 -19.172 1.0753
4063.476232 -19.316 1.8494
4064.208653 -19.333 -0.2753
4064.941075 -19.371 2.5596
4065.673497 -19.776 2.7491
4066.405919 -19.462 4.0334
4067.138341 -19.729 2.0072
4067.870762 -20.024 4.4398
4068.603184 -20.131 5.6436
4069.335606 -19.539 6.7531
4070.068028 -19.433 6.8755
4070.800450 -19.541 6.3685
4071.532871 -19.447 7.9187
4072.265293 -19.463 7.8187
4072.997715 -19.271 9.6224
4073.730137 -19.040 8.0463
4074.462559 -19.032 7.2972
4075.194981 -18.695 10.0859
4075.927402 -19.022 8.4908
4076.659824 -18.437 7.4437
4077.392246 -18.544 6.7648
4078.124668 -18.497 6.3640
4078.857090 -18.523 7.3615
4079.589511 -18.366 5.3071
4080.321933 -18.649 6.8472
4081.054355 -18.421 4.7070
4081.786777 -18.519 3.6975
4082.519199 -18.370 3.0731
4083.251621 -18.774 4.6944
4083.984042 -18.652 2.1255
4084.716464 -18.617 2.4327
4085.448886 -18.547 2.0208
4086.181308 -18.955 2.0255
4086.913730 -18.870 2.2159
4087.646151 -19.222 1.0743
4088.378573 -18.904 1.0199
4089.110995 -19.128 1.8801
4089.843417 -18.927 -0.9406
4090.575839 -19.184 0.4424
4091.308261 -19.168 0.7350
4092.040682 -19.163 0.0269
4092.773104 -19.121 0.2539
4093.505526 -19.309 1.1130
4094.237948 -19.324 0.2651
4094.970370 -19.073 2.0632
4095.702791 -19.295 0.4977
4096.435213 -19.670 0.1361
4097.167635 -19.670 -0.3012
4097.900057 -19.530 -0.3066
4098.632479 -19.815 0.4440
4099.364900 -19.930 2.6674
4100.097322 -20.002 -0.2439
4100.829744 -20.141 1.2841
4101.562166 -20.350 -0.7094
4102.294588 -20.467 4.2075
4103.027010 -20.510 1.5839
4103.759431 -20.475 5.5242
4104.491853 -20.160 0.1039
4105.224275 -20.684 3.3500
4105.956697 -20.505 2.9839
4106.689119 -20.881 5.9484
4107.421540 -20.453 5.4781
4108.153962 -20.342 9.5092
4108.886384 -20.636 9.1661
4109.618806 -20.446 11.9774
4110.351228 -20.015 11.1687
4111.083650 -20.038 11.3174
4111.816071 -20.318 9.2470
4112.548493 -19.592 14.7053
4113.280915 -19.719 12.3502
4114.013337 -19.400 14.4150
4114.745759 -19.216 15.2150
4115.478180 -19.219 13.1231
4116.210602 -18.980 10.7025
4116.943024 -19.086 10.9218
4117.675446 -18.798 10.3658
4118.407868 -18.603 9.6328
4119.140289 -18.774 10.0522
4119.872711 -18.751 9.3936
4120.605133 -18.688 8.1151
4121.337555 -18.133 6.6893
4122.069977 -18.241 6.2706
4122.802399 -18.231 5.9225
4123.534820 -18.546 4.0819
4124.267242 -18.346 3.5664
4124.999664 -18.667 3.4087
4125.732086 -18.607 2.9236
4126.464508 -18.825 3.8432
4127.196929 -18.739 1.7645
4127.929351 -18.686 0.9696
4128.661773 -18.668 -0.2473
4129.394195 -19.193 0.8782
4130.126617 -19.161 1.9652
4130.859039 -19.326 1.2352
4131.591460 -19.353 -1.1162
4132.323882 -19.547 0.7334
4133.056304 -19.505 0.0072
4133.788726 -19.317 0.9896
4134.521148 -19.434 0.5624
4135.253569 -19.664 1.6628
4135.985991 -19.508 0.9106
4136.718413 -20.011 1.9879
4137.450835 -19.778 0.6055
4138.183257 -19.866 2.8046
4138.915679 -20.180 0.2749
4139.648100 -19.740 -0.4464
4140.380522 -19.789 0.9312
4141.112944 -19.987 2.2344
4141.845366 -19.950 1.9884
4142.577788 -20.181 1.7128
4143.310209 -20.150 3.9133
4144.042631 -19.979 3.5233
4144.775053 -20.140 4.2733
4145.507475 -20.168 2.8937
4146.239897 -19.952 5.5120
4146.972318 -20.039 4.7349
4147.704740 -19.664 5.9213
4148.437162 -20.038 5.7394
4149.169584 -19.916 6.9592
4149.902006 -19.893 8.8091
4150.634428 -19.557 7.0469
4151.366849 -19.967 8.2213
4152.099271 -19.969 6.4272
4152.831693 -19.911 8.3060
4153.564115 -19.475 6.7540
4154.296537 -19.825 5.6443
4155.028958 -19.467 5.0717
4155.761380 -19.257 5.8987
4156.493802 -19.032 4.1814
4157.226224 -19.311 2.8457
4157.958646 -19.246 5.0565
4158.691068 -19.073 4.4099
4159.423489 -19.122 3.3438
4160.155911 -19.367 1.4713
4160.888333 -19.011 0.6171
4161.620755 -18.960 1.1622
4162.353177 -18.932 0.9116
4163.085598 -19.399 0.5245
4163.818020 -19.523 -0.1062
4164.550442 -19.593 -0.4324
4165.282864 -19.583 -1.5543
4166.015286 -19.640 -1.0317
4166.747707 -19.658 -1.3069
4167.480129 -19.773 0.8140
4168.212551 -19.846 0.5571
4168.944973 -19.861 -1.4995
4169.677395 -20.108 -2.3104
4170.409817 -20.311 0.0967
4171.142238 -20.183 0.1960
4171.874660 -20.206 0.7937
4172.607082 -20.366 2.1285
4173.339504 -20.287 0.2976
4174.071926 -20.529 1.1895
4174.804347 -20.587 1.0845
4175.536769 -20.523 3.7286
4176.269191 -20.447 4.8064
4177.001613 -20.441 2.5972
4177.734035 -20.193 4.3196
4178.466457 -20.668 1.0629
4179.198878 -20.401 4.9078
4179.931300 -20.496 5.1072
4180.663722 -20.590 3.7261
4181.396144 -20.185 2.6121
4182.128566 -20.307 4.4148
4182.860987 -20.181 5.7504
4183.593409 -20.256 5.1104
4184.325831 -20.165 3.5189
4185.058253 -20.046 3.7921
4185.790675 -20.046 4.5383
4186.523097 -20.308 2.6702
4187.255518 -20.166 4.7233
4187.987940 -19.965 2.8604
4188.720362 -19.961 2.0789
4189.452784 -20.033 3.8623
4190.185206 -19.900 3.4397
4190.917627 -19.943 2.6778
4191.650049 -20.029 1.1013
4192.382471 -20.067 1.0637
4193.114893 -19.895 1.1132
4193.847315 -19.933 1.2179
4194.579736 -19.952 -0.1707
4195.312158 -20.233 -1.1556
4196.044580 -20.214 -0.4852
4196.777002 -20.228 0.0537
4197.509424 -20.364 -1.1113
4198.241846 -20.778 1.2438
4198.974267 -20.791 1.1344
4199.706689 -20.679 2.7179
4200.439111 -20.708 0.0106
4201.171533 -20.896 3.3795
4201.903955 -21.095 1.4021
4202.636376 -20.819 1.8712
4203.368798 -21.118 2.7072
4204.101220 -21.432 4.3875
4204.833642 -20.961 6.0851
4205.566064 -20.920 4.9816
4206.298486 -21.054 3.6332
4207.030907 -20.547 6.5856
4207.763329 -20.699 6.9860
4208.495751 -20.663 5.3369
4209.228173 -20.491 6.1425
4209.960595 -20.221 7.1208
4210.693016 -20.403 6.5929
4211.425438 -20.337 6.2668
4212.157860 -20.117 4.9490
4212.890282 -20.096 5.3144
4213.622704 -20.165 5.5641
4214.355125 -20.083 4.5151
4215.087547 -20.026 4.3992
4215.819969 -20.207 3.4115
4216.552391 -20.230 4.4816
4217.284813 -20.057 3.7205
4218.017235 -20.154 1.0182
4218.749656 -20.208 2.1704
4219.482078 -20.243 1.6653
4220.214500 -20.049 2.1939
4220.946922 -20.352 2.0173
4221.679344 -20.445 2.2390
4222.411765 -20.378 3.5189
4223.144187 -20.464 1.8030
4223.876609 -20.716 1.7859
4224.609031 -20.359 2.1353
4225.341453 -20.575 5.3994
4226.073875 -20.596 3.5640
4226.806296 -20.423 3.9465
4227.538718 -20.484 4.8430
4228.271140 -20.344 5.4742
4229.003562 -20.444 3.5341
4229.735984 -20.440 3.7836
4230.468405 -20.325 4.0121
4231.200827 -20.214 5.8026
4231.933249 -20.256 4.2512
4232.665671 -20.248 2.5683
4233.398093 -20.349 3.8285
4234.130515 -20.079 4.0662
4234.862936 -20.308 2.7008
4235.595358 -20.481 2.4394
4236.327780 -20.325 1.9475
4237.060202 -20.455 3.0525
4237.792624 -20.491 2.1006
4238.525045 -20.501 1.8047
4239.257467 -20.735 3.5406
4239.989889 -20.602 2.6703
4240.722311 -20.638 2.6414
4241.454733 -20.879 2.2253
4242.187154 -20.837 5.4360
4242.919576 -20.534 4.0222
4243.651998 -20.788 4.6368
4244.384420 -21.011 5.2937
4245.116842 -20.726 6.7932
4245.849264 -20.527 7.3896
4246.581685 -20.518 6.8514
4247.314107 -20.725 6.9109
4248.046529 -19.994 6.8080
4248.778951 -20.345 8.3850
4249.511373 -20.258 7.6704
4250.243794 -20.350 8.0736
4250.976216 -19.807 8.6355
4251.708638 -19.623 5.5939
4252.441060 -19.997 6.3530
4253.173482 -19.898 4.5207
4253.905904 -19.868 3.4979
4254.638325 -19.584 3.5881
4255.370747 -19.731 3.2717
4256.103169 -20.013 1.3021
4256.835591 -20.074 0.5590
4257.568013 -20.001 1.2188
4258.300434 -20.150 0.5254
4259.032856 -20.350 0.4705
4259.765278 -20.327 -3.0104
4260.497700 -20.257 -0.6616
4261.230122 -20.496 -2.9227
4261.962543 -20.558 -1.4855
4262.694965 -20.709 0.1256
4263.427387 -20.478 -0.8631
4264.159809 -20.658 0.1261
4264.892231 -20.770 0.8091
4265.624653 -20.892 0.7697
4266.357074 -20.833 0.9019
4267.089496 -20.539 2.9398
4267.821918 -20.952 1.8760
4268.554340 -20.662 3.7191
4269.286762 -20.582 2.6105
4270.019183 -20.563 3.3158
4270.751605 -20.686 3.2184
4271.484027 -20.478 1.3138
4272.216449 -20.141 1.1000
4272.948871 -20.335 1.2285
4273.681293 -20.426 -0.6378
4274.413714 -20.391 0.5326
4275.146136 -20.452 -2.8258
4275.878558 -20.497 -0.3840
4276.610980 -20.827 -3.5458
4277.343402 -20.668 -3.5241
4278.075823 -20.736 -4.2921
4278.808245 -20.901 -4.5273
4279.540667 -21.294 -5.3188
4280.273089 -21.202 -3.0446
4281.005511 -21.336 -4.6907
4281.737933 -21.519 -2.3790
4282.470354 -22.013 -1.2234
4283.202776 -22.019 -2.2078
4283.935198 -22.070 -1.5907
4284.667620 -21.844 1.1584
4285.400042 -22.302 1.3433
4286.132463 -21.993 3.5604
4286.864885 -22.101 4.5941
4287.597307 -21.836 7.3774
4288.329729 -22.182 7.4000
4289.062151 -21.414 7.8970
4289.794572 -21.416 7.0093
4290.526994 -21.100 6.3474
4291.259416 -21.181 10.2511
4291.991838 -20.877 7.6687
4292.724260 -20.561 6.5284
4293.456682 -20.628 6.3458
4294.189103 -20.498 8.8981
4294.921525 -20.469 5.7912
4295.653947 -20.277 4.9111
4296.386369 -20.394 5.0577
4297.118791 -20.266 2.8254
4297.851212 -20.218 0.7371
4298.583634 -20.610 -0.9724
4299.316056 -20.387 -0.1561
4300.048478 -20.898 2.5419
4300.780900 -21.176 -1.3843
4301.513322 -21.319 -2.1432
4302.245743 -21.139 1.8914
4302.978165 -21.739 1.7847
4303.710587 -21.999 1.2502
4304.443009 -21.490 1.0688
4305.175431 -21.628 1.3811
4305.907852 -22.139 6.0581
4306.640274 -22.030 5.3057
4307.372696 -22.053 4.8960
4308.105118 -21.808 6.1522
4308.837540 -21.901 10.7134
4309.569961 -21.707 9.5842
4310.302383 -21.618 8.9431
4311.034805 -21.125 9.6677
4311.767227 -20.843 12.4817
4312.499649 -20.992 10.3779
4313.232071 -20.784 9.9290
4313.964492 -20.605 9.3123
4314.696914 -20.433 9.9899
4315.429336 -20.260 8.8860
4316.161758 -20.271 6.6884
4316.894180 -20.037 5.0847
4317.626601 -19.921 6.7615
4318.359023 -20.156 4.1650
4319.091445 -20.171 2.7008
4319.823867 -20.156 2.1891
4320.556289 -20.028 2.0271
4321.288711 -20.255 1.0373
4322.021132 -20.562 1.2603
4322.753554 -20.371 0.3962
4323.485976 -20.479 -0.8411
4324.218398 -20.703 -1.8517
4324.950820 -20.874 -0.6807
4325.683241 -21.140 -1.0516
4326.415663 -20.847 -0.5953
4327.148085 -21.022 -0.0165
4327.880507 -21.456 -1.9478
4328.612929 -21.210 -1.5820
4329.345351 -20.941 0.5187
4330.077772 -21.247 1.2444
4330.810194 -21.181 0.3428
4331.542616 -21.144 -1.1270
4332.275038 -21.169 -1.0951
4333.007460 -21.167 1.6780
4333.739881 -21.284 -0.3038
4334.472303 -21.128 -0.1241
4335.204725 -21.126 -1.3273
4335.937147 -21.345 -2.1731
4336.669569 -21.663 0.1361
4337.401990 -21.376 -4.3820
4338.134412 -21.298 -3.0308
4338.866834 -21.614 -4.3101
4339.599256 -21.875 -3.9183
4340.331678 -21.847 -6.3646
4341.064100 -21.755 -2.6912
4341.796521 -22.387 -1.5038
4342.528943 -22.016 -5.5566
4343.261365 -22.328 -3.7852
4343.993787 -22.443 -2.5509
4344.726209 -23.064 -4.5215
4345.458630 -23.270 2.6575
4346.191052 -23.149 0.8322
4346.923474 -22.773 4.6544
4347.655896 -23.238 7.0433
4348.388318 -23.256 9.0650
4349.120740 -22.876 8.2743
4349.853161 -22.271 10.8650
4350.585583 -22.191 12.6189
4351.318005 -22.470 11.7897
4352.050427 -21.973 12.0944
4352.782849 -21.275 12.9447
4353.515270 -21.353 15.0457
4354.247692 -21.138 13.7548
4354.980114 -20.895 12.8587
4355.712536 -20.580 10.8658
4356.444958 -20.599 9.0444
4357.177379 -20.499 9.5287
4357.909801 -20.337 6.3503
4358.642223 -20.031 6.4373
4359.374645 -20.244 5.0762
4360.107067 -20.479 4.7969
4360.839489 -20.358 2.5824
4361.571910 -20.315 0.6573
4362.304332 -20.663 -2.1908
4363.036754 -20.806 -2.5914
4363.769176 -20.620 -2.0406
4364.501598 -20.538 -3.5702
4365.234019 -20.879 -3.6294
4365.966441 -21.720 -4.5209
4366.698863 -21.483 -4.2408
4367.431285 -21.520 -5.6046
4368.163707 -21.964 -4.4410
4368.896129 -22.024 -0.3001
4369.628550 -22.317 -2.3319
4370.360972 -22.184 -1.6731
4371.093394 -22.376 0.7118
4371.825816 -22.584 0.8081
4372.558238 -22.303 4.7598
4373.290659 -22.257 3.2199
4374.023081 -22.515 6.2733
4374.755503 -22.132 5.0809
4375.487925 -22.045 4.6266
4376.220347 -21.797 5.0423
4376.952769 -21.538 7.4019
4377.685190 -21.529 5.3889
4378.417612 -21.521 6.1133
4379.150034 -21.420 4.5320
4379.882456 -21.152 3.7796
4380.614878 -20.848 2.9277
4381.347299 -21.003 2.4860
4382.079721 -21.060 0.9020
4382.812143 -21.233 1.1946
4383.544565 -21.116 0.2471
4384.276987 -21.287 -0.3985
4385.009408 -21.279 -2.9641
4385.741830 -21.496 -3.0428
4386.474252 -21.934 -3.6194
4387.206674 -21.667 -3.3353
4387.939096 -22.049 -5.0438
4388.671518 -22.041 -3.5985
4389.403939 -22.231 -2.8572
4390.136361 -22.565 -4.3049
4390.868783 -22.546 -2.4399
4391.601205 -22.713 -0.1923
4392.333627 -22.879 1.6229
4393.066048 -22.987 2.2964
4393.798470 -22.897 2.3127
4394.530892 -22.542 4.4408
4395.263314 -22.582 4.7681
4395.995736 -22.796 4.1200
4396.728158 -22.387 6.9105
4397.460579 -22.132 6.4102
4398.193001 -22.257 7.9086
4398.925423 -21.988 7.3278
4399.657845 -21.783 6.5259
4400.390267 -21.506 6.9724
4401.122688 -21.402 6.3405
4401.855110 -21.230 6.4172
4402.587532 -21.144 3.7910
4403.319954 -21.099 4.1670
4404.052376 -20.672 2.6879
4404.784797 -21.015 1.2358
4405.517219 -20.935 -2.6582
4406.249641 -20.666 -0.3181
4406.982063 -20.496 -1.0664
4407.714485 -20.867 -2.4663
4408.446907 -20.788 -5.4821
4409.179328 -21.210 -3.9537
4409.911750 -21.228 -4.7242
4410.644172 -21.520 -6.1931
4411.376594 -21.533 -8.2024
4412.109016 -21.842 -4.2491
4412.841437 -22.188 -6.3070
4413.573859 -22.560 -5.6655
4414.306281 -22.493 -5.4017
4415.038703 -22.882 -5.1495
4415.771125 -22.975 -5.7009
4416.503547 -23.028 -4.0901
4417.235968 -23.365 -2.4635
4417.968390 -23.237 1.1713
4418.700812 -23.548 3.5167
4419.433234 -23.438 4.3117
4420.165656 -23.681 5.6613
4420.898077 -22.940 7.4489
4421.630499 -22.711 5.6801
4422.362921 -22.486 6.8503
4423.095343 -22.041 5.2476
4423.827765 -22.181 7.3461
4424.560187 -22.323 9.2794
4425.292608 -22.013 7.6741
4426.025030 -21.393 8.0565
4426.757452 -21.814 5.9271
4427.489874 -21.741 4.0138
4428.222296 -21.718 3.7927
4428.954717 -21.293 2.4653
4429.687139 -21.102 2.6273
4430.419561 -21.292 -0.0637
4431.151983 -21.549 -1.2733
4431.884405 -21.778 -0.9130
4432.616826 -21.557 -2.3196
4433.349248 -21.853 -3.1046
4434.081670 -21.584 -3.4613
4434.814092 -22.338 -2.6449
4435.546514 -21.845 -3.3235
4436.278936 -22.525 -2.1119
4437.011357 -22.837 -1.0874
4437.743779 -22.484 -3.1935
4438.476201 -22.337 -4.5367
4439.208623 -23.454 1.2106
4439.941045 -22.954 -1.9521
4440.673466 -23.185 2.8208
4441.405888 -22.799 6.0171
4442.138310 -23.485 2.1985
4442.870732 -23.050 5.8560
4443.603154 -22.524 0.5535
4444.335576 -22.690 11.2299
4445.067997 -22.588 4.9922
4445.800419 -22.610 5.0487
4446.532841 -22.724 6.7638
4447.265263 -21.951 3.1350
4447.997685 -21.659 7.6333
4448.730106 -21.825 6.8622
4449.462528 -21.583 4.7516
4450.194950 -21.418 3.9629
4450.927372 -21.998 2.3626
4451.659794 -21.106 4.1465
4452.392215 -21.950 -0.3717
4453.124637 -21.351 5.6107
4453.857059 -20.840 -2.1620
4454.589481 -21.383 0.7184
4455.321903 -21.627 0.4698
4456.054325 -21.377 -2.5260
4456.786746 -21.839 -4.2911
4457.519168 -21.758 -1.4478
4458.251590 -22.305 -6.4164
4458.984012 -21.829 -2.9666
4459.716434 -22.569 -4.2212
4460.448855 -21.853 -6.5873
4461.181277 -22.933 -4.5016
4461.913699 -22.214 -4.5131
4462.646121 -22.878 -7.4531
4463.378543 -23.161 -2.2487
4464.110965 -22.813 -2.2396
4464.843386 -23.354 -2.9374
4465.575808 -23.344 -3.0645
4466.308230 -23.232 -2.6418
4467.040652 -23.342 1.5492
4467.773074 -22.950 -3.0543
4468.505495 -24.034 2.9287
4469.237917 -23.335 1.5236
4469.970339 -23.456 -3.1838
4470.702761 -23.737 6.4448
4471.435183 -22.459 -5.0628
4472.167605 -23.449 -1.7971
4472.900026 -23.838 3.1832
4473.632448 -23.505 5.8587
4474.364870 -23.472 4.5999
4475.097292 -23.410 12.2879
4475.829714 -23.478 11.7478
4476.562135 -23.528 6.2529
4477.294557 -23.716 8.1642
4478.026979 -23.335 8.0795
4478.759401 -23.252 8.3198
4479.491823 -23.212 6.6351
4480.224244 -23.122 11.6689
4480.956666 -22.665 11.6815
4481.689088 -21.954 13.6594
4482.421510 -22.697 8.5690
4483.153932 -22.115 7.6459
4483.886354 -21.561 8.7311
4484.618775 -22.326 8.8893
4485.351197 -22.138 1.8165
4486.083619 -21.634 4.6483
4486.816041 -22.050 5.3064
4487.548463 -22.110 4.2838
4488.280884 -21.626 1.5248
4489.013306 -21.850 1.9846
4489.745728 -21.825 1.3164
4490.478150 -22.308 0.5449
4491.210572 -21.905 -2.9671
4491.942994 -22.920 -4.6420
4492.675415 -22.364 -0.4095
4493.407837 -22.267 -3.4547
4494.140259 -22.678 -5.2867
4494.872681 -23.187 -1.2058
4495.605103 -22.940 -1.0504
4496.337524 -22.744 -7.3070
4497.069946 -23.214 -1.6320
4497.802368 -23.181 0.2687
4498.534790 -24.307 3.0851
4499.267212 -23.697 2.9559
4499.999633 -23.389 1.8916
4500.732055 -25.022 7.0476
4501.464477 -23.448 5.8308
4502.196899 -24.562 5.5901
4502.929321 -24.002 7.3912
4503.661743 -23.526 4.8888
4504.394164 -23.245 12.0976
4505.126586 -22.989 9.3840
4505.859008 -23.006 6.7524
4506.591430 -23.620 10.3143
4507.323852 -22.925 2.9225
4508.056273 -23.179 9.2754
4508.788695 -22.583 4.6653
4509.521117 -22.713 7.8292
4510.253539 -22.586 6.2859
4510.985961 -22.452 3.6260
4511.718383 -22.919 4.2826
4512.450804 -22.100 2.5401
4513.183226 -22.091 -6.9440
4513.915648 -22.231 -0.6219
4514.648070 -22.717 -4.4556
4515.380492 -22.784 -5.3755
4516.112913 -22.706 -2.3564
4516.845335 -23.049 -0.3760
4517.577757 -23.536 -0.0020
4518.310179 -22.913 -4.2623
4519.042601 -22.739 -4.2373
4519.775023 -23.835 -3.1086
4520.507444 -24.188 2.9966
4521.239866 -23.674 3.1067
4521.972288 -24.125 5.0228
4522.704710 -23.989 2.9830
4523.437132 -23.285 5.5605
4524.169553 -24.097 16.0893
4524.901975 -23.678 11.5237
4525.634397 -23.775 14.5374
4526.366819 -23.503 13.6465
4527.099241 -23.934 16.8062
4527.831662 -23.248 16.3073
4528.564084 -23.579 15.4536
4529.296506 -21.725 14.8549
4530.028928 -22.445 13.2579
4530.761350 -22.329 11.4332
4531.493772 -21.517 10.6808
4532.226193 -22.143 8.5864
4532.958615 -21.895 8.2861
4533.691037 -21.543 7.8713
4534.423459 -21.508 5.9861
4535.155881 -22.126 6.1964
4535.888302 -22.220 6.8990
4536.620724 -21.640 0.8218
4537.353146 -22.042 2.3594
4538.085568 -21.978 -2.8483
4538.817990 -22.112 0.2926
4539.550412 -22.594 0.4006
4540.282833 -23.138 -1.2369
4541.015255 -23.229 1.4662
4541.747677 -23.039 2.8717
4542.480099 -23.431 -1.1844
4543.212521 -23.410 2.8735
4543.944942 -23.294 3.1163
4544.677364 -23.643 2.7838
4545.409786 -23.186 2.0045
4546.142208 -23.849 2.3094
4546.874630 -23.822 1.4406
4547.607051 -23.803 5.7134
4548.339473 -23.977 2.9043
4549.071895 -23.533 9.1570
4549.804317 -24.130 9.1813
4550.536739 -23.287 10.2839
4551.269161 -23.635 2.2413
4552.001582 -23.931 6.9359
4552.734004 -22.601 5.0613
4553.466426 -22.768 10.3087
4554.198848 -23.277 4.4266
4554.931270 -22.755 3.6135
4555.663691 -23.485 5.1390
4556.396113 -22.438 6.3384
4557.128535 -22.501 0.2256
4557.860957 -22.992 -0.3585
4558.593379 -23.519 5.2880
4559.325801 -23.619 1.0957
4560.058222 -23.084 1.6807
4560.790644 -23.812 -2.4236
4561.523066 -23.682 3.8474
4562.255488 -23.998 1.3378
4562.987910 -23.862 -0.0417
4563.720331 -24.537 5.9525
4564.452753 -24.420 3.9883
4565.185175 -24.589 6.5996
4565.917597 -24.884 7.6801
4566.650019 -24.277 3.3521
4567.382441 -24.366 11.0391
4568.114862 -24.137 6.7634
4568.847284 -23.805 8.4894
4569.579706 -23.746 13.1183
4570.312128 -23.888 12.8728
4571.044550 -23.715 11.6714
4571.776971 -23.709 10.3444
4572.509393 -23.621 13.3260
4573.241815 -23.020 11.8405
4573.974237 -23.141 11.5532
4574.706659 -23.049 8.1685
4575.439080 -23.091 11.4890
4576.171502 -22.825 7.9464
4576.903924 -22.608 9.1646
4577.636346 -22.652 4.9857
4578.368768 -22.986 5.4979
4579.101190 -23.047 6.3046
4579.833611 -22.839 4.8834
4580.566033 -23.322 3.3533
4581.298455 -22.945 4.7369
4582.030877 -22.939 2.1304
4582.763299 -22.928 2.8242
4583.495720 -23.081 3.5746
4584.228142 -23.351 0.3187
4584.960564 -23.460 2.9778
4585.692986 -23.373 4.1207
4586.425408 -23.477 2.9667
4587.157830 -23.975 7.8057
4587.890251 -23.689 4.1099
4588.622673 -23.368 6.5790
4589.355095 -23.892 8.9641
4590.087517 -23.701 9.6157
4590.819939 -23.424 8.8986
4591.552360 -23.704 7.2554
4592.284782 -23.408 7.5222
4593.017204 -23.138 9.9900
4593.749626 -23.133 7.7703
4594.482048 -22.496 7.7761
4595.214469 -22.720 8.7448
4595.946891 -22.275 6.4813
4596.679313 -22.012 8.7034
4597.411735 -22.141 5.9403
4598.144157 -22.214 3.9152
4598.876579 -21.947 4.6312
4599.609000 -22.411 2.2007
4600.341422 -21.880 3.8922
4601.073844 -22.380 2.8832
4601.806266 -22.462 1.6738
4602.538688 -22.440 0.7480
4603.271109 -22.643 -2.6335
4604.003531 -22.851 -3.3012
4604.735953 -22.876 -1.1547
4605.468375 -23.298 -3.4657
4606.200797 -22.811 -3.6449
4606.933219 -23.542 1.4911
4607.665640 -23.644 -2.6964
4608.398062 -23.635 0.6100
4609.130484 -23.528 -0.2924
4609.862906 -24.361 0.6365
4610.595328 -24.072 3.2551
4611.327749 -24.000 3.0688
4612.060171 -23.641 6.5758
4612.792593 -23.767 7.6619
4613.525015 -23.460 5.0116
4614.257437 -23.300 7.6152
4614.989859 -23.210 6.0085
4615.722280 -23.374 7.0405
4616.454702 -22.778 7.9772
4617.187124 -22.928 7.0588
4617.919546 -22.354 5.4079
4618.651968 -22.330 7.9000
4619.384389 -22.318 5.8925
4620.116811 -22.230 3.7493
4620.849233 -22.190 2.1725
4621.581655 -22.303 -0.5343
4622.314077 -22.128 0.7916
4623.046498 -22.384 -0.7194
4623.778920 -22.419 -3.6082
4624.511342 -22.765 -3.5317
4625.243764 -22.700 -2.8860
4625.976186 -22.776 -3.6268
4626.708608 -23.261 -4.4712
4627.441029 -23.419 -7.2902
4628.173451 -23.433 -5.4895
4628.905873 -23.815 -3.6311
4629.638295 -23.795 -7.1764
4630.370717 -24.318 -2.5435
4631.103138 -24.040 -2.4406
4631.835560 -24.387 0.8362
4632.567982 -24.519 -0.9821
4633.300404 -25.149 2.1428
4634.032826 -24.417 3.4470
4634.765248 -24.846 5.1545
4635.497669 -24.877 4.0720
4636.230091 -23.845 8.7058
4636.962513 -24.140 5.3652
4637.694935 -23.605 8.4070
4638.427357 -23.881 9.0295
4639.159778 -24.226 11.2740
4639.892200 -22.918 9.8748
4640.624622 -23.324 7.2430
4641.357044 -23.046 3.4599
4642.089466 -23.094 7.7463
4642.821887 -23.005 4.3666
4643.554309 -22.709 0.4205
4644.286731 -23.256 0.4024
4645.019153 -23.392 0.0898
4645.751575 -23.010 -1.2117
4646.483997 -22.908 -1.9272
4647.216418 -22.953 -4.7754
4647.948840 -23.194 -4.2050
4648.681262 -23.356 -3.5468
4649.413684 -23.345 -6.4753
4650.146106 -23.701 -5.1124
4650.878527 -24.064 -4.5345
4651.610949 -24.118 -6.5147
4652.343371 -24.506 -3.7085
4653.075793 -24.538 -5.8651
4653.808215 -24.039 -2.5654
4654.540637 -25.077 1.2491
4655.273058 -24.357 -2.6057
4656.005480 -24.874 -1.5828
4656.737902 -25.012 4.7512
4657.470324 -24.171 5.6855
4658.202746 -24.407 4.5547
4658.935167 -24.441 4.9731
4659.667589 -24.044 6.8488
4660.400011 -24.587 8.1971
4661.132433 -23.839 6.0942
4661.864855 -23.748 7.2123
4662.597277 -23.790 6.3420
4663.329698 -23.560 4.9311
4664.062120 -23.398 4.9861
4664.794542 -23.408 6.0073
4665.526964 -22.842 2.8619
4666.259386 -23.155 2.9404
4666.991807 -23.113 1.2931
4667.724229 -23.258 1.3669
4668.456651 -23.140 2.0308
4669.189073 -23.348 0.2792
4669.921495 -23.453 -0.6938
4670.653916 -23.581 -0.8579
4671.386338 -23.384 -0.4766
4672.118760 -23.714 -2.2463
4672.851182 -23.959 -3.7436
4673.583604 -24.133 -0.5629
4674.316026 -24.095 -0.7790
4675.048447 -24.339 -2.6278
4675.780869 -24.595 -0.0967
4676.513291 -24.983 -1.2705
4677.245713 -24.518 -2.6136
4677.978135 -24.582 1.6136
4678.710556 -24.668 1.3131
4679.442978 -24.727 3.7164
4680.175400 -24.330 3.2379
4680.907822 -24.625 3.6307
4681.640244 -24.333 6.7674
4682.372666 -24.768 5.6790
4683.105087 -24.134 4.0524
4683.837509 -24.069 5.7645
4684.569931 -24.192 5.6523
4685.302353 -23.917 5.8134
4686.034775 -23.785 6.8794
4686.767196 -23.896 3.6539
4687.499618 -23.777 5.3599
4688.232040 -24.042 4.3433
4688.964462 -23.774 3.6263
4689.696884 -23.429 4.2050
4690.429305 -23.915 2.9733
4691.161727 -23.791 4.5245
4691.894149 -23.487 3.8551
4692.626571 -23.920 3.2555
4693.358993 -23.629 3.0815
4694.091415 -23.947 0.8854
4694.823836 -23.752 -0.7818
4695.556258 -22.949 2.3635
4696.288680 -23.904 -0.8099
4697.021102 -23.739 -0.8362
4697.753524 -23.448 0.1921
4698.485945 -23.735 -0.5852
4699.218367 -24.036 -0.2442
4699.950789 -24.369 0.8638
4700.683211 -24.004 -1.6326
4701.415633 -23.952 2.8743
4702.148055 -24.173 0.2649
4702.880476 -24.638 0.0426
4703.612898 -23.903 1.0804
4704.345320 -24.105 -2.0593
4705.077742 -24.334 -1.5485
4705.810164 -24.172 -0.1270
4706.542585 -24.442 -0.6057
4707.275007 -24.451 0.1511
4708.007429 -25.021 -1.5208
4708.739851 -24.848 -0.6554
4709.472273 -24.502 0.4729
4710.204695 -24.954 4.4390
4710.937116 -24.773 3.4783
4711.669538 -24.917 5.2839
4712.401960 -24.840 3.7783
4713.134382 -24.354 3.4135
4713.866804 -24.582 5.3195
4714.599225 -24.321 5.3353
4715.331647 -23.773 5.3266
4716.064069 -24.444 6.3784
4716.796491 -24.023 5.5411
4717.528913 -23.755 3.7792
4718.261334 -23.682 5.4271
4718.993756 -23.853 3.9678
4719.726178 -23.931 2.3873
4720.458600 -23.508 2.2697
4721.191022 -23.437 3.3480
4721.923444 -23.615 2.7100
4722.655865 -23.378 -1.3020
4723.388287 -23.449 -0.9807
4724.120709 -23.757 -2.0790
4724.853131 -23.815 -3.5686
4725.585553 -23.828 -5.1786
4726.317974 -24.186 -4.1608
4727.050396 -24.084 -7.8034
4727.782818 -24.284 -6.8441
4728.515240 -24.303 -7.5546
4729.247662 -24.303 -5.6886
4729.980084 -24.667 -4.9817
4730.712505 -25.092 -4.6551
4731.444927 -25.630 -4.2057
4732.177349 -25.328 -6.4844
4732.909771 -25.376 -7.7249
4733.642193 -25.976 -2.4250
4734.374614 -25.816 -2.6925
4735.107036 -26.216 2.5252
4735.839458 -25.592 0.6532
4736.571880 -25.657 1.8058
4737.304302 -25.548 3.7047
4738.036723 -25.381 5.5756
4738.769145 -25.393 2.4396
4739.501567 -24.907 4.9485
4740.233989 -25.002 5.2032
4740.966411 -25.250 6.4026
4741.698833 -25.073 5.0234
4742.431254 -25.227 3.5841
4743.163676 -24.954 7.6984
4743.896098 -25.040 6.2256
4744.628520 -24.796 0.6744
4745.360942 -24.659 4.5231
4746.093363 -24.962 3.5984
4746.825785 -24.716 3.7328
4747.558207 -24.828 1.7284
4748.290629 -24.947 -0.6966
4749.023051 -24.967 1.6149
4749.755473 -24.820 3.5244
4750.487894 -25.311 1.2519
4751.220316 -25.161 -0.8087
4751.952738 -25.402 3.1106
4752.685160 -25.616 3.0617
4753.417582 -25.450 3.1100
4754.150003 -25.488 1.8203
4754.882425 -25.838 6.9843
4755.614847 -25.895 6.4437
4756.347269 -25.787 5.9568
4757.079691 -25.072 7.7651
4757.812113 -25.729 9.3501
4758.544534 -25.326 10.2430
4759.276956 -25.137 10.6104
4760.009378 -25.162 9.3960
4760.741800 -24.634 12.3345
4761.474222 -24.977 9.9358
4762.206643 -24.867 11.2339
4762.939065 -24.806 12.1479
4763.671487 -24.327 9.5640
4764.403909 -24.630 9.6775
4765.136331 -24.185 9.9491
4765.868752 -24.174 9.7852
4766.601174 -23.927 9.0768
4767.333596 -23.698 6.3549
4768.066018 -23.904 7.9679
4768.798440 -23.619 5.6265
4769.530862 -23.867 4.7607
4770.263283 -23.791 5.4406
4770.995705 -23.793 4.2266
4771.728127 -23.908 2.7043
4772.460549 -23.877 3.5300
4773.192971 -24.077 4.7230
4773.925392 -24.068 4.9301
4774.657814 -23.973 1.8860
4775.390236 -24.030 0.7856
4776.122658 -24.370 3.1505
4776.855080 -24.033 2.1016
4777.587502 -24.110 2.3052
4778.319923 -24.200 2.4939
4779.052345 -24.564 1.6322
4779.784767 -24.421 2.0969
4780.517189 -24.285 1.1832
4781.249611 -24.377 2.5122
4781.982032 -24.358 2.6648
4782.714454 -24.265 0.8701
4783.446876 -24.632 1.3876
4784.179298 -24.362 2.2961
4784.911720 -24.225 1.6402
4785.644141 -24.260 3.1047
4786.376563 -24.227 2.2165
4787.108985 -24.587 3.8951
4787.841407 -24.465 4.7806
4788.573829 -24.152 4.0178
4789.306251 -24.822 2.0366
4790.038672 -23.828 0.9190
4790.771094 -24.393 0.5741
4791.503516 -24.502 2.5195
4792.235938 -24.134 2.3085
4792.968360 -24.417 2.7383
4793.700781 -24.013 -0.1649
4794.433203 -24.241 -0.9073
4795.165625 -24.319 -2.2181
4795.898047 -23.927 1.2915
4796.630469 -23.902 -1.2864
4797.362891 -24.188 -1.4481
4798.095312 -24.454 -0.6714
4798.827734 -24.236 -3.1716
4799.560156 -24.726 -1.3630
4800.292578 -24.780 -3.3808
4801.025000 -24.701 -5.9563
4801.757421 -24.357 -5.9797
4802.489843 -24.984 -1.5635
4803.222265 -24.859 -4.9508
4803.954687 -25.523 -7.2126
4804.687109 -25.246 -1.4367
4805.419531 -25.294 -1.5591
4806.151952 -25.674 -5.3137
4806.884374 -25.909 -3.1625
4807.616796 -25.387 -1.5817
4808.349218 -26.101 0.0503
4809.081640 -26.164 0.3663
4809.814061 -25.639 0.2847
4810.546483 -26.185 3.1302
4811.278905 -26.114 3.2869
4812.011327 -26.601 2.0970
4812.743749 -26.082 7.3331
4813.476170 -25.963 3.6711
4814.208592 -26.103 9.0959
4814.941014 -25.351 6.8885
4815.673436 -25.268 4.4281
4816.405858 -25.142 7.5513
4817.138280 -25.010 8.8683
4817.870701 -24.878 7.4414
4818.603123 -24.344 6.2395
4819.335545 -24.595 5.4238
4820.067967 -24.505 2.2324
4820.800389 -24.601 5.0222
4821.532810 -24.806 2.4486
4822.265232 -24.702 4.1872
4822.997654 -24.837 3.4636
4823.730076 -24.962 1.4028
4824.462498 -24.436 -1.5940
4825.194920 -24.822 -1.0144
4825.927341 -25.060 -0.0446
4826.659763 -25.038 -1.4364
4827.392185 -25.301 -6.7585
4828.124607 -25.447 1.8351
4828.857029 -25.261 -0.2466
4829.589450 -25.679 3.1669
4830.321872 -25.667 3.0712
4831.054294 -25.544 5.3118
4831.786716 -25.402 5.1295
4832.519138 -25.622 4.3300
4833.251559 -25.313 9.4746
4833.983981 -25.091 8.8110
4834.716403 -25.386 8.1014
4835.448825 -25.235 8.7948
4836.181247 -24.885 9.4130
4836.913669 -24.879 3.9911
4837.646090 -24.554 7.3055
4838.378512 -24.394 9.8494
4839.110934 -24.562 3.3042
4839.843356 -24.235 3.1691
4840.575778 -24.150 1.0933
4841.308199 -24.685 0.3518
4842.040621 -24.438 0.2789
4842.773043 -24.135 -3.1117
4843.505465 -24.151 -0.2554
4844.237887 -24.819 0.7670
4844.970309 -24.751 -2.0380
4845.702730 -25.110 -4.2804
4846.435152 -24.910 -3.1016
4847.167574 -25.516 -4.5526
4847.899996 -25.482 -4.5579
4848.632418 -26.341 -6.7626
4849.364839 -25.662 -0.0304
4850.097261 -26.348 -0.1953
4850.829683 -26.359 5.9714
4851.562105 -26.365 -0.8152
4852.294527 -26.846 2.0959
4853.026949 -27.200 7.5775
4853.759370 -26.670 7.7169
4854.491792 -26.500 0.5043
4855.224214 -25.650 9.4068
4855.956636 -25.355 6.3291
4856.689058 -25.281 9.1631
4857.421479 -25.255 6.5131
4858.153901 -25.184 8.6047
4858.886323 -25.280 8.3091
4859.618745 -24.807 7.9243
4860.351167 -24.561 4.2532
4861.083588 -24.639 6.2671
4861.816010 -24.819 2.1804
4862.548432 -24.790 -0.3990
4863.280854 -23.822 -1.6102
4864.013276 -24.259 -2.2769
4864.745698 -24.394 -4.1174
4865.478119 -24.143 -7.2301
4866.210541 -24.712 -8.5239
4866.942963 -24.766 -12.4717
4867.675385 -25.565 -9.0592
4868.407807 -25.212 -12.5720
4869.140228 -26.218 -12.9744
4869.872650 -26.413 -14.0938
4870.605072 -27.584 -9.2130
4871.337494 -27.724 -13.9666
4872.069916 -27.462 -5.3088
4872.802338 -27.225 -2.1064
4873.534759 -28.370 0.1062
4874.267181 -28.266 1.8894
4874.999603 -27.700 5.2663
4875.732025 -27.351 6.6541
4876.464447 -27.028 10.8440
4877.196868 -26.584 13.3164
4877.929290 -26.738 10.0831
4878.661712 -26.456 12.6090
4879.394134 -25.538 15.0029
4880.126556 -25.435 15.7278
4880.858977 -24.975 12.3126
4881.591399 -24.557 10.2147
4882.323821 -24.513 14.4698
4883.056243 -24.332 9.8735
4883.788665 -24.290 8.6423
4884.521087 -23.848 7.2702
4885.253508 -23.584 6.0660
4885.985930 -24.085 4.6783
4886.718352 -23.680 0.3459
4887.450774 -23.755 -0.3133
4888.183196 -23.593 -2.3792
4888.915617 -24.001 -5.5626
4889.648039 -24.178 -7.0071
4890.380461 -24.663 -9.3482
4891.112883 -23.975 -6.2751
4891.845305 -24.665 -12.8687
4892.577727 -25.139 -14.6826
4893.310148 -25.469 -12.4277
4894.042570 -26.069 -8.0348
4894.774992 -26.460 -12.2773
4895.507414 -27.301 -10.3165
4896.239836 -25.912 -9.5557
4896.972257 -26.964 -2.0325
4897.704679 -26.800 -5.9052
4898.437101 -27.330 -4.1418
4899.169523 -27.838 -0.1244
4899.901945 -27.408 5.9612
4900.634367 -27.417 7.1018
4901.366788 -27.347 10.7711
4902.099210 -27.349 9.7339
4902.831632 -26.584 12.4331
4903.564054 -26.363 10.1369
4904.296476 -26.229 11.0886
4905.028897 -26.042 12.5452
4905.761319 -24.986 9.9310
4906.493741 -25.817 8.1886
4907.226163 -25.636 8.7637
4907.958585 -25.229 7.4385
4908.691006 -25.162 7.8722
4909.423428 -25.611 10.4175
4910.155850 -25.555 4.0626
4910.888272 -26.040 1.9335
4911.620694 -25.787 2.7548
4912.353116 -26.263 0.7426
4913.085537 -26.032 -0.1971
4913.817959 -26.122 1.1250
4914.550381 -26.136 0.6338
4915.282803 -26.515 3.1135
4916.015225 -26.963 -0.4766
4916.747646 -26.924 0.5702
4917.480068 -26.118 7.5180
4918.212490 -27.428 5.7460
4918.944912 -27.458 6.2966
4919.677334 -26.894 8.1248
4920.409756 -26.383 10.1879
4921.142177 -26.554 16.8632
4921.874599 -26.528 13.5378
4922.607021 -26.267 16.8893
4923.339443 -25.921 16.8325
4924.071865 -26.351 19.3106
4924.804286 -25.496 14.9767
4925.536708 -25.486 16.5361
4926.269130 -25.001 11.7083
4927.001552 -25.010 10.7203
4927.733974 -25.257 14.9967
4928.466395 -24.922 8.9762
4929.198817 -23.856 9.2151
4929.931239 -24.412 10.1133
4930.663661 -24.305 7.4756
4931.396083 -23.915 6.9860
4932.128505 -24.152 0.0135
4932.860926 -24.054 1.2872
4933.593348 -24.320 -0.5442
4934.325770 -24.341 -1.9760
4935.058192 -24.077 -1.9951
4935.790614 -24.558 -2.4178
4936.523035 -24.626 -3.9047
4937.255457 -24.750 -4.4158
4937.987879 -24.656 -9.4832
4938.720301 -25.044 -5.4529
4939.452723 -25.780 -7.0077
4940.185145 -26.062 -5.0049
4940.917566 -25.612 -5.1743
4941.649988 -26.652 -4.5173
4942.382410 -26.720 -6.5412
4943.114832 -27.511 -7.0356
4943.847254 -26.565 -9.0270
4944.579675 -26.601 -4.6353
4945.312097 -27.189 -2.9423
4946.044519 -27.379 -0.5778
4946.776941 -26.325 -3.4882
4947.509363 -26.970 4.2141
4948.241785 -27.326 3.3351
4948.974206 -27.048 2.9613
4949.706628 -26.772 2.7083
4950.439050 -27.072 2.3171
4951.171472 -26.388 4.7145
4951.903894 -26.348 4.0803
4952.636315 -26.091 -0.4264
4953.368737 -26.295 5.7997
4954.101159 -26.910 2.4375
4954.833581 -26.665 2.0870
4955.566003 -26.556 -0.2297
4956.298424 -26.329 2.3673
4957.030846 -26.608 4.4865
4957.763268 -26.922 4.9468
4958.495690 -26.622 2.7452
4959.228112 -26.601 5.0585
4959.960534 -26.920 3.7328
4960.692955 -26.375 6.6647
4961.425377 -26.480 5.2930
4962.157799 -26.923 7.5463
4962.890221 -26.957 7.1852
4963.622643 -27.245 7.7755
4964.355064 -26.647 6.7052
4965.087486 -26.503 9.9272
4965.819908 -26.883 11.4067
4966.552330 -26.771 10.5294
4967.284752 -26.482 9.2113
4968.017174 -25.763 11.2992
4968.749595 -26.049 13.2004
4969.482017 -25.815 13.7354
4970.214439 -25.703 11.5247
4970.946861 -25.113 11.7880
4971.679283 -25.225 12.1429
4972.411704 -24.784 10.1207
4973.144126 -25.041 7.9674
4973.876548 -24.974 5.8790
4974.608970 -24.692 6.8513
4975.341392 -24.644 5.1401
4976.073813 -24.794 -0.1301
4976.806235 -24.576 3.6567
4977.538657 -25.116 1.6501
4978.271079 -25.159 -2.8619
4979.003501 -25.563 -3.6753
4979.735923 -25.502 -1.9760
4980.468344 -25.795 -4.1215
4981.200766 -25.988 -1.4117
4981.933188 -26.373 -4.0474
4982.665610 -25.952 -7.6800
4983.398032 -26.848 -3.9088
4984.130453 -26.634 -2.7508
4984.862875 -27.497 -3.6368
4985.595297 -27.255 -2.3882
4986.327719 -27.440 0.7220
4987.060141 -27.116 1.9285
4987.792563 -27.696 2.5187
4988.524984 -27.586 8.8546
4989.257406 -27.788 8.3715
4989.989828 -27.677 12.6681
4990.722250 -27.782 7.7690
4991.454672 -26.936 10.4935
4992.187093 -26.739 11.3783
4992.919515 -25.965 12.5878
4993.651937 -26.547 11.0101
4994.384359 -25.978 14.0327
4995.116781 -25.853 13.4403
4995.849203 -25.547 11.2457
4996.581624 -25.776 9.2635
4997.314046 -25.436 8.1509
4998.046468 -25.378 5.9349
4998.778890 -25.084 4.9221
4999.511312 -25.736 5.3112
5000.243733 -25.750 2.6769
5000.976155 -25.627 3.3992
5001.708577 -25.917 4.3958
5002.440999 -26.069 2.4197
5003.173421 -26.172 0.9480
5003.905842 -26.130 5.5579
5004.638264 -26.164 2.0255
5005.370686 -26.109 2.3741
5006.103108 -26.242 0.9512
5006.835530 -26.491 5.0187
5007.567952 -26.315 2.6376
5008.300373 -26.824 4.3180
5009.032795 -26.242 8.1763
5009.765217 -26.331 8.9898
5010.497639 -26.444 10.5072
5011.230061 -26.739 10.4698
5011.962482 -26.041 9.1588
5012.694904 -25.765 11.1674
5013.427326 -26.060 9.3322
5014.159748 -25.817 8.0924
5014.892170 -25.667 9.0417
5015.624592 -25.118 9.2618
5016.357013 -24.898 8.1413
5017.089435 -24.892 8.0106
5017.821857 -25.132 5.5469
5018.554279 -24.821 5.1430
5019.286701 -24.658 3.6410
5020.019122 -25.382 3.5845
5020.751544 -25.330 0.7291
5021.483966 -25.228 -0.2310
5022.216388 -25.199 -4.4293
5022.948810 -25.733 -0.6451
5023.681231 -25.556 -3.4925
5024.413653 -25.310 -0.4701
5025.146075 -25.738 -4.3879
5025.878497 -26.136 -2.1704
5026.610919 -26.923 -1.9631
5027.343341 -26.642 -1.6747
5028.075762 -26.252 -3.1697
5028.808184 -26.782 -0.4974
5029.540606 -27.368 -0.3060
5030.273028 -27.186 0.5168
5031.005450 -26.833 -1.6973
5031.737871 -27.606 1.6095
5032.470293 -27.264 3.7433
5033.202715 -27.020 6.9169
5033.935137 -27.306 2.5413
5034.667559 -27.026 5.3971
5035.399981 -27.250 6.9537
5036.132402 -26.621 9.0636
5036.864824 -25.993 4.8343
5037.597246 -27.033 9.3046
5038.329668 -26.158 6.5829
5039.062090 -26.434 6.7715
5039.794511 -26.594 5.6270
5040.526933 -26.650 5.3228
5041.259355 -26.408 5.5330
5041.991777 -26.357 4.5287
5042.724199 -26.711 3.5371
5043.456621 -26.082 6.2794
5044.189042 -26.117 6.1904
5044.921464 -26.280 5.2013
5045.653886 -26.880 2.7866
5046.386308 -26.705 3.6119
5047.118730 -26.599 4.4630
5047.851151 -26.596 6.8625
5048.583573 -26.744 8.3149
5049.315995 -26.085 11.0074
5050.048417 -26.578 9.4287
5050.780839 -26.884 9.3048
5051.513260 -26.675 7.8726
5052.245682 -26.349 9.8659
5052.978104 -26.122 10.6873
5053.710526 -25.763 9.6143
5054.442948 -26.610 10.0698
5055.175370 -26.070 12.9272
5055.907791 -25.479 10.7219
5056.640213 -25.567 9.2142
5057.372635 -25.892 5.2471
5058.105057 -25.871 6.9536
5058.837479 -25.181 6.6312
5059.569900 -25.367 8.4409
5060.302322 -25.665 8.3813
5061.034744 -25.325 7.3405
5061.767166 -25.670 1.8304
5062.499588 -25.896 4.9202
5063.232010 -26.527 1.2170
5063.964431 -25.984 2.9796
5064.696853 -26.340 4.5300
5065.429275 -26.116 3.6111
5066.161697 -26.863 2.4336
5066.894119 -26.446 5.4797
5067.626540 -26.166 4.6359
5068.358962 -26.447 5.6460
5069.091384 -26.227 6.5326
5069.823806 -26.123 6.6438
5070.556228 -26.011 4.9048
5071.288649 -25.848 1.5696
5072.021071 -25.770 5.2634
5072.753493 -25.829 6.3057
5073.485915 -25.757 5.2671
5074.218337 -25.552 2.2365
5074.950759 -25.840 2.9226
5075.683180 -25.734 4.5454
5076.415602 -25.601 3.1500
5077.148024 -25.386 -0.1207
5077.880446 -26.257 -2.8338
5078.612868 -26.065 -0.1467
5079.345289 -25.839 -3.5326
5080.077711 -25.466 -4.0639
5080.810133 -26.037 -3.4482
5081.542555 -26.216 -6.9077
5082.274977 -26.312 -7.0969
5083.007399 -26.712 -7.9562
5083.739820 -27.118 -10.9025
5084.472242 -26.747 -5.3352
5085.204664 -27.933 -9.0394
5085.937086 -28.023 -5.8710
5086.669508 -28.579 -3.3144
5087.401929 -28.267 -5.7462
5088.134351 -28.959 -1.7829
5088.866773 -28.461 0.3182
5089.599195 -29.307 6.5038
5090.331617 -28.487 8.9915
5091.064039 -28.777 8.7418
5091.796460 -28.260 12.6708
5092.528882 -28.365 15.4257
5093.261304 -27.973 12.9288
5093.993726 -27.262 15.8607
5094.726148 -26.450 18.7717
5095.458569 -26.479 15.7646
5096.190991 -26.001 13.5768
5096.923413 -26.197 13.3953
5097.655835 -25.003 11.9797
5098.388257 -24.977 13.4960
5099.120678 -25.313 8.9085
5099.853100 -24.924 6.0024
5100.585522 -24.753 3.8613
5101.317944 -24.799 4.8261
5102.050366 -24.307 -1.2936
5102.782788 -24.498 -3.1796
5103.515209 -24.563 -3.0721
5104.247631 -25.017 -5.0140
5104.980053 -24.851 -9.0837
5105.712475 -25.309 -10.3796
5106.444897 -25.508 -13.6475
5107.177318 -25.960 -10.4987
5107.909740 -26.343 -14.1141
5108.642162 -26.843 -18.1136
5109.374584 -27.393 -13.9323
5110.107006 -28.540 -10.8496
5110.839428 -28.579 -12.5470
5111.571849 -29.325 -10.9821
5112.304271 -29.710 -8.2817
5113.036693 -30.224 -5.5820
5113.769115 -29.934 -3.4152
5114.501537 -29.843 -1.1885
5115.233958 -29.429 8.3383
5115.966380 -29.563 10.0440
5116.698802 -29.489 13.1754
5117.431224 -28.644 13.6642
5118.163646 -28.379 16.2177
5118.896068 -27.535 18.5002
5119.628489 -27.808 16.4211
5120.360911 -26.813 13.9592
5121.093333 -26.786 14.7749
5121.825755 -26.336 14.0167
5122.558177 -26.080 11.4574
5123.290598 -25.583 8.2905
5124.023020 -26.159 4.4366
5124.755442 -25.970 6.4786
5125.487864 -25.630 3.3000
5126.220286 -25.716 3.1564
5126.952707 -25.428 -2.2899
5127.685129 -26.031 -1.0970
5128.417551 -26.410 -2.9010
5129.149973 -26.289 -6.5386
5129.882395 -26.848 -7.2012
5130.614817 -27.360 -8.6010
5131.347238 -27.594 -11.2358
5132.079660 -28.410 -5.0269
5132.812082 -28.815 -5.9150
5133.544504 -28.221 -4.0045
5134.276926 -29.729 -0.4611
5135.009347 -29.859 5.2350
5135.741769 -30.319 2.8068
5136.474191 -29.011 13.1591
5137.206613 -30.001 15.9413
5137.939035 -28.665 18.2417
5138.671457 -29.034 19.4422
5139.403878 -27.272 23.0145
5140.136300 -27.522 24.9293
5140.868722 -26.735 26.3792
5141.601144 -26.374 22.3594
5142.333566 -25.733 19.3821
5143.065987 -25.477 19.2063
5143.798409 -25.424 18.9810
5144.530831 -24.582 15.1234
5145.263253 -24.299 13.5363
5145.995675 -24.569 10.9692
5146.728096 -24.666 7.9181
5147.460518 -24.309 4.5530
5148.192940 -23.779 3.6035
5148.925362 -24.191 -1.0414
5149.657784 -24.270 -2.4030
5150.390206 -24.226 -4.9521
5151.122627 -24.449 -4.9120
5151.855049 -24.301 -6.3022
5152.587471 -24.956 -9.5369
5153.319893 -25.282 -13.2241
5154.052315 -24.894 -17.4231
5154.784736 -26.022 -17.2628
5155.517158 -26.645 -17.3245
5156.249580 -27.268 -18.1664
5156.982002 -27.235 -12.8542
5157.714424 -28.503 -14.7487
5158.446846 -28.292 -13.0916
5159.179267 -29.070 -5.9476
5159.911689 -29.524 -8.3912
5160.644111 -28.990 -1.3249
5161.376533 -29.246 1.2852
5162.108955 -29.496 3.4376
5162.841376 -29.559 7.8626
5163.573798 -28.697 7.6910
5164.306220 -28.884 16.0905
5165.038642 -27.895 13.6188
5165.771064 -27.884 10.1908
5166.503486 -27.628 11.5271
5167.235907 -27.196 11.2591
5167.968329 -26.524 11.4587
5168.700751 -26.802 8.5663
5169.433173 -26.289 4.8180
5170.165595 -26.023 3.9747
5170.898016 -26.269 2.3357
5171.630438 -25.496 -0.3405
5172.362860 -25.804 0.4198
5173.095282 -25.916 -4.7855
5173.827704 -26.071 -7.8917
5174.560125 -26.313 -7.8503
5175.292547 -27.097 -9.4576
5176.024969 -27.043 -11.9964
5176.757391 -28.013 -11.8810
5177.489813 -27.534 -10.7872
5178.222235 -28.342 -7.8723
5178.954656 -27.739 -12.1554
5179.687078 -28.377 -5.1348
5180.419500 -28.791 -6.1777
5181.151922 -28.725 -0.6502
5181.884344 -29.421 4.4591
5182.616765 -29.284 2.3607
5183.349187 -29.522 2.1069
5184.081609 -28.530 5.1340
5184.814031 -28.674 10.9258
5185.546453 -29.080 6.3524
5186.278875 -27.761 7.2269
5187.011296 -28.107 13.2050
5187.743718 -27.197 14.9784
5188.476140 -27.562 6.4625
5189.208562 -27.943 7.1179
5189.940984 -26.237 7.4720
5190.673405 -26.258 7.3911
5191.405827 -27.245 6.1077
5192.138249 -27.083 -0.8013
5192.870671 -26.321 0.1705
5193.603093 -26.629 2.3291
5194.335514 -26.406 -2.2625
5195.067936 -26.851 0.5978
5195.800358 -26.586 -3.0598
5196.532780 -27.023 -4.9476
5197.265202 -27.067 -7.4730
5197.997624 -27.043 -7.5712
5198.730045 -27.567 -10.6473
5199.462467 -27.865 -7.1697
5200.194889 -27.966 -9.8541
5200.927311 -29.026 -9.0587
5201.659733 -27.592 -15.5436
5202.392154 -28.928 -5.7466
5203.124576 -28.778 -15.2668
5203.856998 -28.408 -9.4620
5204.589420 -28.991 -6.2479
5205.321842 -28.745 -5.6660
5206.054264 -28.827 -7.2239
5206.786685 -29.071 7.6568
5207.519107 -29.328 2.3561
5208.251529 -28.414 3.9990
5208.983951 -29.229 1.5047
5209.716373 -28.646 5.6755
5210.448794 -28.082 3.6151
5211.181216 -27.773 8.1827
5211.913638 -28.244 -2.7386
5212.646060 -28.329 0.7194
5213.378482 -27.955 1.1570
5214.110904 -27.730 1.0607
5214.843325 -27.891 1.6202
5215.575747 -28.434 -4.7457
5216.308169 -28.936 0.8809
5217.040591 -28.562 0.7374
5217.773013 -28.105 -2.2192
5218.505434 -28.352 -3.2890
5219.237856 -28.122 -7.1625
5219.970278 -28.749 1.4518
5220.702700 -28.640 1.1868
5221.435122 -27.867 5.1699
5222.167543 -28.728 1.1625
5222.899965 -29.783 2.2983
5223.632387 -29.432 6.3237
5224.364809 -28.748 1.8063
5225.097231 -29.445 -0.2719
5225.829653 -28.493 1.8684
5226.562074 -27.888 12.3719
5227.294496 -28.312 9.1299
5228.026918 -27.899 12.2662
5228.759340 -26.704 8.5533
5229.491762 -27.498 8.3859
5230.224183 -28.110 9.6916
5230.956605 -27.822 7.1279
5231.689027 -27.166 8.7527
5232.421449 -27.250 9.0327
5233.153871 -27.553 12.0437
5233.886293 -26.113 7.6069
5234.618714 -26.846 9.0582
5235.351136 -27.508 9.1382
5236.083558 -26.825 6.9036
5236.815980 -28.329 7.7312
5237.548402 -27.392 8.9187
5238.280823 -28.342 10.2126
5239.013245 -27.222 6.7036
5239.745667 -27.806 9.3101
5240.478089 -28.025 5.4263
5241.210511 -27.837 10.9002
5241.942932 -28.162 3.2457
5242.675354 -28.302 4.2383
5243.407776 -27.774 3.1376
5244.140198 -27.146 3.9388
5244.872620 -26.318 5.3470
5245.605042 -27.047 0.8535
5246.337463 -26.702 3.9632
5247.069885 -28.067 8.4329
5247.802307 -27.565 3.6420
5248.534729 -27.335 3.6585
5249.267151 -28.170 3.0657
5249.999572 -26.662 -1.1344
5250.731994 -26.416 -7.9744
5251.464416 -26.755 -1.4690
5252.196838 -26.253 -7.6255
5252.929260 -27.080 -8.1789
5253.661682 -26.437 -9.4253
5254.394103 -27.771 -7.9598
5255.126525 -27.109 -7.5078
5255.858947 -27.063 -10.8040
5256.591369 -27.112 -13.4850
5257.323791 -27.922 -9.8774
5258.056212 -27.649 -16.4935
5258.788634 -27.291 -7.7141
5259.521056 -27.552 -14.2078
5260.253478 -29.080 -12.9922
5260.985900 -28.949 -10.3821
5261.718322 -29.328 -10.8048
5262.450743 -28.836 -6.3187
5263.183165 -29.776 -8.7595
5263.915587 -29.416 -5.9872
5264.648009 -29.295 -0.1461
5265.380431 -28.967 -0.7994
5266.112852 -29.431 -0.8375
5266.845274 -29.569 3.6807
5267.577696 -29.746 4.3975
5268.310118 -29.722 0.9644
5269.042540 -29.313 9.5960
5269.774961 -29.466 7.3953
5270.507383 -28.592 8.0746
5271.239805 -28.811 -3.5696
5271.972227 -28.699 4.8900
5272.704649 -28.191 -1.2449
5273.437071 -28.177 6.8356
5274.169492 -28.639 5.2310
5274.901914 -28.223 -1.7867
5275.634336 -28.895 4.8439
5276.366758 -28.867 6.5338
5277.099180 -29.180 5.8481
5277.831601 -28.803 3.9449
5278.564023 -28.513 -3.8756
5279.296445 -28.216 4.5519
5280.028867 -28.801 1.5405
5280.761289 -28.194 5.3886
5281.493711 -29.139 3.3477
5282.226132 -27.903 7.3655
5282.958554 -28.670 0.9838
5283.690976 -28.775 3.8006
5284.423398 -29.351 7.9391
5285.155820 -28.624 6.3162
5285.888241 -29.147 8.3420
5286.620663 -27.774 3.8331
5287.353085 -28.877 8.3644
5288.085507 -28.349 12.7179
5288.817929 -29.374 1.5399
5289.550350 -29.343 11.0172
5290.282772 -28.413 7.1201
5291.015194 -28.483 5.6987
5291.747616 -28.797 7.7192
5292.480038 -27.843 4.0887
5293.212460 -28.712 12.7414
5293.944881 -28.027 10.6691
5294.677303 -28.325 12.5045
5295.409725 -27.963 11.3242
5296.142147 -28.864 5.3662
5296.874569 -28.223 9.6450
5297.606990 -28.948 12.0339
5298.339412 -28.106 15.6567
5299.071834 -27.846 12.4163
5299.804256 -27.758 21.0663
5300.536678 -28.595 8.0533
5301.269100 -27.622 11.6615
5302.001521 -27.508 13.9481
5302.733943 -26.511 14.7002
5303.466365 -27.574 10.1058
5304.198787 -26.315 11.5756
5304.931209 -27.092 8.2282
5305.663630 -26.634 8.2503
5306.396052 -27.194 8.7440
5307.128474 -25.727 9.8131
5307.860896 -25.685 4.8569
5308.593318 -26.156 6.3749
5309.325740 -26.305 5.1959
5310.058161 -26.208 2.4171
5310.790583 -26.457 0.2328
5311.523005 -26.109 -0.3227
5312.255427 -26.307 -2.0299
5312.987849 -26.990 -5.4840
5313.720270 -26.448 -8.9019
5314.452692 -26.405 -8.8988
5315.185114 -27.345 -6.8853
5315.917536 -27.170 -11.8013
5316.649958 -26.619 -11.4010
5317.382379 -28.064 -10.3681
5318.114801 -29.259 -8.2847
5318.847223 -27.953 -9.0273
5319.579645 -29.126 -6.1323
5320.312067 -28.278 -1.8763
5321.044489 -28.926 -6.0284
5321.776910 -29.443 -0.3116
5322.509332 -28.512 1.2236
5323.241754 -28.739 1.9268
5323.974176 -28.722 3.6799
5324.706598 -29.336 3.9235
5325.439019 -28.585 7.0399
5326.171441 -28.805 2.5537
5326.903863 -29.294 6.1046
5327.636285 -28.693 10.8995
5328.368707 -28.037 12.6190
5329.101129 -27.989 8.4885
5329.833550 -27.823 17.8225
5330.565972 -27.970 14.6549
5331.298394 -27.547 11.9248
5332.030816 -28.031 13.8839
5332.763238 -27.031 14.4788
5333.495659 -27.584 11.0768
5334.228081 -27.198 13.3390
5334.960503 -27.103 12.2896
5335.692925 -26.851 10.7383
5336.425347 -26.607 11.5040
5337.157768 -26.041 7.2034
5337.890190 -25.958 6.1978
5338.622612 -25.551 3.6986
5339.355034 -25.838 2.7285
5340.087456 -25.680 4.1848
5340.819878 -25.802 2.5328
5341.552299 -26.021 1.3917
5342.284721 -25.644 -1.1498
5343.017143 -25.648 -2.0757
5343.749565 -26.326 -4.2739
5344.481987 -26.245 -3.0737
5345.214408 -27.520 -5.1961
5345.946830 -26.456 -6.5234
5346.679252 -27.038 -10.6556
5347.411674 -27.812 -7.1122
5348.144096 -27.677 -9.7654
5348.876518 -27.492 -14.5227
5349.608939 -28.226 -12.8363
5350.341361 -27.688 -12.8414
5351.073783 -28.121 -16.2826
5351.806205 -28.324 -15.3152
5352.538627 -28.536 -11.9658
5353.271048 -28.952 -11.8920
5354.003470 -29.270 -13.0962
5354.735892 -29.159 -11.0736
5355.468314 -29.922 -11.0256
5356.200736 -30.364 -2.2794
5356.933158 -30.677 -4.1515
5357.665579 -30.799 0.1365
5358.398001 -31.153 -4.3923
5359.130423 -30.985 6.4000
5359.862845 -30.798 5.0260
5360.595267 -31.308 1.5548
5361.327688 -30.673 4.1501
5362.060110 -29.530 6.5404
5362.792532 -30.436 10.5199
5363.524954 -29.846 3.8538
5364.257376 -29.222 9.6116
5364.989797 -28.700 11.8944
5365.722219 -29.649 11.1572
5366.454641 -29.734 8.3840
5367.187063 -28.895 6.5739
5367.919485 -28.498 4.6122
5368.651907 -29.344 4.8564
5369.384328 -28.911 -1.7188
5370.116750 -28.632 2.3854
5370.849172 -29.067 -1.3207
5371.581594 -28.966 1.7657
5372.314016 -29.105 -4.1587
5373.046437 -30.146 -1.3105
5373.778859 -28.972 -1.5977
5374.511281 -29.160 0.5914
5375.243703 -30.304 1.7418
5375.976125 -30.227 1.5658
5376.708547 -29.439 5.7560
5377.440968 -30.202 7.0374
5378.173390 -30.911 5.7372
5378.905812 -30.056 4.5750
5379.638234 -29.990 7.0377
5380.370656 -29.928 10.4252
5381.103077 -29.417 13.3842
5381.835499 -29.089 12.2791
5382.567921 -28.655 12.0624
5383.300343 -28.854 12.2081
5384.032765 -28.426 10.4904
5384.765186 -28.103 11.2029
5385.497608 -27.611 9.7358
5386.230030 -27.517 11.6492
5386.962452 -27.699 3.6534
5387.694874 -26.901 6.7047
5388.427296 -27.016 3.6918
5389.159717 -27.070 7.3691
5389.892139 -27.051 -0.9453
5390.624561 -27.324 2.7295
5391.356983 -27.006 -2.6914
5392.089405 -27.516 1.6633
5392.821826 -28.157 -4.5753
5393.554248 -27.831 -2.7230
5394.286670 -27.496 -4.1543
5395.019092 -28.437 -0.4089
5395.751514 -29.159 -5.6221
5396.483936 -28.792 -7.8219
5397.216357 -28.610 -4.0798
5397.948779 -29.366 -0.8820
5398.681201 -30.172 -0.0034
5399.413623 -29.155 1.2118
5400.146045 -28.973 2.2596
5400.878466 -29.713 4.2145
5401.610888 -29.952 8.8883
5402.343310 -28.899 11.9943
5403.075732 -28.144 8.6693
5403.808154 -28.490 11.4059
5404.540576 -28.414 10.2242
5405.272997 -27.504 11.3724
5406.005419 -27.110 7.8586
5406.737841 -27.268 9.2063
5407.470263 -27.316 11.9666
5408.202685 -27.156 6.9495
5408.935106 -26.194 3.7822
5409.667528 -26.281 1.4922
5410.399950 -27.304 1.6928
5411.132372 -26.037 -2.3756
5411.864794 -26.317 -4.4617
5412.597215 -26.064 -3.5253
5413.329637 -26.584 -8.8427
5414.062059 -27.362 -10.3928
5414.794481 -27.169 -14.9305
5415.526903 -27.306 -19.6307
5416.259325 -28.510 -22.2010
5416.991746 -28.352 -21.3986
5417.724168 -28.484 -22.8926
5418.456590 -28.634 -19.4542
5419.189012 -29.910 -21.2667
5419.921434 -30.902 -22.7737
5420.653855 -31.326 -23.5880
5421.386277 -31.389 -19.7911
5422.118699 -32.628 -22.9351
5422.851121 -32.545 -15.0307
5423.583543 -32.676 -15.3128
5424.315965 -32.089 -1.8613
5425.048386 -33.371 1.7305
5425.780808 -31.548 6.1834
5426.513230 -31.331 1.4510
5427.245652 -31.266 9.3671
5427.978074 -31.138 12.6411
5428.710495 -28.857 11.1393
5429.442917 -29.885 11.7542
5430.175339 -29.480 14.8758
5430.907761 -29.981 10.4014
5431.640183 -29.378 15.6537
5432.372604 -29.268 9.5248
5433.105026 -28.811 9.0519
5433.837448 -28.844 7.0046
5434.569870 -27.856 3.0594
5435.302292 -28.380 3.5945
5436.034714 -27.530 2.9431
5436.767135 -27.818 2.8307
5437.499557 -27.756 -0.3403
5438.231979 -28.130 -1.7783
5438.964401 -28.161 -2.6522
5439.696823 -28.822 -5.4394
5440.429244 -28.472 -8.3123
5441.161666 -28.779 -9.4943
5441.894088 -28.225 -10.2226
5442.626510 -29.496 -3.4547
5443.358932 -28.995 -5.6320
5444.091354 -30.449 -5.9172
5444.823775 -30.139 -6.8553
5445.556197 -29.956 -6.3300
5446.288619 -30.065 -11.7623
5447.021041 -31.014 -3.6803
5447.753463 -30.473 -5.3243
5448.485884 -30.712 -6.4279
5449.218306 -30.297 -2.6181
5449.950728 -30.310 -4.5831
5450.683150 -30.010 0.2509
5451.415572 -30.645 1.6313
5452.147994 -30.284 -5.4309
5452.880415 -30.244 -4.6946
5453.612837 -29.428 -4.8627
5454.345259 -29.685 2.0138
5455.077681 -29.691 0.7842
5455.810103 -30.426 0.4134
5456.542524 -30.191 -1.2369
5457.274946 -30.164 -0.3661
5458.007368 -29.668 -4.2354
5458.739790 -30.269 -2.4884
5459.472212 -29.554 -8.7066
5460.204633 -29.719 -0.6107
5460.937055 -29.983 -4.2614
5461.669477 -30.093 -3.2698
5462.401899 -30.594 -5.1661
5463.134321 -30.399 1.9580
5463.866743 -31.105 -7.1195
5464.599164 -30.263 -1.3429
5465.331586 -30.893 -9.4399
5466.064008 -31.819 2.7762
5466.796430 -30.397 1.7597
5467.528852 -31.191 0.6922
5468.261273 -31.589 7.9206
5468.993695 -31.465 10.7288
5469.726117 -31.002 12.0162
5470.458539 -31.128 10.4268
5471.190961 -31.306 7.1248
5471.923383 -30.666 12.1318
5472.655804 -30.101 11.8400
5473.388226 -30.362 11.2041
5474.120648 -29.977 11.7377
5474.853070 -29.960 14.3789
5475.585492 -29.803 12.2396
5476.317913 -29.729 10.9353
5477.050335 -29.074 7.0840
5477.782757 -28.920 12.2712
5478.515179 -28.875 11.3107
5479.247601 -28.765 10.3784
5479.980022 -28.640 5.8137
5480.712444 -28.575 9.2858
5481.444866 -29.037 1.3363
5482.177288 -28.794 3.5983
5482.909710 -28.339 -7.4198
5483.642132 -29.015 -0.0103
5484.374553 -29.046 -1.9234
5485.106975 -29.060 0.7050
5485.839397 -29.234 -2.6208
5486.571819 -29.439 -2.3661
5487.304241 -30.057 -6.7448
5488.036662 -30.011 4.1520
5488.769084 -30.532 -8.7366
5489.501506 -29.290 2.4463
5490.233928 -30.462 -1.6436
5490.966350 -30.681 2.6915
5491.698772 -30.934 5.2441
5492.431193 -31.146 3.4515
5493.163615 -31.036 13.0898
5493.896037 -31.307 13.8859
5494.628459 -30.857 10.0931
5495.360881 -29.836 16.4191
5496.093302 -29.972 12.3933
5496.825724 -29.757 14.2824
5497.558146 -29.290 16.7025
5498.290568 -28.103 18.5676
5499.022990 -28.234 20.1897
5499.755412 -28.428 14.7882
5500.487833 -28.544 12.4689
5501.220255 -27.398 12.0195
5501.952677 -27.430 8.1736
5502.685099 -27.292 7.9547
5503.417521 -26.904 6.5241
5504.149942 -26.800 3.4786
5504.882364 -27.254 3.6461
5505.614786 -26.929 1.5223
5506.347208 -28.149 -7.0333
5507.079630 -27.253 -3.4677
5507.812051 -27.628 -6.0178
5508.544473 -28.127 -8.0784
5509.276895 -28.508 -6.4774
5510.009317 -28.064 -8.3640
5510.741739 -28.842 -11.6096
5511.474161 -29.017 -9.4337
5512.206582 -30.783 -11.4252
5512.939004 -29.839 -7.5157
5513.671426 -30.462 -8.2920
5514.403848 -30.771 -9.6345
5515.136270 -31.017 -4.3959
5515.868691 -30.448 -2.2070
5516.601113 -30.574 -0.6025
5517.333535 -31.074 5.4810
5518.065957 -31.458 -0.2664
5518.798379 -30.006 8.2697
5519.530801 -30.711 3.1665
5520.263222 -30.336 10.6300
5520.995644 -29.470 5.3910
5521.728066 -29.178 9.0308
5522.460488 -29.542 8.7742
5523.192910 -28.860 3.5870
5523.925331 -29.446 4.0529
5524.657753 -28.261 -0.4349
5525.390175 -28.617 -2.7106
5526.122597 -28.036 -3.3378
5526.855019 -28.206 -3.6527
5527.587440 -29.068 -4.5057
5528.319862 -29.467 -4.9188
5529.052284 -28.665 -8.6686
5529.784706 -30.495 -12.5592
5530.517128 -29.400 -11.7087
5531.249550 -29.748 -13.3348
5531.981971 -29.330 -15.1190
5532.714393 -30.474 -16.1135
5533.446815 -30.438 -14.8922
5534.179237 -31.293 -15.8166
5534.911659 -31.427 -10.3342
5535.644080 -32.832 -2.8623
5536.376502 -31.232 -12.7537
5537.108924 -32.617 -7.8699
5537.841346 -33.011 -6.2408
5538.573768 -32.010 4.3701
5539.306190 -32.098 11.2817
5540.038611 -31.598 10.6786
5540.771033 -30.881 11.9308
5541.503455 -30.745 19.3971
5542.235877 -30.098 15.5289
5542.968299 -29.938 14.5359
5543.700720 -29.706 13.9453
5544.433142 -29.684 15.4074
5545.165564 -29.077 11.6998
5545.897986 -28.777 10.0139
5546.630408 -27.967 13.0416
5547.362830 -28.768 17.5526
5548.095251 -27.995 6.8408
5548.827673 -28.510 3.5372
5549.560095 -27.942 2.2855
5550.292517 -28.274 0.4003
5551.024939 -27.799 2.1214
5551.757360 -28.637 0.0774
5552.489782 -28.361 -0.4331
5553.222204 -28.491 4.5221
5553.954626 -28.367 -4.2471
5554.687048 -28.404 -7.1058
5555.419469 -28.900 -4.8693
5556.151891 -29.227 -6.0139
5556.884313 -28.756 -4.8217
5557.616735 -29.500 -1.4401
5558.349157 -29.439 -6.7438
5559.081579 -29.212 4.3113
5559.814000 -29.194 -2.2505
5560.546422 -29.438 2.8760
5561.278844 -29.370 1.7216
5562.011266 -28.973 1.2394
5562.743688 -28.977 -3.7473
5563.476109 -29.040 -2.3375
5564.208531 -28.219 -1.4865
5564.940953 -27.935 2.7487
5565.673375 -28.212 -5.1586
5566.405797 -28.242 -1.5006
5567.138219 -28.147 -5.0840
5567.870640 -28.412 -7.6062
5568.603062 -27.347 -8.9084
5569.335484 -28.846 -9.2848
5570.067906 -28.697 -12.0471
5570.800328 -28.713 -11.7323
5571.532749 -29.716 -18.2947
5572.265171 -28.794 -15.5659
5572.997593 -30.390 -23.8032
5573.730015 -29.129 -18.8484
5574.462437 -29.941 -24.4487
5575.194858 -30.093 -9.9456
5575.927280 -30.475 -23.2418
5576.659702 -30.451 -17.1774
5577.392124 -31.397 -15.7992
5578.124546 -32.096 -15.2756
5578.856968 -32.512 -15.5518
5579.589389 -33.265 -11.2811
5580.321811 -32.307 -10.6125
5581.054233 -32.631 -0.2170
5581.786655 -32.139 -7.4079
5582.519077 -31.223 -2.2513
5583.251498 -31.742 -0.8273
5583.983920 -31.875 -0.3934
5584.716342 -31.473 4.6892
5585.448764 -30.378 -1.0828
5586.181186 -29.979 -0.2657
5586.913608 -29.335 1.8635
5587.646029 -29.743 -2.7230
5588.378451 -29.078 -3.9479
5589.110873 -29.349 -6.6112
5589.843295 -29.598 -5.7117
5590.575717 -29.790 -12.8492
5591.308138 -29.180 -16.1001
5592.040560 -29.666 -22.1908
5592.772982 -30.190 -17.6934
5593.505404 -29.755 -24.4028
5594.237826 -28.489 -16.8627
5594.970248 -30.296 -27.1964
5595.702669 -31.678 -22.4867
5596.435091 -33.096 -24.5586
5597.167513 -32.219 -32.5813
5597.899935 -32.337 -26.7634
5598.632357 -33.343 -27.0785
5599.364778 -34.490 -27.2534
5600.097200 -34.850 -23.5159
5600.829622 -34.412 -27.5972
5601.562044 -36.745 -24.5753
5602.294466 -39.702 -16.7795
5603.026887 -37.681 -7.8059
5603.759309 -38.319 -9.0750
5604.491731 -36.470 -4.9442
5605.224153 -35.865 16.2314
5605.956575 -35.776 5.1525
5606.688997 -35.703 4.9480
5607.421418 -34.064 9.9490
5608.153840 -33.782 16.5903
5608.886262 -31.024 12.7750
5609.618684 -32.321 10.5980
5610.351106 -33.710 15.8247
5611.083527 -31.837 13.0875
5611.815949 -30.265 6.5404
5612.548371 -32.446 -1.9769
5613.280793 -30.776 4.6049
5614.013215 -30.987 -0.1435
5614.745637 -30.202 1.0321
5615.478058 -31.904 -2.6486
5616.210480 -30.988 0.5464
5616.942902 -31.349 -7.7872
5617.675324 -30.706 -12.2390
5618.407746 -32.767 -2.9076
5619.140167 -33.281 3.9146
5619.872589 -35.155 0.9927
5620.605011 -35.126 -2.6937
5621.337433 -32.776 -5.8717
5622.069855 -33.161 -7.0374
5622.802276 -34.714 -3.3074
5623.534698 -34.060 3.8308
5624.267120 -34.680 0.1738
5624.999542 -33.106 9.1453
5625.731964 -31.799 13.5474
5626.464386 -31.845 2.7138
5627.196807 -32.091 7.0850
5627.929229 -32.258 11.3494
5628.661651 -30.912 13.3724
5629.394073 -30.865 11.8041
5630.126495 -29.777 12.2415
5630.858916 -30.049 9.1841
5631.591338 -30.284 14.8488
5632.323760 -30.112 4.2128
5633.056182 -30.091 4.7565
5633.788604 -30.295 7.9857
5634.521026 -29.700 8.0414
5635.253447 -30.005 -0.7582
5635.985869 -30.133 -5.8872
5636.718291 -30.370 0.1605
5637.450713 -30.144 0.3362
5638.183135 -29.526 -12.7706
5638.915556 -30.700 -6.8784
5639.647978 -30.890 -9.2802
5640.380400 -31.171 -9.0100
5641.112822 -30.451 -17.8425
5641.845244 -32.552 -8.9297
5642.577666 -31.975 -9.2058
5643.310087 -33.319 0.6136
5644.042509 -34.031 -7.2253
5644.774931 -33.430 -5.2139
5645.507353 -34.859 1.1244
5646.239775 -33.881 9.3572
5646.972196 -35.314 4.5837
5647.704618 -35.210 17.3969
5648.437040 -34.202 24.7590
5649.169462 -34.575 29.8657
5649.901884 -32.811 36.0970
5650.634305 -33.516 32.6140
5651.366727 -32.775 37.1159
5652.099149 -30.954 28.3653
5652.831571 -30.894 35.8728
5653.563993 -30.838 29.3659
5654.296415 -30.685 33.0004
5655.028836 -30.060 27.5582
5655.761258 -30.474 25.2648
5656.493680 -29.759 30.7618
5657.226102 -29.526 19.7147
5657.958524 -28.334 25.2413
5658.690945 -29.549 19.4788
5659.423367 -29.198 21.2747
5660.155789 -28.451 10.9811
5660.888211 -28.429 15.3099
5661.620633 -28.863 11.2501
5662.353055 -29.239 10.6285
5663.085476 -29.113 5.6738
5663.817898 -28.937 10.2690
5664.550320 -29.309 7.8414
5665.282742 -30.265 4.7219
5666.015164 -30.112 7.7123
5666.747585 -28.722 7.9966
5667.480007 -30.877 8.5487
5668.212429 -30.243 9.9209
5668.944851 -30.542 8.4147
5669.677273 -29.277 10.3083
5670.409694 -28.996 13.0586
5671.142116 -29.808 10.6614
5671.874538 -29.736 11.3988
5672.606960 -29.653 12.4983
5673.339382 -29.472 12.8684
5674.071804 -29.687 11.7842
5674.804225 -29.728 10.1680
5675.536647 -28.566 5.3145
5676.269069 -29.429 9.2611
5677.001491 -29.605 7.1366
5677.733913 -28.728 7.9963
5678.466334 -28.139 5.0219
5679.198756 -28.452 0.0128
5679.931178 -28.834 -0.5917
5680.663600 -28.879 3.2126
5681.396022 -28.867 1.2386
5682.128444 -28.535 -2.1720
5682.860865 -29.795 -2.2756
5683.593287 -29.154 -2.2245
5684.325709 -28.698 -6.2242
5685.058131 -29.897 -5.4562
5685.790553 -29.625 -5.9104
5686.522974 -29.967 -10.3741
5687.255396 -29.286 -13.2095
5687.987818 -30.442 -9.2785
5688.720240 -30.581 -4.8933
5689.452662 -30.639 -10.9822
5690.185084 -30.324 -12.5730
5690.917505 -31.523 -10.5667
5691.649927 -31.696 -8.6566
5692.382349 -31.798 -4.7895
5693.114771 -30.817 -5.0812
5693.847193 -30.690 -4.5066
5694.579614 -31.299 0.9680
5695.312036 -31.299 1.7136
5696.044458 -30.140 -0.1409
5696.776880 -31.810 -0.5116
5697.509302 -31.717 0.6512
5698.241723 -31.112 3.5682
5698.974145 -30.782 -5.3657
5699.706567 -30.800 1.5786
5700.438989 -31.008 1.6195
5701.171411 -31.412 -1.0928
5701.903833 -30.603 0.3174
5702.636254 -31.454 -2.5432
5703.368676 -31.482 1.4064
5704.101098 -31.480 2.9991
5704.833520 -31.735 -4.6011
5705.565942 -31.939 4.6732
5706.298363 -31.016 4.3619
5707.030785 -32.061 4.0890
5707.763207 -31.250 1.0506
5708.495629 -31.530 12.1660
5709.228051 -31.421 12.3106
5709.960473 -32.248 12.5518
5710.692894 -31.035 4.1622
5711.425316 -31.458 8.0568
5712.157738 -31.046 10.5884
5712.890160 -30.728 7.7990
5713.622582 -30.271 2.4197
5714.355003 -30.669 13.4437
5715.087425 -30.530 9.7518
5715.819847 -29.787 6.9045
5716.552269 -29.698 2.0297
5717.284691 -29.766 1.9258
5718.017112 -29.714 5.2277
5718.749534 -29.726 0.9048
5719.481956 -29.225 -7.9340
5720.214378 -29.599 -2.0399
5720.946800 -29.587 -3.9668
5721.679222 -29.560 -7.2921
5722.411643 -29.427 -12.9694
5723.144065 -30.008 -9.8270
5723.876487 -30.511 -12.2388
5724.608909 -30.344 -15.9515
5725.341331 -30.016 -19.0406
5726.073752 -31.049 -19.1855
5726.806174 -31.639 -16.4406
5727.538596 -31.636 -20.1893
5728.271018 -32.050 -24.0123
5729.003440 -32.200 -15.3617
5729.735862 -33.029 -12.8289
5730.468283 -33.242 -15.6625
5731.200705 -33.104 -16.9973
5731.933127 -34.061 -1.9401
5732.665549 -34.423 -5.3622
5733.397971 -33.958 6.6665
5734.130392 -34.271 -4.6809
5734.862814 -34.050 8.1342
5735.595236 -32.607 7.9683
5736.327658 -33.278 8.8585
5737.060080 -33.016 5.7422
5737.792502 -31.969 11.2328
5738.524923 -32.792 11.4319
5739.257345 -32.600 6.6738
5739.989767 -32.571 0.7036
5740.722189 -31.868 3.6436
5741.454611 -31.831 -0.5070
5742.187032 -31.034 -0.0118
5742.919454 -31.116 -9.7887
5743.651876 -31.596 -6.7073
5744.384298 -32.076 -5.9762
5745.116720 -31.737 -6.8561
5745.849141 -32.837 -12.5756
5746.581563 -32.806 -9.0841
5747.313985 -33.168 -7.6738
5748.046407 -33.195 -6.8498
5748.778829 -33.453 -12.2229
5749.511251 -34.343 -7.5125
5750.243672 -35.036 1.4626
5750.976094 -35.223 5.6509
5751.708516 -36.605 0.3531
5752.440938 -34.826 3.5677
5753.173360 -34.151 15.1383
5753.905781 -33.161 27.8237
5754.638203 -34.414 24.8647
5755.370625 -32.572 24.9907
5756.103047 -32.469 28.6641
5756.835469 -31.229 25.5978
5757.567891 -32.379 24.5071
5758.300312 -31.158 29.0732
5759.032734 -30.904 23.2303
5759.765156 -30.024 18.3947
5760.497578 -29.997 20.9100
5761.230000 -29.043 17.7256
5761.962421 -29.114 12.6819
5762.694843 -28.750 15.3613
5763.427265 -29.497 12.3397
5764.159687 -29.066 7.2367
5764.892109 -28.734 8.1282
5765.624530 -28.812 6.1062
5766.356952 -29.753 3.3368
5767.089374 -29.179 -1.1781
5767.821796 -29.731 -2.7784
5768.554218 -29.651 -5.8212
5769.286640 -30.829 -5.4409
5770.019061 -30.218 -5.7792
5770.751483 -30.855 -12.7191
5771.483905 -31.010 -11.0297
5772.216327 -32.064 -14.7312
5772.948749 -32.669 -5.8451
5773.681170 -32.527 -6.8096
5774.413592 -33.287 -7.9862
5775.146014 -34.274 -4.1758
5775.878436 -33.692 -3.0010
5776.610858 -33.886 5.2878
5777.343280 -34.247 4.0807
5778.075701 -34.913 7.3691
5778.808123 -34.349 6.5707
5779.540545 -34.244 16.2892
5780.272967 -32.679 14.0010
5781.005389 -32.886 20.7355
5781.737810 -32.667 16.2454
5782.470232 -32.725 11.0438
5783.202654 -32.076 14.8698
5783.935076 -31.595 17.1806
5784.667498 -31.340 9.4496
5785.399920 -30.826 18.3439
5786.132341 -31.684 11.1317
5786.864763 -30.631 14.6597
5787.597185 -31.391 11.9575
5788.329607 -30.624 13.7861
5789.062029 -30.799 9.2476
5789.794450 -31.179 12.1967
5790.526872 -30.461 10.1810
5791.259294 -31.221 11.7246
5791.991716 -30.379 3.4534
5792.724138 -31.170 12.5908
5793.456559 -31.542 1.6825
5794.188981 -31.608 11.4575
5794.921403 -30.951 4.4445
5795.653825 -31.695 6.2628
5796.386247 -32.431 8.3802
5797.118669 -31.448 8.0758
5797.851090 -31.255 5.1116
5798.583512 -30.623 10.7607
5799.315934 -31.972 3.1838
5800.048356 -31.777 13.9205
5800.780778 -30.522 11.0741
5801.513199 -30.396 10.7394
5802.245621 -31.767 6.7834
5802.978043 -30.868 7.6636
5803.710465 -30.381 8.7307
5804.442887 -29.824 6.9156
5805.175309 -30.139 2.5330
5805.907730 -29.985 7.6091
5806.640152 -30.098 6.5360
5807.372574 -29.407 2.5837
5808.104996 -29.783 0.1792
5808.837418 -29.458 -4.7623
5809.569839 -30.371 -0.9503
5810.302261 -29.417 -6.1365
5811.034683 -29.471 -7.4243
5811.767105 -30.373 -7.6667
5812.499527 -30.520 -8.3276
5813.231948 -30.510 -6.1395
5813.964370 -31.041 -12.7380
5814.696792 -32.166 -11.7822
5815.429214 -32.692 -7.7098
5816.161636 -31.646 -14.6977
5816.894058 -32.624 -13.7771
5817.626479 -33.277 -11.1188
5818.358901 -34.020 -6.9254
5819.091323 -34.684 -6.6108
5819.823745 -35.474 -1.1259
5820.556167 -35.655 10.6633
5821.288588 -34.486 13.0661
5822.021010 -33.868 15.4924
5822.753432 -35.792 15.9354
5823.485854 -33.532 20.2914
5824.218276 -33.582 22.6635
5824.950698 -31.774 17.4260
5825.683119 -32.733 24.7376
5826.415541 -31.289 17.8048
5827.147963 -31.322 12.9086
5827.880385 -30.140 12.9482
5828.612807 -31.133 15.7687
5829.345228 -30.187 18.6342
5830.077650 -30.380 10.8149
5830.810072 -29.166 6.4910
5831.542494 -29.843 11.8195
5832.274916 -29.484 4.0502
5833.007338 -29.190 -0.8503
5833.739759 -29.245 -1.6351
5834.472181 -29.430 -8.9377
5835.204603 -29.917 -0.0880
5835.937025 -30.248 -7.5200
5836.669447 -30.111 -7.9024
5837.401868 -31.475 1.6760
5838.134290 -31.490 -8.5331
5838.866712 -32.626 -15.0578
5839.599134 -31.406 -13.9130
5840.331556 -33.941 -13.2210
5841.063977 -33.414 -11.4982
5841.796399 -34.665 -7.3539
5842.528821 -34.301 -15.4974
5843.261243 -34.495 21.5428
5843.993665 -35.404 9.6539
5844.726087 -34.828 9.4537
5845.458508 -35.406 9.7515
5846.190930 -35.090 28.2481
5846.923352 -34.230 34.9886
5847.655774 -33.533 24.3333
5848.388196 -33.228 20.0179
5849.120617 -31.514 31.6142
5849.853039 -32.208 29.9072
5850.585461 -31.133 25.2529
5851.317883 -30.762 16.9563
5852.050305 -31.270 14.2024
5852.782727 -30.045 21.5377
5853.515148 -29.148 18.3661
5854.247570 -30.108 10.5782
5854.979992 -28.835 13.2710
5855.712414 -29.784 6.3967
5856.444836 -29.351 4.5785
5857.177257 -29.672 -5.8295
5857.909679 -30.481 -9.8060
5858.642101 -30.694 -5.4697
5859.374523 -30.696 -9.7220
5860.106945 -30.045 -16.5898
5860.839366 -30.153 -5.0165
5861.571788 -32.539 -7.7838
5862.304210 -32.156 -16.2150
5863.036632 -32.750 -22.0821
5863.769054 -35.640 -25.2968
5864.501476 -34.800 -3.1112
5865.233897 -35.070 -3.0392
5865.966319 -34.313 -8.8007
5866.698741 -32.635 8.9661
5867.431163 -34.379 19.4406
5868.163585 -33.836 18.4038
5868.896006 -33.911 8.6540
5869.628428 -35.581 19.5497
5870.360850 -32.980 29.2989
5871.093272 -31.515 21.5695
5871.825694 -31.684 11.2806
5872.558116 -29.297 18.7570
5873.290537 -30.595 15.8907
5874.022959 -30.205 5.9022
5874.755381 -31.259 -2.7644
5875.487803 -31.238 12.1038
5876.220225 -28.896 6.7346
5876.952646 -29.667 0.4260
5877.685068 -30.709 -14.0836
5878.417490 -28.647 -7.1602
5879.149912 -30.186 -4.8951
5879.882334 -30.144 -14.6096
5880.614756 -31.279 -22.5352
5881.347177 -34.671 -14.5927
5882.079599 -30.915 -14.9871
5882.812021 -32.137 -29.8228
5883.544443 -33.684 -43.8475
5884.276865 -32.469 -26.0171
5885.009286 -35.969 -17.0751
5885.741708 -38.868 -26.7535
5886.474130 -40.474 -33.9961
5887.206552 -46.208 -6.9539
5887.938974 -38.257 13.6714
5888.671395 -41.650 26.5245
5889.403817 -42.074 5.0051
5890.136239 -34.154 13.5572
5890.868661 -35.391 54.7281
5891.601083 -34.460 38.3157
5892.333505 -35.933 50.9352
5893.065926 -32.487 55.7255
5893.798348 -30.321 34.8490
5894.530770 -31.210 28.1315
5895.263192 -31.617 31.5916
5895.995614 -28.147 17.2026
5896.728035 -28.172 26.6527
5897.460457 -29.309 16.8831
5898.192879 -30.300 15.4178
5898.925301 -29.706 20.6009
5899.657723 -28.372 13.5778
5900.390145 -28.060 5.1326
5901.122566 -29.785 -0.3268
5901.854988 -27.235 -13.7648
5902.587410 -29.364 -0.2820
5903.319832 -29.245 -12.6061
5904.052254 -31.640 -19.0924
5904.784675 -33.950 -6.3606
5905.517097 -30.283 -9.7114
5906.249519 -31.595 -30.2764
5906.981941 -32.282 -30.6048
5907.714363 -29.977 -35.1384
5908.446784 -32.713 -29.3716
5909.179206 -37.518 -50.7648
5909.911628 -38.568 -23.7566
5910.644050 -39.288 35.9866
5911.376472 -34.632 -14.1079
5912.108894 -44.093 25.2485
5912.841315 -41.556 1.7145
5913.573737 -39.365 -20.7587
5914.306159 -36.740 29.4756
5915.038581 -36.940 35.3758
5915.771003 -34.067 42.8181
5916.503424 -32.017 59.7905
5917.235846 -32.165 38.4706
5917.968268 -34.060 41.0392
5918.700690 -35.711 57.8384
5919.433112 -35.993 -19.1287
5920.165534 -32.116 33.4189
5920.897955 -31.306 34.1140
5921.630377 -34.231 31.9185
5922.362799 -30.903 48.8374
5923.095221 -32.696 3.2490
5923.827643 -30.688 25.7039
5924.560064 -31.645 32.2419
5925.292486 -32.597 -2.0339
5926.024908 -29.442 9.3641
5926.757330 -33.788 11.9205
5927.489752 -30.618 21.3617
5928.222174 -30.909 33.3344
5928.954595 -31.687 5.6592
5929.687017 -35.396 -15.7825
5930.419439 -37.818 5.5681
5931.151861 -38.746 -19.1057
5931.884283 -31.673 -0.4223
5932.616704 -39.040 43.7144
5933.349126 -36.057 19.1541
5934.081548 -29.696 42.4253
5934.813970 -32.010 16.5759
5935.546392 -34.343 21.3331
5936.278813 -34.278 43.1991
5937.011235 -37.531 16.0168
5937.743657 -33.654 24.0594
5938.476079 -34.335 33.6329
5939.208501 -31.476 45.3627
5939.940923 -30.636 46.2732
5940.673344 -31.348 16.9323
5941.405766 -31.111 35.7753
5942.138188 -31.896 30.9107
5942.870610 -30.856 32.7133
5943.603032 -30.810 36.7716
5944.335453 -31.865 25.2397
5945.067875 -28.824 49.3327
5945.800297 -26.778 35.2548
5946.532719 -28.807 13.6160
5947.265141 -32.200 22.6660
5947.997563 -28.243 30.6461
5948.729984 -29.883 0.6259
5949.462406 -29.356 12.1922
5950.194828 -31.252 22.9103
5950.927250 -31.901 16.4956
5951.659672 -28.780 12.5964
5952.392093 -28.465 9.1239
5953.124515 -34.521 40.8156
5953.856937 -29.966 15.6088
5954.589359 -33.395 39.0810
5955.321781 -31.152 -2.4666
5956.054202 -29.799 23.3436
5956.786624 -30.178 29.4678
5957.519046 -30.067 28.4200
5958.251468 -35.792 13.3145
5958.983890 -32.289 41.7222
5959.716312 -29.702 24.3060
5960.448733 -35.854 57.1131
5961.181155 -32.581 16.3652
5961.913577 -30.965 50.0342
5962.645999 -29.897 49.7621
5963.378421 -27.768 26.6718
5964.110842 -31.754 23.6166
5964.843264 -26.996 35.6016
5965.575686 -28.443 47.4935
5966.308108 -32.355 34.9613
5967.040530 -30.122 43.1414
5967.772952 -27.781 36.6360
5968.505373 -26.642 42.3946
5969.237795 -26.416 21.8054
5969.970217 -27.631 26.7363
5970.702639 -29.595 30.5596
5971.435061 -24.645 42.5234
5972.167482 -28.496 30.9399
5972.899904 -26.382 4.9565
5973.632326 -27.382 18.8309
5974.364748 -26.999 16.5359
5975.097170 -24.660 10.7319
5975.829592 -27.381 4.1893
5976.562013 -26.757 21.1683
5977.294435 -27.149 10.5363
5978.026857 -26.767 12.5956
5978.759279 -27.747 -0.3514
5979.491701 -29.684 -6.1758
5980.224122 -26.354 -13.3368
5980.956544 -24.732 -16.5908
5981.688966 -29.278 -4.5320
5982.421388 -28.411 2.2643
5983.153810 -27.439 -10.4717
5983.886231 -30.618 34.4018
5984.618653 -28.704 -4.3319
5985.351075 -28.953 16.4363
5986.083497 -28.356 2.1365
5986.815919 -30.334 -25.6712
5987.548341 -36.192 -13.4153
5988.280762 -27.103 25.6523
5989.013184 -29.678 16.5762
5989.745606 -30.741 26.6010
5990.478028 -29.698 14.4353
5991.210450 -30.277 14.6368
5991.942871 -27.803 5.3423
5992.675293 -28.518 -3.2302
5993.407715 -28.667 4.2605
5994.140137 -27.403 12.1492
5994.872559 -26.685 -1.6895
5995.604981 -27.430 20.8229
5996.337402 -31.561 10.4950
5997.069824 -27.422 5.1724
5997.802246 -26.981 3.1900
5998.534668 -26.816 -26.3638
5999.267090 -30.979 -19.1582
5999.999511 -31.286 8.9264
6000.731933 -36.145 18.8863
6001.464355 -36.315 21.5225
6002.196777 -37.177 21.3435
6002.929199 -31.924 1.8208
6003.661620 -29.582 18.0118
6004.394042 -38.157 -0.6276
6005.126464 -41.261 -16.3900
6005.858886 -35.161 8.5497
6006.591308 -34.691 -1.2937
6007.323730 -32.134 48.6003
6008.056151 -37.254 29.0816
6008.788573 -34.326 3.5648
6009.520995 -31.274 -2.7445
6010.253417 -37.545 12.8000
6010.985839 -32.859 10.5402
6011.718260 -31.535 16.0957
6012.450682 -34.294 50.5844
6013.183104 -31.548 28.6314
6013.915526 -32.997 36.2860
6014.647948 -28.321 7.2031
6015.380370 -30.936 -15.7953
6016.112791 -31.993 18.7554
6016.845213 -32.915 45.6008
6017.577635 -34.847 35.9916
6018.310057 -33.996 15.9875
6019.042479 -28.433 17.8203
6019.774900 -36.238 24.8617
6020.507322 -31.917 12.3203
6021.239744 -30.483 4.4588
6021.972166 -40.361 16.4662
6022.704588 -31.453 22.0729
6023.437010 -30.879 31.4885
6024.169431 -29.393 0.5360
6024.901853 -31.794 -8.2610
6025.634275 -36.725 24.7784
6026.366697 -31.474 10.0923
6027.099119 -38.086 -4.9308
6027.831540 -32.258 -6.4321
6028.563962 -28.755 6.7800
6029.296384 -30.040 10.8090
6030.028806 -30.161 1.0767
6030.761228 -29.847 20.9009
6031.493649 -30.012 22.6154
6032.226071 -31.910 44.3977
6032.958493 -32.018 4.0989
6033.690915 -35.830 13.4432
6034.423337 -30.020 4.6519
6035.155759 -31.679 14.8726
6035.888180 -32.827 -8.6819
6036.620602 -32.271 -1.5095
6037.353024 -29.125 0.0929
6038.085446 -32.423 11.0576
6038.817868 -31.793 -9.3314
6039.550289 -32.157 -11.4378
6040.282711 -36.352 26.4777
6041.015133 -31.241 -10.7067
6041.747555 -31.388 -18.7059
6042.479977 -29.374 -21.2494
6043.212399 -30.244 1.9905
6043.944820 -35.032 -17.8851
6044.677242 -37.312 -5.1341
6045.409664 -34.251 -18.6525
6046.142086 -34.402 -14.2705
6046.874508 -41.432 21.7068
6047.606929 -39.699 50.1146
6048.339351 -33.538 -1.0369
6049.071773 -36.271 13.7804
6049.804195 -35.603 28.8344
6050.536617 -37.045 32.4299
6051.269038 -34.287 37.9837
6052.001460 -33.559 31.7245
6052.733882 -35.352 42.9691
6053.466304 -30.972 32.8481
6054.198726 -31.770 9.3203
6054.931148 -35.198 14.0732
6055.663569 -32.503 22.9008
6056.395991 -32.705 10.2596
6057.128413 -34.137 31.6859
6057.860835 -28.889 13.5511
6058.593257 -29.671 17.9468
6059.325678 -28.466 26.1547
6060.058100 -31.312 12.9857
6060.790522 -29.539 11.0710
6061.522944 -29.312 13.4594
6062.255366 -33.883 -0.1549
6062.987788 -29.844 17.9751
6063.720209 -29.828 6.6796
6064.452631 -29.332 12.6819
6065.185053 -29.537 5.7188
6065.917475 -30.163 -0.9162
6066.649897 -28.234 9.8398
6067.382318 -31.090 9.9453
6068.114740 -29.786 -4.1957
6068.847162 -30.595 4.6217
6069.579584 -29.364 -0.8569
6070.312006 -29.949 -5.7403
6071.044428 -28.564 0.6669
6071.776849 -31.673 -1.3613
6072.509271 -30.666 8.2462
6073.241693 -33.638 -3.7913
6073.974115 -30.656 -2.6099
6074.706537 -31.312 -0.2294
6075.438958 -29.659 -5.1368
6076.171380 -31.957 -6.1814
6076.903802 -32.171 -13.4644
6077.636224 -32.571 -17.1104
6078.368646 -30.353 -19.5062
6079.101067 -32.915 -1.9498
6079.833489 -35.516 0.5653
6080.565911 -32.081 -21.1078
6081.298333 -32.259 1.2990
6082.030755 -32.661 -6.5585
6082.763177 -32.227 7.4998
6083.495598 -34.705 -2.5626
6084.228020 -33.618 -16.6743
6084.960442 -34.421 6.2946
6085.692864 -34.192 9.2615
6086.425286 -35.193 1.0258
6087.157707 -34.839 2.2927
6087.890129 -35.364 16.9893
6088.622551 -36.983 16.5315
6089.354973 -34.852 16.9181
6090.087395 -34.569 12.7943
6090.819817 -33.326 23.1548
6091.552238 -33.125 25.6041
6092.284660 -33.026 25.8634
6093.017082 -32.917 9.9575
6093.749504 -31.745 18.6158
6094.481926 -30.628 18.9712
6095.214347 -31.386 12.2390
6095.946769 -32.510 11.1744
6096.679191 -30.115 15.9991
6097.411613 -30.438 20.7333
6098.144035 -29.855 11.5658
6098.876456 -30.191 1.7611
6099.608878 -29.844 9.4092
6100.341300 -28.626 9.3532
6101.073722 -30.414 -0.9858
6101.806144 -29.253 -5.3242
6102.538566 -29.288 3.4995
6103.270987 -29.313 5.9792
6104.003409 -30.462 0.9315
6104.735831 -30.585 -13.6163
6105.468253 -29.823 -6.5057
6106.200675 -29.842 -8.8662
6106.933096 -30.006 -13.5243
6107.665518 -30.795 -5.7190
6108.397940 -31.252 -8.8412
6109.130362 -31.461 -3.3727
6109.862784 -32.797 -13.4827
6110.595206 -33.539 -28.9989
6111.327627 -32.284 -7.7085
6112.060049 -32.444 -19.1564
6112.792471 -33.968 -12.0848
6113.524893 -33.999 -19.4976
6114.257315 -33.507 -0.2990
6114.989736 -32.638 0.9861
6115.722158 -34.151 1.7494
6116.454580 -34.473 -7.8459
6117.187002 -34.051 -1.5112
6117.919424 -31.946 4.0481
6118.651846 -32.409 7.6722
6119.384267 -35.168 -1.9978
6120.116689 -32.053 6.4605
6120.849111 -30.514 6.8054
6121.581533 -31.914 11.0330
6122.313955 -33.282 4.8407
6123.046376 -31.805 5.6725
6123.778798 -30.853 7.4028
6124.511220 -32.696 7.9841
6125.243642 -32.138 4.2697
6125.976064 -30.907 2.9852
6126.708485 -29.740 4.9870
6127.440907 -31.113 6.6715
6128.173329 -33.934 -1.5743
6128.905751 -31.033 1.6713
6129.638173 -30.548 0.3064
6130.370595 -30.734 4.5128
6131.103016 -32.879 -4.3071
6131.835438 -31.132 -3.6059
6132.567860 -30.103 -6.3428
6133.300282 -32.142 2.0605
6134.032704 -34.150 -8.2749
6134.765125 -31.512 -2.1351
6135.497547 -31.193 -6.7047
6136.229969 -31.593 -1.5660
6136.962391 -33.347 -6.7802
6137.694813 -32.488 -7.2080
6138.427235 -30.796 -3.9647
6139.159656 -31.331 -0.7535
6139.892078 -33.186 1.6106
6140.624500 -30.953 -7.5810
6141.356922 -30.821 -10.0365
6142.089344 -31.432 -10.9190
6142.821765 -32.567 -0.9252
6143.554187 -30.833 -10.4680
6144.286609 -29.900 -13.1526
6145.019031 -30.922 -7.3987
6145.751453 -33.116 -16.9630
6146.483874 -31.221 -16.7239
6147.216296 -29.969 -20.8534
6147.948718 -31.304 -14.8852
6148.681140 -33.755 -17.4462
6149.413562 -31.589 -22.6270
6150.145984 -30.818 -20.7376
6150.878405 -32.211 -14.6210
6151.610827 -35.221 -21.4177
6152.343249 -33.231 -22.2073
6153.075671 -32.841 -27.9470
6153.808093 -34.244 -25.4800
6154.540514 -37.886 -11.9016
6155.272936 -35.101 -24.1672
6156.005358 -33.939 -33.4028
6156.737780 -35.103 -8.3301
6157.470202 -39.483 8.5479
6158.202624 -37.776 -11.0060
6158.935045 -36.144 -16.8733
6159.667467 -36.515 -2.2352
6160.399889 -37.046 19.1144
6161.132311 -35.862 2.7593
6161.864733 -34.218 1.0086
6162.597154 -34.722 13.9865
6163.329576 -34.468 33.1837
6164.061998 -33.398 9.6780
6164.794420 -33.165 0.6571
6165.526842 -32.598 10.1699
6166.259264 -33.813 26.0009
6166.991685 -31.539 -1.0682
6167.724107 -31.615 -9.4557
6168.456529 -31.223 3.7945
6169.188951 -31.850 11.0724
6169.921373 -31.503 0.1097
6170.653794 -30.699 -9.4692
6171.386216 -31.089 -1.2964
6172.118638 -32.823 -3.0883
6172.851060 -31.399 -9.1460
6173.583482 -31.385 -25.5518
6174.315903 -31.782 -13.5507
6175.048325 -33.307 -3.4452
6175.780747 -33.256 -21.9310
6176.513169 -34.142 -30.4158
6177.245591 -33.936 -11.5422
6177.978013 -34.966 3.6951
6178.710434 -35.513 -16.2041
6179.442856 -39.149 -31.5894
6180.175278 -35.586 -2.4890
6180.907700 -37.083 19.0844
6181.640122 -37.831 1.8098
6182.372543 -37.689 3.2302
6183.104965 -35.248 8.7625
6183.837387 -34.297 23.9666
6184.569809 -34.989 24.6804
6185.302231 -34.891 10.6302
6186.034653 -34.351 17.1422
6186.767074 -31.464 29.7490
6187.499496 -33.147 19.0821
6188.231918 -33.586 12.9639
6188.964340 -32.293 14.2377
6189.696762 -30.336 18.8184
6190.429183 -32.125 13.7050
6191.161605 -31.750 4.6641
6191.894027 -31.023 11.6165
6192.626449 -29.819 13.8141
6193.358871 -31.118 2.7156
6194.091293 -32.076 -6.5778
6194.823714 -30.603 -0.6165
6195.556136 -30.578 9.2714
6196.288558 -31.106 -4.2290
6197.020980 -32.061 -15.5109
6197.753402 -30.708 -7.0332
6198.485823 -30.704 -1.5632
6199.218245 -31.455 -8.3370
6199.950667 -32.789 -11.6508
6200.683089 -31.150 -7.7608
6201.415511 -30.767 -7.2304
6202.147932 -31.124 -8.5853
6202.880354 -33.645 -10.5646
6203.612776 -31.409 -8.1201
6204.345198 -30.172 -6.7808
6205.077620 -31.310 -4.7181
6205.810042 -32.761 -4.2070
6206.542463 -31.107 -10.7272
6207.274885 -30.605 -4.5808
6208.007307 -31.827 -11.4011
6208.739729 -32.419 -10.6614
6209.472151 -31.226 -13.6949
6210.204572 -30.053 -9.9025
6210.936994 -31.520 -17.2540
6211.669416 -33.031 -17.0125
6212.401838 -31.596 -17.6428
6213.134260 -30.333 -15.0396
6213.866682 -33.109 -19.6076
6214.599103 -32.940 -26.8602
6215.331525 -32.224 -24.0468
6216.063947 -32.388 -21.4503
6216.796369 -32.873 -30.4248
6217.528791 -34.371 -33.9238
6218.261212 -33.724 -34.7560
6218.993634 -33.832 -18.6757
6219.726056 -35.031 -25.6373
6220.458478 -36.532 -24.0772
6221.190900 -35.154 -22.4047
6221.923321 -33.942 -23.9756
6222.655743 -35.606 -16.8059
6223.388165 -37.315 -9.3349
6224.120587 -36.795 -11.4702
6224.853009 -34.984 -9.6722
6225.585431 -36.730 2.7454
6226.317852 -36.984 12.8596
6227.050274 -35.219 -2.8628
6227.782696 -32.641 2.5903
6228.515118 -34.356 2.5157
6229.247540 -33.042 2.6413
6229.979961 -32.920 -6.1546
6230.712383 -31.817 -0.9636
6231.444805 -31.239 -7.0374
6232.177227 -33.713 -12.5930
6232.909649 -31.294 -4.8490
6233.642071 -31.105 -19.6925
6234.374492 -31.996 -16.0177
6235.106914 -33.337 -15.2064
6235.839336 -32.670 -19.6233
6236.571758 -31.383 -27.7446
6237.304180 -32.405 -29.2084
6238.036601 -33.813 -31.3290
6238.769023 -32.753 -27.9265
6239.501445 -32.420 -37.7701
6240.233867 -35.889 -43.8739
6240.966289 -35.588 -40.1383
6241.698711 -35.224 -45.2404
6242.431132 -35.541 -40.0832
6243.163554 -38.923 -38.7609
6243.895976 -44.412 -37.6074
6244.628398 -40.863 -27.2026
6245.360820 -40.072 -26.8435
6246.093241 -45.113 -10.9761
6246.825663 -41.049 14.0181
6247.558085 -42.558 17.3832
6248.290507 -40.540 28.4781
6249.022929 -37.959 26.3745
6249.755350 -34.734 44.1404
6250.487772 -35.835 20.8003
6251.220194 -35.983 19.2194
6251.952616 -34.238 20.1943
6252.685038 -32.859 22.3206
6253.417460 -32.789 16.6918
6254.149881 -32.172 12.3392
6254.882303 -33.089 15.3451
6255.614725 -31.922 9.5450
6256.347147 -31.124 3.5189
6257.079569 -32.398 1.5219
6257.811990 -31.799 2.1331
6258.544412 -30.996 0.7874
6259.276834 -31.402 -4.4397
6260.009256 -31.268 -12.4690
6260.741678 -31.738 -6.3522
6261.474100 -31.170 -8.9198
6262.206521 -32.568 -24.2997
6262.938943 -32.628 -18.9786
6263.671365 -33.165 -18.5914
6264.403787 -33.738 -14.8867
6265.136209 -34.305 -18.6628
6265.868630 -33.915 -21.4900
6266.601052 -35.567 -16.4750
6267.333474 -35.406 -6.7197
6268.065896 -35.588 -18.2510
6268.798318 -36.211 -7.2135
6269.530739 -36.597 -9.9366
6270.263161 -34.854 -1.9615
6270.995583 -35.864 -5.6544
6271.728005 -36.364 -1.6146
6272.460427 -34.800 -2.4310
6273.192849 -33.299 1.8677
6273.925270 -33.644 -4.7983
6274.657692 -33.159 -10.0144
6275.390114 -32.937 -9.4388
6276.122536 -33.472 -8.7553
6276.854958 -33.709 -17.9830
6277.587379 -32.577 -12.0613
6278.319801 -33.986 -19.2111
6279.052223 -33.831 -9.9471
6279.784645 -32.543 -31.3577
6280.517067 -34.566 -27.7883
6281.249489 -34.481 -26.9007
6281.981910 -35.056 -31.0553
6282.714332 -35.151 -33.5454
6283.446754 -37.156 -37.5626
6284.179176 -36.931 -29.5579
6284.911598 -38.044 -47.4720
6285.644019 -38.031 -53.2396
6286.376441 -41.301 -42.8612
6287.108863 -44.290 -16.8846
6287.841285 -40.541 -24.4679
6288.573707 -43.331 3.6045
6289.306129 -44.905 12.0439
6290.038550 -41.697 39.7227
6290.770972 -37.957 39.6405
6291.503394 -39.944 23.5638
6292.235816 -37.250 35.2310
6292.968238 -36.104 41.8680
6293.700659 -34.162 32.5136
6294.433081 -33.728 40.3379
6295.165503 -32.960 31.6785
6295.897925 -32.726 30.3787
6296.630347 -31.724 19.0933
6297.362768 -32.925 10.0555
6298.095190 -32.356 13.2845
6298.827612 -31.573 8.6600
6299.560034 -31.024 -3.2050
6300.292456 -30.848 2.4225
6301.024878 -32.145 -3.8939
6301.757299 -30.368 -6.7837
6302.489721 -31.080 -8.1726
6303.222143 -31.766 -25.6230
6303.954565 -32.176 -23.7424
6304.686987 -32.223 -24.3187
6305.419408 -31.666 -32.4965
6306.151830 -32.748 -43.9120
6306.884252 -34.228 -50.1824
6307.616674 -33.963 -51.9823
6308.349096 -34.464 -56.0341
6309.081518 -37.496 -78.4293
6309.813939 -38.017 -59.8334
6310.546361 -41.495 -69.0777
6311.278783 -40.067 -63.3004
6312.011205 -46.402 -35.7568
6312.743627 -46.684 -59.2111
6313.476048 -44.069 13.6289
6314.208470 -44.277 26.9337
6314.940892 -41.808 68.6588
6315.673314 -40.571 53.9312
6316.405736 -38.159 51.3464
6317.138157 -38.327 32.9162
6317.870579 -36.270 32.7877
6318.603001 -35.483 30.9313
6319.335423 -34.433 26.1428
6320.067845 -33.317 10.1166
6320.800267 -33.294 10.9132
6321.532688 -33.422 14.7398
6322.265110 -32.294 8.9554
6322.997532 -32.094 4.8624
6323.729954 -32.301 2.2990
6324.462376 -32.591 -8.8998
6325.194797 -31.681 -16.1162
6325.927219 -31.308 -15.3119
6326.659641 -34.213 -24.3119
6327.392063 -31.827 -24.4869
6328.124485 -33.631 -6.4640
6328.856907 -36.174 -16.3179
6329.589328 -35.029 -40.9678
6330.321750 -36.616 -28.4908
6331.054172 -39.111 -21.2715
6331.786594 -38.245 -35.3938
6332.519016 -44.197 7.5399
6333.251437 -45.457 20.5164
6333.983859 -39.680 9.3947
6334.716281 -45.143 27.9290
6335.448703 -41.612 35.1259
6336.181125 -41.707 60.9798
6336.913547 -38.934 26.0974
6337.645968 -36.581 49.4310
6338.378390 -35.541 62.3767
6339.110812 -36.072 46.2951
6339.843234 -34.124 50.4323
6340.575656 -33.209 40.3021
6341.308077 -32.105 30.7685
6342.040499 -31.795 26.2350
6342.772921 -32.381 19.8036
6343.505343 -33.767 30.3451
6344.237765 -32.090 19.1928
6344.970186 -31.306 22.2195
6345.702608 -31.572 10.8398
6346.435030 -31.433 2.4508
6347.167452 -31.129 3.5936
6347.899874 -33.256 -3.6171
6348.632296 -31.867 -10.1427
6349.364717 -34.096 -5.0546
6350.097139 -35.649 -6.5386
6350.829561 -34.563 -18.8727
6351.561983 -38.070 -36.2845
6352.294405 -40.280 -36.2988
6353.026826 -44.210 -40.1333
6353.759248 -44.379 -50.7831
6354.491670 -45.278 -33.7480
6355.224092 -61.633 -101.9255
6355.956514 -43.303 70.2959
6356.688936 -48.418 64.8217
6357.421357 -40.041 56.8580
6358.153779 -41.236 87.7571
6358.886201 -39.494 61.1157
6359.618623 -35.742 75.4490
6360.351045 -35.358 54.1817
6361.083466 -36.026 52.0436
6361.815888 -33.945 44.3314
6362.548310 -33.014 49.3334
6363.280732 -31.063 26.7174
6364.013154 -31.064 33.5964
6364.745575 -30.683 23.2968
6365.477997 -30.227 20.0216
6366.210419 -30.730 14.4612
6366.942841 -30.573 8.7385
6367.675263 -30.891 0.3187
6368.407685 -30.147 6.4517
6369.140106 -31.932 -2.0808
6369.872528 -32.520 -4.1635
6370.604950 -31.786 -20.1017
6371.337372 -33.838 -15.3409
6372.069794 -33.156 -20.9097
6372.802215 -32.746 -23.8248
6373.534637 -36.636 -19.3166
6374.267059 -33.962 -28.1393
6374.999481 -35.562 -33.8832
6375.731903 -35.220 -34.6691
6376.464325 -36.408 -41.7804
6377.196746 -38.384 -8.1771
6377.929168 -43.201 -18.4780
6378.661590 -42.676 13.3698
6379.394012 -40.802 13.6183
6380.126434 -39.101 22.8700
6380.858855 -39.773 10.0782
6381.591277 -36.973 55.0334
6382.323699 -45.014 45.3543
6383.056121 -34.490 46.5057
6383.788543 -35.754 48.8838
6384.520965 -34.293 51.5073
6385.253386 -31.893 43.0788
6385.985808 -32.297 44.1668
6386.718230 -32.523 35.6785
6387.450652 -31.201 30.8899
6388.183074 -32.399 15.8843
6388.915495 -30.627 20.8450
6389.647917 -30.374 17.9358
6390.380339 -30.005 21.7939
6391.112761 -29.503 13.5323
6391.845183 -29.648 10.4980
6392.577604 -29.587 4.0155
6393.310026 -30.325 8.0603
6394.042448 -30.184 1.2408
6394.774870 -30.028 -5.1958
6395.507292 -31.011 -11.2579
6396.239714 -30.854 -10.0450
6396.972135 -29.396 -7.0690
6397.704557 -31.282 -14.3461
6398.436979 -32.196 -13.5491
6399.169401 -32.842 -13.6694
6399.901823 -33.131 -16.3112
6400.634244 -32.415 -10.6758
6401.366666 -34.931 -13.9501
6402.099088 -35.932 1.3376
6402.831510 -34.641 -12.5911
6403.563932 -35.986 -4.0920
6404.296354 -35.684 -13.2125
6405.028775 -36.141 2.7708
6405.761197 -37.863 -3.6587
6406.493619 -33.170 12.2189
6407.226041 -37.321 14.3807
6407.958463 -35.775 23.6167
6408.690884 -35.377 8.2018
6409.423306 -33.590 11.1110
6410.155728 -33.108 17.0344
6410.888150 -34.162 14.2468
6411.620572 -33.444 17.4135
6412.352993 -32.492 7.5298
6413.085415 -32.950 14.4580
6413.817837 -32.822 14.2258
6414.550259 -33.312 10.0109
6415.282681 -31.500 2.3148
6416.015103 -32.908 1.6621
6416.747524 -32.010 -0.0215
6417.479946 -33.958 -9.1150
6418.212368 -32.893 -2.0181
6418.944790 -33.092 -3.3541
6419.677212 -32.041 0.0676
6420.409633 -33.635 -3.2458
6421.142055 -32.425 -17.4547
6421.874477 -34.772 -18.2451
6422.606899 -33.785 -18.9933
6423.339321 -36.306 -26.1913
6424.071743 -33.285 -28.1494
6424.804164 -35.628 -24.4765
6425.536586 -34.775 -19.7828
6426.269008 -37.146 -42.6361
6427.001430 -35.297 -22.0553
6427.733852 -38.357 -32.5519
6428.466273 -37.994 -26.5014
6429.198695 -41.952 14.2239
6429.931117 -38.486 -13.1136
6430.663539 -40.594 3.8272
6431.395961 -37.829 6.5980
6432.128383 -39.523 0.2731
6432.860804 -37.895 13.3037
6433.593226 -38.921 19.3146
6434.325648 -35.606 26.0265
6435.058070 -38.069 34.5949
6435.790492 -35.868 22.5232
6436.522913 -36.998 26.2053
6437.255335 -32.111 15.6067
6437.987757 -34.363 17.6149
6438.720179 -34.929 5.5745
6439.452601 -35.478 6.5789
6440.185022 -32.872 11.2546
6440.917444 -34.922 5.9999
6441.649866 -33.633 -6.1932
6442.382288 -35.254 1.8777
6443.114710 -33.687 -6.8441
6443.847132 -36.010 -9.4500
6444.579553 -34.418 -8.3829
6445.311975 -36.294 -16.0737
6446.044397 -36.057 -11.1758
6446.776819 -37.889 -13.9937
6447.509241 -36.872 -23.6901
6448.241662 -38.593 -8.3558
6448.974084 -37.006 -12.6472
6449.706506 -39.953 -18.3269
6450.438928 -38.853 -24.2397
6451.171350 -43.362 5.8250
6451.903772 -40.622 9.3397
6452.636193 -41.667 41.1661
6453.368615 -38.843 20.0359
6454.101037 -37.821 36.9732
6454.833459 -37.168 33.2121
6455.565881 -36.527 44.7088
6456.298302 -36.116 30.5417
6457.030724 -34.526 44.4610
6457.763146 -33.402 32.6724
6458.495568 -33.184 37.7094
6459.227990 -32.891 25.7634
6459.960411 -32.229 31.7943
6460.692833 -31.765 24.6670
6461.425255 -30.940 24.3388
6462.157677 -32.471 10.6614
6462.890099 -31.619 17.9365
6463.622521 -31.359 5.6893
6464.354942 -31.587 12.1133
6465.087364 -31.645 -2.3936
6465.819786 -31.199 -0.5524
6466.552208 -31.249 -7.8691
6467.284630 -31.672 -2.6449
6468.017051 -33.297 -12.1616
6468.749473 -33.584 -10.5254
6469.481895 -33.523 -14.9182
6470.214317 -34.020 -9.4899
6470.946739 -35.116 -29.3788
6471.679161 -35.710 -14.1390
6472.411582 -34.890 -21.8588
6473.144004 -39.307 -12.4652
6473.876426 -38.952 -23.1184
6474.608848 -39.094 -1.1088
6475.341270 -39.284 -7.7516
6476.073691 -35.534 21.3481
6476.806113 -39.829 24.5869
6477.538535 -36.254 18.2307
6478.270957 -35.633 13.2681
6479.003379 -36.116 34.8657
6479.735801 -35.885 21.2170
6480.468222 -34.432 30.9059
6481.200644 -33.245 24.6630
6481.933066 -31.574 30.1616
6482.665488 -33.107 25.7051
6483.397910 -31.918 23.1273
6484.130331 -31.981 7.5256
6484.862753 -31.628 14.2214
6485.595175 -32.052 11.4269
6486.327597 -31.063 10.8629
6487.060019 -30.943 -1.9282
6487.792440 -30.479 4.6754
6488.524862 -31.712 -5.5800
6489.257284 -30.918 -4.0258
6489.989706 -31.688 -9.6235
6490.722128 -31.773 -9.8212
6491.454550 -33.215 -12.6359
6492.186971 -32.476 -15.1002
6492.919393 -31.848 -20.8625
6493.651815 -33.122 -15.9614
6494.384237 -33.988 -19.0813
6495.116659 -34.440 -15.2173
6495.849080 -33.982 -28.1017
6496.581502 -35.718 -25.2589
6497.313924 -35.272 -20.7657
6498.046346 -35.645 -5.5132
6498.778768 -35.468 -20.2308
6499.511190 -35.365 -6.3768
6500.243611 -36.802 -18.2574
6500.976033 -35.513 -2.7429
6501.708455 -36.971 -15.0555
6502.440877 -35.708 0.7977
6503.173299 -36.256 1.1517
6503.905720 -33.702 6.2504
6504.638142 -35.083 -0.8552
6505.370564 -33.434 2.5281
6506.102986 -34.746 -1.2863
6506.835408 -33.668 0.2792
6507.567829 -33.101 -6.0143
6508.300251 -33.449 -9.4617
6509.032673 -33.922 -1.5336
6509.765095 -32.422 -5.0026
6510.497517 -34.034 -17.4373
6511.229939 -31.985 -12.8579
6511.962360 -35.453 -12.6422
6512.694782 -33.253 -17.2651
6513.427204 -35.450 -18.5558
6514.159626 -34.295 -21.5103
6514.892048 -34.434 -20.6250
6515.624469 -34.561 -20.7003
6516.356891 -36.258 -32.4012
6517.089313 -33.910 -22.6709
6517.821735 -37.592 -25.6179
6518.554157 -34.585 -28.4015
6519.286579 -36.498 -42.5471
6520.019000 -35.055 -26.5579
6520.751422 -39.135 -26.7170
6521.483844 -36.055 -24.1993
6522.216266 -37.901 -24.8471
6522.948688 -36.543 -20.1718
6523.681109 -37.283 -16.8629
6524.413531 -38.989 -10.9405
6525.145953 -40.039 -15.9011
6525.878375 -37.804 -20.1273
6526.610797 -39.143 -2.7798
6527.343219 -38.494 -10.9038
6528.075640 -37.339 -7.5635
6528.808062 -37.387 5.5597
6529.540484 -39.918 4.7972
6530.272906 -36.588 -11.0226
6531.005328 -41.334 -8.3164
6531.737749 -36.178 -12.2186
6532.470171 -38.974 -1.7583
6533.202593 -35.921 -12.6333
6533.935015 -38.642 -17.7184
6534.667437 -36.519 -10.8893
6535.399858 -39.308 -7.5712
6536.132280 -37.986 -8.5790
6536.864702 -38.618 -10.5718
6537.597124 -38.091 -14.6720
6538.329546 -39.153 5.0204
6539.061968 -36.428 4.2815
6539.794389 -38.209 -2.5223
6540.526811 -38.311 1.0209
6541.259233 -38.655 9.2682
6541.991655 -37.699 5.2085
6542.724077 -41.077 12.3478
6543.456498 -37.670 5.2368
6544.188920 -38.287 4.8177
6544.921342 -36.291 2.8560
6545.653764 -40.001 16.0804
6546.386186 -35.871 13.7665
6547.118608 -37.049 16.1623
6547.851029 -39.931 12.2600
6548.583451 -39.079 15.0869
6549.315873 -36.701 9.4719
6550.048295 -35.528 20.0553
6550.780717 -35.588 1.7924
6551.513138 -38.139 3.3561
6552.245560 -37.166 0.2368
6552.977982 -37.558 14.5797
6553.710404 -37.382 -5.2438
6554.442826 -38.218 6.4937
6555.175247 -36.177 6.6777
6555.907669 -37.336 12.9136
6556.640091 -34.762 -3.3999
6557.372513 -37.490 12.6716
6558.104935 -35.961 2.5048
6558.837357 -37.674 10.9758
6559.569778 -38.252 11.1357
6560.302200 -36.503 21.4801
6561.034622 -35.713 7.4432
6561.767044 -35.557 8.9390
6562.499466 -35.474 5.5801
6563.231887 -36.985 11.5638
6563.964309 -34.865 4.0282
6564.696731 -33.454 12.9316
6565.429153 -35.100 3.2189
6566.161575 -37.164 25.2301
6566.893997 -35.839 5.8143
6567.626418 -35.762 2.1412
6568.358840 -34.250 -0.4843
6569.091262 -35.182 12.3994
6569.823684 -34.219 2.4386
6570.556106 -34.302 8.8215
6571.288527 -34.420 10.7971
6572.020949 -34.586 18.7639
6572.753371 -33.538 6.2417
6573.485793 -33.631 6.1011
6574.218215 -33.834 -0.6902
6574.950637 -33.925 3.7905
6575.683058 -33.938 -4.9390
6576.415480 -32.679 0.5972
6577.147902 -34.375 0.9797
6577.880324 -33.393 7.1639
6578.612746 -33.321 -4.9044
6579.345167 -32.942 -5.0302
6580.077589 -33.875 -7.9387
6580.810011 -34.651 -0.4102
6581.542433 -34.073 -14.0763
6582.274855 -33.517 -2.9082
6583.007276 -33.312 -10.9858
6583.739698 -34.687 -4.3005
6584.472120 -34.530 -11.9824
6585.204542 -34.035 -13.8961
6585.936964 -34.725 -19.6410
6586.669386 -35.867 -12.4646
6587.401807 -34.984 -20.9542
6588.134229 -34.654 -9.4776
6588.866651 -35.577 -26.5145
6589.599073 -36.874 -11.4395
6590.331495 -35.622 -19.0955
6591.063916 -36.143 -21.4563
6591.796338 -36.388 -30.4615
6592.528760 -36.769 1.7734
6593.261182 -37.433 -22.1409
6593.993604 -35.635 -11.9146
6594.726026 -36.038 -12.9279
6595.458447 -34.222 -0.2679
6596.190869 -34.663 -16.2546
6596.923291 -35.496 -17.1545
6597.655713 -36.382 -9.2552
6598.388135 -36.339 -5.5848
6599.120556 -37.782 -9.2161
6599.852978 -36.165 -14.8829
6600.585400 -38.072 -20.8582
6601.317822 -39.889 -1.5146
6602.050244 -37.794 -24.4200
6602.782665 -37.834 -20.5660
6603.515087 -40.100 -17.4855
6604.247509 -37.392 -2.2443
6604.979931 -39.639 -21.6829
6605.712353 -37.136 -13.7837
6606.444775 -37.589 -10.3009
6607.177196 -36.349 -5.9518
6607.909618 -37.311 -25.7289
6608.642040 -36.759 -13.5032
6609.374462 -38.385 -15.5927
6610.106884 -36.373 4.3943
6610.839305 -38.495 -2.7920
6611.571727 -36.132 -14.7205
6612.304149 -38.972 -3.0984
6613.036571 -35.944 -7.5146
6613.768993 -37.519 -11.6443
6614.501415 -35.663 -9.3965
6615.233836 -38.215 -10.0833
6615.966258 -37.199 -6.9147
6616.698680 -38.019 -11.9511
6617.431102 -38.846 -17.5020
6618.163524 -37.671 -31.1006
6618.895945 -37.234 -18.6664
6619.628367 -37.994 -19.3073
6620.360789 -38.302 -29.6010
6621.093211 -40.244 -18.7230
6621.825633 -40.961 -7.3226
6622.558055 -41.133 -26.9183
6623.290476 -40.705 -18.1093
6624.022898 -44.123 -8.3540
6624.755320 -39.460 0.1732
6625.487742 -42.600 20.2827
6626.220164 -44.845 3.7797
6626.952585 -47.531 50.4953
6627.685007 -41.471 39.1546
6628.417429 -44.332 41.9953
6629.149851 -40.854 21.6841
6629.882273 -44.591 50.8353
6630.614694 -38.054 28.6340
6631.347116 -38.732 38.9796
6632.079538 -36.579 31.2204
6632.811960 -36.977 22.4525
6633.544382 -35.363 22.2725
6634.276804 -35.091 25.6287
6635.009225 -36.070 16.3071
6635.741647 -35.532 20.9465
6636.474069 -34.150 6.5427
6637.206491 -34.883 8.6244
6637.938913 -34.235 3.4674
6638.671334 -34.637 2.3632
6639.403756 -33.744 -4.6730
6640.136178 -35.408 -8.8326
6640.868600 -34.561 -17.2861
6641.601022 -34.420 -11.9108
6642.333444 -34.026 -21.1208
6643.065865 -36.679 -18.2948
6643.798287 -36.151 -26.8164
6644.530709 -36.765 -13.2693
6645.263131 -37.996 -16.5269
6645.995553 -40.740 -22.1079
6646.727974 -39.956 -29.0209
6647.460396 -41.698 4.2648
6648.192818 -40.542 -9.3403
6648.925240 -43.679 -15.9186
6649.657662 -44.703 -18.1326
6650.390083 -42.452 33.3229
6651.122505 -41.216 8.7905
6651.854927 -43.678 25.2616
6652.587349 -41.188 35.1696
6653.319771 -39.121 26.9302
6654.052193 -39.558 27.5673
6654.784614 -40.479 37.2417
6655.517036 -39.594 14.9099
6656.249458 -38.155 23.0187
6656.981880 -37.528 19.7644
6657.714302 -38.498 27.3523
6658.446723 -39.503 2.6892
6659.179145 -37.059 7.6277
6659.911567 -36.803 5.2065
6660.643989 -38.196 -8.6504
6661.376411 -40.595 -9.1766
6662.108833 -38.306 -12.9962
6662.841254 -38.139 -12.4370
6663.573676 -41.464 -2.3046
6664.306098 -41.941 -43.1672
6665.038520 -41.806 -35.3265
6665.770942 -43.534 -31.7170
6666.503363 -49.239 -33.1271
6667.235785 -56.817 -36.9573
6667.968207 -49.477 30.2898
6668.700629 -62.245 73.8800
6669.433051 -49.975 88.0928
6670.165473 -42.234 153.0047
6670.897894 -42.017 107.1504
6671.630316 -39.570 95.0159
6672.362738 -38.237 98.9943
6673.095160 -37.874 84.2650
6673.827582 -36.165 86.4430
6674.560003 -34.918 83.0300
6675.292425 -33.954 71.4933
6676.024847 -35.152 70.0208
6676.757269 -33.586 65.9931
6677.489691 -32.822 66.1750
6678.222112 -32.848 58.4284
6678.954534 -32.812 52.4456
6679.686956 -31.666 46.0420
6680.419378 -31.525 42.9322
6681.151800 -31.886 36.3190
6681.884222 -32.994 36.0818
6682.616643 -31.225 33.2965
6683.349065 -32.463 27.1468
6684.081487 -32.225 20.1566
6684.813909 -32.392 19.5552
6685.546331 -31.211 8.7413
6686.278752 -33.908 4.6676
6687.011174 -33.574 6.6895
6687.743596 -35.395 7.2628
6688.476018 -35.036 14.0227
6689.208440 -37.364 -1.3281
6689.940862 -38.255 2.3063
6690.673283 -39.266 10.1745
6691.405705 -36.490 0.3876
6692.138127 -36.498 -1.7685
6692.870549 -36.879 4.2276
6693.602971 -39.879 16.4479
6694.335392 -38.503 6.0347
6695.067814 -37.692 7.1760
6695.800236 -39.495 21.3080
6696.532658 -37.769 31.3283
6697.265080 -34.652 12.9335
6697.997501 -33.154 30.8560
6698.729923 -33.049 19.2682
6699.462345 -35.452 33.9514
6700.194767 -34.323 28.5532
6700.927189 -34.219 35.9356
6701.659611 -36.958 18.0013
6702.392032 -37.592 19.2137
6703.124454 -33.417 29.4819
6703.856876 -34.657 19.7655
6704.589298 -34.800 24.2011
6705.321720 -33.983 18.5081
6706.054141 -39.570 11.5753
6706.786563 -34.665 21.8368
6707.518985 -35.742 -1.0913
6708.251407 -36.205 24.6005
6708.983829 -35.989 16.3691
6709.716251 -34.997 19.7538
6710.448672 -37.587 21.5148
6711.181094 -34.763 35.6447
6711.913516 -34.280 28.5284
6712.645938 -35.419 52.8279
6713.378360 -36.470 56.7973
6714.110781 -35.025 53.4066
6714.843203 -33.815 54.3999
6715.575625 -33.577 49.5031
6716.308047 -35.352 50.7862
6717.040469 -32.216 46.7107
6717.772891 -32.447 45.6332
6718.505312 -31.320 34.3101
6719.237734 -31.244 49.4787
6719.970156 -31.774 39.3039
6720.702578 -29.419 22.1871
6721.435000 -29.634 31.1009
6722.167421 -29.996 22.6537
6722.899843 -30.965 26.2893
6723.632265 -30.238 18.1416
6724.364687 -30.387 19.6652
6725.097109 -29.323 13.0331
6725.829530 -29.441 6.6034
6726.561952 -31.328 4.4691
6727.294374 -31.261 11.7874
6728.026796 -30.768 -1.9983
6728.759218 -31.860 -1.8734
6729.491640 -31.946 -14.1255
6730.224061 -32.098 -11.8925
6730.956483 -31.773 -14.9249
6731.688905 -33.873 -5.4327
6732.421327 -35.031 -26.9813
6733.153749 -36.542 -27.6443
6733.886170 -38.743 -12.8940
6734.618592 -36.933 2.9916
6735.351014 -38.314 15.0184
6736.083436 -35.785 5.2605
6736.815858 -38.501 0.4484
6737.548280 -37.596 32.7104
6738.280701 -39.505 26.6719
6739.013123 -36.103 29.2191
6739.745545 -36.240 20.7583
6740.477967 -33.112 19.8611
6741.210389 -33.011 25.0911
6741.942810 -35.480 34.6524
6742.675232 -32.547 30.2865
6743.407654 -32.003 19.0720
6744.140076 -33.203 25.6417
6744.872498 -33.787 14.9250
6745.604919 -32.379 13.2588
6746.337341 -31.224 11.2222
6747.069763 -28.599 0.7712
6747.802185 -29.166 -0.8363
6748.534607 -31.548 2.4377
6749.267029 -28.933 -4.4508
6749.999450 -32.155 -5.4650
6750.731872 -31.381 -16.0683
6751.464294 -33.071 -8.9198
6752.196716 -32.037 -16.7625
6752.929138 -34.331 -25.3652
6753.661559 -35.076 -34.7184
6754.393981 -35.233 -18.8180
6755.126403 -35.977 -27.0460
6755.858825 -38.013 -22.1858
6756.591247 -38.629 -46.8659
6757.323669 -40.425 -24.3540
6758.056090 -41.787 -27.7870
6758.788512 -40.701 -38.0071
6759.520934 -41.769 -26.5157
6760.253356 -44.074 11.3582
6760.985778 -38.994 15.5569
6761.718199 -40.981 35.3030
6762.450621 -39.716 24.2891
6763.183043 -38.814 36.4154
6763.915465 -37.000 24.2712
6764.647887 -37.474 36.1590
6765.380309 -35.921 37.1933
6766.112730 -34.360 35.7371
6766.845152 -37.791 39.6289
6767.577574 -33.712 31.6706
6768.309996 -34.280 27.8424
6769.042418 -34.185 24.9178
6769.774839 -33.695 8.2206
6770.507261 -32.829 17.1139
6771.239683 -32.983 14.8328
6771.972105 -31.780 10.9785
6772.704527 -31.701 -0.8683
6773.436948 -33.634 1.0480
6774.169370 -34.259 -3.8617
6774.901792 -34.260 5.7618
6775.634214 -33.801 -13.8605
6776.366636 -36.656 -9.4080
6777.099058 -36.321 -17.8798
6777.831479 -38.951 -20.8008
6778.563901 -35.150 -30.4017
6779.296323 -41.301 -29.3574
6780.028745 -42.244 -2.3267
6780.761167 -36.608 0.9459
6781.493588 -41.821 1.9382
6782.226010 -39.677 -6.9397
6782.958432 -36.518 17.4977
6783.690854 -38.152 27.9379
6784.423276 -36.513 25.0859
6785.155698 -36.070 37.1626
6785.888119 -34.889 28.7560
6786.620541 -35.193 42.4305
6787.352963 -34.595 31.5276
6788.085385 -35.064 46.3098
6788.817807 -34.850 41.2181
6789.550228 -31.976 26.7104
6790.282650 -32.714 24.6279
6791.015072 -33.535 35.0834
6791.747494 -32.598 20.5607
6792.479916 -32.653 30.5625
6793.212337 -32.780 14.7470
6793.944759 -31.465 11.9774
6794.677181 -33.086 12.9924
6795.409603 -31.187 -3.6610
6796.142025 -33.287 5.2340
6796.874447 -33.429 -6.8320
6797.606868 -32.356 -10.8268
6798.339290 -32.470 -15.9912
6799.071712 -34.602 -24.0270
6799.804134 -34.979 -25.1451
6800.536556 -36.589 -24.4742
6801.268977 -37.934 -33.6882
6802.001399 -37.497 -29.1169
6802.733821 -37.543 -1.9321
6803.466243 -38.307 -12.1451
6804.198665 -37.151 -2.1465
6804.931087 -36.964 1.1698
6805.663508 -39.263 -6.3591
6806.395930 -37.121 6.5369
6807.128352 -37.035 -0.6009
6807.860774 -37.453 21.6045
6808.593196 -35.869 10.7606
6809.325617 -35.465 1.5463
6810.058039 -34.204 3.6205
6810.790461 -34.481 4.3340
6811.522883 -34.471 5.1766
6812.255305 -32.643 6.3262
6812.987727 -34.626 -7.9890
6813.720148 -33.809 0.4313
6814.452570 -32.012 -2.0963
6815.184992 -33.619 -5.3701
6815.917414 -32.582 -9.0938
6816.649836 -33.477 -16.9451
6817.382257 -33.464 -15.1705
6818.114679 -34.017 -24.6091
6818.847101 -33.342 -36.4030
6819.579523 -33.047 -30.9899
6820.311945 -33.858 -19.4268
6821.044366 -34.302 -24.1501
6821.776788 -35.876 -24.5907
6822.509210 -37.342 -37.9822
6823.241632 -37.847 -24.4182
6823.974054 -37.098 -25.2172
6824.706476 -40.930 -29.3430
6825.438897 -42.504 -22.3015
6826.171319 -40.790 -14.2408
6826.903741 -38.678 -2.9991
6827.636163 -47.983 10.7459
6828.368585 -41.523 23.4260
6829.101006 -43.583 9.0519
6829.833428 -40.791 30.2804
6830.565850 -39.558 26.4853
6831.298272 -36.456 22.9357
6832.030694 -38.167 30.0039
6832.763116 -35.716 31.1258
6833.495537 -34.766 26.0979
6834.227959 -34.661 15.2784
6834.960381 -34.332 26.6030
6835.692803 -34.557 13.8372
6836.425225 -35.201 10.0583
6837.157646 -33.623 12.6088
6837.890068 -31.952 5.9983
6838.622490 -31.829 1.7487
6839.354912 -31.758 -2.3708
6840.087334 -31.711 -2.2189
6840.819755 -33.426 -8.5383
6841.552177 -34.243 -16.7912
6842.284599 -33.063 -11.4058
6843.017021 -34.684 -25.1112
6843.749443 -36.125 -20.5714
6844.481865 -37.594 -0.4101
6845.214286 -41.838 -21.4442
6845.946708 -40.973 -13.2296
6846.679130 -40.582 -8.4642
6847.411552 -43.351 9.9379
6848.143974 -51.241 6.6763
6848.876395 -46.600 16.2983
6849.608817 -50.438 26.5170
6850.341239 -42.591 20.9459
6851.073661 -43.157 25.7834
6851.806083 -44.417 34.0733
6852.538505 -39.717 35.2240
6853.270926 -40.287 30.8404
6854.003348 -39.364 45.3850
6854.735770 -39.719 32.0029
6855.468192 -37.982 24.7258
6856.200614 -40.321 37.9673
6856.933035 -39.109 45.6638
6857.665457 -38.218 39.3083
6858.397879 -38.387 31.0164
6859.130301 -38.711 16.5062
6859.862723 -36.756 32.9855
6860.595145 -36.615 23.3191
6861.327566 -37.269 11.9026
6862.059988 -39.074 3.7603
6862.792410 -37.336 -3.9451
6863.524832 -39.867 3.1161
6864.257254 -40.487 3.2430
6864.989675 -41.233 0.5243
6865.722097 -42.340 13.1005
6866.454519 -47.654 -11.9834
6867.186941 -44.784 -15.9646
6867.919363 -38.514 -29.8104
6868.651784 -41.065 -16.0229
6869.384206 -46.498 -43.3428
6870.116628 -40.054 -7.3887
6870.849050 -43.728 -13.8433
6871.581472 -41.571 40.2580
6872.313894 -43.062 18.1185
6873.046315 -43.544 45.7433
6873.778737 -45.772 18.6957
6874.511159 -38.728 56.9800
6875.243581 -40.275 56.1847
6875.976003 -37.719 51.8199
6876.708424 -39.403 51.1157
6877.440846 -35.221 45.4652
6878.173268 -37.615 51.3049
6878.905690 -35.300 44.9018
6879.638112 -36.211 28.1642
6880.370534 -35.596 29.0217
6881.102955 -35.864 26.5131
6881.835377 -35.064 22.5557
6882.567799 -34.956 13.8654
6883.300221 -33.856 18.4536
6884.032643 -35.214 10.8099
6884.765064 -35.544 4.8529
6885.497486 -35.377 -4.9614
6886.229908 -35.042 1.2202
6886.962330 -35.345 -3.8348
6887.694752 -37.585 -13.0839
6888.427173 -37.218 -8.7358
6889.159595 -36.864 1.1825
6889.892017 -41.792 -21.7589
6890.624439 -39.648 3.6288
6891.356861 -40.374 4.8123
6892.089283 -41.019 22.3831
6892.821704 -38.970 37.3164
6893.554126 -39.687 19.8113
6894.286548 -43.069 51.6803
6895.018970 -38.305 51.2231
6895.751392 -38.749 51.3902
6896.483813 -36.673 69.0520
6897.216235 -35.866 62.6587
6897.948657 -33.899 57.3298
6898.681079 -33.960 67.8084
6899.413501 -33.710 55.1581
6900.145923 -32.109 49.8017
6900.878344 -30.673 50.2563
6901.610766 -31.164 48.2158
6902.343188 -30.418 44.2991
6903.075610 -30.734 47.2619
6903.808032 -29.552 32.7751
6904.540453 -29.334 32.8625
6905.272875 -29.123 24.1041
6906.005297 -29.738 25.0963
6906.737719 -29.073 17.5310
6907.470141 -28.965 14.8575
6908.202563 -30.128 9.5724
6908.934984 -30.263 6.2039
6909.667406 -30.026 3.3971
6910.399828 -31.075 -0.1785
6911.132250 -30.709 -10.7451
6911.864672 -31.182 -10.7496
6912.597093 -31.361 -15.9628
6913.329515 -33.142 -15.2097
6914.061937 -34.970 -44.7893
6914.794359 -37.292 -52.5890
6915.526781 -36.593 -66.0784
6916.259202 -40.102 -67.2952
6916.991624 -39.266 -72.6530
6917.724046 -43.360 -84.4739
6918.456468 -43.064 -71.8678
6919.188890 -48.392 -104.1956
6919.921312 -53.991 -55.6124
6920.653733 -43.699 127.6390
6921.386155 -46.703 42.3755
6922.118577 -41.159 79.2144
6922.850999 -38.841 46.7200
6923.583421 -37.537 59.8358
6924.315842 -36.080 35.9499
6925.048264 -35.127 47.4371
6925.780686 -31.980 24.5802
6926.513108 -31.616 26.3176
6927.245530 -31.390 15.0654
6927.977952 -30.008 18.0764
6928.710373 -30.331 7.8284
6929.442795 -30.096 5.2094
6930.175217 -30.006 -5.5222
6930.907639 -29.885 -3.6402
6931.640061 -32.241 -15.0399
6932.372482 -33.492 -20.5159
6933.104904 -32.754 -24.7225
6933.837326 -32.376 -32.2308
6934.569748 -30.681 -35.3830
6935.302170 -31.623 -40.5691
6936.034591 -33.453 -61.9335
6936.767013 -31.620 -47.8240
6937.499435 -33.573 -64.9368
6938.231857 -35.048 -75.1801
6938.964279 -34.969 -75.3931
6939.696701 -37.781 -81.3432
6940.429122 -38.676 -96.6019
6941.161544 -40.581 -102.2647
6941.893966 -43.483 -93.5038
6942.626388 -50.776 -95.3724
6943.358810 -57.799 -152.6405
6944.091231 -41.333 127.8364
6944.823653 -41.483 128.4187
6945.556075 -37.437 91.4695
6946.288497 -35.995 87.3230
6947.020919 -34.641 82.0507
6947.753341 -35.170 75.8590
6948.485762 -34.073 63.2234
6949.218184 -33.160 54.0907
6949.950606 -32.159 40.0149
6950.683028 -31.833 28.8962
6951.415450 -30.970 21.6863
6952.147871 -31.772 14.8903
6952.880293 -30.579 16.0940
6953.612715 -30.887 5.6567
6954.345137 -29.836 2.3568
6955.077559 -31.286 -7.5210
6955.809981 -30.610 -5.1445
6956.542402 -31.074 -17.2992
6957.274824 -30.389 -23.9603
6958.007246 -31.466 -27.4536
6958.739668 -32.770 -30.6458
6959.472090 -32.108 -39.8196
6960.204511 -32.461 -43.6475
6960.936933 -34.705 -46.5217
6961.669355 -39.844 -31.6033
6962.401777 -42.994 -66.4828
6963.134199 -41.086 -30.6665
6963.866620 -51.667 -88.4907
6964.599042 -56.943 24.7589
6965.331464 -59.810 142.6514
6966.063886 -53.052 126.4857
6966.796308 -44.583 92.2991
6967.528730 -39.622 85.7241
6968.261151 -40.835 86.1738
6968.993573 -38.930 77.1575
6969.725995 -36.475 70.0857
6970.458417 -35.022 63.9172
6971.190839 -35.084 49.4877
6971.923260 -33.284 48.8507
6972.655682 -34.457 48.6200
6973.388104 -32.941 44.8235
6974.120526 -33.293 38.6250
6974.852948 -33.481 30.9978
6975.585370 -32.975 25.0317
6976.317791 -31.701 22.1404
6977.050213 -33.052 20.2943
6977.782635 -33.141 6.3256
6978.515057 -32.327 9.1152
6979.247479 -32.622 6.8262
6979.979900 -32.769 0.2020
6980.712322 -33.858 -12.9805
6981.444744 -34.461 -12.8268
6982.177166 -35.773 -18.6586
6982.909588 -35.934 -17.3124
6983.642009 -37.256 -29.2549
6984.374431 -36.154 -28.8566
6985.106853 -36.430 -35.7854
6985.839275 -39.119 -47.2799
6986.571697 -38.426 -57.8483
6987.304119 -41.129 -60.1113
6988.036540 -43.856 -29.8352
6988.768962 -46.905 -53.4299
6989.501384 -46.881 -14.7478
6990.233806 -51.871 10.8124
6990.966228 -45.399 25.8853
6991.698649 -41.980 60.9160
6992.431071 -40.673 31.2732
6993.163493 -38.207 39.6528
6993.895915 -37.619 38.0873
6994.628337 -36.584 32.7028
6995.360759 -36.163 33.6914
6996.093180 -35.920 36.0951
6996.825602 -34.672 23.8881
6997.558024 -35.502 23.0919
6998.290446 -34.067 24.5299
6999.022868 -33.264 19.5808
6999.755289 -33.301 17.8121
7000.487711 -33.664 6.7819
7001.220133 -34.469 1.2316
7001.952555 -33.594 2.8090
7002.684977 -33.338 -0.3657
7003.417399 -34.657 -3.3463
7004.149820 -35.213 -16.2859
7004.882242 -34.888 -13.2861
7005.614664 -34.391 -12.0847
7006.347086 -36.079 -18.1783
7007.079508 -38.042 -18.2545
7007.811929 -34.779 -14.8168
7008.544351 -35.421 -21.9182
7009.276773 -35.645 -19.8259
7010.009195 -37.113 -16.9540
7010.741617 -39.029 -5.3784
7011.474038 -38.040 -1.7925
7012.206460 -38.460 5.6953
7012.938882 -40.606 20.1522
7013.671304 -38.899 29.5723
7014.403726 -37.730 15.1133
7015.136148 -37.817 36.8875
7015.868569 -36.856 34.2858
7016.600991 -36.245 32.3652
7017.333413 -34.893 32.9868
7018.065835 -34.456 30.3779
7018.798257 -33.958 34.1617
7019.530678 -34.050 37.5316
7020.263100 -32.979 33.3718
7020.995522 -33.090 30.0381
7021.727944 -32.375 31.1969
7022.460366 -32.770 33.3195
7023.192788 -32.139 20.8668
7023.925209 -31.898 16.6979
7024.657631 -31.984 20.3621
7025.390053 -30.725 5.4631
7026.122475 -30.297 1.5088
7026.854897 -31.223 -5.0610
7027.587318 -31.788 -3.5189
7028.319740 -32.553 -0.9106
7029.052162 -32.729 -8.7240
7029.784584 -31.636 -16.9877
7030.517006 -33.292 -3.4701
7031.249427 -35.391 -18.9052
7031.981849 -36.206 -28.8424
7032.714271 -38.335 -32.3481
7033.446693 -41.989 -41.8308
7034.179115 -41.784 -25.1561
7034.911537 -42.719 -18.8567
7035.643958 -45.971 -29.1023
7036.376380 -47.535 19.3854
7037.108802 -43.840 3.8245
7037.841224 -41.099 15.5970
7038.573646 -40.380 15.6174
7039.306067 -42.799 31.3877
7040.038489 -39.661 24.9183
7040.770911 -38.326 10.4797
7041.503333 -37.370 20.9788
7042.235755 -35.356 18.8480
7042.968177 -36.275 19.6429
7043.700598 -35.074 21.2236
7044.433020 -34.561 14.3007
7045.165442 -34.368 22.1251
7045.897864 -33.638 10.0696
7046.630286 -33.575 1.4634
7047.362707 -33.822 6.9485
7048.095129 -34.563 3.9705
7048.827551 -32.848 -5.9010
7049.559973 -33.189 -8.4298
7050.292395 -33.169 -10.9786
7051.024817 -34.512 -17.6029
7051.757238 -33.812 -11.6559
7052.489660 -34.662 -32.9016
7053.222082 -36.472 -29.9274
7053.954504 -35.263 -30.6129
7054.686926 -36.939 -42.3405
7055.419347 -37.735 -42.9589
7056.151769 -37.586 -50.3729
7056.884191 -39.196 -41.5024
7057.616613 -41.809 -34.0800
7058.349035 -45.595 -54.9893
7059.081456 -44.263 -44.7578
7059.813878 -42.999 -6.5690
7060.546300 -48.540 16.8354
7061.278722 -46.275 40.1643
7062.011144 -41.416 29.1727
7062.743566 -41.711 28.7822
7063.475987 -40.304 22.2520
7064.208409 -39.798 22.6578
7064.940831 -38.136 25.1403
7065.673253 -37.996 10.9131
7066.405675 -36.477 4.3116
7067.138096 -35.874 14.9432
7067.870518 -37.074 9.7410
7068.602940 -34.069 0.6057
7069.335362 -33.413 -3.5408
7070.067784 -34.319 -5.3234
7070.800206 -33.709 -11.3622
7071.532627 -33.302 -9.2623
7072.265049 -34.200 -23.3431
7072.997471 -37.807 -14.0073
7073.729893 -35.616 -29.8793
7074.462315 -35.894 -14.4194
7075.194736 -36.352 -29.4640
7075.927158 -36.127 -34.6473
7076.659580 -39.419 -34.4601
7077.392002 -36.448 -41.9708
7078.124424 -41.490 4.2444
7078.856845 -40.191 31.2877
7079.589267 -44.459 11.4008
7080.321689 -39.498 38.0258
7081.054111 -38.151 34.7213
7081.786533 -39.600 39.8309
7082.518955 -37.149 42.9637
7083.251376 -34.801 39.4617
7083.983798 -35.781 33.2410
7084.716220 -34.202 39.4167
7085.448642 -33.787 32.1613
7086.181064 -32.809 34.0044
7086.913485 -32.920 29.3865
7087.645907 -33.010 24.0472
7088.378329 -33.028 22.1300
7089.110751 -32.555 15.4968
7089.843173 -33.535 17.9738
7090.575595 -32.195 7.8408
7091.308016 -31.710 2.0096
7092.040438 -33.440 -4.2839
7092.772860 -31.775 -5.6891
7093.505282 -33.280 -4.9882
7094.237704 -34.355 -11.9226
7094.970125 -34.023 -19.8893
7095.702547 -36.296 -30.1415
7096.434969 -34.781 -38.3562
7097.167391 -37.011 -42.2605
7097.899813 -36.902 -26.8729
7098.632235 -38.763 -39.2487
7099.364656 -41.667 -46.6158
7100.097078 -41.921 -27.3047
7100.829500 -41.961 -43.7241
7101.561922 -48.669 -178.1927
7102.294344 -52.796 8.8777
7103.026765 -50.326 75.3960
7103.759187 -47.221 105.0576
7104.491609 -47.304 71.4071
7105.224031 -49.769 72.2599
7105.956453 -45.340 81.0469
7106.688874 -39.209 32.3168
7107.421296 -39.808 57.6199
7108.153718 -36.320 45.0234
7108.886140 -35.466 31.6946
7109.618562 -34.841 31.0507
7110.350984 -34.047 13.8510
7111.083405 -35.079 18.5935
7111.815827 -35.104 11.0566
7112.548249 -33.757 8.4047
7113.280671 -32.869 0.9435
7114.013093 -32.771 -6.4919
7114.745514 -32.024 -12.8126
7115.477936 -32.558 -21.4287
7116.210358 -31.993 -22.8743
7116.942780 -34.224 -31.9316
7117.675202 -33.206 -39.9857
7118.407624 -32.513 -40.9979
7119.140045 -35.863 -59.5269
7119.872467 -35.427 -69.6199
7120.604889 -36.350 -74.0685
7121.337311 -37.514 -72.4391
7122.069733 -35.906 -81.2683
7122.802154 -38.151 -87.2850
7123.534576 -41.520 -118.1104
7124.266998 -40.342 -109.9685
7124.999420 -44.579 -92.9357
7125.731842 -44.647 -85.0846
7126.464263 -49.791 -60.0631
7127.196685 -51.414 -0.8542
7127.929107 -45.426 61.4093
7128.661529 -46.349 41.8079
7129.393951 -43.685 40.7386
7130.126373 -40.574 41.1803
7130.858794 -38.354 44.0687
7131.591216 -39.602 45.8169
7132.323638 -37.473 38.3683
7133.056060 -35.872 32.5012
7133.788482 -35.298 28.0209
7134.520903 -34.891 27.7126
7135.253325 -34.000 21.6942
7135.985747 -33.234 18.3933
7136.718169 -31.987 14.5231
7137.450591 -32.214 -1.9109
7138.183013 -32.829 4.8888
7138.915434 -32.146 -8.7266
7139.647856 -32.783 -11.0131
7140.380278 -32.793 -10.4163
7141.112700 -34.734 -21.6697
7141.845122 -32.926 -18.1997
7142.577543 -34.457 -20.0559
7143.309965 -33.369 -40.1353
7144.042387 -36.121 -37.8489
7144.774809 -38.290 -34.5590
7145.507231 -36.699 -61.8396
7146.239653 -38.779 -56.0305
7146.972074 -38.175 -63.2378
7147.704496 -38.490 -63.5165
7148.436918 -40.692 -54.0844
7149.169340 -41.909 -56.1134
7149.901762 -47.915 -68.3754
7150.634183 -60.038 -28.1881
7151.366605 -47.455 -86.1091
7152.099027 -53.502 -31.0201
7152.831449 -49.141 3.6940
7153.563871 -44.916 47.7443
7154.296292 -46.133 55.8842
7155.028714 -66.166 152.7061
7155.761136 -43.614 43.7882
7156.493558 -40.893 17.5571
7157.225980 -41.173 59.1116
7157.958402 -37.869 28.1558
7158.690823 -41.247 30.1185
7159.423245 -38.241 33.5762
7160.155667 -37.322 20.6210
7160.888089 -38.107 17.4856
7161.620511 -38.321 2.8279
7162.352932 -37.921 6.8124
7163.085354 -37.954 5.7701
7163.817776 -37.172 10.9875
7164.550198 -39.639 8.0800
7165.282620 -40.622 -16.5822
7166.015042 -40.704 15.7551
7166.747463 -40.857 -29.5775
7167.479885 -46.193 -15.0707
7168.212307 -41.840 -2.4654
7168.944729 -46.821 10.3099
7169.677151 -43.941 13.6030
7170.409572 -44.454 43.3036
7171.141994 -45.393 35.8652
7171.874416 -45.130 21.1511
7172.606838 -53.158 56.5230
7173.339260 -46.867 31.0068
7174.071681 -48.985 66.5423
7174.804103 -41.554 37.8549
7175.536525 -41.908 78.3818
7176.268947 -39.260 69.1647
7177.001369 -41.127 57.2566
7177.733791 -38.005 50.8951
7178.466212 -37.549 63.8431
7179.198634 -36.447 47.6718
7179.931056 -35.750 36.8406
7180.663478 -34.072 42.2734
7181.395900 -34.772 36.6382
7182.128321 -34.496 25.7248
7182.860743 -34.755 31.9077
7183.593165 -34.187 10.4185
7184.325587 -35.064 14.6998
7185.058009 -33.957 16.9503
7185.790431 -33.211 7.8152
7186.522852 -33.671 -2.7783
7187.255274 -36.103 -1.2827
7187.987696 -34.243 8.6967
7188.720118 -35.930 -13.0119
7189.452540 -35.318 -12.6276
7190.184961 -36.051 -1.0989
7190.917383 -35.688 -0.8397
7191.649805 -36.929 -11.5842
7192.382227 -39.435 -4.1527
7193.114649 -40.446 -9.6995
7193.847071 -38.894 6.3470
7194.579492 -40.900 0.9062
7195.311914 -40.296 3.2653
7196.044336 -41.284 14.2110
7196.776758 -41.244 11.9216
7197.509180 -40.473 26.5554
7198.241601 -37.391 25.0942
7198.974023 -36.675 27.0778
7199.706445 -36.847 22.2901
7200.438867 -35.609 22.7143
7201.171289 -35.419 19.3350
7201.903710 -35.560 26.3637
7202.636132 -34.086 18.0024
7203.368554 -33.932 1.9984
7204.100976 -33.645 9.3272
7204.833398 -35.135 8.4738
7205.565820 -33.632 2.3124
7206.298241 -33.942 -4.8542
7207.030663 -33.955 -6.8912
7207.763085 -34.875 -8.2379
7208.495507 -34.850 -11.9575
7209.227929 -34.597 -26.3766
7209.960350 -34.459 -26.5358
7210.692772 -35.113 -25.4205
7211.425194 -35.693 -27.9987
7212.157616 -38.769 -35.4213
7212.890038 -37.819 -34.3203
7213.622460 -38.802 -40.3814
7214.354881 -41.653 -35.1143
7215.087303 -42.144 -42.3565
7215.819725 -46.776 -23.4639
7216.552147 -51.365 18.3975
7217.284569 -47.789 21.4593
7218.016990 -46.156 33.6066
7218.749412 -43.539 42.9316
7219.481834 -40.027 59.3093
7220.214256 -38.881 37.5221
7220.946678 -38.066 48.5547
7221.679100 -38.521 40.6256
7222.411521 -34.878 40.9558
7223.143943 -33.610 35.1622
7223.876365 -35.973 28.9943
7224.608787 -33.147 25.0709
7225.341209 -32.071 25.3061
7226.073630 -32.895 16.4240
7226.806052 -32.680 8.9847
7227.538474 -32.428 7.9015
7228.270896 -32.462 3.6859
7229.003318 -32.494 5.2772
7229.735739 -32.825 -9.3080
7230.468161 -33.113 -9.2935
7231.200583 -32.864 -10.0338
7231.933005 -32.819 -26.4419
7232.665427 -34.153 -25.8585
7233.397849 -34.255 -33.4291
7234.130270 -34.778 -26.4917
7234.862692 -33.444 -32.1545
7235.595114 -35.857 -41.1423
7236.327536 -35.628 -41.4449
7237.059958 -36.750 -41.7457
7237.792379 -39.287 -41.7982
7238.524801 -38.158 -53.6276
7239.257223 -39.769 -30.7382
7239.989645 -40.765 -27.4468
7240.722067 -40.533 -4.9334
7241.454489 -42.801 -20.3494
7242.186910 -39.503 14.4702
7242.919332 -39.292 18.7158
7243.651754 -39.240 21.9528
7244.384176 -39.771 13.8959
7245.116598 -37.746 25.5259
7245.849019 -36.877 14.9418
7246.581441 -35.161 14.2654
7247.313863 -35.776 1.6499
7248.046285 -34.622 6.0453
7248.778707 -32.677 3.5386
7249.511128 -33.390 -8.6660
7250.243550 -35.006 -6.2519
7250.975972 -33.720 -11.4125
7251.708394 -33.409 -22.7560
7252.440816 -33.474 -22.4805
7253.173238 -33.658 -30.6255
7253.905659 -34.233 -32.9111
7254.638081 -34.575 -35.2664
7255.370503 -34.055 -40.3539
7256.102925 -36.474 -52.9573
7256.835347 -36.939 -55.5886
7257.567768 -36.792 -73.0876
7258.300190 -38.656 -56.1227
7259.032612 -40.156 -67.9934
7259.765034 -39.081 -68.6515
7260.497456 -45.199 -66.8826
7261.229878 -46.206 -40.6522
7261.962299 -47.782 -77.8048
7262.694721 -61.757 150.9597
7263.427143 -52.832 -111.3483
7264.159565 -50.029 30.6857
7264.891987 -51.925 80.1923
7265.624408 -48.471 32.3292
7266.356830 -45.317 45.7609
7267.089252 -43.113 33.8773
7267.821674 -40.489 20.1801
7268.554096 -41.975 37.9569
7269.286518 -39.529 9.9401
7270.018939 -36.950 17.1498
7270.751361 -38.953 12.0672
7271.483783 -37.581 2.0677
7272.216205 -37.274 -8.9907
7272.948627 -37.146 -3.8232
7273.681048 -35.658 -12.0371
7274.413470 -35.375 -5.8395
7275.145892 -36.767 -13.8063
7275.878314 -35.051 -31.8414
7276.610736 -35.742 -21.3010
7277.343157 -36.506 -23.2803
7278.075579 -35.991 -22.8458
7278.808001 -36.329 -45.6504
7279.540423 -39.337 -39.6904
7280.272845 -39.814 -22.6956
7281.005267 -41.026 -36.4446
7281.737688 -37.605 -56.6185
7282.470110 -43.984 -66.0223
7283.202532 -40.231 -71.0347
7283.934954 -41.325 -48.0353
7284.667376 -41.089 -49.2724
7285.399797 -44.191 -72.5892
7286.132219 -40.974 -50.4449
7286.864641 -49.834 -4.4693
7287.597063 -44.260 -49.4697
7288.329485 -50.469 13.2268
7289.061907 -39.993 5.4304
7289.794328 -40.856 -6.5006
7290.526750 -39.583 -4.3707
7291.259172 -40.682 9.8810
7291.991594 -40.083 5.9268
7292.724016 -39.783 9.9710
7293.456437 -38.346 -7.2017
7294.188859 -40.047 7.4098
7294.921281 -40.168 -10.3925
7295.653703 -38.975 -17.3777
7296.386125 -42.329 -20.2480
7297.118546 -40.388 -3.8057
7297.850968 -39.938 -24.1695
7298.583390 -40.622 -11.9467
7299.315812 -42.022 -27.2690
7300.048234 -45.942 -33.5162
7300.780656 -49.879 -77.5538
7301.513077 -51.021 -14.4130
7302.245499 -48.440 -105.3530
7302.977921 -57.896 -121.0895
7303.710343 -47.968 108.5732
7304.442765 -45.904 122.9902
7305.175186 -62.210 149.1453
7305.907608 -46.497 93.7117
7306.640030 -44.905 93.6436
7307.372452 -40.578 63.8054
7308.104874 -40.670 47.4806
7308.837296 -42.070 79.2444
7309.569717 -40.835 63.2981
7310.302139 -38.185 70.0735
7311.034561 -38.693 58.7629
7311.766983 -35.124 70.8113
7312.499405 -35.698 45.8197
7313.231826 -33.876 33.4597
7313.964248 -35.166 42.7894
7314.696670 -33.848 31.4690
7315.429092 -33.865 19.7991
7316.161514 -34.470 27.6799
7316.893936 -33.368 18.9985
7317.626357 -32.498 20.4506
7318.358779 -33.541 14.1018
7319.091201 -32.720 4.3831
7319.823623 -32.683 1.5812
7320.556045 -32.687 -0.4176
7321.288466 -32.365 -7.4969
7322.020888 -32.525 -8.4191
7322.753310 -32.958 -22.8359
7323.485732 -32.707 -13.8059
7324.218154 -33.079 -25.3890
7324.950575 -34.146 -26.6925
7325.682997 -34.666 -31.7878
7326.415419 -35.345 -38.2330
7327.147841 -35.108 -42.7031
7327.880263 -35.876 -39.7195
7328.612685 -38.554 -45.5354
7329.345106 -38.397 -37.7975
7330.077528 -39.277 -55.4703
7330.809950 -41.817 -47.7256
7331.542372 -44.564 -84.2623
7332.274794 -42.322 -65.4531
7333.007215 -44.176 -60.7357
7333.739637 -45.949 -50.8177
7334.472059 -49.846 -144.9789
7335.204481 -53.389 -38.7079
7335.936903 -53.754 -37.9349
7336.669325 -43.666 -7.3994
7337.401746 -49.423 5.6553
7338.134168 -47.424 25.8601
7338.866590 -48.852 13.3773
7339.599012 -45.439 2.2583
7340.331434 -50.738 51.7566
7341.063855 -45.029 34.4188
7341.796277 -44.974 35.6238
7342.528699 -41.496 22.9009
7343.261121 -42.480 36.7406
7343.993543 -41.860 7.7477
7344.725964 -42.417 22.6232
7345.458386 -38.426 11.7440
7346.190808 -41.133 21.4381
7346.923230 -41.941 22.5435
7347.655652 -39.789 23.9142
7348.388074 -41.242 8.5884
7349.120495 -39.994 26.7037
7349.852917 -41.460 10.5747
7350.585339 -40.435 20.9232
7351.317761 -40.830 14.8413
7352.050183 -43.041 18.6266
7352.782604 -39.674 22.4263
7353.515026 -40.651 36.8060
7354.247448 -39.734 24.3290
7354.979870 -42.687 20.6462
7355.712292 -39.556 29.8704
7356.444714 -39.160 26.1101
7357.177135 -38.587 25.5388
7357.909557 -39.801 50.7723
7358.641979 -37.789 28.3480
7359.374401 -39.133 31.8801
7360.106823 -38.246 26.2551
7360.839244 -36.373 28.1449
7361.571666 -35.312 39.3099
7362.304088 -35.886 30.3241
7363.036510 -37.171 28.2035
7363.768932 -36.235 31.2124
7364.501354 -35.255 21.7056
7365.233775 -35.359 28.4459
7365.966197 -34.499 20.2716
7366.698619 -34.016 16.4565
7367.431041 -34.092 20.8387
7368.163463 -35.904 15.0178
7368.895884 -33.492 6.7938
7369.628306 -34.367 19.1912
7370.360728 -34.361 0.6650
7371.093150 -35.050 -0.0763
7371.825572 -35.000 0.7264
7372.557993 -34.549 1.9624
7373.290415 -34.951 -1.0255
7374.022837 -36.875 -3.3800
7374.755259 -36.584 -16.8168
7375.487681 -35.801 -2.2742
7376.220103 -36.744 -6.9049
7376.952524 -35.704 -3.7394
7377.684946 -37.725 -12.4209
7378.417368 -35.534 -7.5560
7379.149790 -37.476 -8.0793
7379.882212 -37.963 -16.6133
7380.614633 -36.881 -17.1256
7381.347055 -37.968 7.9468
7382.079477 -37.967 -7.7670
7382.811899 -38.619 -7.1667
7383.544321 -37.875 -8.8413
7384.276743 -36.177 0.1012
7385.009164 -37.605 0.5258
7385.741586 -37.162 -8.9224
7386.474008 -37.474 -0.6042
7387.206430 -36.656 1.7703
7387.938852 -38.888 -5.3337
7388.671273 -36.026 -8.8391
7389.403695 -37.650 -13.5240
7390.136117 -34.977 -14.4363
7390.868539 -37.675 -12.5629
7391.600961 -38.324 -19.6283
7392.333382 -37.898 -17.9219
7393.065804 -36.728 -28.5011
7393.798226 -37.127 -19.8529
7394.530648 -37.425 -23.9240
7395.263070 -39.663 -27.6931
7395.995492 -36.460 -20.3995
7396.727913 -38.896 -10.7073
7397.460335 -39.217 -20.5386
7398.192757 -41.200 -35.1238
7398.925179 -41.406 -25.3075
7399.657601 -42.505 -14.5211
7400.390022 -39.774 -26.7584
7401.122444 -46.010 -31.8456
7401.854866 -42.001 -6.6045
7402.587288 -42.195 -4.2136
7403.319710 -43.890 2.1201
7404.052132 -43.109 -18.7166
7404.784553 -39.862 15.4478
7405.516975 -39.781 14.4404
7406.249397 -40.901 15.0137
7406.981819 -40.681 32.9996
7407.714241 -38.628 6.7522
7408.446662 -36.376 8.4752
7409.179084 -37.601 17.1107
7409.911506 -37.551 12.0393
7410.643928 -36.463 8.1603
7411.376350 -36.331 0.1897
7412.108772 -35.651 6.6234
7412.841193 -35.917 -6.0909
7413.573615 -35.525 -13.2021
7414.306037 -35.936 -20.7427
7415.038459 -35.426 -11.7397
7415.770881 -38.217 -20.5004
7416.503302 -34.716 -29.8279
7417.235724 -35.912 -17.1815
7417.968146 -39.289 -35.5714
7418.700568 -36.700 -31.4521
7419.432990 -35.578 -62.8035
7420.165411 -40.503 -29.2805
7420.897833 -36.590 -46.8696
7421.630255 -39.937 -63.3885
7422.362677 -43.318 -44.9033
7423.095099 -43.127 -79.0625
7423.827521 -45.595 -93.9587
7424.559942 -45.019 -62.7480
7425.292364 -45.956 -99.6732
7426.024786 -49.621 -69.5677
7426.757208 -65.845 123.5149
7427.489630 -47.888 -179.0247
7428.222051 -46.764 67.6863
7428.954473 -48.543 73.2700
7429.686895 -41.058 38.4785
7430.419317 -44.917 73.0406
7431.151739 -38.770 68.0521
7431.884161 -41.769 56.5330
7432.616582 -38.255 33.5436
7433.349004 -38.108 56.0448
7434.081426 -36.010 25.3567
7434.813848 -32.907 33.2473
7435.546270 -37.110 40.9873
7436.278691 -37.779 27.2537
7437.011113 -40.198 31.2708
7437.743535 -35.097 14.2853
7438.475957 -36.468 -4.0847
7439.208379 -33.906 12.9502
7439.940800 -33.719 2.9158
7440.673222 -34.880 -7.6644
7441.405644 -37.636 -5.2185
7442.138066 -38.771 -31.4531
7442.870488 -41.655 -47.7263
7443.602910 -37.443 -14.4877
7444.335331 -43.802 -10.5209
7445.067753 -41.202 -17.2411
7445.800175 -44.687 -8.2670
7446.532597 -36.903 -7.4421
7447.265019 -42.445 20.0736
7447.997440 -41.678 -16.0055
7448.729862 -55.067 -1.6008
7449.462284 -49.169 63.2505
7450.194706 -38.225 47.5583
7450.927128 -39.121 39.1257
7451.659550 -37.030 23.8104
7452.391971 -39.774 19.1793
7453.124393 -37.389 25.8864
7453.856815 -40.844 45.3931
7454.589237 -38.115 14.4629
7455.321659 -35.204 9.8240
7456.054080 -31.562 21.1895
7456.786502 -36.320 -9.5593
7457.518924 -35.840 6.1406
7458.251346 -31.997 -21.6359
7458.983768 -34.431 -6.8289
7459.716190 -36.987 -28.9387
7460.448611 -35.198 -19.5498
7461.181033 -34.016 -35.2018
7461.913455 -34.535 -36.5374
7462.645877 -36.703 -38.8087
7463.378299 -34.587 -50.0001
7464.110720 -38.214 -40.7479
7464.843142 -35.603 -39.4758
7465.575564 -39.423 -53.2606
7466.307986 -39.027 -52.5081
7467.040408 -40.705 -51.0227
7467.772829 -44.466 -74.0067
7468.505251 -42.220 -93.0741
7469.237673 -47.845 -74.0206
7469.970095 -48.012 -57.7278
7470.702517 -44.123 -84.5841
7471.434939 -50.976 71.5411
7472.167360 -44.497 27.1576
7472.899782 -53.536 176.3206
7473.632204 -42.852 2.4487
7474.364626 -41.983 49.7870
7475.097048 -43.982 -1.3213
7475.829469 -36.937 20.2318
7476.561891 -37.383 39.5880
7477.294313 -35.247 34.4739
7478.026735 -34.684 34.7104
7478.759157 -34.144 25.9370
7479.491579 -33.855 -4.1342
7480.224000 -34.398 11.9679
7480.956422 -35.639 -11.4326
7481.688844 -33.211 -2.8667
7482.421266 -32.804 -8.6455
7483.153688 -35.383 -18.5519
7483.886109 -34.754 -19.2103
7484.618531 -33.162 -28.3108
7485.350953 -34.064 -7.1637
7486.083375 -37.144 -27.1875
7486.815797 -36.437 -50.8610
7487.548218 -35.354 -9.4437
7488.280640 -45.193 -67.3041
7489.013062 -37.881 -84.2640
7489.745484 -50.444 -110.1234
7490.477906 -35.791 -50.2032
7491.210328 -48.769 -68.4204
7491.942749 -45.093 -46.7018
7492.675171 -41.334 -82.2607
7493.407593 -45.973 -108.9023
7494.140015 -49.024 -14.8015
7494.872437 -48.439 82.0806
7495.604858 -37.439 25.4633
7496.337280 -55.005 -63.3752
7497.069702 -41.153 54.4137
7497.802124 -39.426 48.5070
7498.534546 -39.006 11.9462
7499.266968 -52.646 110.8999
7499.999389 -40.054 34.7893
7500.731811 -39.378 20.7382
7501.464233 -38.216 23.4609
7502.196655 -35.276 8.1736
7502.929077 -38.979 -8.0742
7503.661498 -42.510 22.7780
7504.393920 -37.215 -7.7906
7505.126342 -43.476 -20.6691
7505.858764 -42.623 -31.1334
7506.591186 -41.307 -7.4904
7507.323608 -39.008 -5.6729
7508.056029 -39.736 -36.3801
7508.788451 -38.238 -28.7201
7509.520873 -38.431 -40.2899
7510.253295 -49.252 12.9802
7510.985717 -42.131 -19.6489
7511.718138 -37.591 13.6501
7512.450560 -40.905 1.3226
7513.182982 -44.293 -12.1410
7513.915404 -40.044 32.1318
7514.647826 -43.483 38.7832
7515.380247 -42.132 25.0035
7516.112669 -54.223 -157.1315
7516.845091 -39.902 49.3050
7517.577513 -43.056 4.2113
7518.309935 -44.423 63.5600
7519.042357 -40.102 -7.7470
7519.774778 -40.155 49.6178
7520.507200 -37.373 -3.6301
7521.239622 -37.583 28.8104
7521.972044 -38.213 35.6190
7522.704466 -37.785 6.0809
7523.436887 -39.858 -8.7070
7524.169309 -36.656 -25.0586
7524.901731 -33.933 -13.4850
7525.634153 -36.292 -17.6863
7526.366575 -37.250 -17.2468
7527.098997 -40.740 -0.5916
7527.831418 -38.221 -10.2724
7528.563840 -38.265 -26.9568
7529.296262 -39.654 -22.7971
7530.028684 -40.898 -10.2120
7530.761106 -37.474 -13.9099
7531.493527 -42.240 -32.8376
7532.225949 -37.369 -15.8023
7532.958371 -45.665 -53.5145
7533.690793 -41.224 -10.2183
7534.423215 -41.856 -26.7911
7535.155636 -44.190 -41.3914
7535.888058 -41.540 -27.8870
7536.620480 -41.262 16.5934
7537.352902 -44.368 -14.7584
7538.085324 -41.465 7.1823
7538.817746 -41.894 15.9535
7539.550167 -45.765 11.8992
7540.282589 -39.703 12.2547
7541.015011 -41.105 -5.7134
7541.747433 -37.918 7.1147
7542.479855 -35.706 -14.4132
7543.212276 -39.541 -5.7872
7543.944698 -40.065 -18.2729
7544.677120 -38.265 9.0616
7545.409542 -38.512 1.7200
7546.141964 -36.967 -15.5255
7546.874386 -37.003 -39.3627
7547.606807 -35.679 -3.2011
7548.339229 -36.349 -7.4343
7549.071651 -38.838 0.3657
7549.804073 -36.800 -36.5243
7550.536495 -35.931 -9.8685
7551.268916 -38.569 -22.8513
7552.001338 -40.170 -1.3213
7552.733760 -40.861 -10.9744
7553.466182 -44.329 16.0917
7554.198604 -40.365 -16.8360
7554.931026 -42.990 11.4266
7555.663447 -43.290 -47.1886
7556.395869 -44.965 26.8332
7557.128291 -42.055 -19.4282
7557.860713 -45.606 18.9812
7558.593135 -50.146 3.8594
7559.325556 -44.910 5.1746
7560.057978 -42.253 54.3624
7560.790400 -41.037 66.8104
7561.522822 -45.573 19.3254
7562.255244 -40.211 54.4228
7562.987665 -40.760 40.9486
7563.720087 -38.910 57.0818
7564.452509 -40.520 19.9556
7565.184931 -39.568 27.5132
7565.917353 -40.964 8.9215
7566.649775 -36.891 26.7388
7567.382196 -40.128 6.2950
7568.114618 -34.367 8.0381
7568.847040 -36.902 -1.9691
7569.579462 -35.929 18.5873
7570.311884 -36.049 14.9794
7571.044305 -36.117 -12.6430
7571.776727 -35.829 -16.3562
7572.509149 -36.755 -13.9291
7573.241571 -36.966 -21.0597
7573.973993 -36.452 -19.6948
7574.706415 -39.046 -49.6863
7575.438836 -41.282 -28.9783
7576.171258 -38.861 -53.8862
7576.903680 -38.302 -23.8873
7577.636102 -38.550 -39.3411
7578.368524 -42.741 -41.4335
7579.100945 -41.887 -72.2224
7579.833367 -44.970 -44.1683
7580.565789 -44.233 -103.4617
7581.298211 -51.822 3.3124
7582.030633 -60.346 -168.5115
7582.763054 -50.861 84.5441
7583.495476 -69.392 -124.4252
7584.227898 -43.705 79.6734
7584.960320 -45.239 96.7750
7585.692742 -47.793 128.7717
7586.425164 -41.710 73.2656
7587.157585 -39.910 64.2334
7587.890007 -43.805 57.6052
7588.622429 -41.606 62.5838
7589.354851 -42.197 74.8474
7590.087273 -37.763 62.1742
7590.819694 -43.121 50.0531
7591.552116 -38.403 25.6248
7592.284538 -39.308 34.3234
7593.016960 -37.607 41.5662
7593.749382 -39.113 28.5684
7594.481804 -36.875 24.0260
7595.214225 -40.078 12.4021
7595.946647 -38.446 10.9326
7596.679069 -41.438 9.2369
7597.411491 -39.229 1.9827
7598.143913 -40.692 1.4592
7598.876334 -39.583 13.9060
7599.608756 -43.047 -2.5693
7600.341178 -41.686 2.6279
7601.073600 -46.926 9.3771
7601.806022 -43.612 -3.6257
7602.538444 -43.198 36.8558
7603.270865 -46.763 41.1352
7604.003287 -44.769 54.8700
7604.735709 -44.303 45.1095
7605.468131 -40.407 66.7779
7606.200553 -42.870 53.1667
7606.932974 -40.848 75.1779
7607.665396 -38.065 64.2084
7608.397818 -38.102 69.9840
7609.130240 -38.784 62.0353
7609.862662 -37.479 59.7965
7610.595083 -34.964 47.6331
7611.327505 -37.160 54.8146
7612.059927 -34.638 46.9458
7612.792349 -34.742 47.9550
7613.524771 -34.071 37.1900
7614.257193 -34.471 37.0266
7614.989614 -34.162 28.8667
7615.722036 -35.179 30.0195
7616.454458 -33.777 25.8458
7617.186880 -34.112 23.7574
7617.919302 -32.826 8.6929
7618.651723 -35.308 14.7335
7619.384145 -33.420 6.0985
7620.116567 -34.124 11.8381
7620.848989 -35.007 2.5064
7621.581411 -36.668 2.0128
7622.313833 -34.367 -3.5717
7623.046254 -36.964 -15.4971
7623.778676 -37.890 -21.3867
7624.511098 -37.329 -10.1859
7625.243520 -36.213 -17.4404
7625.975942 -38.151 -22.0063
7626.708363 -37.746 -23.5513
7627.440785 -40.213 -8.7559
7628.173207 -39.760 -8.1237
7628.905629 -39.578 -12.0016
7629.638051 -40.036 0.6851
7630.370472 -42.972 5.1702
7631.102894 -40.441 -13.0023
7631.835316 -42.340 6.1217
7632.567738 -39.894 30.1996
7633.300160 -40.321 17.5244
7634.032582 -39.096 -4.2224
7634.765003 -39.517 9.6346
7635.497425 -38.374 5.6032
7636.229847 -37.985 11.1505
7636.962269 -39.237 18.0453
7637.694691 -39.936 20.7524
7638.427112 -38.877 -1.1156
7639.159534 -39.389 27.0291
7639.891956 -38.017 15.4827
7640.624378 -39.388 4.0140
7641.356800 -39.604 0.0463
7642.089222 -36.904 8.9101
7642.821643 -38.260 6.9733
7643.554065 -39.536 17.1022
7644.286487 -39.022 4.8096
7645.018909 -39.165 9.8232
7645.751331 -40.239 -8.2009
7646.483752 -38.544 2.9866
7647.216174 -39.613 -10.6567
7647.948596 -37.347 11.6158
7648.681018 -37.663 0.1207
7649.413440 -38.481 -1.8408
7650.145862 -38.116 -1.4541
7650.878283 -39.169 8.7682
7651.610705 -39.113 5.7250
7652.343127 -38.212 -5.6836
7653.075549 -39.995 -16.8426
7653.807971 -38.306 -1.8297
7654.540392 -39.394 -17.6378
7655.272814 -39.110 -7.0330
7656.005236 -39.528 -21.5128
7656.737658 -41.247 -17.2329
7657.470080 -38.719 -20.1907
7658.202501 -40.181 -21.1131
7658.934923 -41.769 -13.3663
7659.667345 -40.657 -1.3759
7660.399767 -42.446 -4.3721
7661.132189 -40.730 -2.1805
7661.864611 -41.124 -2.9893
7662.597032 -41.089 32.6770
7663.329454 -41.042 -13.1606
7664.061876 -40.036 19.9288
7664.794298 -38.765 10.2078
7665.526720 -39.489 27.8143
7666.259141 -40.891 11.1298
7666.991563 -38.187 16.5713
7667.723985 -37.190 12.9429
7668.456407 -36.162 28.8609
7669.188829 -36.510 15.0680
7669.921251 -36.021 24.6653
7670.653672 -37.011 8.5631
7671.386094 -34.281 11.4028
7672.118516 -35.139 2.4150
7672.850938 -35.281 10.8779
7673.583360 -36.640 -4.5737
7674.315781 -34.332 -2.0809
7675.048203 -35.855 -15.4393
7675.780625 -35.501 -16.7362
7676.513047 -33.289 -21.6606
7677.245469 -34.090 -18.7347
7677.977890 -35.698 -27.8652
7678.710312 -35.772 -29.4684
7679.442734 -34.445 -30.8948
7680.175156 -34.891 -35.6046
7680.907578 -37.871 -38.8947
7681.640000 -38.472 -39.7710
7682.372421 -37.047 -39.6361
7683.104843 -37.909 -36.5006
7683.837265 -37.700 -43.5771
7684.569687 -42.739 -39.9420
7685.302109 -45.044 -60.3453
7686.034530 -43.134 -30.5720
7686.766952 -49.857 -40.6653
7687.499374 -45.474 -17.0602
7688.231796 -43.712 -18.1161
7688.964218 -43.182 -6.8076
7689.696640 -44.711 2.9663
7690.429061 -40.103 -0.3718
7691.161483 -41.210 -2.2766
7691.893905 -38.344 9.9377
7692.626327 -40.709 6.6699
7693.358749 -38.620 16.5730
7694.091170 -37.778 -7.5713
7694.823592 -36.438 -15.1663
7695.556014 -37.334 -10.0012
7696.288436 -37.498 -7.2651
7697.020858 -36.384 -21.5222
7697.753280 -35.812 -17.6891
7698.485701 -36.783 -18.0835
7699.218123 -38.319 -26.9289
7699.950545 -40.013 -34.7791
7700.682967 -36.982 -44.3235
7701.415389 -39.093 -43.4695
7702.147810 -39.768 -50.4286
7702.880232 -39.957 -58.6442
7703.612654 -39.871 -54.2388
7704.345076 -41.145 -74.1589
7705.077498 -42.671 -51.6555
7705.809919 -44.151 -82.3143
7706.542341 -44.611 -80.9816
7707.274763 -48.266 -94.2997
7708.007185 -57.897 160.5086
7708.739607 -55.068 123.6216
7709.472029 -52.889 36.9026
7710.204450 -50.178 30.7403
7710.936872 -46.651 32.7986
7711.669294 -47.711 48.1574
7712.401716 -42.567 49.2859
7713.134138 -42.606 42.9915
7713.866559 -40.564 41.2722
7714.598981 -39.871 32.5718
7715.331403 -38.049 23.7478
7716.063825 -38.186 24.8159
7716.796247 -36.847 14.5938
7717.528669 -36.202 8.0485
7718.261090 -37.018 7.5369
7718.993512 -37.334 5.5704
7719.725934 -35.549 10.0729
7720.458356 -36.933 7.0420
7721.190778 -36.582 -17.0954
7721.923199 -37.639 -24.3989
7722.655621 -36.988 -14.7495
7723.388043 -37.291 -19.6956
7724.120465 -37.670 -28.5862
7724.852887 -36.825 -30.9462
7725.585308 -38.489 -24.6483
7726.317730 -38.699 -47.4670
7727.050152 -38.057 -51.1839
7727.782574 -38.606 -27.8088
7728.514996 -42.978 -26.7787
7729.247418 -39.872 -47.3120
7729.979839 -46.010 -31.5304
7730.712261 -43.956 -42.1476
7731.444683 -40.026 -21.9128
7732.177105 -40.962 -26.1700
7732.909527 -43.892 -24.0078
7733.641948 -42.162 -15.3275
7734.374370 -41.123 0.7161
7735.106792 -42.026 -11.6577
7735.839214 -40.116 2.9036
7736.571636 -38.745 -2.8129
7737.304058 -39.451 -15.7726
7738.036479 -39.956 -6.7265
7738.768901 -40.936 -8.5100
7739.501323 -38.469 3.2102
7740.233745 -38.439 -5.3540
7740.966167 -36.916 -22.7939
7741.698588 -40.563 -22.6319
7742.431010 -42.183 -31.3220
7743.163432 -37.649 -19.9844
7743.895854 -39.770 -30.8784
7744.628276 -40.590 -24.3671
7745.360698 -38.850 -33.0971
7746.093119 -40.141 -26.4326
7746.825541 -38.968 -32.9249
7747.557963 -42.869 -32.4052
7748.290385 -40.846 -12.2642
7749.022807 -40.759 -24.4292
7749.755228 -43.915 -4.4637
7750.487650 -43.106 -14.3553
7751.220072 -47.438 -29.6093
7751.952494 -42.093 -9.3367
7752.684916 -42.977 -22.1867
7753.417337 -44.886 1.0159
7754.149759 -45.434 -2.2601
7754.882181 -41.489 12.3110
7755.614603 -39.433 -11.1793
7756.347025 -42.447 -29.2504
7757.079447 -40.267 -8.5363
7757.811868 -41.508 -27.2500
7758.544290 -44.880 -28.5536
7759.276712 -42.033 -29.0718
7760.009134 -43.583 -45.8746
7760.741556 -40.408 -48.9471
7761.473977 -44.180 -68.0580
7762.206399 -42.930 -73.9548
7762.938821 -42.501 -65.3336
7763.671243 -41.310 -72.5923
7764.403665 -44.624 -76.0341
7765.136087 -43.225 -75.4326
7765.868508 -45.336 -115.8738
7766.600930 -40.995 -79.8522
7767.333352 -42.128 -67.0713
7768.065774 -44.099 -124.5232
7768.798196 -46.076 -98.3468
7769.530617 -49.208 -81.6682
7770.263039 -49.844 -175.6211
7770.995461 -56.238 -82.4940
7771.727883 -52.729 -154.9214
7772.460305 -57.349 -176.0017
7773.192726 -51.135 136.0333
7773.925148 -44.669 113.3364
7774.657570 -50.454 142.5208
7775.389992 -47.205 119.0319
7776.122414 -47.348 126.1615
7776.854836 -45.224 103.0627
7777.587257 -43.023 116.3525
7778.319679 -47.406 95.8818
7779.052101 -45.799 41.5360
7779.784523 -41.888 75.0618
7780.516945 -42.965 64.5537
7781.249366 -42.402 54.0320
7781.981788 -41.292 67.2886
7782.714210 -41.283 37.7008
7783.446632 -42.483 34.1512
7784.179054 -40.958 51.1132
7784.911476 -38.653 45.8088
7785.643897 -39.330 31.8342
7786.376319 -41.590 43.0554
7787.108741 -41.697 18.6959
7787.841163 -41.144 31.0314
7788.573585 -38.628 26.9714
7789.306006 -38.625 27.7261
7790.038428 -40.093 11.3242
7790.770850 -40.869 9.1736
7791.503272 -38.072 20.7749
7792.235694 -41.834 6.2698
7792.968116 -38.267 -1.1808
7793.700537 -38.523 2.0502
7794.432959 -38.534 5.6256
7795.165381 -38.032 10.1039
7795.897803 -40.342 -6.5382
7796.630225 -41.213 1.8468
7797.362646 -38.172 -5.8613
7798.095068 -41.886 -0.5768
7798.827490 -42.016 9.5559
7799.559912 -40.189 -17.5204
7800.292334 -41.281 -8.4796
7801.024755 -46.650 -3.5413
7801.757177 -40.004 -20.2107
7802.489599 -43.213 -33.8878
7803.222021 -44.310 8.6720
7803.954443 -43.825 -22.3540
7804.686865 -46.173 -15.9397
7805.419286 -49.582 -22.4785
7806.151708 -48.516 -12.1320
7806.884130 -53.676 -20.7434
7807.616552 -51.022 -7.0266
7808.348974 -43.851 28.6223
7809.081395 -47.874 27.0939
7809.813817 -50.179 32.7773
7810.546239 -49.368 19.4137
7811.278661 -43.523 62.6943
7812.011083 -52.633 -9.1492
7812.743505 -42.486 33.6300
7813.475926 -49.302 84.4729
7814.208348 -57.341 87.6517
7814.940770 -42.805 25.7379
7815.673192 -43.495 48.2109
7816.405614 -52.230 31.3574
7817.138035 -43.548 26.9463
7817.870457 -42.797 34.9823
7818.602879 -44.444 30.3552
7819.335301 -42.991 37.1469
7820.067723 -44.004 17.9390
7820.800144 -39.555 37.9573
7821.532566 -43.616 36.0367
7822.264988 -42.468 16.6201
7822.997410 -45.222 30.2013
7823.729832 -38.207 15.4993
7824.462254 -39.766 37.4426
7825.194675 -41.495 44.7452
7825.927097 -51.442 36.6320
7826.659519 -40.458 -0.2358
7827.391941 -43.528 19.5352
7828.124363 -40.986 29.2428
7828.856784 -39.298 32.2307
7829.589206 -40.889 26.7087
7830.321628 -39.057 34.5227
7831.054050 -39.974 33.8605
7831.786472 -39.686 42.1646
7832.518894 -38.946 18.4816
7833.251315 -46.717 52.0255
7833.983737 -39.067 45.7822
7834.716159 -41.859 49.6661
7835.448581 -38.168 32.4821
7836.181003 -39.216 36.7496
7836.913424 -40.014 41.0502
7837.645846 -38.807 50.6447
7838.378268 -38.883 20.3607
7839.110690 -38.110 40.1323
7839.843112 -43.606 60.4271
7840.575534 -36.512 31.8916
7841.307955 -37.509 30.2400
7842.040377 -37.230 34.0701
7842.772799 -39.057 35.5817
7843.505221 -36.718 18.2578
7844.237643 -43.025 6.8918
7844.970064 -36.005 29.3173
7845.702486 -36.631 36.2990
7846.434908 -36.818 43.2340
7847.167330 -38.051 21.6821
7847.899752 -36.201 18.3938
7848.632173 -37.539 21.0940
7849.364595 -37.937 17.2041
7850.097017 -35.310 17.5928
7850.829439 -36.363 20.6827
7851.561861 -38.113 21.4939
7852.294283 -39.162 24.2532
7853.026704 -36.349 5.7344
7853.759126 -38.377 8.3131
7854.491548 -39.331 11.1495
7855.223970 -34.777 6.4498
7855.956392 -37.463 9.4788
7856.688813 -36.134 3.5111
7857.421235 -37.039 10.7960
7858.153657 -36.758 14.5205
7858.886079 -39.449 3.3298
7859.618501 -34.326 -7.1364
7860.350923 -36.080 2.8766
7861.083344 -39.219 9.6255
7861.815766 -36.316 -16.6011
7862.548188 -36.881 9.0350
7863.280610 -37.198 -8.4414
7864.013032 -35.742 -12.6224
7864.745453 -34.969 -5.7565
7865.477875 -34.920 -11.6049
7866.210297 -36.029 -9.4033
7866.942719 -36.025 -4.4093
7867.675141 -36.497 -26.9875
7868.407562 -33.980 -24.7065
7869.139984 -35.266 -17.6593
7869.872406 -39.780 -32.9797
7870.604828 -38.704 -36.8036
7871.337250 -35.874 -36.8408
7872.069672 -37.280 -20.2421
7872.802093 -38.902 -26.8534
7873.534515 -39.098 -59.2903
7874.266937 -39.350 -30.4202
7874.999359 -40.470 -46.1271
7875.731781 -38.694 -53.5323
7876.464202 -41.618 -48.7659
7877.196624 -45.229 -52.1384
7877.929046 -44.606 -41.1140
7878.661468 -41.167 -62.2040
7879.393890 -49.332 -63.3629
7880.126312 -50.494 -68.8029
7880.858733 -46.216 -9.9052
7881.591155 -46.894 -66.6677
7882.323577 -60.765 -28.6447
7883.055999 -58.374 17.2039
7883.788421 -48.236 14.2844
7884.520842 -46.596 27.4884
7885.253264 -48.652 -52.1896
7885.985686 -42.692 40.6394
7886.718108 -48.393 62.4290
7887.450530 -43.591 15.6467
7888.182952 -45.004 -7.5956
7888.915373 -41.010 32.2317
7889.647795 -40.587 -6.8953
7890.380217 -42.304 -8.4563
7891.112639 -45.260 18.2697
7891.845061 -42.822 -9.3815
7892.577482 -38.671 -20.3505
7893.309904 -39.998 -31.6870
7894.042326 -41.301 -19.8353
7894.774748 -38.455 -24.5868
7895.507170 -45.936 3.3047
7896.239591 -42.679 -16.4780
7896.972013 -44.505 -49.0353
7897.704435 -47.638 16.1118
7898.436857 -42.190 -25.8090
7899.169279 -48.382 -22.8826
7899.901701 -61.613 -62.6320
7900.634122 -44.890 26.7532
7901.366544 -45.542 27.9408
7902.098966 -51.365 37.4240
7902.831388 -45.573 40.1962
7903.563810 -43.587 23.7251
7904.296231 -40.709 41.3081
7905.028653 -43.449 7.9075
7905.761075 -40.856 55.1248
7906.493497 -43.292 48.8972
7907.225919 -40.213 35.0094
7907.958341 -39.338 25.5076
7908.690762 -42.523 26.0701
7909.423184 -38.880 5.8690
7910.155606 -38.004 18.6436
7910.888028 -37.392 9.8795
7911.620450 -39.431 16.0870
7912.352871 -37.912 -0.7922
7913.085293 -38.439 -7.2347
7913.817715 -37.754 7.2737
7914.550137 -40.050 -16.0110
7915.282559 -38.826 0.4907
7916.014980 -39.510 -34.8605
7916.747402 -37.352 -14.0238
7917.479824 -41.614 -37.6244
7918.212246 -41.580 -52.4980
7918.944668 -42.121 -49.9471
7919.677090 -48.570 -91.4380
7920.409511 -44.884 -97.8317
7921.141933 -47.336 -44.3710
7921.874355 -48.343 -67.0552
7922.606777 -47.891 -156.7720
7923.339199 -54.507 148.5254
7924.071620 -54.625 149.7736
7924.804042 -50.013 -179.7147
7925.536464 -43.298 153.8455
7926.268886 -45.417 111.8602
7927.001308 -40.419 81.7944
7927.733730 -40.199 91.4178
7928.466151 -38.882 98.2827
7929.198573 -37.783 97.1100
7929.930995 -37.207 77.8400
7930.663417 -37.348 53.8274
7931.395839 -37.245 53.9307
7932.128260 -34.937 70.0999
7932.860682 -34.618 48.6346
7933.593104 -35.088 39.0291
7934.325526 -36.235 46.8511
7935.057948 -34.790 41.8623
7935.790370 -35.739 39.1455
7936.522791 -36.072 22.4442
7937.255213 -35.115 33.5582
7937.987635 -34.611 23.5361
7938.720057 -35.791 15.3955
7939.452479 -37.630 10.1321
7940.184900 -36.825 2.8757
7940.917322 -37.218 -5.8159
7941.649744 -36.842 -3.9265
7942.382166 -38.409 -12.1252
7943.114588 -37.464 -11.6300
7943.847009 -41.208 -0.3988
7944.579431 -36.877 -32.2806
7945.311853 -41.663 -11.6188
7946.044275 -40.031 -9.5026
7946.776697 -42.211 -10.5546
7947.509119 -42.131 -24.5927
7948.241540 -43.904 4.5670
7948.973962 -47.288 19.1272
7949.706384 -46.525 31.5209
7950.438806 -42.061 33.1174
7951.171228 -43.188 30.2635
7951.903649 -43.051 41.8948
7952.636071 -40.042 22.5802
7953.368493 -38.207 30.3778
7954.100915 -40.401 36.1464
7954.833337 -39.771 32.6503
7955.565759 -38.080 43.1154
7956.298180 -39.220 13.4358
7957.030602 -37.299 24.9089
7957.763024 -39.109 25.4491
7958.495446 -36.634 19.9666
7959.227868 -37.242 6.4209
7959.960289 -37.417 14.6919
7960.692711 -35.274 11.5088
7961.425133 -36.096 12.1460
7962.157555 -35.324 -5.4834
7962.889977 -38.011 -3.2965
7963.622398 -38.670 -13.1001
7964.354820 -37.519 -16.8815
7965.087242 -37.761 -17.2374
7965.819664 -37.934 -31.3405
7966.552086 -38.196 -35.8296
7967.284508 -41.048 -37.0149
7968.016929 -40.073 -42.8209
7968.749351 -42.091 -40.6813
7969.481773 -43.069 -30.1449
7970.214195 -44.244 -53.0907
7970.946617 -44.158 -64.5518
7971.679038 -49.637 -64.1639
7972.411460 -56.893 -9.0377
7973.143882 -56.768 15.6658
7973.876304 -56.774 -84.2959
7974.608726 -51.823 120.2524
7975.341148 -46.285 33.1265
7976.073569 -42.260 51.7881
7976.805991 -43.389 25.1273
7977.538413 -45.429 72.3746
7978.270835 -41.805 72.4473
7979.003257 -38.044 60.4191
7979.735678 -39.433 51.2156
7980.468100 -37.714 49.6976
7981.200522 -38.147 47.7566
7981.932944 -36.249 39.3961
7982.665366 -37.025 41.8689
7983.397788 -36.526 42.8966
7984.130209 -35.292 31.7568
7984.862631 -34.395 27.0671
7985.595053 -35.394 16.1339
7986.327475 -34.823 27.7130
7987.059897 -34.844 21.6470
7987.792318 -35.451 14.7356
7988.524740 -36.535 10.6570
7989.257162 -36.805 3.4696
7989.989584 -36.204 7.0238
7990.722006 -34.118 1.5968
7991.454427 -36.002 -14.9625
7992.186849 -36.432 -13.4205
7992.919271 -36.014 -13.0109
7993.651693 -35.087 -20.3607
7994.384115 -37.348 -12.7784
7995.116537 -37.607 -19.9783
7995.848958 -37.647 -21.0178
7996.581380 -37.502 -21.0067
7997.313802 -38.743 -27.1665
7998.046224 -37.443 -33.5736
7998.778646 -38.343 -25.3933
7999.511067 -37.345 -41.6342
8000.243489 -37.326 -42.6768
8000.975911 -39.477 -39.1720
8001.708333 -39.491 -26.7328
8002.440755 -37.861 -36.0962
8003.173177 -39.844 -39.5044
8003.905598 -39.497 -43.1584
8004.638020 -42.123 -52.6300
8005.370442 -40.585 -51.3607
8006.102864 -43.292 -56.0907
8006.835286 -44.267 -39.7540
8007.567707 -39.969 -49.7654
8008.300129 -40.130 -49.8668
8009.032551 -44.855 -65.1066
8009.764973 -46.791 -80.8828
8010.497395 -43.749 -69.6504
8011.229816 -44.954 -74.5894
8011.962238 -48.513 -88.1294
8012.694660 -48.208 -102.4868
8013.427082 -51.467 -87.6006
8014.159504 -57.616 -87.6929
8014.891926 -51.082 -92.0205
8015.624347 -57.538 -90.8540
8016.356769 -50.852 -87.9868
8017.089191 -46.999 -154.1406
8017.821613 -52.077 145.6877
8018.554035 -51.348 124.6924
8019.286456 -56.075 97.4966
8020.018878 -47.640 67.4380
8020.751300 -47.463 119.7939
8021.483722 -44.246 90.5830
8022.216144 -46.648 114.0674
8022.948566 -47.448 109.7761
8023.680987 -48.094 113.3354
8024.413409 -42.595 80.0134
8025.145831 -39.638 69.2649
8025.878253 -42.069 62.0779
8026.610675 -43.681 90.0483
8027.343096 -40.898 56.7827
8028.075518 -41.309 57.6541
8028.807940 -40.766 62.8555
8029.540362 -41.689 49.3303
8030.272784 -39.353 51.3811
8031.005206 -43.511 43.2825
8031.737627 -41.355 44.6858
8032.470049 -44.598 56.5798
8033.202471 -38.723 38.1707
8033.934893 -39.536 35.1880
8034.667315 -39.201 50.0017
8035.399736 -38.366 49.2163
8036.132158 -37.739 30.6155
8036.864580 -36.556 34.9753
8037.597002 -40.076 27.6538
8038.329424 -39.220 25.3523
8039.061845 -39.438 20.0813
8039.794267 -40.871 36.1619
8040.526689 -41.281 29.2112
8041.259111 -40.147 34.7087
8041.991533 -40.849 -1.8188
8042.723955 -40.594 20.6802
8043.456376 -40.247 6.0454
8044.188798 -41.222 9.3486
8044.921220 -40.400 6.3953
8045.653642 -44.507 1.7546
8046.386064 -45.897 18.1079
8047.118485 -45.572 35.4258
8047.850907 -40.382 1.9448
8048.583329 -41.563 2.9932
8049.315751 -46.306 7.3623
8050.048173 -43.798 27.9661
8050.780595 -41.528 11.0090
8051.513016 -43.439 45.5605
8052.245438 -44.927 42.0959
8052.977860 -42.713 58.0645
8053.710282 -42.431 35.8914
8054.442704 -39.708 57.4607
8055.175125 -40.263 61.3586
8055.907547 -42.084 53.7715
8056.639969 -38.431 47.3965
8057.372391 -37.232 47.4731
8058.104813 -38.376 42.3669
8058.837234 -38.179 46.0068
8059.569656 -36.143 50.1128
8060.302078 -37.714 26.4595
8061.034500 -36.533 32.8806
8061.766922 -36.101 36.0193
8062.499344 -35.710 25.7642
8063.231765 -36.039 22.5925
8063.964187 -34.922 20.1594
8064.696609 -35.807 11.0459
8065.429031 -34.666 12.0500
8066.161453 -35.709 11.0613
8066.893874 -36.000 -1.3792
8067.626296 -34.624 8.8086
8068.358718 -35.412 3.7517
8069.091140 -38.074 4.0183
8069.823562 -36.372 11.1523
8070.555984 -36.467 10.1802
8071.288405 -35.760 -1.4983
8072.020827 -36.720 -11.6208
8072.753249 -39.735 -11.9319
8073.485671 -39.272 -2.1316
8074.218093 -38.230 -20.7742
8074.950514 -38.669 -10.9492
8075.682936 -40.631 -10.0430
8076.415358 -40.579 -15.5811
8077.147780 -39.291 -23.7639
8077.880202 -40.350 -9.0459
8078.612624 -40.989 5.7224
8079.345045 -39.614 -1.9131
8080.077467 -39.572 -19.6836
8080.809889 -39.809 -17.3911
8081.542311 -38.692 -12.7917
8082.274733 -39.659 -13.6416
8083.007154 -40.465 -6.3113
8083.739576 -39.596 -14.1538
8084.471998 -40.858 -18.6077
8085.204420 -40.362 -4.5398
8085.936842 -43.581 -16.8562
8086.669263 -41.889 -21.2983
8087.401685 -41.236 -7.1077
8088.134107 -41.549 -21.2856
8088.866529 -42.985 -25.2954
8089.598951 -43.578 -7.5708
8090.331373 -44.812 1.6372
8091.063794 -47.117 13.6047
8091.796216 -44.352 22.1389
8092.528638 -47.007 27.1128
8093.261060 -41.093 26.5183
8093.993482 -40.016 50.6907
8094.725903 -40.466 34.9619
8095.458325 -42.376 34.8137
8096.190747 -39.853 47.0754
8096.923169 -40.283 41.1221
8097.655591 -38.522 32.8994
8098.388013 -37.578 30.6880
8099.120434 -39.018 19.8513
8099.852856 -36.699 15.6487
8100.585278 -36.978 9.7454
8101.317700 -35.350 11.5542
8102.050122 -35.117 15.9072
8102.782543 -33.789 7.5791
8103.514965 -33.759 5.6494
8104.247387 -35.408 -0.2327
8104.979809 -35.036 -10.3901
8105.712231 -35.165 -9.2275
8106.444652 -33.531 -12.6575
8107.177074 -35.850 -24.3892
8107.909496 -34.856 -20.1499
8108.641918 -34.316 -29.0305
8109.374340 -35.298 -34.1775
8110.106762 -35.241 -38.2112
8110.839183 -34.473 -42.3799
8111.571605 -37.254 -44.7659
8112.304027 -36.140 -55.4861
8113.036449 -38.366 -67.7078
8113.768871 -38.928 -59.8577
8114.501292 -39.545 -69.4792
8115.233714 -40.102 -76.5784
8115.966136 -42.710 -85.1099
8116.698558 -49.560 -103.8660
8117.430980 -50.334 -40.1646
8118.163402 -47.012 -81.4709
8118.895823 -55.055 -120.2046
8119.628245 -49.556 50.1060
8120.360667 -47.758 10.4910
8121.093089 -49.925 53.9468
8121.825511 -43.379 71.2505
8122.557932 -43.852 52.9089
8123.290354 -41.958 40.3115
8124.022776 -42.742 41.6294
8124.755198 -38.567 34.2485
8125.487620 -38.305 19.2058
8126.220042 -38.075 15.8669
8126.952463 -38.311 21.6575
8127.684885 -38.507 23.5139
8128.417307 -38.280 29.6230
8129.149729 -36.935 12.0007
8129.882151 -37.158 -11.3406
8130.614572 -38.619 -3.6643
8131.346994 -37.396 0.1499
8132.079416 -37.357 -16.2480
8132.811838 -38.526 -18.1965
8133.544260 -38.341 -24.9104
8134.276681 -39.256 -26.6370
8135.009103 -38.186 -25.7146
8135.741525 -40.742 -42.1899
8136.473947 -38.911 -21.9275
8137.206369 -41.291 -33.3105
8137.938791 -41.432 -22.6753
8138.671212 -44.909 -23.7405
8139.403634 -45.116 -7.4648
8140.136056 -46.425 -36.6111
8140.868478 -44.189 -21.5793
8141.600900 -49.734 12.7803
8142.333321 -47.322 37.6177
8143.065743 -45.141 32.8860
8143.798165 -48.424 32.2307
8144.530587 -44.506 53.3962
8145.263009 -44.037 41.6946
8145.995431 -42.087 41.9895
8146.727852 -41.113 38.6790
8147.460274 -41.874 54.4968
8148.192696 -39.268 29.0850
8148.925118 -36.165 37.7761
8149.657540 -38.539 20.9998
8150.389961 -38.543 19.4727
8151.122383 -37.359 20.7744
8151.854805 -37.387 18.9348
8152.587227 -35.449 13.9546
8153.319649 -36.915 14.7981
8154.052070 -35.025 11.3792
8154.784492 -35.118 -8.8713
8155.516914 -36.800 -7.2300
8156.249336 -36.578 -8.6814
8156.981758 -37.957 -13.8513
8157.714180 -36.921 -24.9854
8158.446601 -36.074 -20.7168
8159.179023 -38.707 -23.5564
8159.911445 -35.716 -27.9819
8160.643867 -38.251 -36.0750
8161.376289 -38.364 -54.0796
8162.108710 -37.735 -60.1055
8162.841132 -38.043 -59.4822
8163.573554 -39.484 -51.6438
8164.305976 -39.996 -66.3042
8165.038398 -41.897 -76.0334
8165.770820 -41.951 -74.8638
8166.503241 -44.156 -72.1702
8167.235663 -45.505 -98.3142
8167.968085 -50.638 -82.8960
8168.700507 -49.761 -41.8157
8169.432929 -58.410 156.7510
8170.165350 -54.723 94.6399
8170.897772 -45.547 126.3015
8171.630194 -55.168 84.5466
8172.362616 -47.382 124.5901
8173.095038 -45.501 89.3142
8173.827460 -44.222 68.0393
8174.559881 -41.638 61.3052
8175.292303 -41.144 61.0088
8176.024725 -40.358 45.0259
8176.757147 -39.772 71.6113
8177.489569 -38.025 42.4204
8178.221990 -38.288 39.3501
8178.954412 -37.082 32.6724
8179.686834 -37.882 28.1777
8180.419256 -36.932 24.5154
8181.151678 -35.874 30.0227
8181.884099 -36.743 10.4402
8182.616521 -35.316 16.7344
8183.348943 -36.774 -3.0325
8184.081365 -35.272 3.7715
8184.813787 -36.728 -11.4778
8185.546209 -35.655 -9.2122
8186.278630 -35.905 -14.3711
8187.011052 -37.494 -0.9006
8187.743474 -39.052 -29.2622
8188.475896 -37.001 -14.9819
8189.208318 -36.105 -24.2979
8189.940739 -40.232 -39.1680
8190.673161 -39.172 -21.3855
8191.405583 -41.278 -1.0935
8192.138005 -40.591 -26.8010
8192.870427 -39.026 -30.8823
8193.602849 -39.649 -34.2910
8194.335270 -42.932 1.0459
8195.067692 -43.946 -20.2615
8195.800114 -43.600 -50.8125
8196.532536 -44.628 18.4802
8197.264958 -45.313 -50.3533
8197.997379 -43.726 -19.4016
8198.729801 -39.182 -11.2739
8199.462223 -40.819 -44.1365
8200.194645 -41.388 -37.9250
8200.927067 -37.815 -36.4988
8201.659488 -41.997 -39.4744
8202.391910 -44.701 -71.3220
8203.124332 -41.294 -47.2539
8203.856754 -41.252 -24.1206
8204.589176 -47.098 -46.4368
8205.321598 -41.253 -37.1914
8206.054019 -43.325 31.3279
8206.786441 -43.328 -46.0034
8207.518863 -47.615 -0.0388
8208.251285 -46.648 -80.8550
8208.983707 -55.163 -162.9900
8209.716128 -49.543 51.8325
8210.448550 -44.607 56.9751
8211.180972 -44.584 119.4189
8211.913394 -47.914 127.6035
8212.645816 -48.292 77.9700
8213.378238 -41.848 101.0461
8214.110659 -41.122 83.2827
8214.843081 -43.189 86.9861
8215.575503 -48.279 94.5037
8216.307925 -40.122 47.3608
8217.040347 -37.500 80.3679
8217.772768 -38.687 53.6248
8218.505190 -36.505 69.7463
8219.237612 -38.842 61.7668
8219.970034 -38.774 54.1892
8220.702456 -34.974 36.8020
8221.434878 -36.855 25.7805
8222.167299 -35.036 37.8413
8222.899721 -37.622 22.0559
8223.632143 -34.504 39.0293
8224.364565 -37.439 31.6992
8225.096987 -38.715 20.8240
8225.829408 -36.818 4.6406
8226.561830 -33.873 13.7307
8227.294252 -37.521 12.7112
8228.026674 -35.309 3.4043
8228.759096 -38.597 13.1758
8229.491517 -35.242 5.9521
8230.223939 -40.778 18.8613
8230.956361 -34.586 0.1643
8231.688783 -41.279 17.3523
8232.421205 -38.264 19.0176
8233.153627 -39.127 -7.5757
8233.886048 -38.693 -1.4739
8234.618470 -38.476 31.5508
8235.350892 -36.923 11.0869
8236.083314 -38.248 -4.0942
8236.815736 -41.450 -13.3274
8237.548157 -39.722 8.1233
8238.280579 -40.015 -4.3977
8239.013001 -38.903 -12.5964
8239.745423 -40.598 20.4805
8240.477845 -42.058 38.6565
8241.210267 -39.042 23.2974
8241.942688 -40.807 21.5828
8242.675110 -36.764 35.3264
8243.407532 -37.375 10.3643
8244.139954 -46.858 20.0474
8244.872376 -39.750 57.5894
8245.604797 -46.083 45.6047
8246.337219 -39.624 66.6184
8247.069641 -39.769 -7.0486
8247.802063 -46.651 48.3733
8248.534485 -38.171 26.6877
8249.266906 -36.946 27.3118
8249.999328 -40.439 45.8120
8250.731750 -40.939 51.2437
8251.464172 -38.930 46.0271
8252.196594 -39.405 74.6284
8252.929016 -39.214 26.7910
8253.661437 -37.251 58.5610
8254.393859 -39.175 32.2046
8255.126281 -36.555 48.7969
8255.858703 -35.576 37.2246
8256.591125 -37.094 26.7539
8257.323546 -34.760 30.6174
8258.055968 -36.915 17.8789
8258.788390 -36.915 16.0430
8259.520812 -37.991 24.8474
8260.253234 -36.330 22.2720
8260.985656 -35.733 13.9663
8261.718077 -36.052 7.7427
8262.450499 -35.051 2.6689
8263.182921 -38.230 -10.9180
8263.915343 -36.194 -4.0854
8264.647765 -35.157 -11.6311
8265.380186 -35.033 0.3274
8266.112608 -37.061 -17.6748
8266.845030 -38.666 -15.9097
8267.577452 -36.300 -19.3054
8268.309874 -39.289 -13.2722
8269.042296 -37.501 -32.1372
8269.774717 -37.190 -6.5825
8270.507139 -39.060 -27.2383
8271.239561 -43.934 -16.4309
8271.971983 -44.974 -27.1187
8272.704405 -43.633 -6.2935
8273.436826 -41.719 -14.1506
8274.169248 -53.085 -8.7678
8274.901670 -48.979 5.5632
8275.634092 -40.250 14.6567
8276.366514 -43.302 19.2429
8277.098935 -41.071 13.2903
8277.831357 -43.454 15.5947
8278.563779 -40.883 38.1252
8279.296201 -40.816 11.8413
8280.028623 -39.543 14.2239
8280.761045 -39.955 14.5664
8281.493466 -36.650 1.9753
8282.225888 -39.271 4.6233
8282.958310 -37.186 2.4431
8283.690732 -38.897 -6.3308
8284.423154 -36.609 8.2275
8285.155575 -38.124 -15.4353
8285.887997 -38.040 -21.0627
8286.620419 -38.271 -10.9714
8287.352841 -37.071 -20.7290
8288.085263 -36.495 -27.9136
8288.817685 -36.184 -19.6450
8289.550106 -37.590 -33.6418
8290.282528 -36.552 -11.5752
8291.014950 -39.429 -8.6138
8291.747372 -39.576 -15.1709
8292.479794 -43.693 -48.5291
8293.212215 -37.938 -6.3596
8293.944637 -45.405 -18.0012
8294.677059 -43.135 -12.7402
8295.409481 -42.345 28.5137
8296.141903 -43.518 -3.3369
8296.874325 -45.497 -5.1724
8297.606746 -41.847 4.8623
8298.339168 -44.215 37.7471
8299.071590 -43.232 28.4075
8299.804012 -42.803 -11.4084
8300.536434 -42.216 33.5344
8301.268855 -46.724 28.2195
8302.001277 -42.235 -19.1113
8302.733699 -41.256 9.0969
8303.466121 -45.206 17.4536
8304.198543 -38.012 26.6311
8304.930964 -43.700 25.8740
8305.663386 -42.387 15.3811
8306.395808 -38.827 26.4353
8307.128230 -40.854 15.0054
8307.860652 -39.489 -5.0237
8308.593074 -39.562 -2.5750
8309.325495 -39.444 -1.4844
8310.057917 -39.979 -4.6389
8310.790339 -37.351 -2.8044
8311.522761 -37.462 -0.4988
8312.255183 -39.276 -6.4077
8312.987604 -37.555 -1.2380
8313.720026 -35.987 -9.7078
8314.452448 -37.375 -18.4666
8315.184870 -35.985 -8.8372
8315.917292 -38.703 -13.5459
8316.649714 -37.032 -21.1687
8317.382135 -38.390 -5.5229
8318.114557 -36.433 -16.0852
8318.846979 -42.173 -30.4666
8319.579401 -37.537 -41.2214
8320.311823 -39.707 -22.3608
8321.044244 -39.053 -27.0081
8321.776666 -39.849 -26.9033
8322.509088 -38.744 -59.4758
8323.241510 -43.100 -31.1021
8323.973932 -42.355 -63.5139
8324.706353 -43.884 -36.3784
8325.438775 -38.378 -59.4719
8326.171197 -43.116 -85.7502
8326.903619 -46.103 -89.9231
8327.636041 -56.432 -69.1924
8328.368463 -48.999 -133.0654
8329.100884 -66.349 96.5696
8329.833306 -51.547 107.7334
8330.565728 -46.944 177.2644
8331.298150 -47.933 66.7583
8332.030572 -42.064 114.4373
8332.762993 -45.416 102.6255
8333.495415 -42.121 85.8884
8334.227837 -44.332 86.1729
8334.960259 -39.761 81.1184
8335.692681 -38.253 73.3501
8336.425103 -36.788 75.9622
8337.157524 -38.419 56.5808
8337.889946 -36.500 56.0369
8338.622368 -36.241 48.5510
8339.354790 -35.753 39.8125
8340.087212 -34.953 40.0054
8340.819633 -32.864 38.0696
8341.552055 -32.959 32.0952
8342.284477 -32.319 33.4922
8343.016899 -32.949 20.3467
8343.749321 -32.740 21.9089
8344.481743 -32.775 15.5264
8345.214164 -32.161 12.4407
8345.946586 -32.684 1.1187
8346.679008 -32.453 4.2700
8347.411430 -33.705 -1.9048
8348.143852 -32.715 -5.7812
8348.876273 -32.916 -10.9421
8349.608695 -33.309 -13.7622
8350.341117 -33.041 -13.7959
8351.073539 -33.061 -20.7742
8351.805961 -33.324 -27.3879
8352.538382 -32.642 -24.4131
8353.270804 -33.255 -30.6069
8354.003226 -33.684 -32.5366
8354.735648 -34.889 -39.5862
8355.468070 -35.130 -36.0266
8356.200492 -35.587 -39.8342
8356.932913 -37.019 -46.3508
8357.665335 -36.658 -44.3718
8358.397757 -35.708 -44.2881
8359.130179 -38.252 -57.8213
8359.862601 -38.536 -38.3811
8360.595022 -38.659 -59.4871
8361.327444 -39.864 -48.3066
8362.059866 -39.023 -50.0762
8362.792288 -38.821 -50.0598
8363.524710 -40.950 -66.6909
8364.257132 -38.345 -48.6931
8364.989553 -40.180 -57.9468
8365.721975 -40.376 -41.9651
8366.454397 -40.593 -54.1528
8367.186819 -40.530 -43.2957
8367.919241 -41.504 -39.3218
8368.651662 -38.384 -58.9202
8369.384084 -40.172 -74.5112
8370.116506 -38.294 -59.7893
8370.848928 -41.620 -46.0847
8371.581350 -39.752 -42.1074
8372.313771 -40.606 -88.0544
8373.046193 -42.212 -59.2712
8373.778615 -42.736 -57.3926
8374.511037 -41.704 -49.3799
8375.243459 -44.670 -60.7817
8375.975881 -42.433 -58.3445
8376.708302 -42.301 -49.1282
8377.440724 -43.431 -41.5898
8378.173146 -44.506 -64.2380
8378.905568 -45.902 -43.3518
8379.637990 -42.048 -44.9644
8380.370411 -44.176 -37.9146
8381.102833 -48.391 -24.2690
8381.835255 -45.773 -39.1809
8382.567677 -50.553 -41.7122
8383.300099 -43.508 -25.0845
8384.032521 -51.220 -19.6479
8384.764942 -45.876 -6.6995
8385.497364 -48.131 -0.9028
8386.229786 -44.681 5.9141
8386.962208 -50.638 -25.9375
8387.694630 -41.825 -20.4783
8388.427051 -44.951 -21.3513
8389.159473 -39.547 -22.2861
8389.891895 -42.815 -1.3943
8390.624317 -41.838 6.7195
8391.356739 -41.869 0.4521
8392.089161 -42.535 -9.7234
8392.821582 -41.182 8.3850
8393.554004 -41.653 6.9150
8394.286426 -38.021 -6.7622
8395.018848 -38.164 -28.0430
8395.751270 -40.357 -7.8525
8396.483691 -40.130 -25.6069
8397.216113 -38.533 -20.3584
8397.948535 -40.371 -13.4609
8398.680957 -39.006 -16.9734
8399.413379 -36.970 -41.6487
8400.145800 -38.915 -30.3352
8400.878222 -36.564 -37.0618
8401.610644 -38.477 -35.8521
8402.343066 -38.910 -36.1057
8403.075488 -38.513 -38.2725
8403.807910 -38.270 -45.9958
8404.540331 -37.630 -47.5425
8405.272753 -41.218 -50.7883
8406.005175 -40.483 -38.4543
8406.737597 -38.466 -45.3184
8407.470019 -42.861 -47.3108
8408.202440 -38.878 -44.3330
8408.934862 -39.162 -74.6936
8409.667284 -42.898 -65.2844
8410.399706 -40.836 -70.6289
8411.132128 -41.171 -76.0879
8411.864550 -43.194 -61.6663
8412.596971 -40.223 -65.7153
8413.329393 -42.669 -73.2275
8414.061815 -41.517 -62.8550
8414.794237 -43.482 -85.8342
8415.526659 -47.030 -107.3845
8416.259080 -47.862 -57.9504
8416.991502 -44.852 -67.4597
8417.723924 -43.773 -42.2883
8418.456346 -42.406 -72.6038
8419.188768 -51.047 -9.9539
8419.921189 -44.291 -38.9890
8420.653611 -43.916 -53.4360
8421.386033 -47.234 -42.5024
8422.118455 -43.984 -57.9517
8422.850877 -44.288 -43.2458
8423.583299 -41.740 -53.9160
8424.315720 -42.581 -48.5505
8425.048142 -43.255 -39.9475
8425.780564 -39.995 -31.3628
8426.512986 -45.927 -56.5288
8427.245408 -48.588 -28.8257
8427.977829 -42.458 -40.0823
8428.710251 -39.594 -37.4961
8429.442673 -41.537 -30.1636
8430.175095 -40.480 -70.2961
8430.907517 -42.463 -42.9604
8431.639939 -40.342 -43.0112
8432.372360 -38.736 -50.4829
8433.104782 -39.646 -28.1948
8433.837204 -40.606 -48.3909
8434.569626 -42.236 -72.0256
8435.302048 -40.650 -74.7639
8436.034469 -38.411 -81.6919
8436.766891 -39.837 -72.0911
8437.499313 -38.738 -69.0977
8438.231735 -38.833 -84.4133
8438.964157 -38.701 -79.6914
8439.696579 -39.511 -83.0884
8440.429000 -39.818 -93.9575
8441.161422 -38.909 -86.1389
8441.893844 -41.041 -106.5923
8442.626266 -40.527 -92.2454
8443.358688 -40.113 -104.6575
8444.091109 -38.487 -121.5979
8444.823531 -38.598 -124.2644
8445.555953 -40.640 -129.9346
8446.288375 -41.218 -136.7378
8447.020797 -38.071 -146.3813
8447.753218 -39.566 -161.9111
8448.485640 -41.629 -141.0918
8449.218062 -42.144 -149.2217
8449.950484 -39.978 -171.7083
8450.682906 -43.405 -156.0454
8451.415328 -43.638 -176.9297
8452.147749 -44.355 169.6572
8452.880171 -43.884 169.9216
8453.612593 -43.932 160.1780
8454.345015 -47.550 140.4138
8455.077437 -47.097 162.3264
8455.809858 -44.668 135.2085
8456.542280 -43.910 135.4326
8457.274702 -42.636 115.9199
8458.007124 -45.152 111.2158
8458.739546 -43.681 105.7744
8459.471968 -43.435 86.7180
8460.204389 -43.370 64.3823
8460.936811 -44.914 78.3931
8461.669233 -42.493 89.6245
8462.401655 -42.019 78.7979
8463.134077 -41.799 49.2070
8463.866498 -43.957 45.6687
8464.598920 -43.544 45.6035
8465.331342 -42.431 62.2302
8466.063764 -41.182 38.4517
8466.796186 -45.189 36.8960
8467.528607 -46.534 40.4326
8468.261029 -45.869 30.7585
8468.993451 -43.761 25.1221
8469.725873 -43.755 24.1353
8470.458295 -46.823 53.1096
8471.190717 -42.707 67.4868
8471.923138 -45.146 23.0442
8472.655560 -45.414 17.5396
8473.387982 -44.117 42.2905
8474.120404 -46.942 31.9998
8474.852826 -46.394 15.6216
8475.585247 -44.726 19.4292
8476.317669 -46.030 14.0698
8477.050091 -44.570 15.2253
8477.782513 -45.639 -3.3108
8478.514935 -44.378 -8.6780
8479.247357 -45.708 9.4028
8479.979778 -45.940 14.7729
8480.712200 -42.659 3.6536
8481.444622 -47.457 -17.3132
8482.177044 -51.409 -74.0486
8482.909466 -45.915 27.4092
8483.641887 -52.749 -47.1287
8484.374309 -52.544 -3.1543
8485.106731 -50.053 52.5464
8485.839153 -49.566 53.9146
8486.571575 -59.396 -12.9460
8487.303997 -55.129 29.9363
8488.036418 -48.967 27.7600
8488.768840 -45.693 46.6008
8489.501262 -49.460 5.0112
8490.233684 -45.574 29.7407
8490.966106 -46.974 61.2681
8491.698527 -45.948 60.0618
8492.430949 -43.737 42.2986
8493.163371 -43.835 56.5925
8493.895793 -40.119 68.5034
8494.628215 -40.180 45.5186
8495.360636 -44.856 31.8733
8496.093058 -41.710 35.3811
8496.825480 -39.601 49.0085
8497.557902 -40.034 38.2859
8498.290324 -40.711 35.7170
8499.022746 -39.131 20.2361
8499.755167 -38.879 19.4631
8500.487589 -38.665 27.4849
8501.220011 -38.977 3.6135
8501.952433 -40.222 -1.0762
8502.684855 -36.998 16.1084
8503.417276 -37.422 9.4844
8504.149698 -37.661 2.9155
8504.882120 -37.629 -14.6873
8505.614542 -38.413 3.3293
8506.346964 -37.730 -15.4841
8507.079386 -40.175 -23.3164
8507.811807 -38.644 -28.7141
8508.544229 -37.941 -20.8066
8509.276651 -38.833 -26.1921
8510.009073 -38.606 -29.3264
8510.741495 -39.283 -40.9751
8511.473916 -39.190 -30.8206
8512.206338 -39.933 -21.1758
8512.938760 -40.959 -66.2366
8513.671182 -40.781 -43.6746
8514.403604 -42.552 -24.7239
8515.136025 -43.940 -42.2903
8515.868447 -41.121 -36.5300
8516.600869 -44.716 -21.7139
8517.333291 -47.421 -16.2434
8518.065713 -40.881 -21.2280
8518.798135 -43.793 -49.4978
8519.530556 -44.740 -15.6223
8520.262978 -40.805 -20.5093
8520.995400 -40.652 -11.2034
8521.727822 -43.324 -20.7502
8522.460244 -42.321 -30.1313
8523.192665 -39.963 -18.4207
8523.925087 -39.419 -23.6582
8524.657509 -40.585 -33.8601
8525.389931 -41.211 -32.5027
8526.122353 -40.396 -31.7708
8526.854775 -40.868 -29.8018
8527.587196 -39.877 -46.0723
8528.319618 -40.024 -33.6682
8529.052040 -38.940 -49.0120
8529.784462 -37.833 -44.1851
8530.516884 -38.624 -71.5979
8531.249305 -38.632 -69.9053
8531.981727 -38.178 -68.1880
8532.714149 -38.844 -76.3301
8533.446571 -39.030 -89.0325
8534.178993 -39.115 -85.5317
8534.911415 -40.132 -103.0947
8535.643836 -37.945 -104.4661
8536.376258 -37.188 -128.5803
8537.108680 -38.472 -119.9270
8537.841102 -38.671 -126.2410
8538.573524 -39.497 -130.0552
8539.305945 -38.176 -145.0166
8540.038367 -42.675 -161.4875
8540.770789 -42.689 -150.9490
8541.503211 -40.808 -146.5540
8542.235633 -38.442 -176.9309
8542.968054 -43.683 161.8403
8543.700476 -41.692 -175.0417
8544.432898 -43.225 163.1040
8545.165320 -40.554 152.3403
8545.897742 -42.619 145.0361
8546.630164 -43.888 144.0425
8547.362585 -40.560 131.0786
8548.095007 -39.707 129.3467
8548.827429 -40.939 106.8071
8549.559851 -45.138 121.3335
8550.292273 -44.512 61.4404
8551.024694 -47.524 107.4121
8551.757116 -44.046 86.4419
8552.489538 -50.198 54.0779
8553.221960 -48.721 49.7354
8553.954382 -47.475 123.3772
8554.686804 -49.733 45.7649
8555.419225 -51.680 79.9563
8556.151647 -50.423 -42.5815
8556.884069 -51.059 -67.0623
8557.616491 -57.262 111.4583
8558.348913 -67.625 69.4509
8559.081334 -57.419 -117.3594
8559.813756 -49.675 157.1626
8560.546178 -49.808 134.8577
8561.278600 -53.189 -155.2239
8562.011022 -48.900 57.2205
8562.743443 -54.451 -155.8457
8563.475865 -48.504 101.0264
8564.208287 -45.675 83.0688
8564.940709 -44.909 110.7737
8565.673131 -42.115 98.9583
8566.405553 -42.237 95.0327
8567.137974 -44.289 117.4944
8567.870396 -43.138 68.9595
8568.602818 -40.818 84.8801
8569.335240 -40.761 78.6870
8570.067662 -40.557 76.9565
8570.800083 -40.597 66.3762
8571.532505 -38.498 81.2900
8572.264927 -41.954 63.2830
8572.997349 -38.847 74.9736
8573.729771 -39.464 37.6294
8574.462193 -39.637 59.7483
8575.194614 -40.412 39.2759
8575.927036 -39.106 44.5173
8576.659458 -47.244 42.3340
8577.391880 -39.900 20.8462
8578.124302 -38.015 32.0486
8578.856723 -41.692 22.0918
8579.589145 -40.287 11.7839
8580.321567 -36.802 36.3345
8581.053989 -40.913 31.7805
8581.786411 -39.377 26.2920
8582.518833 -44.435 0.5723
8583.251254 -39.018 29.0112
8583.983676 -42.189 7.6936
8584.716098 -47.634 20.1943
8585.448520 -42.712 -3.6379
8586.180942 -41.293 -3.8320
8586.913363 -40.045 -15.4114
8587.645785 -41.078 -33.2537
8588.378207 -39.524 -13.8162
8589.110629 -40.831 -30.7241
8589.843051 -40.689 -34.0125
8590.575472 -45.293 -33.5205
8591.307894 -39.182 -31.0679
8592.040316 -44.825 -49.6704
8592.772738 -43.064 -29.3235
8593.505160 -48.909 -55.3213
8594.237582 -48.514 -87.6797
8594.970003 -48.035 -27.2761
8595.702425 -51.228 -81.4814
8596.434847 -54.767 -162.3198
8597.167269 -46.006 -88.4099
8597.899691 -54.880 -149.1909
8598.632112 -50.062 -79.2380
8599.364534 -44.813 -153.8191
8600.096956 -47.255 -149.8167
8600.829378 -51.569 35.9219
8601.561800 -47.287 147.4099
8602.294222 -44.894 139.8499
8603.026643 -44.133 168.4958
8603.759065 -59.724 9.2690
8604.491487 -53.806 60.4451
8605.223909 -45.744 48.3757
8605.956331 -49.393 114.6797
8606.688752 -49.052 91.6716
8607.421174 -45.344 77.7188
8608.153596 -46.454 28.0728
8608.886018 -50.596 7.6572
8609.618440 -61.302 38.9160
8610.350861 -55.320 -145.3386
8611.083283 -45.831 15.1702
8611.815705 -49.719 14.4763
8612.548127 -53.386 90.4082
8613.280549 -49.118 -91.5129
8614.012971 -53.220 61.0820
8614.745392 -45.204 -133.1333
8615.477814 -44.030 -115.3035
8616.210236 -53.037 153.2253
8616.942658 -50.657 -137.1909
8617.675080 -46.415 -158.2578
8618.407501 -60.996 130.1543
8619.139923 -46.822 -177.6782
8619.872345 -41.026 130.5427
8620.604767 -40.511 166.3184
8621.337189 -42.518 148.0920
8622.069611 -41.768 162.2546
8622.802032 -39.402 120.3083
8623.534454 -38.421 146.0161
8624.266876 -38.152 123.2778
8624.999298 -37.411 118.3042
8625.731720 -37.003 111.5168
8626.464141 -37.952 113.5422
8627.196563 -36.284 90.8257
8627.928985 -37.532 94.9136
8628.661407 -38.665 94.4526
8629.393829 -34.570 95.6365
8630.126251 -35.244 72.3816
8630.858672 -36.042 65.8416
8631.591094 -34.709 65.5430
8632.323516 -37.716 66.1245
8633.055938 -36.488 58.3259
8633.788360 -36.716 63.4248
8634.520781 -40.280 64.0171
8635.253203 -37.240 50.9558
8635.985625 -36.978 41.3516
8636.718047 -38.108 42.0034
8637.450469 -37.238 42.3384
8638.182890 -40.704 36.4736
8638.915312 -40.694 32.7998
8639.647734 -43.901 45.9905
8640.380156 -40.878 7.9719
8641.112578 -41.770 38.9817
8641.845000 -42.223 33.3657
8642.577421 -41.301 43.8108
8643.309843 -37.898 47.3904
8644.042265 -45.156 70.2607
8644.774687 -43.670 71.5696
8645.507109 -43.617 49.9751
8646.239530 -41.593 35.2654
8646.971952 -40.089 41.1487
8647.704374 -36.887 34.8440
8648.436796 -39.494 42.9304
8649.169218 -42.671 28.6516
8649.901640 -39.693 57.8621
8650.634061 -37.369 45.0115
8651.366483 -40.651 30.4136
8652.098905 -38.589 40.9363
8652.831327 -37.468 27.7668
8653.563749 -38.604 22.8220
8654.296170 -42.862 23.3660
8655.028592 -38.374 0.9250
8655.761014 -41.058 26.9377
8656.493436 -43.953 35.1184
8657.225858 -46.726 44.7622
8657.958279 -41.154 7.9751
8658.690701 -43.654 5.5144
8659.423123 -43.774 24.5854
8660.155545 -43.902 -2.4009
8660.887967 -44.664 13.0642
8661.620389 -48.556 57.3049
8662.352810 -46.770 47.6077
8663.085232 -48.225 76.9790
8663.817654 -50.204 63.9717
8664.550076 -43.592 52.9661
8665.282498 -42.639 36.3333
8666.014919 -40.366 55.1296
8666.747341 -42.782 62.4219
8667.479763 -37.247 59.4233
8668.212185 -38.376 44.1328
8668.944607 -39.010 64.1631
8669.677029 -41.695 50.2939
8670.409450 -36.013 51.0195
8671.141872 -38.356 24.3164
8671.874294 -37.786 38.4575
8672.606716 -37.472 26.2793
8673.339138 -35.927 19.5820
8674.071559 -39.006 18.4675
8674.803981 -38.742 16.6106
8675.536403 -38.692 6.5864
8676.268825 -37.450 -4.8071
8677.001247 -38.387 -20.3521
8677.733669 -40.421 -21.1313
8678.466090 -37.727 -14.3958
8679.198512 -38.712 -23.1838
8679.930934 -39.420 -20.9517
8680.663356 -42.646 -14.1421
8681.395778 -44.215 -62.2095
8682.128199 -40.681 -44.0376
8682.860621 -41.485 -47.7856
8683.593043 -45.412 -59.1790
8684.325465 -45.283 -81.0520
8685.057887 -48.269 -129.3381
8685.790308 -49.848 -59.4050
8686.522730 -52.288 86.3276
8687.255152 -49.963 81.7896
8687.987574 -51.665 97.4768
8688.719996 -51.641 144.3726
8689.452418 -47.193 90.0813
8690.184839 -46.618 84.2480
8690.917261 -42.378 98.1816
8691.649683 -42.590 94.7329
8692.382105 -40.562 77.4253
8693.114527 -41.508 105.0813
8693.846948 -41.619 55.4407
8694.579370 -41.579 78.2224
8695.311792 -42.426 45.2026
8696.044214 -40.633 52.1660
8696.776636 -39.164 42.1621
8697.509058 -43.985 52.8386
8698.241479 -40.500 39.1714
8698.973901 -37.217 47.0034
8699.706323 -38.829 34.1201
8700.438745 -40.362 41.3914
8701.171167 -39.907 37.7708
8701.903588 -41.613 32.6960
8702.636010 -39.815 36.1528
8703.368432 -39.763 36.7612
8704.100854 -38.459 30.1091
8704.833276 -43.098 51.2236
8705.565697 -41.838 20.1853
8706.298119 -40.437 28.7456
8707.030541 -43.850 23.8513
8707.762963 -43.168 46.3223
8708.495385 -40.443 22.4626
8709.227807 -41.745 55.5156
8709.960228 -40.650 34.6675
8710.692650 -39.800 46.0178
8711.425072 -42.825 10.2014
8712.157494 -44.192 37.2805
8712.889916 -39.382 13.0662
8713.622337 -42.403 39.0757
8714.354759 -40.515 27.7456
8715.087181 -39.378 18.2595
8715.819603 -39.843 15.4646
8716.552025 -40.123 29.1309
8717.284447 -39.345 17.9226
8718.016868 -41.514 15.4590
8718.749290 -42.094 18.6663
8719.481712 -45.686 16.3982
8720.214134 -42.643 14.5061
8720.946556 -43.742 19.3091
8721.678977 -41.898 25.8767
8722.411399 -41.987 26.8013
8723.143821 -45.192 38.1521
8723.876243 -45.918 36.8672
8724.608665 -45.449 46.9968
8725.341087 -45.872 39.5947
8726.073508 -45.681 45.6855
8726.805930 -45.219 57.3096
8727.538352 -41.859 43.9807
8728.270774 -38.501 60.9084
8729.003196 -43.334 61.0500
8729.735617 -41.175 51.2234
8730.468039 -40.019 66.5427
8731.200461 -39.397 58.6160
8731.932883 -39.251 51.6135
8732.665305 -38.106 51.4126
8733.397726 -37.451 35.8904
8734.130148 -36.305 43.5054
8734.862570 -36.160 41.4102
8735.594992 -35.583 28.0186
8736.327414 -35.594 30.0496
8737.059836 -36.299 29.3772
8737.792257 -36.293 25.8699
8738.524679 -35.599 14.8223
8739.257101 -35.472 19.5493
8739.989523 -34.984 26.2388
8740.721945 -35.311 13.5544
8741.454366 -35.994 7.9370
8742.186788 -35.943 5.0039
8742.919210 -34.700 7.5854
8743.651632 -36.334 0.5571
8744.384054 -35.690 -4.9541
8745.116476 -35.711 -10.1792
8745.848897 -34.986 -13.5508
8746.581319 -36.132 -18.6470
8747.313741 -38.311 -20.1104
8748.046163 -37.159 -15.2632
8748.778585 -38.241 -8.9133
8749.511006 -37.764 -19.6438
8750.243428 -38.806 -31.8406
8750.975850 -38.292 -32.9878
8751.708272 -40.035 -21.3096
8752.440694 -44.260 -22.4597
8753.173115 -41.075 -38.6653
8753.905537 -43.973 -12.7104
8754.637959 -42.110 -2.1802
8755.370381 -44.871 4.7456
8756.102803 -44.735 -6.3835
8756.835225 -45.413 10.9731
8757.567646 -41.662 5.2964
8758.300068 -46.712 15.7576
8759.032490 -42.361 16.5676
8759.764912 -42.385 -11.4814
8760.497334 -42.311 7.2395
8761.229755 -42.437 4.1492
8761.962177 -40.621 14.2581
8762.694599 -42.060 -17.5955
8763.427021 -37.381 -4.3147
8764.159443 -40.849 -12.6914
8764.891865 -40.307 -5.3606
8765.624286 -39.392 -11.8369
8766.356708 -38.944 -10.5396
8767.089130 -40.308 -7.1165
8767.821552 -38.628 -29.0637
8768.553974 -40.772 -35.3567
8769.286395 -39.810 -17.3269
8770.018817 -41.656 -32.1792
8770.751239 -39.673 -32.7937
8771.483661 -40.851 -32.1675
8772.216083 -39.256 -32.9246
8772.948505 -44.428 -67.6331
8773.680926 -45.079 -55.9871
8774.413348 -40.436 -60.6343
8775.145770 -44.544 -32.1777
8775.878192 -52.438 -104.4902
8776.610614 -50.426 -75.5374
8777.343035 -49.152 -15.9211
8778.075457 -50.758 -40.5669
8778.807879 -52.075 28.5605
8779.540301 -63.818 126.7144
8780.272723 -51.573 -11.3452
8781.005144 -44.570 -8.0789
8781.737566 -54.700 2.2607
8782.469988 -51.599 39.9031
8783.202410 -49.709 69.1079
8783.934832 -44.408 11.7012
8784.667254 -45.415 39.0371
8785.399675 -44.079 44.1157
8786.132097 -44.859 2.0471
8786.864519 -41.556 10.9421
8787.596941 -43.005 3.9888
8788.329363 -45.101 4.3792
8789.061784 -41.850 26.5134
8789.794206 -42.257 -0.2710
8790.526628 -40.402 20.8691
8791.259050 -45.016 0.4822
8791.991472 -42.534 13.0771
8792.723894 -44.221 -4.0012
8793.456315 -46.147 24.1665
8794.188737 -45.868 28.8958
8794.921159 -48.374 -3.8262
8795.653581 -44.626 14.8450
8796.386003 -42.702 6.1296
8797.118424 -44.432 29.0229
8797.850846 -50.767 19.0264
8798.583268 -44.312 23.1006
8799.315690 -46.970 66.8730
8800.048112 -49.366 49.8784
8800.780533 -42.479 28.8027
8801.512955 -41.315 25.6902
8802.245377 -41.715 38.2612
8802.977799 -41.975 31.9617
8803.710221 -39.748 38.5205
8804.442643 -39.768 24.1523
8805.175064 -38.265 32.7561
8805.907486 -42.068 23.4719
8806.639908 -39.704 23.4602
8807.372330 -37.720 14.0215
8808.104752 -38.557 12.8677
8808.837173 -38.404 23.2188
8809.569595 -39.914 29.9326
8810.302017 -41.186 18.7903
8811.034439 -39.554 2.9077
8811.766861 -39.205 21.9209
8812.499283 -38.982 5.7253
8813.231704 -38.373 1.8782
8813.964126 -39.580 -1.1531
8814.696548 -40.151 0.8638
8815.428970 -38.290 -5.7422
8816.161392 -38.618 -8.1436
8816.893813 -39.545 -6.8994
8817.626235 -39.966 17.2654
8818.358657 -40.135 -8.3589
8819.091079 -40.211 -4.6414
8819.823501 -38.965 14.0427
8820.555923 -38.521 3.2476
8821.288344 -39.560 -2.6851
8822.020766 -39.754 -8.1345
8822.753188 -41.004 13.3157
8823.485610 -39.820 2.9895
8824.218032 -39.506 -15.5522
8824.950453 -40.048 -13.9695
8825.682875 -39.167 -2.2173
8826.415297 -39.658 -10.8972
8827.147719 -42.079 -35.3254
8827.880141 -39.577 -38.2996
8828.612562 -43.161 -28.9946
8829.344984 -42.567 -2.9678
8830.077406 -42.964 -32.4734
8830.809828 -40.347 -43.6428
8831.542250 -43.094 -49.0447
8832.274672 -43.078 -48.8096
8833.007093 -46.612 -75.4014
8833.739515 -45.535 -68.2898
8834.471937 -48.219 -62.9778
8835.204359 -61.557 -37.5093
8835.936781 -51.129 -1.8469
8836.669202 -53.150 -88.5562
8837.401624 -60.910 -115.2375
8838.134046 -47.179 17.4446
8838.866468 -53.941 91.6326
8839.598890 -58.781 76.1189
8840.331312 -42.613 71.7134
8841.063733 -43.035 51.5059
8841.796155 -41.099 49.1340
8842.528577 -44.861 31.5813
8843.260999 -41.970 60.5061
8843.993421 -41.367 31.7549
8844.725842 -39.530 52.7351
8845.458264 -38.487 29.1362
8846.190686 -38.906 29.0947
8846.923108 -37.915 31.2864
8847.655530 -39.085 24.3538
8848.387951 -40.223 -2.5803
8849.120373 -38.333 19.6072
8849.852795 -36.698 3.7524
8850.585217 -40.362 1.9636
8851.317639 -40.218 -28.5688
8852.050061 -40.662 2.4485
8852.782482 -38.702 -12.4241
8853.514904 -42.116 -11.3865
8854.247326 -47.942 -48.9487
8854.979748 -42.541 -23.2993
8855.712170 -43.782 -61.5557
8856.444591 -45.609 9.6736
8857.177013 -47.559 -6.8337
8857.909435 -46.540 3.6851
8858.641857 -44.831 7.7607
8859.374279 -48.916 14.7324
8860.106701 -70.488 -55.2832
8860.839122 -47.293 6.8154
8861.571544 -41.796 16.7319
8862.303966 -42.909 48.0178
8863.036388 -46.899 40.1028
8863.768810 -39.673 41.1201
8864.501231 -38.970 32.1421
8865.233653 -37.511 55.1465
8865.966075 -39.814 16.2175
8866.698497 -37.936 23.3074
8867.430919 -37.781 4.3040
8868.163341 -36.826 16.0383
8868.895762 -38.625 8.2097
8869.628184 -36.481 18.7749
8870.360606 -36.616 -0.1956
8871.093028 -36.170 4.4619
8871.825450 -37.744 -3.4634
8872.557871 -37.537 -16.7249
8873.290293 -37.109 -15.2605
8874.022715 -39.224 -0.8093
8874.755137 -41.599 -8.6155
8875.487559 -37.732 -2.8904
8876.219980 -38.373 -14.9873
8876.952402 -39.928 -13.8560
8877.684824 -50.142 1.0513
8878.417246 -44.133 0.7791
8879.149668 -46.290 -17.4429
8879.882090 -38.888 10.7007
8880.614511 -45.574 28.2629
8881.346933 -40.357 19.7424
8882.079355 -42.073 -2.1199
8882.811777 -42.743 1.3118
8883.544199 -40.259 25.8953
8884.276620 -40.856 12.3521
8885.009042 -37.286 20.2302
8885.741464 -37.236 13.8767
8886.473886 -37.331 28.8201
8887.206308 -35.922 12.2104
8887.938730 -35.335 4.7327
8888.671151 -34.161 2.9211
8889.403573 -36.882 3.2639
8890.135995 -33.822 -0.1934
8890.868417 -35.179 -9.9036
8891.600839 -33.544 -4.3831
8892.333260 -33.185 -17.7986
8893.065682 -32.910 -20.5234
8893.798104 -33.867 -32.2778
8894.530526 -33.772 -31.8655
8895.262948 -36.824 -34.4360
8895.995369 -33.060 -40.0005
8896.727791 -35.090 -45.6536
8897.460213 -35.509 -56.9087
8898.192635 -39.541 -56.4048
8898.925057 -36.642 -56.5513
8899.657479 -35.724 -53.4690
8900.389900 -38.630 -79.9558
8901.122322 -38.562 -95.9290
8901.854744 -38.531 -78.1311
8902.587166 -40.506 -96.4421
8903.319588 -37.898 -87.7458
8904.052009 -43.703 -101.8438
8904.784431 -46.025 -104.1724
8905.516853 -44.097 -93.8501
8906.249275 -48.444 -83.9253
8906.981697 -57.166 130.8804
8907.714119 -48.179 -59.5076
8908.446540 -51.806 -8.3101
8909.178962 -42.138 -8.4426
8909.911384 -48.018 33.3367
8910.643806 -48.031 -18.1968
8911.376228 -42.761 8.0908
8912.108649 -45.386 42.2351
8912.841071 -42.419 10.2654
8913.573493 -45.774 -16.0942
8914.305915 -46.443 -19.5789
8915.038337 -42.197 -0.4050
8915.770759 -42.116 11.6790
8916.503180 -39.218 -13.4519
8917.235602 -44.554 -24.4258
8917.968024 -38.788 -22.9424
8918.700446 -41.589 -26.1689
8919.432868 -41.056 -43.1543
8920.165289 -37.123 -25.8350
8920.897711 -40.028 -33.6504
8921.630133 -39.170 -30.9810
8922.362555 -39.162 -61.9077
8923.094977 -40.649 -49.1504
8923.827398 -43.258 -27.2847
8924.559820 -45.453 -40.4370
8925.292242 -47.453 -32.5542
8926.024664 -41.808 -54.6707
8926.757086 -41.031 -60.5020
8927.489508 -42.984 -3.3254
8928.221929 -41.279 -37.8474
8928.954351 -45.320 -96.1416
8929.686773 -43.853 -40.1023
8930.419195 -52.625 -77.4836
8931.151617 -37.531 -57.7756
8931.884038 -45.065 -14.3555
8932.616460 -37.689 -47.6499
8933.348882 -44.099 1.7817
8934.081304 -43.614 -52.2991
8934.813726 -40.407 -73.3350
8935.546148 -39.803 -60.5010
8936.278569 -43.937 -89.3188
8937.010991 -37.800 -84.3479
8937.743413 -39.111 -83.3413
8938.475835 -44.317 -71.5767
8939.208257 -48.362 25.2517
8939.940678 -53.260 -132.7295
8940.673100 -43.968 -48.8213
8941.405522 -39.262 -105.3191
8942.137944 -47.158 -19.1880
8942.870366 -39.824 -122.5557
8943.602787 -42.755 -109.9480
8944.335209 -49.007 -118.3979
8945.067631 -41.601 1.9929
8945.800053 -46.457 -16.5796
8946.532475 -45.797 102.2324
8947.264897 -40.312 -2.8271
8947.997318 -40.086 -10.4685
8948.729740 -52.448 -5.5513
8949.462162 -50.490 59.9766
8950.194584 -42.265 -3.3479
8950.927006 -38.485 47.1680
8951.659427 -54.464 -92.0525
8952.391849 -38.855 11.0745
8953.124271 -40.575 70.6726
8953.856693 -46.167 -28.5942
8954.589115 -41.491 -47.8611
8955.321537 -58.458 2.6438
8956.053958 -38.275 -5.6401
8956.786380 -38.131 -41.2444
8957.518802 -36.690 -43.3628
8958.251224 -35.453 -53.2725
8958.983646 -35.422 -57.6682
8959.716067 -37.271 -73.9490
8960.448489 -43.533 -92.9451
8961.180911 -40.812 -57.5825
8961.913333 -42.528 -77.3665
8962.645755 -35.238 -34.1060
8963.378177 -43.101 -76.2681
8964.110598 -47.094 -135.6917
8964.843020 -36.162 -138.7021
8965.575442 -40.554 -87.1150
8966.307864 -40.501 -166.9832
8967.040286 -49.353 -91.6941
8967.772707 -37.211 133.5085
8968.505129 -43.897 -77.5210
8969.237551 -49.600 112.7427
8969.969973 -41.486 -178.4973
8970.702395 -55.554 45.4185
8971.434816 -40.866 -131.8904
8972.167238 -38.709 167.7578
8972.899660 -39.437 -34.3706
8973.632082 -47.447 -105.4746
8974.364504 -41.792 28.2979
8975.096926 -42.175 -18.7700
8975.829347 -39.776 0.6699
8976.561769 -38.642 38.5776
8977.294191 -35.547 -16.0881
8978.026613 -47.382 49.5964
8978.759035 -39.841 -26.2092
8979.491456 -41.071 16.3833
8980.223878 -35.184 -75.1382
8980.956300 -41.403 16.0566
8981.688722 -36.947 -84.8440
8982.421144 -39.982 -48.1296
8983.153566 -42.688 -82.1531
8983.885987 -40.352 -30.9224
8984.618409 -34.742 -49.4009
8985.350831 -38.869 -82.1062
8986.083253 -41.734 -63.7419
8986.815675 -42.398 -79.1462
8987.548096 -48.240 -141.9573
8988.280518 -53.360 -23.3459
8989.012940 -38.272 -157.7463
8989.745362 -45.642 -161.2505
8990.477784 -36.153 -111.0356
8991.210205 -55.828 13.3152
8991.942627 -45.986 -36.2793
8992.675049 -42.628 20.9231
8993.407471 -43.311 -84.3999
8994.139893 -39.388 75.0667
8994.872315 -40.365 -132.6416
8995.604736 -42.941 -154.3816
8996.337158 -41.204 -90.7334
8997.069580 -43.117 78.5647
8997.802002 -41.946 100.9382
8998.534424 -39.202 56.0120
8999.266845 -44.047 42.4060
8999.999267 -46.562 62.4092
9000.731689 -41.584 15.9321
9001.464111 -37.853 42.9280
9002.196533 -45.221 83.5254
9002.928955 -41.880 71.9485
9003.661376 -51.165 -155.1838
9004.393798 -43.103 35.9702
9005.126220 -40.888 76.2588
9005.858642 -39.183 39.9985
9006.591064 -38.201 -23.3457
9007.323485 -41.552 38.1462
9008.055907 -45.443 84.1045
9008.788329 -36.382 17.0842
9009.520751 -53.413 -105.7920
9010.253173 -47.040 67.1829
9010.985595 -47.199 98.0500
9011.718016 -39.471 -7.9006
9012.450438 -43.322 -11.4109
9013.182860 -44.698 -32.5264
9013.915282 -44.542 92.7214
9014.647704 -49.658 68.7402
9015.380125 -45.276 14.6938
9016.112547 -41.126 37.9243
9016.844969 -37.682 34.2629
9017.577391 -46.198 -18.2590
9018.309813 -45.337 -160.6860
9019.042234 -43.412 37.5676
9019.774656 -44.137 55.2783
9020.507078 -46.672 19.4185
9021.239500 -50.323 43.8591
9021.971922 -48.133 65.9756
9022.704344 -49.729 -107.0522
9023.436765 -41.743 -36.8018
9024.169187 -37.315 -76.9993
9024.901609 -46.225 -88.9248
9025.634031 -68.383 118.4856
9026.366453 -49.213 134.4885
9027.098874 -44.423 -147.7659
9027.831296 -47.603 64.4648
9028.563718 -47.495 -9.1057
9029.296140 -48.940 141.6477
9030.028562 -41.624 78.9443
9030.760984 -53.290 121.0139
9031.493405 -39.509 116.6318
9032.225827 -44.380 64.3533
9032.958249 -45.424 143.4512
9033.690671 -37.712 28.7373
9034.423093 -52.225 75.0500
9035.155514 -43.988 92.5339
9035.887936 -39.983 55.9170
9036.620358 -40.491 25.1445
9037.352780 -41.895 74.3616
9038.085202 -37.977 -3.7778
9038.817623 -43.752 45.5417
9039.550045 -37.421 21.2732
9040.282467 -38.147 25.4312
9041.014889 -42.202 57.1248
9041.747311 -36.880 9.5979
9042.479733 -40.697 42.5981
9043.212154 -36.535 36.9568
9043.944576 -39.352 -13.0979
9044.676998 -33.176 -28.2747
9045.409420 -38.105 19.6025
9046.141842 -35.401 9.7810
9046.874263 -42.410 9.8289
9047.606685 -41.697 41.9448
9048.339107 -38.278 -2.4934
9049.071529 -42.172 16.0410
9049.803951 -36.365 -0.3508
9050.536373 -37.990 -8.9573
9051.268794 -39.654 -0.3711
9052.001216 -37.558 48.2183
9052.733638 -40.014 22.9980
9053.466060 -36.970 -52.7131
9054.198482 -36.845 19.1409
9054.930903 -42.349 42.0261
9055.663325 -44.580 20.5930
9056.395747 -42.138 6.4854
9057.128169 -37.857 26.2610
9057.860591 -41.194 27.6755
9058.593013 -36.805 14.0010
9059.325434 -41.038 4.8921
9060.057856 -42.177 22.5249
9060.790278 -40.837 12.2388
9061.522700 -40.866 14.5559
9062.255122 -35.954 4.5979
9062.987543 -40.973 -22.1353
9063.719965 -36.707 -29.2422
9064.452387 -41.265 6.1353
9065.184809 -38.677 -32.7151
9065.917231 -37.886 -10.5383
9066.649652 -41.555 -18.3989
9067.382074 -38.806 7.4604
9068.114496 -39.678 -49.4380
9068.846918 -40.621 -54.9783
9069.579340 -39.700 -55.1702
9070.311762 -46.149 -66.9878
9071.044183 -45.252 -50.9446
9071.776605 -40.579 -56.0569
9072.509027 -42.249 -51.0823
9073.241449 -50.651 -79.5159
9073.973871 -44.514 -33.3062
9074.706292 -45.452 -1.6482
9075.438714 -44.267 -101.0247
9076.171136 -43.094 -57.4250
9076.903558 -50.039 47.3440
9077.635980 -50.008 -9.3169
9078.368402 -48.214 -20.1162
9079.100823 -41.935 -31.4109
9079.833245 -42.652 12.5933
9080.565667 -44.852 36.3726
9081.298089 -52.582 -43.3525
9082.030511 -44.070 -4.4680
9082.762932 -43.685 19.6868
9083.495354 -44.919 -3.9841
9084.227776 -44.867 -55.1362
9084.960198 -44.198 8.9243
9085.692620 -48.995 -66.8767
9086.425041 -46.150 -5.8992
9087.157463 -50.462 -25.6636
9087.889885 -49.224 36.8823
9088.622307 -42.564 1.5874
9089.354729 -44.128 -18.5291
9090.087151 -51.372 13.8796
9090.819572 -50.947 -32.6946
9091.551994 -46.122 -7.4639
9092.284416 -65.980 -40.9526
9093.016838 -49.682 37.6797
9093.749260 -47.426 12.7786
9094.481681 -51.846 61.9807
9095.214103 -46.514 24.0486
9095.946525 -43.106 59.9941
9096.678947 -44.923 26.2241
9097.411369 -44.544 17.9136
9098.143791 -41.911 34.9023
9098.876212 -44.175 47.0818
9099.608634 -42.175 31.7678
9100.341056 -45.238 50.2971
9101.073478 -41.171 23.3809
9101.805900 -40.582 18.7468
9102.538321 -40.367 33.4932
9103.270743 -40.733 15.2920
9104.003165 -40.885 19.6738
9104.735587 -40.020 6.2856
9105.468009 -42.802 11.7390
9106.200431 -42.779 4.7524
9106.932852 -43.403 -16.0410
9107.665274 -45.651 4.2908
9108.397696 -41.374 12.3955
9109.130118 -42.472 -0.7844
9109.862540 -41.226 15.5742
9110.594961 -46.572 -1.1140
9111.327383 -43.782 -12.2000
9112.059805 -45.033 7.0049
9112.792227 -41.250 2.2285
9113.524649 -43.998 4.8601
9114.257070 -43.888 10.5466
9114.989492 -42.045 7.9253
9115.721914 -43.796 12.1084
9116.454336 -44.385 32.1707
9117.186758 -42.355 13.7065
9117.919180 -42.821 -2.0073
9118.651601 -39.960 -0.4651
9119.384023 -40.465 10.1611
9120.116445 -38.393 -14.9917
9120.848867 -38.492 7.5776
9121.581289 -39.124 -13.2803
9122.313710 -40.626 0.6377
9123.046132 -38.387 -20.5422
9123.778554 -40.584 -4.1848
9124.510976 -39.471 -19.0078
9125.243398 -38.574 -18.8093
9125.975820 -41.391 -24.0120
9126.708241 -39.783 -24.3838
9127.440663 -37.668 -30.1379
9128.173085 -41.358 -17.0630
9128.905507 -40.345 -29.9766
9129.637929 -40.101 -37.1797
9130.370350 -39.829 -52.3894
9131.102772 -45.540 -15.2827
9131.835194 -42.678 -36.6345
9132.567616 -43.616 -28.1965
9133.300038 -43.929 -31.4578
9134.032459 -51.761 -34.7332
9134.764881 -42.196 -27.2063
9135.497303 -42.381 -31.2849
9136.229725 -42.600 -57.5947
9136.962147 -41.164 -33.8201
9137.694569 -42.372 -24.7202
9138.426990 -43.899 -3.9419
9139.159412 -44.744 -44.7781
9139.891834 -40.355 -12.3057
9140.624256 -40.068 -29.4531
9141.356678 -41.524 -26.0364
9142.089099 -38.902 -39.1040
9142.821521 -38.814 -13.1948
9143.553943 -40.409 -33.0667
9144.286365 -38.953 -26.4778
9145.018787 -38.980 -41.0569
9145.751209 -39.314 -33.9585
9146.483630 -37.511 -47.2642
9147.216052 -38.836 -33.8306
9147.948474 -37.974 -53.3472
9148.680896 -37.937 -54.4189
9149.413318 -38.397 -62.0322
9150.145739 -38.073 -65.7546
9150.878161 -38.378 -72.1785
9151.610583 -39.230 -82.1792
9152.343005 -41.284 -78.1621
9153.075427 -38.493 -90.3872
9153.807849 -39.390 -94.7483
9154.540270 -40.160 -84.6772
9155.272692 -40.877 -90.7922
9156.005114 -44.505 -115.1743
9156.737536 -43.149 -110.4597
9157.469958 -48.902 -167.2449
9158.202379 -42.359 -156.9900
9158.934801 -44.325 -170.5842
9159.667223 -44.406 -153.8337
9160.399645 -46.388 -176.1904
9161.132067 -49.114 152.8091
9161.864488 -47.929 91.7869
9162.596910 -46.803 142.9358
9163.329332 -45.113 110.0229
9164.061754 -45.846 117.2756
9164.794176 -43.938 80.1536
9165.526598 -45.283 69.4500
9166.259019 -42.221 49.1016
9166.991441 -42.669 40.5259
9167.723863 -42.880 55.4932
9168.456285 -41.484 60.2886
9169.188707 -39.622 30.5342
9169.921128 -39.528 23.7251
9170.653550 -39.048 6.2976
9171.385972 -38.065 11.7947
9172.118394 -38.670 -1.6787
9172.850816 -41.103 2.7156
9173.583238 -38.050 -0.5435
9174.315659 -40.095 -17.6812
9175.048081 -38.561 -9.6270
9175.780503 -43.213 -26.5203
9176.512925 -41.565 -33.5518
9177.245347 -38.907 -31.4153
9177.977768 -39.521 -45.5071
9178.710190 -40.432 -59.7251
9179.442612 -38.625 -42.8057
9180.175034 -46.482 -49.5322
9180.907456 -39.579 -43.0779
9181.639877 -45.845 -69.4709
9182.372299 -42.936 -69.8560
9183.104721 -42.991 -79.2639
9183.837143 -41.486 -69.6755
9184.569565 -49.201 -77.3789
9185.301987 -44.489 -54.2307
9186.034408 -91.324 -147.3357
9186.766830 -46.700 -138.7131
9187.499252 -53.035 -65.3052
9188.231674 -48.270 -53.6433
9188.964096 -53.741 -9.3130
9189.696517 -46.212 -56.5117
9190.428939 -50.239 -9.1433
9191.161361 -50.102 -29.2092
9191.893783 -49.717 -12.7664
9192.626205 -47.248 -2.2144
9193.358627 -49.920 -32.4546
9194.091048 -41.808 -25.4824
9194.823470 -44.370 -7.1655
9195.555892 -44.200 -44.8594
9196.288314 -44.940 -42.5137
9197.020736 -41.839 -43.1597
9197.753157 -42.077 -19.5488
9198.485579 -43.837 -59.3923
9199.218001 -46.848 -34.5669
9199.950423 -45.859 -43.6868
9200.682845 -43.820 -73.0315
9201.415267 -42.779 -63.2405
9202.147688 -48.236 -69.3350
9202.880110 -44.345 -74.0938
9203.612532 -47.127 -70.0757
9204.344954 -46.422 -65.0037
9205.077376 -48.397 -75.4038
9205.809797 -51.647 -90.1221
9206.542219 -55.114 160.6245
9207.274641 -55.991 110.7251
9208.007063 -61.703 -36.5930
9208.739485 -56.797 -151.6348
9209.471906 -48.284 66.3467
9210.204328 -54.131 70.0317
9210.936750 -45.647 69.7976
9211.669172 -44.161 67.7793
9212.401594 -44.263 63.0388
9213.134016 -49.579 62.2756
9213.866437 -42.046 36.4133
9214.598859 -40.760 38.2817
9215.331281 -40.070 33.3555
9216.063703 -39.697 19.2791
9216.796125 -43.335 18.0015
9217.528546 -42.375 14.9722
9218.260968 -39.130 8.9490
9218.993390 -40.717 20.3091
9219.725812 -38.541 5.1914
9220.458234 -41.078 -2.8516
9221.190656 -38.655 10.8892
9221.923077 -41.772 -28.1616
9222.655499 -39.470 -11.9580
9223.387921 -40.504 -19.1240
9224.120343 -42.011 -37.1025
9224.852765 -41.373 -20.5562
9225.585186 -40.025 -25.0151
9226.317608 -40.219 -28.4709
9227.050030 -39.803 -28.7844
9227.782452 -42.209 -56.1736
9228.514874 -43.843 -31.5325
9229.247295 -46.834 -29.5310
9229.979717 -43.085 -35.7078
9230.712139 -45.822 -27.7620
9231.444561 -43.930 -39.2024
9232.176983 -44.886 -41.6414
9232.909405 -41.788 -3.0791
9233.641826 -48.542 -13.1003
9234.374248 -41.335 -6.7988
9235.106670 -41.675 -0.0310
9235.839092 -41.515 7.2949
9236.571514 -44.382 -34.9915
9237.303935 -39.496 -16.5063
9238.036357 -41.435 -3.3147
9238.768779 -38.114 -17.5505
9239.501201 -39.026 -23.4832
9240.233623 -40.301 -36.8394
9240.966045 -39.451 -40.0742
9241.698466 -39.042 -39.0806
9242.430888 -41.844 -26.7068
9243.163310 -40.066 -44.6948
9243.895732 -40.433 -60.0146
9244.628154 -39.373 -53.1418
9245.360575 -42.507 -59.5295
9246.092997 -39.743 -69.6733
9246.825419 -42.767 -61.9329
9247.557841 -39.139 -84.9639
9248.290263 -43.345 -95.7261
9249.022685 -37.952 -97.2483
9249.755106 -41.342 -93.2192
9250.487528 -42.338 -93.6123
9251.219950 -42.785 -98.2671
9251.952372 -45.169 -109.3687
9252.684794 -46.104 -140.5691
9253.417215 -46.062 -134.8301
9254.149637 -47.028 -131.7932
9254.882059 -47.737 -146.0178
9255.614481 -47.092 -169.8916
9256.346903 -53.736 -107.4875
9257.079324 -55.252 131.8555
9257.811746 -62.325 138.3943
9258.544168 -53.223 126.8315
9259.276590 -61.296 175.6731
9260.009012 -48.210 105.6289
9260.741434 -56.586 99.9084
9261.473855 -46.827 17.3430
9262.206277 -48.621 -1.2402
9262.938699 -48.424 54.7864
9263.671121 -45.962 72.9966
9264.403543 -47.556 33.9382
9265.135964 -52.797 32.8879
9265.868386 -45.412 24.7092
9266.600808 -45.993 8.0386
9267.333230 -44.913 25.9998
9268.065652 -44.524 15.4153
9268.798074 -42.732 17.9341
9269.530495 -43.692 1.4575
9270.262917 -43.599 -0.6753
9270.995339 -46.025 17.7666
9271.727761 -41.775 -0.8240
9272.460183 -45.643 -1.5491
9273.192604 -44.859 -19.2698
9273.925026 -42.891 -38.5947
9274.657448 -43.104 -21.6257
9275.389870 -41.747 -9.6672
9276.122292 -43.619 -24.7903
9276.854713 -45.006 -22.0674
9277.587135 -42.779 -17.8975
9278.319557 -44.479 -5.4316
9279.051979 -43.231 -3.4438
9279.784401 -42.753 -34.6841
9280.516823 -40.262 -10.4985
9281.249244 -46.415 -18.4485
9281.981666 -41.839 -7.4812
9282.714088 -43.784 -6.5767
9283.446510 -42.304 -4.8079
9284.178932 -44.797 -24.8032
9284.911353 -42.816 -19.9426
9285.643775 -39.968 -39.5232
9286.376197 -43.689 -34.7883
9287.108619 -41.886 -20.3774
9287.841041 -43.991 -33.9717
9288.573463 -42.900 -24.9006
9289.305884 -41.188 -29.8923
9290.038306 -41.890 -13.5828
9290.770728 -41.121 -26.5957
9291.503150 -41.180 -51.8848
9292.235572 -38.417 -49.9370
9292.967993 -39.916 -51.7566
9293.700415 -38.906 -47.6768
9294.432837 -41.847 -43.7439
9295.165259 -38.438 -47.9832
9295.897681 -41.188 -63.0093
9296.630103 -38.909 -74.3416
9297.362524 -39.281 -69.2180
9298.094946 -39.318 -92.2173
9298.827368 -40.598 -73.5930
9299.559790 -41.012 -90.3313
9300.292212 -41.097 -84.1536
9301.024633 -39.355 -108.9404
9301.757055 -42.796 -96.6140
9302.489477 -40.402 -83.7827
9303.221899 -40.916 -115.9812
9303.954321 -40.715 -119.9390
9304.686742 -45.468 -112.5449
9305.419164 -42.880 -119.1887
9306.151586 -41.124 -152.4119
9306.884008 -48.117 -105.1187
9307.616430 -48.038 -154.6304
9308.348852 -40.035 -136.5078
9309.081273 -44.590 -144.8208
9309.813695 -45.805 175.6558
9310.546117 -50.022 -75.0425
9311.278539 -57.502 160.9087
9312.010961 -55.965 106.4409
9312.743382 -54.092 -69.6504
9313.475804 -56.736 -132.0381
9314.208226 -66.157 -4.4087
9314.940648 -49.712 -112.5884
9315.673070 -49.260 -61.3623
9316.405492 -58.039 -48.5283
9317.137913 -49.654 -59.8232
9317.870335 -50.244 -37.0864
9318.602757 -49.364 -80.8857
9319.335179 -44.189 -87.4033
9320.067601 -43.325 -98.2500
9320.800022 -42.683 -136.2163
9321.532444 -47.367 -113.9199
9322.264866 -50.070 -137.0439
9322.997288 -49.824 -124.1680
9323.729710 -44.470 -134.4766
9324.462132 -44.602 -128.8711
9325.194553 -45.247 -128.9531
9325.926975 -50.809 -131.8643
9326.659397 -43.807 -144.3896
9327.391819 -43.206 -137.3403
9328.124241 -49.020 124.6255
9328.856662 -48.161 124.0659
9329.589084 -50.986 134.1826
9330.321506 -46.720 119.6709
9331.053928 -45.148 111.7007
9331.786350 -45.169 117.8521
9332.518771 -44.386 113.8076
9333.251193 -45.002 107.4922
9333.983615 -44.234 60.7900
9334.716037 -42.389 47.9932
9335.448459 -41.123 57.2104
9336.180881 -44.317 31.7544
9336.913302 -41.955 32.2646
9337.645724 -45.103 37.4961
9338.378146 -44.499 48.6992
9339.110568 -43.137 8.4116
9339.842990 -46.356 25.5088
9340.575411 -44.763 12.8638
9341.307833 -44.012 1.2720
9342.040255 -40.829 -19.0425
9342.772677 -43.035 -2.2881
9343.505099 -47.716 11.0752
9344.237521 -46.123 -48.2632
9344.969942 -51.420 45.7661
9345.702364 -44.277 -29.4634
9346.434786 -43.876 -15.4546
9347.167208 -45.951 -46.7969
9347.899630 -49.101 -51.6221
9348.632051 -46.905 -63.7456
9349.364473 -53.078 -10.0708
9350.096895 -57.691 131.3765
9350.829317 -50.620 -127.7686
9351.561739 -52.283 -55.5703
9352.294160 -56.987 60.6970
9353.026582 -57.666 -5.3057
9353.759004 -46.153 26.6860
9354.491426 -51.572 32.6934
9355.223848 -49.328 87.4211
9355.956270 -53.144 4.0605
9356.688691 -48.155 16.5977
9357.421113 -50.520 -25.6523
9358.153535 -44.604 37.8335
9358.885957 -48.616 44.5571
9359.618379 -52.756 106.2610
9360.350800 -48.761 6.0171
9361.083222 -43.084 -24.3730
9361.815644 -51.647 57.3564
9362.548066 -49.353 104.8599
9363.280488 -50.713 23.7603
9364.012910 -46.943 40.2861
9364.745331 -44.550 17.5049
9365.477753 -43.803 32.1104
9366.210175 -44.423 1.8716
9366.942597 -46.303 67.9023
9367.675019 -49.483 68.1675
9368.407440 -44.775 30.0098
9369.139862 -48.078 15.4160
9369.872284 -46.327 -0.3643
9370.604706 -45.411 -5.1772
9371.337128 -44.082 14.7295
9372.069550 -43.002 18.8291
9372.801971 -48.630 21.9189
9373.534393 -40.248 13.9546
9374.266815 -49.639 -9.4927
9374.999237 -44.177 16.7607
9375.731659 -53.261 38.1436
9376.464080 -44.963 -9.8379
9377.196502 -43.734 -15.8486
9377.928924 -43.996 -11.3271
9378.661346 -44.121 19.8198
9379.393768 -48.261 -23.9570
9380.126189 -43.660 -34.1274
9380.858611 -46.783 -23.6035
9381.591033 -41.984 -28.0605
9382.323455 -46.709 -23.9795
9383.055877 -48.038 -15.3481
9383.788299 -42.644 -24.4321
9384.520720 -43.615 -7.4409
9385.253142 -42.988 -13.2812
9385.985564 -43.890 -6.1104
9386.717986 -46.076 -8.4155
9387.450408 -54.241 -19.0400
9388.182829 -47.969 -13.1113
9388.915251 -45.909 -29.2817
9389.647673 -44.325 -61.2490
9390.380095 -42.993 -20.0034
9391.112517 -47.606 -50.1240
9391.844939 -40.947 -26.7646
9392.577360 -42.583 -47.1611
9393.309782 -41.391 -60.8105
9394.042204 -40.781 -51.7173
9394.774626 -40.501 -63.6875
9395.507048 -40.589 -51.9961
9396.239469 -43.777 -67.0986
9396.971891 -41.766 -69.8486
9397.704313 -41.102 -62.2754
9398.436735 -41.080 -89.9277
9399.169157 -45.391 -118.1748
9399.901578 -42.554 -78.5518
9400.634000 -41.779 -109.6450
9401.366422 -39.796 -126.6880
9402.098844 -44.841 -95.3315
9402.831266 -49.678 -124.3262
9403.563688 -39.229 -120.3560
9404.296109 -38.726 -145.5483
9405.028531 -37.980 -150.5977
9405.760953 -41.355 -171.7920
9406.493375 -41.307 -171.6079
9407.225797 -43.260 169.9136
9407.958218 -44.283 167.1128
9408.690640 -40.596 151.0518
9409.423062 -41.660 139.9380
9410.155484 -41.198 124.4502
9410.887906 -40.666 143.3521
9411.620328 -44.174 108.2573
9412.352749 -41.653 119.7769
9413.085171 -41.853 108.6621
9413.817593 -42.266 90.5874
9414.550015 -43.801 102.1719
9415.282437 -43.447 97.8340
9416.014858 -48.010 75.4321
9416.747280 -44.877 74.1489
9417.479702 -48.203 88.5684
9418.212124 -43.386 91.6318
9418.944546 -47.012 54.2197
9419.676968 -47.544 26.2861
9420.409389 -45.849 58.7114
9421.141811 -50.883 3.0518
9421.874233 -47.461 2.8457
9422.606655 -52.939 -6.4526
9423.339077 -46.659 38.3086
9424.071498 -51.090 7.6362
9424.803920 -49.762 65.0464
9425.536342 -54.311 -17.8120
9426.268764 -55.656 27.3633
9427.001186 -54.907 107.3745
9427.733607 -48.952 141.1797
9428.466029 -50.272 155.3975
9429.198451 -49.944 69.4990
9429.930873 -50.052 79.1738
9430.663295 -47.510 90.8877
9431.395717 -50.820 100.2891
9432.128138 -47.268 59.1753
9432.860560 -44.736 98.7446
9433.592982 -42.943 77.0200
9434.325404 -48.994 74.7563
9435.057826 -45.150 61.1719
9435.790247 -43.387 53.0645
9436.522669 -40.761 64.0771
9437.255091 -47.416 28.8374
9437.987513 -40.884 40.9731
9438.719935 -45.263 57.8291
9439.452357 -45.773 11.2549
9440.184778 -49.992 26.6250
9440.917200 -44.967 39.0581
9441.649622 -49.306 6.1011
9442.382044 -47.045 -3.6143
9443.114466 -46.429 -10.3613
9443.846887 -56.981 -20.6304
9444.579309 -50.032 -15.2129
9445.311731 -65.303 174.7705
9446.044153 -63.096 -87.2686
9446.776575 -51.421 -4.8550
9447.508996 -54.846 120.2446
9448.241418 -48.755 75.0522
9448.973840 -61.405 -149.1914
9449.706262 -44.730 110.9106
9450.438684 -46.037 137.0659
9451.171106 -44.895 99.0803
9451.903527 -46.318 119.0859
9452.635949 -44.617 80.3689
9453.368371 -44.125 65.5420
9454.100793 -44.724 79.4983
9454.833215 -45.653 95.3740
9455.565636 -41.276 74.9346
9456.298058 -43.391 71.2097
9457.030480 -42.701 55.1768
9457.762902 -41.350 58.3420
9458.495324 -42.042 41.1982
9459.227746 -39.519 46.8027
9459.960167 -39.935 42.4380
9460.692589 -40.859 25.5674
9461.425011 -41.478 22.0713
9462.157433 -41.801 16.6182
9462.889855 -42.925 33.5371
9463.622276 -41.173 1.1743
9464.354698 -42.005 11.9619
9465.087120 -43.789 20.9102
9465.819542 -41.524 -3.3887
9466.551964 -42.866 4.8730
9467.284386 -46.523 18.1973
9468.016807 -41.619 4.4336
9468.749229 -46.558 -5.5537
9469.481651 -45.114 -4.6021
9470.214073 -48.466 14.5879
9470.946495 -49.530 6.0977
9471.678916 -46.173 9.4399
9472.411338 -59.745 34.3115
9473.143760 -48.032 20.6543
9473.876182 -45.844 39.3301
9474.608604 -49.325 54.8008
9475.341025 -48.709 50.2524
9476.073447 -51.445 34.7158
9476.805869 -50.519 36.0034
9477.538291 -41.958 46.3220
9478.270713 -43.147 21.5771
9479.003135 -45.569 33.8320
9479.735556 -42.580 28.4702
9480.467978 -45.421 10.5942
9481.200400 -40.922 9.5244
9481.932822 -41.982 5.1807
9482.665244 -42.385 13.2451
9483.397665 -41.280 2.9893
9484.130087 -43.258 9.6357
9484.862509 -41.372 1.4570
9485.594931 -40.807 13.1270
9486.327353 -41.955 15.0684
9487.059775 -42.586 2.5088
9487.792196 -40.535 -6.2065
9488.524618 -41.762 -2.3149
9489.257040 -42.268 -23.2695
9489.989462 -43.981 -7.9971
9490.721884 -43.571 -28.1631
9491.454305 -40.440 -28.5332
9492.186727 -44.059 -20.1650
9492.919149 -43.942 -53.2148
9493.651571 -47.000 -44.5898
9494.383993 -43.688 -42.9766
9495.116414 -44.393 -32.6084
9495.848836 -57.245 -48.5010
9496.581258 -54.497 -77.0215
9497.313680 -46.573 1.2583
9498.046102 -50.988 -24.6357
9498.778524 -47.684 -33.6162
9499.510945 -46.834 -52.6553
9500.243367 -51.102 -12.9863
9500.975789 -52.724 39.6919
9501.708211 -47.813 40.0220
9502.440633 -48.230 26.8926
9503.173054 -45.081 6.4756
9503.905476 -46.440 4.9233
9504.637898 -44.423 3.0000
9505.370320 -45.222 12.7061
9506.102742 -41.924 -16.1709
9506.835164 -43.927 -7.5439
9507.567585 -42.238 9.2920
9508.300007 -43.752 2.5112
9509.032429 -45.356 -1.1870
9509.764851 -42.018 8.0708
9510.497273 -43.250 -1.3496
9511.229694 -40.893 -12.8838
9511.962116 -41.178 -5.6069
9512.694538 -42.805 -25.3984
9513.426960 -44.013 -17.3569
9514.159382 -44.629 -19.7671
9514.891804 -43.658 -27.1963
9515.624225 -44.132 -15.8604
9516.356647 -42.369 -1.2773
9517.089069 -42.013 -22.1709
9517.821491 -47.511 -31.8506
9518.553913 -43.596 -18.1846
9519.286334 -43.111 -11.8901
9520.018756 -44.718 -11.8740
9520.751178 -45.037 -9.6133
9521.483600 -47.884 -15.9292
9522.216022 -45.838 -34.0439
9522.948443 -44.453 -29.1641
9523.680865 -44.874 -7.0469
9524.413287 -47.756 -17.6377
9525.145709 -49.050 -49.3740
9525.878131 -49.160 -39.5938
9526.610553 -43.318 -12.4043
9527.342974 -44.490 -21.2852
9528.075396 -41.286 -39.3730
9528.807818 -41.922 -20.8584
9529.540240 -43.956 -30.7183
9530.272662 -49.045 -13.5400
9531.005083 -44.614 -21.0137
9531.737505 -48.125 -26.0278
9532.469927 -43.463 -52.1016
9533.202349 -40.682 -23.8076
9533.934771 -44.338 -36.8647
9534.667193 -41.756 -52.2549
9535.399614 -43.251 -47.0234
9536.132036 -45.003 -48.3213
9536.864458 -42.699 -42.6035
9537.596880 -45.724 -29.1304
9538.329302 -47.667 -73.0640
9539.061723 -41.788 -43.9736
9539.794145 -44.249 -56.2100
9540.526567 -46.441 -73.4131
9541.258989 -46.719 -30.1841
9541.991411 -46.395 -61.8154
9542.723832 -48.735 -45.0859
9543.456254 -46.673 -55.2666
9544.188676 -44.618 -48.2910
9544.921098 -45.117 -37.7783
9545.653520 -44.929 -46.2139
9546.385942 -47.459 -86.2993
9547.118363 -46.756 -61.5054
9547.850785 -44.909 -32.2500
9548.583207 -43.083 -62.6113
9549.315629 -42.406 -50.1934
9550.048051 -46.794 -74.5957
9550.780472 -51.702 -71.2310
9551.512894 -48.803 -57.5703
9552.245316 -46.119 -97.0332
9552.977738 -43.740 -118.0327
9553.710160 -51.860 -93.7271
9554.442582 -42.700 -66.3174
9555.175003 -46.312 -94.2588
9555.907425 -50.639 -90.2773
9556.639847 -44.073 -87.3145
9557.372269 -47.284 -72.2275
9558.104691 -44.714 -95.7246
9558.837112 -44.166 -85.6416
9559.569534 -52.629 -51.9814
9560.301956 -43.234 -113.0391
9561.034378 -44.822 -68.5566
9561.766800 -45.621 -110.9863
9562.499222 -50.466 -106.8706
9563.231643 -44.909 -104.0674
9563.964065 -46.047 -107.0142
9564.696487 -47.428 -100.5679
9565.428909 -48.457 -72.8115
9566.161331 -50.045 -113.3833
9566.893752 -47.249 -110.8491
9567.626174 -46.809 -112.1895
9568.358596 -50.485 -164.1187
9569.091018 -51.791 -125.4824
9569.823440 -47.395 -133.7461
9570.555861 -47.791 -87.8955
9571.288283 -51.210 -147.6475
9572.020705 -45.144 -155.8052
9572.753127 -54.190 -163.1685
9573.485549 -52.686 -129.4639
9574.217971 -50.512 167.2300
9574.950392 -43.282 -168.7168
9575.682814 -49.098 168.5254
9576.415236 -45.720 -171.5444
9577.147658 -48.211 160.8896
9577.880080 -44.516 167.5869
9578.612501 -44.587 168.7402
9579.344923 -44.986 158.7065
9580.077345 -46.716 176.5439
9580.809767 -47.706 134.8936
9581.542189 -46.274 149.6792
9582.274611 -46.168 137.1890
9583.007032 -47.191 95.1387
9583.739454 -50.631 86.0200
9584.471876 -47.148 94.1484
9585.204298 -42.474 88.9873
9585.936720 -49.361 76.6768
9586.669141 -43.013 71.6001
9587.401563 -44.656 34.7227
9588.133985 -45.955 51.8071
9588.866407 -45.621 28.4751
9589.598829 -47.505 11.0737
9590.331250 -44.049 -24.2446
9591.063672 -48.430 -19.4692
9591.796094 -45.446 -19.6577
9592.528516 -46.644 -27.9932
9593.260938 -43.501 -10.1294
9593.993360 -43.322 -47.2847
9594.725781 -42.553 -51.7529
9595.458203 -45.426 -85.8311
9596.190625 -43.497 -90.1270
9596.923047 -44.858 -122.1831
9597.655469 -45.259 -89.9985
9598.387890 -45.872 -120.6660
9599.120312 -46.991 -141.3540
9599.852734 -49.886 -155.4912
9600.585156 -48.641 -146.0918
9601.317578 -43.548 -159.1514
9602.050000 -45.910 -174.9346
9602.782421 -53.670 171.4102
9603.514843 -42.368 -178.1953
9604.247265 -45.300 163.9956
9604.979687 -45.092 146.6748
9605.712109 -44.102 163.2837
9606.444530 -48.361 124.7314
9607.176952 -44.233 103.9868
9607.909374 -44.223 135.6733
9608.641796 -48.708 90.0933
9609.374218 -43.568 84.0576
9610.106640 -43.475 78.5786
9610.839061 -43.753 71.3525
9611.571483 -41.956 46.5806
9612.303905 -41.558 41.6104
9613.036327 -45.756 36.8687
9613.768749 -44.826 45.9268
9614.501170 -47.291 15.6367
9615.233592 -44.356 -4.0054
9615.966014 -45.424 3.6084
9616.698436 -44.991 26.3340
9617.430858 -46.727 -60.0303
9618.163279 -43.112 -16.7339
9618.895701 -47.646 -35.2559
9619.628123 -47.327 -61.7661
9620.360545 -47.122 -89.3657
9621.092967 -45.165 -69.6421
9621.825389 -47.145 -75.0991
9622.557810 -47.773 -121.0376
9623.290232 -45.647 -112.2437
9624.022654 -46.068 -96.5205
9624.755076 -46.188 -135.2559
9625.487498 -45.630 -142.6836
9626.219919 -43.651 -161.0898
9626.952341 -47.242 178.4438
9627.684763 -45.596 162.4863
9628.417185 -41.866 168.7520
9629.149607 -43.016 155.8359
9629.882029 -45.072 153.5239
9630.614450 -46.746 148.6738
9631.346872 -42.389 149.1855
9632.079294 -45.764 123.8960
9632.811716 -44.186 130.5449
9633.544138 -43.289 111.2065
9634.276559 -41.902 116.1802
9635.008981 -45.523 122.2856
9635.741403 -44.746 99.2329
9636.473825 -43.691 93.5967
9637.206247 -45.104 106.0708
9637.938668 -47.059 142.6797
9638.671090 -47.990 99.1050
9639.403512 -44.295 91.1533
9640.135934 -45.772 59.4375
9640.868356 -45.291 98.5361
9641.600778 -50.613 100.2241
9642.333199 -47.181 95.5391
9643.065621 -51.453 79.6099
9643.798043 -51.014 88.8145
9644.530465 -52.496 78.6016
9645.262887 -49.283 86.6372
9645.995308 -56.580 41.3013
9646.727730 -48.545 87.4321
9647.460152 -51.040 109.3179
9648.192574 -45.781 113.0713
9648.924996 -49.090 77.2383
9649.657418 -46.904 135.8584
9650.389839 -54.704 55.7432
9651.122261 -45.358 92.7129
9651.854683 -44.768 91.7461
9652.587105 -47.150 129.5186
9653.319527 -44.363 117.5815
9654.051948 -46.494 97.2017
9654.784370 -43.386 102.7461
9655.516792 -46.041 95.1685
9656.249214 -45.523 98.7339
9656.981636 -43.577 73.6860
9657.714058 -44.926 73.9746
9658.446479 -43.050 78.0688
9659.178901 -49.494 82.0576
9659.911323 -43.800 98.0264
9660.643745 -46.273 63.1206
9661.376167 -44.651 70.8232
9662.108588 -47.592 56.2954
9662.841010 -43.448 74.6343
9663.573432 -43.162 67.1235
9664.305854 -44.817 104.7925
9665.038276 -43.194 75.7695
9665.770697 -42.831 63.9941
9666.503119 -49.196 100.0801
9667.235541 -42.064 85.6440
9667.967963 -44.259 79.5293
9668.700385 -40.874 49.0234
9669.432807 -41.559 76.8643
9670.165228 -42.868 80.9775
9670.897650 -42.863 64.1113
9671.630072 -41.951 56.8545
9672.362494 -40.097 64.7476
9673.094916 -41.096 68.9712
9673.827337 -39.466 50.3936
9674.559759 -42.546 37.3325
9675.292181 -41.179 67.1509
9676.024603 -40.090 35.0752
9676.757025 -40.879 61.6377
9677.489447 -38.024 67.0757
9678.221868 -40.775 58.5186
9678.954290 -40.026 50.6968
9679.686712 -40.401 30.7202
9680.419134 -40.076 15.5596
9681.151556 -40.902 33.5415
9681.883977 -39.572 30.7988
9682.616399 -42.462 11.2549
9683.348821 -39.774 17.1152
9684.081243 -40.879 31.1816
9684.813665 -40.201 22.6367
9685.546086 -40.581 37.6001
9686.278508 -40.858 21.9312
9687.010930 -42.467 -4.1846
9687.743352 -44.279 47.0645
9688.475774 -43.690 -8.0073
9689.208196 -40.060 17.1470
9689.940617 -44.707 9.6616
9690.673039 -38.338 17.4453
9691.405461 -42.541 1.8872
9692.137883 -40.064 -0.9946
9692.870305 -43.688 3.8682
9693.602726 -41.662 22.3999
9694.335148 -45.279 -6.9917
9695.067570 -39.590 37.3784
9695.799992 -43.521 -0.1084
9696.532414 -42.770 61.0889
9697.264836 -41.177 20.5264
9697.997257 -45.833 24.3867
9698.729679 -43.376 15.4951
9699.462101 -42.350 40.2422
9700.194523 -39.320 17.6958
9700.926945 -39.585 13.1367
9701.659366 -39.359 38.3457
9702.391788 -40.766 -2.2212
9703.124210 -42.273 -2.0273
9703.856632 -47.064 -31.4712
9704.589054 -42.633 -18.0015
9705.321476 -41.612 -14.7632
9706.053897 -48.176 -9.5020
9706.786319 -42.053 -17.6006
9707.518741 -39.886 -9.2695
9708.251163 -43.503 -29.1860
9708.983585 -46.698 -11.1221
9709.716006 -44.163 -18.6582
9710.448428 -42.548 -33.4312
9711.180850 -40.274 -33.3770
9711.913272 -48.013 -24.7446
9712.645694 -40.520 -21.2793
9713.378115 -49.525 -56.0181
9714.110537 -42.279 -59.7700
9714.842959 -45.485 -31.0615
9715.575381 -42.046 -63.8325
9716.307803 -39.391 -59.5137
9717.040225 -46.501 -79.3276
9717.772646 -44.743 -52.2803
9718.505068 -52.612 -177.9819
9719.237490 -41.196 -52.2866
9719.969912 -38.668 -54.1826
9720.702334 -40.837 -66.2139
9721.434755 -44.109 -101.8823
9722.167177 -42.143 -120.7354
9722.899599 -47.687 -69.3833
9723.632021 -41.962 -86.5332
9724.364443 -41.962 -53.5713
9725.096865 -50.378 -150.9771
9725.829286 -44.061 -87.1450
9726.561708 -46.043 -100.5649
9727.294130 -53.365 -99.4165
9728.026552 -45.701 -144.0234
9728.758974 -48.888 -158.2222
9729.491395 -48.482 147.9331
9730.223817 -44.453 175.1143
9730.956239 -42.346 166.7632
9731.688661 -45.678 150.1450
9732.421083 -49.310 141.1553
9733.153504 -45.758 139.8032
9733.885926 -43.272 126.1274
9734.618348 -45.956 125.5015
9735.350770 -42.446 86.0068
9736.083192 -45.377 76.2178
9736.815614 -46.990 128.8042
9737.548035 -49.000 59.4492
9738.280457 -44.694 44.9482
9739.012879 -40.731 58.7788
9739.745301 -41.785 66.6558
9740.477723 -46.017 35.4102
9741.210144 -42.951 45.4316
9741.942566 -43.068 21.5493
9742.674988 -43.217 -2.0420
9743.407410 -41.430 -13.1143
9744.139832 -39.510 16.6055
9744.872254 -43.760 8.9229
9745.604675 -42.539 1.4971
9746.337097 -40.897 0.6851
9747.069519 -45.318 -39.1475
9747.801941 -40.595 -12.1406
9748.534363 -39.409 -49.0156
9749.266784 -47.479 -79.3911
9749.999206 -43.405 -28.1216
9750.731628 -41.122 -24.0186
9751.464050 -42.293 -65.9355
9752.196472 -43.697 -17.8350
9752.928894 -43.441 -29.1807
9753.661315 -44.698 -21.0083
9754.393737 -57.046 -65.1094
9755.126159 -55.840 -81.9409
9755.858581 -46.478 -39.4922
9756.591003 -42.260 -53.3486
9757.323424 -47.990 -55.5093
9758.055846 -43.399 -8.1353
9758.788268 -45.061 -17.4648
9759.520690 -51.959 32.0913
9760.253112 -45.559 30.2178
9760.985533 -48.453 20.5444
9761.717955 -55.653 -12.1899
9762.450377 -60.629 15.3813
9763.182799 -47.830 -10.4102
9763.915221 -44.960 -18.3223
9764.647643 -46.301 -10.1543
9765.380064 -44.391 -27.1851
9766.112486 -46.304 -27.3140
9766.844908 -49.948 28.4067
9767.577330 -44.889 -52.0146
9768.309752 -40.593 1.0547
9769.042173 -44.989 -110.6484
9769.774595 -69.050 -130.5640
9770.507017 -43.969 -58.0454
9771.239439 -42.923 -102.9478
9771.971861 -47.452 -33.8511
9772.704283 -51.153 -133.6494
9773.436704 -49.077 -175.5723
9774.169126 -44.787 -80.0449
9774.901548 -46.425 -14.9902
9775.633970 -42.900 -144.1050
9776.366392 -49.237 -161.8071
9777.098813 -50.290 -148.2998
9777.831235 -52.617 -34.0293
9778.563657 -51.717 172.2256
9779.296079 -50.175 110.9800
9780.028501 -53.949 -111.3716
9780.760922 -47.428 61.1021
9781.493344 -46.729 24.7915
9782.225766 -49.226 -21.2559
9782.958188 -47.110 45.0952
9783.690610 -42.787 57.6299
9784.423032 -40.192 31.3901
9785.155453 -44.752 32.2856
9785.887875 -44.159 25.6699
9786.620297 -50.504 -23.4185
9787.352719 -56.801 -5.7793
9788.085141 -41.030 -9.4795
9788.817562 -42.749 -31.9756
9789.549984 -43.097 -46.8516
9790.282406 -41.378 -43.3350
9791.014828 -41.350 -13.0635
9791.747250 -50.986 -70.4380
9792.479672 -46.853 -80.5791
9793.212093 -44.354 -112.3247
9793.944515 -44.735 -94.7363
9794.676937 -43.374 -141.1328
9795.409359 -50.601 -92.6958
9796.141781 -59.570 -30.2739
9796.874202 -47.496 164.6079
9797.606624 -53.224 153.7236
9798.339046 -47.162 -162.2026
9799.071468 -47.911 133.3149
9799.803890 -44.625 111.8774
9800.536312 -50.521 152.2754
9801.268733 -46.934 121.1484
9802.001155 -44.319 93.4751
9802.733577 -39.682 82.5244
9803.465999 -55.216 58.4385
9804.198421 -44.301 90.6592
9804.930842 -42.152 84.6055
9805.663264 -39.818 63.4194
9806.395686 -40.649 39.0142
9807.128108 -41.097 51.8691
9807.860530 -38.330 34.9683
9808.592951 -39.093 38.3203
9809.325373 -38.663 35.8306
9810.057795 -40.146 43.6748
9810.790217 -38.240 28.2495
9811.522639 -37.460 14.6797
9812.255061 -38.986 9.5693
9812.987482 -37.241 -1.3276
9813.719904 -40.795 2.0474
9814.452326 -38.858 -26.5430
9815.184748 -37.741 -13.6606
9815.917170 -42.066 -25.3794
9816.649591 -40.277 -25.6914
9817.382013 -40.579 -35.5596
9818.114435 -41.899 -45.6133
9818.846857 -41.707 -40.9053
9819.579279 -42.413 -37.5684
9820.311701 -45.281 -59.6548
9821.044122 -41.473 -60.2598
9821.776544 -44.503 -100.7451
9822.508966 -50.363 -26.9556
9823.241388 -46.795 -66.0996
9823.973810 -46.136 -123.4497
9824.706231 -46.874 -103.6621
9825.438653 -49.218 -75.1353
9826.171075 -51.038 42.2012
9826.903497 -47.788 -109.1782
9827.635919 -52.991 87.4424
9828.368340 -48.329 28.2979
9829.100762 -58.052 86.2329
9829.833184 -47.700 32.7715
9830.565606 -47.594 13.6372
9831.298028 -44.016 -25.3940
9832.030450 -43.990 18.4497
9832.762871 -47.581 0.1016
9833.495293 -48.147 3.1758
9834.227715 -41.666 12.8301
9834.960137 -43.673 -10.0737
9835.692559 -45.355 32.0449
9836.424980 -47.690 -31.4570
9837.157402 -41.796 -15.4297
9837.889824 -41.628 -43.3809
9838.622246 -45.975 -53.9614
9839.354668 -47.281 -58.6548
9840.087090 -41.378 -73.1812
9840.819511 -45.465 -53.1392
9841.551933 -45.363 -48.3281
9842.284355 -45.891 -62.0435
9843.016777 -39.664 -85.8569
9843.749199 -43.623 -89.2896
9844.481620 -45.453 -121.6382
9845.214042 -51.437 -132.7378
9845.946464 -43.007 -131.1421
9846.678886 -44.649 -119.8311
9847.411308 -44.032 -131.4219
9848.143730 -49.653 -144.7603
9848.876151 -47.381 -121.9702
9849.608573 -47.206 -128.3438
9850.340995 -44.244 -179.1914
9851.073417 -47.270 141.1001
9851.805839 -59.691 128.5732
9852.538260 -51.094 124.0327
9853.270682 -48.691 145.4463
9854.003104 -53.119 172.2134
9854.735526 -52.282 -162.6909
9855.467948 -53.859 49.6582
9856.200369 -54.206 131.7178
9856.932791 -47.071 25.5088
9857.665213 -51.448 -12.6274
9858.397635 -53.090 -8.9917
9859.130057 -52.305 -12.2896
9859.862479 -50.389 -37.9888
9860.594900 -49.293 -87.1182
9861.327322 -51.638 -95.8618
9862.059744 -53.567 170.2524
9862.792166 -61.846 169.1172
9863.524588 -48.485 -143.9922
9864.257009 -55.524 172.0103
9864.989431 -53.283 -171.1997
9865.721853 -52.532 -175.8804
9866.454275 -45.206 -175.0400
9867.186697 -48.416 168.0063
9867.919119 -42.884 136.8032
9868.651540 -40.592 138.3853
9869.383962 -45.959 143.6289
9870.116384 -42.115 133.4033
9870.848806 -40.515 112.7803
9871.581228 -42.933 120.8955
9872.313649 -44.394 108.7778
9873.046071 -40.794 106.6250
9873.778493 -40.043 92.7334
9874.510915 -39.003 80.1108
9875.243337 -39.820 81.7119
9875.975758 -38.490 67.4487
9876.708180 -39.063 61.3896
9877.440602 -40.376 62.7178
9878.173024 -41.892 56.4268
9878.905446 -42.078 32.2549
9879.637868 -38.459 35.5103
9880.370289 -38.456 29.5498
9881.102711 -39.633 4.0659
9881.835133 -39.380 20.1138
9882.567555 -37.905 0.6313
9883.299977 -38.410 -12.1812
9884.032398 -41.341 -30.6738
9884.764820 -42.807 -26.8975
9885.497242 -41.650 -33.8203
9886.229664 -41.278 -31.0869
9886.962086 -44.320 -67.6455
9887.694508 -41.866 -54.5708
9888.426929 -43.676 -64.1641
9889.159351 -42.065 -93.8408
9889.891773 -46.219 -138.2520
9890.624195 -43.610 -103.7783
9891.356617 -46.632 -141.6963
9892.089038 -47.678 -138.6562
9892.821460 -42.659 -174.3003
9893.553882 -44.278 172.1772
9894.286304 -46.136 164.3013
9895.018726 -46.087 168.4111
9895.751148 -41.137 147.9404
9896.483569 -39.841 138.6997
9897.215991 -40.843 114.5996
9897.948413 -43.081 64.5952
9898.680835 -40.416 103.0820
9899.413257 -42.214 87.8042
9900.145678 -42.343 89.0063
9900.878100 -43.337 106.4141
9901.610522 -40.925 82.1406
9902.342944 -41.919 75.6201
9903.075366 -42.354 70.7856
9903.807787 -46.685 43.3208
9904.540209 -45.894 43.6987
9905.272631 -44.770 31.0732
9906.005053 -45.713 0.5542
9906.737475 -50.537 21.4404
9907.469897 -55.849 -30.9482
9908.202318 -47.289 -0.8882
9908.934740 -50.489 57.9160
9909.667162 -46.650 -48.2144
9910.399584 -47.555 21.5952
9911.132006 -55.465 -2.2271
9911.864427 -47.256 -96.5112
9912.596849 -59.261 99.3350
9913.329271 -55.534 -135.0156
9914.061693 -50.658 90.7588
9914.794115 -49.917 59.9551
9915.526537 -47.654 41.1177
9916.258958 -43.717 110.6777
9916.991380 -49.293 93.9009
9917.723802 -45.604 52.6255
9918.456224 -43.664 70.0566
9919.188646 -41.799 85.5630
9919.921067 -41.441 70.3550
9920.653489 -38.929 49.1206
9921.385911 -43.042 35.7876
9922.118333 -41.994 55.3677
9922.850755 -40.839 38.7964
9923.583176 -40.846 38.7407
9924.315598 -40.644 41.9819
9925.048020 -40.861 33.9072
9925.780442 -43.161 24.3433
9926.512864 -40.097 14.8257
9927.245286 -38.920 9.9731
9927.977707 -44.544 10.7192
9928.710129 -39.976 1.7725
9929.442551 -40.169 -27.1621
9930.174973 -44.735 -22.6807
9930.907395 -43.056 -13.0903
9931.639816 -43.194 -7.1133
9932.372238 -39.778 -25.4204
9933.104660 -42.046 -44.2017
9933.837082 -43.492 -18.0259
9934.569504 -44.893 -56.9585
9935.301926 -45.341 -53.1782
9936.034347 -51.152 -36.3584
9936.766769 -54.871 32.2876
9937.499191 -55.242 -28.3433
9938.231613 -54.777 -5.6328
9938.964035 -55.767 -71.8711
9939.696456 -51.891 79.7725
9940.428878 -51.789 -2.3096
9941.161300 -48.800 27.6431
9941.893722 -53.690 68.8291
9942.626144 -45.486 45.0713
9943.358566 -46.626 47.2764
9944.090987 -46.447 0.9976
9944.823409 -53.036 39.4736
9945.555831 -47.020 28.0220
9946.288253 -43.888 25.3052
9947.020675 -44.181 37.5327
9947.753096 -46.290 22.9844
9948.485518 -45.790 24.4526
9949.217940 -44.444 19.5352
9949.950362 -45.902 12.0781
9950.682784 -50.222 12.8457
9951.415205 -44.567 48.6055
9952.147627 -46.964 16.8208
9952.880049 -44.927 -4.1895
9953.612471 -47.200 19.9058
9954.344893 -42.038 16.9028
9955.077315 -47.024 42.6587
9955.809736 -44.785 -9.2295
9956.542158 -43.193 -50.9668
9957.274580 -41.949 -20.2993
9958.007002 -46.408 -42.1274
9958.739424 -49.745 -8.4937
9959.471845 -47.958 -9.9185
9960.204267 -46.116 -50.6919
9960.936689 -46.296 -36.8481
9961.669111 -44.200 -51.0171
9962.401533 -41.499 -59.5967
9963.133955 -50.356 -68.5161
9963.866376 -44.228 -54.2451
9964.598798 -44.310 -69.3950
9965.331220 -54.051 -108.8696
9966.063642 -53.151 -40.7002
9966.796064 -47.302 -85.7217
9967.528485 -51.209 -128.7817
9968.260907 -45.788 -133.8950
9968.993329 -49.534 -136.8618
9969.725751 -45.674 -133.7510
9970.458173 -44.804 175.1567
9971.190594 -51.206 104.5474
9971.923016 -48.003 131.0454
9972.655438 -46.117 165.5645
9973.387860 -45.697 138.8145
9974.120282 -45.919 117.7715
9974.852704 -42.620 96.7808
9975.585125 -47.865 111.3696
9976.317547 -46.627 118.2363
9977.049969 -41.449 90.1362
9977.782391 -40.937 52.5098
9978.514813 -40.490 71.1714
9979.247234 -43.305 76.7227
9979.979656 -42.172 65.2476
9980.712078 -42.986 46.8208
9981.444500 -46.761 37.6201
9982.176922 -43.814 33.2798
9982.909344 -39.970 28.1216
9983.641765 -40.118 10.0254
9984.374187 -43.080 13.1079
9985.106609 -44.542 4.8882
9985.839031 -41.661 16.3960
9986.571453 -43.222 -13.0562
9987.303874 -45.136 -21.4961
9988.036296 -41.587 -35.1421
9988.768718 -50.932 -11.5752
9989.501140 -42.012 -21.3628
9990.233562 -44.682 -34.2139
9990.965984 -45.006 -62.7354
9991.698405 -62.128 -11.6919
9992.430827 -51.332 -63.5205
9993.163249 -55.956 158.8359
9993.895671 -70.272 -138.3081
9994.628093 -48.784 70.5073
9995.360514 -50.556 128.9800
9996.092936 -50.757 -176.3765
9996.825358 -54.127 65.1196
9997.557780 -50.512 86.0815
9998.290202 -45.710 58.9907
9999.022623 -47.542 59.3252
9999.755045 -50.775 124.9668
10000.487467 -42.820 56.1196
10001.219889 -40.334 28.4468
10001.952311 -41.672 51.1479
10002.684733 -41.895 26.4956
10003.417154 -40.587 37.3940
10004.149576 -42.891 7.8306
10004.881998 -43.784 0.0249
10005.614420 -40.744 22.0132
10006.346842 -39.773 -4.7207
10007.079263 -39.835 1.0063
10007.811685 -42.225 -12.0381
10008.544107 -44.557 -18.9370
10009.276529 -44.639 -35.9844
10010.008951 -40.619 -53.9521
10010.741373 -42.396 -52.6216
10011.473794 -44.351 -84.1235
10012.206216 -44.401 -71.8623
10012.938638 -40.045 -76.2905
10013.671060 -43.541 -101.6353
10014.403482 -45.778 -118.4380
10015.135903 -45.631 -123.3574
10015.868325 -44.626 -118.5229
10016.600747 -46.215 -151.9668
10017.333169 -49.313 179.3477
10018.065591 -49.546 -123.8081
10018.798012 -49.217 -154.8003
10019.530434 -58.024 139.5776
10020.262856 -45.894 107.7300
10020.995278 -48.611 103.4653
10021.727700 -54.229 57.5879
10022.460122 -46.924 96.0054
10023.192543 -44.592 96.1089
10023.924965 -46.757 45.4399
10024.657387 -55.573 21.0254
10025.389809 -47.366 27.8979
10026.122231 -61.225 55.2686
10026.854652 -48.949 15.6191
10027.587074 -51.582 31.0991
10028.319496 -46.610 36.6445
10029.051918 -47.934 -0.3960
10029.784340 -45.724 -44.2085
10030.516762 -43.111 -47.0938
10031.249183 -46.173 -60.3589
10031.981605 -45.738 -64.1577
10032.714027 -43.700 -86.3442
10033.446449 -43.009 -75.7466
10034.178871 -44.876 -99.1484
10034.911292 -44.074 -149.6191
10035.643714 -42.802 -102.5449
10036.376136 -39.322 -146.2383
10037.108558 -40.583 -141.6670
10037.840980 -41.530 -157.8086
10038.573402 -42.775 -164.4941
10039.305823 -39.068 -177.3184
10040.038245 -39.815 166.4648
10040.770667 -39.720 155.2305
10041.503089 -41.687 157.9277
10042.235511 -38.632 142.0674
10042.967932 -38.824 135.9980
10043.700354 -36.076 122.3408
10044.432776 -36.748 117.9189
10045.165198 -38.167 106.0430
10045.897620 -36.454 99.5508
10046.630041 -34.520 100.5850
10047.362463 -36.859 92.4590
10048.094885 -41.022 88.5000
10048.827307 -38.001 75.0166
10049.559729 -35.563 79.6670
10050.292151 -36.195 66.0977
10051.024572 -36.391 69.4082
10051.756994 -36.073 53.3984
10052.489416 -35.732 43.2949
10053.221838 -37.214 45.9941
10053.954260 -37.374 36.3027
10054.686681 -37.648 32.7412
10055.419103 -35.650 34.0107
10056.151525 -37.548 25.6758
10056.883947 -38.903 18.8242
10057.616369 -43.128 30.0645
10058.348791 -39.082 17.4795
10059.081212 -39.678 -1.9443
10059.813634 -45.799 -29.6582
10060.546056 -44.449 -8.2109
10061.278478 -41.211 -14.0234
10062.010900 -41.959 -10.2598
10062.743321 -50.454 -38.6289
10063.475743 -45.246 12.5225
10064.208165 -44.361 4.7197
10064.940587 -50.563 -80.1260
10065.673009 -53.015 -33.1689
10066.405430 -49.708 -20.6699
10067.137852 -47.416 -8.2324
10067.870274 -60.731 -20.4082
10068.602696 -54.198 90.1465
10069.335118 -47.846 58.9609
10070.067540 -55.414 104.2480
10070.799961 -47.860 -2.6660
10071.532383 -46.378 103.2520
10072.264805 -48.620 104.6836
10072.997227 -58.719 61.8838
10073.729649 -51.457 33.4443
10074.462070 -46.412 69.2295
10075.194492 -43.387 59.9512
10075.926914 -42.669 18.5732
10076.659336 -44.770 100.6543
10077.391758 -45.546 52.4775
10078.124180 -43.734 46.1709
10078.856601 -48.652 39.7051
10079.589023 -45.459 54.0322
10080.321445 -63.798 52.7666
10081.053867 -44.477 30.6221
10081.786289 -40.923 38.4580
10082.518710 -43.965 25.5498
10083.251132 -43.438 55.3389
10083.983554 -45.189 74.8945
10084.715976 -44.733 28.8438
10085.448398 -51.754 21.2559
10086.180820 -46.143 65.9727
10086.913241 -42.668 17.9180
10087.645663 -44.722 -21.7529
10088.378085 -47.198 9.3398
10089.110507 -50.008 -3.7744
10089.842929 -44.128 35.7178
10090.575350 -46.659 8.7744
10091.307772 -46.682 24.9658
10092.040194 -48.682 50.2871
10092.772616 -46.310 78.1611
10093.505038 -38.054 0.9941
10094.237459 -55.235 28.4297
10094.969881 -47.264 120.3516
10095.702303 -53.148 23.4668
10096.434725 -45.562 47.4707
10097.167147 -53.738 26.9199
10097.899569 -42.673 31.8018
10098.631990 -44.053 45.4326
10099.364412 -52.773 -35.1650
10100.096834 -49.754 4.2256
10100.829256 -49.218 56.1729
10101.561678 -48.763 122.1855
10102.294099 -55.720 37.9785
10103.026521 -48.140 40.9502
10103.758943 -46.724 95.2451
10104.491365 -45.947 96.9512
10105.223787 -42.926 59.6016
10105.956209 -45.127 85.6934
10106.688630 -43.279 87.5010
10107.421052 -42.689 46.1045
10108.153474 -41.602 67.5830
10108.885896 -40.733 50.5928
10109.618318 -43.304 41.3135
10110.350739 -39.284 40.4697
10111.083161 -41.456 50.2510
10111.815583 -41.889 63.5127
10112.548005 -38.266 49.2422
10113.280427 -40.294 61.9102
10114.012848 -39.647 13.9492
10114.745270 -40.072 26.0537
10115.477692 -37.503 51.0098
10116.210114 -40.996 22.6973
10116.942536 -39.804 3.6396
10117.674958 -42.482 12.3545
10118.407379 -40.933 26.2666
10119.139801 -46.291 18.5166
10119.872223 -37.904 15.4053
10120.604645 -41.838 2.5723
10121.337067 -44.613 -8.6748
10122.069488 -42.695 -6.1357
10122.801910 -42.866 -9.4521
10123.534332 -43.992 -28.9629
10124.266754 -47.558 33.2266
10124.999176 -57.292 -0.2588
10125.731598 -56.538 143.0771
10126.464019 -54.034 -3.5254
10127.196441 -50.395 108.9150
10127.928863 -54.215 138.2949
10128.661285 -54.795 101.4980
10129.393707 -53.657 89.6055
10130.126128 -43.495 79.3018
10130.858550 -44.826 75.8867
10131.590972 -45.494 95.2812
10132.323394 -42.716 96.8770
10133.055816 -42.867 82.7764
10133.788238 -45.559 107.5947
10134.520659 -41.104 75.9980
10135.253081 -42.930 93.7012
10135.985503 -40.861 57.1660
10136.717925 -41.724 54.8291
10137.450347 -42.177 45.9980
10138.182768 -42.819 66.8516
10138.915190 -40.624 45.9141
10139.647612 -43.421 34.5303
10140.380034 -43.100 -5.7568
10141.112456 -40.996 16.3076
10141.844877 -37.077 50.1875
10142.577299 -41.913 39.1855
10143.309721 -41.900 38.5879
10144.042143 -41.509 8.2383
10144.774565 -41.777 26.3008
10145.506987 -42.292 37.8154
10146.239408 -44.567 42.7627
10146.971830 -47.095 47.1797
10147.704252 -43.578 28.1348
10148.436674 -43.221 29.1055
10149.169096 -47.755 8.7568
10149.901517 -43.353 68.0859
10150.633939 -42.606 65.1260
10151.366361 -41.838 14.3711
10152.098783 -42.146 61.3203
10152.831205 -44.795 48.9688
10153.563627 -43.296 38.1846
10154.296048 -38.767 44.5303
10155.028470 -41.929 46.5186
10155.760892 -41.096 62.0146
10156.493314 -40.357 49.6885
10157.225736 -38.581 55.5625
10157.958157 -38.732 50.8584
10158.690579 -39.412 46.4756
10159.423001 -39.089 31.1816
10160.155423 -37.224 43.9443
10160.887845 -38.138 33.6309
10161.620266 -36.670 35.4297
10162.352688 -36.831 35.8809
10163.085110 -38.305 28.7695
10163.817532 -38.297 32.0723
10164.549954 -37.083 39.5400
10165.282376 -35.868 22.4463
10166.014797 -37.346 20.2393
10166.747219 -37.684 15.8477
10167.479641 -38.282 17.3516
10168.212063 -35.754 17.9238
10168.944485 -36.268 14.2314
10169.676906 -36.430 6.3750
10170.409328 -37.001 -3.5996
10171.141750 -36.353 12.1377
10171.874172 -38.775 7.9111
10172.606594 -39.738 -17.4902
10173.339016 -37.351 -16.5020
10174.071437 -37.314 -0.7793
10174.803859 -38.239 -14.1240
10175.536281 -37.241 -21.7080
10176.268703 -38.641 -15.7051
10177.001125 -36.335 -22.1045
10177.733546 -39.219 -22.2441
10178.465968 -38.903 -38.8223
10179.198390 -41.085 -17.5771
10179.930812 -37.211 -30.9863
10180.663234 -39.751 -23.2002
10181.395656 -38.203 -50.5127
10182.128077 -39.617 -39.5889
10182.860499 -40.060 -29.9814
10183.592921 -39.031 -51.0283
10184.325343 -38.126 -50.6904
10185.057765 -40.106 -46.1514
10185.790186 -42.601 -44.4590
10186.522608 -42.209 -46.4590
10187.255030 -41.082 -67.5693
10187.987452 -44.564 -86.2881
10188.719874 -38.972 -39.1475
10189.452295 -44.521 -74.6230
10190.184717 -41.419 -75.9746
10190.917139 -46.183 -75.1094
10191.649561 -44.926 -53.6562
10192.381983 -45.388 -50.4199
10193.114405 -52.186 -38.0889
10193.846826 -51.993 13.5029
10194.579248 -46.540 -22.2490
10195.311670 -52.494 -7.1699
10196.044092 -47.818 -57.6719
10196.776514 -51.389 3.6592
10197.508935 -49.154 -8.3691
10198.241357 -51.596 -20.7383
10198.973779 -46.325 -59.8936
10199.706201 -46.734 -33.0303
10200.438623 -45.241 -35.2549
10201.171045 -46.433 5.0088
10201.903466 -52.645 -41.0830
10202.635888 -48.555 -14.5166
10203.368310 -44.432 -27.1826
10204.100732 -42.170 -23.9814
10204.833154 -44.062 -20.2246
10205.565575 -42.963 -19.8320
10206.297997 -44.540 -39.1270
10207.030419 -43.531 -36.8789
10207.762841 -48.117 -77.6777
10208.495263 -43.094 -37.2812
10209.227684 -44.644 -44.7930
10209.960106 -46.260 -32.9268
10210.692528 -43.290 -63.1289
10211.424950 -43.136 -37.3008
10212.157372 -41.341 -46.1768
10212.889794 -43.353 -51.3262
10213.622215 -47.370 -104.1055
10214.354637 -45.863 -60.0205
10215.087059 -43.198 -57.3867
10215.819481 -45.578 -70.6621
10216.551903 -47.848 -122.8555
10217.284324 -58.754 -44.0889
10218.016746 -57.763 -41.0029
10218.749168 -57.001 -66.0010
10219.481590 -56.951 -177.1123
10220.214012 -50.744 -178.4131
10220.946434 -56.456 -140.7363
10221.678855 -55.089 -63.5850
10222.411277 -50.625 138.8027
10223.143699 -59.102 -143.5576
10223.876121 -52.553 -171.5576
10224.608543 -57.520 110.9492
10225.340964 -51.584 133.0771
10226.073386 -54.615 49.6113
10226.805808 -51.996 30.7246
10227.538230 -46.187 27.6318
10228.270652 -46.913 66.9033
10229.003074 -47.059 31.0361
10229.735495 -51.566 60.6309
10230.467917 -44.984 58.9160
10231.200339 -46.510 71.6367
10231.932761 -45.874 26.4004
10232.665183 -49.350 40.8076
10233.397604 -43.794 45.2988
10234.130026 -45.009 44.9863
10234.862448 -42.786 42.1738
10235.594870 -45.739 40.4863
10236.327292 -43.141 28.1602
10237.059713 -43.898 28.4043
10237.792135 -42.038 17.4775
10238.524557 -45.014 -6.2051
10239.256979 -39.690 -7.8691
10239.989401 -41.741 2.9990
10240.721823 -39.978 -13.4492
10241.454244 -42.039 -16.2754
10242.186666 -40.974 -3.1318
10242.919088 -42.883 -13.6846
10243.651510 -41.500 -16.1279
10244.383932 -40.970 -24.1152
10245.116353 -41.129 -28.2295
10245.848775 -44.834 -28.8096
10246.581197 -41.045 -33.9668
10247.313619 -44.592 -35.6133
10248.046041 -42.157 -44.1787
10248.778463 -43.426 -38.5742
10249.510884 -41.753 -43.3086
10250.243306 -44.007 -58.8418
10250.975728 -42.249 -71.9512
10251.708150 -45.647 -73.1270
10252.440572 -44.276 -91.0752
10253.172993 -45.034 -97.6885
10253.905415 -44.544 -93.1191
10254.637837 -54.288 -103.7158
10255.370259 -46.362 -123.8281
10256.102681 -52.068 -84.3477
10256.835102 -48.688 -98.2773
10257.567524 -51.032 -121.9307
10258.299946 -50.538 -103.0977
10259.032368 -43.852 -104.3926
10259.764790 -51.321 -39.1406
10260.497212 -49.553 86.2129
10261.229633 -50.639 -39.4219
10261.962055 -49.787 -113.0273
10262.694477 -61.138 -127.0312
10263.426899 -51.091 54.8193
10264.159321 -50.124 -49.2920
10264.891742 -50.350 -39.3291
10265.624164 -48.127 -16.0264
10266.356586 -42.164 8.5156
10267.089008 -44.096 -28.9268
10267.821430 -45.995 -26.7461
10268.553852 -44.076 -37.5479
10269.286273 -44.752 -33.9160
10270.018695 -46.162 -43.8848
10270.751117 -47.321 -39.7773
10271.483539 -45.481 -82.1611
10272.215961 -47.975 -73.7031
10272.948382 -44.743 -79.0664
10273.680804 -45.512 -101.0078
10274.413226 -42.289 -89.7803
10275.145648 -44.075 -83.6279
10275.878070 -42.726 -104.0088
10276.610492 -43.773 -140.0547
10277.342913 -43.374 -111.4570
10278.075335 -48.280 -134.4531
10278.807757 -43.748 -137.2383
10279.540179 -41.562 -153.3691
10280.272601 -42.496 -155.0186
10281.005022 -42.614 150.9658
10281.737444 -47.602 159.5488
10282.469866 -39.412 150.0156
10283.202288 -43.492 146.9004
10283.934710 -43.639 138.1768
10284.667131 -43.777 147.5742
10285.399553 -40.241 122.5000
10286.131975 -45.060 144.1436
10286.864397 -43.794 110.4492
10287.596819 -43.394 108.5654
10288.329241 -40.183 65.4668
10289.061662 -45.137 65.0059
10289.794084 -41.262 59.7510
10290.526506 -45.108 45.6611
10291.258928 -41.900 40.1494
10291.991350 -46.944 20.4111
10292.723771 -40.384 23.9502
10293.456193 -44.197 16.2432
10294.188615 -43.860 21.1396
10294.921037 -42.183 -13.6738
10295.653459 -40.738 -24.8418
10296.385881 -41.338 -10.2520
10297.118302 -42.616 -28.2744
10297.850724 -42.351 -28.2158
10298.583146 -39.464 -37.6240
10299.315568 -44.120 -45.1553
10300.047990 -42.310 -60.2832
10300.780411 -44.840 -69.1074
10301.512833 -40.572 -62.3828
10302.245255 -46.615 -96.5098
10302.977677 -44.785 -94.3057
10303.710099 -46.077 -111.7500
10304.442520 -46.537 -90.5605
10305.174942 -56.054 -127.0830
10305.907364 -43.645 -166.6396
10306.639786 -48.484 -148.8682
10307.372208 -51.683 -114.8916
10308.104630 -46.460 -148.1904
10308.837051 -42.519 172.2646
10309.569473 -45.657 -169.9600
10310.301895 -52.063 -144.1904
10311.034317 -50.548 -172.8584
10311.766739 -45.254 152.2100
10312.499160 -47.883 -167.5479
10313.231582 -52.225 -161.7988
10313.964004 -50.591 -129.7422
10314.696426 -47.037 172.3438
10315.428848 -46.981 -164.6328
10316.161270 -47.031 -166.6855
10316.893691 -47.889 152.4756
10317.626113 -49.168 160.2266
10318.358535 -52.795 171.3652
10319.090957 -49.335 121.1348
10319.823379 -47.963 120.7803
10320.555800 -52.006 125.8760
10321.288222 -45.060 141.6240
10322.020644 -47.429 136.6084
10322.753066 -45.807 103.2637
10323.485488 -47.176 78.8652
10324.217910 -48.810 121.9121
10324.950331 -46.396 112.3662
10325.682753 -45.702 106.6289
10326.415175 -48.595 91.8691
10327.147597 -45.353 62.2012
10327.880019 -46.490 59.7490
10328.612440 -45.169 60.8574
10329.344862 -45.774 39.7188
10330.077284 -46.522 54.8945
10330.809706 -47.392 59.4697
10331.542128 -47.488 52.1523
10332.274549 -41.263 47.1387
10333.006971 -46.731 73.4932
10333.739393 -46.897 53.0400
10334.471815 -44.783 44.9287
10335.204237 -44.926 21.9727
10335.936659 -51.380 31.9922
10336.669080 -49.497 25.2275
10337.401502 -57.412 6.4238
10338.133924 -47.599 20.1895
10338.866346 -47.512 67.7539
10339.598768 -54.142 -5.7627
10340.331189 -50.668 112.6016
10341.063611 -54.157 72.6934
10341.796033 -55.981 17.2344
10342.528455 -59.515 162.9170
10343.260877 -62.381 61.4814
10343.993299 -50.577 35.1289
10344.725720 -54.412 76.2520
10345.458142 -44.084 103.0811
10346.190564 -52.718 67.3506
10346.922986 -54.977 63.1621
10347.655408 -46.364 44.2988
10348.387829 -52.550 31.1553
10349.120251 -44.662 66.5820
10349.852673 -49.951 58.5557
10350.585095 -45.405 26.8818
10351.317517 -49.570 40.6543
10352.049938 -47.319 21.1543
10352.782360 -40.878 47.2480
10353.514782 -44.823 65.8438
10354.247204 -50.538 50.2646
10354.979626 -45.293 44.4531
10355.712048 -41.724 33.7002
10356.444469 -44.919 23.5771
10357.176891 -48.842 28.0957
10357.909313 -44.610 44.2090
10358.641735 -43.003 14.9561
10359.374157 -45.568 35.5889
10360.106578 -43.672 52.4141
10360.839000 -43.995 51.0625
10361.571422 -43.760 20.9102
10362.303844 -42.837 34.3291
10363.036266 -46.062 36.4482
10363.768688 -43.737 36.0391
10364.501109 -44.174 21.5898
10365.233531 -43.844 38.3125
10365.965953 -41.271 15.2695
10366.698375 -42.618 18.0498
10367.430797 -41.568 1.5127
10368.163218 -41.022 7.7500
10368.895640 -44.177 26.1846
10369.628062 -44.264 16.4736
10370.360484 -42.959 -13.4414
10371.092906 -42.607 -1.0303
10371.825328 -40.115 -11.3066
10372.557749 -42.756 3.7920
10373.290171 -43.370 -1.0264
10374.022593 -41.402 -7.4111
10374.755015 -41.714 -41.8457
10375.487437 -43.108 -1.5752
10376.219858 -41.856 -32.9258
10376.952280 -45.784 -42.7061
10377.684702 -44.475 -25.7002
10378.417124 -45.349 -23.8975
10379.149546 -44.933 -54.3203
10379.881967 -44.073 -55.3047
10380.614389 -42.498 -43.6875
10381.346811 -46.705 -78.4385
10382.079233 -44.513 -62.5283
10382.811655 -46.072 -43.6348
10383.544077 -51.077 -72.5088
10384.276498 -60.427 13.1016
10385.008920 -49.691 -35.4893
10385.741342 -46.968 -42.7559
10386.473764 -55.735 -81.0869
10387.206186 -54.522 60.6826
10387.938607 -50.995 34.3447
10388.671029 -51.663 8.7295
10389.403451 -57.168 -152.6855
10390.135873 -63.104 -24.8594
10390.868295 -53.565 -147.8018
10391.600717 -57.953 159.7832
10392.333138 -52.097 -0.4189
10393.065560 -54.679 105.6279
10393.797982 -60.696 37.7773
10394.530404 -52.470 -44.1475
10395.262826 -47.842 19.7969
10395.995247 -45.482 -10.0850
10396.727669 -66.669 26.5967
10397.460091 -57.060 -75.3418
10398.192513 -62.408 18.9014
10398.924935 -58.827 21.1807
10399.657357 -47.192 17.0547
10400.389778 -60.502 -17.4688
10401.122200 -54.678 6.2588
10401.854622 -49.266 29.3994
10402.587044 -44.673 -9.1787
10403.319466 -48.699 -4.1133
10404.051887 -45.534 6.0752
10404.784309 -53.764 62.1250
10405.516731 -51.887 -11.3574
10406.249153 -41.865 -10.2012
10406.981575 -39.717 -12.3633
10407.713996 -39.683 -5.8496
10408.446418 -37.628 -30.5156
10409.178840 -39.461 -8.3760
10409.911262 -38.973 -21.3447
10410.643684 -39.968 -21.6777
10411.376106 -40.747 -31.5820
10412.108527 -38.330 -24.4834
10412.840949 -39.618 -43.4170
10413.573371 -39.775 -43.7812
10414.305793 -41.460 -32.8086
10415.038215 -40.958 -45.4961
10415.770636 -41.231 -53.7217
10416.503058 -41.940 -31.3301
10417.235480 -42.589 -49.5195
10417.967902 -47.955 -49.9521
10418.700324 -44.218 -47.7100
10419.432746 -46.558 -59.9219
10420.165167 -42.790 -68.0820
10420.897589 -45.736 -121.8232
10421.630011 -59.169 -70.0098
10422.362433 -49.878 -16.9570
10423.094855 -55.687 -51.8477
10423.827276 -54.102 -10.7373
10424.559698 -45.832 1.7793
10425.292120 -45.556 -14.7910
10426.024542 -45.926 -8.9482
10426.756964 -48.784 -12.0947
10427.489385 -44.234 1.1729
10428.221807 -43.797 11.1855
10428.954229 -48.358 -12.5137
10429.686651 -41.983 -13.7148
10430.419073 -40.495 -36.8594
10431.151495 -40.665 -7.7021
10431.883916 -46.258 -60.2881
10432.616338 -42.744 -63.8262
10433.348760 -44.153 0.3379
10434.081182 -37.658 -26.8867
10434.813604 -42.637 -30.2627
10435.546025 -40.331 -50.2539
10436.278447 -38.373 -29.2598
10437.010869 -39.855 -35.6279
10437.743291 -43.805 -92.3838
10438.475713 -41.252 -36.3389
10439.208135 -36.244 -75.7119
10439.940556 -44.967 -55.7041
10440.672978 -39.913 -71.9209
10441.405400 -39.827 -58.3223
10442.137822 -46.446 -33.5225
10442.870244 -44.514 -58.3223
10443.602665 -40.309 -33.0791
10444.335087 -46.839 -75.1250
10445.067509 -38.858 -15.7783
10445.799931 -41.287 -60.6582
10446.532353 -39.471 -87.5000
10447.264775 -41.096 -56.0430
10447.997196 -41.252 -52.5195
10448.729618 -37.983 -73.7695
10449.462040 -38.960 -70.5088
10450.194462 -39.494 -120.2754
10450.926884 -35.617 -79.7178
10451.659305 -36.657 -72.8604
10452.391727 -37.074 -84.2236
10453.124149 -39.156 -138.7021
10453.856571 -48.011 -140.9365
10454.588993 -40.280 -99.1279
10455.321414 -46.066 -58.8965
10456.053836 -43.060 -109.0850
10456.786258 -41.497 -140.1602
10457.518680 -47.762 -170.2373
10458.251102 -39.391 167.0137
10458.983524 -36.903 -169.7900
10459.715945 -36.732 -175.7900
10460.448367 -41.796 178.0283
10461.180789 -40.457 156.0195
10461.913211 -39.739 153.7871
10462.645633 -40.784 159.0684
10463.378054 -42.867 151.5010
10464.110476 -35.068 132.1191
10464.842898 -36.608 126.5938
10465.575320 -36.268 139.6699
10466.307742 -37.937 97.2910
10467.040164 -39.286 119.7969
10467.772585 -35.141 93.9746
10468.505007 -37.207 64.7500
10469.237429 -35.292 96.3799
10469.969851 -37.280 98.9150
10470.702273 -37.662 76.6602
10471.434694 -42.898 71.5869
10472.167116 -39.629 79.5811
10472.899538 -38.628 63.8496
10473.631960 -37.584 51.5986
10474.364382 -37.914 61.1533
10475.096803 -42.146 39.4043
10475.829225 -40.222 46.2324
10476.561647 -48.799 51.7842
10477.294069 -51.504 -5.7764
10478.026491 -44.609 -29.4795
10478.758913 -46.054 172.6143
10479.491334 -42.880 132.6396
10480.223756 -41.801 166.7500
10480.956178 -43.638 -172.3604
10481.688600 -40.680 -146.4932
10482.421022 -41.681 155.5723
10483.153443 -40.987 -156.6025
10483.885865 -41.015 -146.6338
10484.618287 -66.162 55.0371
10485.350709 -42.683 168.5869
10486.083131 -41.007 151.2959
10486.815553 -46.815 -170.2627
10487.547974 -41.354 156.8740
10488.280396 -66.489 74.8486
10489.012818 -47.134 25.9717
10489.745240 -44.675 2.0938
10490.477662 -39.162 23.9434
10491.210083 -37.900 1.8711
10491.942505 -39.823 32.1602
10492.674927 -39.421 -8.5625
10493.407349 -43.100 -0.6055
10494.139771 -47.892 122.5400
10494.872193 -44.390 127.1484
10495.604614 -47.324 53.5371
10496.337036 -44.685 146.2705
10497.069458 -41.370 -12.5078
10497.801880 -37.533 -31.3779
10498.534302 -44.550 -173.3096
10499.266723 -46.872 13.5127
10499.999145 -40.435 -28.0977
10500.731567 -38.969 -12.2246
10501.463989 -38.593 -6.2969
10502.196411 -40.115 -21.0508
10502.928832 -41.932 -29.4072
10503.661254 -40.193 -8.4492
10504.393676 -42.071 -20.1270
10505.126098 -38.098 -13.3340
10505.858520 -45.617 -21.4043
10506.590942 -48.525 35.3252
10507.323363 -40.919 -70.5479
10508.055785 -46.976 3.1816
10508.788207 -45.010 -25.2061
10509.520629 -38.597 -23.5361
10510.253051 -49.727 3.9365
10510.985472 -52.191 41.9941
10511.717894 -49.143 25.2588
10512.450316 -41.595 -11.3037
10513.182738 -40.918 -37.8281
10513.915160 -42.161 -35.3311
10514.647582 -42.049 -15.0527
10515.380003 -38.420 -43.2520
10516.112425 -44.568 -8.7412
10516.844847 -41.048 -0.2529
10517.577269 -42.316 -29.6299
10518.309691 -41.595 -62.1309
10519.042112 -43.217 -52.7510
10519.774534 -40.654 -54.5859
10520.506956 -39.987 -51.8887
10521.239378 -48.714 -33.9795
10521.971800 -42.136 -66.3086
10522.704221 -40.780 -98.5166
10523.436643 -40.602 -89.6348
10524.169065 -42.552 -60.2148
10524.901487 -47.540 -91.0996
10525.633909 -45.601 -71.1992
10526.366331 -42.335 -73.3916
10527.098752 -41.316 -79.6143
10527.831174 -51.558 -14.7578
10528.563596 -46.478 -38.8828
10529.296018 -50.580 -112.7656
10530.028440 -41.432 -135.0732
10530.760861 -46.676 -80.7002
10531.493283 -44.725 -116.8398
10532.225705 -56.907 60.3594
10532.958127 -48.115 161.7402
10533.690549 -49.799 -140.1426
10534.422971 -57.798 133.9736
10535.155392 -46.881 103.1816
10535.887814 -41.653 151.5410
10536.620236 -42.402 139.8750
10537.352658 -43.968 149.9551
10538.085080 -43.616 178.3662
10538.817501 -48.070 96.2666
10539.549923 -41.667 116.6113
10540.282345 -45.506 44.9229
10541.014767 -43.626 68.7754
10541.747189 -59.651 137.7256
10542.479611 -48.780 -17.0107
10543.212032 -41.871 31.5371
10543.944454 -45.086 53.2471
10544.676876 -40.228 102.4805
10545.409298 -44.236 47.0068
10546.141720 -42.291 50.7061
10546.874141 -41.850 15.7061
10547.606563 -45.471 -74.2939
10548.338985 -42.977 -5.1963
10549.071407 -41.229 -37.2031
10549.803829 -40.864 -61.8262
10550.536250 -41.597 -29.9072
10551.268672 -37.279 -19.5059
10552.001094 -52.113 -59.7637
10552.733516 -41.699 1.0244
10553.465938 -42.334 -60.7773
10554.198360 -46.981 -104.5596
10554.930781 -43.651 -62.6357
10555.663203 -40.406 -92.5996
10556.395625 -43.367 -133.1455
10557.128047 -39.874 -117.7754
10557.860469 -40.277 -88.4180
10558.592890 -41.551 -108.1123
10559.325312 -42.744 -96.6846
10560.057734 -43.346 -130.7461
10560.790156 -45.815 -78.7539
10561.522578 -42.429 -121.1406
10562.255000 -42.053 -128.5518
10562.987421 -45.911 -151.0508
10563.719843 -47.732 -133.4316
10564.452265 -49.621 179.8740
10565.184687 -48.083 -163.5410
10565.917109 -41.515 136.2637
10566.649530 -42.204 169.9746
10567.381952 -43.865 -174.5918
10568.114374 -45.541 119.7480
10568.846796 -46.928 135.2148
10569.579218 -45.868 94.2773
10570.311639 -39.909 118.3789
10571.044061 -42.852 109.2715
10571.776483 -40.048 124.1074
10572.508905 -44.828 81.7275
10573.241327 -42.528 75.9951
10573.973749 -44.940 97.6611
10574.706170 -43.180 48.8594
10575.438592 -42.510 76.1318
10576.171014 -42.013 53.6211
10576.903436 -41.053 65.0801
10577.635858 -40.424 59.3193
10578.368279 -46.535 48.9053
10579.100701 -43.832 43.9229
10579.833123 -42.880 29.3887
10580.565545 -42.012 23.8047
10581.297967 -43.913 21.8828
10582.030389 -42.990 38.7842
10582.762810 -42.216 29.6279
10583.495232 -44.406 35.1787
10584.227654 -45.209 10.2959
10584.960076 -44.285 32.5283
10585.692498 -46.281 -15.4902
10586.424919 -43.226 28.4326
10587.157341 -52.236 14.2422
10587.889763 -47.231 15.3789
10588.622185 -45.272 6.5264
10589.354607 -51.548 -24.7148
10590.087029 -46.020 -45.3223
10590.819450 -48.480 25.9170
10591.551872 -48.948 -35.2959
10592.284294 -43.690 -13.7656
10593.016716 -44.355 19.7383
10593.749138 -48.863 73.8184
10594.481559 -57.788 139.3242
10595.213981 -50.331 74.3662
10595.946403 -45.619 12.2959
10596.678825 -47.494 54.0420
10597.411247 -53.327 137.4805
10598.143668 -46.380 6.5547
10598.876090 -52.240 -15.8818
10599.608512 -46.268 31.5127
10600.340934 -43.730 41.0068
10601.073356 -42.441 51.4805
10601.805778 -44.869 -0.8975
10602.538199 -41.360 20.6992
10603.270621 -45.466 0.5693
10604.003043 -42.891 4.9258
10604.735465 -42.740 -10.8486
10605.467887 -42.504 1.4609
10606.200308 -46.637 6.1787
10606.932730 -44.311 -7.6445
10607.665152 -44.218 -26.3730
10608.397574 -45.527 -12.3477
10609.129996 -62.328 -109.0020
10609.862418 -51.113 -59.0615
10610.594839 -47.611 -69.9180
10611.327261 -45.753 -35.8359
10612.059683 -50.213 -55.1650
10612.792105 -46.880 -79.0078
10613.524527 -51.443 -101.1709
10614.256948 -53.568 -92.0381
10614.989370 -49.585 -94.4404
10615.721792 -53.793 -89.2549
10616.454214 -53.719 -152.1914
10617.186636 -54.387 108.9082
10617.919057 -50.718 -173.1562
10618.651479 -51.516 117.3096
10619.383901 -51.332 128.7197
10620.116323 -46.769 106.9932
10620.848745 -43.385 90.1309
10621.581167 -43.606 74.9912
10622.313588 -42.742 102.4609
10623.046010 -43.939 48.6436
10623.778432 -45.104 65.5430
10624.510854 -42.191 63.2773
10625.243276 -44.267 48.0010
10625.975697 -42.956 48.6113
10626.708119 -49.791 58.1113
10627.440541 -45.379 -3.0098
10628.172963 -43.956 24.4062
10628.905385 -44.235 -0.4824
10629.637807 -47.365 10.0176
10630.370228 -43.206 12.7412
10631.102650 -45.113 3.7920
10631.835072 -41.858 -3.9209
10632.567494 -45.234 9.0723
10633.299916 -42.996 -39.7031
10634.032337 -46.369 -32.8467
10634.764759 -50.033 -6.2959
10635.497181 -48.187 -12.2920
10636.229603 -54.215 -19.1650
10636.962025 -57.642 36.9648
10637.694447 -45.313 -35.5498
10638.426868 -52.114 -43.8555
10639.159290 -55.618 -59.0391
10639.891712 -64.794 15.0938
10640.624134 -47.490 50.5957
10641.356556 -50.309 63.7178
10642.088977 -43.833 78.2627
10642.821399 -44.044 69.5996
10643.553821 -42.484 13.6289
10644.286243 -41.704 59.0410
10645.018665 -46.164 53.7422
10645.751086 -43.344 61.9590
10646.483508 -42.035 22.3916
10647.215930 -41.218 31.9180
10647.948352 -42.021 3.3271
10648.680774 -42.202 10.4199
10649.413196 -40.568 0.0137
10650.145617 -40.629 10.5107
10650.878039 -44.393 3.5508
10651.610461 -43.432 6.0986
10652.342883 -42.575 -23.1025
10653.075305 -50.562 -7.0586
10653.807726 -43.662 -5.8916
10654.540148 -44.802 2.8574
10655.272570 -43.903 -29.1816
10656.004992 -42.243 -12.0947
10656.737414 -49.761 -16.5889
10657.469836 -44.987 -22.7412
10658.202257 -45.326 -55.6973
10658.934679 -50.277 33.4014
10659.667101 -56.147 -6.5850
10660.399523 -45.831 37.6543
10661.131945 -45.972 -4.3906
10661.864366 -53.218 22.2715
10662.596788 -49.449 6.1738
10663.329210 -44.105 21.0137
10664.061632 -50.861 -18.9785
10664.794054 -48.551 13.2803
10665.526475 -47.714 -7.9746
10666.258897 -44.876 -20.9512
10666.991319 -43.901 -34.4463
10667.723741 -44.187 -19.8135
10668.456163 -51.976 -49.3574
10669.188585 -42.848 -45.7520
10669.921006 -44.336 -56.5000
10670.653428 -44.471 -42.0000
10671.385850 -46.441 -61.7256
10672.118272 -41.445 -76.6973
10672.850694 -41.480 -76.8613
10673.583115 -46.565 -80.9189
10674.315537 -43.657 -99.6035
10675.047959 -41.275 -98.1719
10675.780381 -40.304 -69.8467
10676.512803 -41.796 -111.6064
10677.245225 -43.794 -121.6855
10677.977646 -44.236 -132.6982
10678.710068 -41.046 -136.9307
10679.442490 -43.946 -125.5439
10680.174912 -41.536 -156.5508
10680.907334 -44.604 -163.1475
10681.639755 -38.578 -168.4502
10682.372177 -38.820 -174.6309
10683.104599 -38.519 152.0117
10683.837021 -40.162 152.8379
10684.569443 -38.813 159.9844
10685.301865 -40.393 131.8213
10686.034286 -37.412 137.5938
10686.766708 -39.056 108.1270
10687.499130 -38.307 128.3799
10688.231552 -37.495 112.8740
10688.963974 -37.493 110.5479
10689.696395 -37.401 105.7490
10690.428817 -39.137 111.4814
10691.161239 -38.546 84.2705
10691.893661 -37.046 79.1582
10692.626083 -38.217 74.0859
10693.358504 -39.827 74.6992
10694.090926 -39.134 63.8721
10694.823348 -38.679 73.6387
10695.555770 -38.975 61.2568
10696.288192 -40.596 74.8896
10697.020614 -39.582 47.6221
10697.753035 -38.601 51.7051
10698.485457 -41.711 42.6406
10699.217879 -42.135 30.5332
10699.950301 -42.617 27.7559
10700.682723 -40.891 37.7432
10701.415144 -42.767 28.1494
10702.147566 -46.912 13.0615
10702.879988 -41.088 6.8516
10703.612410 -43.671 16.3828
10704.344832 -42.800 27.5664
10705.077254 -46.028 47.1279
10705.809675 -44.320 1.9492
10706.542097 -41.177 35.4307
10707.274519 -43.820 -7.7148
10708.006941 -46.628 29.0498
10708.739363 -41.855 -6.0762
10709.471784 -43.078 22.1523
10710.204206 -41.516 -27.1279
10710.936628 -47.009 14.1797
10711.669050 -44.185 -12.3340
10712.401472 -42.899 18.3008
10713.133893 -47.774 1.5381
10713.866315 -47.601 -36.5332
10714.598737 -44.677 -4.0635
10715.331159 -54.838 -8.9082
10716.063581 -45.192 -1.7578
10716.796003 -49.272 -1.1113
10717.528424 -47.143 -37.3867
10718.260846 -47.266 -30.8193
10718.993268 -52.779 42.4434
10719.725690 -50.441 -31.4580
10720.458112 -48.923 -90.0859
10721.190533 -59.109 -23.0527
10721.922955 -59.693 -129.5918
10722.655377 -58.386 74.6201
10723.387799 -62.656 -15.2393
10724.120221 -55.118 -65.1738
10724.852643 -53.989 73.0127
10725.585064 -56.488 88.9678
10726.317486 -55.048 139.3506
10727.049908 -47.165 84.9658
10727.782330 -58.598 -16.1494
10728.514752 -50.212 95.2314
10729.247173 -49.392 88.5332
10729.979595 -46.141 46.7520
10730.712017 -49.180 59.5049
10731.444439 -42.804 72.8213
10732.176861 -45.440 65.3076
10732.909283 -44.549 69.8301
10733.641704 -43.539 52.0869
10734.374126 -45.687 69.6113
10735.106548 -50.901 51.2012
10735.838970 -43.894 49.4980
10736.571392 -47.245 41.9902
10737.303813 -47.343 73.0723
10738.036235 -50.117 36.0078
10738.768657 -46.081 36.4502
10739.501079 -47.941 8.2715
10740.233501 -46.616 24.6592
10740.965922 -45.035 22.1074
10741.698344 -43.160 16.0137
10742.430766 -47.867 31.1729
10743.163188 -50.836 35.2305
10743.895610 -61.371 34.0078
10744.628032 -58.536 27.3535
10745.360453 -62.055 -69.5244
10746.092875 -56.774 31.2041
10746.825297 -54.903 -154.5918
10747.557719 -54.225 -24.4023
10748.290141 -64.904 -63.2861
10749.022562 -44.179 95.9629
10749.754984 -50.351 68.7930
10750.487406 -49.228 62.6650
10751.219828 -48.030 77.4111
10751.952250 -41.817 74.9619
10752.684672 -43.575 70.5615
10753.417093 -44.444 43.2324
10754.149515 -45.847 65.1768
10754.881937 -45.689 46.3252
10755.614359 -43.906 59.8027
10756.346781 -43.387 46.6748
10757.079202 -43.024 36.3232
10757.811624 -42.243 47.1768
10758.544046 -44.476 62.0117
10759.276468 -43.371 10.4600
10760.008890 -43.034 19.3711
10760.741311 -42.255 28.7158
10761.473733 -42.735 15.6826
10762.206155 -41.746 2.6650
10762.938577 -41.339 -0.8525
10763.670999 -42.004 10.3008
10764.403421 -43.115 0.3164
10765.135842 -42.298 3.3037
10765.868264 -42.582 10.8066
10766.600686 -42.122 -7.6758
10767.333108 -48.300 8.2207
10768.065530 -45.407 -6.2764
10768.797951 -48.441 30.7412
10769.530373 -47.499 -31.5176
10770.262795 -45.135 -22.6963
10770.995217 -48.617 -53.1475
10771.727639 -44.062 -30.4766
10772.460061 -47.234 -63.7070
10773.192482 -46.563 -64.1992
10773.924904 -45.137 -22.9971
10774.657326 -67.765 -32.2090
10775.389748 -56.174 -2.6348
10776.122170 -49.093 44.8008
10776.854591 -51.805 -37.1064
10777.587013 -47.974 5.0586
10778.319435 -46.286 -48.1387
10779.051857 -60.976 -48.2803
10779.784279 -50.710 -10.9365
10780.516701 -54.025 -69.1250
10781.249122 -60.442 -89.7422
10781.981544 -67.383 60.8242
10782.713966 -55.310 -61.6816
10783.446388 -58.847 -158.5908
10784.178810 -50.573 89.6680
10784.911231 -56.239 111.0283
10785.643653 -52.129 113.4902
10786.376075 -46.493 129.9570
10787.108497 -52.443 80.9893
10787.840919 -45.268 81.4258
10788.573340 -48.473 92.6729
10789.305762 -44.600 72.0723
10790.038184 -50.314 73.5254
10790.770606 -41.872 70.0732
10791.503028 -42.509 66.2607
10792.235450 -42.246 64.0410
10792.967871 -43.595 62.9570
10793.700293 -39.954 57.2158
10794.432715 -40.969 45.3506
10795.165137 -41.471 46.9102
10795.897559 -40.330 26.0801
10796.629980 -40.936 34.0586
10797.362402 -42.460 12.9707
10798.094824 -45.356 -4.3770
10798.827246 -40.034 -8.6738
10799.559668 -40.472 7.0557
10800.292090 -44.319 -29.8350
10801.024511 -40.498 -19.0645
10801.756933 -42.935 -25.0576
10802.489355 -43.674 -25.9277
10803.221777 -41.445 -48.1992
10803.954199 -42.455 -48.7998
10804.686620 -42.061 -58.3340
10805.419042 -42.693 -45.9766
10806.151464 -42.677 -112.2500
10806.883886 -41.510 -90.9873
10807.616308 -46.100 -139.5225
10808.348729 -43.763 -124.5244
10809.081151 -42.746 -139.3984
10809.813573 -42.422 -157.0674
10810.545995 -44.861 -171.7441
10811.278417 -42.548 -171.6426
10812.010839 -43.586 175.2061
10812.743260 -42.892 160.5850
10813.475682 -38.753 157.2959
10814.208104 -41.176 119.8994
10814.940526 -37.654 129.3984
10815.672948 -38.139 111.1475
10816.405369 -38.773 120.8535
10817.137791 -37.995 105.0596
10817.870213 -37.782 95.8887
10818.602635 -38.061 96.2549
10819.335057 -39.922 93.6279
10820.067479 -39.227 71.0703
10820.799900 -37.813 85.2520
10821.532322 -37.447 68.1777
10822.264744 -35.926 66.5312
10822.997166 -35.901 60.9346
10823.729588 -36.161 58.4102
10824.462009 -38.186 49.2979
10825.194431 -37.726 49.5039
10825.926853 -39.026 35.9629
10826.659275 -39.376 24.3184
10827.391697 -38.626 33.3281
10828.124119 -38.754 31.0625
10828.856540 -39.950 20.1299
10829.588962 -40.136 9.6973
10830.321384 -41.078 11.8555
10831.053806 -41.053 -1.7695
10831.786228 -39.546 25.1797
10832.518649 -39.442 4.8809
10833.251071 -40.866 16.6982
10833.983493 -39.665 31.9775
10834.715915 -39.444 10.0898
10835.448337 -42.885 11.6025
10836.180758 -41.465 12.6885
10836.913180 -40.250 8.4922
10837.645602 -40.790 19.3887
10838.378024 -39.386 22.1016
10839.110446 -41.341 16.1484
10839.842868 -38.901 19.0498
10840.575289 -36.270 -1.3242
10841.307711 -38.161 1.3809
10842.040133 -37.110 5.7236
10842.772555 -35.715 -8.4404
10843.504977 -37.382 -17.4463
10844.237398 -36.837 -13.4414
10844.969820 -39.670 -15.9961
10845.702242 -35.528 -12.1602
10846.434664 -35.996 -16.5303
10847.167086 -36.024 -19.6016
10847.899508 -36.549 -19.4746
10848.631929 -35.779 -22.0264
10849.364351 -36.238 -35.9639
10850.096773 -36.524 -36.6455
10850.829195 -35.823 -40.9854
10851.561617 -37.605 -38.1768
10852.294038 -36.580 -52.5693
10853.026460 -38.959 -42.7744
10853.758882 -42.969 -53.2734
10854.491304 -37.743 -48.4277
10855.223726 -38.269 -73.4922
10855.956147 -39.331 -55.2744
10856.688569 -40.645 -54.0049
10857.420991 -37.792 -69.8535
10858.153413 -38.585 -65.0791
10858.885835 -38.545 -78.8135
10859.618257 -41.362 -65.1123
10860.350678 -47.256 -50.6924
10861.083100 -39.360 -61.7334
10861.815522 -38.239 -69.7520
10862.547944 -46.390 -55.2764
10863.280366 -45.205 -88.4639
10864.012787 -42.420 -107.4531
10864.745209 -41.383 -104.8438
10865.477631 -44.552 -88.0264
10866.210053 -42.270 -70.6768
10866.942475 -42.795 -100.9775
10867.674897 -43.334 -105.0674
10868.407318 -40.220 -97.4688
10869.139740 -40.894 -87.9521
10869.872162 -41.931 -98.8691
10870.604584 -38.590 -114.7295
10871.337006 -43.714 -93.2549
10872.069427 -44.638 -122.8223
10872.801849 -38.841 -129.6338
10873.534271 -43.349 -151.3770
10874.266693 -41.631 -165.9980
10874.999115 -41.226 -139.0859
10875.731537 -40.058 -168.5068
10876.463958 -41.338 -177.4561
10877.196380 -38.704 -169.3018
10877.928802 -42.632 -143.7207
10878.661224 -43.172 176.6357
10879.393646 -40.800 171.3184
10880.126067 -40.160 150.6738
10880.858489 -42.172 163.1436
10881.590911 -40.217 171.2236
10882.323333 -42.711 138.0205
10883.055755 -40.936 127.4170
10883.788176 -44.167 119.3848
10884.520598 -45.355 129.0244
10885.253020 -41.423 123.6816
10885.985442 -43.405 98.4521
10886.717864 -41.585 65.8115
10887.450286 -44.712 53.0186
10888.182707 -46.384 100.7832
10888.915129 -41.496 67.0059
10889.647551 -45.644 50.9893
10890.379973 -45.766 55.3984
10891.112395 -46.716 53.6162
10891.844816 -44.631 32.2637
10892.577238 -44.390 38.0566
10893.309660 -48.028 2.5352
10894.042082 -43.857 38.9336
10894.774504 -44.619 42.7451
10895.506926 -45.175 -34.4082
10896.239347 -44.515 -39.3877
10896.971769 -49.845 5.0605
10897.704191 -53.858 -42.7920
10898.436613 -55.665 -26.8857
10899.169035 -57.660 155.4717
10899.901456 -58.877 52.7432
10900.633878 -56.019 171.7559
10901.366300 -67.077 -61.5000
10902.098722 -54.237 61.5059
10902.831144 -50.297 -72.7002
10903.563565 -54.775 -122.0117
10904.295987 -46.366 -115.6904
10905.028409 -56.873 149.9053
10905.760831 -47.201 149.4297
10906.493253 -46.977 95.4492
10907.225675 -51.717 55.7646
10907.958096 -64.878 34.7412
10908.690518 -45.717 98.2197
10909.422940 -47.548 75.0107
10910.155362 -43.003 69.7119
10910.887784 -44.657 69.3125
10911.620205 -42.045 49.1143
10912.352627 -40.657 45.0869
10913.085049 -47.023 47.7539
10913.817471 -40.268 30.7686
10914.549893 -42.941 45.3242
10915.282315 -43.646 13.6543
10916.014736 -45.250 -10.9062
10916.747158 -45.367 25.8574
10917.479580 -42.668 17.6025
10918.212002 -41.366 26.6006
10918.944424 -42.104 5.0078
10919.676845 -42.605 -49.2529
10920.409267 -42.860 -28.0459
10921.141689 -41.139 8.3799
10921.874111 -44.376 -18.7715
10922.606533 -41.880 3.4512
10923.338955 -44.067 -0.4053
10924.071376 -40.476 -9.8457
10924.803798 -45.111 -30.7373
10925.536220 -45.342 -39.2324
10926.268642 -50.952 -49.7812
10927.001064 -42.468 -36.8223
10927.733485 -44.307 -45.2842
10928.465907 -42.598 -24.9561
10929.198329 -43.218 -42.2480
10929.930751 -41.296 -57.7402
10930.663173 -42.430 -49.1670
10931.395594 -43.812 -54.6328
10932.128016 -48.086 -32.0068
10932.860438 -40.414 -60.0264
10933.592860 -40.072 -85.9404
10934.325282 -42.283 -105.0820
10935.057704 -40.173 -107.8535
10935.790125 -42.621 -83.8604
10936.522547 -41.848 -125.2764
10937.254969 -40.814 -127.3818
10937.987391 -45.848 -133.7764
10938.719813 -41.185 -119.5869
10939.452234 -43.352 -144.3379
10940.184656 -39.565 -139.0117
10940.917078 -43.787 -141.8398
10941.649500 -43.628 -153.9932
10942.381922 -37.905 -160.4873
10943.114344 -41.825 175.2832
10943.846765 -43.447 -176.1240
10944.579187 -42.944 -177.5557
10945.311609 -41.275 150.5889
10946.044031 -40.798 139.3447
10946.776453 -43.669 153.8291
10947.508874 -45.236 134.2568
10948.241296 -41.775 124.2705
10948.973718 -42.113 89.1689
10949.706140 -42.591 105.6055
10950.438562 -40.548 100.7139
10951.170983 -40.095 96.8496
10951.903405 -39.112 98.7178
10952.635827 -43.712 73.4209
10953.368249 -42.703 81.6309
10954.100671 -41.486 75.0967
10954.833093 -37.761 85.0781
10955.565514 -38.499 54.5283
10956.297936 -42.225 22.6455
10957.030358 -42.442 38.0537
10957.762780 -41.201 55.0303
10958.495202 -41.246 17.5000
10959.227623 -42.598 23.6064
10959.960045 -43.127 24.7979
10960.692467 -43.888 15.8975
10961.424889 -42.968 22.6699
10962.157311 -44.368 14.1045
10962.889733 -44.419 19.9902
10963.622154 -47.532 22.5010
10964.354576 -43.251 -17.4307
10965.086998 -44.076 4.0918
10965.819420 -51.265 2.2061
10966.551842 -47.126 69.9922
10967.284263 -44.140 -12.3584
10968.016685 -48.250 -21.8730
10968.749107 -48.013 4.0947
10969.481529 -49.816 0.6211
10970.213951 -52.648 -22.2852
10970.946373 -46.786 -3.8945
10971.678794 -48.816 30.4736
10972.411216 -49.916 13.7012
10973.143638 -44.291 23.7852
10973.876060 -49.461 -4.7305
10974.608482 -52.680 9.1611
10975.340903 -46.708 -7.2900
10976.073325 -47.949 -62.9805
10976.805747 -47.601 -57.1768
10977.538169 -47.442 -48.6445
10978.270591 -50.197 -38.1768
10979.003012 -43.806 -41.4775
10979.735434 -48.674 -30.1152
10980.467856 -54.954 -27.7041
10981.200278 -58.126 -52.7959
10981.932700 -49.503 -55.5918
10982.665122 -52.003 -13.3555
10983.397543 -63.061 6.9277
10984.129965 -57.325 85.8887
10984.862387 -56.737 37.3984
10985.594809 -59.621 -11.7549
10986.327231 -59.765 -83.9209
10987.059652 -50.484 85.5850
10987.792074 -56.422 -145.7676
10988.524496 -56.243 19.7627
10989.256918 -52.269 48.9629
10989.989340 -61.873 47.3135
10990.721762 -54.081 2.9443
10991.454183 -59.724 -66.0195
10992.186605 -47.280 31.5908
10992.919027 -49.938 8.2383
10993.651449 -56.887 -22.4453
10994.383871 -56.715 -11.7910
10995.116292 -52.433 2.6709
10995.848714 -51.960 -35.5869
10996.581136 -52.859 -59.2617
10997.313558 -46.583 -26.8809
10998.045980 -52.478 -29.4941
10998.778401 -58.273 45.7295
10999.510823 -47.869 -149.9258
11000.243245 -52.000 -154.5244
11000.975667 -60.862 -178.5234
11001.708089 -66.530 158.2754
11002.440511 -57.286 -120.0088
11003.172932 -49.878 175.4795
11003.905354 -49.691 176.1523
11004.637776 -46.295 153.8467
11005.370198 -43.016 164.9043
11006.102620 -44.643 162.7197
11006.835041 -42.447 133.3027
11007.567463 -44.082 135.1172
11008.299885 -41.512 121.5498
11009.032307 -41.463 116.3369
11009.764729 -38.313 89.8379
11010.497151 -38.620 76.7246
11011.229572 -38.935 101.9395
11011.961994 -41.840 69.4043
11012.694416 -37.634 73.0713
11013.426838 -37.705 59.9961
11014.159260 -39.145 61.3115
11014.891681 -38.129 49.9521
11015.624103 -38.739 46.2617
11016.356525 -37.835 42.9609
11017.088947 -38.100 41.0957
11017.821369 -39.101 29.6572
11018.553791 -39.464 23.0537
11019.286212 -37.933 21.4668
11020.018634 -38.907 13.8008
11020.751056 -41.596 -3.1953
11021.483478 -44.899 -14.2539
11022.215900 -43.718 6.2646
11022.948321 -43.908 -5.4688
11023.680743 -46.372 -21.4785
11024.413165 -44.545 -48.9150
11025.145587 -45.844 -38.9443
11025.878009 -45.205 -61.7373
11026.610430 -55.098 -6.1094
11027.342852 -54.711 -73.5420
11028.075274 -47.112 -77.4365
11028.807696 -67.249 58.7510
11029.540118 -50.555 -14.5713
11030.272540 -48.404 28.6621
11031.004961 -49.916 46.8438
11031.737383 -52.504 64.5742
11032.469805 -55.241 -38.8945
11033.202227 -49.287 32.2393
11033.934649 -47.428 40.8154
11034.667070 -43.540 54.2939
11035.399492 -43.782 31.4395
11036.131914 -42.978 29.9717
11036.864336 -42.034 19.9873
11037.596758 -44.181 40.3701
11038.329180 -46.908 28.9111
11039.061601 -46.377 3.8535
11039.794023 -46.042 -6.7119
11040.526445 -46.708 12.8018
11041.258867 -44.317 -48.9170
11041.991289 -44.703 -14.6602
11042.723710 -45.238 -46.5127
11043.456132 -44.932 -50.1455
11044.188554 -43.873 -80.2217
11044.920976 -44.862 -69.9287
11045.653398 -46.377 -71.8184
11046.385819 -51.094 22.1162
11047.118241 -49.844 -140.6562
11047.850663 -49.013 -90.3320
11048.583085 -44.719 -102.4541
11049.315507 -49.039 -156.8115
11050.047929 -47.198 137.7432
11050.780350 -49.910 95.6729
11051.512772 -57.098 90.0186
11052.245194 -54.023 54.3691
11052.977616 -48.598 109.4873
11053.710038 -45.855 94.4258
11054.442459 -43.910 83.4785
11055.174881 -48.440 93.7861
11055.907303 -46.924 63.7393
11056.639725 -44.477 46.8467
11057.372147 -42.128 42.8076
11058.104569 -40.631 44.3057
11058.836990 -47.356 36.4668
11059.569412 -39.197 25.1992
11060.301834 -42.180 0.1924
11061.034256 -41.605 7.2871
11061.766678 -43.264 0.8115
11062.499099 -41.774 -4.0059
11063.231521 -42.263 -18.7031
11063.963943 -39.619 -7.8672
11064.696365 -44.582 -30.6318
11065.428787 -41.882 -17.3994
11066.161209 -43.366 -37.2920
11066.893630 -45.522 -68.9033
11067.626052 -47.251 -77.2256
11068.358474 -46.679 -61.7949
11069.090896 -45.983 -66.7363
11069.823318 -46.834 -24.3389
11070.555739 -58.378 -119.1846
11071.288161 -60.190 18.2725
11072.020583 -61.289 -27.5234
11072.753005 -55.819 -123.0303
11073.485427 -45.882 112.7314
11074.217848 -49.535 63.3506
11074.950270 -46.877 90.8027
11075.682692 -43.564 70.1504
11076.415114 -44.433 101.5771
11077.147536 -42.713 67.5977
11077.879958 -44.746 56.2188
11078.612379 -41.969 48.6152
11079.344801 -40.640 65.4062
11080.077223 -42.504 48.3711
11080.809645 -40.956 31.2510
11081.542067 -39.415 28.0928
11082.274488 -39.093 40.2119
11083.006910 -37.343 18.9541
11083.739332 -38.630 15.0020
11084.471754 -38.239 19.7373
11085.204176 -36.903 15.4053
11085.936598 -37.834 6.1992
11086.669019 -38.127 -7.3906
11087.401441 -37.727 -9.3047
11088.133863 -38.886 -9.6963
11088.866285 -36.361 -24.7949
11089.598707 -36.709 -27.8730
11090.331128 -39.125 -34.2422
11091.063550 -39.536 -16.9805
11091.795972 -36.542 -44.2373
11092.528394 -37.050 -47.8291
11093.260816 -34.734 -40.5293
11093.993237 -37.975 -46.7627
11094.725659 -38.479 -76.2695
11095.458081 -38.658 -67.2559
11096.190503 -39.407 -68.7129
11096.922925 -39.920 -62.1250
11097.655347 -38.389 -69.4238
11098.387768 -37.818 -76.5293
11099.120190 -40.115 -92.8223
11099.852612 -41.883 -78.1094
11100.585034 -40.711 -81.4541
11101.317456 -41.302 -87.8037
11102.049877 -43.053 -117.0801
11102.782299 -45.099 -111.6357
11103.514721 -40.129 -112.0557
11104.247143 -40.390 -111.3271
11104.979565 -39.160 -118.4043
11105.711987 -45.211 -114.2432
11106.444408 -40.150 -129.9248
11107.176830 -42.072 -123.7383
11107.909252 -43.436 -142.3203
11108.641674 -43.711 -143.0576
11109.374096 -42.694 -141.7197
11110.106517 -45.092 -141.9385
11110.838939 -45.288 -128.5918
11111.571361 -50.182 -143.8691
11112.303783 -44.374 -132.3447
11113.036205 -44.750 -155.6621
11113.768627 -50.046 -161.8447
11114.501048 -48.263 164.3096
11115.233470 -46.165 -144.3379
11115.965892 -45.696 -119.5547
11116.698314 -44.495 -140.7559
11117.430736 -48.912 -176.9756
11118.163157 -44.929 -144.1279
11118.895579 -43.883 -135.4297
11119.628001 -43.234 -172.3115
11120.360423 -62.260 -151.5352
11121.092845 -44.250 -169.6729
11121.825266 -47.910 178.4238
11122.557688 -44.040 -173.2939
11123.290110 -48.565 128.1133
11124.022532 -43.610 -173.0879
11124.754954 -44.734 171.8271
11125.487376 -44.720 163.1621
11126.219797 -44.198 130.4766
11126.952219 -43.741 138.1436
11127.684641 -42.406 126.7871
11128.417063 -42.266 123.5000
11129.149485 -43.724 107.8828
11129.881906 -44.029 119.3223
11130.614328 -44.160 102.6475
11131.346750 -41.889 103.2139
11132.079172 -43.986 110.7549
11132.811594 -42.938 88.7402
11133.544016 -41.730 77.5557
11134.276437 -42.002 71.0947
11135.008859 -41.802 48.3438
11135.741281 -44.201 52.3301
11136.473703 -43.679 32.0186
11137.206125 -40.545 49.5088
11137.938546 -41.255 25.2422
11138.670968 -41.963 26.5176
11139.403390 -44.071 27.2021
11140.135812 -46.513 18.2812
11140.868234 -41.974 2.9150
11141.600655 -45.625 3.0264
11142.333077 -44.191 34.4590
11143.065499 -41.154 15.0391
11143.797921 -43.050 -15.1543
11144.530343 -49.110 -33.2334
11145.262765 -47.833 -52.5547
11145.995186 -61.884 16.9824
11146.727608 -46.516 -51.0371
11147.460030 -59.688 -59.4658
11148.192452 -49.515 -70.4912
11148.924874 -47.409 -35.9092
11149.657295 -53.540 -46.5254
11150.389717 -53.533 101.0576
11151.122139 -62.368 -40.7139
11151.854561 -55.007 131.8887
11152.586983 -53.858 -134.5762
11153.319405 -57.862 -176.8076
11154.051826 -49.569 -174.9824
11154.784248 -48.097 124.7832
11155.516670 -57.471 -170.4648
11156.249092 -53.764 113.9209
11156.981514 -47.304 158.4844
11157.713935 -48.466 94.5088
11158.446357 -60.667 134.9541
11159.178779 -47.775 131.3301
11159.911201 -51.132 -179.6299
11160.643623 -47.573 102.8682
11161.376045 -49.964 7.8389
11162.108466 -47.803 100.2217
11162.840888 -46.875 152.1348
11163.573310 -43.871 101.5127
11164.305732 -54.185 85.1504
11165.038154 -48.135 90.9736
11165.770575 -48.364 162.5352
11166.502997 -45.014 112.4756
11167.235419 -46.574 114.7744
11167.967841 -43.868 109.5479
11168.700263 -48.181 78.8193
11169.432684 -41.680 82.3926
11170.165106 -49.697 85.9023
11170.897528 -46.471 123.6621
11171.629950 -48.208 116.6182
11172.362372 -44.342 98.1562
11173.094794 -44.394 83.3535
11173.827215 -40.257 61.0674
11174.559637 -42.548 73.1172
11175.292059 -40.961 76.9131
11176.024481 -44.435 90.5508
11176.756903 -43.379 66.2256
11177.489324 -41.577 40.6094
11178.221746 -44.745 29.1523
11178.954168 -42.942 72.6201
11179.686590 -43.022 33.5635
11180.419012 -41.431 42.9736
11181.151434 -40.230 37.2910
11181.883855 -42.007 41.3232
11182.616277 -46.761 53.5576
11183.348699 -44.664 48.0938
11184.081121 -42.161 35.0693
11184.813543 -41.377 30.0244
11185.545964 -45.918 10.6250
11186.278386 -45.697 30.1865
11187.010808 -39.247 28.4600
11187.743230 -43.455 30.0703
11188.475652 -44.839 -16.5879
11189.208073 -43.307 3.7139
11189.940495 -46.388 -13.5635
11190.672917 -40.452 0.0029
11191.405339 -43.920 0.5098
11192.137761 -48.098 -3.7803
11192.870183 -41.788 -14.1689
11193.602604 -47.556 17.7295
11194.335026 -46.121 -23.3770
11195.067448 -41.823 -13.4268
11195.799870 -41.029 -30.6943
11196.532292 -45.351 -27.6768
11197.264713 -40.409 21.1543
11197.997135 -39.656 -3.2510
11198.729557 -40.624 -10.1064
11199.461979 -42.661 -6.2578
11200.194401 -43.383 -26.6699
11200.926823 -46.247 -16.3193
11201.659244 -47.021 -37.4814
11202.391666 -39.888 -17.2188
11203.124088 -41.102 4.3906
11203.856510 -50.206 -48.9111
11204.588932 -42.197 -45.5381
11205.321353 -44.831 -0.2314
11206.053775 -43.481 -42.6553
11206.786197 -64.083 20.9307
11207.518619 -47.329 -65.9023
11208.251041 -45.213 -64.8506
11208.983463 -44.165 -59.2051
11209.715884 -51.943 88.9033
11210.448306 -51.746 -26.4492
11211.180728 -47.737 -51.3330
11211.913150 -43.756 -22.7334
11212.645572 -51.630 -51.5117
11213.377993 -45.468 -54.4287
11214.110415 -51.647 20.8994
11214.842837 -47.133 -2.1611
11215.575259 -61.346 149.6064
11216.307681 -46.383 -26.5098
11217.040102 -42.451 -13.7930
11217.772524 -54.001 21.0146
11218.504946 -43.484 -28.7725
11219.237368 -45.159 -74.6709
11219.969790 -47.245 -72.7041
11220.702212 -55.118 -23.5684
11221.434633 -49.169 -130.8291
11222.167055 -50.021 26.3906
11222.899477 -55.381 73.1572
11223.631899 -44.678 13.4121
11224.364321 -45.660 8.5391
11225.096742 -47.539 -1.3516
11225.829164 -41.755 -1.8906
11226.561586 -58.169 -100.3555
11227.294008 -46.418 -63.9395
11228.026430 -47.119 -47.0039
11228.758852 -46.934 -8.9854
11229.491273 -43.110 18.9004
11230.223695 -54.636 -40.2422
11230.956117 -52.577 -67.3438
11231.688539 -45.554 -58.5225
11232.420961 -43.598 -64.5938
11233.153382 -44.557 -100.1172
11233.885804 -44.602 -51.0908
11234.618226 -48.431 -47.4795
11235.350648 -47.301 -97.0264
11236.083070 -44.424 -73.5049
11236.815491 -56.417 29.4775
11237.547913 -40.785 -107.9814
11238.280335 -45.080 -150.7207
11239.012757 -48.837 -145.4766
11239.745179 -48.148 -95.4512
11240.477601 -47.781 -101.6357
11241.210022 -46.294 -130.6143
11241.942444 -51.538 -100.9912
11242.674866 -45.448 -175.1963
11243.407288 -47.993 -146.0830
11244.139710 -41.575 -90.3203
11244.872131 -55.614 -134.7266
11245.604553 -40.466 -124.4482
11246.336975 -44.155 -114.2432
11247.069397 -48.907 -143.8438
11247.801819 -48.178 -143.4473
11248.534241 -50.444 -89.7061
11249.266662 -42.690 -168.7031
11249.999084 -47.222 -142.5107
11250.731506 -68.467 -15.2900
11251.463928 -46.843 -153.1572
11252.196350 -46.860 -121.6025
11252.928771 -47.029 -151.5518
11253.661193 -46.752 165.6279
11254.393615 -50.318 -130.3633
11255.126037 -44.931 174.9102
11255.858459 -43.466 179.3838
11256.590881 -49.307 105.4990
11257.323302 -41.716 160.9248
11258.055724 -44.788 130.9805
11258.788146 -42.827 -157.9834
11259.520568 -48.390 124.2061
11260.252990 -46.856 100.2744
11260.985411 -43.079 117.2988
11261.717833 -44.836 107.8525
11262.450255 -41.177 129.0928
11263.182677 -39.978 111.5254
11263.915099 -42.352 118.4600
11264.647520 -39.186 88.2295
11265.379942 -40.826 84.0068
11266.112364 -42.354 43.7803
11266.844786 -37.751 62.9600
11267.577208 -41.041 82.5967
11268.309630 -43.769 73.9678
11269.042051 -46.713 97.5615
11269.774473 -40.757 45.5908
11270.506895 -40.171 47.7988
11271.239317 -40.267 41.3457
11271.971739 -38.280 26.7793
11272.704160 -44.771 1.5527
11273.436582 -38.004 24.1172
11274.169004 -39.699 24.9238
11274.901426 -40.814 -3.5068
11275.633848 -42.911 -9.4775
11276.366270 -37.668 8.1816
11277.098691 -38.605 -4.2168
11277.831113 -40.523 -5.5371
11278.563535 -45.078 7.5039
11279.295957 -39.279 -8.2705
11280.028379 -48.612 -57.8281
11280.760800 -61.413 -28.0645
11281.493222 -41.944 -48.6260
11282.225644 -46.546 -28.3662
11282.958066 -45.783 -13.9658
11283.690488 -38.879 -17.3135
11284.422909 -42.877 -23.5518
11285.155331 -43.691 -21.0098
11285.887753 -43.134 -46.8887
11286.620175 -47.264 132.8018
11287.352597 -46.437 -21.9004
11288.085019 -59.115 65.5840
11288.817440 -50.696 20.6846
11289.549862 -42.941 -20.1875
11290.282284 -52.345 -34.0273
11291.014706 -44.624 -2.1660
11291.747128 -54.584 94.9590
11292.479549 -48.477 30.1328
11293.211971 -47.119 -38.9014
11293.944393 -45.715 15.3809
11294.676815 -45.300 -8.3594
11295.409237 -43.673 -20.1172
11296.141659 -43.505 -44.6621
11296.874080 -53.814 -51.9141
11297.606502 -44.508 -10.6963
11298.338924 -44.048 34.4668
11299.071346 -42.954 -35.2051
11299.803768 -43.720 -23.0195
11300.536189 -45.545 18.8613
11301.268611 -48.100 -12.8711
11302.001033 -48.202 -65.2197
11302.733455 -44.884 -18.3613
11303.465877 -41.697 -24.0791
11304.198299 -53.774 -4.3428
11304.930720 -41.081 -38.4648
11305.663142 -45.020 -33.1982
11306.395564 -44.373 -28.6738
11307.127986 -40.276 -50.3555
11307.860408 -43.284 -79.3330
11308.592829 -44.145 -46.9248
11309.325251 -48.493 -13.5176
11310.057673 -51.472 -59.0322
11310.790095 -45.007 -61.6084
11311.522517 -40.037 -88.0918
11312.254938 -45.110 -81.3184
11312.987360 -43.816 -102.4277
11313.719782 -40.965 -127.2959
11314.452204 -45.084 -123.4639
11315.184626 -47.831 -112.6074
11315.917048 -42.686 -161.7832
11316.649469 -43.523 -153.5967
11317.381891 -47.151 -142.4326
11318.114313 -51.242 -177.6328
11318.846735 -41.571 -165.8965
11319.579157 -41.525 164.8652
11320.311578 -46.012 154.5156
11321.044000 -46.783 160.9531
11321.776422 -43.997 136.8906
11322.508844 -42.920 121.5439
11323.241266 -44.541 123.3525
11323.973688 -41.177 109.3906
11324.706109 -40.215 97.8838
11325.438531 -41.080 107.1504
11326.170953 -38.610 87.3945
11326.903375 -38.982 64.9580
11327.635797 -38.496 83.2783
11328.368218 -40.927 63.5596
11329.100640 -38.333 52.2930
11329.833062 -37.342 42.1816
11330.565484 -38.513 46.8193
11331.297906 -38.274 38.0283
11332.030327 -37.550 30.6055
11332.762749 -38.529 25.5996
11333.495171 -38.855 16.5234
11334.227593 -40.136 -1.4932
11334.960015 -37.690 7.3252
11335.692437 -37.180 -7.0352
11336.424858 -36.612 -4.5967
11337.157280 -41.247 -25.6523
11337.889702 -36.563 -23.8506
11338.622124 -35.418 -30.2021
11339.354546 -39.512 -17.4512
11340.086967 -40.602 -42.7461
11340.819389 -37.936 -58.6934
11341.551811 -38.780 -39.4922
11342.284233 -39.272 -65.4619
11343.016655 -38.065 -95.8555
11343.749077 -40.497 -81.7988
11344.481498 -38.477 -86.6748
11345.213920 -41.766 -89.1357
11345.946342 -40.681 -133.3389
11346.678764 -41.250 -112.5459
11347.411186 -45.137 -108.1670
11348.143607 -44.395 -130.9717
11348.876029 -42.260 -150.2090
11349.608451 -42.928 -152.7773
11350.340873 -44.298 -161.1240
11351.073295 -48.834 -177.3359
11351.805717 -40.503 -173.0371
11352.538138 -43.473 167.1211
11353.270560 -47.840 175.6582
11354.002982 -43.661 -178.9951
11354.735404 -40.480 159.3955
11355.467826 -45.978 133.3281
11356.200247 -51.713 109.8789
11356.932669 -47.445 100.0410
11357.665091 -45.059 141.9297
11358.397513 -47.703 124.1709
11359.129935 -51.601 100.2969
11359.862356 -45.363 94.6855
11360.594778 -41.657 122.0752
11361.327200 -47.782 94.0010
11362.059622 -46.503 59.3760
11362.792044 -42.388 76.8887
11363.524466 -41.884 101.0664
11364.256887 -46.312 113.8320
11364.989309 -54.016 23.6338
11365.721731 -45.776 88.8623
11366.454153 -43.043 99.0801
11367.186575 -44.674 60.6299
11367.918996 -43.946 53.7285
11368.651418 -43.110 43.1514
11369.383840 -46.302 68.5732
11370.116262 -46.491 57.4639
11370.848684 -43.406 9.5762
11371.581106 -48.961 46.8213
11372.313527 -42.632 64.3105
11373.045949 -47.745 45.5137
11373.778371 -47.925 -22.5762
11374.510793 -45.051 34.9326
11375.243215 -45.060 44.4873
11375.975636 -51.078 34.0000
11376.708058 -45.493 -11.8145
11377.440480 -63.641 -66.8682
11378.172902 -47.914 71.8447
11378.905324 -48.684 -7.4365
11379.637745 -48.414 -41.3584
11380.370167 -48.674 -2.6748
11381.102589 -50.542 18.2637
11381.835011 -59.989 161.9609
11382.567433 -50.401 -26.4883
11383.299855 -49.551 -67.7246
11384.032276 -49.296 39.6787
11384.764698 -46.798 -131.7666
11385.497120 -55.065 -78.1045
11386.229542 -54.002 31.8555
11386.961964 -47.010 38.0537
11387.694385 -65.301 -79.0439
11388.426807 -54.679 -71.0908
11389.159229 -53.465 127.3662
11389.891651 -42.995 86.3252
11390.624073 -51.722 91.8135
11391.356495 -68.307 90.8184
11392.088916 -57.010 89.6650
11392.821338 -44.982 77.1846
11393.553760 -46.359 87.0049
11394.286182 -48.575 110.2393
11395.018604 -49.864 130.3037
11395.751025 -42.374 78.1699
11396.483447 -48.276 74.3770
11397.215869 -51.028 47.4346
11397.948291 -52.213 48.7930
11398.680713 -40.722 66.9980
11399.413135 -44.780 85.6885
11400.145556 -50.012 25.2080
11400.877978 -45.935 127.9766
11401.610400 -42.212 53.0088
11402.342822 -49.425 53.0068
11403.075244 -51.189 95.9033
11403.807665 -47.468 73.8066
11404.540087 -46.930 41.7451
11405.272509 -45.469 80.6592
11406.004931 -46.283 84.6055
11406.737353 -48.096 105.3047
11407.469774 -38.099 60.3242
11408.202196 -46.391 75.1592
11408.934618 -49.453 28.6553
11409.667040 -41.899 38.1689
11410.399462 -41.644 39.8838
11411.131884 -42.559 51.3750
11411.864305 -52.608 54.7139
11412.596727 -45.284 58.7246
11413.329149 -38.266 34.3525
11414.061571 -44.211 56.8789
11414.793993 -49.397 39.1777
11415.526414 -42.866 34.5898
11416.258836 -42.631 48.2314
11416.991258 -41.879 40.7002
11417.723680 -47.501 16.3008
11418.456102 -46.396 69.0967
11419.188524 -41.959 -0.6582
11419.920945 -42.417 0.7412
11420.653367 -46.485 -7.2803
11421.385789 -46.627 -29.4521
11422.118211 -43.801 -6.9658
11422.850633 -48.651 7.9189
11423.583054 -54.185 -80.9561
11424.315476 -55.457 55.0996
11425.047898 -46.346 15.1182
11425.780320 -60.257 78.2510
11426.512742 -52.490 -30.1621
11427.245164 -47.402 -23.0059
11427.977585 -49.637 11.8838
11428.710007 -48.344 47.2480
11429.442429 -51.902 -2.5596
11430.174851 -45.823 117.1650
11430.907273 -44.075 21.1680
11431.639694 -45.478 88.6348
11432.372116 -44.980 80.8232
11433.104538 -47.844 36.9209
11433.836960 -44.492 19.5254
11434.569382 -42.253 53.6611
11435.301803 -47.340 34.1338
11436.034225 -41.944 55.6475
11436.766647 -37.850 12.0635
11437.499069 -40.606 19.9990
11438.231491 -41.584 12.7393
11438.963913 -41.100 6.6748
11439.696334 -38.520 -8.9688
11440.428756 -40.907 -4.9580
11441.161178 -41.039 -17.8770
11441.893600 -40.720 2.0244
11442.626022 -37.827 -28.5576
11443.358443 -37.472 -27.5244
11444.090865 -40.289 -45.7295
11444.823287 -42.482 -58.4414
11445.555709 -38.556 -53.5996
11446.288131 -40.773 -65.2930
11447.020553 -42.590 -94.9941
11447.752974 -44.672 -48.3770
11448.485396 -40.074 -80.2471
11449.217818 -43.016 -104.9922
11449.950240 -42.444 -118.5508
11450.682662 -43.792 -120.7295
11451.415083 -43.799 -135.8232
11452.147505 -43.287 -137.1914
11452.879927 -42.433 169.3506
11453.612349 -46.039 146.7236
11454.344771 -44.747 -171.7461
11455.077192 -43.020 148.5332
11455.809614 -39.772 150.1133
11456.542036 -42.958 123.1328
11457.274458 -44.204 98.8535
11458.006880 -41.249 83.0029
11458.739302 -38.468 90.6846
11459.471723 -37.463 73.1543
11460.204145 -42.131 62.0781
11460.936567 -39.810 61.5742
11461.668989 -38.608 56.2070
11462.401411 -38.116 41.4873
11463.133832 -37.064 45.7432
11463.866254 -36.476 31.1621
11464.598676 -38.919 33.5049
11465.331098 -35.360 22.4707
11466.063520 -37.751 -7.9004
11466.795942 -38.424 -1.2119
11467.528363 -37.284 1.0156
11468.260785 -36.823 -17.1201
11468.993207 -38.181 -31.0781
11469.725629 -41.086 -7.8115
11470.458051 -39.706 -26.2432
11471.190472 -39.007 -26.4180
11471.922894 -39.191 -57.5312
11472.655316 -43.436 -61.8340
11473.387738 -45.741 -62.6621
11474.120160 -39.914 -92.7295
11474.852582 -42.109 -91.8428
11475.585003 -43.560 -102.4717
11476.317425 -44.270 -139.4531
11477.049847 -49.800 -130.4922
11477.782269 -47.118 -149.8135
11478.514691 -46.938 160.0195
11479.247112 -54.586 149.0303
11479.979534 -45.587 -150.4863
11480.711956 -46.833 153.5361
11481.444378 -46.981 99.0771
11482.176800 -45.282 99.5459
11482.909221 -42.177 68.3760
11483.641643 -48.548 40.0537
11484.374065 -48.487 56.0703
11485.106487 -46.454 56.7617
11485.838909 -45.621 15.3799
11486.571331 -44.848 4.2822
11487.303752 -44.694 -4.1035
11488.036174 -43.903 20.1709
11488.768596 -41.110 -2.8818
11489.501018 -43.387 -13.9727
11490.233440 -41.539 -37.8770
11490.965861 -42.721 -19.5020
11491.698283 -41.473 -39.4658
11492.430705 -44.139 -65.6377
11493.163127 -42.724 -79.7686
11493.895549 -42.076 -46.9639
11494.627971 -38.718 -56.1230
11495.360392 -41.723 -109.6992
11496.092814 -45.482 -83.0215
11496.825236 -44.565 -96.2109
11497.557658 -43.113 -97.9678
11498.290080 -41.729 -117.5781
11499.022501 -44.558 -138.9180
11499.754923 -47.001 -135.1348
11500.487345 -43.857 -107.1445
11501.219767 -40.497 -154.1201
11501.952189 -46.615 -143.3223
11502.684610 -44.897 174.9307
11503.417032 -44.250 -174.1572
11504.149454 -46.102 -164.8887
11504.881876 -46.361 138.2285
11505.614298 -45.550 140.1113
11506.346720 -50.212 -126.3115
11507.079141 -43.767 157.0498
11507.811563 -53.736 114.8076
11508.543985 -46.940 95.1318
11509.276407 -50.804 153.5664
11510.008829 -63.834 86.5820
11510.741250 -53.693 99.5303
11511.473672 -50.165 127.7930
11512.206094 -53.236 -75.5869
11512.938516 -47.404 136.2256
11513.670938 -51.384 -174.0820
11514.403360 -57.779 115.1025
11515.135781 -61.821 -78.4307
11515.868203 -51.261 155.8398
11516.600625 -52.978 155.4619
11517.333047 -47.727 118.3379
11518.065469 -49.488 -152.6465
11518.797890 -46.918 171.8232
11519.530312 -47.733 167.3125
11520.262734 -41.806 136.7285
11520.995156 -41.684 150.3496
11521.727578 -42.833 131.9629
11522.460000 -43.539 131.6484
11523.192421 -39.952 124.0664
11523.924843 -41.769 122.1904
11524.657265 -40.217 125.0234
11525.389687 -43.574 117.0986
11526.122109 -40.341 109.8682
11526.854530 -38.549 118.1855
11527.586952 -38.582 98.0215
11528.319374 -38.969 95.3105
11529.051796 -36.418 90.5625
11529.784218 -40.494 97.5771
11530.516639 -38.320 97.5234
11531.249061 -39.115 81.0820
11531.981483 -38.621 74.9502
11532.713905 -38.336 75.4980
11533.446327 -37.570 72.6436
11534.178749 -36.383 58.2529
11534.911170 -36.960 50.3691
11535.643592 -39.781 53.0068
11536.376014 -37.521 47.1641
11537.108436 -39.886 40.7822
11537.840858 -38.188 47.2061
11538.573279 -40.538 34.8965
11539.305701 -38.317 32.8936
11540.038123 -37.874 22.9531
11540.770545 -37.505 33.2285
11541.502967 -42.616 21.6064
11542.235389 -39.379 28.1260
11542.967810 -40.708 -1.1504
11543.700232 -41.923 3.5049
11544.432654 -42.328 -6.6934
11545.165076 -40.915 11.2471
11545.897498 -42.956 -2.7197
11546.629919 -43.477 -19.7285
11547.362341 -51.178 -2.2148
11548.094763 -45.079 14.1836
11548.827185 -49.311 -17.4863
11549.559607 -46.431 -3.7539
11550.292028 -50.462 114.4561
11551.024450 -50.647 51.4287
11551.756872 -52.962 41.9307
11552.489294 -49.182 53.5000
11553.221716 -46.420 108.6260
11553.954138 -41.282 55.3682
11554.686559 -46.708 69.3203
11555.418981 -43.893 61.5029
11556.151403 -41.685 53.4512
11556.883825 -46.036 46.8857
11557.616247 -43.748 68.0420
11558.348668 -39.241 56.9590
11559.081090 -41.062 58.0127
11559.813512 -37.071 45.2500
11560.545934 -42.381 56.2441
11561.278356 -39.528 38.0010
11562.010778 -38.739 39.3477
11562.743199 -38.118 23.7412
11563.475621 -37.853 23.3232
11564.208043 -37.006 13.5273
11564.940465 -37.368 20.6299
11565.672887 -37.872 11.6504
11566.405308 -38.619 4.0820
11567.137730 -37.170 10.6084
11567.870152 -36.887 10.2021
11568.602574 -36.965 -14.1523
11569.334996 -38.034 -7.6133
11570.067418 -37.149 -9.5762
11570.799839 -36.805 -14.1367
11571.532261 -37.862 -21.1094
11572.264683 -39.579 -38.0332
11572.997105 -37.874 -33.1562
11573.729527 -41.920 -18.4102
11574.461948 -37.926 -32.9414
11575.194370 -39.323 -53.5391
11575.926792 -39.968 -34.0352
11576.659214 -45.240 -51.2930
11577.391636 -43.527 -19.8340
11578.124057 -46.469 -37.4922
11578.856479 -52.378 -59.8047
11579.588901 -51.876 -49.9219
11580.321323 -45.386 -25.7383
11581.053745 -51.679 -72.6641
11581.786167 -44.379 -32.4395
11582.518588 -51.763 8.6924
11583.251010 -47.259 -28.8125
11583.983432 -57.702 101.2666
11584.715854 -49.042 -1.1611
11585.448276 -47.016 3.1250
11586.180697 -48.786 1.2051
11586.913119 -51.196 -50.6641
11587.645541 -44.101 11.6719
11588.377963 -42.091 21.4502
11589.110385 -40.769 14.5947
11589.842807 -43.297 0.9834
11590.575228 -45.221 -16.8398
11591.307650 -44.377 -5.6406
11592.040072 -43.665 -6.9023
11592.772494 -48.219 -58.7422
11593.504916 -41.025 -20.9883
11594.237337 -45.678 -30.1016
11594.969759 -41.584 -24.8867
11595.702181 -42.784 -37.3223
11596.434603 -42.301 -30.5527
11597.167025 -41.978 -10.3711
11597.899446 -38.653 -11.5781
11598.631868 -50.574 -10.1719
11599.364290 -42.346 -35.0176
11600.096712 -41.092 -27.4844
11600.829134 -41.917 -41.9180
11601.561556 -46.171 -23.4980
11602.293977 -39.027 -54.3125
11603.026399 -37.887 -35.7598
11603.758821 -41.506 -52.3008
11604.491243 -47.783 -24.7773
11605.223665 -38.797 -47.0117
11605.956086 -49.016 -51.5215
11606.688508 -40.162 -44.3047
11607.420930 -44.037 -60.0820
11608.153352 -43.778 -50.4844
11608.885774 -53.037 -46.9570
11609.618196 -43.733 -72.1016
11610.350617 -43.557 -93.9199
11611.083039 -40.856 -102.5352
11611.815461 -50.151 -56.9355
11612.547883 -44.079 -95.3770
11613.280305 -53.792 -115.5156
11614.012726 -45.117 -73.6797
11614.745148 -41.672 -68.3730
11615.477570 -44.408 -106.3984
11616.209992 -52.806 -2.2207
11616.942414 -49.867 -78.4102
11617.674836 -46.936 -109.7793
11618.407257 -43.740 -70.9785
11619.139679 -48.505 99.3105
11619.872101 -46.436 -1.6514
11620.604523 -45.175 -0.6182
11621.336945 -49.896 -89.7500
11622.069366 -47.483 -60.2305
11622.801788 -45.795 -90.4531
11623.534210 -48.564 -28.4434
11624.266632 -43.212 -75.5742
11624.999054 -48.672 -38.2676
11625.731475 -45.754 -52.9336
11626.463897 -46.784 -38.7070
11627.196319 -48.392 -76.9414
11627.928741 -47.808 -90.5918
11628.661163 -45.132 -101.6133
11629.393585 -46.998 -84.6602
11630.126006 -45.868 -113.1172
11630.858428 -54.635 16.3203
11631.590850 -44.348 -97.3438
11632.323272 -45.384 -120.8320
11633.055694 -46.984 -111.7344
11633.788115 -44.478 -150.8867
11634.520537 -48.661 -142.0410
11635.252959 -41.471 -135.6055
11635.985381 -44.222 178.8047
11636.717803 -47.830 156.7500
11637.450225 -45.622 150.3203
11638.182646 -48.665 128.3477
11638.915068 -44.729 124.1797
11639.647490 -44.096 114.8984
11640.379912 -45.928 82.6914
11641.112334 -50.109 69.4316
11641.844755 -51.354 95.0801
11642.577177 -44.159 58.2832
11643.309599 -52.493 49.5508
11644.042021 -54.844 22.6367
11644.774443 -53.452 50.8125
11645.506864 -43.160 18.9180
11646.239286 -45.281 5.2168
11646.971708 -47.396 -20.1055
11647.704130 -56.582 26.3691
11648.436552 -43.881 11.1523
11649.168974 -43.431 -18.7832
11649.901395 -44.234 -2.9766
11650.633817 -44.960 -1.9180
11651.366239 -44.283 1.3887
11652.098661 -44.116 -70.3613
11652.831083 -46.284 -66.8477
11653.563504 -51.082 -78.8457
11654.295926 -52.432 -54.5391
11655.028348 -48.336 -80.2070
11655.760770 -51.641 -48.1660
11656.493192 -49.161 176.7520
11657.225614 -46.551 47.5293
11657.958035 -58.812 128.8887
11658.690457 -61.180 -20.8105
11659.422879 -52.626 120.7090
11660.155301 -50.430 -109.9238
11660.887723 -59.883 130.9004
11661.620144 -52.562 -138.3496
11662.352566 -54.885 86.8477
11663.084988 -51.015 53.9531
11663.817410 -54.731 -158.6992
11664.549832 -49.727 120.0215
11665.282254 -52.178 117.9258
11666.014675 -49.295 64.3262
11666.747097 -54.437 24.8457
11667.479519 -45.230 54.7441
11668.211941 -44.973 86.5078
11668.944363 -43.963 44.7500
11669.676784 -46.285 45.7012
11670.409206 -43.329 18.9727
11671.141628 -47.448 84.4492
11671.874050 -45.183 33.8184
11672.606472 -48.082 -1.8242
11673.338893 -42.379 19.6270
11674.071315 -43.136 52.4102
11674.803737 -41.264 16.9355
11675.536159 -49.054 45.5840
11676.268581 -45.227 23.3418
11677.001003 -42.939 57.7812
11677.733424 -41.304 14.1348
11678.465846 -43.492 25.9258
11679.198268 -43.306 20.4238
11679.930690 -40.312 20.2676
11680.663112 -40.518 6.3340
11681.395533 -40.347 5.2969
11682.127955 -42.240 22.7734
11682.860377 -43.594 25.2109
11683.592799 -40.486 2.4375
11684.325221 -38.458 -11.8691
11685.057643 -39.592 -3.9531
11685.790064 -41.388 -22.2363
11686.522486 -36.813 -22.4082
11687.254908 -38.139 -12.3242
11687.987330 -40.192 -20.8457
11688.719752 -42.391 -27.8926
11689.452173 -37.770 -34.3105
11690.184595 -41.780 -20.3867
11690.917017 -40.668 -25.7148
11691.649439 -44.556 -38.1348
11692.381861 -41.003 -38.6133
11693.114282 -41.333 -50.6328
11693.846704 -41.252 -50.2969
11694.579126 -45.208 -42.5352
11695.311548 -42.087 -64.9355
11696.043970 -43.618 -80.9316
11696.776392 -44.431 -78.5254
11697.508813 -46.335 -110.4004
11698.241235 -44.558 -111.3633
11698.973657 -44.541 -107.3203
11699.706079 -46.338 -122.9062
11700.438501 -50.282 -104.9434
11701.170922 -49.465 -102.3809
11701.903344 -45.634 -92.0625
11702.635766 -45.433 -85.0156
11703.368188 -55.218 -130.4414
11704.100610 -46.772 -41.1543
11704.833032 -50.435 -28.6797
11705.565453 -52.986 -114.4082
11706.297875 -54.226 22.9219
11707.030297 -46.667 -57.0137
11707.762719 -44.925 -41.3008
11708.495141 -46.599 -19.2324
11709.227562 -48.097 -22.2871
11709.959984 -44.354 -62.8496
11710.692406 -46.800 -41.9180
11711.424828 -43.857 -40.4941
11712.157250 -49.619 -47.5215
11712.889672 -46.611 -72.2383
11713.622093 -48.407 -81.3008
11714.354515 -43.861 -69.5938
11715.086937 -44.442 -79.7676
11715.819359 -42.492 -65.9141
11716.551781 -44.784 -84.0176
11717.284202 -44.017 -98.6641
11718.016624 -47.642 -58.4688
11718.749046 -46.177 -82.2363
11719.481468 -47.786 -109.0684
11720.213890 -46.374 -87.6328
11720.946311 -47.095 -75.3457
11721.678733 -44.386 -96.6836
11722.411155 -46.930 -119.4199
11723.143577 -47.841 -113.5078
11723.875999 -53.459 -161.7461
11724.608421 -44.320 -109.9336
11725.340842 -48.676 -133.5098
11726.073264 -49.449 -103.1035
11726.805686 -50.394 -43.4902
11727.538108 -47.203 -75.8145
11728.270530 -61.965 162.6582
11729.002951 -56.534 -59.1113
11729.735373 -50.982 -12.8789
11730.467795 -52.943 -65.8984
11731.200217 -50.699 -144.0781
11731.932639 -48.450 -135.1367
11732.665061 -56.633 -102.8711
11733.397482 -46.439 -109.5684
11734.129904 -47.771 -150.0898
11734.862326 -49.678 -134.6445
11735.594748 -57.453 167.2031
11736.327170 -51.719 -127.2949
11737.059591 -54.834 -94.9629
11737.792013 -46.424 -108.4551
11738.524435 -55.883 -76.8320
11739.256857 -55.982 -160.7031
11739.989279 -48.201 162.8027
11740.721700 -53.557 175.3555
11741.454122 -65.140 -143.7812
11742.186544 -49.991 -144.4004
11742.918966 -46.928 149.8945
11743.651388 -48.391 166.3027
11744.383810 -53.485 104.2051
11745.116231 -51.763 161.2305
11745.848653 -47.691 88.7500
11746.581075 -48.827 85.4922
11747.313497 -46.748 46.6055
11748.045919 -55.945 57.2656
11748.778340 -49.668 79.5469
11749.510762 -51.708 66.2031
11750.243184 -47.900 2.3438
11750.975606 -50.969 43.2930
11751.708028 -46.692 25.4316
11752.440450 -50.185 57.0664
11753.172871 -42.919 -1.0742
11753.905293 -45.486 0.5840
11754.637715 -48.938 -28.2402
11755.370137 -44.306 -32.7852
11756.102559 -45.157 -6.9648
11756.834980 -45.235 -60.4727
11757.567402 -41.979 -40.8047
11758.299824 -44.717 -78.3672
11759.032246 -46.128 -53.8555
11759.764668 -42.471 -79.8262
11760.497090 -41.374 -66.6816
11761.229511 -41.131 -92.6543
11761.961933 -42.930 -86.2129
11762.694355 -40.664 -125.8496
11763.426777 -44.942 -136.1270
11764.159199 -39.785 -135.8984
11764.891620 -41.244 -107.1152
11765.624042 -40.227 -138.7617
11766.356464 -42.052 -149.8672
11767.088886 -41.575 -148.9609
11767.821308 -41.176 -139.9043
11768.553729 -39.210 -148.5488
11769.286151 -44.638 -174.2715
11770.018573 -41.271 155.6465
11770.750995 -46.316 172.7656
11771.483417 -41.156 154.8359
11772.215839 -41.701 162.8496
11772.948260 -41.576 156.4219
11773.680682 -42.512 124.9727
11774.413104 -39.953 121.5488
11775.145526 -42.549 127.3633
11775.877948 -40.178 98.3027
11776.610369 -45.193 61.1992
11777.342791 -44.798 91.3477
11778.075213 -40.087 101.5234
11778.807635 -41.936 87.2344
11779.540057 -44.376 63.3066
11780.272479 -42.373 92.9844
11781.004900 -43.504 49.8652
11781.737322 -41.978 66.5938
11782.469744 -42.277 22.9395
11783.202166 -45.252 45.9219
11783.934588 -43.889 31.0352
11784.667009 -47.084 -16.2793
11785.399431 -43.348 -12.4297
11786.131853 -51.486 11.3008
11786.864275 -44.943 -27.3242
11787.596697 -49.355 23.4336
11788.329118 -40.960 -31.5742
11789.061540 -46.824 -17.3223
11789.793962 -43.549 6.1367
11790.526384 -43.452 -43.3945
11791.258806 -41.313 -47.2070
11791.991228 -42.951 -31.9297
11792.723649 -47.989 -18.6699
11793.456071 -51.667 11.9570
11794.188493 -41.730 -62.0918
11794.920915 -52.466 -69.6895
11795.653337 -54.450 -48.8672
11796.385758 -50.582 -95.2383
11797.118180 -48.060 -69.7422
11797.850602 -52.127 -101.1406
11798.583024 -50.040 -91.2793
11799.315446 -45.040 92.2773
11800.047868 -44.790 -88.9961
11800.780289 -46.200 -141.2734
11801.512711 -48.199 -169.4004
11802.245133 -45.311 -178.1387
11802.977555 -49.884 -155.5391
11803.709977 -45.117 176.5742
11804.442398 -45.291 132.2559
11805.174820 -39.746 99.0176
11805.907242 -56.254 129.0430
11806.639664 -48.811 152.7598
11807.372086 -46.335 128.6328
11808.104508 -50.759 116.1797
11808.836929 -56.377 94.7324
11809.569351 -44.107 109.6406
11810.301773 -44.181 76.2500
11811.034195 -39.347 72.9727
11811.766617 -70.898 40.4922
11812.499038 -46.998 65.5449
11813.231460 -46.389 51.3418
11813.963882 -54.594 10.3164
11814.696304 -47.737 2.9355
11815.428726 -46.859 47.1660
11816.161147 -44.525 10.4023
11816.893569 -38.817 29.7988
11817.625991 -48.224 -63.9023
11818.358413 -51.293 -11.1836
11819.090835 -45.838 18.1953
11819.823257 -54.786 -23.3281
11820.555678 -46.671 -52.8984
11821.288100 -55.678 -4.4941
11822.020522 -55.741 -58.9805
11822.752944 -40.784 23.0801
11823.485366 -44.961 -135.6113
11824.217787 -66.073 26.3633
11824.950209 -51.795 -58.8516
11825.682631 -51.567 -161.4824
11826.415053 -46.059 -167.8008
11827.147475 -52.841 125.6484
11827.879897 -55.889 67.3770
11828.612318 -38.649 45.1348
11829.344740 -46.626 158.7832
11830.077162 -47.869 100.3418
11830.809584 -43.052 98.4922
11831.542006 -44.660 95.1152
11832.274427 -43.092 91.5527
11833.006849 -40.777 58.2695
11833.739271 -40.954 68.3945
11834.471693 -35.157 35.9434
11835.204115 -47.321 44.6992
11835.936536 -39.225 52.1875
11836.668958 -39.962 27.9434
11837.401380 -41.841 57.8965
11838.133802 -43.395 15.2832
11838.866224 -39.711 8.5078
11839.598646 -39.211 2.0508
11840.331067 -34.241 -1.2852
11841.063489 -42.157 -29.0430
11841.795911 -39.412 -8.7773
11842.528333 -39.346 -22.3691
11843.260755 -42.405 -40.4023
11843.993176 -40.155 -55.4844
11844.725598 -40.498 -39.0684
11845.458020 -42.391 -63.1406
11846.190442 -33.724 -40.9180
11846.922864 -41.005 -109.7207
11847.655286 -43.422 -76.9043
11848.387707 -43.888 -70.9844
11849.120129 -43.274 -143.5781
11849.852551 -43.173 -137.3809
11850.584973 -47.808 -114.9043
11851.317395 -50.060 -176.0234
11852.049816 -38.199 -47.3359
11852.782238 -43.039 160.7949
11853.514660 -47.750 104.9512
11854.247082 -45.438 101.1172
11854.979504 -48.404 134.7637
11855.711926 -40.913 115.1328
11856.444347 -44.410 52.5469
11857.176769 -56.153 16.1504
11857.909191 -38.514 -18.4414
11858.641613 -41.765 102.7637
11859.374035 -42.972 44.5195
11860.106456 -50.591 55.8398
11860.838878 -43.330 60.8633
11861.571300 -42.377 31.5137
11862.303722 -39.817 8.0508
11863.036144 -39.700 -12.4590
11863.768565 -33.016 -43.3418
11864.500987 -47.871 -37.5879
11865.233409 -39.128 -42.4141
11865.965831 -39.226 -46.0215
11866.698253 -46.938 -61.2871
11867.430675 -39.730 -65.7676
11868.163096 -38.319 -71.6602
11868.895518 -42.142 -94.1875
11869.627940 -32.348 -85.2715
11870.360362 -39.978 -125.0215
11871.092784 -38.870 -113.4492
11871.825205 -37.887 -119.9629
11872.557627 -39.803 -149.2812
11873.290049 -41.869 -141.0273
11874.022471 -39.093 -151.6289
11874.754893 -38.966 -139.0469
11875.487315 -34.751 -112.2285
11876.219736 -38.317 167.5762
11876.952158 -46.265 -174.3145
11877.684580 -40.556 155.6016
11878.417002 -37.770 114.0820
11879.149424 -40.388 117.1777
11879.881845 -44.333 138.2480
11880.614267 -41.611 113.9766
11881.346689 -47.106 -121.6387
11882.079111 -33.709 102.2656
11882.811533 -41.873 67.3672
11883.543954 -47.483 94.0840
11884.276376 -33.748 60.7734
11885.008798 -37.161 63.1426
11885.741220 -39.701 63.2480
11886.473642 -42.589 57.7285
11887.206064 -38.565 -59.4375
11887.938485 -38.591 38.4258
11888.670907 -39.757 -0.6816
11889.403329 -39.373 -3.9883
11890.135751 -41.512 21.1914
11890.868173 -41.832 -8.5781
11891.600594 -40.468 -22.8242
11892.333016 -41.670 -17.1406
11893.065438 -34.524 -115.5488
11893.797860 -50.042 -53.5234
11894.530282 -43.536 -55.4824
11895.262704 -49.004 -111.4238
11895.995125 -40.029 -10.0156
11896.727547 -41.948 -103.9648
11897.459969 -44.446 -143.2988
11898.192391 -42.978 -113.1816
11898.924813 -33.443 -121.7871
11899.657234 -65.802 127.1426
11900.389656 -50.264 -149.9844
11901.122078 -53.668 123.9453
11901.854500 -46.745 92.2773
11902.586922 -45.945 80.3008
11903.319344 -48.081 168.0430
11904.051765 -49.855 153.4727
11904.784187 -35.676 -125.6719
11905.516609 -41.747 111.2852
11906.249031 -51.442 61.5391
11906.981453 -49.339 122.6094
11907.713874 -41.365 21.2246
11908.446296 -37.331 20.5273
11909.178718 -39.592 -8.5840
11909.911140 -42.103 8.5684
11910.643562 -36.173 -146.6914
11911.375983 -47.392 -69.0586
11912.108405 -45.630 39.0039
11912.840827 -43.234 3.6387
11913.573249 -43.421 -22.3594
11914.305671 -54.317 -95.8535
11915.038093 -37.211 -90.0469
11915.770514 -38.216 -57.1191
11916.502936 -40.740 -169.8242
11917.235358 -43.214 -22.2734
11917.967780 -41.314 -111.1562
11918.700202 -52.026 -30.6367
11919.432623 -43.123 134.7090
11920.165045 -39.886 -126.4707
11920.897467 -47.933 -112.4941
11921.629889 -40.244 -101.4277
11922.362311 -35.681 -170.1074
11923.094733 -52.878 26.5664
11923.827154 -46.708 73.6406
11924.559576 -42.376 136.4922
11925.291998 -35.715 -7.4180
11926.024420 -49.351 -56.9961
11926.756842 -53.155 138.4434
11927.489263 -56.947 -79.4492
11928.221685 -41.311 136.0254
11928.954107 -40.232 64.5566
11929.686529 -36.692 69.7656
11930.418951 -54.298 33.6035
11931.151372 -40.118 -26.6230
11931.883794 -47.253 -97.3320
11932.616216 -45.655 15.8398
11933.348638 -41.776 -82.4316
11934.081060 -48.890 38.6328
11934.813482 -41.470 -9.6621
11935.545903 -44.434 -7.9883
11936.278325 -41.708 -157.4629
11937.010747 -37.085 -137.7656
11937.743169 -36.144 -38.6855
11938.475591 -41.960 18.8281
11939.208012 -38.671 -136.4805
11939.940434 -39.644 120.2930
11940.672856 -39.469 -66.3965
11941.405278 -45.310 -166.7168
11942.137700 -37.314 -59.6738
11942.870122 -33.491 -67.5371
11943.602543 -48.018 83.8516
11944.334965 -40.953 -164.0352
11945.067387 -34.749 -77.3555
11945.799809 -31.869 138.4082
11946.532231 -40.274 -147.7402
11947.264652 -36.926 118.1230
11947.997074 -43.639 163.5488
11948.729496 -44.211 -156.1895
11949.461918 -34.604 -87.3926
11950.194340 -40.425 173.2637
11950.926762 -44.001 -176.4180
11951.659183 -44.117 80.6504
11952.391605 -43.770 9.6973
11953.124027 -33.818 167.1758
11953.856449 -33.561 86.0293
11954.588871 -33.838 -142.8594
11955.321292 -39.838 35.2090
11956.053714 -38.341 126.0312
11956.786136 -33.696 89.9375
11957.518558 -36.311 121.6094
11958.250980 -33.067 -68.6797
11958.983401 -33.817 57.7012
11959.715823 -39.859 163.5664
11960.448245 -40.814 143.1641
11961.180667 -41.698 -159.8262
11961.913089 -36.852 159.7441
11962.645511 -48.390 -19.9922
11963.377932 -34.071 82.9043
11964.110354 -53.875 89.9238
11964.842776 -27.613 65.4512
11965.575198 -36.004 73.2266
11966.307620 -32.043 154.1543
11967.040041 -33.273 -7.6211
11967.772463 -33.308 62.0703
11968.504885 -35.541 34.7754
11969.237307 -29.945 90.7188
11969.969729 -35.221 16.2324
11970.702151 -30.804 36.2480
11971.434572 -35.684 64.0059
11972.166994 -43.919 3.9727
11972.899416 -34.757 77.1270
11973.631838 -34.423 53.2480
11974.364260 -35.784 93.4570
11975.096681 -36.384 -7.1250
11975.829103 -33.612 37.0234
11976.561525 -44.903 -52.1309
11977.293947 -41.324 -79.6348
11978.026369 -38.970 -74.8984
11978.758790 -31.370 -22.5996
11979.491212 -34.236 83.0703
11980.223634 -38.406 78.1816
11980.956056 -34.225 54.4863
11981.688478 -44.831 148.0039
11982.420900 -45.097 127.2227
11983.153321 -46.898 -18.5469
11983.885743 -43.790 -80.4062
11984.618165 -35.980 69.4062
11985.350587 -39.591 44.0020
11986.083009 -30.545 50.4453
11986.815430 -34.484 50.5449
11987.547852 -44.380 34.6602
11988.280274 -38.104 41.3320
11989.012696 -41.472 -80.3789
11989.745118 -32.569 60.4121
11990.477540 -30.558 -7.4375
11991.209961 -43.235 -22.6270
11991.942383 -31.379 1.1211
11992.674805 -42.361 -11.8398
11993.407227 -30.379 34.6348
11994.139649 -35.736 -93.7324
11994.872070 -43.795 12.6348
11995.604492 -32.756 107.3359
11996.336914 -52.017 76.1914
11997.069336 -34.927 35.3750
11997.801758 -35.830 -109.9004
11998.534180 -36.161 41.0684
11999.266601 -33.838 -0.1426
11999.999023 -45.556 44.8555
12000.731445 -34.050 134.8555
12001.463867 -50.790 148.6680
12002.196289 -42.877 -163.8262
12002.928710 -39.779 40.5215
12003.661132 -38.546 -26.0762
12004.393554 -39.836 14.3008
12005.125976 -48.565 -112.6406
12005.858398 -39.193 -117.9297
12006.590819 -47.185 92.5762
12007.323241 -52.870 118.4062
12008.055663 -36.914 34.2852
12008.788085 -38.591 143.3027
12009.520507 -41.999 3.0508
12010.252929 -40.958 48.7344
12010.985350 -41.105 13.0762
12011.717772 -37.586 64.7539
12012.450194 -45.551 119.1582
12013.182616 -42.142 -166.3945
12013.915038 -35.818 -71.3398
12014.647459 -47.842 -61.7129
12015.379881 -34.564 25.8086
12016.112303 -37.545 73.4922
12016.844725 -39.252 153.2598
12017.577147 -48.365 86.9453
12018.309569 -50.002 84.6250
12019.041990 -44.580 -41.4785
12019.774412 -57.659 174.0684
12020.506834 -49.141 -58.8281
12021.239256 -46.701 -112.7930
12021.971678 -36.616 -171.1875
12022.704099 -38.171 170.3711
12023.436521 -47.327 80.5137
12024.168943 -42.546 67.3574
12024.901365 -33.782 96.8027
12025.633787 -36.574 78.0547
12026.366208 -47.860 27.5898
12027.098630 -31.880 67.3145
12027.831052 -35.092 48.3262
12028.563474 -32.720 97.8398
12029.295896 -37.594 5.2480
12030.028318 -43.499 70.1445
12030.760739 -34.327 16.2539
12031.493161 -38.139 79.4473
12032.225583 -35.101 60.6855
12032.958005 -50.500 28.2754
12033.690427 -37.724 7.9238
12034.422848 -38.697 52.9492
12035.155270 -35.892 12.0137
12035.887692 -37.770 44.7891
12036.620114 -36.194 27.5547
12037.352536 -47.169 -38.3848
12038.084958 -47.879 26.7031
12038.817379 -39.215 40.3242
12039.549801 -32.655 3.6113
12040.282223 -35.441 20.7051
12041.014645 -50.493 -84.2871
12041.747067 -29.028 57.9297
12042.479488 -32.847 18.5371
12043.211910 -43.929 71.3398
12043.944332 -36.503 115.5430
12044.676754 -45.766 74.9805
12045.409176 -40.842 97.6250
12046.141598 -37.202 -3.7773
12046.874019 -40.585 40.1152
12047.606441 -40.409 39.9395
12048.338863 -36.680 61.6543
12049.071285 -44.341 -19.0371
12049.803707 -34.871 24.1328
12050.536128 -39.818 39.9238
12051.268550 -48.161 -121.7500
12052.000972 -51.019 75.1191
12052.733394 -34.151 32.4766
12053.465816 -33.589 -57.7070
12054.198237 -40.031 -25.9922
12054.930659 -44.568 16.0078
12055.663081 -41.862 -50.1621
12056.395503 -39.140 -31.4141
12057.127925 -40.664 -25.8633
12057.860347 -41.181 72.4336
12058.592768 -33.342 -97.1523
12059.325190 -36.067 -30.4551
12060.057612 -36.360 -115.0762
12060.790034 -42.756 -55.6113
12061.522456 -35.770 -72.0566
12062.254877 -43.835 -6.5996
12062.987299 -49.061 -111.2422
12063.719721 -40.707 -40.7832
12064.452143 -44.866 -42.4883
12065.184565 -43.983 -130.1973
12065.916987 -51.005 -127.9922
12066.649408 -38.799 -139.5762
12067.381830 -56.623 11.6348
12068.114252 -41.066 70.2637
12068.846674 -49.822 -125.4785
12069.579096 -49.387 -105.9082
12070.311517 -45.180 128.8477
12071.043939 -44.313 116.0195
12071.776361 -45.229 -173.0449
12072.508783 -45.755 38.1992
12073.241205 -45.320 84.5547
12073.973626 -45.713 -96.4512
12074.706048 -53.522 90.4336
12075.438470 -45.180 77.7480
12076.170892 -37.546 23.8184
12076.903314 -41.116 11.0195
12077.635736 -42.248 -68.0586
12078.368157 -39.333 -12.7832
12079.100579 -42.546 -0.4434
12079.833001 -48.730 2.0117
12080.565423 -42.927 -130.5898
12081.297845 -55.152 -54.5410
12082.030266 -46.399 -21.3418
12082.762688 -41.774 -51.6250
12083.495110 -43.851 -99.7637
12084.227532 -42.859 -8.8008
12084.959954 -48.703 -102.1406
12085.692376 -39.885 -93.1016
12086.424797 -39.226 -110.6484
12087.157219 -46.924 -142.9727
12087.889641 -40.215 -74.0664
12088.622063 -39.558 -99.8867
12089.354485 -40.636 175.7324
12090.086906 -39.779 -155.7344
12090.819328 -41.866 -97.0371
12091.551750 -41.671 -154.3594
12092.284172 -43.989 -159.0820
12093.016594 -44.266 134.6816
12093.749016 -47.947 -155.8730
12094.481437 -42.547 -159.5566
12095.213859 -44.021 -142.9434
12095.946281 -44.658 155.0234
12096.678703 -45.557 146.0566
12097.411125 -44.724 155.5020
12098.143546 -42.404 136.6465
12098.875968 -46.323 126.2383
12099.608390 -44.854 102.0840
12100.340812 -46.653 126.1602
12101.073234 -53.172 108.1250
12101.805655 -41.650 76.1016
12102.538077 -44.622 81.9434
12103.270499 -48.072 126.6914
12104.002921 -45.895 43.9160
12104.735343 -45.084 51.5020
12105.467765 -46.233 -6.2129
12106.200186 -42.169 45.4609
12106.932608 -40.709 14.5703
12107.665030 -43.921 22.1875
12108.397452 -47.511 -15.0020
12109.129874 -41.198 -36.2461
12109.862295 -42.596 -28.4219
12110.594717 -42.435 -12.6621
12111.327139 -47.821 -84.8770
12112.059561 -41.763 -52.3945
12112.791983 -43.751 -60.2207
12113.524405 -44.484 -68.8242
12114.256826 -45.144 -51.2598
12114.989248 -43.553 -93.4121
12115.721670 -42.391 -77.0801
12116.454092 -51.386 172.5977
12117.186514 -54.578 -113.9668
12117.918935 -45.738 -137.8125
12118.651357 -48.753 -140.9805
12119.383779 -48.542 161.3027
12120.116201 -47.599 174.3887
12120.848623 -40.166 -166.7051
12121.581044 -44.117 -170.2207
12122.313466 -50.584 156.1719
12123.045888 -44.046 172.1875
12123.778310 -40.555 150.0684
12124.510732 -46.423 159.1406
12125.243154 -40.089 98.6328
12125.975575 -44.878 132.3223
12126.707997 -44.111 153.8828
12127.440419 -44.833 99.2715
12128.172841 -40.511 95.5879
12128.905263 -42.651 78.0059
12129.637684 -42.678 109.6074
12130.370106 -44.313 70.7695
12131.102528 -42.590 69.3320
12131.834950 -43.106 63.8945
12132.567372 -42.485 64.9180
12133.299794 -47.171 41.5938
12134.032215 -43.065 41.6016
12134.764637 -46.928 62.8555
12135.497059 -46.252 73.9336
12136.229481 -57.135 48.4688
12136.961903 -41.277 52.8906
12137.694324 -49.998 76.7305
12138.426746 -51.491 45.1816
12139.159168 -47.825 71.5938
12139.891590 -45.398 52.1406
12140.624012 -50.434 56.9570
12141.356434 -47.449 70.9688
12142.088855 -52.128 85.8809
12142.821277 -44.232 52.8418
12143.553699 -51.382 52.3340
12144.286121 -43.597 85.1562
12145.018543 -45.619 89.3398
12145.750964 -45.351 35.6074
12146.483386 -44.937 71.4492
12147.215808 -43.810 54.4805
12147.948230 -43.069 49.2363
12148.680652 -40.650 25.6523
12149.413073 -44.318 36.8945
12150.145495 -44.844 25.9219
12150.877917 -43.033 17.4062
12151.610339 -42.103 -3.8516
12152.342761 -45.521 16.3887
12153.075183 -42.651 -9.9980
12153.807604 -42.074 -19.8613
12154.540026 -40.197 -30.6621
12155.272448 -46.132 -41.8965
12156.004870 -45.506 -22.7910
12156.737292 -42.079 -48.3652
12157.469713 -38.930 -47.1602
12158.202135 -44.614 -57.4414
12158.934557 -44.324 -61.0176
12159.666979 -42.703 -91.8594
12160.399401 -43.036 -81.1387
12161.131823 -44.703 -130.8887
12161.864244 -46.785 -134.1211
12162.596666 -44.621 -105.7656
12163.329088 -46.271 -154.7773
12164.061510 -49.220 -101.1113
12164.793932 -48.072 -135.5723
12165.526353 -47.546 -166.8125
12166.258775 -47.150 -101.4766
12166.991197 -48.681 156.0625
12167.723619 -49.813 135.6699
12168.456041 -48.290 115.5879
12169.188462 -53.335 157.9824
12169.920884 -44.874 126.7480
12170.653306 -62.058 77.6309
12171.385728 -48.813 74.0801
12172.118150 -64.874 26.7031
12172.850572 -44.933 87.5195
12173.582993 -53.854 33.2285
12174.315415 -52.817 106.8711
12175.047837 -49.949 64.0625
12175.780259 -54.434 11.3887
12176.512681 -45.808 42.1230
12177.245102 -53.063 -19.6973
12177.977524 -54.328 -39.5078
12178.709946 -57.155 39.5625
12179.442368 -44.795 -16.7578
12180.174790 -53.086 -60.7246
12180.907212 -51.565 -104.5996
12181.639633 -59.889 -116.3613
12182.372055 -50.718 -91.5781
12183.104477 -56.863 -161.4238
12183.836899 -50.339 -144.6270
12184.569321 -49.993 170.2188
12185.301742 -46.234 -154.1699
12186.034164 -54.355 157.8535
12186.766586 -42.926 175.5098
12187.499008 -46.202 161.2070
12188.231430 -45.165 145.9746
12188.963852 -41.829 130.0488
12189.696273 -43.424 142.7070
12190.428695 -40.974 131.6719
12191.161117 -45.097 107.7598
12191.893539 -41.776 115.5859
12192.625961 -42.441 122.0684
12193.358382 -39.018 111.3184
12194.090804 -39.082 96.8145
12194.823226 -41.128 94.6152
12195.555648 -39.288 87.9609
12196.288070 -37.612 79.1211
12197.020491 -38.935 84.7871
12197.752913 -39.641 76.8008
12198.485335 -37.833 62.0723
12199.217757 -38.604 59.1094
12199.950179 -39.554 71.9473
12200.682601 -37.932 61.4258
12201.415022 -40.167 45.5391
12202.147444 -38.099 43.8984
12202.879866 -38.708 36.1660
12203.612288 -39.195 41.7305
12204.344710 -40.604 32.0898
12205.077131 -40.399 31.7871
12205.809553 -43.107 29.8945
12206.541975 -42.840 6.4688
12207.274397 -41.377 11.8047
12208.006819 -42.023 11.4219
12208.739241 -42.732 -3.4219
12209.471662 -46.489 5.4258
12210.204084 -43.456 -3.8789
12210.936506 -45.979 -29.5156
12211.668928 -43.708 -38.0352
12212.401350 -44.804 -27.9043
12213.133771 -45.182 -40.8984
12213.866193 -46.686 -9.3809
12214.598615 -48.466 -29.3477
12215.331037 -49.095 -73.9082
12216.063459 -55.553 -41.3711
12216.795880 -51.967 -35.4121
12217.528302 -52.720 -92.5117
12218.260724 -59.095 86.2207
12218.993146 -59.397 -139.7773
12219.725568 -49.835 65.4492
12220.457990 -54.612 170.0840
12221.190411 -53.808 106.9473
12221.922833 -54.541 64.4863
12222.655255 -56.944 155.0664
12223.387677 -56.884 98.8926
12224.120099 -50.726 85.0410
12224.852520 -50.050 83.8125
12225.584942 -53.543 97.5859
12226.317364 -53.731 87.7539
12227.049786 -48.607 75.2480
12227.782208 -55.433 55.6680
12228.514630 -49.451 42.8008
12229.247051 -49.577 108.1445
12229.979473 -51.503 81.1406
12230.711895 -55.974 78.8262
12231.444317 -50.241 87.9746
12232.176739 -43.376 93.7305
12232.909160 -49.988 80.8750
12233.641582 -44.858 54.0527
12234.374004 -45.578 78.5645
12235.106426 -43.497 65.6895
12235.838848 -43.044 55.8887
12236.571270 -42.414 64.2715
12237.303691 -41.675 53.0859
12238.036113 -43.177 62.8496
12238.768535 -41.821 54.9805
12239.500957 -43.539 56.0117
12240.233379 -39.413 51.4609
12240.965800 -38.861 50.6973
12241.698222 -40.120 38.5527
12242.430644 -40.640 48.7012
12243.163066 -40.324 21.8594
12243.895488 -39.131 39.5332
12244.627909 -39.037 38.4102
12245.360331 -37.921 15.6270
12246.092753 -39.459 20.8027
12246.825175 -38.596 13.2676
12247.557597 -39.678 -13.3086
12248.290019 -39.915 4.3398
12249.022440 -39.670 -7.8145
12249.754862 -41.704 -21.5020
12250.487284 -38.743 -17.4551
12251.219706 -42.753 -36.6699
12251.952128 -41.468 -26.8945
12252.684549 -43.000 -42.3633
12253.416971 -44.657 -35.1133
12254.149393 -43.828 -59.3242
12254.881815 -45.380 -58.1406
12255.614237 -47.617 -63.6914
12256.346659 -50.197 -18.8438
12257.079080 -46.606 -89.2012
12257.811502 -53.197 -127.3438
12258.543924 -49.348 -160.5137
12259.276346 -47.735 -154.5039
12260.008768 -54.779 146.0508
12260.741189 -52.492 153.3848
12261.473611 -45.541 154.0762
12262.206033 -46.570 115.9121
12262.938455 -45.196 133.5137
12263.670877 -44.906 82.8438
12264.403298 -42.406 104.2617
12265.135720 -42.343 95.9375
12265.868142 -43.205 80.0371
12266.600564 -41.395 59.7383
12267.332986 -39.354 68.3359
12268.065408 -39.336 46.9434
12268.797829 -41.147 37.7285
12269.530251 -39.738 53.5273
12270.262673 -40.515 42.0176
12270.995095 -40.243 31.0684
12271.727517 -41.438 26.6367
12272.459938 -40.997 22.8047
12273.192360 -40.401 22.5449
12273.924782 -38.717 6.8477
12274.657204 -42.424 -0.8379
12275.389626 -38.556 7.1426
12276.122048 -42.410 17.4336
12276.854469 -42.806 -4.3613
12277.586891 -41.651 1.5273
12278.319313 -40.277 -23.3418
12279.051735 -40.130 -10.4043
12279.784157 -41.495 -15.2227
12280.516578 -42.268 -32.1562
12281.249000 -42.640 -22.0312
12281.981422 -42.624 -16.9297
12282.713844 -48.006 -42.8320
12283.446266 -43.877 -31.5820
12284.178688 -42.750 -27.3281
12284.911109 -47.808 -27.1465
12285.643531 -40.798 -40.9609
12286.375953 -50.294 -29.4395
12287.108375 -42.722 -37.2129
12287.840797 -53.106 -82.9062
12288.573218 -47.799 -15.6543
12289.305640 -52.231 -67.6172
12290.038062 -49.295 -57.9707
12290.770484 -52.038 -30.3965
12291.502906 -49.502 -39.4844
12292.235327 -47.867 -123.7422
12292.967749 -61.734 -48.5859
12293.700171 -47.971 -53.4355
12294.432593 -52.470 -174.5879
12295.165015 -52.378 166.6602
12295.897437 -54.966 -71.5957
12296.629858 -48.364 120.4961
12297.362280 -57.284 -74.1406
12298.094702 -48.314 116.1328
12298.827124 -49.584 64.2617
12299.559546 -44.643 82.6934
12300.291967 -44.631 76.5410
12301.024389 -43.633 93.2734
12301.756811 -41.565 81.9297
12302.489233 -39.827 50.2656
12303.221655 -42.686 43.2871
12303.954077 -41.270 69.4766
12304.686498 -38.702 48.9492
12305.418920 -36.957 51.7285
12306.151342 -36.836 43.3301
12306.883764 -36.607 42.9375
12307.616186 -39.645 39.1465
12308.348607 -36.660 30.5176
12309.081029 -35.927 10.7832
12309.813451 -37.198 25.9746
12310.545873 -36.165 8.0547
12311.278295 -36.037 11.6543
12312.010716 -38.928 -0.2852
12312.743138 -38.505 -3.8105
12313.475560 -41.104 -10.6367
12314.207982 -36.321 -11.6016
12314.940404 -38.069 -41.9219
12315.672826 -39.143 -16.3027
12316.405247 -37.876 -49.2168
12317.137669 -38.847 -41.4531
12317.870091 -41.332 -49.0137
12318.602513 -41.437 -65.3652
12319.334935 -43.214 -64.4902
12320.067356 -40.403 -84.6895
12320.799778 -44.189 -86.9043
12321.532200 -65.718 96.9277
12322.264622 -43.201 -93.7188
12322.997044 -48.026 -18.7910
12323.729466 -55.942 -56.8516
12324.461887 -54.993 164.5273
12325.194309 -50.690 -169.5645
12325.926731 -51.815 41.6074
12326.659153 -51.240 106.2598
12327.391575 -43.813 82.1875
12328.123996 -49.772 54.4941
12328.856418 -45.053 42.0918
12329.588840 -41.408 51.9434
12330.321262 -44.217 33.4883
12331.053684 -45.972 41.4434
12331.786106 -42.080 24.1270
12332.518527 -47.323 35.3398
12333.250949 -38.750 42.8613
12333.983371 -41.261 -18.1562
12334.715793 -38.349 -24.9492
12335.448215 -39.133 7.1465
12336.180636 -40.002 1.2246
12336.913058 -40.785 -10.6699
12337.645480 -39.227 -19.6035
12338.377902 -44.302 -36.6621
12339.110324 -40.517 -21.6270
12339.842745 -40.302 -48.1504
12340.575167 -46.706 -36.0137
12341.307589 -40.574 -29.3477
12342.040011 -40.638 -27.2598
12342.772433 -41.790 -34.3184
12343.504855 -47.639 -5.5547
12344.237276 -46.301 -59.6973
12344.969698 -44.628 -6.0742
12345.702120 -43.727 -32.7266
12346.434542 -44.061 -27.3711
12347.166964 -43.873 -35.7266
12347.899385 -50.107 6.3945
12348.631807 -41.692 -15.9863
12349.364229 -45.167 -38.8281
12350.096651 -44.352 -87.4922
12350.829073 -41.867 0.2031
12351.561495 -42.476 -18.3730
12352.293916 -40.359 -29.9238
12353.026338 -38.061 -19.3945
12353.758760 -38.374 -25.8008
12354.491182 -40.596 -45.8105
12355.223604 -41.123 -31.1074
12355.956025 -39.218 -40.4707
12356.688447 -37.238 -21.6602
12357.420869 -39.529 -52.5469
12358.153291 -37.808 -55.2695
12358.885713 -36.691 -52.6367
12359.618134 -41.198 -58.5938
12360.350556 -41.053 -50.8945
12361.082978 -37.919 -68.2383
12361.815400 -44.002 -93.9629
12362.547822 -40.493 -69.5586
12363.280244 -39.840 -82.8379
12364.012665 -38.929 -86.2461
12364.745087 -44.052 -106.7363
12365.477509 -45.346 -84.4434
12366.209931 -39.319 -112.8926
12366.942353 -46.603 -112.9082
12367.674774 -41.663 -151.9199
12368.407196 -44.499 -101.5566
12369.139618 -40.875 -166.3848
12369.872040 -43.196 -146.5352
12370.604462 -44.084 -127.7715
12371.336884 -50.588 48.0879
12372.069305 -56.027 156.0742
12372.801727 -55.617 175.1523
12373.534149 -44.104 116.9180
12374.266571 -49.714 27.4824
12374.998993 -57.562 115.4941
12375.731414 -56.249 -69.4199
12376.463836 -45.801 38.9062
12377.196258 -47.584 -2.9453
12377.928680 -47.100 -8.4102
12378.661102 -42.741 -60.8828
12379.393524 -61.153 5.5195
12380.125945 -43.796 -83.9785
12380.858367 -48.989 -112.0371
12381.590789 -42.386 -77.2402
12382.323211 -42.639 -88.3867
12383.055633 -44.048 -86.6406
12383.788054 -42.410 -114.6465
12384.520476 -42.066 -99.0742
12385.252898 -46.933 -140.5586
12385.985320 -40.794 -109.9160
12386.717742 -38.913 -114.2148
12387.450163 -40.614 -164.0977
12388.182585 -41.044 -153.8555
12388.915007 -38.375 -152.0605
12389.647429 -38.324 -172.0957
12390.379851 -41.039 -164.0352
12391.112273 -38.526 158.2539
12391.844694 -39.910 167.5176
12392.577116 -36.349 139.2402
12393.309538 -39.275 157.3281
12394.041960 -36.686 143.3633
12394.774382 -38.408 122.6719
12395.506803 -39.050 127.8652
12396.239225 -36.762 138.0840
12396.971647 -36.118 109.0039
12397.704069 -39.081 106.9766
12398.436491 -37.022 99.9863
12399.168913 -40.475 89.7949
12399.901334 -39.461 83.7832
12400.633756 -38.196 66.2285
12401.366178 -39.963 57.7812
12402.098600 -39.908 60.5312
12402.831022 -40.513 48.7227
12403.563443 -42.379 12.2773
12404.295865 -38.459 50.2480
12405.028287 -41.692 29.8047
12405.760709 -41.135 24.4609
12406.493131 -38.667 11.7383
12407.225552 -39.292 -20.7539
12407.957974 -43.430 27.7676
12408.690396 -40.914 10.4336
12409.422818 -43.280 -9.7070
12410.155240 -40.873 12.1406
12410.887662 -43.359 -2.9004
12411.620083 -43.662 7.9941
12412.352505 -47.683 -26.2266
12413.084927 -41.492 4.1172
12413.817349 -43.846 9.3164
12414.549771 -43.144 28.4609
12415.282192 -50.950 30.8457
12416.014614 -40.110 43.0156
12416.747036 -43.968 21.6074
12417.479458 -43.069 8.5859
12418.211880 -40.954 31.6738
12418.944302 -43.359 2.0039
12419.676723 -42.064 10.1816
12420.409145 -39.863 0.2383
12421.141567 -44.850 -21.0020
12421.873989 -39.744 -2.2969
12422.606411 -39.236 -14.5781
12423.338832 -40.845 -8.7461
12424.071254 -38.569 -29.1465
12424.803676 -36.324 -22.0430
12425.536098 -37.951 -16.5215
12426.268520 -36.232 -35.4473
12427.000942 -39.758 -43.3926
12427.733363 -38.262 -42.6094
12428.465785 -41.190 -45.1367
12429.198207 -37.972 -52.4551
12429.930629 -36.914 -54.7285
12430.663051 -38.636 -71.0723
12431.395472 -41.063 -79.5605
12432.127894 -39.267 -68.3145
12432.860316 -40.524 -89.2148
12433.592738 -41.344 -88.6699
12434.325160 -39.790 -116.6641
12435.057581 -40.584 -120.0039
12435.790003 -44.964 -117.3398
12436.522425 -42.430 -126.2695
12437.254847 -44.031 -130.0723
12437.987269 -40.718 -129.4082
12438.719691 -41.589 -137.8066
12439.452112 -48.738 -161.7656
12440.184534 -44.678 -149.2324
12440.916956 -49.197 -168.4629
12441.649378 -52.795 -163.3691
12442.381800 -45.995 177.7695
12443.114221 -45.220 141.4453
12443.846643 -55.380 17.7480
12444.579065 -49.874 149.7227
12445.311487 -64.287 -167.2168
12446.043909 -50.325 50.0996
12446.776331 -58.737 74.2285
12447.508752 -60.630 167.3262
12448.241174 -53.921 -1.2109
12448.973596 -56.202 -69.3340
12449.706018 -53.225 -60.6230
12450.438440 -48.964 -159.9375
12451.170861 -52.703 -164.8066
12451.903283 -56.777 30.3730
12452.635705 -50.687 -101.7812
12453.368127 -49.686 -96.4141
12454.100549 -48.736 -143.3770
12454.832970 -52.698 -91.8379
12455.565392 -49.923 -129.1758
12456.297814 -48.319 -179.5254
12457.030236 -47.695 175.8496
12457.762658 -47.922 137.2109
12458.495080 -52.547 162.2871
12459.227501 -44.465 145.0156
12459.959923 -47.776 125.4297
12460.692345 -44.337 124.1484
12461.424767 -46.476 78.8496
12462.157189 -41.546 111.7715
12462.889610 -44.678 54.7637
12463.622032 -44.313 88.7363
12464.354454 -43.632 64.9434
12465.086876 -42.347 62.7988
12465.819298 -41.843 62.9531
12466.551720 -40.435 55.2754
12467.284141 -41.210 36.1289
12468.016563 -40.416 28.8379
12468.748985 -40.949 25.1289
12469.481407 -39.175 17.5879
12470.213829 -40.964 13.5664
12470.946250 -41.421 1.0840
12471.678672 -42.241 -8.1797
12472.411094 -39.087 -3.8984
12473.143516 -40.263 -32.3926
12473.875938 -40.993 -15.5352
12474.608360 -40.143 -22.7207
12475.340781 -40.474 -32.2754
12476.073203 -39.251 -36.9180
12476.805625 -41.968 -68.3008
12477.538047 -41.602 -48.8242
12478.270469 -42.866 -46.7422
12479.002890 -39.943 -78.3516
12479.735312 -41.871 -65.9531
12480.467734 -44.648 -72.6211
12481.200156 -42.475 -92.4082
12481.932578 -43.756 -100.0098
12482.664999 -42.900 -106.1641
12483.397421 -45.639 -126.0273
12484.129843 -48.937 -103.3770
12484.862265 -43.200 -136.2246
12485.594687 -47.187 -165.8105
12486.327109 -44.939 -153.9219
12487.059530 -46.522 -137.1660
12487.791952 -46.966 -124.7910
12488.524374 -45.606 -168.7793
12489.256796 -54.411 142.7480
12489.989218 -58.207 100.2695
12490.721639 -52.953 146.5527
12491.454061 -56.545 159.8223
12492.186483 -48.967 127.0332
12492.918905 -48.447 171.6680
12493.651327 -48.002 101.3359
12494.383749 -51.143 92.8047
12495.116170 -45.248 98.9121
12495.848592 -52.478 91.3613
12496.581014 -45.557 92.5664
12497.313436 -42.568 66.5625
12498.045858 -49.028 48.6230
12498.778279 -48.222 39.9648
12499.510701 -44.980 60.1133
12500.243123 -56.227 41.6094
12500.975545 -46.556 21.0918
12501.707967 -51.597 -27.9922
12502.440389 -55.398 39.4824
12503.172810 -54.762 -14.8086
12503.905232 -54.490 -38.2754
12504.637654 -65.388 -20.9707
12505.370076 -51.535 -82.3594
12506.102498 -50.762 25.6758
12506.834919 -56.928 111.1895
12507.567341 -58.949 -68.2676
12508.299763 -68.319 -138.0430
12509.032185 -56.491 15.7832
12509.764607 -54.233 176.6426
12510.497028 -59.063 103.7227
12511.229450 -51.910 165.9609
12511.961872 -58.524 -168.5000
12512.694294 -48.005 67.3359
12513.426716 -59.338 71.0156
12514.159138 -47.249 89.6074
12514.891559 -50.427 89.2910
12515.623981 -44.806 86.6973
12516.356403 -42.878 86.7227
12517.088825 -40.736 65.8594
12517.821247 -42.213 67.3906
12518.553668 -41.239 68.3066
12519.286090 -42.961 47.3301
12520.018512 -42.360 46.6836
12520.750934 -39.568 40.4551
12521.483356 -39.960 43.3301
12522.215778 -40.716 37.2656
12522.948199 -40.046 37.0273
12523.680621 -41.452 27.6934
12524.413043 -37.411 12.7402
12525.145465 -36.527 3.3359
12525.877887 -37.340 14.7402
12526.610308 -39.479 -3.5039
12527.342730 -38.741 -3.7969
12528.075152 -38.913 -4.5898
12528.807574 -37.274 -13.4238
12529.539996 -38.626 -36.9297
12530.272417 -38.011 -20.2949
12531.004839 -38.917 -31.3848
12531.737261 -39.250 -22.1523
12532.469683 -41.054 -44.0859
12533.202105 -38.830 -63.8008
12533.934527 -41.415 -74.2617
12534.666948 -38.161 -79.1328
12535.399370 -40.890 -90.0078
12536.131792 -40.100 -88.7148
12536.864214 -39.209 -100.2344
12537.596636 -41.695 -110.2598
12538.329057 -40.136 -123.7539
12539.061479 -39.776 -133.5000
12539.793901 -38.077 -158.9062
12540.526323 -37.989 -148.6504
12541.258745 -39.490 -155.4199
12541.991167 -39.180 -176.7539
12542.723588 -39.316 161.1523
12543.456010 -39.442 175.0469
12544.188432 -37.792 171.0625
12544.920854 -39.569 159.7852
12545.653276 -38.518 158.1465
12546.385697 -39.650 139.5781
12547.118119 -37.009 134.3379
12547.850541 -38.966 143.2832
12548.582963 -37.602 131.1484
12549.315385 -38.237 114.9316
12550.047807 -38.404 120.1133
12550.780228 -39.889 95.1113
12551.512650 -38.843 99.5000
12552.245072 -38.930 99.5293
12552.977494 -38.692 74.2988
12553.709916 -38.181 68.8887
12554.442337 -38.154 75.7188
12555.174759 -39.233 55.7598
12555.907181 -42.219 58.3809
12556.639603 -43.277 71.3184
12557.372025 -40.254 50.8672
12558.104446 -41.177 78.2559
12558.836868 -43.988 61.1719
12559.569290 -45.666 24.4688
12560.301712 -40.575 37.6543
12561.034134 -42.989 63.2793
12561.766556 -45.131 63.7656
12562.498977 -44.757 69.0684
12563.231399 -44.026 86.5879
12563.963821 -42.666 80.2559
12564.696243 -42.570 69.5527
12565.428665 -42.544 70.2188
12566.161086 -41.340 71.8887
12566.893508 -41.886 77.7949
12567.625930 -43.033 58.4316
12568.358352 -41.986 67.3828
12569.090774 -39.318 60.1270
12569.823196 -39.871 63.1172
12570.555617 -39.641 58.2051
12571.288039 -40.005 55.6758
12572.020461 -38.668 31.5684
12572.752883 -38.869 45.0312
12573.485305 -39.165 41.5820
12574.217726 -40.812 39.5938
12574.950148 -38.493 22.9180
12575.682570 -39.198 24.1895
12576.414992 -40.016 19.3691
12577.147414 -40.794 13.4668
12577.879835 -40.274 5.6152
12578.612257 -39.187 -6.0977
12579.344679 -40.793 -21.6035
12580.077101 -44.706 -28.0840
12580.809523 -42.930 -11.9492
12581.541945 -45.193 0.2598
12582.274366 -44.532 -38.0430
12583.006788 -45.287 -32.7070
12583.739210 -48.202 -57.3926
12584.471632 -53.054 -72.4004
12585.204054 -50.271 37.5430
12585.936475 -53.439 -24.0078
12586.668897 -50.625 35.7266
12587.401319 -47.942 97.7305
12588.133741 -48.239 103.4941
12588.866163 -45.493 78.7773
12589.598585 -42.674 57.2930
12590.331006 -43.142 57.3945
12591.063428 -42.649 76.6660
12591.795850 -40.861 64.2051
12592.528272 -43.342 42.3262
12593.260694 -40.625 45.3516
12593.993115 -38.233 43.1680
12594.725537 -38.742 42.9570
12595.457959 -37.656 34.5645
12596.190381 -37.480 17.3730
12596.922803 -37.887 22.0254
12597.655225 -36.952 9.0898
12598.387646 -37.078 7.9766
12599.120068 -39.179 -2.9902
12599.852490 -40.617 -12.1582
12600.584912 -38.859 -5.0234
12601.317334 -36.445 -22.5117
12602.049755 -38.870 -29.4961
12602.782177 -39.601 -40.9180
12603.514599 -41.930 -41.9258
12604.247021 -41.972 -60.9355
12604.979443 -40.073 -45.8047
12605.711864 -42.339 -65.4238
12606.444286 -46.072 -104.8535
12607.176708 -45.060 -109.8086
12607.909130 -43.300 -110.3750
12608.641552 -48.071 -113.0430
12609.373974 -51.037 -150.4141
12610.106395 -51.993 -149.1504
12610.838817 -47.142 -175.2441
12611.571239 -47.702 128.6699
12612.303661 -43.863 122.7402
12613.036083 -46.312 114.2734
12613.768504 -43.538 101.0664
12614.500926 -45.119 92.6973
12615.233348 -42.323 72.6973
12615.965770 -43.136 68.8516
12616.698192 -39.929 61.9902
12617.430614 -38.135 34.4082
12618.163035 -38.917 54.1680
12618.895457 -42.778 52.9512
12619.627879 -38.391 40.9512
12620.360301 -37.937 27.4121
12621.092723 -39.158 17.8613
12621.825144 -39.157 10.8301
12622.557566 -38.335 15.1270
12623.289988 -38.524 -1.7793
12624.022410 -38.979 -8.6152
12624.754832 -39.866 -21.6465
12625.487253 -40.335 -22.3906
12626.219675 -41.208 -19.9902
12626.952097 -42.755 -18.8984
12627.684519 -43.550 -52.5879
12628.416941 -42.232 -54.7754
12629.149363 -40.760 -49.7285
12629.881784 -46.674 -53.3164
12630.614206 -51.296 -58.4883
12631.346628 -49.313 -50.0000
12632.079050 -45.302 -83.4590
12632.811472 -49.458 154.6816
12633.543893 -55.391 -135.1055
12634.276315 -50.616 76.5391
12635.008737 -50.304 112.9082
12635.741159 -47.969 103.0117
12636.473581 -48.475 114.9121
12637.206003 -52.427 87.0410
12637.938424 -43.096 71.5742
12638.670846 -43.923 66.6426
12639.403268 -46.026 77.0742
12640.135690 -42.478 48.1992
12640.868112 -46.732 53.2148
12641.600533 -40.900 37.9121
12642.332955 -39.922 60.3711
12643.065377 -41.094 44.6172
12643.797799 -42.425 32.5547
12644.530221 -41.564 38.1934
12645.262643 -39.920 24.4648
12645.995064 -37.691 26.7500
12646.727486 -39.308 30.6719
12647.459908 -38.811 22.8066
12648.192330 -42.157 18.3066
12648.924752 -41.026 5.5879
12649.657173 -41.839 34.0762
12650.389595 -40.017 19.8320
12651.122017 -39.887 9.3516
12651.854439 -40.888 2.3457
12652.586861 -38.722 12.8008
12653.319282 -39.367 10.4336
12654.051704 -38.542 29.5254
12654.784126 -41.145 18.4531
12655.516548 -38.275 18.0449
12656.248970 -39.946 12.6641
12656.981392 -39.930 17.4160
12657.713813 -39.317 12.4180
12658.446235 -39.047 5.2734
12659.178657 -38.519 2.3730
12659.911079 -39.560 1.9707
12660.643501 -38.343 -16.2402
12661.375922 -38.800 6.2715
12662.108344 -37.141 -5.8516
12662.840766 -38.944 -24.5547
12663.573188 -35.633 -14.0273
12664.305610 -38.333 -19.2598
12665.038032 -38.027 -24.2695
12665.770453 -36.806 -19.0469
12666.502875 -37.210 -35.3984
12667.235297 -37.029 -33.7598
12667.967719 -37.458 -29.8652
12668.700141 -40.539 -43.1445
12669.432562 -36.613 -39.2285
12670.164984 -39.014 -52.2070
12670.897406 -38.463 -58.4258
12671.629828 -40.142 -59.2793
12672.362250 -39.737 -69.8496
12673.094671 -39.899 -65.6719
12673.827093 -40.732 -58.9434
12674.559515 -41.561 -58.1016
12675.291937 -39.819 -79.2695
12676.024359 -40.333 -96.2695
12676.756781 -42.656 -84.1582
12677.489202 -42.715 -83.2852
12678.221624 -42.297 -90.7227
12678.954046 -42.685 -93.5879
12679.686468 -43.766 -62.9609
12680.418890 -44.936 -112.8086
12681.151311 -42.359 -77.6523
12681.883733 -48.268 -48.7852
12682.616155 -46.702 -65.0078
12683.348577 -47.886 -135.2012
12684.080999 -50.785 -97.7734
12684.813421 -46.225 14.4590
12685.545842 -53.446 -97.7285
12686.278264 -50.245 -45.0078
12687.010686 -46.167 -99.9785
12687.743108 -44.139 -128.4648
12688.475530 -52.486 -121.1699
12689.207951 -49.841 -81.7305
12689.940373 -67.480 95.1191
12690.672795 -50.809 9.4102
12691.405217 -52.271 5.8965
12692.137639 -54.319 -59.4531
12692.870061 -45.995 -82.5840
12693.602482 -46.972 -54.3047
12694.334904 -43.885 -11.7148
12695.067326 -50.560 38.9258
12695.799748 -48.770 -113.1211
12696.532170 -47.979 -26.8184
12697.264591 -50.239 -91.5078
12697.997013 -45.957 -1.3125
12698.729435 -46.525 -33.0957
12699.461857 -54.544 -90.9453
12700.194279 -48.372 -30.3047
12700.926700 -42.018 -29.5918
12701.659122 -50.799 -49.8008
12702.391544 -42.922 -59.8262
12703.123966 -39.319 -67.9707
12703.856388 -43.597 -43.7539
12704.588810 -40.775 -39.4961
12705.321231 -39.489 -31.8477
12706.053653 -40.760 -69.5020
12706.786075 -41.027 -70.2148
12707.518497 -44.839 -134.8184
12708.250919 -43.700 -80.2109
12708.983340 -44.404 -46.9180
12709.715762 -49.333 -45.3945
12710.448184 -40.982 -77.9707
12711.180606 -41.823 -108.4297
12711.913028 -45.903 -48.8203
12712.645450 -43.714 -71.8906
12713.377871 -48.084 -121.2207
12714.110293 -40.310 -100.7695
12714.842715 -41.102 -83.4688
12715.575137 -54.382 -56.7344
12716.307559 -37.904 -93.7090
12717.039980 -39.739 -62.8633
12717.772402 -42.462 -52.4375
12718.504824 -46.641 -64.4961
12719.237246 -42.263 -156.3242
12719.969668 -42.325 -90.3379
12720.702089 -44.890 -117.1094
12721.434511 -46.317 -62.5977
12722.166933 -44.724 -145.8965
12722.899355 -49.050 -85.7812
12723.631777 -48.495 -121.5000
12724.364199 -45.645 -111.9473
12725.096620 -46.272 -169.5234
12725.829042 -44.652 -88.2070
12726.561464 -48.692 -42.6074
12727.293886 -46.240 -33.3438
12728.026308 -45.869 -113.0742
12728.758729 -46.758 -108.2031
12729.491151 -46.997 -123.2988
12730.223573 -46.840 -123.6348
12730.955995 -49.988 -126.7676
12731.688417 -43.812 -104.9355
12732.420839 -45.392 -129.9961
12733.153260 -47.247 -136.8379
12733.885682 -47.969 -106.0625
12734.618104 -49.132 163.6875
12735.350526 -45.816 -170.3418
12736.082948 -53.327 -105.5645
12736.815369 -54.278 -37.6875
12737.547791 -51.644 175.4062
12738.280213 -44.266 -152.1133
12739.012635 -42.882 -157.5273
12739.745057 -42.359 -154.9336
12740.477479 -47.030 164.0176
12741.209900 -41.677 162.0352
12741.942322 -60.984 -163.0781
12742.674744 -40.538 111.6816
12743.407166 -44.309 129.0996
12744.139588 -54.304 133.2871
12744.872009 -43.415 89.1758
12745.604431 -46.828 79.9941
12746.336853 -50.802 74.1211
12747.069275 -39.903 109.8691
12747.801697 -48.485 44.7383
12748.534118 -41.574 40.3047
12749.266540 -39.493 92.4316
12749.998962 -42.851 29.2812
12750.731384 -41.352 10.1270
12751.463806 -40.758 11.5176
12752.196228 -39.544 -14.9531
12752.928649 -40.139 22.4414
12753.661071 -41.146 -13.5449
12754.393493 -38.418 12.0957
12755.125915 -40.701 -7.5527
12755.858337 -44.163 -8.7734
12756.590758 -37.223 5.7832
12757.323180 -39.353 -33.6719
12758.055602 -39.779 -36.5703
12758.788024 -38.575 -21.8086
12759.520446 -39.097 -34.4238
12760.252868 -38.310 -32.5137
12760.985289 -41.085 -55.4082
12761.717711 -39.320 -64.8125
12762.450133 -40.573 -75.9766
12763.182555 -38.698 -55.9668
12763.914977 -43.931 -86.6250
12764.647398 -46.062 -86.8945
12765.379820 -41.200 -41.4688
12766.112242 -39.651 -77.2090
12766.844664 -46.819 -151.2969
12767.577086 -44.989 -95.8516
12768.309507 -47.219 -74.1289
12769.041929 -52.873 -105.9336
12769.774351 -49.426 -114.5801
12770.506773 -49.635 -36.8340
12771.239195 -46.579 -94.6270
12771.971617 -48.612 -84.6484
12772.704038 -48.226 -47.5156
12773.436460 -50.083 -57.7363
12774.168882 -46.392 -99.1504
12774.901304 -53.309 -94.3496
12775.633726 -51.332 143.4570
12776.366147 -43.979 -79.1367
12777.098569 -41.767 -28.4707
12777.830991 -46.516 -82.2148
12778.563413 -43.040 -67.9258
12779.295835 -46.567 -67.0430
12780.028257 -43.956 -79.8691
12780.760678 -47.780 13.3613
12781.493100 -42.399 -88.3086
12782.225522 -44.138 -18.2109
12782.957944 -46.319 -105.9512
12783.690366 -51.053 -80.6719
12784.422787 -47.969 -55.4922
12785.155209 -47.797 -107.2031
12785.887631 -50.984 -99.2969
12786.620053 -50.150 -151.2949
12787.352475 -46.214 135.8652
12788.084897 -49.001 -169.4395
12788.817318 -65.778 173.3008
12789.549740 -49.037 125.1074
12790.282162 -47.354 124.4648
12791.014584 -47.360 54.9961
12791.747006 -44.882 114.2363
12792.479427 -45.831 58.9570
12793.211849 -44.677 75.6016
12793.944271 -40.849 46.2656
12794.676693 -42.907 55.2402
12795.409115 -42.369 40.1914
12796.141536 -44.960 57.7812
12796.873958 -42.048 36.0898
12797.606380 -40.575 46.3242
12798.338802 -39.365 23.0957
12799.071224 -39.435 -0.4102
12799.803646 -37.976 19.6523
12800.536067 -37.530 -9.2207
12801.268489 -38.052 -8.8047
12802.000911 -37.665 -2.3496
12802.733333 -38.107 -30.7324
12803.465755 -37.502 -17.7520
12804.198176 -37.910 -20.7363
12804.930598 -38.332 -31.4277
12805.663020 -37.920 -34.0703
12806.395442 -38.309 -49.7773
12807.127864 -36.388 -49.9785
12807.860286 -37.446 -48.2461
12808.592707 -40.009 -80.7148
12809.325129 -39.051 -90.7363
12810.057551 -39.950 -88.0605
12810.789973 -39.262 -72.6074
12811.522395 -39.612 -78.7617
12812.254816 -36.612 -73.7422
12812.987238 -40.276 -100.1465
12813.719660 -43.981 -83.0117
12814.452082 -44.996 -101.9844
12815.184504 -43.220 -131.4824
12815.916925 -50.015 -125.6348
12816.649347 -45.621 -96.1191
12817.381769 -42.385 -105.3184
12818.114191 -49.723 -124.3672
12818.846613 -56.236 -54.3613
12819.579035 -47.948 -127.0098
12820.311456 -52.991 -164.6094
12821.043878 -49.442 178.0605
12821.776300 -50.783 162.2910
12822.508722 -55.408 36.2793
12823.241144 -79.392 -155.2031
12823.973565 -57.436 92.3145
12824.705987 -56.032 -10.5508
12825.438409 -43.988 23.5664
12826.170831 -48.082 -2.1406
12826.903253 -46.469 6.7324
12827.635675 -48.353 46.0488
12828.368096 -49.424 -3.9922
12829.100518 -52.003 -40.4141
12829.832940 -47.906 17.7969
12830.565362 -47.308 -9.3652
12831.297784 -48.965 -26.4805
12832.030205 -45.307 3.1113
12832.762627 -43.700 24.4355
12833.495049 -43.366 -1.4453
12834.227471 -40.657 -10.7617
12834.959893 -40.944 0.2266
12835.692315 -44.728 -5.6211
12836.424736 -41.835 -1.5508
12837.157158 -40.587 0.6562
12837.889580 -38.323 -28.1152
12838.622002 -42.076 -19.3223
12839.354424 -40.420 -12.1172
12840.086845 -39.242 -31.8750
12840.819267 -38.077 -22.7969
12841.551689 -41.295 -17.9492
12842.284111 -41.465 -36.2754
12843.016533 -40.494 -40.3184
12843.748954 -40.116 -30.7344
12844.481376 -40.296 -39.1953
12845.213798 -42.991 -28.3848
12845.946220 -38.438 -35.9766
12846.678642 -39.245 -44.0566
12847.411064 -39.794 -57.1660
12848.143485 -40.374 -37.9980
12848.875907 -39.944 -61.0273
12849.608329 -40.174 -60.2070
12850.340751 -39.524 -57.2051
12851.073173 -40.582 -56.4668
12851.805594 -38.564 -64.6660
12852.538016 -38.980 -68.9629
12853.270438 -41.378 -74.2148
12854.002860 -39.258 -81.3633
12854.735282 -38.684 -78.8789
12855.467704 -38.817 -75.6348
12856.200125 -42.553 -84.0117
12856.932547 -42.220 -87.2910
12857.664969 -38.198 -83.3945
12858.397391 -40.458 -83.6758
12859.129813 -40.999 -121.2129
12859.862234 -41.664 -107.1992
12860.594656 -39.949 -97.4258
12861.327078 -39.228 -103.3320
12862.059500 -39.822 -104.9180
12862.791922 -42.200 -94.4727
12863.524343 -38.338 -86.6465
12864.256765 -40.766 -110.7754
12864.989187 -40.947 -102.6797
12865.721609 -41.504 -117.1270
12866.454031 -40.550 -122.5176
12867.186453 -41.021 -109.5371
12867.918874 -41.778 -110.9551
12868.651296 -40.793 -124.9316
12869.383718 -38.832 -123.8418
12870.116140 -43.041 -138.1641
12870.848562 -41.652 -130.5996
12871.580983 -42.311 -108.4180
12872.313405 -40.939 -133.5840
12873.045827 -39.209 -147.4492
12873.778249 -40.733 -142.1680
12874.510671 -42.944 -143.6680
12875.243093 -40.600 -140.1738
12875.975514 -40.573 -165.8086
12876.707936 -38.581 -153.1719
12877.440358 -42.788 -169.6973
12878.172780 -41.271 -179.4121
12878.905202 -42.250 -176.1562
12879.637623 -43.067 -171.8984
12880.370045 -41.437 177.9746
12881.102467 -40.161 169.6699
12881.834889 -42.463 151.0684
12882.567311 -39.263 146.5742
12883.299733 -42.678 139.4453
12884.032154 -47.754 139.6953
12884.764576 -40.585 125.8848
12885.496998 -45.645 105.1602
12886.229420 -44.941 89.6426
12886.961842 -41.876 112.8242
12887.694263 -41.193 91.2363
12888.426685 -41.051 69.8340
12889.159107 -40.040 80.0156
12889.891529 -43.123 44.2422
12890.623951 -41.342 44.8379
12891.356372 -41.918 28.9551
12892.088794 -39.971 36.9844
12892.821216 -41.590 6.1172
12893.553638 -40.595 9.6465
12894.286060 -41.637 8.3457
12895.018482 -39.099 -3.0391
12895.750903 -40.692 -28.1426
12896.483325 -40.755 -18.0605
12897.215747 -40.305 -43.0918
12897.948169 -37.975 -35.7207
12898.680591 -41.257 -32.0215
12899.413012 -40.506 -56.0039
12900.145434 -43.931 -51.1074
12900.877856 -40.861 -56.1582
12901.610278 -39.828 -76.1484
12902.342700 -40.831 -64.2148
12903.075122 -40.559 -73.7520
12903.807543 -41.784 -61.3047
12904.539965 -40.079 -105.3711
12905.272387 -44.965 -77.8262
12906.004809 -46.900 -103.1016
12906.737231 -46.255 -88.6895
12907.469652 -41.662 -115.6660
12908.202074 -50.276 -127.8457
12908.934496 -50.664 -115.3477
12909.666918 -45.270 -97.2773
12910.399340 -48.595 -132.5117
12911.131761 -47.731 -168.5801
12911.864183 -46.950 -167.4336
12912.596605 -53.979 -146.1152
12913.329027 -57.985 -110.5781
12914.061449 -55.335 18.1211
12914.793871 -50.525 -76.8809
12915.526292 -50.363 -57.3926
12916.258714 -48.002 -81.2363
12916.991136 -48.879 -56.2441
12917.723558 -48.558 -59.1016
12918.455980 -42.096 -65.4570
12919.188401 -42.801 -77.6523
12919.920823 -43.959 -51.4336
12920.653245 -42.116 -80.0918
12921.385667 -41.222 -81.9316
12922.118089 -42.940 -100.2500
12922.850511 -44.428 -94.8809
12923.582932 -41.479 -96.3418
12924.315354 -42.725 -97.2305
12925.047776 -42.357 -90.7148
12925.780198 -41.635 -111.7910
12926.512620 -40.565 -127.1055
12927.245041 -42.893 -134.5547
12927.977463 -44.661 -145.2344
12928.709885 -41.123 -128.0703
12929.442307 -47.076 -167.1914
12930.174729 -44.277 -152.8770
12930.907151 -41.985 -151.8359
12931.639572 -43.179 165.5293
12932.371994 -46.276 179.9902
12933.104416 -44.392 -151.4961
12933.836838 -44.969 159.1875
12934.569260 -45.931 176.6953
12935.301681 -48.179 170.4648
12936.034103 -46.534 141.9629
12936.766525 -50.372 148.0273
12937.498947 -60.289 141.4238
12938.231369 -60.339 -52.9473
12938.963790 -62.091 -124.2793
12939.696212 -63.181 -121.3242
12940.428634 -51.384 -115.8770
12941.161056 -48.637 -44.0703
12941.893478 -53.264 -87.6035
12942.625900 -55.164 -60.0488
12943.358321 -45.655 -37.5605
12944.090743 -48.533 -88.5215
12944.823165 -44.351 -80.8301
12945.555587 -45.908 -63.4570
12946.288009 -47.077 -78.3398
12947.020430 -45.035 -72.9297
12947.752852 -47.102 -91.9258
12948.485274 -47.878 -110.8867
12949.217696 -48.392 -121.6562
12949.950118 -43.129 -110.7676
12950.682540 -41.955 -110.6797
12951.414961 -46.514 -134.2031
12952.147383 -45.422 -142.4707
12952.879805 -45.382 -119.2207
12953.612227 -43.621 -135.1641
12954.344649 -44.301 -159.1797
12955.077070 -46.928 -137.0879
12955.809492 -51.374 -127.4629
12956.541914 -42.974 -156.3789
12957.274336 -47.061 172.2988
12958.006758 -50.137 -164.9258
12958.739179 -48.240 166.1797
12959.471601 -46.305 -172.8379
12960.204023 -51.596 -154.6230
12960.936445 -52.812 160.7012
12961.668867 -44.336 154.2441
12962.401289 -56.998 -132.5469
12963.133710 -49.775 171.6621
12963.866132 -48.917 142.0156
12964.598554 -49.407 165.6680
12965.330976 -48.587 155.7227
12966.063398 -47.004 175.3105
12966.795819 -51.964 176.2441
12967.528241 -52.255 -166.5293
12968.260663 -47.755 171.2441
12968.993085 -47.400 162.1719
12969.725507 -50.531 134.4922
12970.457929 -47.783 145.0332
12971.190350 -45.473 157.7480
12971.922772 -45.197 159.2441
12972.655194 -46.116 173.9766
12973.387616 -45.094 164.8516
12974.120038 -46.020 159.8809
12974.852459 -49.212 -165.5371
12975.584881 -42.200 161.7266
12976.317303 -43.716 141.5293
12977.049725 -45.172 130.9043
12977.782147 -41.530 131.2695
12978.514569 -45.196 113.3125
12979.246990 -42.996 100.7598
12979.979412 -40.441 128.7012
12980.711834 -41.296 96.4316
12981.444256 -44.299 123.8281
12982.176678 -46.614 94.8613
12982.909099 -44.218 101.8008
12983.641521 -41.989 99.9727
12984.373943 -41.170 95.9473
12985.106365 -45.929 108.5898
12985.838787 -45.096 108.6348
12986.571208 -43.568 93.1094
12987.303630 -42.662 93.1094
12988.036052 -44.173 87.1387
12988.768474 -44.934 75.3789
12989.500896 -40.604 86.8848
12990.233318 -48.488 79.1895
12990.965739 -41.130 56.8477
12991.698161 -42.368 69.8066
12992.430583 -45.791 76.4043
12993.163005 -42.276 43.1250
12993.895427 -45.717 37.2480
12994.627848 -47.600 55.1172
12995.360270 -44.802 31.3027
12996.092692 -44.174 69.0156
12996.825114 -43.388 24.0684
12997.557536 -44.078 61.6934
12998.289958 -46.621 20.4941
12999.022379 -44.130 38.5957
12999.754801 -45.210 14.2480
13000.487223 -51.218 61.2773
13001.219645 -42.047 4.0137
13001.952067 -44.107 -6.4082
13002.684488 -43.976 -13.3418
13003.416910 -45.458 15.9277
13004.149332 -45.071 -3.4727
13004.881754 -45.088 -19.2812
13005.614176 -46.047 -19.0234
13006.346597 -44.352 -31.0176
13007.079019 -46.196 -42.8594
13007.811441 -44.913 -22.4277
13008.543863 -42.749 1.2539
13009.276285 -46.755 -4.4824
13010.008707 -46.688 -34.1191
13010.741128 -43.242 -16.0312
13011.473550 -44.804 -17.4062
13012.205972 -45.488 -6.1445
13012.938394 -46.184 7.7305
13013.670816 -50.159 -2.2129
13014.403237 -45.426 -36.4570
13015.135659 -49.396 26.4395
13015.868081 -49.283 -12.6484
13016.600503 -48.321 -25.0723
13017.332925 -51.668 -10.1562
13018.065347 -43.721 -13.8008
13018.797768 -50.181 43.8008
13019.530190 -48.129 -3.3770
13020.262612 -47.035 -38.6621
13020.995034 -45.915 -27.5938
13021.727456 -49.950 -31.5234
13022.459877 -45.612 -17.2949
13023.192299 -40.914 -35.0020
13023.924721 -43.039 -43.3457
13024.657143 -41.809 -27.0703
13025.389565 -41.224 -46.8711
13026.121987 -40.767 -56.1406
13026.854408 -42.594 -35.4316
13027.586830 -38.983 -54.2207
13028.319252 -40.249 -63.1172
13029.051674 -39.828 -86.9121
13029.784096 -37.622 -81.2188
13030.516517 -40.257 -75.7207
13031.248939 -39.555 -84.1816
13031.981361 -39.395 -91.7949
13032.713783 -41.604 -88.3906
13033.446205 -41.171 -106.5918
13034.178626 -42.367 -124.7949
13034.911048 -39.425 -131.7266
13035.643470 -39.566 -133.0586
13036.375892 -39.582 -135.3730
13037.108314 -40.381 -142.2871
13037.840736 -39.246 -148.8516
13038.573157 -38.852 -167.6953
13039.305579 -37.753 174.1562
13040.038001 -37.617 -160.4023
13040.770423 -39.550 -178.2695
13041.502845 -38.159 172.5977
13042.235266 -40.989 157.7617
13042.967688 -39.382 146.8223
13043.700110 -38.314 128.7871
13044.432532 -38.612 114.6445
13045.164954 -37.814 117.5625
13045.897376 -38.179 122.5840
13046.629797 -39.000 108.3066
13047.362219 -37.523 109.8555
13048.094641 -39.340 103.7051
13048.827063 -38.601 93.3203
13049.559485 -38.563 94.2930
13050.291906 -37.815 71.2148
13051.024328 -38.712 78.0312
13051.756750 -40.566 80.3945
13052.489172 -38.366 62.2715
13053.221594 -37.903 51.2012
13053.954015 -37.754 32.4824
13054.686437 -39.847 43.8594
13055.418859 -39.094 41.1875
13056.151281 -39.702 36.2227
13056.883703 -37.302 26.3125
13057.616125 -38.701 23.3398
13058.348546 -39.556 26.5312
13059.080968 -40.287 6.2305
13059.813390 -39.177 8.5156
13060.545812 -39.599 16.0391
13061.278234 -41.476 14.0625
13062.010655 -38.103 5.9062
13062.743077 -40.727 -3.6562
13063.475499 -46.070 -8.7812
13064.207921 -41.773 15.8828
13064.940343 -40.388 12.1074
13065.672765 -41.641 14.5977
13066.405186 -40.322 13.1094
13067.137608 -42.953 14.8711
13067.870030 -38.127 8.8340
13068.602452 -38.656 7.3691
13069.334874 -39.165 -6.3438
13070.067295 -39.297 -2.3066
13070.799717 -39.527 -9.6680
13071.532139 -36.500 -14.4531
13072.264561 -37.281 -14.1309
13072.996983 -38.191 -11.3438
13073.729405 -36.561 -27.9863
13074.461826 -37.383 -31.7246
13075.194248 -35.748 -33.2188
13075.926670 -36.917 -44.0312
13076.659092 -37.892 -30.1504
13077.391514 -35.470 -39.0332
13078.123935 -36.200 -48.7422
13078.856357 -36.427 -50.2617
13079.588779 -35.723 -53.2227
13080.321201 -34.916 -59.4941
13081.053623 -36.180 -62.5664
13081.786044 -34.950 -76.0762
13082.518466 -35.893 -68.7695
13083.250888 -35.400 -74.3047
13083.983310 -37.174 -78.7402
13084.715732 -37.568 -102.2129
13085.448154 -35.953 -96.2988
13086.180575 -37.644 -84.1816
13086.912997 -37.331 -126.5684
13087.645419 -37.629 -106.7227
13088.377841 -37.885 -113.4727
13089.110263 -38.265 -116.3027
13089.842684 -38.648 -127.6367
13090.575106 -38.049 -137.6191
13091.307528 -39.844 -117.6699
13092.039950 -40.317 -136.6133
13092.772372 -38.041 -153.3516
13093.504794 -39.004 -155.0312
13094.237215 -42.909 -144.4883
13094.969637 -43.690 -174.5117
13095.702059 -40.700 170.1426
13096.434481 -43.228 128.9707
13097.166903 -48.197 141.1309
13097.899324 -44.976 146.7617
13098.631746 -41.969 124.6387
13099.364168 -51.711 -167.6816
13100.096590 -53.174 111.0859
13100.829012 -51.403 37.3086
13101.561433 -49.454 68.6055
13102.293855 -45.687 151.9551
13103.026277 -58.167 -168.9648
13103.758699 -44.872 30.3730
13104.491121 -81.989 99.9785
13105.223543 -52.924 92.5625
13105.955964 -56.934 60.6641
13106.688386 -48.681 -24.9551
13107.420808 -53.452 -46.8594
13108.153230 -51.581 -39.2891
13108.885652 -48.998 -63.9980
13109.618073 -49.958 -26.7930
13110.350495 -62.782 98.1387
13111.082917 -47.055 -80.7266
13111.815339 -44.487 -91.3262
13112.547761 -41.271 -143.8516
13113.280183 -47.711 -149.3047
13114.012604 -46.527 -113.3066
13114.745026 -50.098 -103.7695
13115.477448 -51.850 -68.6406
13116.209870 -51.354 122.2812
13116.942292 -42.704 -172.0840
13117.674713 -59.809 155.5527
13118.407135 -50.703 87.6270
13119.139557 -54.179 -76.7109
13119.871979 -49.075 112.3633
13120.604401 -52.331 -52.5352
13121.336823 -45.464 115.9551
13122.069244 -43.909 57.6660
13122.801666 -53.191 5.9473
13123.534088 -45.129 61.2637
13124.266510 -45.833 -2.9062
13124.998932 -46.676 29.6660
13125.731353 -48.861 17.9707
13126.463775 -46.264 0.3574
13127.196197 -47.742 -4.8145
13127.928619 -44.328 -11.2246
13128.661041 -43.611 -2.3750
13129.393462 -44.459 -32.0625
13130.125884 -44.737 -49.3105
13130.858306 -41.549 -38.8359
13131.590728 -42.755 -39.7012
13132.323150 -41.942 -60.8789
13133.055572 -41.659 -75.2422
13133.787993 -46.436 -44.9805
13134.520415 -41.405 -83.9805
13135.252837 -41.561 -88.9023
13135.985259 -42.336 -106.9609
13136.717681 -42.058 -116.5117
13137.450102 -38.788 -123.9121
13138.182524 -39.462 -115.0996
13138.914946 -43.493 -113.2773
13139.647368 -44.504 -139.7188
13140.379790 -43.332 -134.9121
13141.112212 -40.655 -140.8145
13141.844633 -47.544 -120.6973
13142.577055 -47.986 -146.1895
13143.309477 -45.231 -171.1504
13144.041899 -45.000 175.4316
13144.774321 -47.037 -167.5547
13145.506742 -54.656 100.4316
13146.239164 -47.430 -153.9316
13146.971586 -42.611 139.3320
13147.704008 -39.996 111.8164
13148.436430 -55.610 98.2324
13149.168851 -43.705 119.9023
13149.901273 -51.113 51.4727
13150.633695 -44.011 94.3965
13151.366117 -43.392 55.4863
13152.098539 -42.734 68.3516
13152.830961 -41.498 17.5000
13153.563382 -40.307 18.3535
13154.295804 -43.676 22.8398
13155.028226 -40.776 15.8848
13155.760648 -42.293 -2.7402
13156.493070 -40.860 2.8379
13157.225491 -40.118 -2.8750
13157.957913 -42.592 -18.9980
13158.690335 -39.583 -48.4160
13159.422757 -39.750 -23.2871
13160.155179 -36.897 -45.5098
13160.887601 -41.535 -56.1133
13161.620022 -37.405 -56.7422
13162.352444 -40.347 -63.8906
13163.084866 -36.529 -62.2793
13163.817288 -38.417 -85.0527
13164.549710 -39.116 -72.0176
13165.282131 -38.584 -92.3809
13166.014553 -37.467 -93.6523
13166.746975 -39.069 -114.5273
13167.479397 -36.901 -114.6074
13168.211819 -39.577 -112.8535
13168.944241 -39.480 -108.9004
13169.676662 -39.565 -127.1387
13170.409084 -40.346 -148.5020
13171.141506 -40.287 -121.2520
13171.873928 -40.464 -152.1426
13172.606350 -38.002 -161.2598
13173.338771 -39.531 -153.0312
13174.071193 -43.278 175.6523
13174.803615 -43.249 166.7559
13175.536037 -46.163 142.9277
13176.268459 -42.205 155.6172
13177.000880 -43.785 149.5742
13177.733302 -45.574 133.3379
13178.465724 -43.961 126.6797
13179.198146 -42.947 129.5391
13179.930568 -42.664 96.7129
13180.662990 -44.813 56.4121
13181.395411 -47.716 83.1426
13182.127833 -51.715 61.2285
13182.860255 -49.595 16.5781
13183.592677 -47.675 -20.0488
13184.325099 -45.629 -19.2637
13185.057520 -47.726 -15.5664
13185.789942 -42.918 -33.1133
13186.522364 -46.086 -42.1152
13187.254786 -40.537 -49.1680
13187.987208 -43.129 -71.2773
13188.719630 -38.708 -77.5117
13189.452051 -41.532 -58.3359
13190.184473 -42.493 -78.3828
13190.916895 -40.091 -96.3770
13191.649317 -40.541 -105.5547
13192.381739 -37.419 -108.1934
13193.114160 -41.514 -110.4512
13193.846582 -40.096 -112.5879
13194.579004 -38.422 -114.1895
13195.311426 -39.037 -134.6172
13196.043848 -40.332 -129.3008
13196.776269 -37.202 -148.0938
13197.508691 -38.037 -150.7539
13198.241113 -40.003 -159.5977
13198.973535 -39.133 -159.2500
13199.705957 -38.768 -161.0352
13200.438379 -37.671 -163.9746
13201.170800 -38.567 -178.4629
13201.903222 -38.702 170.1094
13202.635644 -38.072 171.6406
13203.368066 -39.726 175.2500
13204.100488 -40.375 176.6758
13204.832909 -40.229 148.1152
13205.565331 -40.144 146.6055
13206.297753 -42.029 146.6465
13207.030175 -39.904 159.1094
13207.762597 -40.219 120.6152
13208.495019 -38.800 137.9844
13209.227440 -40.892 131.7422
13209.959862 -40.124 120.5703
13210.692284 -41.945 105.6738
13211.424706 -40.351 123.3359
13212.157128 -40.310 104.2070
13212.889549 -41.452 101.7324
13213.621971 -40.776 107.5195
13214.354393 -38.850 118.4355
13215.086815 -44.128 99.0801
13215.819237 -41.353 88.8906
13216.551659 -40.939 84.3828
13217.284080 -40.527 99.7227
13218.016502 -41.543 68.0859
13218.748924 -41.839 56.6934
13219.481346 -42.282 40.7988
13220.213768 -41.301 40.6758
13220.946189 -42.258 21.9629
13221.678611 -42.700 20.9023
13222.411033 -42.084 4.3516
13223.143455 -44.383 10.2539
13223.875877 -42.319 -3.3398
13224.608298 -39.960 -4.9258
13225.340720 -39.376 -18.6953
13226.073142 -42.802 -19.2793
13226.805564 -40.876 -40.7031
13227.537986 -40.962 -53.7480
13228.270408 -42.761 -41.3262
13229.002829 -42.084 -63.9629
13229.735251 -40.436 -83.5684
13230.467673 -42.610 -84.3750
13231.200095 -41.928 -85.0840
13231.932517 -43.999 -109.9902
13232.664938 -43.462 -108.9102
13233.397360 -42.916 -127.1777
13234.129782 -43.414 -148.6758
13234.862204 -42.758 -163.9141
13235.594626 -41.479 -163.5469
13236.327048 -43.226 -167.7461
13237.059469 -44.841 -177.2656
13237.791891 -44.275 151.6348
13238.524313 -44.057 152.4805
13239.256735 -42.393 141.7734
13239.989157 -44.651 117.2246
13240.721578 -42.803 106.2734
13241.454000 -45.151 140.1309
13242.186422 -42.086 75.5742
13242.918844 -45.101 68.5312
13243.651266 -40.938 73.9902
13244.383687 -42.165 54.5781
13245.116109 -41.712 60.1602
13245.848531 -41.428 38.2520
13246.580953 -40.371 47.7324
13247.313375 -41.007 35.4434
13248.045797 -42.557 5.5566
13248.778218 -41.576 -1.1758
13249.510640 -41.620 12.8535
13250.243062 -43.925 -26.0293
13250.975484 -42.922 -27.9766
13251.707906 -42.258 -31.1816
13252.440327 -40.942 -25.6387
13253.172749 -43.053 -51.4844
13253.905171 -45.155 -42.6797
13254.637593 -42.446 -68.9609
13255.370015 -42.647 -75.9102
13256.102437 -44.910 -76.5137
13256.834858 -45.028 -95.3242
13257.567280 -44.590 -114.4141
13258.299702 -49.581 -61.0859
13259.032124 -46.594 -107.2246
13259.764546 -42.616 -149.8574
13260.496967 -44.358 -138.8770
13261.229389 -51.545 176.3516
13261.961811 -47.700 -179.4746
13262.694233 -48.012 156.9375
13263.426655 -47.852 146.2754
13264.159077 -50.011 143.8516
13264.891498 -51.038 174.4688
13265.623920 -56.261 111.7871
13266.356342 -49.380 85.1895
13267.088764 -52.749 117.9043
13267.821186 -49.130 118.4727
13268.553607 -48.655 105.3906
13269.286029 -55.738 -46.7969
13270.018451 -48.091 8.8203
13270.750873 -47.084 -4.9277
13271.483295 -51.842 -49.5371
13272.215716 -60.221 36.3223
13272.948138 -48.204 -6.8320
13273.680560 -47.923 -102.3770
13274.412982 -48.262 -78.9609
13275.145404 -48.814 -31.6094
13275.877826 -52.440 -75.9629
13276.610247 -49.879 -131.7637
13277.342669 -52.469 -154.1719
13278.075091 -54.525 -127.9277
13278.807513 -48.004 -176.4707
13279.539935 -46.562 -150.2285
13280.272356 -44.753 -166.0156
13281.004778 -44.217 143.5273
13281.737200 -48.029 100.0605
13282.469622 -49.320 155.8281
13283.202044 -43.247 126.3164
13283.934466 -47.074 107.8789
13284.666887 -41.864 110.3008
13285.399309 -42.239 82.5449
13286.131731 -42.486 80.3828
13286.864153 -44.956 77.9199
13287.596575 -52.233 68.3750
13288.328996 -43.473 89.3477
13289.061418 -41.670 35.8066
13289.793840 -41.252 39.5098
13290.526262 -41.207 39.1230
13291.258684 -40.540 24.7402
13291.991105 -44.233 11.6562
13292.723527 -39.617 12.1309
13293.455949 -39.429 10.5293
13294.188371 -41.587 5.0605
13294.920793 -42.112 -17.1738
13295.653215 -40.180 -17.6230
13296.385636 -40.756 -7.3359
13297.118058 -43.081 -38.9316
13297.850480 -43.916 -47.1953
13298.582902 -42.008 -58.3184
13299.315324 -43.012 -69.8496
13300.047745 -43.798 -76.0234
13300.780167 -42.879 -86.4473
13301.512589 -43.100 -103.8594
13302.245011 -42.683 -83.4727
13302.977433 -40.919 -121.1816
13303.709855 -46.758 -145.4902
13304.442276 -49.083 161.8242
13305.174698 -41.914 -130.3340
13305.907120 -46.911 -141.1504
13306.639542 -44.386 157.2207
13307.371964 -49.223 151.2285
13308.104385 -48.054 102.3184
13308.836807 -46.415 121.6738
13309.569229 -48.753 141.6309
13310.301651 -44.834 79.3125
13311.034073 -48.115 60.0098
13311.766495 -38.949 88.1660
13312.498916 -43.482 77.9062
13313.231338 -41.207 54.4531
13313.963760 -42.067 48.2227
13314.696182 -42.708 34.1758
13315.428604 -40.969 30.0059
13316.161025 -41.239 19.8281
13316.893447 -40.132 11.0723
13317.625869 -40.860 8.0273
13318.358291 -40.175 16.6152
13319.090713 -39.553 -13.6270
13319.823134 -39.043 -16.7852
13320.555556 -39.886 -13.9863
13321.287978 -40.574 -23.1504
13322.020400 -40.070 -53.5215
13322.752822 -38.612 -54.1582
13323.485244 -39.605 -45.2012
13324.217665 -39.619 -61.0586
13324.950087 -38.459 -78.1191
13325.682509 -39.469 -68.4297
13326.414931 -39.841 -97.3750
13327.147353 -39.729 -88.7812
13327.879774 -38.245 -100.6797
13328.612196 -37.985 -105.9121
13329.344618 -40.493 -115.2012
13330.077040 -41.543 -121.3594
13330.809462 -40.555 -130.0039
13331.541884 -42.133 -133.5430
13332.274305 -41.402 -167.9043
13333.006727 -43.107 -170.8828
13333.739149 -40.846 -165.1328
13334.471571 -42.849 -175.7910
13335.203993 -42.829 150.6895
13335.936414 -42.966 164.6543
13336.668836 -45.752 172.4395
13337.401258 -45.778 156.4590
13338.133680 -43.461 147.0039
13338.866102 -53.356 101.5957
13339.598523 -53.280 -125.9688
13340.330945 -49.633 113.6191
13341.063367 -57.270 58.8477
13341.795789 -44.025 2.4512
13342.528211 -48.325 -5.1699
13343.260633 -42.658 -43.6348
13343.993054 -46.847 10.7949
13344.725476 -44.050 -23.7246
13345.457898 -45.832 -52.0859
13346.190320 -44.190 -50.7344
13346.922742 -46.161 -53.5352
13347.655163 -45.929 -83.3379
13348.387585 -43.845 -79.0332
13349.120007 -43.770 -86.0840
13349.852429 -41.283 -116.8652
13350.584851 -43.179 -99.4180
13351.317273 -40.782 -110.2227
13352.049694 -40.814 -128.2852
13352.782116 -42.976 -133.0195
13353.514538 -40.239 -122.0527
13354.246960 -38.908 -139.5781
13354.979382 -40.141 -134.7168
13355.711803 -43.368 -154.5488
13356.444225 -43.608 -149.6504
13357.176647 -43.042 -166.7188
13357.909069 -40.604 -163.4590
13358.641491 -44.306 143.6211
13359.373913 -42.584 159.1523
13360.106334 -41.694 168.1895
13360.838756 -45.420 136.5469
13361.571178 -45.004 132.2461
13362.303600 -45.819 109.0078
13363.036022 -41.408 123.0215
13363.768443 -46.392 121.5156
13364.500865 -43.182 105.7871
13365.233287 -49.234 37.6113
13365.965709 -44.932 113.1973
13366.698131 -54.316 80.3262
13367.430552 -47.789 54.3086
13368.162974 -48.801 121.9453
13368.895396 -49.934 84.1719
13369.627818 -52.275 62.1465
13370.360240 -48.558 51.1855
13371.092662 -55.778 83.2715
13371.825083 -53.744 162.2227
13372.557505 -71.846 -111.7461
13373.289927 -51.389 93.5469
13374.022349 -54.428 -68.0117
13374.754771 -64.812 142.8926
13375.487192 -49.500 -135.5645
13376.219614 -50.416 146.3965
13376.952036 -54.634 -106.1797
13377.684458 -47.446 -169.7773
13378.416880 -75.075 47.9082
13379.149302 -46.948 -171.0098
13379.881723 -46.685 165.0273
13380.614145 -46.582 125.0078
13381.346567 -53.301 155.2539
13382.078989 -52.037 42.3223
13382.811411 -49.479 130.4102
13383.543832 -50.850 161.3164
13384.276254 -45.442 176.0371
13385.008676 -54.024 145.0723
13385.741098 -51.671 -179.6152
13386.473520 -47.521 170.4648
13387.205941 -51.127 -175.8516
13387.938363 -51.502 165.8809
13388.670785 -50.477 -162.9102
13389.403207 -48.914 -156.0918
13390.135629 -42.938 -157.4844
13390.868051 -47.187 -177.4609
13391.600472 -44.443 -168.3457
13392.332894 -51.286 -163.3105
13393.065316 -42.312 -157.9238
13393.797738 -45.593 171.3125
13394.530160 -45.770 168.5645
13395.262581 -41.945 156.9648
13395.995003 -42.615 163.2773
13396.727425 -41.741 131.1309
13397.459847 -43.720 149.7500
13398.192269 -41.049 146.9395
13398.924691 -40.147 133.1113
13399.657112 -44.705 123.3574
13400.389534 -41.684 126.0469
13401.121956 -40.934 113.9512
13401.854378 -39.484 116.2520
13402.586800 -42.775 118.1074
13403.319221 -42.397 101.7578
13404.051643 -41.722 96.8262
13404.784065 -37.263 101.8672
13405.516487 -44.634 58.8438
13406.248909 -41.374 71.0078
13406.981331 -39.421 65.5957
13407.713752 -38.958 75.1172
13408.446174 -39.334 56.1914
13409.178596 -45.020 70.4668
13409.911018 -41.407 51.0703
13410.643440 -43.368 57.6621
13411.375861 -44.439 37.5977
13412.108283 -53.155 66.3730
13412.840705 -47.673 39.6953
13413.573127 -46.051 43.1992
13414.305549 -55.658 7.0879
13415.037970 -50.463 -51.5020
13415.770392 -45.384 -19.2793
13416.502814 -62.167 -26.8691
13417.235236 -52.686 24.6074
13417.967658 -64.026 -5.5332
13418.700080 -45.845 -2.3496
13419.432501 -62.228 -46.9941
13420.164923 -45.819 5.7402
13420.897345 -58.575 -96.5664
13421.629767 -52.011 137.5391
13422.362189 -49.134 99.6211
13423.094610 -42.884 97.7012
13423.827032 -45.222 148.9258
13424.559454 -45.218 70.2051
13425.291876 -62.574 21.1523
13426.024298 -46.069 79.2168
13426.756720 -44.573 89.1191
13427.489141 -48.437 13.8262
13428.221563 -42.356 82.1973
13428.953985 -44.728 61.6523
13429.686407 -43.723 55.6504
13430.418829 -46.468 21.1680
13431.151250 -54.252 47.7578
13431.883672 -54.125 28.3633
13432.616094 -41.031 43.2578
13433.348516 -46.691 41.0625
13434.080938 -41.365 23.0000
13434.813359 -51.203 -8.8574
13435.545781 -46.469 79.9277
13436.278203 -41.836 35.2344
13437.010625 -44.517 69.9844
13437.743047 -47.007 174.3789
13438.475469 -54.329 153.2441
13439.207890 -47.917 -44.8750
13439.940312 -44.401 -114.4414
13440.672734 -51.114 67.4941
13441.405156 -59.087 -16.2871
13442.137578 -49.429 92.6953
13442.869999 -47.263 88.9336
13443.602421 -46.224 -128.2773
13444.334843 -50.952 -173.1445
13445.067265 -42.753 132.5664
13445.799687 -43.751 119.8457
13446.532109 -48.890 107.1621
13447.264530 -39.998 82.9961
13447.996952 -43.476 -179.8418
13448.729374 -45.568 69.4668
13449.461796 -47.150 132.9707
13450.194218 -46.679 117.4316
13450.926639 -47.973 61.3652
13451.659061 -44.247 42.5508
13452.391483 -44.322 102.6445
13453.123905 -52.924 59.4375
13453.856327 -53.881 148.2891
13454.588749 -54.489 -162.2051
13455.321170 -46.177 74.2285
13456.053592 -42.738 124.0371
13456.786014 -50.866 -40.0508
13457.518436 -38.978 85.6406
13458.250858 -40.952 75.5820
13458.983279 -54.752 -61.1211
13459.715701 -42.936 122.6992
13460.448123 -53.089 129.7773
13461.180545 -43.413 71.6035
13461.912967 -45.523 -10.9512
13462.645388 -42.420 119.8008
13463.377810 -49.681 -103.5078
13464.110232 -42.069 137.1113
13464.842654 -47.090 19.4277
13465.575076 -42.270 41.9961
13466.307498 -42.335 102.1094
13467.039919 -42.237 67.3457
13467.772341 -40.739 80.9043
13468.504763 -42.120 92.8711
13469.237185 -45.712 30.2324
13469.969607 -38.562 37.8457
13470.702028 -38.726 41.4551
13471.434450 -40.775 26.4004
13472.166872 -39.570 69.8320
13472.899294 -34.422 25.3398
13473.631716 -41.352 20.8418
13474.364138 -39.763 12.5996
13475.096559 -38.436 44.6191
13475.828981 -51.278 39.8203
13476.561403 -39.469 1.9785
13477.293825 -41.492 11.1523
13478.026247 -40.171 -0.3125
13478.758668 -39.745 -9.5391
13479.491090 -36.417 -9.7852
13480.223512 -43.600 -40.7930
13480.955934 -44.498 5.6543
13481.688356 -38.984 -7.7734
13482.420777 -40.022 -12.9629
13483.153199 -35.475 -4.3281
13483.885621 -37.572 -10.1465
13484.618043 -43.130 -15.5234
13485.350465 -34.955 -66.5234
13486.082887 -39.864 -63.2324
13486.815308 -50.001 -31.2520
13487.547730 -40.374 -47.1777
13488.280152 -47.847 -99.2520
13489.012574 -50.881 -9.9863
13489.744996 -45.841 -60.3223
13490.477417 -48.383 179.9238
13491.209839 -49.344 -178.1094
13491.942261 -50.176 -104.5312
13492.674683 -46.699 -71.6758
13493.407105 -44.124 40.8477
13494.139527 -42.286 -27.5430
13494.871948 -45.901 35.3145
13495.604370 -45.189 -24.8809
13496.336792 -38.874 -2.2324
13497.069214 -47.552 117.0430
13497.801636 -51.729 66.4375
13498.534057 -40.279 -3.2637
13499.266479 -42.148 52.9414
13499.998901 -48.330 33.2695
13500.731323 -42.617 44.2832
13501.463745 -41.528 0.8691
13502.196167 -42.188 -75.2402
13502.928588 -43.454 30.0020
13503.661010 -44.516 -52.0859
13504.393432 -41.443 -58.8984
13505.125854 -41.907 10.8828
13505.858276 -46.251 -46.1992
13506.590697 -42.480 -58.3418
13507.323119 -51.360 -78.2988
13508.055541 -44.659 -79.8750
13508.787963 -41.468 -95.6484
13509.520385 -45.091 -129.1113
13510.252806 -41.058 -106.6367
13510.985228 -45.188 -113.7383
13511.717650 -42.346 -123.5664
13512.450072 -46.208 -138.2520
13513.182494 -43.188 179.8203
13513.914916 -38.752 -164.0117
13514.647337 -41.612 -158.2480
13515.379759 -43.518 -178.1543
13516.112181 -46.376 -132.3672
13516.844603 -47.175 -146.3125
13517.577025 -53.466 -165.3301
13518.309446 -40.546 105.9277
13519.041868 -43.805 95.9590
13519.774290 -42.104 132.9102
13520.506712 -49.368 168.5098
13521.239134 -41.821 120.8184
13521.971556 -43.542 114.3828
13522.703977 -43.543 92.9023
13523.436399 -39.872 109.9922
13524.168821 -39.689 75.4199
13524.901243 -45.372 87.2832
13525.633665 -48.435 61.5137
13526.366086 -49.674 -115.4160
13527.098508 -44.663 56.0938
13527.830930 -44.459 31.2441
13528.563352 -46.559 80.0039
13529.295774 -45.712 -44.4258
13530.028196 -58.820 148.1582
13530.760617 -39.875 68.2363
13531.493039 -47.382 16.0312
13532.225461 -49.880 69.3066
13532.957883 -46.679 75.6250
13533.690305 -58.538 2.1484
13534.422726 -47.763 20.3477
13535.155148 -46.404 158.8867
13535.887570 -45.137 10.9199
13536.619992 -41.715 82.9492
13537.352414 -53.663 39.0586
13538.084835 -44.161 -175.6875
13538.817257 -40.088 109.2617
13539.549679 -42.821 92.5840
13540.282101 -49.781 72.5488
13541.014523 -39.681 83.4863
13541.746945 -43.599 68.8906
13542.479366 -42.267 32.8496
13543.211788 -52.497 114.6348
13543.944210 -43.379 70.9785
13544.676632 -38.310 53.6504
13545.409054 -42.022 51.4043
13546.141475 -43.353 68.8828
13546.873897 -39.307 35.2461
13547.606319 -40.687 40.0234
13548.338741 -44.585 49.5371
13549.071163 -41.800 46.2012
13549.803585 -42.410 43.6895
13550.536006 -41.362 43.3086
13551.268428 -41.916 9.5254
13552.000850 -42.382 7.0840
13552.733272 -41.458 27.3789
13553.465694 -41.003 10.2227
13554.198115 -37.753 -32.6777
13554.930537 -39.413 -4.4004
13555.662959 -41.763 -13.8340
13556.395381 -38.061 -11.1523
13557.127803 -42.964 -44.4395
13557.860224 -39.726 -50.9824
13558.592646 -36.517 -23.4453
13559.325068 -39.700 -45.6309
13560.057490 -39.828 -22.0039
13560.789912 -40.290 -53.1895
13561.522334 -39.968 -74.8320
13562.254755 -43.393 -71.5117
13562.987177 -39.468 -58.8574
13563.719599 -40.407 -73.5977
13564.452021 -41.111 -97.0430
13565.184443 -41.149 -89.3613
13565.916864 -40.805 -94.3809
13566.649286 -43.783 -117.2031
13567.381708 -43.975 -125.0176
13568.114130 -44.146 -47.1816
13568.846552 -44.329 -102.8047
13569.578974 -39.006 -111.9199
13570.311395 -45.537 -135.7441
13571.043817 -43.060 -134.6582
13571.776239 -47.025 -109.2168
13572.508661 -49.503 -155.3262
13573.241083 -47.802 178.0098
13573.973504 -51.082 -162.8125
13574.705926 -47.623 -179.7969
13575.438348 -43.725 173.0820
13576.170770 -47.656 136.8691
13576.903192 -44.902 141.2383
13577.635614 -45.752 126.8066
13578.368035 -49.065 98.5488
13579.100457 -49.033 104.6934
13579.832879 -46.542 23.5996
13580.565301 -45.593 56.3398
13581.297723 -46.263 64.4043
13582.030144 -46.173 57.3789
13582.762566 -50.419 89.0039
13583.494988 -46.262 40.5176
13584.227410 -49.864 33.8340
13584.959832 -48.667 63.2773
13585.692253 -48.220 28.8555
13586.424675 -44.967 4.4805
13587.157097 -45.272 36.4102
13587.889519 -44.107 9.7910
13588.621941 -42.624 -40.3574
13589.354363 -41.737 -53.5566
13590.086784 -51.410 -8.5723
13590.819206 -44.346 -46.6660
13591.551628 -41.660 -45.5410
13592.284050 -45.849 -61.6758
13593.016472 -50.148 -124.5254
13593.748893 -47.170 -84.2910
13594.481315 -46.051 -95.4453
13595.213737 -47.200 -93.9824
13595.946159 -51.772 -102.4531
13596.678581 -45.939 -115.7695
13597.411003 -46.883 -105.0605
13598.143424 -53.920 -144.8594
13598.875846 -45.200 -137.9473
13599.608268 -47.076 -114.8652
13600.340690 -51.718 179.8594
13601.073112 -46.936 -121.4727
13601.805533 -50.785 155.2109
13602.537955 -51.450 -162.8496
13603.270377 -54.536 179.8965
13604.002799 -49.909 118.6875
13604.735221 -45.467 130.8770
13605.467642 -53.579 103.7168
13606.200064 -58.966 80.4180
13606.932486 -55.964 93.7324
13607.664908 -52.580 48.4316
13608.397330 -52.167 106.3984
13609.129752 -51.064 27.2969
13609.862173 -48.722 71.0605
13610.594595 -52.038 -1.4297
13611.327017 -57.451 -35.0195
13612.059439 -50.781 -39.3027
13612.791861 -58.442 0.7988
13613.524282 -45.606 25.8730
13614.256704 -44.960 -18.5098
13614.989126 -41.515 -55.1465
13615.721548 -45.092 -32.8320
13616.453970 -48.946 17.0078
13617.186392 -44.308 -45.1328
13617.918813 -48.948 -31.9062
13618.651235 -45.186 -76.3047
13619.383657 -43.123 -53.2305
13620.116079 -44.875 -31.5801
13620.848501 -44.860 -67.4004
13621.580922 -44.752 -78.4375
13622.313344 -45.176 -61.7930
13623.045766 -44.605 -76.2910
13623.778188 -43.807 -72.8887
13624.510610 -42.174 -105.2383
13625.243032 -45.120 -83.5332
13625.975453 -43.869 -92.8672
13626.707875 -42.431 -116.5430
13627.440297 -42.425 -107.1523
13628.172719 -44.331 -144.4082
13628.905141 -42.958 -114.5742
13629.637562 -42.912 -160.7930
13630.369984 -42.269 -150.4766
13631.102406 -44.780 -153.6426
13631.834828 -45.969 -165.0293
13632.567250 -44.180 -137.9160
13633.299671 -45.368 -153.3398
13634.032093 -50.279 -158.5312
13634.764515 -45.274 -177.2109
13635.496937 -47.904 178.9160
13636.229359 -40.255 166.9453
13636.961781 -47.020 130.6562
13637.694202 -47.201 176.7637
13638.426624 -45.428 152.8574
13639.159046 -46.899 163.7734
13639.891468 -46.838 109.7305
13640.623890 -42.268 110.0254
13641.356311 -41.728 116.1289
13642.088733 -43.706 122.6582
13642.821155 -41.703 76.1133
13643.553577 -40.055 97.9180
13644.285999 -48.148 102.0332
13645.018421 -42.206 77.5391
13645.750842 -44.292 67.2812
13646.483264 -43.540 83.8496
13647.215686 -43.224 48.9375
13647.948108 -47.989 74.9160
13648.680530 -44.422 36.9805
13649.412951 -42.616 59.1348
13650.145373 -50.340 73.4141
13650.877795 -50.241 15.7832
13651.610217 -43.641 52.2676
13652.342639 -45.811 52.5820
13653.075060 -47.978 62.8516
13653.807482 -48.001 57.4121
13654.539904 -47.184 26.3633
13655.272326 -50.675 64.6543
13656.004748 -53.861 66.9023
13656.737170 -46.992 85.9414
13657.469591 -45.565 82.0449
13658.202013 -44.612 74.5684
13658.934435 -45.249 82.2148
13659.666857 -43.876 76.2793
13660.399279 -45.448 45.5566
13661.131700 -47.927 67.4297
13661.864122 -46.723 93.7676
13662.596544 -41.011 65.3555
13663.328966 -39.444 55.7246
13664.061388 -44.719 72.9707
13664.793810 -44.694 52.6367
13665.526231 -41.946 69.9414
13666.258653 -43.460 66.8535
13666.991075 -45.233 60.3320
13667.723497 -44.769 40.8223
13668.455919 -43.951 48.2441
13669.188340 -45.335 42.3477
13669.920762 -45.694 54.9395
13670.653184 -42.778 32.5742
13671.385606 -45.971 12.2129
13672.118028 -44.606 -1.3828
13672.850450 -44.766 -24.2344
13673.582871 -56.688 25.0684
13674.315293 -52.085 -74.9199
13675.047715 -44.665 -14.8613
13675.780137 -44.262 -12.8496
13676.512559 -41.577 -20.0469
13677.244980 -43.873 -28.8535
13677.977402 -39.839 -10.9492
13678.709824 -43.682 7.0703
13679.442246 -52.248 -20.0879
13680.174668 -49.314 12.5918
13680.907089 -49.784 2.3906
13681.639511 -50.057 36.8848
13682.371933 -49.931 69.8984
13683.104355 -44.877 66.6270
13683.836777 -53.261 -46.6660
13684.569199 -45.225 37.5723
13685.301620 -44.018 18.3750
13686.034042 -46.270 53.9941
13686.766464 -41.948 11.0527
13687.498886 -42.942 53.7461
13688.231308 -43.642 56.8926
13688.963729 -42.553 58.4512
13689.696151 -44.728 27.8438
13690.428573 -40.221 41.4004
13691.160995 -44.394 35.6348
13691.893417 -43.164 37.4766
13692.625839 -42.460 10.6523
13693.358260 -41.257 22.1562
13694.090682 -42.923 -6.4492
13694.823104 -41.275 0.2168
13695.555526 -44.765 -39.9609
13696.287948 -42.543 -11.2676
13697.020369 -43.066 -22.6895
13697.752791 -44.727 -63.6484
13698.485213 -42.770 -72.3301
13699.217635 -44.398 -44.0293
13699.950057 -42.744 -69.6055
13700.682478 -45.633 -64.6230
13701.414900 -44.710 -77.6777
13702.147322 -43.628 -71.6035
13702.879744 -46.347 -102.3418
13703.612166 -45.432 -91.0664
13704.344588 -48.053 -97.1191
13705.077009 -47.197 -99.2422
13705.809431 -51.107 -153.8809
13706.541853 -51.840 -115.6934
13707.274275 -45.805 -137.3906
13708.006697 -53.106 -166.9746
13708.739118 -51.324 80.9082
13709.471540 -65.466 135.9160
13710.203962 -51.145 -108.1172
13710.936384 -62.514 122.9570
13711.668806 -61.565 51.9160
13712.401228 -54.019 -68.5645
13713.133649 -57.539 -76.4551
13713.866071 -62.401 51.4160
13714.598493 -57.649 -39.1250
13715.330915 -52.318 -75.3418
13716.063337 -50.335 -62.0938
13716.795758 -48.999 -53.6484
13717.528180 -54.103 -93.5137
13718.260602 -46.289 -68.3438
13718.993024 -57.724 -171.3633
13719.725446 -49.763 -142.7852
13720.457868 -49.009 -140.3535
13721.190289 -50.249 -108.9590
13721.922711 -44.256 -117.6660
13722.655133 -42.333 -105.8047
13723.387555 -42.683 -114.8047
13724.119977 -42.984 -114.3770
13724.852398 -43.200 -140.3340
13725.584820 -43.819 -99.7930
13726.317242 -50.172 -179.0059
13727.049664 -46.743 -166.5977
13727.782086 -44.239 -175.7305
13728.514507 -47.249 -168.3574
13729.246929 -46.279 172.9609
13729.979351 -47.049 -132.7676
13730.711773 -42.893 176.7949
13731.444195 -43.024 147.5547
13732.176617 -46.323 147.2305
13732.909038 -51.429 117.3555
13733.641460 -45.140 125.5332
13734.373882 -47.057 156.1582
13735.106304 -42.923 151.1660
13735.838726 -52.811 129.9414
13736.571147 -45.083 137.8242
13737.303569 -53.876 164.4453
13738.035991 -47.254 85.8008
13738.768413 -52.473 76.2832
13739.500835 -48.953 79.8750
13740.233257 -52.038 120.5762
13740.965678 -49.332 130.2793
13741.698100 -53.116 89.5312
13742.430522 -48.520 80.3711
13743.162944 -51.922 95.5957
13743.895366 -59.233 114.3730
13744.627787 -56.156 11.5762
13745.360209 -56.805 14.6504
13746.092631 -61.854 -70.5352
13746.825053 -58.469 -125.5527
13747.557475 -51.303 -22.0020
13748.289896 -74.283 120.6172
13749.022318 -49.866 -99.4219
13749.754740 -57.738 -12.5234
13750.487162 -43.861 -87.9219
13751.219584 -45.627 -85.8770
13751.952006 -47.913 -87.1602
13752.684427 -44.459 -101.0996
13753.416849 -43.166 -118.5078
13754.149271 -48.233 -106.1465
13754.881693 -48.697 -117.0195
13755.614115 -49.195 -118.2852
13756.346536 -45.784 -122.6465
13757.078958 -45.802 -123.6133
13757.811380 -41.988 -162.8047
13758.543802 -41.909 -167.0195
13759.276224 -40.738 -168.6973
13760.008646 -41.239 -166.6133
13760.741067 -40.972 179.0625
13761.473489 -40.500 -176.8906
13762.205911 -41.338 173.8242
13762.938333 -44.645 -173.5137
13763.670755 -46.387 168.0039
13764.403176 -43.786 158.1289
13765.135598 -42.990 152.7520
13765.868020 -46.295 142.8535
13766.600442 -43.646 115.0449
13767.332864 -48.459 135.4570
13768.065286 -47.944 124.8691
13768.797707 -54.878 -179.8633
13769.530129 -50.140 142.2969
13770.262551 -51.614 121.3633
13770.994973 -53.556 172.0391
13771.727395 -52.150 165.4688
13772.459816 -48.474 -130.6445
13773.192238 -51.388 -81.2617
13773.924660 -49.911 -131.9727
13774.657082 -45.886 -110.8594
13775.389504 -43.360 -156.3047
13776.121925 -44.677 -155.5234
13776.854347 -42.623 -146.8672
13777.586769 -43.238 -159.9160
13778.319191 -45.589 -152.1719
13779.051613 -39.934 -159.1992
13779.784035 -38.126 -169.0625
13780.516456 -38.202 -166.9824
13781.248878 -38.880 -175.7129
13781.981300 -39.208 173.7266
13782.713722 -39.126 167.7168
13783.446144 -40.029 177.6895
13784.178565 -37.167 162.6621
13784.910987 -38.949 153.3516
13785.643409 -37.314 157.6289
13786.375831 -38.601 139.9512
13787.108253 -37.873 132.5430
13787.840675 -36.690 126.6133
13788.573096 -36.563 129.9219
13789.305518 -36.575 121.9766
13790.037940 -37.895 113.8125
13790.770362 -36.546 103.5859
13791.502784 -37.454 104.7461
13792.235205 -39.206 106.2090
13792.967627 -37.400 93.4570
13793.700049 -38.899 95.7305
13794.432471 -41.048 84.8711
13795.164893 -42.214 89.8906
13795.897314 -38.514 77.6055
13796.629736 -40.539 67.0859
13797.362158 -40.597 80.2305
13798.094580 -47.372 89.4531
13798.827002 -43.876 85.7109
13799.559424 -44.294 90.2754
13800.291845 -45.310 60.3262
13801.024267 -47.352 106.2012
13801.756689 -49.128 96.0898
13802.489111 -42.918 96.2109
13803.221533 -43.711 116.8711
13803.953954 -45.996 123.7207
13804.686376 -41.786 106.8262
13805.418798 -41.026 101.7266
13806.151220 -40.251 93.6172
13806.883642 -38.185 95.1250
13807.616064 -40.443 106.8262
13808.348485 -37.695 96.4062
13809.080907 -37.716 80.2227
13809.813329 -36.540 93.7969
13810.545751 -37.219 84.3867
13811.278173 -38.470 62.4004
13812.010594 -35.092 66.6934
13812.743016 -39.351 66.8984
13813.475438 -38.097 51.0801
13814.207860 -35.869 57.3340
13814.940282 -36.721 48.4043
13815.672704 -36.282 49.7188
13816.405125 -37.017 44.4863
13817.137547 -35.933 48.5625
13817.869969 -35.998 41.7812
13818.602391 -37.994 46.3906
13819.334813 -38.660 54.1426
13820.067234 -40.094 30.2109
13820.799656 -39.096 19.8652
13821.532078 -41.119 41.7266
13822.264500 -40.451 16.8516
13822.996922 -40.253 15.3418
13823.729343 -43.919 18.9004
13824.461765 -39.688 9.5762
13825.194187 -40.498 -8.3281
13825.926609 -42.992 21.5098
13826.659031 -47.958 25.4492
13827.391453 -53.112 -6.3965
13828.123874 -44.368 -57.0352
13828.856296 -40.808 -66.4980
13829.588718 -46.284 -90.0879
13830.321140 -43.753 -72.0723
13831.053562 -45.732 -57.9238
13831.785983 -45.032 -109.5801
13832.518405 -49.003 -61.1582
13833.250827 -49.354 -168.9551
13833.983249 -48.586 -75.0059
13834.715671 -47.197 -50.9023
13835.448093 -47.178 -102.5020
13836.180514 -50.043 -123.7246
13836.912936 -47.787 -45.2305
13837.645358 -42.483 -57.9219
13838.377780 -49.064 -8.1289
13839.110202 -53.069 -59.9043
13839.842623 -48.713 -18.8652
13840.575045 -54.780 -35.4961
13841.307467 -45.530 -77.2383
13842.039889 -57.196 177.2188
13842.772311 -45.959 -72.6074
13843.504732 -50.410 -54.5391
13844.237154 -47.247 -65.0742
13844.969576 -62.080 141.2500
13845.701998 -44.077 -69.4336
13846.434420 -56.132 -84.5352
13847.166842 -46.811 -121.2168
13847.899263 -60.572 177.6211
13848.631685 -56.195 -58.9297
13849.364107 -49.734 -88.1875
13850.096529 -53.043 -71.6074
13850.828951 -48.749 147.8906
13851.561372 -41.829 9.2246
13852.293794 -38.368 16.1934
13853.026216 -43.682 -7.5410
13853.758638 -38.699 13.6973
13854.491060 -41.946 3.0723
13855.223482 -39.151 23.2520
13855.955903 -40.896 -4.8848
13856.688325 -42.889 22.8555
13857.420747 -41.626 -0.6777
13858.153169 -41.666 -10.5605
13858.885591 -38.084 -6.0078
13859.618012 -39.179 -6.9395
13860.350434 -38.830 -35.7656
13861.082856 -38.158 -30.3477
13861.815278 -38.733 -42.4863
13862.547700 -41.215 -10.6504
13863.280122 -46.035 -83.8398
13864.012543 -43.573 -94.8457
13864.744965 -46.064 -68.0430
13865.477387 -45.612 -106.0176
13866.209809 -43.336 -126.5352
13866.942231 -46.132 -112.6191
13867.674652 -42.608 -122.7461
13868.407074 -46.144 -177.5039
13869.139496 -39.004 -42.3047
13869.871918 -47.745 -51.7363
13870.604340 -45.783 -122.7852
13871.336761 -42.890 -47.8203
13872.069183 -44.385 -145.2832
13872.801605 -48.206 -160.1602
13873.534027 -47.666 -29.3242
13874.266449 -43.107 83.5918
13874.998871 -50.405 129.4727
13875.731292 -52.568 76.1562
13876.463714 -50.002 132.4648
13877.196136 -48.080 74.7578
13877.928558 -49.554 90.2188
13878.660980 -46.666 82.1328
13879.393401 -47.949 110.6445
13880.125823 -46.860 42.2246
13880.858245 -48.572 62.8340
13881.590667 -47.538 48.6758
13882.323089 -46.479 7.4766
13883.055511 -41.944 3.4199
13883.787932 -50.183 -28.2656
13884.520354 -45.048 -59.6758
13885.252776 -47.576 -31.4805
13885.985198 -45.337 -11.6328
13886.717620 -50.100 -44.1172
13887.450041 -45.341 -7.7832
13888.182463 -60.842 3.6621
13888.914885 -59.394 23.9805
13889.647307 -54.385 -152.6016
13890.379729 -49.185 -55.2188
13891.112150 -56.712 -63.5059
13891.844572 -48.019 32.3613
13892.576994 -51.464 -41.7168
13893.309416 -50.212 39.4199
13894.041838 -51.891 150.9375
13894.774260 -46.429 19.6328
13895.506681 -52.067 51.7207
13896.239103 -54.097 12.4785
13896.971525 -50.571 102.5820
13897.703947 -48.186 -3.5898
13898.436369 -47.477 48.5840
13899.168790 -53.267 49.8027
13899.901212 -58.844 27.5566
13900.633634 -44.708 -15.5273
13901.366056 -46.599 21.7539
13902.098478 -43.153 -23.2988
13902.830900 -46.849 64.8066
13903.563321 -41.087 -10.8516
13904.295743 -47.037 -14.8555
13905.028165 -43.720 4.3301
13905.760587 -43.261 -25.3730
13906.493009 -42.594 -42.7891
13907.225430 -44.212 -51.7480
13907.957852 -43.090 -40.3828
13908.690274 -45.479 -43.3711
13909.422696 -38.744 -50.7852
13910.155118 -41.947 -67.3750
13910.887540 -40.393 -87.5000
13911.619961 -40.690 -81.8887
13912.352383 -43.604 -87.3027
13913.084805 -46.701 -108.3574
13913.817227 -40.851 -106.4375
13914.549649 -50.778 -93.6953
13915.282070 -45.584 -99.3809
13916.014492 -48.797 -83.6211
13916.746914 -44.642 -78.3125
13917.479336 -51.312 -126.5605
13918.211758 -47.087 -92.6367
13918.944179 -44.401 -151.5898
13919.676601 -47.409 175.9746
13920.409023 -54.453 -56.3320
13921.141445 -49.531 -55.7168
13921.873867 -51.039 -23.8594
13922.606289 -41.550 14.7852
13923.338710 -47.789 -0.2676
13924.071132 -46.467 -29.4766
13924.803554 -39.634 6.3086
13925.535976 -46.397 -22.2422
13926.268398 -45.220 -8.7734
13927.000819 -43.359 -20.3340
13927.733241 -43.173 -56.9941
13928.465663 -43.705 -63.9023
13929.198085 -40.846 -53.2754
13929.930507 -41.286 -76.8086
13930.662929 -42.739 -76.6230
13931.395350 -47.396 -89.4746
13932.127772 -43.725 -102.7422
13932.860194 -39.937 -102.4531
13933.592616 -43.011 -114.6074
13934.325038 -40.652 -128.7129
13935.057459 -44.209 -151.0371
13935.789881 -41.659 -159.4629
13936.522303 -41.692 -164.5293
13937.254725 -40.741 -155.9082
13937.987147 -39.695 162.5977
13938.719568 -39.712 171.2891
13939.451990 -41.789 162.7188
13940.184412 -40.151 162.0352
13940.916834 -39.281 127.5664
13941.649256 -39.686 130.7891
13942.381678 -41.445 116.1094
13943.114099 -40.634 117.8555
13943.846521 -40.966 107.8438
13944.578943 -40.945 104.4297
13945.311365 -41.762 102.7695
13946.043787 -42.663 113.2031
13946.776208 -42.595 77.4180
13947.508630 -44.949 92.9023
13948.241052 -43.240 42.3984
13948.973474 -46.852 72.2227
13949.705896 -44.775 27.4219
13950.438318 -52.258 53.8867
13951.170739 -47.120 18.4922
13951.903161 -47.155 14.4180
13952.635583 -50.768 47.9414
13953.368005 -52.402 -64.5703
13954.100427 -61.782 89.7852
13954.832848 -52.041 -164.2441
13955.565270 -58.160 -137.2383
13956.297692 -51.650 -154.2441
13957.030114 -59.867 -150.0020
13957.762536 -45.760 152.3008
13958.494958 -55.404 115.5117
13959.227379 -45.407 136.2812
13959.959801 -49.064 105.4844
13960.692223 -41.323 99.7500
13961.424645 -44.132 96.5547
13962.157067 -42.985 92.8828
13962.889488 -42.376 115.7148
13963.621910 -43.308 105.6094
13964.354332 -41.486 81.9062
13965.086754 -41.070 91.4766
13965.819176 -39.385 66.1758
13966.551597 -39.327 63.8047
13967.284019 -41.561 50.0273
13968.016441 -41.468 53.0156
13968.748863 -39.884 24.1016
13969.481285 -40.741 9.1680
13970.213707 -39.208 1.3750
13970.946128 -39.685 3.0234
13971.678550 -38.410 -15.5234
13972.410972 -41.708 -22.4883
13973.143394 -39.807 -20.6328
13973.875816 -40.254 -36.3633
13974.608237 -39.810 -43.0703
13975.340659 -39.909 -52.8438
13976.073081 -41.749 -60.3086
13976.805503 -41.901 -76.7109
13977.537925 -42.544 -98.4688
13978.270347 -47.457 -79.6602
13979.002768 -43.670 -108.2812
13979.735190 -46.974 -139.8984
13980.467612 -43.960 -145.7109
13981.200034 -42.024 -155.9336
13981.932456 -48.732 -138.0430
13982.664877 -48.251 -164.3242
13983.397299 -47.165 160.3906
13984.129721 -43.545 151.9297
13984.862143 -44.599 106.8320
13985.594565 -44.637 118.1328
13986.326986 -44.535 103.3750
13987.059408 -41.569 102.4727
13987.791830 -44.155 78.2383
13988.524252 -43.456 64.8008
13989.256674 -41.410 68.4883
13989.989096 -40.380 61.6445
13990.721517 -41.253 51.1992
13991.453939 -39.798 38.8398
13992.186361 -40.173 39.3867
13992.918783 -40.450 22.0469
13993.651205 -40.352 20.5703
13994.383626 -40.345 34.9844
13995.116048 -41.419 12.1172
13995.848470 -40.319 25.3594
13996.580892 -41.862 3.8438
13997.313314 -40.259 14.3438
13998.045736 -45.058 4.8086
13998.778157 -46.439 -31.6602
13999.510579 -44.420 -18.0508
14000.243001 -55.384 15.6055
14000.975423 -50.867 -34.1445
14001.707845 -49.777 -6.0469
14002.440266 -46.580 23.7266
14003.172688 -53.111 54.7188
14003.905110 -49.452 18.5039
14004.637532 -44.817 17.6250
14005.369954 -47.497 39.7539
14006.102376 -45.990 36.0430
14006.834797 -46.368 13.9336
14007.567219 -41.217 24.8945
14008.299641 -43.277 37.3555
14009.032063 -42.087 22.9766
14009.764485 -40.514 39.8203
14010.496906 -39.563 35.9297
14011.229328 -39.235 5.1172
14011.961750 -38.592 17.4883
14012.694172 -36.952 8.8047
14013.426594 -36.770 4.2344
14014.159015 -36.242 2.7578
14014.891437 -37.606 -8.9570
14015.623859 -38.073 -6.5508
14016.356281 -37.553 -4.1680
14017.088703 -35.698 -20.9414
14017.821125 -36.359 -17.1094
14018.553546 -38.474 -23.6055
14019.285968 -36.600 -42.1367
14020.018390 -37.976 -32.8125
14020.750812 -37.241 -49.1133
14021.483234 -39.305 -58.6484
14022.215655 -38.974 -66.6367
14022.948077 -39.302 -68.5195
14023.680499 -41.082 -75.0547
14024.412921 -42.558 -97.9883
14025.145343 -40.308 -77.0820
14025.877765 -43.523 -96.2578
14026.610186 -43.232 -98.1758
14027.342608 -44.656 -106.8633
14028.075030 -42.827 -127.6484
14028.807452 -44.014 -101.6445
14029.539874 -47.680 -132.0898
14030.272295 -43.240 -146.7188
14031.004717 -51.199 -170.7422
14031.737139 -50.629 -92.5977
14032.469561 -52.751 -145.4688
14033.201983 -56.879 128.7930
14033.934404 -62.486 73.7266
14034.666826 -53.264 -44.4727
14035.399248 -53.147 -150.3047
14036.131670 -45.917 85.4961
14036.864092 -54.563 38.9805
14037.596514 -48.420 6.3789
14038.328935 -49.463 66.4844
14039.061357 -49.923 30.0391
14039.793779 -50.085 32.0430
14040.526201 -53.344 -36.7656
14041.258623 -47.681 5.6367
14041.991044 -54.452 1.4570
14042.723466 -53.122 -82.2695
14043.455888 -48.367 9.7891
14044.188310 -54.436 -7.0781
14044.920732 -60.640 -14.2461
14045.653154 -54.192 87.2852
14046.385575 -49.653 -2.1250
14047.117997 -49.529 31.7109
14047.850419 -50.614 29.5898
14048.582841 -46.733 35.5664
14049.315263 -45.940 40.1250
14050.047684 -48.065 77.0625
14050.780106 -40.886 38.6250
14051.512528 -38.396 35.5898
14052.244950 -40.859 39.2734
14052.977372 -39.434 21.9727
14053.709794 -39.411 34.1992
14054.442215 -40.827 22.5352
14055.174637 -38.159 14.2383
14055.907059 -42.923 2.1016
14056.639481 -37.117 6.0156
14057.371903 -37.033 10.4805
14058.104324 -38.439 -5.6211
14058.836746 -36.738 1.6016
14059.569168 -34.711 -13.4648
14060.301590 -34.372 -17.6562
14061.034012 -35.995 -29.0430
14061.766433 -33.977 -26.8711
14062.498855 -36.901 -32.0625
14063.231277 -37.546 -44.9297
14063.963699 -37.680 -53.5586
14064.696121 -36.748 -56.8398
14065.428543 -38.240 -64.6641
14066.160964 -37.318 -62.3750
14066.893386 -36.003 -75.9180
14067.625808 -36.449 -87.9922
14068.358230 -37.833 -83.2188
14069.090652 -37.678 -110.1094
14069.823073 -36.950 -111.1797
14070.555495 -38.250 -115.9961
14071.287917 -38.346 -104.3086
14072.020339 -35.893 -121.3438
14072.752761 -37.685 -127.0039
14073.485183 -38.533 -129.9062
14074.217604 -37.859 -145.8711
14074.950026 -39.131 -146.7148
14075.682448 -37.259 -152.0664
14076.414870 -37.135 -179.9062
14077.147292 -40.548 175.7070
14077.879713 -39.306 172.3789
14078.612135 -38.966 -177.3320
14079.344557 -39.650 162.3594
14080.076979 -42.322 172.7969
14080.809401 -43.916 149.9883
14081.541822 -44.071 141.3516
14082.274244 -40.008 127.3359
14083.006666 -45.395 120.8320
14083.739088 -46.663 109.1523
14084.471510 -43.988 98.0742
14085.203932 -43.831 89.4609
14085.936353 -49.369 85.7305
14086.668775 -47.253 84.3789
14087.401197 -55.531 80.7148
14088.133619 -54.535 66.9375
14088.866041 -48.677 11.5156
14089.598462 -56.027 64.8906
14090.330884 -66.392 -37.1641
14091.063306 -60.630 -22.4961
14091.795728 -47.021 -39.5664
14092.528150 -48.166 -24.9531
14093.260572 -48.872 -70.5117
14093.992993 -52.818 -64.9414
14094.725415 -47.514 -47.7305
14095.457837 -52.061 -44.7695
14096.190259 -48.619 -75.7773
14096.922681 -59.885 -90.3359
14097.655102 -49.806 -113.3086
14098.387524 -47.986 -104.0469
14099.119946 -49.954 -130.0312
14099.852368 -45.089 -154.4883
14100.584790 -52.603 -162.1523
14101.317212 -52.031 -148.5117
14102.049633 -48.591 -176.5469
14102.782055 -45.814 136.9648
14103.514477 -49.010 -131.0820
14104.246899 -51.502 -174.3438
14104.979321 -50.867 178.9961
14105.711742 -57.761 96.8086
14106.444164 -50.164 168.7891
14107.176586 -46.982 140.1875
14107.909008 -55.593 138.9844
14108.641430 -48.965 81.0781
14109.373851 -53.821 174.6367
14110.106273 -48.244 -177.7539
14110.838695 -44.194 169.6328
14111.571117 -50.563 157.1914
14112.303539 -54.436 -165.4570
14113.035961 -49.013 89.8750
14113.768382 -52.250 113.4453
14114.500804 -46.661 132.4805
14115.233226 -48.153 -163.1172
14115.965648 -54.428 120.5469
14116.698070 -47.429 141.8711
14117.430491 -57.804 146.0898
14118.162913 -51.026 171.9922
14118.895335 -49.036 177.0195
14119.627757 -47.641 149.6992
14120.360179 -55.043 137.8594
14121.092601 -46.977 130.0156
14121.825022 -48.280 96.3984
14122.557444 -47.031 102.4844
14123.289866 -44.870 91.7695
14124.022288 -48.545 88.2344
14124.754710 -45.271 89.5312
14125.487131 -45.172 86.1367
14126.219553 -43.345 91.3008
14126.951975 -45.123 103.1602
14127.684397 -49.349 96.7461
14128.416819 -44.506 80.4180
14129.149240 -42.122 42.9258
14129.881662 -47.552 73.8633
14130.614084 -42.648 52.7344
14131.346506 -42.689 33.0938
14132.078928 -42.745 16.4453
14132.811350 -45.496 40.5234
14133.543771 -43.352 45.4570
14134.276193 -41.861 33.5508
14135.008615 -42.227 34.9961
14135.741037 -43.687 22.0742
14136.473459 -41.667 5.6875
14137.205880 -42.588 21.2344
14137.938302 -42.129 13.9531
14138.670724 -42.911 7.1094
14139.403146 -44.249 -9.8477
14140.135568 -45.707 -15.3594
14140.867990 -41.709 7.4766
14141.600411 -45.294 -31.8398
14142.332833 -43.408 -16.8789
14143.065255 -45.747 -19.0430
14143.797677 -42.432 -19.7422
14144.530099 -47.633 -53.8711
14145.262520 -48.945 -90.1562
14145.994942 -44.390 -62.4023
14146.727364 -58.045 -23.1016
14147.459786 -47.011 -46.8984
14148.192208 -52.549 -38.9219
14148.924630 -45.593 -55.8281
14149.657051 -42.386 -17.9609
14150.389473 -49.970 -7.3750
14151.121895 -45.997 -52.1953
14151.854317 -44.755 -40.9883
14152.586739 -52.912 -84.6016
14153.319160 -56.346 -103.0039
14154.051582 -52.138 -83.0625
14154.784004 -43.443 -32.1719
14155.516426 -47.317 -71.7852
14156.248848 -54.419 -113.1250
14156.981269 -51.527 -87.0234
14157.713691 -49.506 -88.6641
14158.446113 -45.682 -77.4766
14159.178535 -51.267 -135.4648
14159.910957 -50.722 -109.5156
14160.643379 -49.966 -136.6445
14161.375800 -63.251 -33.0273
14162.108222 -49.321 162.6172
14162.840644 -48.291 -151.2422
14163.573066 -52.394 -73.5117
14164.305488 -52.670 -85.1953
14165.037909 -49.323 158.1992
14165.770331 -47.443 131.8438
14166.502753 -47.894 178.5664
14167.235175 -45.979 126.0547
14167.967597 -47.232 151.7500
14168.700019 -49.253 119.4258
14169.432440 -44.657 103.3984
14170.164862 -48.214 46.1211
14170.897284 -47.242 105.6484
14171.629706 -46.566 73.1562
14172.362128 -46.165 87.4492
14173.094549 -43.005 69.3555
14173.826971 -42.590 62.1367
14174.559393 -42.706 70.0664
14175.291815 -42.677 50.7266
14176.024237 -45.989 50.8750
14176.756658 -42.341 47.1406
14177.489080 -42.659 30.5938
14178.221502 -41.372 -14.5547
14178.953924 -44.298 -27.1719
14179.686346 -42.910 6.9727
14180.418768 -39.310 -12.1992
14181.151189 -41.459 -16.4336
14181.883611 -39.390 -17.8438
14182.616033 -42.145 -29.2266
14183.348455 -40.932 -36.1484
14184.080877 -41.791 -48.5977
14184.813298 -40.036 -52.8516
14185.545720 -40.958 -44.9609
14186.278142 -40.778 -57.3867
14187.010564 -41.413 -78.6211
14187.742986 -41.569 -87.2539
14188.475408 -43.959 -81.6055
14189.207829 -41.733 -106.6055
14189.940251 -41.764 -97.2773
14190.672673 -43.228 -92.1484
14191.405095 -45.332 -110.1328
14192.137517 -42.298 -94.3633
14192.869938 -47.385 -123.6602
14193.602360 -48.300 -104.6523
14194.334782 -50.408 -125.1016
14195.067204 -45.975 -124.3359
14195.799626 -46.676 -141.3516
14196.532048 -49.097 -112.5156
14197.264469 -64.692 -8.3633
14197.996891 -53.891 138.1406
14198.729313 -50.251 -149.3750
14199.461735 -57.103 106.5430
14200.194157 -53.252 70.7539
14200.926578 -50.543 -124.7227
14201.659000 -47.524 134.2344
14202.391422 -45.170 -83.3203
14203.123844 -42.702 -81.5781
14203.856266 -46.900 -77.1992
14204.588687 -43.060 -94.0898
14205.321109 -42.092 -76.1445
14206.053531 -36.769 -74.5625
14206.785953 -42.579 -108.7461
14207.518375 -38.220 -123.3320
14208.250797 -43.343 -87.2969
14208.983218 -44.383 -98.3633
14209.715640 -39.178 -114.7578
14210.448062 -40.351 -121.1836
14211.180484 -41.382 -122.5273
14211.912906 -41.008 -108.6758
14212.645327 -44.751 -149.0625
14213.377749 -39.380 -127.2188
14214.110171 -39.986 -120.9492
14214.842593 -39.927 -136.3477
14215.575015 -41.876 -155.9062
14216.307437 -40.529 -137.2031
14217.039858 -43.555 -130.2422
14217.772280 -42.136 -137.8359
14218.504702 -41.604 -143.5000
14219.237124 -39.784 -138.0703
14219.969546 -38.912 -143.4141
14220.701967 -42.456 -94.6250
14221.434389 -42.542 -114.5508
14222.166811 -50.650 -92.1914
14222.899233 -39.760 -139.1016
14223.631655 -38.994 -93.1055
14224.364076 -41.935 -140.2969
14225.096498 -43.298 -114.1680
14225.828920 -44.393 -168.4414
14226.561342 -45.464 -144.0859
14227.293764 -45.986 -141.9258
14228.026186 -44.380 159.7070
14228.758607 -46.159 -162.2539
14229.491029 -45.531 -125.8047
14230.223451 -40.502 163.8828
14230.955873 -40.390 -178.8281
14231.688295 -46.119 156.1719
14232.420716 -39.622 172.3945
14233.153138 -39.939 177.1406
14233.885560 -39.455 142.3281
14234.617982 -43.806 123.6016
14235.350404 -45.383 -157.8281
14236.082826 -42.804 137.7695
14236.815247 -43.768 150.2852
14237.547669 -42.891 148.9766
14238.280091 -40.891 149.1289
14239.012513 -40.692 151.5977
14239.744935 -40.098 121.1602
14240.477356 -43.801 103.2773
14241.209778 -44.408 114.7734
14241.942200 -54.760 122.4648
14242.674622 -36.674 138.0703
14243.407044 -60.315 -163.3320
14244.139466 -50.407 -175.8594
14244.871887 -44.870 158.8789
14245.604309 -43.449 121.1445
14246.336731 -45.466 -55.5273
14247.069153 -44.779 -140.5781
14247.801575 -43.802 -165.4609
14248.533996 -45.827 175.7852
14249.266418 -42.456 134.5625
14249.998840 -47.135 -133.0156
14250.731262 -59.230 -115.4102
14251.463684 -47.038 143.8242
14252.196105 -46.832 -177.0039
14252.928527 -44.963 -171.4336
14253.660949 -43.321 -161.2930
14254.393371 -40.831 174.5312
14255.125793 -41.852 162.1133
14255.858215 -39.173 171.3359
14256.590636 -42.129 152.7812
14257.323058 -36.984 121.3320
14258.055480 -39.136 124.1602
14258.787902 -45.733 153.7891
14259.520324 -42.223 103.5430
14260.252745 -37.719 100.7500
14260.985167 -41.755 107.0195
14261.717589 -41.043 72.5195
14262.450011 -39.979 94.1406
14263.182433 -40.983 76.1992
14263.914855 -38.478 69.6289
14264.647276 -45.791 69.0352
14265.379698 -37.404 46.3008
14266.112120 -36.935 48.4375
14266.844542 -37.604 52.0469
14267.576964 -38.891 41.3281
14268.309385 -38.776 27.8359
14269.041807 -39.771 24.9297
14269.774229 -37.362 17.6602
14270.506651 -39.941 21.7656
14271.239073 -38.440 -1.2344
14271.971494 -37.003 26.5391
14272.703916 -42.538 -30.9766
14273.436338 -41.114 -13.5195
14274.168760 -41.604 -16.7305
14274.901182 -46.302 -11.4648
14275.633604 -44.245 -30.7031
14276.366025 -42.003 -68.3047
14277.098447 -45.085 13.5273
14277.830869 -45.173 -51.2539
14278.563291 -45.357 -30.0508
14279.295713 -50.561 -64.4883
14280.028134 -45.823 17.9180
14280.760556 -46.740 13.0273
14281.492978 -44.158 -58.2070
14282.225400 -53.342 -41.8320
14282.957822 -50.551 -83.1445
14283.690244 -44.454 -94.7148
14284.422665 -50.029 -55.4922
14285.155087 -47.466 -25.7305
14285.887509 -46.224 -94.8477
14286.619931 -47.443 -93.5820
14287.352353 -41.458 -101.9414
14288.084774 -44.752 -108.7891
14288.817196 -49.951 -29.5781
14289.549618 -46.886 -45.2891
14290.282040 -65.942 156.4375
14291.014462 -49.326 -90.0195
14291.746884 -45.047 -132.4141
14292.479305 -45.118 -40.1523
14293.211727 -47.245 -159.9141
14293.944149 -44.387 -170.2461
14294.676571 -46.482 -97.2578
14295.408993 -47.636 -164.2617
14296.141414 -45.379 -167.9531
14296.873836 -46.678 -160.9570
14297.606258 -46.137 -170.9062
14298.338680 -46.963 -173.7656
14299.071102 -45.065 -179.3086
14299.803523 -44.834 -176.6211
14300.535945 -44.508 148.1406
14301.268367 -41.688 122.2695
14302.000789 -43.652 140.0547
14302.733211 -38.881 114.9141
14303.465633 -44.876 115.7305
14304.198054 -39.195 106.2852
14304.930476 -41.099 81.2891
14305.662898 -39.416 97.7852
14306.395320 -37.093 84.4844
14307.127742 -37.233 85.8203
14307.860163 -38.047 86.4141
14308.592585 -42.914 86.9336
14309.325007 -35.282 55.1367
14310.057429 -38.996 56.5547
14310.789851 -39.147 59.8359
14311.522273 -38.473 51.2578
14312.254694 -39.898 32.4180
14312.987116 -39.106 37.3945
14313.719538 -39.498 30.9922
14314.451960 -39.645 32.4023
14315.184382 -39.298 20.1406
14315.916803 -39.375 13.2109
14316.649225 -41.857 9.5547
14317.381647 -41.916 14.5742
14318.114069 -38.639 -9.9883
14318.846491 -41.179 -10.6328
14319.578912 -44.849 13.7812
14320.311334 -45.885 -30.2031
14321.043756 -51.495 -39.2734
14321.776178 -43.109 -9.3398
14322.508600 -52.439 -2.1562
14323.241022 -59.297 -134.5234
14323.973443 -59.333 -11.5977
14324.705865 -54.546 88.7734
14325.438287 -44.142 109.4844
14326.170709 -48.357 89.8164
14326.903131 -45.702 94.6133
14327.635552 -42.624 111.9961
14328.367974 -39.734 95.0547
14329.100396 -39.641 68.9844
14329.832818 -39.276 51.7461
14330.565240 -39.495 61.2070
14331.297662 -37.237 46.6758
14332.030083 -36.908 68.4531
14332.762505 -37.098 58.2422
14333.494927 -37.811 41.6016
14334.227349 -36.059 47.0859
14334.959771 -35.969 24.0547
14335.692192 -35.898 20.2852
14336.424614 -35.023 15.2070
14337.157036 -34.127 14.0156
14337.889458 -34.950 12.2812
14338.621880 -34.691 -3.4648
14339.354302 -34.421 -6.3359
14340.086723 -34.659 -5.6914
14340.819145 -35.465 -14.6211
14341.551567 -35.301 -31.2031
14342.283989 -34.748 -29.0391
14343.016411 -36.112 -31.4062
14343.748832 -38.481 -38.3398
14344.481254 -38.359 -50.2461
14345.213676 -36.999 -55.3750
14345.946098 -39.401 -50.4180
14346.678520 -40.446 -59.4297
14347.410941 -40.105 -61.2930
14348.143363 -42.101 -75.4219
14348.875785 -41.925 -69.2539
14349.608207 -49.307 -81.4297
14350.340629 -48.386 -113.8125
14351.073051 -45.755 -80.7734
14351.805472 -49.833 -31.2734
14352.537894 -79.265 -92.9766
14353.270316 -63.179 153.7734
14354.002738 -49.580 3.9688
14354.735160 -46.967 18.5781
14355.467581 -44.787 42.7383
14356.200003 -46.016 1.9297
14356.932425 -43.517 32.8633
14357.664847 -43.850 17.8125
14358.397269 -40.771 15.1992
14359.129691 -40.478 -9.3047
14359.862112 -41.178 -7.3516
14360.594534 -39.314 -18.1602
14361.326956 -40.142 -6.2109
14362.059378 -40.847 -14.0586
14362.791800 -37.642 -34.8164
14363.524221 -39.124 -32.8672
14364.256643 -38.910 -52.5273
14364.989065 -38.667 -52.2148
14365.721487 -37.668 -56.9336
14366.453909 -40.180 -52.2734
14367.186330 -39.433 -67.1953
14367.918752 -39.716 -74.3203
14368.651174 -38.210 -94.1133
14369.383596 -40.736 -85.8906
14370.116018 -42.807 -95.2070
14370.848440 -42.300 -117.0547
14371.580861 -44.094 -116.3672
14372.313283 -42.801 -110.6289
14373.045705 -44.900 -133.0039
14373.778127 -47.706 -158.1289
14374.510549 -52.673 -165.7383
14375.242970 -52.640 156.1914
14375.975392 -57.355 -2.3203
14376.707814 -56.658 138.1680
14377.440236 -45.391 60.2930
14378.172658 -48.134 27.2266
14378.905080 -43.320 37.6836
14379.637501 -43.085 15.6836
14380.369923 -46.067 7.3086
14381.102345 -41.970 9.4336
14381.834767 -39.180 22.8945
14382.567189 -40.654 3.2773
14383.299610 -38.470 -7.3008
14384.032032 -38.667 -16.0508
14384.764454 -37.498 -14.2539
14385.496876 -38.079 -29.9219
14386.229298 -39.182 -30.6914
14386.961720 -36.497 -45.1641
14387.694141 -37.686 -41.9141
14388.426563 -36.882 -46.9336
14389.158985 -37.019 -49.7383
14389.891407 -37.129 -70.5039
14390.623829 -38.231 -68.8828
14391.356250 -35.877 -80.4414
14392.088672 -37.714 -86.9062
14392.821094 -39.245 -89.4844
14393.553516 -37.553 -81.9023
14394.285938 -36.531 -111.6914
14395.018359 -38.194 -106.4883
14395.750781 -37.003 -109.4805
14396.483203 -39.191 -120.9102
14397.215625 -41.566 -132.0156
14397.948047 -42.923 -144.6914
14398.680469 -41.760 -134.6875
14399.412890 -45.358 -118.9492
14400.145312 -47.736 -146.3086
14400.877734 -43.464 -133.9648
14401.610156 -47.739 -139.8984
14402.342578 -49.867 -127.1641
14403.074999 -56.809 -116.2461
14403.807421 -59.134 -124.4727
14404.539843 -62.209 -71.8750
14405.272265 -51.721 -15.6680
14406.004687 -51.431 -88.6875
14406.737109 -46.942 -27.5078
14407.469530 -54.276 -94.7891
14408.201952 -52.219 -41.4102
14408.934374 -42.744 -30.8320
14409.666796 -45.276 -68.9922
14410.399218 -41.486 -46.7539
14411.131639 -41.949 -62.6406
14411.864061 -43.981 -65.9453
14412.596483 -40.668 -68.7109
14413.328905 -40.344 -79.4922
14414.061327 -42.559 -84.8945
14414.793748 -41.756 -78.9961
14415.526170 -43.256 -110.7266
14416.258592 -40.945 -113.6719
14416.991014 -45.839 -109.4062
14417.723436 -41.197 -119.3945
14418.455858 -40.840 -111.1523
14419.188279 -42.718 -126.1250
14419.920701 -50.357 -160.7422
14420.653123 -47.548 -142.5859
14421.385545 -59.522 -133.0547
14422.117967 -45.735 -163.2344
14422.850388 -50.185 -119.5117
14423.582810 -52.975 167.5117
14424.315232 -50.702 -94.2930
14425.047654 -55.225 -162.5000
14425.780076 -53.506 -137.8320
14426.512498 -59.479 -143.1914
14427.244919 -63.413 -113.5312
14427.977341 -54.514 -54.5898
14428.709763 -50.253 28.1172
14429.442185 -50.061 -60.4219
14430.174607 -53.132 -141.5312
14430.907028 -52.139 -72.9805
14431.639450 -46.369 -39.5312
14432.371872 -44.777 -58.6406
14433.104294 -48.961 -24.8594
14433.836716 -46.977 -57.3945
14434.569138 -43.612 -67.5664
14435.301559 -47.720 -62.9375
14436.033981 -42.534 -94.8359
14436.766403 -46.214 -111.3203
14437.498825 -42.293 -83.6445
14438.231247 -43.682 -84.4570
14438.963668 -43.880 -101.3125
14439.696090 -42.702 -105.1328
14440.428512 -42.452 -109.9648
14441.160934 -43.470 -124.6055
14441.893356 -42.558 -132.0234
14442.625777 -43.786 -127.8086
14443.358199 -43.636 -128.4023
14444.090621 -43.637 -110.2695
14444.823043 -52.501 -140.6836
14445.555465 -43.951 -140.2305
14446.287887 -50.851 -141.8555
14447.020308 -49.900 -92.5898
14447.752730 -45.190 -159.1797
14448.485152 -50.712 -144.3047
14449.217574 -52.032 -153.5078
14449.949996 -64.526 -170.8555
14450.682417 -51.100 -91.1445
14451.414839 -55.227 -68.3984
14452.147261 -65.973 149.7539
14452.879683 -58.971 -1.3242
14453.612105 -55.613 -23.7500
14454.344527 -48.578 -12.8438
14455.076948 -52.588 -65.7422
14455.809370 -45.671 -75.0000
14456.541792 -46.370 -59.7383
14457.274214 -45.071 -87.0703
14458.006636 -51.365 -96.3477
14458.739057 -46.548 -81.7656
14459.471479 -47.124 -150.8711
14460.203901 -42.609 -122.6367
14460.936323 -47.965 -122.8203
14461.668745 -44.321 -127.6484
14462.401166 -50.551 -137.2812
14463.133588 -47.015 -112.6055
14463.866010 -46.488 -129.1914
14464.598432 -45.792 -109.5430
14465.330854 -44.209 178.5156
14466.063276 -53.306 154.8398
14466.795697 -52.195 -129.9883
14467.528119 -53.861 141.4375
14468.260541 -50.315 -143.1680
14468.992963 -59.842 131.2148
14469.725385 -55.544 -157.4258
14470.457806 -48.165 7.2930
14471.190228 -55.216 123.9219
14471.922650 -52.049 -31.9844
14472.655072 -51.563 -16.7695
14473.387494 -47.229 -4.1641
14474.119916 -47.976 -15.4062
14474.852337 -44.838 -18.0469
14475.584759 -47.037 -45.7773
14476.317181 -45.689 -47.3633
14477.049603 -45.448 -34.0273
14477.782025 -41.485 -54.3359
14478.514446 -41.705 -58.9258
14479.246868 -41.304 -67.3984
14479.979290 -39.581 -83.1523
14480.711712 -40.102 -86.9766
14481.444134 -38.815 -91.4102
14482.176556 -37.790 -99.3281
14482.908977 -40.980 -112.0273
14483.641399 -39.375 -108.9961
14484.373821 -37.989 -113.6562
14485.106243 -37.407 -121.3711
14485.838665 -37.702 -129.6328
14486.571086 -37.810 -133.4531
14487.303508 -37.277 -146.6719
14488.035930 -38.304 -142.6094
14488.768352 -37.818 -170.4180
14489.500774 -38.243 -159.9414
14490.233195 -38.116 -172.6328
14490.965617 -39.330 -160.3828
14491.698039 -38.569 -169.4023
14492.430461 -39.277 163.0820
14493.162883 -37.388 163.8008
14493.895305 -40.578 161.3242
14494.627726 -39.909 148.5859
14495.360148 -40.324 157.4258
14496.092570 -42.132 137.7070
14496.824992 -42.574 120.2812
14497.557414 -39.633 155.3750
14498.289835 -43.583 132.2422
14499.022257 -43.837 127.5508
14499.754679 -43.017 128.3125
14500.487101 -41.831 116.2227
14501.219523 -46.710 138.3906
14501.951945 -47.063 117.4844
14502.684366 -45.530 131.3984
14503.416788 -44.910 104.5742
14504.149210 -49.220 129.5859
14504.881632 -48.379 60.8125
14505.614054 -48.735 86.9219
14506.346475 -43.826 87.2266
14507.078897 -44.593 103.5195
14507.811319 -47.901 88.2148
14508.543741 -45.700 67.8125
14509.276163 -48.042 80.5391
14510.008584 -46.263 78.5898
14510.741006 -45.061 85.7109
14511.473428 -48.707 68.1211
14512.205850 -45.884 53.9570
14512.938272 -46.973 79.0938
14513.670694 -50.693 27.2734
14514.403115 -47.188 41.7539
14515.135537 -51.699 50.1602
14515.867959 -45.414 25.3164
14516.600381 -47.620 23.7500
14517.332803 -46.769 12.7734
14518.065224 -41.441 22.8906
14518.797646 -44.825 2.7266
14519.530068 -42.041 -8.4570
14520.262490 -43.244 -23.3672
14520.994912 -44.684 -7.5859
14521.727334 -43.209 -17.4766
14522.459755 -43.598 -32.2109
14523.192177 -43.354 -38.4258
14523.924599 -42.310 -44.3984
14524.657021 -44.276 -55.6875
14525.389443 -44.698 -82.8438
14526.121864 -44.209 -78.0625
14526.854286 -48.030 -110.2266
14527.586708 -43.829 -108.4414
14528.319130 -48.609 -99.8984
14529.051552 -43.630 -103.9453
14529.783974 -49.998 -57.9141
14530.516395 -47.806 -104.5039
14531.248817 -50.820 -86.8477
14531.981239 -50.415 -133.2852
14532.713661 -64.726 98.6641
14533.446083 -59.149 -71.4570
14534.178504 -56.980 -11.9844
14534.910926 -58.871 -35.8555
14535.643348 -49.263 -14.5586
14536.375770 -56.989 -22.2344
14537.108192 -56.127 -57.1562
14537.840613 -57.981 -79.5977
14538.573035 -59.211 57.8984
14539.305457 -45.861 5.7500
14540.037879 -51.732 -8.3945
14540.770301 -45.397 -21.0664
14541.502723 -44.407 -21.5078
14542.235144 -48.368 -36.4648
14542.967566 -44.209 -38.6758
14543.699988 -41.338 -50.4766
14544.432410 -49.084 -45.8125
14545.164832 -52.085 -50.0391
14545.897253 -42.489 -46.4883
14546.629675 -44.630 -71.4062
14547.362097 -43.192 -75.9336
14548.094519 -55.302 -96.5938
14548.826941 -45.666 -89.9883
14549.559363 -48.761 -94.6523
14550.291784 -56.623 -52.3203
14551.024206 -45.324 -94.8555
14551.756628 -45.010 -121.5039
14552.489050 -51.104 -55.7617
14553.221472 -48.362 -65.4336
14553.953893 -47.421 -35.8594
14554.686315 -53.598 -74.4219
14555.418737 -53.838 7.4766
14556.151159 -51.436 -135.9805
14556.883581 -61.329 42.2656
14557.616003 -47.081 -26.7812
14558.348424 -49.007 -3.3047
14559.080846 -47.889 -38.9023
14559.813268 -47.816 -13.9023
14560.545690 -48.037 -37.4883
14561.278112 -45.130 -38.8008
14562.010533 -44.621 -16.1055
14562.742955 -41.911 -17.8359
14563.475377 -44.767 -34.7695
14564.207799 -44.324 -48.9805
14564.940221 -40.404 -43.5078
14565.672642 -39.785 -43.8594
14566.405064 -39.830 -65.3125
14567.137486 -41.371 -54.3789
14567.869908 -42.576 -67.1797
14568.602330 -40.780 -77.6484
14569.334752 -38.119 -65.9297
14570.067173 -38.455 -72.7969
14570.799595 -38.431 -82.3359
14571.532017 -41.318 -95.9531
14572.264439 -40.612 -97.0781
14572.996861 -38.788 -97.2031
14573.729282 -42.087 -92.3086
14574.461704 -41.484 -114.6016
14575.194126 -41.275 -121.9336
14575.926548 -40.432 -112.2461
14576.658970 -39.916 -104.3516
14577.391392 -40.220 -118.2656
14578.123813 -45.004 -131.4727
14578.856235 -50.873 -132.1250
14579.588657 -59.604 165.8867
14580.321079 -53.076 178.5898
14581.053501 -50.624 -134.6797
14581.785922 -54.016 9.4375
14582.518344 -52.978 -171.9805
14583.250766 -53.784 -108.9531
14583.983188 -57.757 166.7734
14584.715610 -52.042 147.8203
14585.448031 -59.026 -33.8047
14586.180453 -52.666 -73.7031
14586.912875 -64.235 172.0273
14587.645297 -52.608 -53.7773
14588.377719 -46.768 -61.0742
14589.110141 -49.943 -40.4688
14589.842562 -45.087 -87.1602
14590.574984 -45.476 -59.0781
14591.307406 -46.241 -41.1367
14592.039828 -43.042 -75.6758
14592.772250 -46.741 -109.8359
14593.504671 -43.123 -96.0977
14594.237093 -40.956 -125.8320
14594.969515 -46.404 -110.4414
14595.701937 -40.862 -145.8711
14596.434359 -45.699 -151.4844
14597.166781 -46.983 -133.6289
14597.899202 -42.816 -167.1523
14598.631624 -42.642 -176.9961
14599.364046 -42.852 -158.1172
14600.096468 -42.951 171.5156
14600.828890 -44.109 168.0430
14601.561311 -40.778 -171.0352
14602.293733 -38.382 176.2070
14603.026155 -41.086 152.4961
14603.758577 -40.269 169.5000
14604.490999 -38.247 175.6523
14605.223421 -41.296 167.9961
14605.955842 -41.503 154.5742
14606.688264 -43.715 147.0586
14607.420686 -41.743 128.2578
14608.153108 -42.558 136.2500
14608.885530 -48.074 114.1172
14609.617951 -47.325 99.6758
14610.350373 -49.345 76.3789
14611.082795 -51.009 142.8711
14611.815217 -49.412 175.9648
14612.547639 -46.038 67.4297
14613.280060 -49.978 23.1953
14614.012482 -45.331 -39.6523
14614.744904 -47.749 1.2891
14615.477326 -43.547 -23.1992
14616.209748 -47.330 -90.4141
14616.942170 -45.645 -48.6602
14617.674591 -46.360 -52.3438
14618.407013 -44.351 -33.7109
14619.139435 -45.139 -131.4297
14619.871857 -43.910 -144.5039
14620.604279 -40.927 -129.8555
14621.336700 -48.623 -168.6953
14622.069122 -52.017 -112.9609
14622.801544 -43.104 -133.4141
14623.533966 -42.307 -176.3125
14624.266388 -41.636 -168.9688
14624.998810 -46.957 -152.9258
14625.731231 -46.826 -148.6836
14626.463653 -58.253 -140.6680
14627.196075 -44.203 -169.1367
14627.928497 -46.059 148.5547
14628.660919 -55.995 -168.1953
14629.393340 -47.027 173.6406
14630.125762 -59.432 73.0977
14630.858184 -51.914 174.9492
14631.590606 -49.798 45.7930
14632.323028 -51.689 80.4258
14633.055449 -48.139 63.8633
14633.787871 -54.909 58.5430
14634.520293 -52.996 17.4844
14635.252715 -56.474 10.9688
14635.985137 -48.033 -29.5664
14636.717559 -47.314 -48.6836
14637.449980 -48.044 -72.9180
14638.182402 -43.551 -66.4844
14638.914824 -42.342 -88.8047
14639.647246 -44.146 -59.6992
14640.379668 -41.289 -87.4414
14641.112089 -43.486 -63.1523
14641.844511 -44.054 -74.0430
14642.576933 -43.211 -78.3047
14643.309355 -40.572 -115.2812
14644.041777 -39.536 -95.3828
14644.774199 -42.885 -114.9414
14645.506620 -43.811 -154.2812
14646.239042 -40.846 -140.8242
14646.971464 -40.540 -127.4922
14647.703886 -45.553 -164.0312
14648.436308 -41.854 -155.5000
14649.168729 -39.941 -154.2656
14649.901151 -42.080 -138.6953
14650.633573 -42.015 173.3086
14651.365995 -41.703 -176.1055
14652.098417 -42.252 172.7109
14652.830839 -46.827 -152.6719
14653.563260 -45.334 152.9766
14654.295682 -44.427 142.1445
14655.028104 -42.980 145.0078
14655.760526 -45.913 105.7188
14656.492948 -44.465 143.6797
14657.225369 -64.561 21.2266
14657.957791 -45.293 109.0977
14658.690213 -49.020 98.6953
14659.422635 -46.063 47.5586
14660.155057 -45.813 97.1992
14660.887478 -49.709 111.4883
14661.619900 -46.489 44.7891
14662.352322 -54.925 38.6055
14663.084744 -49.801 -16.9805
14663.817166 -49.911 -42.2578
14664.549588 -58.125 23.4453
14665.282009 -44.185 -74.6602
14666.014431 -45.773 -83.1875
14666.746853 -53.411 -47.6875
14667.479275 -45.412 -101.7734
14668.211697 -42.167 -112.3125
14668.944118 -45.135 -114.2695
14669.676540 -50.467 -133.1836
14670.408962 -43.521 -133.6953
14671.141384 -44.263 -132.9102
14671.873806 -44.816 -150.0117
14672.606228 -43.101 177.5742
14673.338649 -40.080 -149.0742
14674.071071 -43.920 -158.3047
14674.803493 -40.818 -157.3906
14675.535915 -40.746 -161.8438
14676.268337 -40.273 -178.9375
14677.000758 -39.497 -173.1484
14677.733180 -38.127 178.2812
14678.465602 -40.312 164.3242
14679.198024 -38.628 176.9062
14679.930446 -39.852 165.4180
14680.662867 -40.656 157.7070
14681.395289 -42.289 166.9805
14682.127711 -41.535 138.1484
14682.860133 -41.529 128.8828
14683.592555 -41.100 129.4023
14684.324977 -37.061 112.4297
14685.057398 -42.230 118.1172
14685.789820 -39.716 110.0508
14686.522242 -45.263 101.6836
14687.254664 -40.101 101.3086
14687.987086 -45.817 79.4570
14688.719507 -43.550 123.5586
14689.451929 -44.424 76.9258
14690.184351 -42.712 95.9883
14690.916773 -47.983 84.0859
14691.649195 -51.585 89.8438
14692.381617 -47.650 26.6016
14693.114038 -51.006 81.2930
14693.846460 -53.026 84.7500
14694.578882 -57.246 -0.1211
14695.311304 -70.109 81.0742
14696.043726 -50.000 112.3477
14696.776147 -47.246 -130.2930
14697.508569 -66.075 -133.7031
14698.240991 -59.492 104.8750
14698.973413 -53.222 172.9062
14699.705835 -49.266 -169.0742
14700.438257 -47.088 -176.9102
14701.170678 -47.913 -153.8281
14701.903100 -44.364 150.0547
14702.635522 -45.608 169.9414
14703.367944 -48.590 166.8867
14704.100366 -45.137 160.0859
14704.832787 -44.714 144.8516
14705.565209 -44.200 148.2930
14706.297631 -47.439 142.6367
14707.030053 -44.702 114.8047
14707.762475 -44.613 118.7695
14708.494896 -42.775 134.9805
14709.227318 -41.741 117.6953
14709.959740 -43.389 94.5547
14710.692162 -45.720 119.1250
14711.424584 -42.503 87.0039
14712.157006 -42.596 105.5000
14712.889427 -43.024 96.5781
14713.621849 -40.854 77.7422
14714.354271 -44.466 85.2031
14715.086693 -42.422 78.6211
14715.819115 -42.804 58.5508
14716.551536 -43.117 33.7930
14717.283958 -42.026 52.1719
14718.016380 -44.282 27.8984
14718.748802 -44.793 45.7852
14719.481224 -45.045 29.9023
14720.213646 -46.496 10.4219
14720.946067 -45.395 20.7695
14721.678489 -50.427 6.2734
14722.410911 -49.245 34.7539
14723.143333 -47.761 -31.9648
14723.875755 -53.534 16.8008
14724.608176 -59.022 -45.3164
14725.340598 -54.815 -73.5000
14726.073020 -53.239 -116.6914
14726.805442 -47.955 -109.8086
14727.537864 -48.500 -96.7422
14728.270285 -60.145 -21.6562
14729.002707 -49.195 -140.4180
14729.735129 -49.033 -142.3516
14730.467551 -51.700 -144.4727
14731.199973 -56.038 -113.3438
14731.932395 -46.129 175.7227
14732.664816 -49.352 142.9492
14733.397238 -42.771 153.8086
14734.129660 -48.016 167.6211
14734.862082 -44.509 143.0820
14735.594504 -42.675 116.3594
14736.326925 -42.914 142.5703
14737.059347 -44.532 108.5742
14737.791769 -43.735 120.0078
14738.524191 -42.282 108.3203
14739.256613 -43.623 97.6992
14739.989035 -41.523 93.0781
14740.721456 -42.233 91.1211
14741.453878 -44.897 86.2500
14742.186300 -41.779 87.9688
14742.918722 -40.927 79.2891
14743.651144 -41.295 79.1914
14744.383565 -40.194 63.3477
14745.115987 -41.184 60.7148
14745.848409 -41.312 59.9883
14746.580831 -42.215 53.4336
14747.313253 -40.588 39.9219
14748.045675 -43.373 47.1406
14748.778096 -43.556 32.8242
14749.510518 -47.433 50.8008
14750.242940 -46.933 24.6992
14750.975362 -43.226 15.4336
14751.707784 -46.477 10.5117
14752.440205 -47.599 18.2461
14753.172627 -46.929 -7.6602
14753.905049 -48.424 -9.9648
14754.637471 -49.052 17.9336
14755.369893 -57.514 1.1445
14756.102314 -51.946 31.4336
14756.834736 -61.919 0.4414
14757.567158 -50.858 66.6445
14758.299580 -50.922 -28.3984
14759.032002 -48.236 37.8281
14759.764424 -45.197 35.8672
14760.496845 -47.803 54.5000
14761.229267 -46.872 53.1602
14761.961689 -47.037 62.4492
14762.694111 -46.815 16.0859
14763.426533 -51.465 67.0234
14764.158954 -49.758 29.6523
14764.891376 -52.004 39.9766
14765.623798 -49.936 43.2383
14766.356220 -48.548 15.4219
14767.088642 -43.589 26.6758
14767.821064 -51.930 7.0195
14768.553485 -46.176 36.0312
14769.285907 -41.772 22.2227
14770.018329 -45.168 -2.6289
14770.750751 -44.446 -0.7148
14771.483173 -46.220 -9.6289
14772.215594 -45.920 16.3516
14772.948016 -45.834 -14.3594
14773.680438 -43.583 -7.9062
14774.412860 -46.830 5.2617
14775.145282 -43.762 -5.5859
14775.877703 -46.388 -0.7070
14776.610125 -49.664 -27.5000
14777.342547 -49.348 -76.0977
14778.074969 -47.090 -28.5352
14778.807391 -47.799 -57.1328
14779.539813 -46.450 -45.4688
14780.272234 -47.125 -33.8555
14781.004656 -49.922 -49.3906
14781.737078 -52.667 -96.3945
14782.469500 -46.210 -55.6445
14783.201922 -53.899 -42.0703
14783.934343 -48.299 -84.5703
14784.666765 -63.823 -94.5820
14785.399187 -50.157 -60.1523
14786.131609 -55.011 -53.2695
14786.864031 -46.147 -68.0195
14787.596453 -52.722 -60.2305
14788.328874 -54.487 -118.7852
14789.061296 -60.371 13.1602
14789.793718 -47.832 -21.3438
14790.526140 -49.859 40.4258
14791.258562 -56.803 -28.0156
14791.990983 -53.843 -110.3984
14792.723405 -52.758 -19.3320
14793.455827 -49.903 17.8242
14794.188249 -46.107 -44.3555
14794.920671 -46.914 9.2852
14795.653093 -44.444 -13.6406
14796.385514 -47.523 -5.6523
14797.117936 -60.246 96.0508
14797.850358 -44.449 -31.3789
14798.582780 -50.674 -28.4609
14799.315202 -56.971 -4.7148
14800.047623 -48.728 -20.6992
14800.780045 -49.280 -43.9766
14801.512467 -57.576 -23.9453
14802.244889 -45.880 -43.1445
14802.977311 -45.387 -58.6758
14803.709732 -54.601 -119.2695
14804.442154 -45.648 -26.6719
14805.174576 -59.903 24.8398
14805.906998 -42.432 -63.3086
14806.639420 -43.633 -70.1445
14807.371842 -45.516 -76.7461
14808.104263 -44.577 -81.5273
14808.836685 -44.592 -88.6797
14809.569107 -46.794 -79.1289
14810.301529 -57.454 -72.6016
14811.033951 -46.031 -70.2695
14811.766372 -45.067 -89.2148
14812.498794 -46.425 -74.6602
14813.231216 -43.858 -75.4102
14813.963638 -44.131 -74.0352
14814.696060 -42.650 -88.1602
14815.428482 -44.568 -77.9570
14816.160903 -44.172 -94.1211
14816.893325 -45.099 -83.4297
14817.625747 -42.282 -98.0156
14818.358169 -45.402 -102.1016
14819.090591 -44.805 -87.3242
14819.823012 -44.985 -82.7969
14820.555434 -44.288 -83.1289
14821.287856 -41.107 -100.7969
14822.020278 -40.623 -109.8047
14822.752700 -43.100 -120.0352
14823.485121 -43.469 -106.7930
14824.217543 -43.157 -108.0859
14824.949965 -42.190 -116.6836
14825.682387 -44.299 -133.1797
14826.414809 -43.159 -124.5742
14827.147231 -40.330 -127.6953
14827.879652 -41.254 -150.2695
14828.612074 -43.265 -153.5898
14829.344496 -41.439 -162.3945
14830.076918 -44.472 -150.5312
14830.809340 -41.194 -169.6289
14831.541761 -43.847 -169.8672
14832.274183 -41.597 -179.0898
14833.006605 -39.494 171.2578
14833.739027 -39.367 -172.8047
14834.471449 -43.825 149.5625
14835.203871 -40.242 152.8984
14835.936292 -43.807 138.9297
14836.668714 -48.379 148.5977
14837.401136 -45.925 144.9922
14838.133558 -41.851 141.6328
14838.865980 -43.848 103.2969
14839.598401 -45.912 115.1719
14840.330823 -46.730 84.8398
14841.063245 -46.905 107.4805
14841.795667 -49.525 51.2109
14842.528089 -48.457 56.9258
14843.260511 -48.730 44.3594
14843.992932 -46.175 33.4570
14844.725354 -48.430 50.3164
14845.457776 -44.921 17.4531
14846.190198 -47.226 -6.3164
14846.922620 -44.702 -8.5273
14847.655041 -43.126 -6.6289
14848.387463 -46.039 -48.0586
14849.119885 -45.059 -32.8320
14849.852307 -42.798 -52.6992
14850.584729 -43.227 -59.9492
14851.317150 -41.347 -73.4219
14852.049572 -45.105 -62.1484
14852.781994 -43.293 -96.8438
14853.514416 -41.440 -101.7773
14854.246838 -40.292 -99.5000
14854.979260 -40.672 -108.3320
14855.711681 -43.046 -132.3789
14856.444103 -39.932 -151.4297
14857.176525 -43.559 -135.4805
14857.908947 -40.430 -130.5859
14858.641369 -43.745 -172.0586
14859.373790 -41.655 -165.0469
14860.106212 -41.847 -177.5508
14860.838634 -41.395 160.9062
14861.571056 -42.607 171.4609
14862.303478 -40.378 166.6836
14863.035900 -44.676 153.2773
14863.768321 -43.301 163.7891
14864.500743 -40.355 129.5078
14865.233165 -44.650 126.7266
14865.965587 -41.012 130.5703
14866.698009 -40.446 138.0938
14867.430430 -43.325 119.2539
14868.162852 -42.698 115.2852
14868.895274 -42.495 119.1133
14869.627696 -46.729 51.0195
14870.360118 -47.863 82.8594
14871.092539 -48.383 92.1406
14871.824961 -46.552 69.2852
14872.557383 -45.184 55.0938
14873.289805 -49.125 52.0547
14874.022227 -46.224 71.0117
14874.754649 -46.504 66.6875
14875.487070 -51.815 63.7539
14876.219492 -49.319 20.9570
14876.951914 -53.603 46.7461
14877.684336 -54.918 23.1328
14878.416758 -56.397 -32.3125
14879.149179 -48.496 157.6406
14879.881601 -46.681 85.8281
14880.614023 -49.444 94.3906
14881.346445 -53.752 148.0938
14882.078867 -48.529 78.4258
14882.811289 -60.352 161.0586
14883.543710 -51.328 153.2617
14884.276132 -45.512 150.9492
14885.008554 -49.920 127.6758
14885.740976 -49.149 82.9023
14886.473398 -55.862 136.6914
14887.205819 -58.139 -171.8867
14887.938241 -46.295 90.5195
14888.670663 -44.387 128.0703
14889.403085 -45.976 144.0742
14890.135507 -49.534 118.1367
14890.867929 -51.815 81.2656
14891.600350 -44.297 103.8594
14892.332772 -50.347 84.7148
14893.065194 -52.693 82.5625
14893.797616 -45.610 69.9180
14894.530038 -45.706 44.6758
14895.262459 -57.870 62.4375
14895.994881 -51.708 99.8320
14896.727303 -40.966 75.0195
14897.459725 -53.664 68.0430
14898.192147 -47.542 24.3789
14898.924568 -53.650 53.0938
14899.656990 -45.889 9.7109
14900.389412 -49.890 84.9727
14901.121834 -53.175 53.8242
14901.854256 -54.007 -76.1445
14902.586678 -44.519 10.6797
14903.319099 -46.910 31.6602
14904.051521 -45.201 -17.4609
14904.783943 -44.298 -23.7695
14905.516365 -46.218 -23.6211
14906.248787 -45.523 -21.9258
14906.981208 -45.562 -56.7227
14907.713630 -49.573 -31.8203
14908.446052 -48.105 -7.3477
14909.178474 -43.101 -52.3789
14909.910896 -46.160 -42.9805
14910.643318 -41.614 -99.8789
14911.375739 -48.603 -56.0625
14912.108161 -45.804 -125.5312
14912.840583 -46.398 -172.3203
14913.573005 -47.468 -125.6172
14914.305427 -43.627 -113.1562
14915.037848 -48.639 -164.6211
14915.770270 -45.247 -173.6797
14916.502692 -40.488 -160.3789
14917.235114 -44.562 151.5703
14917.967536 -42.013 179.6797
14918.699957 -41.253 175.6914
14919.432379 -44.667 -174.8750
14920.164801 -43.540 159.5352
14920.897223 -44.444 146.9180
14921.629645 -45.025 -161.8555
14922.362067 -41.691 143.9570
14923.094488 -42.208 122.0977
14923.826910 -43.924 145.3984
14924.559332 -40.362 140.6445
14925.291754 -40.495 100.7344
14926.024176 -41.125 86.8789
14926.756597 -41.174 42.4609
14927.489019 -39.397 80.0820
14928.221441 -40.337 66.0352
14928.953863 -40.376 64.5234
14929.686285 -44.659 81.9609
14930.418707 -40.231 48.1328
14931.151128 -44.921 77.0352
14931.883550 -36.587 57.4844
14932.615972 -39.257 41.2031
14933.348394 -41.052 33.9688
14934.080816 -43.598 27.3984
14934.813237 -39.560 42.9023
14935.545659 -43.663 51.3711
14936.278081 -46.215 26.3789
14937.010503 -44.177 79.6367
14937.742925 -40.119 43.8750
14938.475347 -45.408 21.9766
14939.207768 -48.470 78.8789
14939.940190 -48.688 25.0273
14940.672612 -40.124 -65.1172
14941.405034 -46.668 -24.4727
14942.137456 -51.255 83.0508
14942.869877 -46.410 38.6445
14943.602299 -46.462 73.3125
14944.334721 -40.099 -6.0938
14945.067143 -54.381 155.8867
14945.799565 -39.770 96.3750
14946.531986 -46.019 157.2891
14947.264408 -39.105 -36.3125
14947.996830 -36.897 14.5898
14948.729252 -49.010 54.7148
14949.461674 -42.983 37.1094
14950.194096 -41.545 10.5625
14950.926517 -46.486 19.7266
14951.658939 -40.261 0.1523
14952.391361 -38.877 1.0039
14953.123783 -39.883 33.1250
14953.856205 -46.561 160.7852
14954.588626 -39.022 -60.7305
14955.321048 -44.877 -41.7031
14956.053470 -51.412 -153.4648
14956.785892 -42.822 15.6016
14957.518314 -43.340 -85.7969
14958.250736 -40.930 -36.9727
14958.983157 -43.765 -75.1602
14959.715579 -36.338 -0.3555
14960.448001 -44.822 -139.7734
14961.180423 -43.459 -140.7773
14961.912845 -47.526 -63.6094
14962.645266 -42.351 -131.2031
14963.377688 -40.731 -95.1055
14964.110110 -41.761 -94.6992
14964.842532 -45.483 52.1875
14965.574954 -45.681 -158.3516
14966.307375 -42.282 -114.3047
14967.039797 -43.793 -113.5430
14967.772219 -40.879 142.3281
14968.504641 -39.564 -95.2734
14969.237063 -41.704 -179.1367
14969.969485 -48.686 -56.4766
14970.701906 -45.060 -130.3203
14971.434328 -48.090 3.0039
14972.166750 -40.555 153.4297
14972.899172 -42.293 177.6133
14973.631594 -42.186 -18.2148
14974.364015 -52.062 1.6758
14975.096437 -41.844 -100.8594
14975.828859 -36.712 -96.9336
14976.561281 -43.788 -88.3672
14977.293703 -41.152 99.6055
14978.026125 -41.964 -54.0430
14978.758546 -42.806 -100.1484
14979.490968 -43.119 -29.9141
14980.223390 -40.632 -80.3711
14980.955812 -40.290 -99.8750
14981.688234 -40.449 -101.7656
14982.420655 -42.765 -80.1172
14983.153077 -37.296 -141.6797
14983.885499 -42.113 -147.7852
14984.617921 -47.056 -98.2383
14985.350343 -37.634 162.7031
14986.082765 -58.570 36.7695
14986.815186 -45.925 165.6250
14987.547608 -37.094 -172.1172
14988.280030 -33.579 157.3242
14989.012452 -39.396 -168.2461
14989.744874 -38.274 158.6914
14990.477295 -39.378 163.6562
14991.209717 -45.767 -175.4062
14991.942139 -36.500 -156.9023
14992.674561 -31.496 126.7227
14993.406983 -38.908 169.1719
14994.139404 -41.183 142.7734
14994.871826 -37.990 66.9180
14995.604248 -44.406 49.5820
14996.336670 -34.268 108.6484
14997.069092 -38.286 77.9688
14997.801514 -37.812 117.9844
14998.533935 -39.845 32.4297
14999.266357 -44.047 47.1562
14999.998779 -42.987 -18.7969
15000.731201 -35.307 -19.1680
15001.463623 -41.122 -41.0781
15002.196044 -37.792 -3.5547
15002.928466 -36.328 -3.8164
15003.660888 -43.366 4.6914
15004.393310 -34.803 -23.1641
15005.125732 -37.752 -20.4219
15005.858154 -39.979 -66.6133
15006.590575 -34.504 -47.6211
15007.322997 -37.197 -40.9336
15008.055419 -37.548 -50.6992
15008.787841 -34.017 -54.1055
15009.520263 -36.939 -80.0703
15010.252684 -38.560 -98.7383
15010.985106 -38.954 -86.4414
15011.717528 -36.150 -97.8828
15012.449950 -36.256 -125.1992
15013.182372 -35.221 -124.9297
15013.914793 -35.517 -132.5742
15014.647215 -39.966 -178.2617
15015.379637 -42.801 -156.6758
15016.112059 -38.258 -176.5195
15016.844481 -36.989 -155.0859
15017.576903 -39.330 168.0195
15018.309324 -38.021 -176.3164
15019.041746 -36.835 168.4141
15019.774168 -36.409 176.3516
15020.506590 -39.510 139.2383
15021.239012 -41.779 152.0273
15021.971433 -41.250 137.5625
15022.703855 -48.839 111.4727
15023.436277 -39.964 89.8047
15024.168699 -38.395 128.9805
15024.901121 -37.936 56.1914
15025.633543 -46.560 13.7891
15026.365964 -44.700 39.8125
15027.098386 -39.134 22.0039
15027.830808 -40.308 38.2422
15028.563230 -39.236 65.2969
15029.295652 -37.733 42.3125
15030.028073 -37.404 20.7578
15030.760495 -38.452 13.2617
15031.492917 -40.875 37.1602
15032.225339 -40.000 7.0078
15032.957761 -40.401 7.7617
15033.690183 -43.498 2.9453
15034.422604 -41.471 13.3164
15035.155026 -38.999 -55.2656
15035.887448 -36.449 6.7109
15036.619870 -45.914 -5.6562
15037.352292 -49.483 43.9883
15038.084713 -44.165 -49.7734
15038.817135 -42.848 -17.0664
15039.549557 -41.741 -78.4062
15040.281979 -47.110 -43.0586
15041.014401 -54.453 -173.0664
15041.746822 -44.552 -144.0625
15042.479244 -41.365 -71.0156
15043.211666 -46.021 0.2852
15043.944088 -41.863 -90.6172
15044.676510 -50.481 -23.3711
15045.408932 -42.038 67.1172
15046.141353 -40.963 -92.7148
15046.873775 -46.453 -71.5898
15047.606197 -38.780 -134.4023
15048.338619 -44.837 156.0312
15049.071041 -47.988 -128.1641
15049.803462 -37.646 -103.8750
15050.535884 -52.162 -118.8359
15051.268306 -43.590 -71.6836
15052.000728 -53.830 173.1719
15052.733150 -47.415 -27.6172
15053.465572 -51.334 36.4023
15054.197993 -42.267 -104.4141
15054.930415 -50.571 -37.3750
15055.662837 -51.154 52.1836
15056.395259 -49.577 -41.3906
15057.127681 -43.119 -66.7617
15057.860102 -49.159 -29.6367
15058.592524 -43.212 144.1914
15059.324946 -55.735 -148.2773
15060.057368 -48.745 51.2031
15060.789790 -44.657 -123.1602
15061.522211 -59.713 83.6953
15062.254633 -49.826 68.1367
15062.987055 -48.073 -73.1172
15063.719477 -50.017 -41.9492
15064.451899 -52.658 -50.0156
15065.184321 -46.967 -149.2578
15065.916742 -53.523 127.4492
15066.649164 -53.712 62.4219
15067.381586 -52.445 -78.9844
15068.114008 -50.066 100.3906
15068.846430 -44.268 -173.7109
15069.578851 -46.749 -137.4570
15070.311273 -44.156 -149.2891
15071.043695 -43.303 147.5898
15071.776117 -44.698 135.9688
15072.508539 -46.794 -171.4102
15073.240961 -45.570 148.4297
15073.973382 -40.097 160.6953
15074.705804 -43.956 158.4609
15075.438226 -48.726 150.1055
15076.170648 -48.717 122.8047
15076.903070 -45.192 125.8789
15077.635491 -49.759 112.6094
15078.367913 -53.213 160.5938
15079.100335 -48.460 146.3242
15079.832757 -49.479 114.9375
15080.565179 -48.635 79.9180
15081.297601 -47.486 95.8750
15082.030022 -41.066 50.5898
15082.762444 -47.174 100.2852
15083.494866 -48.709 58.2891
15084.227288 -54.421 94.5078
15084.959710 -50.332 89.7734
15085.692131 -44.227 19.6172
15086.424553 -44.836 13.3828
15087.156975 -43.730 33.2500
15087.889397 -48.885 45.1133
15088.621819 -44.123 61.9844
15089.354240 -44.058 21.5625
15090.086662 -48.847 56.0977
15090.819084 -46.705 -5.1719
15091.551506 -45.251 8.8008
15092.283928 -47.901 36.4883
15093.016350 -45.889 -7.9023
15093.748771 -51.247 -2.1367
15094.481193 -52.402 4.5742
15095.213615 -45.838 12.4375
15095.946037 -47.245 -29.5391
15096.678459 -59.310 -159.6758
15097.410880 -44.942 8.7812
15098.143302 -52.182 -47.1914
15098.875724 -58.970 134.2773
15099.608146 -62.050 -24.8359
15100.340568 -55.356 -22.5625
15101.072990 -45.176 2.5273
15101.805411 -59.031 -91.7109
15102.537833 -50.921 -47.0312
15103.270255 -47.666 -20.6484
15104.002677 -49.961 -78.6797
15104.735099 -54.465 -86.2031
15105.467520 -47.553 -79.9102
15106.199942 -50.440 -51.4453
15106.932364 -44.571 -30.8555
15107.664786 -48.309 -64.1562
15108.397208 -50.207 -91.7109
15109.129629 -57.719 -35.1992
15109.862051 -48.332 -87.2461
15110.594473 -52.218 -61.9453
15111.326895 -53.466 -68.2422
15112.059317 -55.138 -24.5352
15112.791739 -50.921 -83.7148
15113.524160 -72.128 -13.7734
15114.256582 -45.630 -130.5938
15114.989004 -66.660 -153.5742
15115.721426 -52.023 173.3164
15116.453848 -54.619 -142.1797
15117.186269 -48.706 147.4141
15117.918691 -50.206 111.9180
15118.651113 -73.803 -7.9258
15119.383535 -56.020 102.3359
15120.115957 -54.360 123.7500
15120.848379 -42.834 94.3750
15121.580800 -50.996 92.7695
15122.313222 -49.340 67.5781
15123.045644 -46.566 42.4023
15123.778066 -48.836 46.1172
15124.510488 -48.137 15.2188
15125.242909 -49.702 48.1719
15125.975331 -51.041 43.4609
15126.707753 -45.106 -10.4336
15127.440175 -45.521 -4.5508
15128.172597 -47.816 -5.4258
15128.905019 -44.001 21.1367
15129.637440 -41.381 -2.2305
15130.369862 -41.050 -9.4453
15131.102284 -45.116 -16.9570
15131.834706 -43.116 -14.0469
15132.567128 -42.343 -45.9102
15133.299549 -44.679 -50.2266
15134.031971 -44.434 -31.6211
15134.764393 -40.641 -63.9492
15135.496815 -41.675 -64.3477
15136.229237 -41.857 -84.2695
15136.961658 -48.251 -58.4141
15137.694080 -45.431 -106.6758
15138.426502 -44.120 -91.2031
15139.158924 -44.254 -119.7500
15139.891346 -43.069 -134.1641
15140.623768 -46.376 -150.5820
15141.356189 -46.750 164.0664
15142.088611 -48.320 -153.3867
15142.821033 -50.801 -173.3398
15143.553455 -51.158 130.6602
15144.285877 -50.351 143.1133
15145.018298 -40.991 125.3867
15145.750720 -45.919 114.3086
15146.483142 -47.290 127.0898
15147.215564 -41.737 102.8125
15147.947986 -46.553 111.3164
15148.680408 -41.099 81.4648
15149.412829 -41.446 64.1133
15150.145251 -41.671 69.9336
15150.877673 -40.863 65.6211
15151.610095 -39.905 63.2578
15152.342517 -39.349 54.0781
15153.074938 -40.603 55.9258
15153.807360 -45.233 2.1211
15154.539782 -36.793 42.6094
15155.272204 -37.439 18.3711
15156.004626 -37.915 19.9883
15156.737047 -39.586 11.9141
15157.469469 -38.600 -10.7969
15158.201891 -38.590 -16.5781
15158.934313 -36.231 -18.2578
15159.666735 -37.970 -28.5781
15160.399157 -36.046 -30.7656
15161.131578 -37.986 -28.0195
15161.864000 -39.048 -49.6719
15162.596422 -37.772 -33.6484
15163.328844 -35.782 -50.4180
15164.061266 -36.887 -62.2500
15164.793687 -37.665 -65.5625
15165.526109 -36.521 -85.1328
15166.258531 -38.708 -80.4648
15166.990953 -37.661 -83.3008
15167.723375 -37.189 -80.0898
15168.455797 -38.078 -92.1562
15169.188218 -38.651 -99.6055
15169.920640 -37.221 -109.0508
15170.653062 -39.768 -133.5898
15171.385484 -37.733 -133.2070
15172.117906 -40.958 -126.5625
15172.850327 -43.965 -118.0820
15173.582749 -39.818 -139.1914
15174.315171 -43.326 -162.4336
15175.047593 -43.144 -150.6133
15175.780015 -48.409 -133.1289
15176.512437 -44.206 -158.5234
15177.244858 -42.812 -153.2852
15177.977280 -47.126 -170.3398
15178.709702 -50.281 -56.3398
15179.442124 -55.743 146.5781
15180.174546 -59.501 65.3398
15180.906967 -48.453 -150.7578
15181.639389 -48.953 152.1641
15182.371811 -47.644 -176.4883
15183.104233 -50.256 171.2695
15183.836655 -52.656 -53.7734
15184.569076 -51.199 -130.0195
15185.301498 -47.459 166.2109
15186.033920 -57.847 -33.1758
15186.766342 -54.970 -51.7109
15187.498764 -50.831 -96.8438
15188.231186 -50.898 -104.4648
15188.963607 -50.185 -126.1914
15189.696029 -52.647 -114.2695
15190.428451 -45.191 -110.7109
15191.160873 -48.388 -132.0234
15191.893295 -62.028 -53.7539
15192.625716 -47.792 -131.9531
15193.358138 -53.739 -145.1211
15194.090560 -47.823 179.3789
15194.822982 -46.943 -171.4102
15195.555404 -48.462 -169.6289
15196.287826 -50.608 -169.3672
15197.020247 -48.582 173.3672
15197.752669 -52.877 96.1562
15198.485091 -51.712 -160.2969
15199.217513 -63.752 15.6953
15199.949935 -62.291 -158.6836
15200.682356 -46.189 145.8086
15201.414778 -69.314 59.5664
15202.147200 -51.521 -95.9102
15202.879622 -53.035 -109.7695
15203.612044 -53.206 98.7422
15204.344465 -54.891 166.7695
15205.076887 -54.722 83.3750
15205.809309 -64.447 100.6719
15206.541731 -51.295 103.3789
15207.274153 -54.250 -91.9375
15208.006575 -61.660 102.8555
15208.738996 -67.484 -164.7461
15209.471418 -48.758 -20.2422
15210.203840 -70.663 72.0508
15210.936262 -53.248 -133.2383
15211.668684 -55.698 57.0859
15212.401105 -50.543 129.2070
15213.133527 -53.903 131.3477
15213.865949 -57.047 -75.1094
15214.598371 -57.792 -134.6172
15215.330793 -60.477 -22.7188
15216.063215 -50.635 -120.2148
15216.795636 -47.806 -145.1797
15217.528058 -63.421 -122.0664
15218.260480 -49.217 130.0000
15218.992902 -49.819 89.7422
15219.725324 -54.198 -134.7617
15220.457745 -64.798 -120.7539
15221.190167 -55.629 24.3242
15221.922589 -56.864 -167.4648
15222.655011 -52.256 -133.3828
15223.387433 -64.515 -139.9766
15224.119855 -47.267 141.6289
15224.852276 -43.065 168.7383
15225.584698 -45.411 -155.4492
15226.317120 -47.243 -146.7578
15227.049542 -47.705 -154.8320
15227.781964 -49.919 -163.7148
15228.514385 -53.885 161.5742
15229.246807 -57.051 107.2578
15229.979229 -46.993 126.5938
15230.711651 -46.266 175.3789
15231.444073 -45.363 113.9258
15232.176494 -48.579 109.7344
15232.908916 -47.225 177.5625
15233.641338 -45.460 128.6836
15234.373760 -46.833 139.8008
15235.106182 -45.262 129.1445
15235.838604 -45.358 83.8320
15236.571025 -44.624 135.6797
15237.303447 -41.441 121.0078
15238.035869 -42.507 99.8281
15238.768291 -48.612 48.2539
15239.500713 -45.317 67.8398
15240.233134 -46.336 72.6250
15240.965556 -45.845 93.5703
15241.697978 -40.481 62.0469
15242.430400 -43.504 73.3359
15243.162822 -40.489 54.2617
15243.895244 -48.830 69.4375
15244.627665 -47.745 35.3828
15245.360087 -43.515 53.1328
15246.092509 -44.478 58.0547
15246.824931 -46.053 13.8047
15247.557353 -40.296 40.9219
15248.289774 -44.193 14.8750
15249.022196 -45.004 29.5547
15249.754618 -44.281 16.7031
15250.487040 -41.578 0.7422
15251.219462 -44.985 22.1914
15251.951883 -47.076 -11.6875
15252.684305 -43.150 -1.2812
15253.416727 -42.814 -11.6367
15254.149149 -49.234 -0.8633
15254.881571 -42.333 -8.6523
15255.613993 -43.744 1.1758
15256.346414 -44.818 -45.3008
15257.078836 -51.623 -2.8945
15257.811258 -49.887 -55.8477
15258.543680 -44.424 -59.5508
15259.276102 -48.732 -15.0195
15260.008523 -48.898 -51.9102
15260.740945 -48.059 -59.8672
15261.473367 -46.563 -104.1758
15262.205789 -45.975 -88.0977
15262.938211 -50.709 -116.3047
15263.670633 -53.558 -79.0898
15264.403054 -45.658 -106.5508
15265.135476 -49.785 -78.5156
15265.867898 -47.537 -79.9141
15266.600320 -47.773 -141.1680
15267.332742 -46.559 -119.7773
15268.065163 -47.725 -132.6562
15268.797585 -51.727 -175.8867
15269.530007 -46.700 -164.4648
15270.262429 -49.628 -147.8477
15270.994851 -47.771 155.1133
15271.727273 -49.565 142.3906
15272.459694 -44.736 149.8320
15273.192116 -46.759 164.1914
15273.924538 -48.639 154.5547
15274.656960 -47.577 111.9922
15275.389382 -49.132 158.0859
15276.121803 -51.327 120.0820
15276.854225 -50.232 61.2344
15277.586647 -47.197 100.2148
15278.319069 -46.211 43.6992
15279.051491 -51.327 55.9219
15279.783912 -47.353 90.6523
15280.516334 -43.664 33.6875
15281.248756 -44.398 52.9570
15281.981178 -48.977 45.3359
15282.713600 -43.924 21.6406
15283.446022 -44.304 22.2227
15284.178443 -44.074 16.0117
15284.910865 -43.375 -2.0195
15285.643287 -45.705 1.3750
15286.375709 -43.464 -26.1602
15287.108131 -42.470 -30.3203
15287.840552 -42.607 -29.5000
15288.572974 -41.855 -38.9688
15289.305396 -41.749 -45.1094
15290.037818 -42.620 -48.4688
15290.770240 -42.139 -71.1016
15291.502662 -44.870 -69.9219
15292.235083 -41.812 -58.4727
15292.967505 -43.574 -81.9648
15293.699927 -42.605 -95.9961
15294.432349 -41.557 -77.0898
15295.164771 -41.194 -107.5977
15295.897192 -43.688 -110.3867
15296.629614 -48.497 -98.3438
15297.362036 -46.193 -133.3867
15298.094458 -45.813 -97.4062
15298.826880 -46.386 -123.8711
15299.559301 -46.506 -150.8242
15300.291723 -47.492 -120.5078
15301.024145 -47.185 -152.3242
15301.756567 -46.895 -158.4844
15302.488989 -48.902 -122.4453
15303.221411 -46.833 162.3125
15303.953832 -47.877 -104.7734
15304.686254 -52.030 172.5000
15305.418676 -43.664 -177.3789
15306.151098 -56.241 -21.2461
15306.883520 -50.513 -143.9648
15307.615941 -49.575 -140.0000
15308.348363 -51.574 -163.7578
15309.080785 -68.827 -5.9297
15309.813207 -55.992 172.5430
15310.545629 -49.329 -131.0469
15311.278051 -45.202 171.2656
15312.010472 -42.713 -78.4922
15312.742894 -45.489 -119.3828
15313.475316 -47.234 -154.2734
15314.207738 -45.868 -115.7109
15314.940160 -45.474 -143.9492
15315.672581 -47.487 -143.5664
15316.405003 -51.230 -138.5781
15317.137425 -44.344 176.6016
15317.869847 -45.521 -126.3008
15318.602269 -44.491 -157.1680
15319.334691 -45.092 161.2344
15320.067112 -39.647 154.5469
15320.799534 -43.872 167.7148
15321.531956 -42.780 148.4844
15322.264378 -44.680 155.0312
15322.996800 -38.530 151.2969
15323.729221 -41.948 160.8164
15324.461643 -40.050 128.4062
15325.194065 -49.558 162.2188
15325.926487 -40.735 115.1289
15326.658909 -43.324 86.3047
15327.391330 -44.162 101.1055
15328.123752 -42.379 81.2305
15328.856174 -41.375 90.8906
15329.588596 -45.961 70.7969
15330.321018 -47.316 85.1172
15331.053440 -42.546 59.6484
15331.785861 -42.881 81.9922
15332.518283 -49.653 73.9453
15333.250705 -52.630 26.5586
15333.983127 -44.321 29.7852
15334.715549 -47.340 -23.1523
15335.447970 -49.196 -140.5039
15336.180392 -56.900 -56.3047
15336.912814 -47.357 -63.3906
15337.645236 -54.218 -133.7930
15338.377658 -47.159 -77.0078
15339.110080 -47.091 -146.4453
15339.842501 -45.189 -170.1680
15340.574923 -44.335 160.6602
15341.307345 -42.192 -148.6992
15342.039767 -47.273 -178.7266
15342.772189 -43.654 174.3281
15343.504610 -47.437 122.4023
15344.237032 -45.666 172.8867
15344.969454 -39.030 158.7695
15345.701876 -44.612 136.6133
15346.434298 -42.822 136.1133
15347.166719 -40.415 140.4805
15347.899141 -44.618 108.2773
15348.631563 -41.619 119.5156
15349.363985 -39.149 120.5000
15350.096407 -44.001 91.3633
15350.828829 -40.842 97.4141
15351.561250 -45.834 84.7930
15352.293672 -37.151 61.3477
15353.026094 -42.877 58.4297
15353.758516 -39.566 63.4492
15354.490938 -41.784 61.2266
15355.223359 -41.307 50.4258
15355.955781 -43.183 46.8828
15356.688203 -47.330 76.9961
15357.420625 -45.332 47.7930
15358.153047 -42.068 50.0664
15358.885469 -46.141 70.9961
15359.617890 -45.571 86.5430
15360.350312 -45.172 33.1992
15361.082734 -40.612 66.6250
15361.815156 -44.985 -10.6367
15362.547578 -52.041 65.4453
15363.279999 -44.263 43.8516
15364.012421 -42.296 35.6797
15364.744843 -51.524 -32.7109
15365.477265 -42.723 61.0898
15366.209687 -42.952 27.9336
15366.942109 -41.814 53.5234
15367.674530 -44.124 43.9102
15368.406952 -39.855 48.9922
15369.139374 -42.301 49.7578
15369.871796 -39.866 -5.6133
15370.604218 -42.158 29.3516
15371.336639 -42.042 39.7969
15372.069061 -42.005 20.6406
15372.801483 -37.415 12.1406
15373.533905 -39.947 1.0000
15374.266327 -39.658 6.2695
15374.998748 -38.910 -2.3008
15375.731170 -37.174 -2.1797
15376.463592 -41.095 -10.9492
15377.196014 -37.697 -5.5195
15377.928436 -38.261 -35.7109
15378.660858 -38.355 -24.1016
15379.393279 -37.820 -41.9336
15380.125701 -37.234 -46.5117
15380.858123 -38.333 -42.1758
15381.590545 -38.194 -46.0508
15382.322967 -42.707 -43.2344
15383.055388 -41.034 -72.1680
15383.787810 -40.928 -84.0820
15384.520232 -40.242 -52.0703
15385.252654 -38.685 -99.4258
15385.985076 -44.889 -83.9883
15386.717498 -42.535 -94.7617
15387.449919 -42.890 -77.9141
15388.182341 -43.358 -103.6484
15388.914763 -45.414 -75.2266
15389.647185 -49.125 -71.0664
15390.379607 -51.780 -93.8750
15391.112028 -49.206 -140.4531
15391.844450 -50.198 -131.4062
15392.576872 -48.075 -109.5312
15393.309294 -47.296 -131.3945
15394.041716 -50.382 -132.3867
15394.774137 -53.278 -101.3242
15395.506559 -48.977 -145.7148
15396.238981 -45.322 -32.7461
15396.971403 -50.586 -168.0195
15397.703825 -50.298 -72.2383
15398.436247 -50.664 -149.0430
15399.168668 -50.599 -33.1953
15399.901090 -54.731 150.5898
15400.633512 -50.810 -106.5195
15401.365934 -58.206 -26.7617
15402.098356 -50.166 -51.1406
15402.830777 -47.231 -158.1602
15403.563199 -50.113 -142.7891
15404.295621 -52.187 -113.2969
15405.028043 -47.171 -131.1328
15405.760465 -42.678 149.2930
15406.492887 -54.401 -179.7148
15407.225308 -45.888 163.7617
15407.957730 -51.686 -119.8984
15408.690152 -48.447 106.9648
15409.422574 -49.983 154.7578
15410.154996 -53.286 123.4023
15410.887417 -57.203 -109.4297
15411.619839 -46.619 126.3242
15412.352261 -51.084 80.4062
15413.084683 -54.087 112.5078
15413.817105 -56.251 20.5352
15414.549527 -50.837 66.4414
15415.281948 -46.171 36.6758
15416.014370 -50.361 18.8398
15416.746792 -45.830 -40.5664
15417.479214 -50.515 44.8516
15418.211636 -46.312 0.4141
15418.944057 -49.578 59.1094
15419.676479 -45.548 -34.0977
15420.408901 -51.634 107.3789
15421.141323 -48.799 -0.0625
15421.873745 -49.558 -82.0703
15422.606166 -42.725 -64.6328
15423.338588 -62.410 -18.7422
15424.071010 -50.933 -104.4180
15424.803432 -62.159 171.4844
15425.535854 -44.658 -88.6719
15426.268276 -54.699 66.8750
15427.000697 -59.553 -151.6289
15427.733119 -54.167 140.4922
15428.465541 -50.559 -171.5664
15429.197963 -51.554 150.1016
15429.930385 -49.971 -166.8672
15430.662806 -50.428 151.7344
15431.395228 -48.308 -143.9609
15432.127650 -43.478 113.2891
15432.860072 -48.837 127.3242
15433.592494 -46.791 115.1328
15434.324916 -56.527 170.1250
15435.057337 -47.515 152.3281
15435.789759 -48.139 148.0664
15436.522181 -47.055 121.9141
15437.254603 -55.562 25.3516
15437.987025 -43.638 101.6289
15438.719446 -49.976 55.7031
15439.451868 -50.308 65.2305
15440.184290 -54.860 95.1055
15440.916712 -45.868 69.7422
15441.649134 -44.482 71.1094
15442.381555 -43.823 58.6094
15443.113977 -56.073 26.4023
15443.846399 -42.725 67.3477
15444.578821 -45.394 31.7109
15445.311243 -44.570 53.3008
15446.043665 -47.066 24.6133
15446.776086 -41.447 37.8359
15447.508508 -45.444 34.8203
15448.240930 -46.276 32.6367
15448.973352 -51.033 -36.3906
15449.705774 -42.532 31.8125
15450.438195 -45.634 26.5820
15451.170617 -41.248 19.2422
15451.903039 -46.960 -22.5547
15452.635461 -43.146 1.1016
15453.367883 -39.926 2.6445
15454.100305 -41.462 1.7461
15454.832726 -41.914 -58.2695
15455.565148 -43.714 -14.1953
15456.297570 -44.961 -26.7812
15457.029992 -46.743 -68.9297
15457.762414 -44.608 -64.8789
15458.494835 -47.032 -47.0234
15459.227257 -43.321 -63.2188
15459.959679 -49.518 -76.5312
15460.692101 -41.503 -107.8555
15461.424523 -47.690 -75.3945
15462.156945 -44.568 -93.5391
15462.889366 -48.596 -68.7266
15463.621788 -46.756 -147.3516
15464.354210 -49.018 -139.2031
15465.086632 -52.128 -94.4688
15465.819054 -46.311 -151.4453
15466.551475 -43.218 -155.7109
15467.283897 -53.733 131.3906
15468.016319 -48.034 -176.7695
15468.748741 -52.384 152.8750
15469.481163 -48.254 -178.5312
15470.213584 -53.447 111.8281
15470.946006 -52.045 98.9023
15471.678428 -47.710 83.3789
15472.410850 -49.152 157.3203
15473.143272 -46.176 55.2656
15473.875694 -46.435 65.3164
15474.608115 -41.941 24.3672
15475.340537 -47.499 50.8398
15476.072959 -45.914 22.1016
15476.805381 -42.423 32.6094
15477.537803 -42.756 22.9531
15478.270224 -48.048 5.1914
15479.002646 -40.771 15.6836
15479.735068 -42.840 8.0078
15480.467490 -42.212 2.3945
15481.199912 -43.806 -26.2227
15481.932334 -40.676 -5.2383
15482.664755 -40.805 -27.2461
15483.397177 -40.407 -29.6562
15484.129599 -42.439 -65.8789
15484.862021 -39.150 -47.7344
15485.594443 -40.767 -58.8672
15486.326864 -40.337 -52.8750
15487.059286 -43.175 -75.8828
15487.791708 -41.268 -65.8359
15488.524130 -43.455 -72.5430
15489.256552 -44.242 -86.4336
15489.988973 -40.017 -118.9219
15490.721395 -43.329 -91.2695
15491.453817 -42.615 -108.8281
15492.186239 -45.483 -110.5703
15492.918661 -42.218 -135.6211
15493.651083 -46.404 -129.8164
15494.383504 -43.909 -126.5430
15495.115926 -45.309 -130.6211
15495.848348 -42.026 173.5312
15496.580770 -49.227 -132.8203
15497.313192 -49.035 -179.2422
15498.045613 -51.958 -165.2227
15498.778035 -46.668 -177.3398
15499.510457 -58.200 -171.8867
15500.242879 -49.091 -155.8906
15500.975301 -55.060 120.7344
15501.707723 -45.858 110.1914
15502.440144 -67.083 39.5469
15503.172566 -60.822 119.0703
15503.904988 -48.330 51.0586
15504.637410 -47.206 109.3750
15505.369832 -50.997 31.1328
15506.102253 -58.730 34.7656
15506.834675 -46.530 -16.8945
15507.567097 -47.727 56.8008
15508.299519 -50.892 -25.2383
15509.031941 -50.803 -31.4219
15509.764363 -42.281 -36.4492
15510.496784 -48.784 -1.8828
15511.229206 -45.791 -38.7070
15511.961628 -49.082 -47.9609
15512.694050 -47.938 -81.6602
15513.426472 -53.289 -63.5352
15514.158893 -43.540 -75.0078
15514.891315 -42.865 -97.7812
15515.623737 -43.292 -106.8438
15516.356159 -44.992 -131.7305
15517.088581 -40.723 -98.4414
15517.821002 -43.270 -128.1289
15518.553424 -42.636 -115.8320
15519.285846 -45.085 -168.8242
15520.018268 -42.639 -132.8750
15520.750690 -43.039 -132.0430
15521.483112 -43.836 -109.4492
15522.215533 -44.098 -148.5938
15522.947955 -47.629 -146.3125
15523.680377 -45.718 -151.2344
15524.412799 -45.509 171.5078
15525.145221 -47.441 -176.3672
15525.877642 -41.703 -142.5273
15526.610064 -44.715 -175.7344
15527.342486 -52.153 -175.4258
15528.074908 -44.593 165.1523
15528.807330 -47.351 -138.9727
15529.539752 -45.660 -149.2617
15530.272173 -43.062 -161.4414
15531.004595 -44.959 141.1719
15531.737017 -45.162 -174.0195
15532.469439 -41.548 160.7617
15533.201861 -48.137 156.2031
15533.934282 -47.028 167.3164
15534.666704 -44.189 166.8984
15535.399126 -42.454 174.8281
15536.131548 -42.424 165.4180
15536.863970 -44.662 142.4688
15537.596391 -44.301 153.4766
15538.328813 -43.009 160.2109
15539.061235 -42.849 153.6172
15539.793657 -42.408 128.1367
15540.526079 -43.115 138.9492
15541.258501 -42.684 130.3906
15541.990922 -43.079 126.3711
15542.723344 -39.003 95.0547
15543.455766 -40.564 106.8203
15544.188188 -40.562 106.4766
15544.920610 -42.689 122.6289
15545.653031 -44.454 84.1797
15546.385453 -42.714 84.7734
15547.117875 -43.345 82.9023
15547.850297 -40.523 67.5312
15548.582719 -39.657 48.4727
15549.315141 -43.367 50.1367
15550.047562 -43.578 69.1914
15550.779984 -40.906 50.8125
15551.512406 -39.763 24.0117
15552.244828 -42.986 1.7344
15552.977250 -42.496 36.5859
15553.709671 -44.928 -0.6406
15554.442093 -41.056 1.4961
15555.174515 -47.742 -4.3789
15555.906937 -45.492 1.6328
15556.639359 -49.432 -34.7109
15557.371781 -40.913 -38.6914
15558.104202 -43.286 -32.8008
15558.836624 -46.923 -28.8633
15559.569046 -47.561 -17.8359
15560.301468 -44.974 -10.8359
15561.033890 -45.700 -83.7773
15561.766311 -45.353 -98.0234
15562.498733 -45.379 -94.8242
15563.231155 -43.977 -91.7656
15563.963577 -45.408 -129.8438
15564.695999 -47.025 -133.2070
15565.428420 -44.447 -136.3750
15566.160842 -44.908 -97.0000
15566.893264 -45.566 -152.9609
15567.625686 -45.684 -164.1758
15568.358108 -45.104 -153.5547
15569.090530 -44.765 -163.1289
15569.822951 -43.742 176.6484
15570.555373 -45.958 -173.8867
15571.287795 -46.189 175.9492
15572.020217 -47.997 166.6680
15572.752639 -44.868 176.1914
15573.485060 -45.072 151.0195
15574.217482 -43.994 160.4180
15574.949904 -42.651 155.5039
15575.682326 -42.242 160.0977
15576.414748 -42.479 151.6250
15577.147170 -43.445 159.1328
15577.879591 -50.877 146.8164
15578.612013 -40.224 137.9648
15579.344435 -41.578 130.2344
15580.076857 -40.686 128.4414
15580.809279 -43.603 128.3398
15581.541700 -42.316 114.3008
15582.274122 -43.093 115.9805
15583.006544 -42.491 106.0820
15583.738966 -43.477 87.6641
15584.471388 -42.179 101.5195
15585.203809 -39.563 97.9570
15585.936231 -42.827 102.7305
15586.668653 -40.688 90.5508
15587.401075 -41.114 92.6836
15588.133497 -42.651 71.8945
15588.865919 -39.273 81.3438
15589.598340 -43.025 65.8008
15590.330762 -39.480 62.5469
15591.063184 -39.706 63.0117
15591.795606 -39.488 66.0508
15592.528028 -41.974 75.4062
15593.260449 -40.759 56.8750
15593.992871 -39.155 45.3438
15594.725293 -39.627 51.0586
15595.457715 -44.598 43.2500
15596.190137 -40.273 46.6641
15596.922559 -40.701 43.1641
15597.654980 -41.309 18.7305
15598.387402 -44.518 29.9375
15599.119824 -40.815 26.3594
15599.852246 -44.211 14.5273
15600.584668 -41.216 26.9727
15601.317089 -47.959 8.5898
15602.049511 -41.289 17.6289
15602.781933 -42.042 7.4219
15603.514355 -42.815 17.1641
15604.246777 -46.063 -4.9414
15604.979199 -42.272 24.4883
15605.711620 -43.226 -5.7383
15606.444042 -42.590 -3.2500
15607.176464 -43.947 -1.8672
15607.908886 -44.717 -0.3203
15608.641308 -44.234 16.8945
15609.373729 -44.392 -13.5156
15610.106151 -46.049 -2.7461
15610.838573 -44.395 15.0508
15611.570995 -45.199 -7.4727
15612.303417 -43.882 -19.1680
15613.035838 -52.521 -54.8281
15613.768260 -48.866 8.4766
15614.500682 -46.404 -24.9805
15615.233104 -58.712 -36.3711
15615.965526 -51.664 33.2969
15616.697948 -50.240 -15.0469
15617.430369 -58.452 -3.0977
15618.162791 -48.897 -31.8750
15618.895213 -56.645 121.1367
15619.627635 -74.881 83.2578
15620.360057 -49.406 48.4531
15621.092478 -49.630 62.2031
15621.824900 -44.639 66.8086
15622.557322 -44.303 60.6367
15623.289744 -44.108 49.8008
15624.022166 -41.595 59.2383
15624.754588 -46.508 61.1367
15625.487009 -41.514 42.5508
15626.219431 -42.621 24.6719
15626.951853 -41.398 22.0273
15627.684275 -41.917 18.4062
15628.416697 -38.612 19.9062
15629.149118 -39.903 12.9688
15629.881540 -37.529 11.4336
15630.613962 -39.700 1.8633
15631.346384 -39.256 3.0742
15632.078806 -37.917 0.0391
15632.811228 -37.855 2.3086
15633.543649 -36.006 -7.6914
15634.276071 -37.333 -11.7188
15635.008493 -36.601 -22.1719
15635.740915 -36.938 -27.9336
15636.473337 -38.028 -30.0234
15637.205758 -36.378 -46.2734
15637.938180 -36.507 -53.2383
15638.670602 -38.331 -48.1914
15639.403024 -37.896 -38.6211
15640.135446 -37.410 -58.2422
15640.867867 -37.139 -62.2656
15641.600289 -38.457 -75.2461
15642.332711 -38.939 -72.6484
15643.065133 -39.000 -67.7070
15643.797555 -37.743 -72.0312
15644.529977 -38.587 -85.6875
15645.262398 -41.295 -100.8320
15645.994820 -40.445 -101.9531
15646.727242 -41.433 -100.4844
15647.459664 -41.872 -112.0312
15648.192086 -41.874 -104.3320
15648.924507 -43.801 -107.5469
15649.656929 -42.262 -119.4102
15650.389351 -42.175 -126.1289
15651.121773 -44.802 -138.1875
15651.854195 -44.883 -119.1758
15652.586617 -42.772 -143.1484
15653.319038 -43.429 -134.7031
15654.051460 -47.413 -143.9727
15654.783882 -46.274 -173.6680
15655.516304 -52.727 -73.8555
15656.248726 -48.120 -143.6367
15656.981147 -52.940 -149.2305
15657.713569 -49.088 -160.1562
15658.445991 -51.141 -123.6289
15659.178413 -48.854 -177.3906
15659.910835 -49.991 -177.0898
15660.643256 -50.898 -153.8789
15661.375678 -48.454 -167.6328
15662.108100 -47.343 131.0703
15662.840522 -53.665 67.1562
15663.572944 -51.476 152.7344
15664.305366 -50.415 145.3711
15665.037787 -45.212 135.9922
15665.770209 -52.639 110.7383
15666.502631 -43.295 109.9375
15667.235053 -58.893 12.6523
15667.967475 -55.645 96.0469
15668.699896 -47.941 65.1953
15669.432318 -48.506 46.9102
15670.164740 -44.645 64.7656
15670.897162 -47.161 74.5586
15671.629584 -43.648 79.0430
15672.362006 -42.463 23.0039
15673.094427 -42.623 36.5625
15673.826849 -42.858 52.1953
15674.559271 -43.102 49.5391
15675.291693 -48.032 8.3867
15676.024115 -48.462 29.2969
15676.756536 -39.710 23.3164
15677.488958 -48.591 0.5312
15678.221380 -46.089 6.5117
15678.953802 -39.604 -29.6797
15679.686224 -39.372 -4.3750
15680.418646 -40.955 -1.0234
15681.151067 -40.246 -34.8203
15681.883489 -41.869 -37.0586
15682.615911 -39.125 -33.2109
15683.348333 -41.012 -47.0586
15684.080755 -38.849 -51.6680
15684.813176 -42.406 -63.4531
15685.545598 -40.871 -70.8750
15686.278020 -37.496 -66.4453
15687.010442 -41.363 -78.3008
15687.742864 -40.781 -91.1250
15688.475285 -38.548 -99.3672
15689.207707 -42.164 -79.5352
15689.940129 -40.007 -84.0625
15690.672551 -38.302 -109.6797
15691.404973 -39.988 -121.6836
15692.137395 -55.796 -87.4336
15692.869816 -38.840 -103.6367
15693.602238 -41.394 -101.1641
15694.334660 -39.936 -139.2383
15695.067082 -42.425 -92.1133
15695.799504 -40.466 -143.5000
15696.531925 -42.419 -174.8984
15697.264347 -46.780 -138.7461
15697.996769 -41.929 -114.8477
15698.729191 -40.669 -165.2734
15699.461613 -47.506 170.3438
15700.194035 -40.171 -156.5977
15700.926456 -42.764 175.7969
15701.658878 -42.347 -158.1406
15702.391300 -42.983 -151.2812
15703.123722 -41.009 -171.9648
15703.856144 -40.178 -146.2109
15704.588565 -39.219 -154.1797
15705.320987 -41.695 -165.2734
15706.053409 -43.014 -179.2031
15706.785831 -45.737 172.0000
15707.518253 -48.629 130.7812
15708.250674 -43.836 95.0625
15708.983096 -49.429 -116.0664
15709.715518 -41.515 178.1133
15710.447940 -60.956 146.0273
15711.180362 -53.901 -125.2227
15711.912784 -46.867 124.9609
15712.645205 -47.103 -162.7930
15713.377627 -75.546 34.3906
15714.110049 -51.714 -161.7578
15714.842471 -43.579 62.1719
15715.574893 -51.117 122.8477
15716.307314 -54.248 138.9648
15717.039736 -51.651 -165.3320
15717.772158 -44.525 135.7227
15718.504580 -45.641 69.1602
15719.237002 -47.126 -170.2109
15719.969424 -46.585 109.8984
15720.701845 -45.145 78.7734
15721.434267 -51.545 40.8672
15722.166689 -52.874 121.4375
15722.899111 -43.626 65.7344
15723.631533 -49.298 59.9180
15724.363954 -44.075 17.4180
15725.096376 -52.098 -33.3906
15725.828798 -51.691 148.8789
15726.561220 -42.997 66.8594
15727.293642 -43.839 44.3516
15728.026064 -48.231 17.9102
15728.758485 -42.467 12.8672
15729.490907 -44.282 11.4180
15730.223329 -49.493 25.8789
15730.955751 -41.476 10.5625
15731.688173 -41.402 -6.3477
15732.420594 -45.604 3.2070
15733.153016 -40.204 5.4805
15733.885438 -47.017 -7.6055
15734.617860 -47.919 -3.5312
15735.350282 -45.960 -0.7305
15736.082703 -42.796 -8.5195
15736.815125 -47.816 -47.2539
15737.547547 -48.586 -83.4141
15738.279969 -40.988 -29.2422
15739.012391 -53.181 -102.7070
15739.744813 -50.410 -87.5977
15740.477234 -51.816 178.9570
15741.209656 -51.727 179.8320
15741.942078 -41.024 -156.8125
15742.674500 -49.084 -153.2734
15743.406922 -50.887 120.4336
15744.139343 -42.125 -41.7852
15744.871765 -53.465 -94.2734
15745.604187 -54.239 -59.1641
15746.336609 -49.881 -46.5000
15747.069031 -54.284 -156.8555
15747.801453 -43.747 79.0586
15748.533874 -50.719 -64.5117
15749.266296 -45.498 133.3164
15749.998718 -66.032 70.5156
15750.731140 -48.386 -151.0195
15751.463562 -62.568 -29.1914
15752.195983 -48.002 85.8477
15752.928405 -46.770 121.6914
15753.660827 -63.118 108.9688
15754.393249 -45.538 40.1484
15755.125671 -52.924 -33.0469
15755.858092 -69.821 94.5938
15756.590514 -47.111 26.8789
15757.322936 -63.124 -114.4805
15758.055358 -59.338 -106.4648
15758.787780 -43.768 9.8711
15759.520202 -47.488 19.1367
15760.252623 -50.606 40.4766
15760.985045 -48.055 71.7305
15761.717467 -47.534 -26.0195
15762.449889 -47.256 3.8047
15763.182311 -51.545 -29.1367
15763.914732 -44.448 -39.1055
15764.647154 -41.156 -26.9141
15765.379576 -43.956 -50.6367
15766.111998 -49.119 -33.5820
15766.844420 -43.922 -80.0312
15767.576842 -43.604 -60.4844
15768.309263 -41.637 -63.9023
15769.041685 -43.484 -38.4883
15769.774107 -41.927 -48.7148
15770.506529 -44.869 -60.5938
15771.238951 -43.730 -70.3711
15771.971372 -43.538 -56.9023
15772.703794 -45.474 -124.0898
15773.436216 -44.390 -44.6914
15774.168638 -45.757 -73.6953
15774.901060 -47.016 -128.2188
15775.633482 -41.537 -98.5586
15776.365903 -43.980 -116.0078
15777.098325 -42.598 -93.5703
15777.830747 -42.357 -146.7930
15778.563169 -45.944 -148.9414
15779.295591 -41.495 -110.3359
15780.028012 -44.556 -134.5391
15780.760434 -43.822 -131.4102
15781.492856 -42.232 -156.7500
15782.225278 -49.781 177.1719
15782.957700 -42.823 -178.5859
15783.690121 -40.367 170.5938
15784.422543 -45.878 169.6953
15785.154965 -44.933 176.8086
15785.887387 -42.819 -149.6445
15786.619809 -45.387 166.8164
15787.352231 -42.885 130.2617
15788.084652 -47.459 101.9766
15788.817074 -39.601 143.3555
15789.549496 -46.140 155.0430
15790.281918 -40.751 115.2031
15791.014340 -44.914 143.2695
15791.746761 -46.882 120.0938
15792.479183 -46.971 79.0977
15793.211605 -43.993 53.8125
15793.944027 -42.594 61.5352
15794.676449 -47.259 34.1016
15795.408871 -44.420 54.6172
15796.141292 -46.844 31.9219
15796.873714 -56.260 -20.8359
15797.606136 -50.886 28.3086
15798.338558 -46.081 39.1172
15799.070980 -49.958 17.5352
15799.803401 -52.607 15.5000
15800.535823 -46.467 114.2461
15801.268245 -50.893 -25.8672
15802.000667 -52.957 21.2266
15802.733089 -54.542 -12.1953
15803.465510 -49.969 -111.2227
15804.197932 -73.505 -11.5195
15804.930354 -52.414 -50.9688
15805.662776 -47.540 -53.6289
15806.395198 -52.482 15.8125
15807.127620 -52.948 -40.3906
15807.860041 -63.627 -14.2539
15808.592463 -56.659 179.9961
15809.324885 -52.920 -84.0078
15810.057307 -51.970 -173.0781
15810.789729 -47.573 154.4688
15811.522150 -54.158 -160.0742
15812.254572 -50.100 148.2930
15812.986994 -47.670 147.9531
15813.719416 -51.225 109.8125
15814.451838 -53.892 165.0156
15815.184260 -48.855 140.8398
15815.916681 -53.764 65.7383
15816.649103 -52.557 85.3945
15817.381525 -44.547 91.4648
15818.113947 -52.968 128.0234
15818.846369 -48.165 109.8086
15819.578790 -46.183 89.9531
15820.311212 -49.430 121.7500
15821.043634 -46.042 72.8164
15821.776056 -47.081 71.9961
15822.508478 -54.495 51.0391
15823.240900 -46.679 60.2734
15823.973321 -45.310 41.2266
15824.705743 -44.910 63.6523
15825.438165 -53.552 70.9961
15826.170587 -49.756 35.8281
15826.903009 -44.699 51.1992
15827.635430 -44.560 15.7539
15828.367852 -48.762 61.1016
15829.100274 -48.151 19.5547
15829.832696 -43.373 21.9141
15830.565118 -46.633 10.5391
15831.297539 -47.243 26.5000
15832.029961 -48.811 6.2773
15832.762383 -46.635 -17.6133
15833.494805 -45.753 47.0273
15834.227227 -49.133 7.8867
15834.959649 -42.996 -1.3906
15835.692070 -43.182 9.1758
15836.424492 -56.605 -32.0898
15837.156914 -47.154 -20.8828
15837.889336 -51.597 44.5469
15838.621758 -42.273 -24.0234
15839.354179 -43.471 -21.7109
15840.086601 -45.615 -34.9102
15840.819023 -46.101 -34.9141
15841.551445 -43.717 -21.3477
15842.283867 -48.517 2.7891
15843.016289 -44.025 -17.0742
15843.748710 -48.394 -10.4648
15844.481132 -42.798 -1.2461
15845.213554 -43.905 13.0742
15845.945976 -47.377 -37.4453
15846.678398 -43.264 -9.6055
15847.410819 -43.593 -5.5195
15848.143241 -49.438 -7.0547
15848.875663 -42.939 -26.0625
15849.608085 -46.592 -46.5117
15850.340507 -40.750 -14.0977
15851.072928 -42.535 -22.0312
15851.805350 -46.325 -35.0781
15852.537772 -41.506 -47.3555
15853.270194 -43.187 -49.5234
15854.002616 -41.701 -53.0820
15854.735038 -40.794 -66.0078
15855.467459 -42.551 -52.6250
15856.199881 -41.007 -66.8242
15856.932303 -40.317 -73.1758
15857.664725 -39.561 -72.3789
15858.397147 -42.838 -84.1562
15859.129568 -42.160 -70.1328
15859.861990 -42.549 -90.0117
15860.594412 -39.709 -86.5430
15861.326834 -41.529 -93.6523
15862.059256 -41.105 -98.3242
15862.791678 -40.253 -99.0352
15863.524099 -39.892 -124.7305
15864.256521 -40.539 -116.8203
15864.988943 -39.062 -111.1484
15865.721365 -42.151 -135.3555
15866.453787 -40.218 -119.5898
15867.186208 -40.979 -160.6562
15867.918630 -41.286 -148.8945
15868.651052 -42.611 -166.4609
15869.383474 -42.010 -167.7773
15870.115896 -43.722 -178.3594
15870.848318 -43.631 -171.7578
15871.580739 -41.747 169.0742
15872.313161 -40.933 168.9570
15873.045583 -42.349 173.6250
15873.778005 -43.549 159.6719
15874.510427 -48.644 144.7070
15875.242848 -44.925 147.1523
15875.975270 -43.930 154.9297
15876.707692 -47.382 153.9805
15877.440114 -43.144 125.2617
15878.172536 -45.028 146.6836
15878.904957 -44.958 134.0156
15879.637379 -49.659 150.8789
15880.369801 -54.792 99.3398
15881.102223 -49.508 150.1602
15881.834645 -53.793 126.6875
15882.567067 -60.229 53.8125
15883.299488 -47.263 70.2852
15884.031910 -55.878 106.0859
15884.764332 -48.363 60.3711
15885.496754 -52.636 107.7734
15886.229176 -56.894 -85.8086
15886.961597 -47.744 149.4688
15887.694019 -45.298 -92.3945
15888.426441 -54.676 177.6211
15889.158863 -49.311 57.2109
15889.891285 -53.098 176.9141
15890.623707 -53.923 74.0000
15891.356128 -56.470 -108.5664
15892.088550 -59.344 -117.4844
15892.820972 -52.376 123.0195
15893.553394 -50.330 0.0898
15894.285816 -57.380 156.4648
15895.018237 -52.167 -9.5430
15895.750659 -43.612 136.5312
15896.483081 -50.865 126.3789
15897.215503 -48.780 167.1953
15897.947925 -52.492 -133.8945
15898.680346 -55.152 112.2148
15899.412768 -50.336 95.3047
15900.145190 -45.919 119.0391
15900.877612 -43.118 78.4297
15901.610034 -53.379 94.6289
15902.342456 -47.063 58.8672
15903.074877 -45.520 68.0508
15903.807299 -53.654 87.8047
15904.539721 -45.523 100.1133
15905.272143 -53.551 24.4375
15906.004565 -51.117 100.9961
15906.736986 -45.400 30.9570
15907.469408 -44.549 96.3711
15908.201830 -45.813 30.3320
15908.934252 -46.481 44.8555
15909.666674 -53.870 50.6758
15910.399096 -43.604 65.8711
15911.131517 -60.077 56.3750
15911.863939 -50.748 73.3008
15912.596361 -49.147 17.9023
15913.328783 -50.315 104.5938
15914.061205 -57.520 63.5078
15914.793626 -50.965 88.1953
15915.526048 -52.682 -27.0352
15916.258470 -47.491 65.8203
15916.990892 -50.634 98.0859
15917.723314 -46.582 51.6250
15918.455736 -51.449 43.5547
15919.188157 -51.166 68.7461
15919.920579 -49.413 55.3750
15920.653001 -47.611 73.4805
15921.385423 -55.853 103.4062
15922.117845 -48.371 58.7383
15922.850266 -46.613 48.1289
15923.582688 -45.505 73.6953
15924.315110 -44.350 38.3633
15925.047532 -43.713 49.6211
15925.779954 -47.072 43.5781
15926.512375 -48.124 35.4531
15927.244797 -45.726 4.2617
15927.977219 -42.882 50.0664
15928.709641 -50.689 -10.6953
15929.442063 -50.171 -0.3047
15930.174485 -45.807 -10.3477
15930.906906 -42.403 7.3086
15931.639328 -44.961 -12.5391
15932.371750 -43.813 21.9219
15933.104172 -48.957 4.8242
15933.836594 -41.576 25.6875
15934.569015 -47.249 -25.2422
15935.301437 -44.697 10.6992
15936.033859 -43.284 -34.6680
15936.766281 -44.209 -7.4258
15937.498703 -46.860 -37.3945
15938.231125 -50.576 -33.2656
15938.963546 -47.391 -62.4492
15939.695968 -52.215 4.7070
15940.428390 -46.861 -87.3203
15941.160812 -46.357 -67.7344
15941.893234 -46.185 -80.0742
15942.625655 -58.278 -36.9141
15943.358077 -47.697 -91.4922
15944.090499 -52.041 -149.6875
15944.822921 -48.891 -161.3867
15945.555343 -53.318 145.2617
15946.287764 -48.275 163.1055
15947.020186 -49.987 162.4648
15947.752608 -50.778 179.1719
15948.485030 -45.803 138.0078
15949.217452 -49.272 131.4102
15949.949874 -51.970 87.3320
15950.682295 -46.106 100.0430
15951.414717 -48.082 65.4727
15952.147139 -47.180 66.6211
15952.879561 -43.560 86.0117
15953.611983 -49.150 73.9531
15954.344404 -42.344 48.5234
15955.076826 -42.432 58.8008
15955.809248 -42.965 46.5586
15956.541670 -39.494 64.6094
15957.274092 -39.152 29.0391
15958.006514 -40.419 33.7969
15958.738935 -40.819 54.2539
15959.471357 -42.855 21.7422
15960.203779 -40.067 36.6211
15960.936201 -40.831 17.0117
15961.668623 -39.398 10.2109
15962.401044 -41.792 9.9219
15963.133466 -38.369 7.3711
15963.865888 -40.583 0.3672
15964.598310 -39.191 -21.9570
15965.330732 -43.025 -14.3281
15966.063154 -39.437 -24.8242
15966.795575 -38.975 -16.3047
15967.527997 -40.052 -29.3516
15968.260419 -45.885 -20.0234
15968.992841 -39.624 -17.1836
15969.725263 -41.770 -8.9219
15970.457684 -41.374 -11.9180
15971.190106 -40.192 -36.7070
15971.922528 -40.443 -34.7852
15972.654950 -41.828 -39.9883
15973.387372 -41.663 -23.0469
15974.119793 -49.714 -24.2930
15974.852215 -39.844 -20.1406
15975.584637 -44.915 -42.3555
15976.317059 -41.427 -34.6445
15977.049481 -42.336 -51.7148
15977.781903 -40.541 -39.6094
15978.514324 -40.867 -27.6445
15979.246746 -40.235 -42.5938
15979.979168 -43.755 -40.5703
15980.711590 -38.516 -36.7852
15981.444012 -43.387 -25.3633
15982.176433 -41.874 -43.4141
15982.908855 -42.181 -68.9609
15983.641277 -40.517 -52.1562
15984.373699 -40.639 -71.0469
15985.106121 -40.514 -68.1406
15985.838543 -41.378 -67.9648
15986.570964 -38.700 -80.4570
15987.303386 -42.052 -88.7578
15988.035808 -39.791 -87.1914
15988.768230 -41.581 -118.4336
15989.500652 -38.604 -89.7031
15990.233073 -40.802 -90.9688
15990.965495 -41.794 -111.7461
15991.697917 -42.910 -113.2422
15992.430339 -41.947 -101.9023
15993.162761 -46.259 -100.0781
15993.895182 -47.870 -120.0547
15994.627604 -44.017 -130.6484
15995.360026 -44.741 -105.8203
15996.092448 -42.233 -136.5156
15996.824870 -48.406 -112.4844
15997.557292 -49.853 -80.5430
15998.289713 -47.688 -103.2969
15999.022135 -49.663 -49.9023
15999.754557 -49.718 -46.6016
16000.486979 -55.715 -122.3438
16001.219401 -47.234 -76.5898
16001.951822 -44.238 -34.2812
16002.684244 -47.756 -48.4102
16003.416666 -43.315 -45.0234
16004.149088 -43.449 -60.2656
16004.881510 -42.667 -34.7148
16005.613932 -41.085 -35.8672
16006.346353 -46.384 -52.2305
16007.078775 -41.866 -51.3750
16007.811197 -39.763 -57.6250
16008.543619 -39.469 -67.9062
16009.276041 -39.180 -65.5938
16010.008462 -37.447 -76.1484
16010.740884 -37.428 -76.8086
16011.473306 -37.672 -91.4961
16012.205728 -39.413 -92.8945
16012.938150 -36.280 -99.1836
16013.670572 -37.526 -109.9570
16014.402993 -36.568 -107.7070
16015.135415 -36.702 -93.0586
16015.867837 -35.812 -114.6445
16016.600259 -37.281 -114.9648
16017.332681 -35.991 -115.5898
16018.065102 -36.856 -130.5156
16018.797524 -36.242 -131.4688
16019.529946 -37.581 -137.4648
16020.262368 -37.580 -143.3672
16020.994790 -38.237 -151.0234
16021.727211 -36.707 -147.6523
16022.459633 -37.084 -161.4414
16023.192055 -37.272 -158.7852
16023.924477 -36.816 -177.6289
16024.656899 -36.113 -177.1484
16025.389321 -37.516 -177.6016
16026.121742 -37.405 170.8906
16026.854164 -39.084 175.9531
16027.586586 -38.403 177.0391
16028.319008 -40.695 154.3945
16029.051430 -41.164 152.1836
16029.783851 -38.500 135.3008
16030.516273 -40.460 140.6406
16031.248695 -42.375 132.0078
16031.981117 -44.260 130.1641
16032.713539 -43.743 113.7461
16033.445961 -43.606 110.1680
16034.178382 -43.502 92.6016
16034.910804 -48.023 89.6797
16035.643226 -44.582 77.9531
16036.375648 -46.975 110.7031
16037.108070 -47.928 61.1641
16037.840491 -46.669 42.1992
16038.572913 -53.771 16.1016
16039.305335 -70.799 -153.4414
16040.037757 -50.055 -15.3164
16040.770179 -49.687 -28.6719
16041.502600 -50.992 -13.8242
16042.235022 -48.538 -58.1055
16042.967444 -63.477 159.3008
16043.699866 -53.488 -54.7656
16044.432288 -50.901 -85.3711
16045.164710 -54.955 -132.2539
16045.897131 -51.341 179.2305
16046.629553 -52.692 -124.4648
16047.361975 -55.334 129.2969
16048.094397 -49.547 173.0625
16048.826819 -54.436 -160.4727
16049.559240 -55.514 -163.5664
16050.291662 -46.461 -161.8008
16051.024084 -54.298 177.9258
16051.756506 -57.413 113.6445
16052.488928 -51.248 -79.0000
16053.221350 -44.252 85.0430
16053.953771 -52.427 -23.2227
16054.686193 -54.918 83.1484
16055.418615 -55.597 -8.5547
16056.151037 -46.481 26.0977
16056.883459 -59.705 45.5195
16057.615880 -50.690 4.1680
16058.348302 -58.405 -12.3828
16059.080724 -47.216 32.3789
16059.813146 -49.495 -15.8750
16060.545568 -45.798 4.8906
16061.277990 -46.146 -28.8281
16062.010411 -50.068 -59.7031
16062.742833 -46.269 -63.7344
16063.475255 -45.462 -62.3555
16064.207677 -42.113 -82.8789
16064.940099 -47.035 -49.2578
16065.672520 -45.242 -83.6406
16066.404942 -44.961 -108.8359
16067.137364 -44.572 -72.0000
16067.869786 -40.993 -83.4766
16068.602208 -45.837 -105.6914
16069.334629 -43.702 -116.9648
16070.067051 -42.346 -102.6719
16070.799473 -44.818 -116.1289
16071.531895 -50.936 -71.1406
16072.264317 -43.163 -148.0234
16072.996739 -43.089 -158.8477
16073.729160 -44.342 -162.2969
16074.461582 -41.618 -143.5391
16075.194004 -43.276 -145.7500
16075.926426 -45.932 -137.9492
16076.658848 -47.193 -169.8867
16077.391269 -45.494 165.0195
16078.123691 -48.324 176.1055
16078.856113 -45.681 159.0703
16079.588535 -44.188 149.4258
16080.320957 -48.954 159.2969
16081.053379 -49.204 -166.6367
16081.785800 -44.509 155.1367
16082.518222 -61.671 132.3711
16083.250644 -54.741 -162.9219
16083.983066 -49.115 124.8867
16084.715488 -49.530 145.6250
16085.447909 -43.092 115.7109
16086.180331 -47.469 95.2148
16086.912753 -45.711 136.8086
16087.645175 -53.882 130.7812
16088.377597 -47.292 35.9414
16089.110018 -47.007 111.5195
16089.842440 -48.599 48.1562
16090.574862 -45.638 79.3867
16091.307284 -46.045 65.6875
16092.039706 -48.950 133.1484
16092.772128 -47.858 12.8047
16093.504549 -44.338 29.7930
16094.236971 -41.656 -14.7617
16094.969393 -47.450 33.8086
16095.701815 -43.382 41.5547
16096.434237 -50.088 1.1680
16097.166658 -46.392 -0.5938
16097.899080 -45.669 22.4219
16098.631502 -41.738 -26.4531
16099.363924 -54.009 44.1211
16100.096346 -39.073 -28.9805
16100.828768 -45.764 -22.8086
16101.561189 -45.180 -71.4727
16102.293611 -46.719 -74.5078
16103.026033 -43.965 -38.1289
16103.758455 -47.100 -55.4062
16104.490877 -49.909 -94.7695
16105.223298 -44.110 -66.1602
16105.955720 -39.550 -112.8008
16106.688142 -50.047 -104.5273
16107.420564 -40.650 -91.2539
16108.152986 -39.730 -107.8281
16108.885408 -45.998 -152.2695
16109.617829 -44.150 -99.2578
16110.350251 -42.917 -123.6211
16111.082673 -43.909 -148.1797
16111.815095 -43.905 -130.3555
16112.547517 -46.726 -163.5625
16113.279938 -46.834 -147.4961
16114.012360 -55.008 173.4609
16114.744782 -47.515 -152.6328
16115.477204 -46.416 -165.9453
16116.209626 -45.414 178.2266
16116.942047 -47.022 116.7734
16117.674469 -50.246 -151.7539
16118.406891 -48.058 109.5078
16119.139313 -47.275 91.1328
16119.871735 -45.932 138.7969
16120.604157 -52.976 145.9102
16121.336578 -41.915 109.3438
16122.069000 -56.099 27.6133
16122.801422 -48.292 101.1641
16123.533844 -62.549 -13.4609
16124.266266 -42.615 54.9414
16124.998687 -48.603 19.7930
16125.731109 -49.794 34.1328
16126.463531 -42.217 -7.1445
16127.195953 -45.013 26.1055
16127.928375 -45.803 1.3633
16128.660797 -44.132 9.0781
16129.393218 -39.620 -52.9688
16130.125640 -41.352 -32.8516
16130.858062 -41.449 -39.5391
16131.590484 -43.474 -51.5391
16132.322906 -42.706 -35.8086
16133.055327 -41.922 -60.3867
16133.787749 -43.210 -67.5859
16134.520171 -43.864 -64.5898
16135.252593 -37.192 -88.9180
16135.985015 -40.902 -84.8594
16136.717436 -40.652 -91.4180
16137.449858 -39.123 -109.2305
16138.182280 -40.844 -114.0156
16138.914702 -39.182 -122.4922
16139.647124 -37.936 -115.3359
16140.379546 -41.695 -113.9141
16141.111967 -37.999 -137.0898
16141.844389 -36.663 -143.2344
16142.576811 -39.086 -142.5000
16143.309233 -40.936 -157.1797
16144.041655 -39.399 -156.8711
16144.774076 -43.177 -162.3086
16145.506498 -42.743 -154.9336
16146.238920 -42.876 162.8516
16146.971342 -39.481 -170.4844
16147.703764 -41.330 161.3008
16148.436186 -42.313 161.8242
16149.168607 -40.613 153.3359
16149.901029 -40.610 -179.5000
16150.633451 -47.956 122.1914
16151.365873 -44.428 137.2344
16152.098295 -48.721 86.2461
16152.830716 -43.092 157.3750
16153.563138 -44.310 104.5117
16154.295560 -46.855 125.8594
16155.027982 -45.105 113.0391
16155.760404 -62.236 98.8555
16156.492826 -51.451 49.8516
16157.225247 -53.421 83.2031
16157.957669 -45.622 46.2617
16158.690091 -55.767 -77.6523
16159.422513 -44.522 -45.3320
16160.154935 -64.159 -48.2109
16160.887356 -54.850 -77.8477
16161.619778 -56.522 -62.7656
16162.352200 -49.619 -24.4570
16163.084622 -68.948 -108.1602
16163.817044 -59.100 -159.9297
16164.549465 -50.617 -138.8008
16165.281887 -53.482 -136.9141
16166.014309 -48.953 -72.2266
16166.746731 -52.512 -100.7188
16167.479153 -49.336 -114.6016
16168.211575 -49.225 -57.9609
16168.943996 -55.568 -171.5547
16169.676418 -67.432 -29.9062
16170.408840 -48.735 -151.9258
16171.141262 -46.427 -77.6406
16171.873684 -50.256 -150.5977
16172.606105 -46.415 -113.0352
16173.338527 -46.707 -112.4688
16174.070949 -56.075 -138.4531
16174.803371 -51.556 -24.9023
16175.535793 -58.735 -81.9922
16176.268215 -48.174 -125.9141
16177.000636 -49.716 -132.6133
16177.733058 -46.067 -99.9062
16178.465480 -48.705 -93.6406
16179.197902 -42.550 -112.5117
16179.930324 -42.953 -128.3555
16180.662745 -49.008 -115.4648
16181.395167 -44.155 -128.3320
16182.127589 -44.343 -145.1328
16182.860011 -40.018 -137.2734
16183.592433 -40.214 -143.9023
16184.324854 -42.243 -120.7695
16185.057276 -40.366 -158.7109
16185.789698 -40.935 -148.4609
16186.522120 -42.784 -171.3594
16187.254542 -40.679 -172.9766
16187.986964 -38.959 164.8516
16188.719385 -41.672 167.3164
16189.451807 -42.802 -179.6953
16190.184229 -42.308 166.9062
16190.916651 -42.464 156.0469
16191.649073 -46.137 -174.6992
16192.381494 -43.508 142.6406
16193.113916 -48.090 132.4570
16193.846338 -42.053 131.9648
16194.578760 -42.064 137.4258
16195.311182 -45.942 130.2422
16196.043604 -49.463 137.4805
16196.776025 -42.516 114.0938
16197.508447 -45.876 133.2344
16198.240869 -51.555 144.8984
16198.973291 -47.724 163.7383
16199.705713 -49.362 147.1719
16200.438134 -47.112 -178.5430
16201.170556 -47.573 -150.9531
16201.902978 -60.714 -51.3750
16202.635400 -48.712 154.7852
16203.367822 -42.385 175.8203
16204.100244 -46.170 -160.0547
16204.832665 -43.464 -170.5352
16205.565087 -41.603 165.6211
16206.297509 -42.781 -169.3516
16207.029931 -41.574 -174.8828
16207.762353 -42.109 174.8594
16208.494774 -40.663 163.5859
16209.227196 -38.380 172.2500
16209.959618 -41.207 161.9102
16210.692040 -39.148 144.8242
16211.424462 -38.924 138.0117
16212.156883 -37.363 141.0039
16212.889305 -38.661 135.0195
16213.621727 -39.835 133.0859
16214.354149 -37.807 116.1250
16215.086571 -37.479 137.1875
16215.818993 -37.495 111.9180
16216.551414 -39.521 109.8711
16217.283836 -38.306 103.8438
16218.016258 -37.683 111.2578
16218.748680 -38.185 89.5000
16219.481102 -38.454 83.2617
16220.213523 -38.676 78.7930
16220.945945 -38.335 83.0469
16221.678367 -40.696 63.6641
16222.410789 -40.015 62.1875
16223.143211 -37.441 59.7734
16223.875633 -40.419 48.2969
16224.608054 -44.077 55.3438
16225.340476 -41.248 34.6211
16226.072898 -40.287 46.6992
16226.805320 -41.135 55.7109
16227.537742 -43.362 22.8477
16228.270163 -45.249 0.3281
16229.002585 -41.628 35.2031
16229.735007 -46.414 26.4375
16230.467429 -48.705 13.8594
16231.199851 -48.609 -43.2773
16231.932272 -50.409 -35.5586
16232.664694 -56.146 -53.5156
16233.397116 -65.555 35.8047
16234.129538 -58.162 140.2539
16234.861960 -66.008 46.2461
16235.594382 -54.108 62.1055
16236.326803 -46.839 161.4297
16237.059225 -46.166 -172.0625
16237.791647 -49.834 162.5703
16238.524069 -45.898 153.7539
16239.256491 -46.384 126.3164
16239.988912 -45.390 131.1055
16240.721334 -45.455 110.3672
16241.453756 -43.088 108.3594
16242.186178 -42.924 118.7070
16242.918600 -45.479 114.4297
16243.651022 -39.781 89.0586
16244.383443 -40.407 94.5430
16245.115865 -40.498 96.5039
16245.848287 -40.122 83.5156
16246.580709 -39.465 74.0117
16247.313131 -39.746 70.5898
16248.045552 -38.281 78.9609
16248.777974 -39.596 66.2930
16249.510396 -37.492 47.8398
16250.242818 -36.994 57.8398
16250.975240 -38.299 25.1953
16251.707662 -39.826 36.4688
16252.440083 -37.472 41.4102
16253.172505 -37.003 37.4141
16253.904927 -39.563 31.1445
16254.637349 -37.265 4.1094
16255.369771 -37.299 9.5078
16256.102192 -38.435 6.8086
16256.834614 -38.745 -13.8359
16257.567036 -37.397 -10.6289
16258.299458 -37.999 -10.9492
16259.031880 -37.793 -28.0547
16259.764301 -40.464 -15.9141
16260.496723 -41.539 -40.4297
16261.229145 -40.197 -34.6289
16261.961567 -42.580 -47.4688
16262.693989 -41.179 -48.3984
16263.426411 -41.596 -65.1367
16264.158832 -43.173 -46.7461
16264.891254 -45.673 -75.9102
16265.623676 -43.891 -75.5312
16266.356098 -51.797 -91.0625
16267.088520 -45.002 -76.6250
16267.820941 -50.000 -86.0234
16268.553363 -84.275 -26.4453
16269.285785 -49.317 -102.5508
16270.018207 -50.955 -48.4688
16270.750629 -54.945 -30.5742
16271.483051 -49.581 55.2422
16272.215472 -53.366 141.0703
16272.947894 -51.716 -23.1992
16273.680316 -51.496 66.8516
16274.412738 -55.600 18.8047
16275.145160 -52.032 30.4062
16275.877581 -46.694 18.1875
16276.610003 -44.939 14.0781
16277.342425 -47.647 -11.2344
16278.074847 -49.585 -3.7070
16278.807269 -45.239 -23.9102
16279.539690 -51.076 5.0938
16280.272112 -43.038 -39.3086
16281.004534 -45.475 -52.6875
16281.736956 -48.755 -72.2930
16282.469378 -44.501 -73.5625
16283.201800 -46.556 -73.2969
16283.934221 -44.653 -103.4570
16284.666643 -44.525 -118.0508
16285.399065 -48.627 -135.2031
16286.131487 -47.599 -104.2930
16286.863909 -47.272 -165.7422
16287.596330 -43.905 -173.8008
16288.328752 -42.308 -145.4453
16289.061174 -44.586 -167.8086
16289.793596 -43.236 159.6836
16290.526018 -43.303 172.5859
16291.258440 -41.158 143.4414
16291.990861 -42.181 141.6602
16292.723283 -41.593 124.4453
16293.455705 -39.806 106.1211
16294.188127 -41.444 115.4414
16294.920549 -38.310 78.6523
16295.652970 -38.554 104.4414
16296.385392 -40.958 77.0547
16297.117814 -39.699 67.6797
16297.850236 -39.179 62.1133
16298.582658 -40.279 65.3203
16299.315080 -38.477 46.8281
16300.047501 -37.199 41.4570
16300.779923 -37.854 28.7305
16301.512345 -39.292 45.8750
16302.244767 -36.332 12.5664
16302.977189 -37.763 9.0156
16303.709610 -38.584 11.0781
16304.442032 -37.410 1.8984
16305.174454 -36.965 -18.5547
16305.906876 -40.102 -20.9336
16306.639298 -37.405 -19.9844
16307.371719 -39.469 -18.3242
16308.104141 -37.153 -38.5352
16308.836563 -39.382 -46.3555
16309.568985 -37.234 -61.8945
16310.301407 -39.329 -58.8828
16311.033829 -38.138 -67.6602
16311.766250 -39.607 -80.0508
16312.498672 -40.657 -86.8828
16313.231094 -40.791 -95.8984
16313.963516 -42.223 -93.0234
16314.695938 -43.418 -103.2539
16315.428359 -43.320 -95.4922
16316.160781 -47.163 -152.1797
16316.893203 -45.321 -105.1211
16317.625625 -43.556 -144.5430
16318.358047 -54.550 -133.8555
16319.090469 -53.203 119.3867
16319.822890 -55.818 -136.5391
16320.555312 -56.840 -175.9844
16321.287734 -54.364 157.2109
16322.020156 -49.086 85.9258
16322.752578 -54.744 -0.9375
16323.484999 -59.170 116.4062
16324.217421 -54.484 42.4766
16324.949843 -45.730 45.7344
16325.682265 -48.734 8.6445
16326.414687 -48.951 -21.0273
16327.147108 -51.581 -59.6797
16327.879530 -50.730 -2.8047
16328.611952 -49.600 -58.3633
16329.344374 -54.968 -67.0273
16330.076796 -50.497 -36.9336
16330.809218 -46.379 -34.4297
16331.541639 -44.032 -50.5703
16332.274061 -45.579 -66.5234
16333.006483 -48.545 -99.3516
16333.738905 -50.791 -118.3125
16334.471327 -46.478 -103.5430
16335.203748 -46.954 -126.5664
16335.936170 -48.535 -108.1172
16336.668592 -55.438 177.9102
16337.401014 -45.718 -128.7773
16338.133436 -47.977 -141.9609
16338.865858 -52.083 -117.2734
16339.598279 -52.415 113.4570
16340.330701 -50.393 -153.1719
16341.063123 -50.153 115.5078
16341.795545 -55.027 40.7148
16342.527967 -62.486 159.3828
16343.260388 -52.426 -169.9453
16343.992810 -63.830 -50.0742
16344.725232 -46.925 118.5898
16345.457654 -49.658 64.2227
16346.190076 -49.639 7.3828
16346.922498 -48.399 44.0586
16347.654919 -50.626 18.8398
16348.387341 -44.858 73.9453
16349.119763 -60.424 -2.1992
16349.852185 -45.770 36.6758
16350.584607 -46.670 45.7773
16351.317028 -43.876 41.4297
16352.049450 -51.516 60.5508
16352.781872 -43.716 30.4844
16353.514294 -52.785 20.5508
16354.246716 -49.334 -31.1094
16354.979137 -51.597 -23.6484
16355.711559 -41.459 24.6016
16356.443981 -49.527 36.6641
16357.176403 -44.790 42.3672
16357.908825 -47.014 32.8008
16358.641247 -45.930 46.1172
16359.373668 -46.466 21.1641
16360.106090 -42.525 10.4453
16360.838512 -45.423 -1.8867
16361.570934 -41.537 12.1758
16362.303356 -42.190 -0.1133
16363.035777 -42.981 15.0859
16363.768199 -44.505 -10.2031
16364.500621 -42.707 -3.5977
16365.233043 -41.796 -31.3633
16365.965465 -39.523 -33.5117
16366.697887 -42.231 -37.9805
16367.430308 -41.610 -23.4922
16368.162730 -40.546 -39.3984
16368.895152 -39.961 -34.4609
16369.627574 -39.369 -44.9609
16370.359996 -40.278 -47.4375
16371.092417 -38.749 -57.0312
16371.824839 -38.752 -57.1719
16372.557261 -38.225 -80.3203
16373.289683 -38.002 -69.6016
16374.022105 -40.997 -70.3984
16374.754526 -40.633 -69.4023
16375.486948 -40.168 -99.7578
16376.219370 -40.930 -92.8203
16376.951792 -41.936 -97.8203
16377.684214 -43.767 -78.9141
16378.416636 -42.462 -128.6641
16379.149057 -40.551 -118.0273
16379.881479 -43.750 -127.9609
16380.613901 -44.539 -113.8359
16381.346323 -41.367 -144.8789
16382.078745 -44.510 -167.1641
16382.811166 -46.494 -139.5156
16383.543588 -44.358 -122.0352
16384.276010 -53.014 -138.6250
16385.008432 -51.557 -155.5000
16385.740854 -55.223 -146.3789
16386.473276 -52.254 -40.5312
16387.205697 -48.380 -168.0664
16387.938119 -50.207 -88.4141
16388.670541 -48.720 -126.0586
16389.402963 -53.070 -61.8164
16390.135385 -53.549 116.7969
16390.867806 -48.668 -118.7734
16391.600228 -46.856 -65.1367
16392.332650 -57.921 -94.9453
16393.065072 -50.903 -78.1992
16393.797494 -51.255 -62.7109
16394.529916 -49.531 -61.1172
16395.262337 -46.737 -48.8203
16395.994759 -46.765 -82.8789
16396.727181 -49.319 -64.6406
16397.459603 -44.504 -75.9961
16398.192025 -43.930 -69.1562
16398.924446 -51.240 -120.5000
16399.656868 -47.121 -84.5742
16400.389290 -49.535 -115.2383
16401.121712 -54.686 -52.5781
16401.854134 -54.140 -144.0273
16402.586555 -51.202 -70.4297
16403.318977 -53.802 -87.1406
16404.051399 -50.085 -29.7305
16404.783821 -56.125 174.5859
16405.516243 -56.314 29.6680
16406.248665 -54.844 -85.7422
16406.981086 -46.432 1.1602
16407.713508 -66.426 91.5547
16408.445930 -68.579 130.0898
16409.178352 -54.777 -61.7148
16409.910774 -43.821 -47.2695
16410.643195 -47.753 -96.3438
16411.375617 -42.713 -15.6797
16412.108039 -47.370 -92.9766
16412.840461 -43.409 -105.9961
16413.572883 -46.176 -75.1367
16414.305305 -45.154 -57.6992
16415.037726 -43.004 -79.7930
16415.770148 -40.720 -101.4570
16416.502570 -41.479 -86.4141
16417.234992 -42.917 -84.0312
16417.967414 -41.109 -96.0625
16418.699835 -43.167 -107.8203
16419.432257 -40.065 -97.9844
16420.164679 -42.199 -120.3867
16420.897101 -45.230 -150.5039
16421.629523 -40.433 -112.3555
16422.361944 -48.852 -130.3750
16423.094366 -40.712 -140.9297
16423.826788 -39.508 -126.6719
16424.559210 -40.826 -145.1133
16425.291632 -44.362 -163.3867
16426.024054 -50.523 163.9258
16426.756475 -52.194 -158.9219
16427.488897 -44.751 -144.6797
16428.221319 -47.474 -160.2109
16428.953741 -47.614 131.0742
16429.686163 -50.344 -175.7852
16430.418584 -49.447 -160.4453
16431.151006 -60.348 119.3164
16431.883428 -51.099 -134.8086
16432.615850 -44.600 126.7188
16433.348272 -47.469 168.6602
16434.080694 -44.704 -144.2656
16434.813115 -45.126 -153.0469
16435.545537 -43.988 159.8281
16436.277959 -46.568 173.8750
16437.010381 -58.709 66.7344
16437.742803 -46.673 -166.2969
16438.475224 -45.805 -146.7344
16439.207646 -46.731 -162.6289
16439.940068 -56.480 93.9062
16440.672490 -69.921 -81.2812
16441.404912 -51.649 145.6602
16442.137334 -46.537 -174.2695
16442.869755 -40.276 143.0586
16443.602177 -45.018 -163.0195
16444.334599 -43.647 -179.0352
16445.067021 -51.920 147.0312
16445.799443 -43.430 -174.3750
16446.531864 -43.548 -150.2969
16447.264286 -45.205 -178.5430
16447.996708 -48.598 127.7578
16448.729130 -39.240 132.4180
16449.461552 -44.789 136.7148
16450.193973 -39.227 148.3555
16450.926395 -41.657 162.8164
16451.658817 -44.988 122.6250
16452.391239 -52.568 108.6562
16453.123661 -49.385 99.8984
16453.856083 -54.284 140.4844
16454.588504 -50.241 138.3906
16455.320926 -55.802 179.9805
16456.053348 -51.136 176.6133
16456.785770 -44.634 -68.6875
16457.518192 -55.139 -108.2305
16458.250613 -48.525 -96.5430
16458.983035 -48.940 144.8750
16459.715457 -46.660 18.7734
16460.447879 -40.776 -165.7305
16461.180301 -44.712 129.9648
16461.912723 -44.944 135.3789
16462.645144 -43.782 137.5312
16463.377566 -43.085 106.2266
16464.109988 -57.494 89.8516
16464.842410 -39.745 82.4375
16465.574832 -53.771 66.1289
16466.307253 -41.491 92.9688
16467.039675 -43.714 56.2969
16467.772097 -47.258 115.5938
16468.504519 -53.878 -126.7227
16469.236941 -43.356 93.5078
16469.969362 -42.501 44.6836
16470.701784 -40.755 26.2734
16471.434206 -43.578 17.5273
16472.166628 -40.220 40.6016
16472.899050 -41.058 20.8516
16473.631472 -38.142 -12.8867
16474.363893 -39.551 6.4961
16475.096315 -44.134 25.1328
16475.828737 -41.513 -28.5312
16476.561159 -45.391 13.6016
16477.293581 -36.147 -44.1055
16478.026002 -40.893 -95.0977
16478.758424 -40.124 -63.0625
16479.490846 -42.599 -61.2188
16480.223268 -40.133 -74.6992
16480.955690 -42.311 -95.3984
16481.688112 -36.763 -105.3047
16482.420533 -39.089 -75.8867
16483.152955 -41.075 -79.1406
16483.885377 -39.874 -92.7656
16484.617799 -41.327 -87.8438
16485.350221 -45.796 -82.2617
16486.082642 -46.730 -88.3672
16486.815064 -38.858 -128.0508
16487.547486 -38.255 -117.2852
16488.279908 -47.770 170.9414
16489.012330 -40.652 178.7539
16489.744752 -44.520 142.2148
16490.477173 -40.033 179.2422
16491.209595 -41.243 147.8281
16491.942017 -37.368 138.3672
16492.674439 -41.133 164.1523
16493.406861 -44.124 151.8320
16494.139282 -42.149 142.6797
16494.871704 -40.686 162.8633
16495.604126 -46.032 150.4492
16496.336548 -42.524 -142.7891
16497.068970 -43.595 144.2266
16497.801391 -40.061 103.8945
16498.533813 -45.292 168.6758
16499.266235 -43.859 112.0664
16499.998657 -44.915 94.6172
16500.731079 -45.479 118.2344
16501.463501 -55.518 166.8125
16502.195922 -46.511 109.2148
16502.928344 -57.548 -173.3984
16503.660766 -58.942 -110.4062
16504.393188 -50.373 55.5039
16505.125610 -48.881 128.1836
16505.858031 -45.393 -8.0938
16506.590453 -47.161 -58.8242
16507.322875 -55.120 -1.0273
16508.055297 -49.921 -123.5352
16508.787719 -50.402 -113.7969
16509.520141 -53.042 -5.2539
16510.252562 -47.364 -163.0742
16510.984984 -50.009 -112.0430
16511.717406 -50.589 -102.9805
16512.449828 -44.722 -73.4883
16513.182250 -48.321 -9.5938
16513.914671 -49.981 155.7266
16514.647093 -45.631 -138.4219
16515.379515 -45.997 -161.4141
16516.111937 -44.897 149.6406
16516.844359 -50.294 58.5781
16517.576780 -54.051 -144.5156
16518.309202 -40.736 -163.1562
16519.041624 -44.866 159.6289
16519.774046 -42.989 -167.7617
16520.506468 -43.562 161.0117
16521.238890 -58.824 -96.0156
16521.971311 -43.010 119.7695
16522.703733 -45.687 -166.2812
16523.436155 -43.415 145.2148
16524.168577 -49.655 176.7969
16524.900999 -45.744 -168.4609
16525.633420 -41.865 174.8359
16526.365842 -45.814 159.3828
16527.098264 -46.828 162.3672
16527.830686 -40.317 99.4883
16528.563108 -40.493 108.0820
16529.295530 -48.038 89.6055
16530.027951 -43.698 -130.6172
16530.760373 -46.570 174.2266
16531.492795 -44.733 -165.4453
16532.225217 -45.353 -151.9492
16532.957639 -46.182 156.1016
16533.690060 -49.185 178.9141
16534.422482 -48.410 -161.1211
16535.154904 -61.865 -36.6055
16535.887326 -46.099 167.6523
16536.619748 -45.759 -171.5312
16537.352170 -66.086 82.7070
16538.084591 -52.977 19.7891
16538.817013 -49.243 159.5039
16539.549435 -47.145 10.2656
16540.281857 -44.946 68.2891
16541.014279 -51.695 125.6758
16541.746700 -45.391 -175.1406
16542.479122 -52.168 131.1055
16543.211544 -44.279 114.6992
16543.943966 -47.823 100.1719
16544.676388 -51.828 178.7422
16545.408809 -59.371 175.3125
16546.141231 -40.717 130.1133
16546.873653 -51.154 -155.1562
16547.606075 -53.671 95.1953
16548.338497 -55.131 13.5430
16549.070919 -44.480 48.7383
16549.803340 -46.289 93.8359
16550.535762 -44.285 111.2930
16551.268184 -46.899 75.9688
16552.000606 -48.377 98.5352
16552.733028 -52.328 48.9805
16553.465449 -51.418 115.0000
16554.197871 -64.139 177.6172
16554.930293 -44.978 40.1992
16555.662715 -59.480 74.1484
16556.395137 -48.762 -91.6328
16557.127559 -51.306 51.3242
16557.859980 -46.500 88.4766
16558.592402 -41.132 46.1719
16559.324824 -52.878 159.0820
16560.057246 -47.802 -29.6875
16560.789668 -57.500 -13.4961
16561.522089 -44.888 -25.8867
16562.254511 -43.611 43.0078
16562.986933 -47.254 11.9102
16563.719355 -52.573 20.8203
16564.451777 -54.898 34.4688
16565.184198 -62.225 93.6055
16565.916620 -54.746 -67.5391
16566.649042 -60.171 -120.7305
16567.381464 -49.183 -175.7695
16568.113886 -55.821 -51.6289
16568.846308 -51.741 -1.0742
16569.578729 -75.463 -63.8594
16570.311151 -56.320 138.9922
16571.043573 -51.361 127.0703
16571.775995 -61.956 -57.5898
16572.508417 -45.624 -4.3086
16573.240838 -47.930 4.6758
16573.973260 -58.976 -96.0156
16574.705682 -47.207 -55.5078
16575.438104 -49.739 -33.1484
16576.170526 -48.677 -76.5430
16576.902948 -46.367 -75.3945
16577.635369 -50.095 -63.5977
16578.367791 -44.601 -29.1211
16579.100213 -40.990 -61.9492
16579.832635 -52.275 -69.5547
16580.565057 -43.670 -73.7773
16581.297478 -47.603 -21.9492
16582.029900 -44.853 -118.3359
16582.762322 -43.429 -93.9258
16583.494744 -42.108 -109.1836
16584.227166 -40.201 -85.0625
16584.959588 -42.521 -117.6758
16585.692009 -41.213 -112.3984
16586.424431 -38.739 -122.1367
16587.156853 -40.336 -102.6758
16587.889275 -42.411 -121.8867
16588.621697 -41.142 -132.7188
16589.354118 -38.478 -152.4023
16590.086540 -43.486 -142.1719
16590.818962 -38.427 -136.6445
16591.551384 -37.953 -152.8359
16592.283806 -40.157 -156.9258
16593.016227 -41.517 -150.1875
16593.748649 -38.379 -175.6289
16594.481071 -38.199 173.1367
16595.213493 -38.044 167.1992
16595.945915 -41.788 157.7461
16596.678337 -38.539 154.7070
16597.410758 -38.254 140.3633
16598.143180 -40.565 150.3672
16598.875602 -42.275 134.3594
16599.608024 -38.274 130.3320
16600.340446 -39.869 134.0430
16601.072867 -38.528 120.2695
16601.805289 -40.953 119.5820
16602.537711 -40.657 107.1875
16603.270133 -41.888 83.6016
16604.002555 -44.207 123.7188
16604.734977 -46.055 93.7969
16605.467398 -49.392 90.8164
16606.199820 -42.910 103.4453
16606.932242 -41.068 118.8242
16607.664664 -60.968 22.3750
16608.397086 -51.995 137.9297
16609.129507 -61.137 11.9453
16609.861929 -48.321 177.4453
16610.594351 -55.834 -150.1094
16611.326773 -58.380 148.3086
16612.059195 -48.958 162.7539
16612.791616 -48.531 157.0938
16613.524038 -47.999 177.4297
16614.256460 -44.673 151.0078
16614.988882 -47.601 138.6094
16615.721304 -41.628 -179.0742
16616.453726 -45.766 154.9336
16617.186147 -43.212 160.0352
16617.918569 -41.753 131.4258
16618.650991 -41.520 139.8984
16619.383413 -45.605 120.5352
16620.115835 -42.070 134.8359
16620.848256 -42.397 138.1758
16621.580678 -44.671 137.6328
16622.313100 -45.785 115.1211
16623.045522 -41.967 99.7656
16623.777944 -42.451 85.7969
16624.510366 -42.182 86.7344
16625.242787 -48.764 95.3242
16625.975209 -46.411 98.0000
16626.707631 -45.837 55.3203
16627.440053 -50.113 94.5312
16628.172475 -49.543 -11.5430
16628.904896 -48.567 72.2773
16629.637318 -46.202 53.7500
16630.369740 -52.817 114.6289
16631.102162 -59.720 -87.6914
16631.834584 -67.405 62.4023
16632.567006 -54.937 102.1250
16633.299427 -46.773 161.0742
16634.031849 -47.573 -172.8477
16634.764271 -47.327 169.7422
16635.496693 -53.776 142.8945
16636.229115 -43.340 139.3047
16636.961536 -46.444 -176.0156
16637.693958 -44.241 140.6172
16638.426380 -44.010 126.7773
16639.158802 -40.474 147.9336
16639.891224 -42.747 159.6250
16640.623645 -41.726 120.0703
16641.356067 -43.037 121.5273
16642.088489 -40.340 102.6875
16642.820911 -45.390 127.7734
16643.553333 -39.130 116.7148
16644.285755 -40.744 90.6406
16645.018176 -40.577 109.5156
16645.750598 -41.810 85.1172
16646.483020 -39.376 86.8945
16647.215442 -41.827 79.2695
16647.947864 -38.943 83.2695
16648.680285 -42.815 76.2773
16649.412707 -41.718 61.9766
16650.145129 -45.794 55.1797
16650.877551 -42.231 76.3828
16651.609973 -46.139 37.7227
16652.342395 -40.381 55.6211
16653.074816 -40.279 34.5273
16653.807238 -42.570 36.1016
16654.539660 -45.239 71.7656
16655.272082 -44.295 49.3359
16656.004504 -47.383 74.2031
16656.736925 -44.305 61.9883
16657.469347 -49.483 30.9141
16658.201769 -50.217 100.9648
16658.934191 -44.488 58.4141
16659.666613 -44.137 36.4766
16660.399035 -57.595 89.7930
16661.131456 -41.714 57.3984
16661.863878 -45.435 0.6367
16662.596300 -43.923 67.9062
16663.328722 -44.776 45.7305
16664.061144 -45.486 49.9492
16664.793565 -45.347 34.7148
16665.525987 -43.284 43.1250
16666.258409 -46.181 46.0469
16666.990831 -46.629 30.8477
16667.723253 -45.051 33.5625
16668.455674 -46.144 60.1602
16669.188096 -45.762 12.4531
16669.920518 -47.320 -4.7969
16670.652940 -43.523 -22.3594
16671.385362 -42.733 -11.8477
16672.117784 -56.062 -110.6250
16672.850205 -49.666 -13.0312
16673.582627 -46.810 -29.5234
16674.315049 -50.010 -22.2617
16675.047471 -49.427 -122.6016
16675.779893 -45.536 -48.2891
16676.512314 -45.013 -31.3047
16677.244736 -49.301 -120.0859
16677.977158 -45.724 -100.4648
16678.709580 -60.549 -159.3477
16679.442002 -49.194 -109.4141
16680.174424 -53.507 -178.8828
16680.906845 -63.953 -139.2266
16681.639267 -49.406 -178.9375
16682.371689 -53.599 -174.2812
16683.104111 -64.575 -172.7617
16683.836533 -41.059 167.6367
16684.568954 -47.481 108.2109
16685.301376 -46.480 -155.1055
16686.033798 -46.521 135.7227
16686.766220 -43.460 157.5859
16687.498642 -49.516 113.5234
16688.231063 -51.023 89.4102
16688.963485 -47.329 85.1602
16689.695907 -45.304 99.2969
16690.428329 -46.990 96.4766
16691.160751 -46.315 73.7227
16691.893173 -50.138 65.3594
16692.625594 -46.067 99.6406
16693.358016 -45.406 66.8477
16694.090438 -53.396 23.3906
16694.822860 -47.916 73.3359
16695.555282 -48.015 37.7969
16696.287703 -51.457 20.4375
16697.020125 -54.075 109.5391
16697.752547 -48.566 24.1445
16698.484969 -48.344 54.3203
16699.217391 -48.268 49.3555
16699.949813 -57.303 -31.9453
16700.682234 -52.346 -53.5195
16701.414656 -48.914 47.4414
16702.147078 -52.403 14.4844
16702.879500 -49.662 -19.6133
16703.611922 -53.041 3.0391
16704.344343 -62.556 14.1133
16705.076765 -55.189 -2.6836
16705.809187 -50.193 -49.5156
16706.541609 -49.743 11.5078
16707.274031 -64.105 28.1133
16708.006453 -50.749 -97.9727
16708.738874 -51.099 -124.2930
16709.471296 -55.348 55.1758
16710.203718 -54.886 -80.5117
16710.936140 -55.672 64.2344
16711.668562 -58.328 -63.7422
16712.400983 -52.108 -10.9570
16713.133405 -54.995 113.5156
16713.865827 -50.852 62.7695
16714.598249 -50.406 142.5586
16715.330671 -50.542 135.9766
16716.063092 -50.066 19.4531
16716.795514 -50.252 79.7695
16717.527936 -53.558 92.6914
16718.260358 -50.463 77.1680
16718.992780 -43.956 60.7461
16719.725202 -58.911 99.0664
16720.457623 -60.246 158.6328
16721.190045 -47.356 96.9141
16721.922467 -48.160 60.5625
16722.654889 -52.567 82.8789
16723.387311 -61.494 73.3945
16724.119732 -53.848 35.3047
16724.852154 -52.360 96.8438
16725.584576 -53.754 73.7695
16726.316998 -62.561 -149.2031
16727.049420 -60.786 54.7305
16727.781842 -55.941 15.5312
16728.514263 -53.126 94.9531
16729.246685 -63.687 -172.2617
16729.979107 -64.318 164.3281
16730.711529 -49.241 80.1484
16731.443951 -52.399 -151.0195
16732.176372 -53.067 155.7891
16732.908794 -50.888 114.5156
16733.641216 -47.057 114.0234
16734.373638 -51.881 132.7852
16735.106060 -50.751 123.0000
16735.838481 -57.037 76.5508
16736.570903 -50.316 150.6406
16737.303325 -54.009 67.5078
16738.035747 -47.607 98.3594
16738.768169 -47.261 88.0781
16739.500591 -44.508 67.1445
16740.233012 -46.824 85.4102
16740.965434 -46.097 87.7422
16741.697856 -56.138 19.8984
16742.430278 -45.134 52.5547
16743.162700 -47.808 79.0117
16743.895121 -44.670 67.4375
16744.627543 -46.381 38.3516
16745.359965 -45.601 41.8477
16746.092387 -52.512 77.3750
16746.824809 -47.074 62.9414
16747.557231 -44.374 34.9414
16748.289652 -44.551 10.4570
16749.022074 -42.642 10.8516
16749.754496 -45.502 -3.1484
16750.486918 -45.012 -2.4258
16751.219340 -50.379 -32.8633
16751.951761 -46.498 13.5430
16752.684183 -48.510 -49.6953
16753.416605 -46.827 -26.4453
16754.149027 -48.080 -22.6836
16754.881449 -49.794 -61.6836
16755.613871 -79.566 -69.3242
16756.346292 -50.741 -1.5508
16757.078714 -56.399 -11.4062
16757.811136 -50.324 -5.0664
16758.543558 -49.073 -30.2656
16759.275980 -49.799 -38.1914
16760.008401 -49.093 -29.1797
16760.740823 -47.409 -39.7070
16761.473245 -50.888 -60.0195
16762.205667 -47.363 -23.8203
16762.938089 -51.098 -31.6719
16763.670510 -51.038 -39.9453
16764.402932 -51.191 7.7500
16765.135354 -57.428 -80.4844
16765.867776 -44.555 -20.5039
16766.600198 -50.325 -73.2812
16767.332620 -55.573 -63.6641
16768.065041 -51.984 -71.9844
16768.797463 -48.233 -89.1602
16769.529885 -57.705 2.9609
16770.262307 -52.430 -124.2500
16770.994729 -46.818 -65.2461
16771.727150 -49.227 -48.4375
16772.459572 -51.805 -70.9844
16773.191994 -52.815 -106.6562
16773.924416 -48.314 -79.8359
16774.656838 -48.832 -95.6562
16775.389260 -56.777 -63.8047
16776.121681 -50.165 -143.1523
16776.854103 -49.638 -134.6992
16777.586525 -57.389 -103.7812
16778.318947 -49.987 -156.2812
16779.051369 -57.398 161.6016
16779.783790 -64.830 -105.7109
16780.516212 -53.252 -160.4805
16781.248634 -51.265 171.0039
16781.981056 -46.422 151.5430
16782.713478 -50.108 -158.5586
16783.445899 -48.322 162.9727
16784.178321 -53.968 -178.8281
16784.910743 -46.735 145.2969
16785.643165 -53.039 138.2617
16786.375587 -49.367 -158.3008
16787.108009 -56.250 152.7383
16787.840430 -49.079 122.0977
16788.572852 -56.312 -179.8789
16789.305274 -57.646 119.7461
16790.037696 -43.406 126.7148
16790.770118 -48.897 96.8047
16791.502539 -49.426 78.3047
16792.234961 -51.799 97.1992
16792.967383 -49.203 95.2812
16793.699805 -43.905 97.4414
16794.432227 -50.491 109.1758
16795.164649 -44.529 76.8477
16795.897070 -50.139 61.4023
16796.629492 -50.422 82.6836
16797.361914 -52.538 63.4766
16798.094336 -56.360 111.2852
16798.826758 -44.746 62.5781
16799.559179 -45.994 91.9883
16800.291601 -52.157 78.8242
16801.024023 -49.667 80.5312
16801.756445 -45.199 80.9453
16802.488867 -45.676 59.0703
16803.221289 -44.099 42.7461
16803.953710 -45.680 43.4844
16804.686132 -47.155 39.3320
16805.418554 -48.070 88.7617
16806.150976 -52.226 25.7539
16806.883398 -48.302 25.0117
16807.615819 -60.435 -106.2773
16808.348241 -52.293 3.8711
16809.080663 -46.567 10.9531
16809.813085 -46.061 26.6406
16810.545507 -49.027 -37.7539
16811.277928 -49.148 83.7109
16812.010350 -52.894 -38.9883
16812.742772 -53.162 10.6172
16813.475194 -50.603 -25.6602
16814.207616 -54.892 28.0703
16814.940038 -43.659 8.6836
16815.672459 -48.496 -0.8281
16816.404881 -50.271 36.4141
16817.137303 -54.412 -171.5703
16817.869725 -46.661 91.2656
16818.602147 -44.502 38.5781
16819.334568 -48.902 -9.6758
16820.066990 -59.512 48.5273
16820.799412 -55.598 31.7734
16821.531834 -44.174 -33.2852
16822.264256 -42.454 -15.6914
16822.996678 -45.809 12.3242
16823.729099 -49.560 -45.3359
16824.461521 -47.279 -54.6641
16825.193943 -41.655 16.4531
16825.926365 -42.694 -40.2461
16826.658787 -44.073 -51.5430
16827.391208 -50.066 -3.8516
16828.123630 -48.181 -54.2891
16828.856052 -43.252 -65.1680
16829.588474 -45.373 -63.9297
16830.320896 -41.699 -75.3164
16831.053317 -43.549 -57.9961
16831.785739 -47.594 -70.1992
16832.518161 -42.144 -95.4023
16833.250583 -44.784 -104.5625
16833.983005 -42.301 -105.4844
16834.715427 -45.285 -117.1094
16835.447848 -42.931 -137.4062
16836.180270 -42.414 -94.0039
16836.912692 -48.274 -171.9492
16837.645114 -45.616 -92.7422
16838.377536 -44.732 -129.2969
16839.109957 -41.462 -119.5078
16839.842379 -44.343 -138.0898
16840.574801 -45.199 -140.1016
16841.307223 -40.521 177.0273
16842.039645 -44.023 -154.5742
16842.772067 -40.158 -152.6250
16843.504488 -42.887 159.2539
16844.236910 -41.400 -159.0078
16844.969332 -46.168 144.0938
16845.701754 -43.389 163.8711
16846.434176 -45.190 128.1719
16847.166597 -42.304 154.9141
16847.899019 -43.308 141.6562
16848.631441 -52.422 128.6914
16849.363863 -45.389 130.5859
16850.096285 -48.751 143.7773
16850.828707 -44.621 140.4258
16851.561128 -46.478 168.8398
16852.293550 -40.561 121.4531
16853.025972 -44.101 138.7422
16853.758394 -57.693 164.4609
16854.490816 -50.689 118.4570
16855.223237 -41.828 75.6758
16855.955659 -51.952 93.7578
16856.688081 -46.310 90.9961
16857.420503 -49.629 83.8477
16858.152925 -46.249 70.2578
16858.885346 -46.713 87.0156
16859.617768 -47.834 102.9688
16860.350190 -43.636 75.6562
16861.082612 -49.743 58.6953
16861.815034 -55.777 75.2617
16862.547456 -49.388 61.9297
16863.279877 -45.038 63.3906
16864.012299 -41.186 53.5547
16864.744721 -54.389 -7.3555
16865.477143 -46.072 29.4023
16866.209565 -48.347 -132.5156
16866.941986 -44.781 24.4141
16867.674408 -51.438 36.6719
16868.406830 -52.209 25.8750
16869.139252 -59.067 -147.1406
16869.871674 -44.220 32.1133
16870.604096 -48.767 76.5820
16871.336517 -49.706 -20.7070
16872.068939 -47.005 30.6836
16872.801361 -47.421 13.4570
16873.533783 -46.212 -176.5664
16874.266205 -54.485 -29.2031
16874.998626 -55.490 1.0352
16875.731048 -49.055 17.0156
16876.463470 -53.500 15.0000
16877.195892 -60.395 -148.5430
16877.928314 -59.825 116.4492
16878.660735 -49.182 10.6602
16879.393157 -55.477 -163.6797
16880.125579 -49.384 56.9883
16880.858001 -50.616 100.9766
16881.590423 -55.041 84.4453
16882.322845 -56.282 -37.1133
16883.055266 -47.488 94.2305
16883.787688 -54.743 55.7891
16884.520110 -55.986 35.8164
16885.252532 -48.646 122.6719
16885.984954 -53.908 80.6758
16886.717375 -50.748 93.9336
16887.449797 -44.252 65.7031
16888.182219 -41.379 65.7344
16888.914641 -46.594 95.3945
16889.647063 -45.808 52.6680
16890.379485 -44.300 41.1680
16891.111906 -43.517 69.1680
16891.844328 -42.675 46.2422
16892.576750 -45.189 4.7891
16893.309172 -44.436 10.0352
16894.041594 -38.965 20.7031
16894.774015 -43.755 34.0898
16895.506437 -42.097 -3.1562
16896.238859 -40.000 11.7383
16896.971281 -42.387 -3.0625
16897.703703 -44.541 1.0273
16898.436125 -47.361 3.3984
16899.168546 -41.357 -29.7969
16899.900968 -42.691 -24.1523
16900.633390 -46.610 -25.5117
16901.365812 -43.133 -43.8906
16902.098234 -40.233 -39.4414
16902.830655 -44.168 -63.6758
16903.563077 -45.408 -99.1055
16904.295499 -44.564 -62.7734
16905.027921 -40.024 -82.8867
16905.760343 -45.661 -102.0859
16906.492764 -48.796 -146.3086
16907.225186 -50.181 -162.1680
16907.957608 -46.089 -118.2773
16908.690030 -45.520 -132.8359
16909.422452 -43.949 -153.9922
16910.154874 -43.645 -176.6250
16910.887295 -48.026 -156.4180
16911.619717 -42.055 -167.8945
16912.352139 -38.580 165.3086
16913.084561 -38.282 151.9688
16913.816983 -41.345 166.6523
16914.549404 -41.376 143.4609
16915.281826 -39.557 134.2578
16916.014248 -39.023 122.1719
16916.746670 -44.563 108.6289
16917.479092 -41.309 104.3242
16918.211514 -38.260 97.6523
16918.943935 -40.912 104.6250
16919.676357 -40.990 83.9453
16920.408779 -37.893 80.1992
16921.141201 -37.077 78.3633
16921.873623 -39.352 77.9492
16922.606044 -37.202 56.4844
16923.338466 -35.795 35.8047
16924.070888 -35.624 59.3320
16924.803310 -36.339 56.0273
16925.535732 -37.325 18.0938
16926.268153 -36.868 40.3125
16927.000575 -36.492 26.0039
16927.732997 -38.797 24.2969
16928.465419 -38.388 16.1641
16929.197841 -39.509 -7.8242
16929.930263 -36.004 10.8125
16930.662684 -37.545 5.3594
16931.395106 -38.400 -0.2188
16932.127528 -37.363 0.3398
16932.859950 -36.336 -5.1602
16933.592372 -40.348 -12.4219
16934.324793 -38.901 -20.1406
16935.057215 -37.472 -33.9688
16935.789637 -38.483 -14.7852
16936.522059 -37.488 -16.8320
16937.254481 -38.519 -35.8281
16937.986903 -38.740 -15.3281
16938.719324 -39.291 -28.7773
16939.451746 -39.446 -49.4727
16940.184168 -39.223 -56.2656
16940.916590 -39.969 -39.9102
16941.649012 -39.787 -36.1836
16942.381433 -38.241 -44.4219
16943.113855 -38.444 -59.9648
16943.846277 -39.640 -37.8867
16944.578699 -41.051 -47.2383
16945.311121 -40.722 -57.5430
16946.043543 -38.282 -55.7461
16946.775964 -40.542 -58.3281
16947.508386 -40.976 -42.0508
16948.240808 -43.664 -61.9883
16948.973230 -40.152 -77.8438
16949.705652 -42.229 -71.5391
16950.438073 -40.912 -76.8203
16951.170495 -42.529 -89.4609
16951.902917 -41.961 -83.7422
16952.635339 -44.017 -127.6016
16953.367761 -43.539 -86.3203
16954.100182 -47.361 -100.3828
16954.832604 -43.948 -98.9648
16955.565026 -44.643 -105.0859
16956.297448 -49.374 -72.8984
16957.029870 -45.038 -109.0234
16957.762292 -45.216 -121.7500
16958.494713 -49.032 -91.2695
16959.227135 -49.756 -81.0039
16959.959557 -53.019 8.9141
16960.691979 -43.571 -108.6992
16961.424401 -48.412 -85.1406
16962.156822 -53.966 -60.3828
16962.889244 -46.859 -41.7305
16963.621666 -46.614 -89.6719
16964.354088 -50.631 -66.0820
16965.086510 -52.040 -19.6445
16965.818932 -49.214 -73.9297
16966.551353 -50.710 -71.9141
16967.283775 -48.261 -40.1992
16968.016197 -47.204 -42.5391
16968.748619 -51.359 -77.2578
16969.481041 -53.758 -74.3086
16970.213462 -57.373 -109.0703
16970.945884 -45.077 -66.8711
16971.678306 -48.622 -44.6094
16972.410728 -48.140 -105.1328
16973.143150 -46.514 -66.7109
16973.875571 -45.038 -74.3672
16974.607993 -50.434 -72.3398
16975.340415 -50.867 -105.8359
16976.072837 -54.129 -106.0195
16976.805259 -44.177 -76.6602
16977.537681 -51.604 -51.0664
16978.270102 -47.361 -75.4141
16979.002524 -46.642 -84.0391
16979.734946 -46.271 -68.5820
16980.467368 -57.577 -51.2969
16981.199790 -50.532 -70.2109
16981.932211 -52.224 -82.6367
16982.664633 -44.022 -75.0547
16983.397055 -45.215 -58.0820
16984.129477 -49.549 -110.0898
16984.861899 -42.752 -75.4805
16985.594321 -43.225 -73.2773
16986.326742 -45.637 -96.7461
16987.059164 -43.971 -94.0352
16987.791586 -46.106 -76.7734
16988.524008 -40.781 -80.8555
16989.256430 -44.730 -87.4727
16989.988851 -39.877 -95.6094
16990.721273 -41.547 -92.2148
16991.453695 -42.169 -92.5938
16992.186117 -42.637 -105.0742
16992.918539 -44.315 -121.8867
16993.650961 -43.612 -115.3555
16994.383382 -40.069 -118.0859
16995.115804 -40.674 -126.3281
16995.848226 -40.402 -141.6562
16996.580648 -42.020 -132.9414
16997.313070 -43.019 -135.6016
16998.045491 -41.862 -161.9297
16998.777913 -41.338 -162.7812
16999.510335 -41.189 -150.5586
17000.242757 -39.847 -148.7422
17000.975179 -39.995 -153.4414
17001.707600 -39.725 -157.8789
17002.440022 -39.220 179.8438
17003.172444 -46.030 -168.6211
17003.904866 -43.098 178.8828
17004.637288 -41.516 -171.4336
17005.369710 -42.986 162.4258
17006.102131 -43.154 165.4531
17006.834553 -45.272 -166.8516
17007.566975 -40.711 148.2930
17008.299397 -47.377 131.7500
17009.031819 -45.625 143.8281
17009.764240 -48.426 141.2891
17010.496662 -45.735 127.8008
17011.229084 -43.673 102.0586
17011.961506 -47.305 106.7695
17012.693928 -51.329 98.2812
17013.426350 -50.092 116.1758
17014.158771 -46.552 67.2188
17014.891193 -55.171 -107.2383
17015.623615 -49.669 54.0938
17016.356037 -63.154 -5.0234
17017.088459 -46.035 1.8867
17017.820880 -48.267 -10.0195
17018.553302 -50.192 -84.5117
17019.285724 -56.045 39.1016
17020.018146 -56.067 -157.6055
17020.750568 -59.539 -12.1758
17021.482989 -62.186 -24.0508
17022.215411 -57.275 -66.5156
17022.947833 -43.566 -57.3555
17023.680255 -53.257 -139.2109
17024.412677 -48.757 -121.4688
17025.145099 -45.541 -148.4844
17025.877520 -47.943 -159.8594
17026.609942 -45.793 -136.2734
17027.342364 -45.558 -63.9219
17028.074786 -46.453 -143.0938
17028.807208 -47.975 -108.9570
17029.539629 -49.724 173.5742
17030.272051 -49.642 -172.3398
17031.004473 -43.595 -166.7305
17031.736895 -43.609 -167.7188
17032.469317 -44.458 170.0781
17033.201739 -46.998 -164.0742
17033.934160 -45.322 173.5234
17034.666582 -49.669 130.3125
17035.399004 -41.691 -170.4805
17036.131426 -42.461 154.6602
17036.863848 -38.661 140.8008
17037.596269 -41.072 145.5469
17038.328691 -42.478 146.0078
17039.061113 -42.344 129.5391
17039.793535 -38.650 125.2461
17040.525957 -41.728 138.1719
17041.258379 -40.717 132.4766
17041.990800 -42.458 115.7266
17042.723222 -39.548 112.8203
17043.455644 -40.835 114.0430
17044.188066 -41.411 105.9688
17044.920488 -42.865 84.2539
17045.652909 -43.019 97.2812
17046.385331 -44.263 64.5352
17047.117753 -39.346 92.3867
17047.850175 -41.505 86.2695
17048.582597 -41.500 85.7891
17049.315018 -41.906 55.9648
17050.047440 -44.813 48.0664
17050.779862 -43.838 46.5898
17051.512284 -42.675 42.8789
17052.244706 -42.816 34.5273
17052.977128 -42.027 35.2812
17053.709549 -44.375 2.5781
17054.441971 -38.708 26.1328
17055.174393 -39.934 -5.3633
17055.906815 -41.667 11.5195
17056.639237 -54.198 -7.0469
17057.371658 -55.620 45.2930
17058.104080 -46.216 -44.2266
17058.836502 -52.093 -61.8672
17059.568924 -46.868 -29.8984
17060.301346 -51.255 -14.1562
17061.033768 -46.963 -61.7188
17061.766189 -51.492 -46.9453
17062.498611 -48.929 -48.0000
17063.231033 -56.952 -53.0898
17063.963455 -45.175 -75.7812
17064.695877 -50.527 -36.4336
17065.428298 -55.552 -33.5586
17066.160720 -62.053 18.7422
17066.893142 -54.556 -166.9766
17067.625564 -52.414 29.2500
17068.357986 -56.163 -3.1289
17069.090407 -49.099 -5.9688
17069.822829 -51.666 -39.6562
17070.555251 -56.215 1.2383
17071.287673 -57.682 32.7422
17072.020095 -49.285 33.7891
17072.752517 -50.384 -26.9219
17073.484938 -48.678 21.9414
17074.217360 -48.238 -34.7734
17074.949782 -49.599 -27.8086
17075.682204 -54.382 -50.1289
17076.414626 -46.832 -24.0312
17077.147047 -47.987 -52.7734
17077.879469 -50.246 1.3711
17078.611891 -46.601 -24.8555
17079.344313 -48.973 -85.3945
17080.076735 -53.977 -67.3555
17080.809157 -53.038 -27.3242
17081.541578 -46.692 -67.6562
17082.274000 -63.284 -80.1562
17083.006422 -50.482 -97.8398
17083.738844 -49.905 -0.2031
17084.471266 -54.103 -112.1719
17085.203687 -49.580 -84.3242
17085.936109 -46.128 -102.7461
17086.668531 -51.681 -50.0664
17087.400953 -46.223 -80.1133
17088.133375 -51.653 -53.5352
17088.865797 -47.639 -85.9844
17089.598218 -53.571 -106.0352
17090.330640 -46.230 -82.4102
17091.063062 -44.644 -106.8789
17091.795484 -41.954 -88.3594
17092.527906 -51.946 -46.5312
17093.260327 -45.617 -86.9297
17093.992749 -50.124 -79.0977
17094.725171 -45.603 -60.3008
17095.457593 -45.586 -27.7734
17096.190015 -46.940 -97.8320
17096.922436 -51.127 -147.1055
17097.654858 -44.496 -97.1484
17098.387280 -48.282 -53.6055
17099.119702 -50.022 -97.6719
17099.852124 -46.470 -101.0117
17100.584546 -47.291 -117.1992
17101.316967 -46.076 -89.3633
17102.049389 -48.034 -139.5195
17102.781811 -43.900 -94.1523
17103.514233 -46.905 -115.9961
17104.246655 -53.490 -96.3125
17104.979076 -43.035 -112.7344
17105.711498 -47.696 -140.0859
17106.443920 -45.966 -106.4961
17107.176342 -51.378 -134.8945
17107.908764 -43.466 -152.9531
17108.641186 -57.442 -145.1719
17109.373607 -43.976 -135.6406
17110.106029 -55.112 -104.8867
17110.838451 -41.869 -149.2695
17111.570873 -45.546 -153.8789
17112.303295 -43.732 -155.6562
17113.035716 -43.994 -137.1797
17113.768138 -46.043 -137.5938
17114.500560 -44.659 -122.3477
17115.232982 -44.528 -143.1992
17115.965404 -43.949 -135.0195
17116.697825 -43.622 -136.2812
17117.430247 -42.706 -141.8516
17118.162669 -44.413 -151.1641
17118.895091 -45.090 -110.3320
17119.627513 -41.375 -152.5586
17120.359935 -45.356 -115.5156
17121.092356 -40.463 -143.5586
17121.824778 -41.894 -154.7617
17122.557200 -41.745 -163.0586
17123.289622 -39.166 -170.6992
17124.022044 -41.350 -168.5195
17124.754465 -43.272 -153.0938
17125.486887 -41.971 -158.3242
17126.219309 -39.255 168.4180
17126.951731 -39.477 164.3672
17127.684153 -41.703 152.3164
17128.416575 -37.212 172.0000
17129.148996 -40.588 141.4141
17129.881418 -40.211 140.9844
17130.613840 -44.700 170.9453
17131.346262 -39.898 138.6211
17132.078684 -42.779 143.7773
17132.811105 -40.036 133.5430
17133.543527 -44.153 129.3438
17134.275949 -41.881 120.6250
17135.008371 -43.178 101.2109
17135.740793 -42.322 103.5352
17136.473215 -41.851 95.5156
17137.205636 -40.497 84.0312
17137.938058 -41.613 90.7500
17138.670480 -42.281 91.2344
17139.402902 -39.383 57.5430
17140.135324 -41.574 58.6094
17140.867745 -44.213 33.5078
17141.600167 -41.801 44.2930
17142.332589 -42.835 9.9727
17143.065011 -40.312 20.9414
17143.797433 -42.868 27.2461
17144.529854 -44.550 10.1211
17145.262276 -41.859 -17.8789
17145.994698 -44.629 -0.8477
17146.727120 -44.662 -12.2461
17147.459542 -42.916 -1.5586
17148.191964 -44.100 -22.8086
17148.924385 -43.066 -33.8906
17149.656807 -49.112 -43.8750
17150.389229 -40.334 -55.3281
17151.121651 -38.451 -44.9688
17151.854073 -45.530 -68.8008
17152.586494 -42.255 -78.5781
17153.318916 -45.442 -115.4648
17154.051338 -39.602 -97.7422
17154.783760 -45.533 -101.6289
17155.516182 -43.631 -118.9414
17156.248604 -43.212 -126.0078
17156.981025 -41.038 -109.7148
17157.713447 -44.847 -134.6133
17158.445869 -43.868 -146.1758
17159.178291 -42.227 -161.1797
17159.910713 -42.308 -150.8359
17160.643134 -43.978 -174.3984
17161.375556 -44.346 170.5430
17162.107978 -43.457 158.1953
17162.840400 -45.098 168.3867
17163.572822 -42.693 178.2305
17164.305243 -42.873 142.8555
17165.037665 -43.764 170.4688
17165.770087 -43.558 158.6055
17166.502509 -48.959 140.2734
17167.234931 -44.788 151.2461
17167.967353 -47.312 133.9414
17168.699774 -54.364 90.5039
17169.432196 -47.538 153.3750
17170.164618 -47.341 109.8008
17170.897040 -49.560 121.8242
17171.629462 -57.249 91.7305
17172.361883 -53.319 -28.4609
17173.094305 -55.479 110.4414
17173.826727 -58.817 -33.2539
17174.559149 -47.241 -108.5078
17175.291571 -57.314 -149.2539
17176.023993 -49.962 -130.8398
17176.756414 -50.655 -90.2344
17177.488836 -48.115 -147.1758
17178.221258 -51.997 -169.0703
17178.953680 -47.842 -146.7227
17179.686102 -43.092 172.6797
17180.418523 -51.644 174.5078
17181.150945 -45.128 -169.6797
17181.883367 -45.850 158.8594
17182.615789 -44.380 163.1562
17183.348211 -45.373 143.4102
17184.080633 -42.191 137.9453
17184.813054 -43.122 140.9844
17185.545476 -40.889 139.5547
17186.277898 -44.168 121.0742
17187.010320 -40.258 142.4922
17187.742742 -42.862 101.1836
17188.475163 -39.862 98.0977
17189.207585 -40.388 118.2383
17189.940007 -37.000 76.2734
17190.672429 -41.234 100.0820
17191.404851 -43.853 93.1484
17192.137272 -41.624 91.8047
17192.869694 -42.165 56.1406
17193.602116 -41.949 87.8477
17194.334538 -40.257 53.6914
17195.066960 -47.531 39.6680
17195.799382 -39.831 2.2695
17196.531803 -41.780 19.1328
17197.264225 -42.638 4.4023
17197.996647 -44.579 -15.2148
17198.729069 -44.923 31.1055
17199.461491 -40.794 -11.4102
17200.193912 -44.531 -36.7148
17200.926334 -56.787 16.6016
17201.658756 -41.938 -39.0625
17202.391178 -46.566 -38.6914
17203.123600 -58.978 56.0547
17203.856022 -41.315 -101.4375
17204.588443 -61.899 -78.2031
17205.320865 -49.831 -74.0586
17206.053287 -44.255 -119.4922
17206.785709 -46.775 -139.6758
17207.518131 -53.629 -154.0781
17208.250552 -53.095 -137.5977
17208.982974 -49.778 113.0547
17209.715396 -48.633 -156.8125
17210.447818 -48.355 159.8086
17211.180240 -42.808 88.4219
17211.912661 -45.824 154.4766
17212.645083 -41.725 132.7070
17213.377505 -44.875 131.5117
17214.109927 -38.991 139.9609
17214.842349 -40.005 122.5977
17215.574771 -50.219 74.0586
17216.307192 -41.085 117.9922
17217.039614 -43.266 75.6641
17217.772036 -42.235 95.7578
17218.504458 -40.862 104.2188
17219.236880 -37.830 74.6875
17219.969301 -39.996 111.6211
17220.701723 -42.113 99.2266
17221.434145 -39.075 120.0000
17222.166567 -43.787 43.5430
17222.898989 -39.146 80.1211
17223.631411 -42.191 70.0586
17224.363832 -36.679 43.5781
17225.096254 -39.204 57.6406
17225.828676 -42.726 84.9844
17226.561098 -43.751 76.9805
17227.293520 -40.330 58.0156
17228.025941 -40.629 44.7656
17228.758363 -40.408 62.0859
17229.490785 -42.494 76.2188
17230.223207 -49.573 37.8438
17230.955629 -49.419 15.1680
17231.688051 -43.581 18.0469
17232.420472 -45.619 47.5352
17233.152894 -44.315 37.4805
17233.885316 -44.107 22.5820
17234.617738 -43.351 24.6094
17235.350160 -53.511 -99.5898
17236.082581 -42.476 53.4180
17236.815003 -51.298 17.5664
17237.547425 -41.864 20.4414
17238.279847 -42.494 46.8203
17239.012269 -47.774 23.9688
17239.744690 -43.228 45.6523
17240.477112 -41.169 12.7070
17241.209534 -47.326 -75.0117
17241.941956 -44.172 10.2852
17242.674378 -48.918 -58.3398
17243.406800 -40.395 -15.9453
17244.139221 -44.891 -14.6875
17244.871643 -47.024 118.1445
17245.604065 -43.612 31.6992
17246.336487 -51.574 -12.8164
17247.068909 -43.537 10.6016
17247.801330 -44.051 21.5742
17248.533752 -47.200 17.3438
17249.266174 -40.866 23.8164
17249.998596 -46.691 40.0898
17250.731018 -46.428 73.3828
17251.463440 -41.214 58.3477
17252.195861 -51.492 72.1562
17252.928283 -41.473 29.7070
17253.660705 -56.736 -25.5156
17254.393127 -45.199 8.8789
17255.125549 -51.184 40.4609
17255.857970 -43.212 -9.9531
17256.590392 -41.282 -3.6602
17257.322814 -44.260 34.0938
17258.055236 -42.514 -21.3008
17258.787658 -43.424 21.2656
17259.520079 -43.632 -0.6602
17260.252501 -48.605 -32.6992
17260.984923 -42.487 -0.6797
17261.717345 -47.046 -24.7305
17262.449767 -46.565 -65.5312
17263.182189 -54.258 -48.1016
17263.914610 -46.794 -48.0508
17264.647032 -52.174 -59.3984
17265.379454 -47.028 -54.5703
17266.111876 -56.463 -53.6992
17266.844298 -49.223 -75.3359
17267.576719 -45.480 -54.3008
17268.309141 -45.667 45.2344
17269.041563 -46.298 -114.4258
17269.773985 -51.069 -60.8008
17270.506407 -52.728 -49.8594
17271.238829 -49.779 -80.8398
17271.971250 -45.791 -38.2617
17272.703672 -55.725 -153.2109
17273.436094 -52.423 -143.2422
17274.168516 -45.389 -130.4961
17274.900938 -53.772 -76.8008
17275.633359 -55.099 -22.2539
17276.365781 -52.483 -124.3086
17277.098203 -54.523 68.5625
17277.830625 -51.643 51.2734
17278.563047 -50.699 -133.0352
17279.295469 -60.086 -88.0508
17280.027890 -47.445 32.3242
17280.760312 -49.843 7.6172
17281.492734 -50.249 124.1797
17282.225156 -51.085 74.8477
17282.957578 -44.686 26.7422
17283.689999 -56.697 16.9062
17284.422421 -46.348 10.3945
17285.154843 -39.538 16.6914
17285.887265 -41.744 3.1836
17286.619687 -46.420 30.4453
17287.352108 -44.639 -6.9492
17288.084530 -41.980 -24.3047
17288.816952 -41.687 8.9180
17289.549374 -39.380 -13.5391
17290.281796 -42.225 -34.4180
17291.014218 -40.329 -23.2500
17291.746639 -39.433 -22.0703
17292.479061 -39.953 -48.9258
17293.211483 -40.447 -58.4648
17293.943905 -38.810 -77.9883
17294.676327 -37.754 -46.0859
17295.408748 -39.658 -64.1523
17296.141170 -37.371 -51.6836
17296.873592 -39.175 -69.6758
17297.606014 -40.549 -67.9180
17298.338436 -41.109 -50.6523
17299.070858 -39.262 -75.1016
17299.803279 -42.160 -91.5234
17300.535701 -42.322 -92.0859
17301.268123 -40.714 -112.7227
17302.000545 -39.754 -105.4492
17302.732967 -41.366 -86.0312
17303.465388 -42.965 -114.7500
17304.197810 -44.566 -67.5195
17304.930232 -40.978 -125.2070
17305.662654 -44.954 -116.1680
17306.395076 -45.322 -129.5039
17307.127497 -43.549 -148.4766
17307.859919 -44.075 -118.2617
17308.592341 -48.796 -116.7617
17309.324763 -52.776 89.0547
17310.057185 -44.710 -150.3906
17310.789607 -48.710 -148.2734
17311.522028 -46.338 -169.7109
17312.254450 -52.813 129.2930
17312.986872 -55.959 105.8945
17313.719294 -54.098 135.1680
17314.451716 -61.870 -117.6758
17315.184137 -57.513 -7.6602
17315.916559 -53.239 -25.7812
17316.648981 -52.057 119.9180
17317.381403 -59.222 105.8477
17318.113825 -47.685 -79.2500
17318.846247 -46.721 -40.2070
17319.578668 -54.670 -12.9258
17320.311090 -48.044 -27.5352
17321.043512 -52.914 10.8594
17321.775934 -49.149 -14.8828
17322.508356 -49.089 -51.9844
17323.240777 -54.103 40.6016
17323.973199 -50.231 -48.3438
17324.705621 -44.846 -73.5664
17325.438043 -55.673 -37.4414
17326.170465 -47.415 -77.0469
17326.902887 -52.091 -98.0352
17327.635308 -48.424 -100.1367
17328.367730 -49.823 -99.3203
17329.100152 -45.712 -60.3867
17329.832574 -46.418 -76.4805
17330.564996 -42.737 -102.2422
17331.297417 -46.437 -127.9531
17332.029839 -45.809 -105.5547
17332.762261 -47.868 -114.4531
17333.494683 -42.819 -119.0742
17334.227105 -43.335 -129.4062
17334.959526 -45.710 -124.3281
17335.691948 -47.798 -134.4062
17336.424370 -40.448 -122.4336
17337.156792 -43.555 -132.7383
17337.889214 -42.135 -136.6406
17338.621636 -46.664 -143.8633
17339.354057 -49.041 -169.3398
17340.086479 -46.051 -166.8359
17340.818901 -43.906 158.2500
17341.551323 -44.480 178.2539
17342.283745 -47.089 -155.9023
17343.016166 -43.389 166.1875
17343.748588 -55.131 153.0000
17344.481010 -60.167 149.6680
17345.213432 -57.217 55.4375
17345.945854 -52.297 111.5781
17346.678276 -48.427 52.5352
17347.410697 -52.706 103.4844
17348.143119 -55.902 35.9570
17348.875541 -53.275 -10.4102
17349.607963 -53.198 8.2500
17350.340385 -48.112 23.8711
17351.072806 -45.951 -50.6094
17351.805228 -43.486 -5.2734
17352.537650 -43.846 -23.9219
17353.270072 -44.205 -25.3008
17354.002494 -44.457 -61.4531
17354.734915 -43.560 -48.1562
17355.467337 -41.248 -62.0273
17356.199759 -41.487 -49.3008
17356.932181 -40.235 -57.8984
17357.664603 -39.063 -71.0195
17358.397025 -38.747 -66.0391
17359.129446 -39.690 -74.0039
17359.861868 -38.039 -85.9180
17360.594290 -39.044 -84.4062
17361.326712 -40.836 -94.7461
17362.059134 -40.168 -106.6133
17362.791555 -38.368 -96.1484
17363.523977 -40.014 -108.5898
17364.256399 -40.412 -117.0117
17364.988821 -37.449 -122.6484
17365.721243 -37.795 -133.8438
17366.453665 -39.719 -120.7227
17367.186086 -37.931 -130.3164
17367.918508 -40.333 -141.2109
17368.650930 -38.262 -148.8438
17369.383352 -38.677 -156.6016
17370.115774 -41.699 -142.4414
17370.848195 -40.389 -170.1523
17371.580617 -37.725 -160.5078
17372.313039 -39.910 178.2148
17373.045461 -40.052 176.6094
17373.777883 -42.593 170.7852
17374.510305 -41.326 178.7344
17375.242726 -40.835 177.8906
17375.975148 -43.680 153.8828
17376.707570 -43.616 151.3672
17377.439992 -42.151 132.9219
17378.172414 -44.336 141.2930
17378.904835 -45.569 144.1523
17379.637257 -46.162 115.8008
17380.369679 -46.877 127.2852
17381.102101 -48.128 126.4688
17381.834523 -51.818 105.3594
17382.566944 -47.638 81.7695
17383.299366 -45.087 143.1836
17384.031788 -45.710 66.9805
17384.764210 -52.915 85.7734
17385.496632 -57.833 -11.3672
17386.229054 -49.242 -14.8320
17386.961475 -51.616 -38.2930
17387.693897 -48.163 -1.5664
17388.426319 -48.045 -32.8555
17389.158741 -55.973 -82.0859
17389.891163 -46.399 -48.5898
17390.623584 -43.078 -92.2461
17391.356006 -41.183 -101.9414
17392.088428 -42.990 -113.6328
17392.820850 -43.805 -116.0703
17393.553272 -42.432 -91.8047
17394.285694 -43.679 -100.7852
17395.018115 -41.510 -128.5781
17395.750537 -41.149 -138.9727
17396.482959 -41.161 -148.0938
17397.215381 -43.030 -130.5156
17397.947803 -42.065 -159.7812
17398.680224 -42.419 -137.7734
17399.412646 -42.338 -138.0820
17400.145068 -39.217 -144.6680
17400.877490 -42.125 -164.3828
17401.609912 -40.918 -145.0820
17402.342333 -40.334 -175.2930
17403.074755 -44.188 -168.3945
17403.807177 -43.246 -166.9688
17404.539599 -40.032 -169.9492
17405.272021 -42.042 -178.4688
17406.004443 -42.120 -175.3516
17406.736864 -40.133 170.2891
17407.469286 -42.602 174.3867
17408.201708 -41.215 159.7422
17408.934130 -44.880 -162.5469
17409.666552 -43.654 -170.8047
17410.398973 -49.278 -171.2656
17411.131395 -45.106 178.2812
17411.863817 -42.845 150.9297
17412.596239 -41.480 -176.0195
17413.328661 -42.993 -160.9219
17414.061083 -43.644 -169.7344
17414.793504 -42.932 -152.6055
17415.525926 -43.562 -164.3320
17416.258348 -44.448 -162.0742
17416.990770 -42.762 -162.3555
17417.723192 -41.425 -159.4766
17418.455613 -40.914 170.0391
17419.188035 -41.360 178.9961
17419.920457 -41.552 168.5781
17420.652879 -42.329 -165.4141
17421.385301 -39.874 179.7500
17422.117723 -39.896 169.3281
17422.850144 -39.831 164.5469
17423.582566 -38.202 162.1172
17424.314988 -40.404 141.8086
17425.047410 -39.270 162.3125
17425.779832 -36.305 163.0898
17426.512253 -37.495 152.1172
17427.244675 -37.970 152.0234
17427.977097 -38.151 136.9414
17428.709519 -39.887 154.3398
17429.441941 -38.298 143.2812
17430.174362 -36.725 108.9570
17430.906784 -38.484 129.0625
17431.639206 -37.646 116.5781
17432.371628 -37.118 128.5039
17433.104050 -38.983 120.3281
17433.836472 -40.932 98.5469
17434.568893 -41.755 113.9180
17435.301315 -38.723 101.6328
17436.033737 -38.713 94.2773
17436.766159 -41.107 98.4609
17437.498581 -39.463 98.4805
17438.231002 -39.273 102.7500
17438.963424 -39.448 85.8789
17439.695846 -39.450 69.5820
17440.428268 -43.215 77.3086
17441.160690 -42.644 73.5781
17441.893112 -39.685 59.5664
17442.625533 -41.469 70.6250
17443.357955 -41.787 51.2539
17444.090377 -43.996 63.8125
17444.822799 -40.885 34.0508
17445.555221 -42.719 48.8359
17446.287642 -46.888 62.5898
17447.020064 -43.003 51.1914
17447.752486 -42.369 23.0703
17448.484908 -47.436 34.0820
17449.217330 -44.499 35.1289
17449.949751 -49.207 46.0859
17450.682173 -47.861 -0.4648
17451.414595 -52.448 26.6992
17452.147017 -53.088 -32.1211
17452.879439 -49.331 -44.0195
17453.611861 -53.550 -23.2539
17454.344282 -50.832 -45.8867
17455.076704 -50.816 -56.7578
17455.809126 -48.270 -108.3164
17456.541548 -51.862 -121.2422
17457.273970 -46.917 -126.0430
17458.006391 -48.136 -127.7461
17458.738813 -45.573 -177.3281
17459.471235 -47.112 -161.0703
17460.203657 -44.847 -149.6680
17460.936079 -43.817 -173.0781
17461.668501 -39.963 -173.6211
17462.400922 -43.642 175.1953
17463.133344 -43.651 169.8047
17463.865766 -39.079 156.0820
17464.598188 -40.233 155.3945
17465.330610 -41.096 131.1094
17466.063031 -41.498 131.1484
17466.795453 -41.581 120.9453
17467.527875 -39.426 140.1406
17468.260297 -40.216 121.7031
17468.992719 -40.532 97.3984
17469.725141 -39.993 108.1367
17470.457562 -38.289 105.7031
17471.189984 -40.169 103.6758
17471.922406 -38.862 90.4727
17472.654828 -37.136 85.5195
17473.387250 -36.248 83.0312
17474.119671 -39.026 71.1250
17474.852093 -38.200 64.4492
17475.584515 -38.929 66.8633
17476.316937 -39.459 64.6133
17477.049359 -37.719 39.6758
17477.781780 -40.051 34.5234
17478.514202 -38.152 35.5312
17479.246624 -38.830 40.3203
17479.979046 -39.540 34.0273
17480.711468 -41.778 17.7812
17481.443890 -40.233 16.7969
17482.176311 -39.859 13.7109
17482.908733 -40.804 11.6992
17483.641155 -39.844 -2.3008
17484.373577 -44.688 -3.5195
17485.105999 -40.971 -18.6641
17485.838420 -45.910 -51.3398
17486.570842 -43.480 -54.7773
17487.303264 -49.288 -48.5039
17488.035686 -46.138 -39.5547
17488.768108 -47.227 -86.4805
17489.500530 -47.024 -47.3906
17490.232951 -49.197 -74.7188
17490.965373 -52.202 -70.5234
17491.697795 -46.861 -86.2930
17492.430217 -49.692 -77.3750
17493.162639 -47.811 -106.2852
17493.895060 -61.263 -20.2969
17494.627482 -52.383 -74.8867
17495.359904 -56.448 -71.6680
17496.092326 -54.002 -51.1797
17496.824748 -54.128 -15.3477
17497.557169 -60.919 87.2969
17498.289591 -49.237 -36.2891
17499.022013 -54.780 41.4805
17499.754435 -74.228 1.5938
17500.486857 -57.190 -9.1406
17501.219279 -50.838 -42.8008
17501.951700 -53.728 -62.3672
17502.684122 -50.285 -60.7227
17503.416544 -44.704 -74.7070
17504.148966 -54.129 -123.4805
17504.881388 -44.948 -74.3594
17505.613809 -47.589 -75.5820
17506.346231 -49.191 -80.3906
17507.078653 -44.559 -113.1094
17507.811075 -45.045 -116.1641
17508.543497 -47.539 -118.5352
17509.275919 -45.698 -134.2617
17510.008340 -43.677 -142.8516
17510.740762 -43.060 -146.4180
17511.473184 -47.914 -168.8633
17512.205606 -45.156 -144.6992
17512.938028 -44.496 -165.5586
17513.670449 -41.742 -160.7578
17514.402871 -43.239 -177.4727
17515.135293 -43.756 -171.5352
17515.867715 -41.844 -166.4258
17516.600137 -41.391 -172.0547
17517.332559 -44.762 160.8047
17518.064980 -43.696 163.0703
17518.797402 -42.344 -171.0430
17519.529824 -49.925 160.4414
17520.262246 -47.356 159.3945
17520.994668 -46.815 140.3008
17521.727089 -45.628 144.5117
17522.459511 -45.653 142.4453
17523.191933 -56.967 125.6367
17523.924355 -54.163 152.7734
17524.656777 -45.028 148.2773
17525.389198 -47.277 157.7344
17526.121620 -47.004 153.3828
17526.854042 -45.538 137.8828
17527.586464 -43.893 131.0977
17528.318886 -45.525 120.8789
17529.051308 -43.862 135.9336
17529.783729 -47.579 106.7656
17530.516151 -42.926 148.9531
17531.248573 -43.770 127.1016
17531.980995 -44.493 116.6133
17532.713417 -43.156 119.9609
17533.445838 -40.004 132.7852
17534.178260 -41.660 105.4023
17534.910682 -40.133 90.1484
17535.643104 -41.466 93.9375
17536.375526 -39.743 103.1328
17537.107948 -39.733 102.9961
17537.840369 -39.343 80.5117
17538.572791 -39.231 89.1992
17539.305213 -39.331 83.5977
17540.037635 -39.029 61.4180
17540.770057 -37.822 69.3672
17541.502478 -39.666 61.5703
17542.234900 -38.675 71.6289
17542.967322 -38.958 46.4922
17543.699744 -38.185 32.8281
17544.432166 -38.028 36.6133
17545.164587 -39.697 32.3906
17545.897009 -38.759 21.5195
17546.629431 -36.569 17.2344
17547.361853 -38.372 3.0742
17548.094275 -38.844 4.5430
17548.826697 -39.669 16.4023
17549.559118 -37.221 5.2969
17550.291540 -40.458 -15.5352
17551.023962 -39.373 -8.4648
17551.756384 -39.743 -39.0352
17552.488806 -39.874 -18.8242
17553.221227 -38.080 -30.9375
17553.953649 -43.382 -34.9453
17554.686071 -41.058 -53.4219
17555.418493 -39.774 -41.3516
17556.150915 -40.150 -52.3203
17556.883337 -39.850 -68.4180
17557.615758 -40.676 -58.6133
17558.348180 -39.885 -72.8750
17559.080602 -41.091 -82.9766
17559.813024 -42.440 -99.6211
17560.545446 -44.943 -95.2266
17561.277867 -41.973 -69.8164
17562.010289 -40.677 -78.9062
17562.742711 -45.294 -125.5195
17563.475133 -43.561 -110.0703
17564.207555 -44.299 -94.2930
17564.939977 -44.388 -121.6875
17565.672398 -48.919 -126.2031
17566.404820 -43.379 -108.8516
17567.137242 -41.162 -74.3828
17567.869664 -42.081 -105.0977
17568.602086 -45.782 -81.4688
17569.334507 -43.607 -126.9961
17570.066929 -41.794 -114.9375
17570.799351 -40.992 -138.7031
17571.531773 -42.693 -140.1133
17572.264195 -43.674 -126.7773
17572.996616 -43.332 -125.3320
17573.729038 -41.778 -125.6797
17574.461460 -45.442 -155.2617
17575.193882 -42.781 -155.5234
17575.926304 -50.976 -145.2266
17576.658726 -36.328 -149.5195
17577.391147 -41.384 172.1133
17578.123569 -43.561 -169.3789
17578.855991 -41.948 178.7227
17579.588413 -42.002 169.0430
17580.320835 -43.871 165.1484
17581.053256 -40.637 167.9492
17581.785678 -42.410 168.1562
17582.518100 -48.934 153.6172
17583.250522 -41.711 151.5469
17583.982944 -42.159 125.4297
17584.715366 -44.015 152.1953
17585.447787 -43.290 131.2227
17586.180209 -43.257 111.5000
17586.912631 -43.877 130.3164
17587.645053 -54.724 84.6992
17588.377475 -45.653 121.9336
17589.109896 -44.869 81.0195
17589.842318 -44.066 129.4531
17590.574740 -46.382 96.8867
17591.307162 -49.251 91.1992
17592.039584 -43.275 117.0000
17592.772005 -46.329 113.6602
17593.504427 -53.910 -58.4648
17594.236849 -46.379 178.8555
17594.969271 -46.935 134.4297
17595.701693 -46.851 99.0508
17596.434115 -48.624 84.3359
17597.166536 -47.466 79.2773
17597.898958 -47.958 58.5117
17598.631380 -50.664 87.4844
17599.363802 -51.738 31.9883
17600.096224 -57.238 123.1797
17600.828645 -53.077 7.7461
17601.561067 -46.721 32.5078
17602.293489 -54.083 19.3750
17603.025911 -56.045 68.8750
17603.758333 -53.763 -52.9062
17604.490755 -49.054 -70.8984
17605.223176 -50.864 -112.8711
17605.955598 -61.435 153.4727
17606.688020 -48.668 -0.5781
17607.420442 -65.767 119.4688
17608.152864 -50.596 -149.6641
17608.885285 -42.955 -167.0391
17609.617707 -56.313 -25.2344
17610.350129 -50.454 151.3711
17611.082551 -44.243 -153.6094
17611.814973 -46.382 166.5195
17612.547395 -50.105 172.9609
17613.279816 -46.035 177.6523
17614.012238 -51.655 -165.9102
17614.744660 -42.945 151.1211
17615.477082 -45.048 170.3125
17616.209504 -47.134 136.6289
17616.941925 -46.277 165.1641
17617.674347 -42.422 156.4805
17618.406769 -46.643 100.4648
17619.139191 -45.083 101.2031
17619.871613 -44.587 128.7930
17620.604034 -43.510 115.2734
17621.336456 -43.784 100.2500
17622.068878 -45.581 109.3828
17622.801300 -55.445 130.0039
17623.533722 -41.533 105.8086
17624.266144 -51.096 59.9336
17624.998565 -48.924 90.2109
17625.730987 -59.228 85.6133
17626.463409 -51.699 68.5664
17627.195831 -58.940 47.3477
17627.928253 -53.527 173.0977
17628.660674 -55.564 172.5352
17629.393096 -45.086 162.6094
17630.125518 -53.560 82.5625
17630.857940 -50.582 140.1016
17631.590362 -49.712 159.9375
17632.322784 -45.502 157.4258
17633.055205 -56.130 116.1250
17633.787627 -45.447 143.7031
17634.520049 -40.812 177.4297
17635.252471 -41.017 133.6914
17635.984893 -46.739 144.4766
17636.717314 -40.642 150.4453
17637.449736 -42.398 133.2266
17638.182158 -39.760 131.0508
17638.914580 -38.578 125.0469
17639.647002 -40.086 124.8086
17640.379423 -39.277 118.3242
17641.111845 -38.227 104.2539
17641.844267 -36.901 86.5586
17642.576689 -37.009 91.8906
17643.309111 -39.588 89.3086
17644.041533 -36.717 77.9727
17644.773954 -38.876 61.4727
17645.506376 -36.800 65.6172
17646.238798 -39.224 56.2617
17646.971220 -38.866 60.6484
17647.703642 -37.349 41.0391
17648.436063 -37.787 42.5469
17649.168485 -40.003 36.5273
17649.900907 -36.849 34.5469
17650.633329 -37.865 19.5000
17651.365751 -37.629 24.8906
17652.098173 -36.843 -0.6445
17652.830594 -41.070 -13.2422
17653.563016 -38.196 3.8633
17654.295438 -38.837 -13.3086
17655.027860 -39.806 -32.5156
17655.760282 -42.395 2.0625
17656.492703 -43.864 -71.6992
17657.225125 -43.995 -55.0664
17657.957547 -45.833 -94.2266
17658.689969 -46.900 -73.9219
17659.422391 -50.072 -102.6562
17660.154813 -50.519 -120.4922
17660.887234 -50.311 -148.7031
17661.619656 -47.223 -155.1602
17662.352078 -45.167 -150.7695
17663.084500 -47.069 -167.3164
17663.816922 -45.012 -175.7539
17664.549343 -43.548 174.5156
17665.281765 -53.249 112.7383
17666.014187 -50.318 141.2148
17666.746609 -45.439 100.0000
17667.479031 -41.353 72.2266
17668.211452 -47.517 91.2500
17668.943874 -43.003 67.7656
17669.676296 -42.166 97.1602
17670.408718 -42.353 44.4492
17671.141140 -40.736 54.4648
17671.873562 -39.386 55.6836
17672.605983 -39.419 44.5117
17673.338405 -40.104 36.7656
17674.070827 -41.301 18.4531
17674.803249 -39.832 19.4688
17675.535671 -42.030 -9.1758
17676.268092 -45.200 5.5508
17677.000514 -41.977 -15.4961
17677.732936 -41.490 -9.8906
17678.465358 -40.807 -45.3594
17679.197780 -41.778 -31.4570
17679.930202 -39.598 -53.4023
17680.662623 -42.757 -57.6484
17681.395045 -43.778 -77.5664
17682.127467 -41.997 -66.0508
17682.859889 -44.103 -89.6992
17683.592311 -44.282 -97.2031
17684.324732 -39.783 -126.0078
17685.057154 -46.408 -120.4766
17685.789576 -41.699 -139.7578
17686.521998 -41.365 -153.7656
17687.254420 -45.042 -166.1133
17687.986841 -42.842 -147.2305
17688.719263 -46.805 -165.9727
17689.451685 -41.620 148.8125
17690.184107 -42.982 -179.4258
17690.916529 -48.148 145.1992
17691.648951 -40.887 159.0078
17692.381372 -41.036 141.2148
17693.113794 -42.764 136.6484
17693.846216 -41.720 119.0273
17694.578638 -44.617 112.4219
17695.311060 -41.473 96.9648
17696.043481 -43.394 104.0391
17696.775903 -42.122 75.2422
17697.508325 -43.273 74.7031
17698.240747 -40.563 66.6250
17698.973169 -42.698 70.5625
17699.705591 -42.784 66.8242
17700.438012 -44.152 37.1758
17701.170434 -41.937 48.3164
17701.902856 -45.454 29.6055
17702.635278 -43.850 24.1289
17703.367700 -45.643 33.0781
17704.100121 -44.494 30.4336
17704.832543 -43.176 45.6289
17705.564965 -55.669 95.6953
17706.297387 -50.748 20.3750
17707.029809 -48.269 37.2109
17707.762231 -50.379 -7.3008
17708.494652 -48.298 -6.7266
17709.227074 -49.107 52.6602
17709.959496 -50.540 21.9805
17710.691918 -57.721 103.6680
17711.424340 -60.846 67.1641
17712.156761 -58.680 -34.5000
17712.889183 -48.455 38.6367
17713.621605 -53.198 74.6094
17714.354027 -47.662 35.3281
17715.086449 -51.118 57.6484
17715.818870 -47.403 62.6133
17716.551292 -42.230 64.8945
17717.283714 -55.488 40.5234
17718.016136 -45.240 23.7227
17718.748558 -45.606 30.1211
17719.480980 -47.049 19.4062
17720.213401 -42.464 10.4648
17720.945823 -46.595 25.8945
17721.678245 -44.485 8.6953
17722.410667 -45.105 -5.1367
17723.143089 -52.293 6.6758
17723.875510 -48.287 -31.0391
17724.607932 -44.749 -14.0703
17725.340354 -53.874 -25.2305
17726.072776 -43.000 -38.8086
17726.805198 -50.177 -44.0195
17727.537620 -47.294 -3.9766
17728.270041 -48.714 21.2734
17729.002463 -58.545 -33.1055
17729.734885 -48.514 -38.8086
17730.467307 -46.306 -4.4141
17731.199729 -52.634 16.0117
17731.932150 -45.377 -19.5859
17732.664572 -48.899 9.1172
17733.396994 -48.525 -19.3750
17734.129416 -57.365 23.9688
17734.861838 -51.460 107.4492
17735.594260 -48.241 -48.3828
17736.326681 -47.137 -7.9102
17737.059103 -49.719 2.9766
17737.791525 -46.819 -35.6758
17738.523947 -57.621 9.9727
17739.256369 -44.941 12.9219
17739.988790 -45.483 11.5781
17740.721212 -54.431 59.8594
17741.453634 -47.052 -43.7148
17742.186056 -44.187 -52.7227
17742.918478 -49.055 -28.9688
17743.650899 -43.508 -68.3008
17744.383321 -45.276 -68.2812
17745.115743 -42.517 -75.7656
17745.848165 -54.628 -59.1211
17746.580587 -52.475 142.4102
17747.313009 -45.412 -90.7344
17748.045430 -52.642 -94.4414
17748.777852 -45.800 -112.1406
17749.510274 -44.586 -107.7656
17750.242696 -44.639 -100.0000
17750.975118 -48.323 -113.9727
17751.707539 -49.291 -23.2148
17752.439961 -42.114 159.2891
17753.172383 -45.082 -151.0156
17753.904805 -52.005 -130.5352
17754.637227 -45.645 -159.2617
17755.369649 -46.791 -125.6953
17756.102070 -48.007 -176.9180
17756.834492 -48.990 174.5352
17757.566914 -48.345 147.5352
17758.299336 -42.610 124.5820
17759.031758 -49.485 149.4219
17759.764179 -48.662 127.7461
17760.496601 -45.644 130.8242
17761.229023 -52.476 161.7383
17761.961445 -47.788 102.9648
17762.693867 -52.167 108.8086
17763.426288 -62.059 98.4766
17764.158710 -40.441 97.4062
17764.891132 -50.775 -179.3984
17765.623554 -57.183 -138.1641
17766.355976 -56.479 146.4570
17767.088398 -47.859 -140.9922
17767.820819 -49.127 -167.0859
17768.553241 -57.891 -179.9219
17769.285663 -50.332 129.4961
17770.018085 -42.595 86.4375
17770.750507 -53.846 157.3398
17771.482928 -50.083 -175.6758
17772.215350 -52.584 62.2422
17772.947772 -51.006 -122.9531
17773.680194 -55.708 -176.3203
17774.412616 -50.374 44.7812
17775.145038 -46.840 52.8828
17775.877459 -42.208 50.1367
17776.609881 -55.328 85.7539
17777.342303 -53.486 166.2500
17778.074725 -51.109 0.5234
17778.807147 -53.283 -111.1484
17779.539568 -55.777 -7.3281
17780.271990 -51.066 -7.7344
17781.004412 -52.549 -25.7148
17781.736834 -40.986 41.5586
17782.469256 -53.039 -107.8633
17783.201678 -53.008 -105.9805
17783.934099 -51.806 -29.8320
17784.666521 -50.544 -146.9102
17785.398943 -62.403 32.9297
17786.131365 -43.707 -76.5312
17786.863787 -58.322 -82.8555
17787.596208 -45.832 33.3672
17788.328630 -47.265 -144.8945
17789.061052 -50.999 -121.0625
17789.793474 -54.805 -138.5625
17790.525896 -48.852 -152.8320
17791.258317 -44.725 167.2070
17791.990739 -47.760 -152.8555
17792.723161 -57.935 -162.4922
17793.455583 -41.281 38.5547
17794.188005 -47.097 140.5039
17794.920427 -50.023 -170.4727
17795.652848 -51.707 127.3711
17796.385270 -48.281 135.0273
17797.117692 -51.235 172.0156
17797.850114 -54.684 -175.5039
17798.582536 -61.841 38.0859
17799.314957 -41.065 17.0273
17800.047379 -47.900 105.2461
17800.779801 -43.985 163.5000
17801.512223 -46.183 141.0703
17802.244645 -44.441 138.3242
17802.977067 -48.566 118.1055
17803.709488 -48.526 153.8555
17804.441910 -49.538 154.0820
17805.174332 -41.810 33.5625
17805.906754 -44.360 117.4727
17806.639176 -46.096 128.4141
17807.371597 -48.102 91.3086
17808.104019 -44.019 140.2695
17808.836441 -43.582 123.2852
17809.568863 -44.197 128.7578
17810.301285 -44.024 138.1250
17811.033706 -41.434 25.9805
17811.766128 -38.624 116.0430
17812.498550 -41.619 115.2070
17813.230972 -41.891 106.0352
17813.963394 -40.040 110.9844
17814.695816 -39.758 94.3984
17815.428237 -40.343 90.0742
17816.160659 -39.447 82.5391
17816.893081 -38.951 8.8438
17817.625503 -37.659 68.8594
17818.357925 -40.311 71.5781
17819.090346 -40.418 51.2695
17819.822768 -38.665 65.1719
17820.555190 -37.655 54.0156
17821.287612 -40.761 30.5430
17822.020034 -38.169 26.3516
17822.752456 -34.218 -4.5625
17823.484877 -36.660 25.3398
17824.217299 -38.537 15.2188
17824.949721 -38.189 10.3398
17825.682143 -40.651 17.3672
17826.414565 -38.904 2.5273
17827.146986 -37.720 -17.8164
17827.879408 -38.041 -27.9023
17828.611830 -32.504 -43.1914
17829.344252 -41.347 -21.8711
17830.076674 -37.758 -47.8711
17830.809096 -38.439 -46.1172
17831.541517 -41.589 -68.6914
17832.273939 -39.945 -64.6719
17833.006361 -37.814 -90.4648
17833.738783 -41.197 -101.8359
17834.471205 -34.101 -75.7109
17835.203626 -43.847 -119.0938
17835.936048 -44.991 -109.7188
17836.668470 -39.362 -120.6289
17837.400892 -46.630 -158.9297
17838.133314 -45.763 -137.4922
17838.865735 -44.534 -170.0859
17839.598157 -41.382 -141.1797
17840.330579 -38.058 -105.6367
17841.063001 -44.811 166.0117
17841.795423 -47.624 142.6680
17842.527845 -44.177 174.0312
17843.260266 -44.962 152.1602
17843.992688 -42.108 124.6758
17844.725110 -45.249 147.3984
17845.457532 -44.377 160.6914
17846.189954 -45.299 -81.0664
17846.922375 -43.795 53.2656
17847.654797 -42.381 60.0273
17848.387219 -40.875 58.5312
17849.119641 -39.497 61.6797
17849.852063 -40.639 30.5742
17850.584485 -43.865 38.3789
17851.316906 -40.981 14.4023
17852.049328 -41.738 -63.7695
17852.781750 -41.221 -4.0859
17853.514172 -39.656 -21.8555
17854.246594 -41.488 3.7461
17854.979015 -41.764 -14.1484
17855.711437 -40.798 -20.4102
17856.443859 -44.000 -20.5625
17857.176281 -41.887 -55.3555
17857.908703 -36.769 -89.3086
17858.641124 -42.457 -33.4336
17859.373546 -43.549 -45.3086
17860.105968 -44.222 -55.4648
17860.838390 -43.727 -40.3672
17861.570812 -43.704 -46.8438
17862.303234 -48.184 -84.3750
17863.035655 -43.310 -118.2617
17863.768077 -35.910 -131.4023
17864.500499 -44.023 -103.9961
17865.232921 -43.986 -104.8242
17865.965343 -43.221 -169.3750
17866.697764 -62.478 84.1523
17867.430186 -48.382 172.0742
17868.162608 -43.091 167.7695
17868.895030 -45.413 -177.3047
17869.627452 -38.978 -142.5859
17870.359874 -59.374 -138.0234
17871.092295 -59.568 148.4805
17871.824717 -53.435 140.4258
17872.557139 -50.404 49.4531
17873.289561 -52.665 3.0000
17874.021983 -49.282 72.5000
17874.754404 -49.602 81.8281
17875.486826 -41.933 -162.4375
17876.219248 -50.308 -3.3906
17876.951670 -52.416 -84.3359
17877.684092 -50.004 44.8477
17878.416514 -50.718 9.5352
17879.148935 -46.117 20.2617
17879.881357 -65.257 152.8398
17880.613779 -57.562 -160.2031
17881.346201 -41.984 -160.0781
17882.078623 -61.810 -148.2852
17882.811044 -46.517 -20.9883
17883.543466 -62.687 17.1914
17884.275888 -46.381 -8.8516
17885.008310 -49.113 -57.2930
17885.740732 -51.191 98.8398
17886.473153 -47.862 -177.2070
17887.205575 -37.651 -166.5039
17887.937997 -51.346 -78.4922
17888.670419 -52.085 135.1953
17889.402841 -45.994 -175.3164
17890.135263 -49.466 106.8164
17890.867684 -47.226 142.2031
17891.600106 -45.129 164.7500
17892.332528 -43.676 163.5273
17893.064950 -38.168 153.1133
17893.797372 -60.515 -147.8398
17894.529793 -53.309 63.1797
17895.262215 -49.644 -90.2227
17895.994637 -49.769 -56.2383
17896.727059 -50.972 -3.0664
17897.459481 -50.643 36.1055
17898.191903 -53.242 117.0859
17898.924324 -47.614 -133.1875
17899.656746 -47.445 -85.7734
17900.389168 -50.062 -29.9141
17901.121590 -79.722 -70.4609
17901.854012 -46.057 -36.6992
17902.586433 -55.410 -74.5352
17903.318855 -47.251 -57.0781
17904.051277 -54.455 158.4922
17904.783699 -45.306 -165.5312
17905.516121 -43.196 -140.9727
17906.248542 -45.881 -33.0352
17906.980964 -53.460 -145.9336
17907.713386 -42.988 -45.8086
17908.445808 -42.467 -101.5859
17909.178230 -53.129 98.2188
17909.910652 -44.799 -94.0508
17910.643073 -41.632 145.6094
17911.375495 -46.190 -103.5078
17912.107917 -42.035 -92.2852
17912.840339 -48.572 -111.5703
17913.572761 -48.443 -71.8555
17914.305182 -45.907 -141.5938
17915.037604 -51.468 -143.5820
17915.770026 -38.837 173.5781
17916.502448 -44.304 148.8320
17917.234870 -48.212 -67.9023
17917.967292 -49.877 67.7031
17918.699713 -41.474 69.1367
17919.432135 -46.121 42.9883
17920.164557 -48.657 -12.4883
17920.896979 -51.067 -115.3242
17921.629401 -46.514 -119.8281
17922.361822 -45.502 -168.1758
17923.094244 -48.540 13.4883
17923.826666 -43.962 67.3320
17924.559088 -55.446 -160.8203
17925.291510 -50.521 -16.2695
17926.023932 -38.411 17.9844
17926.756353 -39.323 -26.2734
17927.488775 -42.622 47.1523
17928.221197 -55.375 83.7695
17928.953619 -44.036 -121.4531
17929.686041 -40.245 -50.9062
17930.418462 -47.527 -68.1992
17931.150884 -46.457 -87.8320
17931.883306 -45.065 -67.0938
17932.615728 -43.675 -56.0586
17933.348150 -40.464 -23.2070
17934.080571 -40.437 100.4375
17934.812993 -41.118 45.8945
17935.545415 -39.406 -77.6406
17936.277837 -52.543 99.4766
17937.010259 -41.272 -153.3281
17937.742681 -35.156 -77.5000
17938.475102 -46.617 -88.6055
17939.207524 -47.018 147.6250
17939.939946 -40.112 -74.2656
17940.672368 -42.445 144.0430
17941.404790 -49.698 113.5117
17942.137211 -43.805 21.4688
17942.869633 -36.626 -136.0469
17943.602055 -41.244 -155.9492
17944.334477 -44.081 -99.8125
17945.066899 -36.788 -156.1289
17945.799321 -50.659 -125.5664
17946.531742 -41.706 -125.7969
17947.264164 -45.116 -131.7930
17947.996586 -33.916 -160.4102
17948.729008 -43.910 -147.3125
17949.461430 -48.565 -84.8203
17950.193851 -37.783 -80.6367
17950.926273 -36.832 142.3047
17951.658695 -42.534 -138.9844
17952.391117 -50.649 132.2617
17953.123539 -34.991 127.6289
17953.855960 -34.417 136.2188
17954.588382 -39.627 84.2695
17955.320804 -41.648 139.7539
17956.053226 -39.063 107.6758
17956.785648 -33.995 94.7383
17957.518070 -33.853 86.8984
17958.250491 -39.527 28.2109
17958.982913 -38.462 50.4570
17959.715335 -39.201 116.7773
17960.447757 -36.969 36.2109
17961.180179 -41.380 176.9531
17961.912600 -33.905 83.9844
17962.645022 -35.894 100.7734
17963.377444 -38.638 55.8242
17964.109866 -36.469 49.8477
17964.842288 -36.547 72.2578
17965.574710 -45.401 -31.4531
17966.307131 -38.228 34.8555
17967.039553 -39.699 59.5039
17967.771975 -34.530 37.4023
17968.504397 -48.094 -113.6914
17969.236819 -35.111 35.9062
17969.969240 -39.945 -81.9062
17970.701662 -32.368 -4.7188
17971.434084 -35.410 65.4688
17972.166506 -47.302 0.4727
17972.898928 -50.702 -68.1094
17973.631350 -33.703 52.6602
17974.363771 -38.290 -6.6797
17975.096193 -34.972 8.6641
17975.828615 -39.667 52.5977
17976.561037 -33.524 55.6133
17977.293459 -48.265 -156.5898
17978.025880 -38.404 82.9336
17978.758302 -49.653 167.3398
17979.490724 -38.722 -99.6992
17980.223146 -45.995 99.2891
17980.955568 -37.617 -34.0898
17981.687989 -49.078 37.5000
17982.420411 -35.103 5.9844
17983.152833 -49.042 32.1211
17983.885255 -35.970 33.5742
17984.617677 -39.891 29.9141
17985.350099 -34.417 -55.8984
17986.082520 -39.082 -41.5664
17986.814942 -50.830 -99.9883
17987.547364 -36.146 36.5977
17988.279786 -37.684 -27.4180
17989.012208 -36.550 -69.3047
17989.744629 -33.121 23.0859
17990.477051 -32.933 -10.0430
17991.209473 -31.289 -22.5703
17991.941895 -47.109 -39.4336
17992.674317 -30.282 -29.9922
17993.406739 -33.017 -51.8477
17994.139160 -39.338 -175.9141
17994.871582 -37.489 -25.7891
17995.604004 -44.468 -40.4609
17996.336426 -41.597 -50.3906
17997.068848 -38.940 -53.7656
17997.801269 -35.934 -37.3828
17998.533691 -40.538 -44.7344
17999.266113 -33.632 -114.2188
17999.998535 -41.971 -104.8477
18000.730957 -36.386 -97.8125
18001.463378 -39.881 163.9492
18002.195800 -39.831 -85.4727
18002.928222 -46.301 -103.7266
18003.660644 -44.481 162.0938
18004.393066 -42.298 86.9258
18005.125488 -40.768 -144.9570
18005.857909 -54.914 -87.6445
18006.590331 -40.897 -115.9062
18007.322753 -40.068 -101.8945
18008.055175 -42.573 -168.1172
18008.787597 -45.520 179.3203
18009.520018 -54.056 98.8438
18010.252440 -45.436 167.3398
18010.984862 -55.157 87.9531
18011.717284 -45.777 57.1523
18012.449706 -53.962 140.2266
18013.182128 -42.419 168.4414
18013.914549 -56.719 144.0703
18014.646971 -47.670 -148.3281
18015.379393 -54.150 83.3203
18016.111815 -49.214 81.5312
18016.844237 -43.260 168.6914
18017.576658 -40.861 47.0781
18018.309080 -44.756 142.4883
18019.041502 -48.414 -175.1836
18019.773924 -52.989 15.0977
18020.506346 -44.486 107.2109
18021.238768 -40.651 168.3281
18021.971189 -47.948 11.5156
18022.703611 -45.572 7.7930
18023.436033 -38.623 21.9922
18024.168455 -40.430 10.6914
18024.900877 -41.358 3.1562
18025.633298 -47.582 -123.0586
18026.365720 -35.151 1.0625
18027.098142 -41.537 -38.0938
18027.830564 -37.693 15.6211
18028.562986 -39.309 -18.3906
18029.295407 -50.219 -124.3281
18030.027829 -48.449 -113.4375
18030.760251 -43.652 -74.4922
18031.492673 -40.180 160.9648
18032.225095 -35.434 -4.1328
18032.957517 -43.367 -18.4766
18033.689938 -38.675 13.5508
18034.422360 -56.910 -82.2344
18035.154782 -39.354 -24.1953
18035.887204 -55.113 -40.2422
18036.619626 -34.951 -57.1836
18037.352047 -38.978 -59.1328
18038.084469 -34.264 -49.1484
18038.816891 -42.358 -18.6641
18039.549313 -45.332 76.9805
18040.281735 -41.438 -34.2617
18041.014157 -43.800 -27.5508
18041.746578 -43.249 -157.7109
18042.479000 -35.697 -24.8867
18043.211422 -53.209 -33.6484
18043.943844 -42.342 25.8047
18044.676266 -43.721 -68.5859
18045.408687 -38.184 -78.4023
18046.141109 -41.391 -19.6602
18046.873531 -41.062 -45.4492
18047.605953 -40.772 -31.1641
18048.338375 -44.961 7.7539
18049.070796 -47.109 -27.2734
18049.803218 -42.247 -75.2109
18050.535640 -45.197 -39.0000
18051.268062 -38.658 -71.8477
18052.000484 -49.374 -74.9375
18052.732906 -35.648 -97.1484
18053.465327 -46.628 -140.9219
18054.197749 -46.864 -108.6445
18054.930171 -52.503 -42.2852
18055.662593 -44.311 79.8711
18056.395015 -47.707 -141.2891
18057.127436 -40.050 -157.5781
18057.859858 -43.483 -129.2070
18058.592280 -43.198 -118.7109
18059.324702 -38.727 -77.5625
18060.057124 -48.552 -170.3594
18060.789546 -44.163 -108.9492
18061.521967 -52.650 -77.3672
18062.254389 -52.963 0.3125
18062.986811 -49.753 -130.8438
18063.719233 -55.358 95.7734
18064.451655 -48.023 -144.5117
18065.184076 -40.617 -30.9102
18065.916498 -51.215 -138.6289
18066.648920 -44.729 -23.2070
18067.381342 -49.466 69.7656
18068.113764 -54.940 14.8320
18068.846186 -44.125 5.9570
18069.578607 -44.932 -74.0820
18070.311029 -51.792 -21.1211
18071.043451 -47.051 -52.7305
18071.775873 -52.697 -26.3828
18072.508295 -56.596 154.5469
18073.240716 -48.755 -34.6484
18073.973138 -38.823 -44.8594
18074.705560 -50.188 85.3203
18075.437982 -44.989 -30.4141
18076.170404 -41.199 -88.5234
18076.902825 -39.783 -68.1875
18077.635247 -42.434 -104.0000
18078.367669 -40.459 -117.9531
18079.100091 -42.921 -144.2109
18079.832513 -41.587 -95.9688
18080.564935 -49.765 -87.2930
18081.297356 -44.036 -172.5469
18082.029778 -42.432 -149.2930
18082.762200 -37.390 -123.2578
18083.494622 -38.418 -160.0234
18084.227044 -41.497 -168.5938
18084.959465 -42.785 -179.0977
18085.691887 -38.490 -158.8945
18086.424309 -43.429 -154.6484
18087.156731 -42.091 178.3125
18087.889153 -40.468 -151.7031
18088.621575 -41.898 -161.5117
18089.353996 -42.039 168.4258
18090.086418 -62.526 158.6914
18090.818840 -47.576 179.0078
18091.551262 -55.240 -111.8242
18092.283684 -46.925 146.0547
18093.016105 -49.204 110.3359
18093.748527 -51.468 111.0898
18094.480949 -48.113 -157.2578
18095.213371 -59.642 154.8750
18095.945793 -47.105 54.3438
18096.678214 -58.945 87.2734
18097.410636 -49.929 -86.4844
18098.143058 -50.806 -102.6797
18098.875480 -47.418 -79.0508
18099.607902 -55.383 -2.9492
18100.340324 -47.325 -143.6641
18101.072745 -73.560 -15.6172
18101.805167 -49.905 -174.6719
18102.537589 -52.035 -162.2656
18103.270011 -45.812 -161.2930
18104.002433 -49.838 -150.8008
18104.734854 -54.915 163.9531
18105.467276 -46.197 -167.7891
18106.199698 -47.058 178.1133
18106.932120 -49.495 103.9180
18107.664542 -43.494 170.5000
18108.396964 -42.643 152.8516
18109.129385 -40.198 154.8594
18109.861807 -43.218 164.8438
18110.594229 -45.821 109.9570
18111.326651 -43.089 164.7305
18112.059073 -38.875 138.7812
18112.791494 -43.107 99.1562
18113.523916 -40.199 102.2344
18114.256338 -43.169 113.0000
18114.988760 -44.908 112.1016
18115.721182 -44.547 140.1797
18116.453604 -41.971 72.9062
18117.186025 -44.101 100.8203
18117.918447 -46.569 80.4453
18118.650869 -43.152 56.4961
18119.383291 -43.704 72.9453
18120.115713 -44.012 78.0938
18120.848134 -56.187 102.2148
18121.580556 -50.909 37.0312
18122.312978 -44.981 3.4297
18123.045400 -42.264 37.3008
18123.777822 -48.909 74.7422
18124.510243 -48.252 -3.5352
18125.242665 -49.341 26.5742
18125.975087 -51.243 -9.0781
18126.707509 -58.935 52.1094
18127.439931 -47.888 -55.2188
18128.172353 -44.997 -53.3359
18128.904774 -45.825 0.7539
18129.637196 -46.096 11.8164
18130.369618 -48.997 17.5938
18131.102040 -49.439 23.7070
18131.834462 -49.094 5.5625
18132.566883 -48.739 85.6250
18133.299305 -56.621 -112.7383
18134.031727 -60.068 88.4023
18134.764149 -66.478 65.6953
18135.496571 -51.431 47.3555
18136.228993 -48.351 -25.2070
18136.961414 -56.337 3.3086
18137.693836 -56.820 -34.1172
18138.426258 -49.760 89.8438
18139.158680 -53.987 -179.5742
18139.891102 -70.801 175.7930
18140.623523 -48.094 86.0234
18141.355945 -49.575 68.0742
18142.088367 -44.946 81.8867
18142.820789 -44.575 36.1016
18143.553211 -51.009 15.5273
18144.285632 -44.181 84.3828
18145.018054 -45.179 68.5625
18145.750476 -44.521 36.7656
18146.482898 -47.202 31.6836
18147.215320 -42.473 92.5703
18147.947742 -45.198 25.7148
18148.680163 -42.212 61.2969
18149.412585 -45.227 57.0234
18150.145007 -41.391 56.5508
18150.877429 -41.526 52.2266
18151.609851 -44.703 70.2695
18152.342272 -40.188 33.1602
18153.074694 -42.199 57.3555
18153.807116 -42.573 8.7344
18154.539538 -39.724 35.7188
18155.271960 -43.610 29.7930
18156.004382 -40.524 20.7031
18156.736803 -39.953 55.5820
18157.469225 -39.529 31.5156
18158.201647 -39.085 8.1953
18158.934069 -37.304 7.6914
18159.666491 -38.606 0.6016
18160.398912 -38.230 4.6094
18161.131334 -37.670 0.7891
18161.863756 -37.418 13.5703
18162.596178 -38.998 0.2461
18163.328600 -38.604 -8.9375
18164.061022 -37.678 -13.6250
18164.793443 -35.400 -18.7422
18165.525865 -37.080 -19.3633
18166.258287 -37.375 -22.0977
18166.990709 -36.117 -25.6836
18167.723131 -36.516 -22.8906
18168.455552 -38.637 -43.3164
18169.187974 -36.828 -46.4258
18169.920396 -36.634 -49.1367
18170.652818 -36.566 -39.1055
18171.385240 -35.681 -52.7969
18172.117661 -37.138 -52.5859
18172.850083 -35.976 -54.1602
18173.582505 -35.544 -60.4844
18174.314927 -39.384 -75.8398
18175.047349 -36.736 -77.6016
18175.779771 -37.340 -74.9492
18176.512192 -36.277 -73.4883
18177.244614 -36.897 -83.0352
18177.977036 -37.394 -85.8359
18178.709458 -36.562 -95.1406
18179.441880 -38.191 -88.0156
18180.174301 -39.634 -123.7695
18180.906723 -40.235 -110.6445
18181.639145 -37.814 -117.3555
18182.371567 -40.343 -107.7930
18183.103989 -40.644 -122.2500
18183.836411 -42.961 -141.1406
18184.568832 -44.410 -125.0312
18185.301254 -43.322 -117.5820
18186.033676 -48.083 169.2578
18186.766098 -48.683 -122.5039
18187.498520 -45.426 -158.1016
18188.230941 -51.000 -146.0977
18188.963363 -46.962 -146.6055
18189.695785 -48.449 -173.9766
18190.428207 -48.396 171.7930
18191.160629 -59.309 157.5156
18191.893050 -45.585 96.9336
18192.625472 -57.794 123.4375
18193.357894 -65.154 164.4570
18194.090316 -51.628 0.0625
18194.822738 -52.851 53.2656
18195.555160 -48.498 -31.5430
18196.287581 -50.618 -87.4688
18197.020003 -45.346 -21.0820
18197.752425 -49.485 -21.2383
18198.484847 -45.774 -39.0742
18199.217269 -43.384 -59.8281
18199.949690 -46.654 -53.8477
18200.682112 -45.351 -104.1602
18201.414534 -44.166 -73.5156
18202.146956 -41.105 -81.6484
18202.879378 -41.127 -86.3633
18203.611800 -47.251 -53.2891
18204.344221 -41.401 -92.8906
18205.076643 -42.413 -100.2812
18205.809065 -40.249 -99.4453
18206.541487 -43.900 -108.4414
18207.273909 -44.263 -118.6680
18208.006330 -43.731 -128.1875
18208.738752 -46.043 -120.2109
18209.471174 -55.638 81.8438
18210.203596 -42.506 -124.0664
18210.936018 -45.127 -144.2188
18211.668440 -54.815 -127.4062
18212.400861 -47.346 -130.3125
18213.133283 -48.714 -136.3555
18213.865705 -45.236 -172.4258
18214.598127 -53.447 -163.6367
18215.330549 -45.766 56.1289
18216.062970 -53.401 141.9023
18216.795392 -47.692 171.6055
18217.527814 -51.057 -66.0039
18218.260236 -49.570 11.3594
18218.992658 -52.954 -44.6602
18219.725079 -52.621 14.8633
18220.457501 -44.799 -7.9141
18221.189923 -39.362 27.8594
18221.922345 -49.408 -34.3750
18222.654767 -43.625 -58.1523
18223.387189 -44.653 -69.6641
18224.119610 -41.510 -78.0430
18224.852032 -42.052 -66.8125
18225.584454 -42.716 -77.1914
18226.316876 -39.150 -86.7656
18227.049298 -41.427 -48.9297
18227.781719 -40.201 -81.1562
18228.514141 -41.152 -96.9336
18229.246563 -38.964 -114.6016
18229.978985 -39.677 -101.0078
18230.711407 -41.695 -135.8438
18231.443829 -38.805 -122.0977
18232.176250 -37.881 -122.1523
18232.908672 -43.446 -86.6016
18233.641094 -38.364 -142.9609
18234.373516 -38.211 -151.9414
18235.105938 -37.775 -153.1562
18235.838359 -38.926 -160.6914
18236.570781 -38.415 -163.2422
18237.303203 -37.061 -179.1484
18238.035625 -38.254 178.0156
18238.768047 -46.899 144.3711
18239.500468 -37.972 162.9609
18240.232890 -38.197 143.0781
18240.965312 -40.534 168.7656
18241.697734 -41.106 132.4062
18242.430156 -40.581 140.1172
18243.162578 -39.770 126.4141
18243.894999 -43.917 129.7812
18244.627421 -43.687 78.3789
18245.359843 -43.407 100.2070
18246.092265 -42.286 88.2969
18246.824687 -42.560 70.4102
18247.557108 -42.707 68.8477
18248.289530 -50.302 75.9414
18249.021952 -43.966 42.4180
18249.754374 -45.763 47.1914
18250.486796 -38.813 -18.3594
18251.219218 -45.638 8.6016
18251.951639 -47.634 -13.1016
18252.684061 -44.971 -44.8906
18253.416483 -45.686 -36.9883
18254.148905 -44.733 -36.2852
18254.881327 -47.417 -27.4180
18255.613748 -44.780 -64.3984
18256.346170 -37.607 -64.1602
18257.078592 -45.680 -67.1680
18257.811014 -44.387 -104.3789
18258.543436 -42.067 -131.6445
18259.275858 -40.375 -138.6484
18260.008279 -41.529 -125.4023
18260.740701 -43.945 -121.4062
18261.473123 -39.285 -149.0859
18262.205545 -40.339 -102.6367
18262.937967 -40.181 -158.8203
18263.670388 -43.005 -169.4180
18264.402810 -40.579 -167.9336
18265.135232 -42.786 -166.8477
18265.867654 -43.898 -179.9141
18266.600076 -44.790 155.4180
18267.332497 -42.083 175.5742
18268.064919 -42.376 -113.2031
18268.797341 -43.988 145.4805
18269.529763 -46.347 151.0781
18270.262185 -45.432 147.3359
18270.994607 -46.265 149.9453
18271.727028 -53.699 118.5312
18272.459450 -47.289 91.1836
18273.191872 -48.097 149.2031
18273.924294 -44.175 -88.2344
18274.656716 -48.119 83.0312
18275.389137 -50.453 39.1211
18276.121559 -61.807 -6.4062
18276.853981 -57.023 -38.8359
18277.586403 -47.825 -26.5977
18278.318825 -50.982 9.4180
18279.051247 -46.205 -93.0391
18279.783668 -39.083 -95.5781
18280.516090 -45.381 -66.1367
18281.248512 -44.841 -73.4844
18281.980934 -45.647 -97.3438
18282.713356 -42.631 -106.9570
18283.445777 -43.104 -105.9922
18284.178199 -44.906 -96.3672
18284.910621 -42.241 -117.5039
18285.643043 -34.957 -116.6250
18286.375465 -41.125 -131.2812
18287.107886 -40.090 -120.9297
18287.840308 -41.225 -142.2305
18288.572730 -38.249 -151.8086
18289.305152 -39.403 -150.4102
18290.037574 -42.085 -149.4062
18290.769996 -39.164 -163.1016
18291.502417 -35.417 -150.6602
18292.234839 -41.748 -176.4492
18292.967261 -41.283 171.0234
18293.699683 -38.853 173.7422
18294.432105 -40.264 177.5820
18295.164526 -40.545 166.0586
18295.896948 -40.721 156.6172
18296.629370 -39.246 144.9414
18297.361792 -38.172 176.3398
18298.094214 -41.827 138.8047
18298.826636 -38.928 145.1055
18299.559057 -38.577 137.0977
18300.291479 -40.279 140.6250
18301.023901 -42.763 119.9805
18301.756323 -45.143 118.8750
18302.488745 -42.871 93.8047
18303.221166 -39.625 163.9180
18303.953588 -39.993 73.6055
18304.686010 -42.662 117.2344
18305.418432 -45.090 112.0820
18306.150854 -42.236 103.4336
18306.883276 -49.021 35.1758
18307.615697 -45.094 59.6602
18308.348119 -47.892 98.6953
18309.080541 -45.467 178.1836
18309.812963 -62.095 23.5625
18310.545385 -45.547 87.7969
18311.277806 -44.420 66.2695
18312.010228 -46.895 114.9727
18312.742650 -50.404 -47.1133
18313.475072 -66.209 104.3047
18314.207494 -49.637 152.8867
18314.939915 -40.086 -176.0820
18315.672337 -51.142 141.2266
18316.404759 -46.453 144.2422
18317.137181 -50.049 142.9062
18317.869603 -45.513 98.6211
18318.602025 -62.140 120.5977
18319.334446 -45.402 102.8945
18320.066868 -41.886 99.0703
18320.799290 -41.137 122.7383
18321.531712 -44.319 71.3711
18322.264134 -52.278 74.7578
18322.996555 -51.085 84.7188
18323.728977 -46.897 101.5547
18324.461399 -59.626 71.2773
18325.193821 -45.330 33.3594
18325.926243 -40.267 82.8242
18326.658665 -42.929 136.0820
18327.391086 -47.796 85.5977
18328.123508 -47.014 67.3789
18328.855930 -45.980 28.1875
18329.588352 -50.110 71.6680
18330.320774 -48.305 43.2930
18331.053195 -49.970 38.4102
18331.785617 -43.759 25.9453
18332.518039 -42.296 85.3555
18333.250461 -47.059 21.7227
18333.982883 -46.757 2.3945
18334.715304 -45.016 13.8398
18335.447726 -49.806 71.0430
18336.180148 -47.894 28.5469
18336.912570 -44.979 31.4219
18337.644992 -45.141 5.1992
18338.377414 -42.225 65.7305
18339.109835 -44.852 -49.2930
18339.842257 -47.290 32.0898
18340.574679 -46.006 11.9570
18341.307101 -51.387 -30.5156
18342.039523 -46.017 -47.2656
18342.771944 -60.893 -109.2148
18343.504366 -51.325 -59.5469
18344.236788 -48.380 159.4688
18344.969210 -45.334 -45.1523
18345.701632 -48.776 15.4766
18346.434054 -42.178 -24.3086
18347.166475 -53.164 -46.9570
18347.898897 -46.739 -91.1758
18348.631319 -44.118 -81.3047
18349.363741 -54.084 -165.4102
18350.096163 -51.096 81.5469
18350.828584 -47.545 -119.5586
18351.561006 -59.048 -74.1016
18352.293428 -47.204 -159.0352
18353.025850 -49.743 71.6680
18353.758272 -48.256 -98.5977
18354.490694 -60.640 -103.0820
18355.223115 -49.330 -96.9414
18355.955537 -44.005 124.3008
18356.687959 -60.954 119.2617
18357.420381 -49.735 63.0273
18358.152803 -44.487 22.6445
18358.885224 -43.197 22.8555
18359.617646 -51.701 120.3242
18360.350068 -54.892 51.3828
18361.082490 -45.794 13.9844
18361.814912 -47.560 15.9805
18362.547333 -49.003 21.7070
18363.279755 -42.725 13.7266
18364.012177 -44.300 -6.1680
18364.744599 -45.325 -6.0039
18365.477021 -46.312 -29.0703
18366.209443 -49.213 -34.1055
18366.941864 -42.035 -16.4062
18367.674286 -43.547 -28.2383
18368.406708 -39.861 -55.2617
18369.139130 -40.459 -64.7773
18369.871552 -38.711 -76.2148
18370.603973 -39.764 -69.9961
18371.336395 -39.083 -96.2031
18372.068817 -38.815 -106.4844
18372.801239 -42.451 -95.1055
18373.533661 -45.803 -96.6758
18374.266083 -42.652 -135.1758
18374.998504 -40.614 -133.1875
18375.730926 -40.852 -137.9062
18376.463348 -43.107 -138.8828
18377.195770 -39.065 -151.5781
18377.928192 -41.022 -173.2930
18378.660613 -39.792 -155.2852
18379.393035 -42.714 163.0391
18380.125457 -39.842 -175.8359
18380.857879 -41.032 148.1445
18381.590301 -42.213 155.1055
18382.322722 -49.981 172.5508
18383.055144 -44.721 128.1055
18383.787566 -45.830 143.9961
18384.519988 -44.050 118.9414
18385.252410 -50.750 66.3047
18385.984832 -42.120 112.8945
18386.717253 -45.506 65.8125
18387.449675 -51.339 60.1211
18388.182097 -52.885 -32.3477
18388.914519 -57.177 112.7266
18389.646941 -51.546 35.4570
18390.379362 -50.693 -24.5547
18391.111784 -43.239 11.8320
18391.844206 -49.073 -19.5508
18392.576628 -43.719 -49.2031
18393.309050 -46.476 -51.8320
18394.041472 -47.408 -66.3359
18394.773893 -50.824 -100.5547
18395.506315 -43.595 -105.8086
18396.238737 -48.655 -110.1367
18396.971159 -46.595 -99.8477
18397.703581 -43.545 -127.9727
18398.436002 -46.776 -133.1992
18399.168424 -44.183 -147.0977
18399.900846 -43.496 -123.3242
18400.633268 -42.300 -177.8281
18401.365690 -40.083 -146.5742
18402.098112 -44.905 178.2930
18402.830533 -42.731 -172.8008
18403.562955 -42.507 -174.6055
18404.295377 -43.807 -167.0039
18405.027799 -41.507 -177.9961
18405.760221 -47.054 155.9414
18406.492642 -43.128 130.5898
18407.225064 -46.734 127.0273
18407.957486 -47.830 149.1484
18408.689908 -47.427 99.3086
18409.422330 -46.500 133.7148
18410.154751 -49.013 71.6367
18410.887173 -52.746 27.9062
18411.619595 -51.033 -4.7031
18412.352017 -50.858 161.6406
18413.084439 -62.401 98.6875
18413.816861 -60.399 -29.3203
18414.549282 -46.321 18.7070
18415.281704 -47.285 -37.7734
18416.014126 -55.434 -89.8984
18416.746548 -48.757 170.8398
18417.478970 -48.041 -130.4141
18418.211391 -45.933 -139.2070
18418.943813 -45.673 -123.2891
18419.676235 -44.802 -99.2500
18420.408657 -44.282 -106.7500
18421.141079 -42.778 -108.2148
18421.873501 -50.831 -78.2734
18422.605922 -49.033 -155.5391
18423.338344 -46.596 -116.9531
18424.070766 -47.822 -159.1211
18424.803188 -44.860 -123.2891
18425.535610 -43.298 -179.3672
18426.268031 -46.322 -179.8320
18427.000453 -41.522 -162.7383
18427.732875 -42.536 -172.3828
18428.465297 -44.077 143.7500
18429.197719 -43.581 -163.0195
18429.930140 -44.459 -171.4727
18430.662562 -44.860 -179.1211
18431.394984 -43.086 178.8789
18432.127406 -44.261 163.7734
18432.859828 -44.409 140.1172
18433.592250 -41.771 148.7148
18434.324671 -42.110 158.0234
18435.057093 -43.232 155.5977
18435.789515 -45.455 134.7344
18436.521937 -41.007 120.6211
18437.254359 -44.650 114.5039
18437.986780 -43.523 120.4531
18438.719202 -38.968 141.9414
18439.451624 -41.120 136.2227
18440.184046 -41.015 105.7656
18440.916468 -41.963 120.6680
18441.648890 -41.606 105.2930
18442.381311 -41.222 96.6406
18443.113733 -43.404 73.4492
18443.846155 -41.216 93.6680
18444.578577 -44.467 94.3750
18445.310999 -43.256 103.1016
18446.043420 -45.096 90.6016
18446.775842 -43.896 83.2461
18447.508264 -46.970 71.3594
18448.240686 -48.690 96.9844
18448.973108 -45.172 60.8672
18449.705530 -49.030 50.3789
18450.437951 -48.226 149.8555
18451.170373 -45.259 97.1641
18451.902795 -52.346 77.0977
18452.635217 -54.237 146.3711
18453.367639 -48.985 98.4219
18454.100060 -55.158 142.9062
18454.832482 -51.993 113.5195
18455.564904 -59.799 129.7656
18456.297326 -53.723 84.4023
18457.029748 -50.190 128.2070
18457.762169 -51.927 112.6406
18458.494591 -48.314 151.3906
18459.227013 -45.392 144.8984
18459.959435 -41.752 140.6172
18460.691857 -49.592 147.2188
18461.424279 -46.777 117.9570
18462.156700 -44.489 125.9688
18462.889122 -39.324 114.4297
18463.621544 -40.949 93.9062
18464.353966 -40.486 96.8984
18465.086388 -39.568 88.0234
18465.818809 -38.970 90.8750
18466.551231 -41.136 96.3359
18467.283653 -40.130 85.5586
18468.016075 -38.990 84.9219
18468.748497 -39.045 69.9609
18469.480919 -37.441 55.2266
18470.213340 -39.071 66.0977
18470.945762 -38.716 54.3945
18471.678184 -38.557 54.0664
18472.410606 -37.922 27.8906
18473.143028 -38.311 24.3711
18473.875449 -37.581 42.0234
18474.607871 -38.783 32.7617
18475.340293 -39.109 11.9219
18476.072715 -39.978 10.7578
18476.805137 -40.214 5.7031
18477.537558 -38.771 8.1328
18478.269980 -38.382 -7.7812
18479.002402 -39.253 -12.5625
18479.734824 -39.795 -1.6953
18480.467246 -40.539 -16.9336
18481.199668 -39.178 -30.8008
18481.932089 -42.419 -29.2969
18482.664511 -39.770 -32.1797
18483.396933 -42.904 -28.4219
18484.129355 -40.144 -46.5977
18484.861777 -41.756 -57.3828
18485.594198 -45.759 -57.8750
18486.326620 -46.002 -56.5117
18487.059042 -44.067 -80.0625
18487.791464 -44.261 -73.2148
18488.523886 -47.193 -47.0156
18489.256308 -44.753 -114.6406
18489.988729 -41.105 -96.7695
18490.721151 -45.691 -96.2383
18491.453573 -50.783 -147.3828
18492.185995 -55.420 -116.5195
18492.918417 -53.718 -141.4531
18493.650838 -52.271 -158.7773
18494.383260 -62.249 -147.7344
18495.115682 -55.298 81.5352
18495.848104 -45.260 -121.5273
18496.580526 -55.745 -143.2148
18497.312948 -53.895 106.0234
18498.045369 -54.565 60.3984
18498.777791 -51.428 21.3164
18499.510213 -50.815 120.5469
18500.242635 -58.464 133.7148
18500.975057 -51.728 65.8398
18501.707478 -54.675 59.2344
18502.439900 -54.397 85.2344
18503.172322 -47.724 24.5898
18503.904744 -59.242 30.1055
18504.637166 -49.165 0.9414
18505.369587 -49.547 -12.4102
18506.102009 -46.121 29.4922
18506.834431 -44.929 23.9102
18507.566853 -48.763 -27.8711
18508.299275 -48.785 -48.4258
18509.031697 -49.855 15.1953
18509.764118 -46.670 -2.9922
18510.496540 -42.163 -44.9766
18511.228962 -47.684 -3.1523
18511.961384 -43.017 -20.8242
18512.693806 -45.043 -20.0195
18513.426227 -49.205 -46.0078
18514.158649 -49.128 -27.0664
18514.891071 -48.308 -3.6367
18515.623493 -44.840 -38.7812
18516.355915 -45.036 -85.1758
18517.088337 -47.780 -52.0117
18517.820758 -45.932 -36.4844
18518.553180 -42.992 -15.8242
18519.285602 -43.954 -87.9531
18520.018024 -49.493 -55.5391
18520.750446 -41.776 -51.7656
18521.482867 -45.826 -55.5977
18522.215289 -41.860 -82.7031
18522.947711 -44.215 -95.2305
18523.680133 -45.750 -91.4258
18524.412555 -47.704 -71.7656
18525.144976 -45.520 -89.2109
18525.877398 -45.640 -112.2891
18526.609820 -43.573 -73.5703
18527.342242 -44.263 -108.6367
18528.074664 -43.888 -136.6289
18528.807086 -53.532 -107.7227
18529.539507 -43.585 -113.0742
18530.271929 -42.583 -97.8047
18531.004351 -44.732 -145.9805
18531.736773 -43.601 -145.4805
18532.469195 -46.074 -64.8867
18533.201616 -45.982 -134.1094
18533.934038 -42.822 -148.6406
18534.666460 -46.425 -171.5000
18535.398882 -44.405 -129.9688
18536.131304 -45.965 -161.8750
18536.863726 -40.150 171.4531
18537.596147 -49.093 156.3438
18538.328569 -52.371 -175.6016
18539.060991 -48.153 -171.3516
18539.793413 -44.125 -171.0078
18540.525835 -49.710 163.3867
18541.258256 -49.629 160.7852
18541.990678 -49.033 162.0547
18542.723100 -44.607 170.4570
18543.455522 -50.484 145.1719
18544.187944 -58.123 -30.2461
18544.920366 -47.734 -154.0938
18545.652787 -47.837 139.9375
18546.385209 -52.638 110.5000
18547.117631 -50.687 173.2656
18547.850053 -51.656 131.7578
18548.582475 -47.793 -172.4453
18549.314896 -63.302 65.7852
18550.047318 -64.316 168.1914
18550.779740 -60.150 -163.1758
18551.512162 -51.820 -170.7305
18552.244584 -52.064 -161.5078
18552.977005 -53.580 -168.4492
18553.709427 -61.159 -62.8984
18554.441849 -49.896 141.3672
18555.174271 -67.435 11.1484
18555.906693 -55.407 -68.5312
18556.639115 -49.654 -129.6758
18557.371536 -46.057 -179.8945
18558.103958 -58.367 -177.4961
18558.836380 -50.081 -120.7188
18559.568802 -49.368 -134.5352
18560.301224 -85.105 102.2539
18561.033645 -45.279 -110.6016
18561.766067 -49.305 -96.6133
18562.498489 -48.349 -137.1172
18563.230911 -44.056 177.2148
18563.963333 -48.001 -163.3516
18564.695755 -45.325 -137.9062
18565.428176 -45.947 -121.1172
18566.160598 -44.097 168.7539
18566.893020 -45.381 -162.5820
18567.625442 -43.465 -146.6016
18568.357864 -45.174 -162.9336
18569.090285 -45.971 177.4648
18569.822707 -47.862 155.2891
18570.555129 -45.113 -168.4141
18571.287551 -46.459 148.7695
18572.019973 -42.389 153.4336
18572.752394 -43.390 156.4688
18573.484816 -45.977 162.0078
18574.217238 -45.328 160.5234
18574.949660 -40.200 149.2500
18575.682082 -44.525 130.9453
18576.414504 -45.896 138.9062
18577.146925 -44.768 143.9727
18577.879347 -41.133 122.0938
18578.611769 -43.179 129.7734
18579.344191 -45.841 152.8398
18580.076613 -43.577 111.5469
18580.809034 -41.490 86.5898
18581.541456 -44.727 86.6289
18582.273878 -46.086 123.8398
18583.006300 -43.360 52.7969
18583.738722 -42.879 78.6367
18584.471144 -44.151 55.7852
18585.203565 -46.299 46.2734
18585.935987 -45.180 59.8945
18586.668409 -45.304 49.8281
18587.400831 -40.263 35.6758
18588.133253 -45.924 70.2930
18588.865674 -48.720 31.1602
18589.598096 -41.921 56.8398
18590.330518 -41.891 18.4883
18591.062940 -52.880 16.9883
18591.795362 -46.244 62.5430
18592.527784 -47.073 16.9883
18593.260205 -42.298 22.0469
18593.992627 -47.742 5.1289
18594.725049 -44.688 -23.8711
18595.457471 -55.380 23.4922
18596.189893 -45.417 15.6289
18596.922314 -45.654 -51.2852
18597.654736 -49.190 -25.4492
18598.387158 -50.741 -0.6875
18599.119580 -47.025 -8.1055
18599.852002 -53.386 -126.7188
18600.584423 -46.197 -86.4062
18601.316845 -47.298 -4.9766
18602.049267 -51.769 -53.8242
18602.781689 -55.508 -90.8789
18603.514111 -50.794 -95.4102
18604.246533 -51.971 -2.5586
18604.978954 -48.607 -133.9141
18605.711376 -57.222 -174.1719
18606.443798 -57.577 -74.4570
18607.176220 -58.258 -149.2305
18607.908642 -47.175 -75.3125
18608.641063 -46.690 -136.1289
18609.373485 -53.492 161.8555
18610.105907 -56.605 108.3984
18610.838329 -48.522 -179.9961
18611.570751 -43.246 168.0039
18612.303173 -41.708 159.8867
18613.035594 -48.381 100.4531
18613.768016 -45.375 161.8867
18614.500438 -41.442 142.7617
18615.232860 -43.850 109.1211
18615.965282 -44.875 107.7656
18616.697703 -49.832 101.7539
18617.430125 -44.091 103.2695
18618.162547 -50.847 76.5391
18618.894969 -47.113 82.7852
18619.627391 -45.590 42.3672
18620.359812 -46.113 57.2500
18621.092234 -42.651 78.6250
18621.824656 -43.775 58.2031
18622.557078 -45.287 26.0703
18623.289500 -44.503 51.8516
18624.021922 -42.155 22.5625
18624.754343 -43.699 -1.5039
18625.486765 -44.809 -10.1445
18626.219187 -49.572 55.1133
18626.951609 -44.723 15.5703
18627.684031 -45.586 -32.6094
18628.416452 -46.869 -40.6328
18629.148874 -43.920 -16.3555
18629.881296 -46.189 -78.9531
18630.613718 -45.160 -53.1992
18631.346140 -47.717 -80.7188
18632.078562 -51.469 -110.1797
18632.810983 -52.297 -87.3281
18633.543405 -51.733 -56.8281
18634.275827 -46.280 -74.9805
18635.008249 -53.596 -74.4219
18635.740671 -50.867 -91.0469
18636.473092 -52.751 -63.7539
18637.205514 -50.210 -104.5703
18637.937936 -58.519 121.4062
18638.670358 -61.863 77.9023
18639.402780 -58.191 119.4102
18640.135202 -55.788 141.3438
18640.867623 -47.985 29.2578
18641.600045 -52.425 87.7070
18642.332467 -46.146 53.0391
18643.064889 -45.995 49.3047
18643.797311 -48.673 26.8906
18644.529732 -44.554 44.1875
18645.262154 -43.627 34.2773
18645.994576 -44.563 -2.7773
18646.726998 -44.100 26.8594
18647.459420 -45.254 -0.0586
18648.191841 -40.130 -14.3516
18648.924263 -42.334 -22.6289
18649.656685 -41.175 -17.2266
18650.389107 -39.104 -19.7227
18651.121529 -38.917 -25.1953
18651.853951 -38.039 -33.1484
18652.586372 -38.333 -48.1367
18653.318794 -38.604 -52.2930
18654.051216 -41.969 -61.8477
18654.783638 -39.632 -69.0625
18655.516060 -38.125 -86.6680
18656.248481 -38.439 -75.1250
18656.980903 -38.669 -85.9141
18657.713325 -39.763 -79.1602
18658.445747 -39.767 -98.8203
18659.178169 -39.080 -104.0391
18659.910591 -37.612 -106.4766
18660.643012 -36.607 -125.8984
18661.375434 -39.872 -128.8594
18662.107856 -38.894 -120.2656
18662.840278 -40.697 -133.0742
18663.572700 -39.650 -141.7461
18664.305121 -38.926 -149.9727
18665.037543 -39.955 -154.7305
18665.769965 -41.240 -167.6602
18666.502387 -38.542 -161.7695
18667.234809 -41.283 -179.2031
18667.967230 -46.237 168.5195
18668.699652 -45.661 -163.7109
18669.432074 -45.132 -153.0273
18670.164496 -46.398 -176.8438
18670.896918 -52.007 -152.0156
18671.629340 -52.056 -147.1719
18672.361761 -46.075 -153.5898
18673.094183 -66.651 -120.6953
18673.826605 -58.839 138.3281
18674.559027 -55.285 -145.9648
18675.291449 -49.979 -84.2617
18676.023870 -50.336 -148.7227
18676.756292 -54.101 -115.6172
18677.488714 -46.060 -107.7109
18678.221136 -44.504 -143.4766
18678.953558 -46.915 -103.1250
18679.685980 -44.342 -124.5078
18680.418401 -43.356 -112.9922
18681.150823 -38.861 -130.8555
18681.883245 -44.913 -120.5156
18682.615667 -39.559 -117.2188
18683.348089 -41.295 -145.4102
18684.080510 -36.217 -162.2539
18684.812932 -41.310 -160.8164
18685.545354 -41.321 -157.2344
18686.277776 -38.303 -161.9688
18687.010198 -39.736 -173.3750
18687.742620 -39.074 -156.7930
18688.475041 -37.542 -170.4023
18689.207463 -42.008 179.5234
18689.939885 -36.504 -166.8594
18690.672307 -36.185 169.9648
18691.404729 -35.884 163.7578
18692.137150 -38.766 143.2305
18692.869572 -36.124 162.9609
18693.601994 -38.304 152.8086
18694.334416 -38.386 138.8125
18695.066838 -39.655 141.1875
18695.799259 -36.494 132.2305
18696.531681 -41.197 130.9258
18697.264103 -40.895 125.6250
18697.996525 -41.839 135.8594
18698.728947 -40.719 102.1797
18699.461369 -38.745 132.2227
18700.193790 -38.693 113.0703
18700.926212 -45.612 106.1484
18701.658634 -39.099 109.5391
18702.391056 -36.210 102.0039
18703.123478 -37.145 98.0625
18703.855899 -41.461 64.8711
18704.588321 -40.233 99.7695
18705.320743 -39.967 95.5195
18706.053165 -37.194 74.1094
18706.785587 -38.580 75.9219
18707.518009 -37.776 74.1211
18708.250430 -40.594 80.2695
18708.982852 -39.316 76.1875
18709.715274 -41.261 51.9062
18710.447696 -39.799 71.0781
18711.180118 -39.165 58.7734
18711.912539 -42.328 49.3516
18712.644961 -37.649 81.5195
18713.377383 -40.482 73.2578
18714.109805 -42.163 56.5898
18714.842227 -41.813 57.6758
18715.574648 -40.282 38.1367
18716.307070 -39.801 30.1133
18717.039492 -42.096 12.5156
18717.771914 -44.319 78.6602
18718.504336 -54.279 -174.4180
18719.236758 -45.520 48.1758
18719.969179 -40.888 -2.1797
18720.701601 -46.336 12.1562
18721.434023 -40.980 -21.5547
18722.166445 -47.829 -31.8008
18722.898867 -43.506 27.2656
18723.631288 -41.101 -5.9062
18724.363710 -43.035 -33.1562
18725.096132 -41.639 -30.9180
18725.828554 -46.747 -103.3242
18726.560976 -48.176 -94.8711
18727.293398 -46.795 -79.0195
18728.025819 -47.256 -127.9766
18728.758241 -45.923 163.7422
18729.490663 -47.255 -119.9219
18730.223085 -44.856 -159.8984
18730.955507 -56.133 109.3672
18731.687928 -39.970 114.0859
18732.420350 -49.934 160.9531
18733.152772 -46.780 152.6602
18733.885194 -44.646 118.5195
18734.617616 -43.604 168.1992
18735.350038 -48.200 144.4570
18736.082459 -47.567 62.7266
18736.814881 -39.947 119.1562
18737.547303 -41.765 74.0664
18738.279725 -39.445 88.4141
18739.012147 -42.202 40.7969
18739.744568 -41.549 52.0273
18740.476990 -42.180 32.0586
18741.209412 -41.672 28.1680
18741.941834 -41.970 19.7734
18742.674256 -40.638 12.3242
18743.406677 -41.428 2.2227
18744.139099 -40.808 49.9258
18744.871521 -42.883 -4.7227
18745.603943 -44.265 56.1875
18746.336365 -40.820 -6.9648
18747.068787 -39.209 -28.4219
18747.801208 -39.958 -36.6836
18748.533630 -41.238 7.9648
18749.266052 -36.167 7.6719
18749.998474 -49.405 -15.0938
18750.730896 -43.364 -2.4805
18751.463317 -69.732 -114.0391
18752.195739 -52.968 -9.8555
18752.928161 -55.094 -106.6445
18753.660583 -52.908 -70.7109
18754.393005 -53.013 -116.8984
18755.125427 -49.299 -119.4336
18755.857848 -46.890 -89.4766
18756.590270 -44.289 -122.6172
18757.322692 -46.627 109.7852
18758.055114 -53.157 159.1094
18758.787536 -49.894 151.1719
18759.519957 -50.773 146.2656
18760.252379 -44.765 36.1367
18760.984801 -46.003 37.5938
18761.717223 -53.886 112.3242
18762.449645 -58.916 -162.9258
18763.182067 -45.322 100.3711
18763.914488 -47.787 48.8047
18764.646910 -43.203 69.7656
18765.379332 -47.443 64.5078
18766.111754 -46.831 16.7266
18766.844176 -46.930 2.7500
18767.576597 -54.958 45.8125
18768.309019 -51.266 -10.7227
18769.041441 -42.237 -16.1367
18769.773863 -45.492 -15.4180
18770.506285 -46.081 -46.9609
18771.238706 -47.765 -23.2109
18771.971128 -43.317 -23.5469
18772.703550 -41.608 -41.9258
18773.435972 -41.960 -85.7734
18774.168394 -48.775 -107.8242
18774.900816 -48.728 -62.2539
18775.633237 -46.401 -73.2891
18776.365659 -52.266 -111.4688
18777.098081 -53.014 -123.8086
18777.830503 -47.361 -48.5195
18778.562925 -45.071 -165.4023
18779.295346 -44.640 -143.3867
18780.027768 -41.644 -152.1836
18780.760190 -49.528 156.0742
18781.492612 -48.957 112.2617
18782.225034 -46.910 -142.6562
18782.957456 -44.969 167.0195
18783.689877 -43.689 147.7344
18784.422299 -49.539 99.8281
18785.154721 -43.743 100.9023
18785.887143 -38.401 117.8438
18786.619565 -41.432 103.0859
18787.351986 -51.269 62.0078
18788.084408 -41.857 90.5391
18788.816830 -45.549 74.8945
18789.549252 -48.538 12.4883
18790.281674 -45.772 76.7188
18791.014095 -48.805 77.8086
18791.746517 -48.595 71.2383
18792.478939 -47.090 36.2422
18793.211361 -48.210 20.3945
18793.943783 -46.916 29.5430
18794.676205 -49.557 55.0742
18795.408626 -50.986 83.6172
18796.141048 -45.795 -76.1562
18796.873470 -48.776 -13.2109
18797.605892 -62.240 -121.0039
18798.338314 -55.773 -115.0156
18799.070735 -46.605 -79.4375
18799.803157 -46.628 -156.7344
18800.535579 -61.882 -94.5547
18801.268001 -45.644 -159.6953
18802.000423 -54.053 80.2617
18802.732845 -46.162 168.2070
18803.465266 -43.632 152.8516
18804.197688 -49.346 162.9492
18804.930110 -49.001 159.5898
18805.662532 -50.005 174.2891
18806.394954 -43.497 130.8281
18807.127375 -46.153 146.7891
18807.859797 -50.541 -179.4180
18808.592219 -47.404 75.3672
18809.324641 -45.637 82.7969
18810.057063 -46.841 64.1875
18810.789485 -49.778 78.5000
18811.521906 -49.622 35.1914
18812.254328 -41.220 62.7109
18812.986750 -48.691 33.7266
18813.719172 -47.078 30.5742
18814.451594 -46.349 29.9648
18815.184015 -46.518 12.9102
18815.916437 -43.806 -1.4688
18816.648859 -46.801 -7.6055
18817.381281 -45.800 -23.8281
18818.113703 -44.013 30.7812
18818.846124 -46.995 -23.4805
18819.578546 -49.682 -56.0703
18820.310968 -46.791 -34.2617
18821.043390 -47.151 -14.7578
18821.775812 -45.030 -45.9102
18822.508234 -47.128 -51.9375
18823.240655 -49.727 -78.6602
18823.973077 -44.447 -67.5586
18824.705499 -44.153 -100.9297
18825.437921 -49.971 -145.8828
18826.170343 -47.440 -103.2031
18826.902764 -48.486 -61.0977
18827.635186 -49.120 -80.3594
18828.367608 -50.099 -85.6172
18829.100030 -48.425 -121.5195
18829.832452 -48.227 -177.9883
18830.564874 -48.310 -120.0859
18831.297295 -45.231 -96.9180
18832.029717 -50.512 -139.0625
18832.762139 -56.340 169.8047
18833.494561 -47.669 -163.0000
18834.226983 -41.606 -152.1016
18834.959404 -49.344 -168.5664
18835.691826 -48.510 165.6211
18836.424248 -44.589 178.5820
18837.156670 -50.529 154.8867
18837.889092 -51.081 -178.9922
18838.621513 -44.837 140.6992
18839.353935 -51.656 153.7305
18840.086357 -51.122 111.9961
18840.818779 -53.173 127.2070
18841.551201 -44.927 92.5195
18842.283623 -45.499 111.4766
18843.016044 -46.888 137.3828
18843.748466 -46.812 91.4258
18844.480888 -45.411 77.9258
18845.213310 -46.298 58.1641
18845.945732 -49.574 80.0352
18846.678153 -45.656 43.4219
18847.410575 -41.249 37.8945
18848.142997 -44.812 41.3633
18848.875419 -46.974 46.3320
18849.607841 -42.711 28.7344
18850.340263 -41.029 28.7500
18851.072684 -43.878 -21.1875
18851.805106 -42.450 -11.4922
18852.537528 -42.026 -7.5938
18853.269950 -40.735 -11.5977
18854.002372 -43.782 -9.1875
18854.734793 -43.479 -47.5547
18855.467215 -41.157 -35.3008
18856.199637 -41.715 -55.3984
18856.932059 -41.265 -71.9297
18857.664481 -42.808 -77.3633
18858.396903 -42.807 -81.1445
18859.129324 -40.147 -72.6367
18859.861746 -41.483 -98.1797
18860.594168 -43.251 -109.3203
18861.326590 -42.654 -110.3203
18862.059012 -43.941 -115.4766
18862.791433 -41.473 -146.1055
18863.523855 -42.420 -142.7461
18864.256277 -43.887 -142.6094
18864.988699 -43.384 -159.6211
18865.721121 -45.841 -177.4727
18866.453542 -44.915 173.8242
18867.185964 -43.919 151.4453
18867.918386 -49.398 164.0859
18868.650808 -43.163 155.6719
18869.383230 -44.556 132.7109
18870.115652 -43.768 128.2969
18870.848073 -47.045 109.1406
18871.580495 -47.878 134.3281
18872.312917 -44.556 112.7930
18873.045339 -43.006 77.2188
18873.777761 -45.045 65.9492
18874.510182 -44.482 65.7656
18875.242604 -44.510 65.0938
18875.975026 -42.280 48.7227
18876.707448 -44.919 62.9844
18877.439870 -45.869 31.0273
18878.172292 -51.290 -17.9531
18878.904713 -51.914 37.3984
18879.637135 -44.908 -33.2539
18880.369557 -47.144 -41.2422
18881.101979 -48.207 -33.4766
18881.834401 -51.768 -50.8906
18882.566822 -50.872 -63.2344
18883.299244 -46.570 -30.1289
18884.031666 -45.507 -74.5703
18884.764088 -43.279 -38.8984
18885.496510 -46.538 -65.5586
18886.228931 -49.190 -83.4883
18886.961353 -44.290 -94.7031
18887.693775 -46.464 -99.3125
18888.426197 -48.367 -91.2539
18889.158619 -45.662 -55.7031
18889.891041 -45.128 -128.5000
18890.623462 -49.536 -100.9531
18891.355884 -48.407 -79.5391
18892.088306 -51.528 -114.9531
18892.820728 -47.522 -124.3047
18893.553150 -46.966 -164.6172
18894.285571 -49.009 -124.0312
18895.017993 -45.916 -105.4375
18895.750415 -46.058 -125.5156
18896.482837 -46.193 -108.1562
18897.215259 -44.335 -103.8633
18897.947681 -48.750 -131.5977
18898.680102 -43.627 -138.8516
18899.412524 -45.980 -174.3164
18900.144946 -43.994 -142.5039
18900.877368 -46.548 -146.3086
18901.609790 -42.648 -160.6758
18902.342211 -46.876 -155.3203
18903.074633 -49.213 -173.0586
18903.807055 -47.205 -179.4219
18904.539477 -41.425 -172.2852
18905.271899 -48.687 172.0781
18906.004321 -45.221 168.3594
18906.736742 -46.470 167.5469
18907.469164 -44.377 -172.9180
18908.201586 -46.955 145.0938
18908.934008 -44.607 130.5078
18909.666430 -47.779 136.6875
18910.398851 -42.253 130.7578
18911.131273 -47.434 138.6602
18911.863695 -46.715 104.6836
18912.596117 -51.918 -156.3906
18913.328539 -48.572 97.5898
18914.060960 -50.344 138.6719
18914.793382 -49.012 136.8867
18915.525804 -48.841 149.6914
18916.258226 -46.751 160.2500
18916.990648 -54.473 -150.3906
18917.723070 -50.007 131.5469
18918.455491 -53.970 -148.8867
18919.187913 -50.395 158.8828
18919.920335 -57.738 -126.4023
18920.652757 -47.704 -158.1992
18921.385179 -52.905 -151.6602
18922.117600 -44.388 -174.3672
18922.850022 -49.565 172.8750
18923.582444 -49.543 -164.7812
18924.314866 -52.808 163.3516
18925.047288 -43.761 154.1016
18925.779710 -45.468 126.9570
18926.512131 -44.966 160.7109
18927.244553 -48.030 167.2578
18927.976975 -45.180 146.2969
18928.709397 -42.153 112.5938
18929.441819 -45.041 105.8242
18930.174240 -44.859 110.9297
18930.906662 -42.002 107.1523
18931.639084 -43.028 124.9570
18932.371506 -45.964 60.4805
18933.103928 -43.167 106.9219
18933.836349 -42.165 94.3125
18934.568771 -44.571 69.1562
18935.301193 -45.094 61.9492
18936.033615 -44.130 50.9766
18936.766037 -43.633 58.8672
18937.498459 -45.647 36.6094
18938.230880 -42.675 18.2344
18938.963302 -45.156 2.6523
18939.695724 -41.606 19.1523
18940.428146 -45.080 -4.0625
18941.160568 -45.419 -3.9023
18941.892989 -49.212 -41.3750
18942.625411 -46.492 -3.3750
18943.357833 -46.122 -68.1172
18944.090255 -42.495 -70.7734
18944.822677 -52.602 -101.8086
18945.555099 -47.038 -61.6875
18946.287520 -46.013 -96.9883
18947.019942 -45.688 -123.4062
18947.752364 -49.821 -100.8359
18948.484786 -50.181 -112.5781
18949.217208 -42.809 -126.3945
18949.949629 -44.728 -115.9609
18950.682051 -46.963 -143.9336
18951.414473 -42.943 -148.1523
18952.146895 -45.000 -152.7344
18952.879317 -45.247 -167.0117
18953.611739 -45.619 150.8242
18954.344160 -45.185 147.6641
18955.076582 -44.326 165.2734
18955.809004 -43.400 154.0352
18956.541426 -44.604 156.3047
18957.273848 -46.029 127.1523
18958.006269 -43.728 134.1562
18958.738691 -45.765 122.1758
18959.471113 -43.321 107.1250
18960.203535 -43.261 108.4883
18960.935957 -47.213 115.0508
18961.668378 -42.718 65.6992
18962.400800 -45.164 103.9219
18963.133222 -45.884 79.2227
18963.865644 -46.617 65.5078
18964.598066 -47.811 59.6328
18965.330488 -44.206 44.3398
18966.062909 -44.839 38.7227
18966.795331 -65.097 -147.4727
18967.527753 -47.243 12.6562
18968.260175 -54.783 38.6562
18968.992597 -50.795 -6.7148
18969.725018 -50.412 -36.3984
18970.457440 -44.213 -43.5312
18971.189862 -48.796 -67.8555
18971.922284 -57.096 -58.4961
18972.654706 -47.325 -51.4141
18973.387128 -58.242 -17.3555
18974.119549 -51.291 -139.9453
18974.851971 -45.230 -129.9688
18975.584393 -43.980 -103.6211
18976.316815 -48.165 -135.9336
18977.049237 -50.618 -152.2031
18977.781658 -48.775 -170.2891
18978.514080 -43.912 -173.7969
18979.246502 -42.433 -171.1367
18979.978924 -39.612 161.8516
18980.711346 -43.664 173.3281
18981.443767 -43.202 160.2852
18982.176189 -43.419 160.4609
18982.908611 -42.334 153.0039
18983.641033 -40.734 124.6602
18984.373455 -41.037 123.9062
18985.105877 -42.151 133.7930
18985.838298 -40.773 126.9297
18986.570720 -41.150 112.2852
18987.303142 -41.873 104.8203
18988.035564 -45.389 95.3164
18988.767986 -42.079 81.4883
18989.500407 -39.620 70.1484
18990.232829 -40.196 80.4844
18990.965251 -38.914 69.5547
18991.697673 -41.007 59.6133
18992.430095 -41.398 61.7852
18993.162517 -40.538 56.0156
18993.894938 -38.317 22.9688
18994.627360 -40.654 41.2148
18995.359782 -39.496 24.2734
18996.092204 -41.862 17.8398
18996.824626 -43.252 21.8516
18997.557047 -41.706 2.0820
18998.289469 -40.825 -1.9844
18999.021891 -45.187 -9.4180
18999.754313 -43.879 -45.3047
19000.486735 -41.317 -29.8750
19001.219157 -43.892 -32.3477
19001.951578 -44.545 -54.6562
19002.684000 -45.282 -67.2148
19003.416422 -43.026 -60.3398
19004.148844 -44.081 -70.3477
19004.881266 -45.900 -54.8906
19005.613687 -43.992 -86.3438
19006.346109 -45.297 -106.8711
19007.078531 -49.249 -107.6758
19007.810953 -51.714 -101.1836
19008.543375 -46.701 -94.0234
19009.275796 -57.580 -113.0312
19010.008218 -47.201 -115.4023
19010.740640 -58.409 -161.5117
19011.473062 -49.289 -144.7773
19012.205484 -50.762 149.4414
19012.937906 -54.978 140.4375
19013.670327 -50.052 121.7500
19014.402749 -50.200 95.0234
19015.135171 -48.480 108.8555
19015.867593 -48.934 77.9805
19016.600015 -48.502 81.7188
19017.332436 -48.538 95.5625
19018.064858 -46.389 107.2070
19018.797280 -46.219 53.7383
19019.529702 -46.416 85.5859
19020.262124 -46.327 80.2070
19020.994546 -46.990 76.8086
19021.726967 -42.890 66.1602
19022.459389 -47.654 100.6016
19023.191811 -46.263 72.2461
19023.924233 -49.734 55.3945
19024.656655 -48.336 43.5273
19025.389076 -40.998 25.5703
19026.121498 -44.381 28.6484
19026.853920 -43.805 6.1914
19027.586342 -45.348 7.1016
19028.318764 -46.502 19.6289
19029.051185 -56.565 -12.1680
19029.783607 -48.084 -4.4258
19030.516029 -48.211 11.0234
19031.248451 -49.275 -15.6602
19031.980873 -56.093 -20.6758
19032.713295 -51.354 -5.4961
19033.445716 -67.301 -36.4766
19034.178138 -53.875 -7.6289
19034.910560 -56.027 -84.5508
19035.642982 -49.379 -49.4922
19036.375404 -53.521 -110.4219
19037.107825 -55.752 -116.6797
19037.840247 -61.679 87.9961
19038.572669 -56.444 98.1992
19039.305091 -49.608 70.9531
19040.037513 -53.034 15.3672
19040.769935 -66.837 161.2266
19041.502356 -53.429 127.8008
19042.234778 -58.237 22.4922
19042.967200 -47.122 67.1250
19043.699622 -49.081 107.7539
19044.432044 -49.123 11.4375
19045.164465 -52.819 81.8164
19045.896887 -48.183 30.8672
19046.629309 -51.820 30.7852
19047.361731 -58.305 10.5391
19048.094153 -47.746 35.5195
19048.826575 -45.786 -30.5273
19049.558996 -46.876 -15.2734
19050.291418 -47.690 -12.8281
19051.023840 -51.546 -5.5273
19051.756262 -44.746 -36.8125
19052.488684 -63.470 -55.5820
19053.221105 -52.587 -43.0312
19053.953527 -46.166 -30.5039
19054.685949 -44.638 -51.2148
19055.418371 -48.070 -108.1992
19056.150793 -41.753 -89.3281
19056.883214 -53.160 -80.1875
19057.615636 -49.411 -100.1289
19058.348058 -47.631 -112.9766
19059.080480 -49.149 -169.8203
19059.812902 -44.888 -119.1055
19060.545324 -46.118 -138.7109
19061.277745 -46.116 -148.7305
19062.010167 -46.921 -134.2344
19062.742589 -57.036 -121.6797
19063.475011 -44.889 -163.6875
19064.207433 -43.792 154.7422
19064.939854 -44.730 109.0859
19065.672276 -54.673 160.3984
19066.404698 -47.213 144.8320
19067.137120 -44.161 143.3750
19067.869542 -47.218 153.2031
19068.601964 -51.746 61.3242
19069.334385 -47.623 78.0156
19070.066807 -44.452 83.6211
19070.799229 -46.736 93.9062
19071.531651 -57.651 59.5430
19072.264073 -53.221 45.4297
19072.996494 -43.928 85.0000
19073.728916 -52.710 -34.2617
19074.461338 -43.791 11.7031
19075.193760 -44.543 4.9375
19075.926182 -46.805 37.5625
19076.658603 -42.791 14.7031
19077.391025 -42.904 -26.0586
19078.123447 -43.192 -31.2305
19078.855869 -51.513 -91.1484
19079.588291 -50.027 -78.5586
19080.320713 -47.396 -53.2070
19081.053134 -46.981 -93.6523
19081.785556 -49.953 -80.3828
19082.517978 -45.684 -102.3125
19083.250400 -44.318 -89.8828
19083.982822 -42.536 -121.4336
19084.715243 -42.107 -122.9258
19085.447665 -42.594 -107.1406
19086.180087 -42.346 -77.0977
19086.912509 -43.290 -117.1719
19087.644931 -44.558 -160.9961
19088.377353 -43.765 -114.3320
19089.109774 -53.085 -120.8164
19089.842196 -42.221 -158.8711
19090.574618 -46.175 -174.9453
19091.307040 -45.586 -147.2188
19092.039462 -42.658 178.2383
19092.771883 -48.470 -124.3867
19093.504305 -41.269 -165.5156
19094.236727 -46.955 -171.9570
19094.969149 -61.957 -160.3594
19095.701571 -45.108 178.0000
19096.433993 -42.777 130.0234
19097.166414 -45.191 127.6602
19097.898836 -47.708 150.9023
19098.631258 -45.307 143.5156
19099.363680 -47.088 107.2852
19100.096102 -66.544 128.3984
19100.828523 -50.266 90.5625
19101.560945 -45.736 147.0352
19102.293367 -51.099 92.5938
19103.025789 -51.668 110.3359
19103.758211 -51.925 88.0625
19104.490632 -49.113 136.0703
19105.223054 -50.433 147.5078
19105.955476 -51.073 28.8203
19106.687898 -46.588 132.5703
19107.420320 -52.288 172.7383
19108.152742 -46.463 149.5430
19108.885163 -43.446 134.0586
19109.617585 -52.481 144.7773
19110.350007 -56.360 93.0625
19111.082429 -46.419 33.4805
19111.814851 -45.125 -12.7266
19112.547272 -49.863 -44.5039
19113.279694 -50.893 68.0781
19114.012116 -45.674 39.4883
19114.744538 -44.331 91.4922
19115.476960 -50.327 34.0508
19116.209382 -60.781 -133.8945
19116.941803 -47.717 110.7812
19117.674225 -46.680 -29.9180
19118.406647 -54.531 62.9219
19119.139069 -46.522 -64.3672
19119.871491 -48.092 17.0508
19120.603912 -50.089 -104.9531
19121.336334 -44.933 -50.0117
19122.068756 -54.124 13.0469
19122.801178 -47.710 -29.6797
19123.533600 -46.907 -56.7656
19124.266021 -43.885 -71.5781
19124.998443 -55.405 -95.2031
19125.730865 -52.348 -46.0977
19126.463287 -50.696 -173.4414
19127.195709 -48.492 -52.1680
19127.928131 -46.488 -166.4609
19128.660552 -59.222 -62.9766
19129.392974 -45.345 -106.3047
19130.125396 -48.986 -143.8125
19130.857818 -49.446 -178.1289
19131.590240 -54.857 -155.2578
19132.322661 -47.169 134.6641
19133.055083 -47.352 -159.6953
19133.787505 -49.774 149.2461
19134.519927 -51.169 12.6992
19135.252349 -51.156 -163.1758
19135.984771 -56.929 -179.9570
19136.717192 -48.081 153.8203
19137.449614 -52.587 38.4570
19138.182036 -46.939 109.0039
19138.914458 -53.888 104.2070
19139.646880 -48.253 128.8867
19140.379301 -46.601 48.0391
19141.111723 -52.195 20.3320
19141.844145 -44.340 22.3828
19142.576567 -44.757 11.2188
19143.308989 -42.686 9.9141
19144.041411 -43.350 -22.1914
19144.773832 -43.371 -42.6680
19145.506254 -43.852 -39.6914
19146.238676 -39.864 -27.7188
19146.971098 -41.095 -77.3906
19147.703520 -39.688 -76.4219
19148.435941 -42.572 -46.7969
19149.168363 -40.332 -54.4336
19149.900785 -45.126 -69.4766
19150.633207 -41.399 -92.7305
19151.365629 -41.325 -87.2852
19152.098050 -38.011 -82.8398
19152.830472 -37.905 -120.6094
19153.562894 -39.861 -101.3164
19154.295316 -39.932 -113.3906
19155.027738 -39.404 -123.4492
19155.760160 -44.706 -131.0781
19156.492581 -40.431 -154.2578
19157.225003 -40.010 -138.7188
19157.957425 -40.902 -146.6602
19158.689847 -36.148 -155.0703
19159.422269 -38.304 -151.9844
19160.154690 -41.540 -173.3828
19160.887112 -41.825 -156.2500
19161.619534 -47.739 156.5273
19162.351956 -42.159 158.9102
19163.084378 -42.574 133.2656
19163.816800 -45.090 -171.5312
19164.549221 -42.864 150.4297
19165.281643 -43.126 121.4883
19166.014065 -46.139 108.9844
19166.746487 -48.009 137.7461
19167.478909 -50.266 81.9453
19168.211330 -45.180 165.2344
19168.943752 -55.147 -157.8086
19169.676174 -66.025 -77.6719
19170.408596 -50.273 175.8984
19171.141018 -49.943 -157.4180
19171.873439 -51.270 149.3242
19172.605861 -44.218 -98.2148
19173.338283 -55.417 -91.6523
19174.070705 -45.710 -127.0820
19174.803127 -52.792 -90.8633
19175.535549 -42.491 -96.1758
19176.267970 -43.055 -157.6797
19177.000392 -44.736 -149.7773
19177.732814 -40.377 -135.3750
19178.465236 -41.585 -169.5234
19179.197658 -43.592 -125.7344
19179.930079 -41.903 170.3633
19180.662501 -41.283 -168.6992
19181.394923 -42.055 -152.4727
19182.127345 -38.821 165.3203
19182.859767 -41.712 174.4805
19183.592189 -42.566 177.7344
19184.324610 -42.462 -179.3594
19185.057032 -45.243 154.2188
19185.789454 -43.376 156.9414
19186.521876 -42.473 126.0195
19187.254298 -43.423 127.0977
19187.986719 -42.817 128.2773
19188.719141 -44.071 123.7305
19189.451563 -44.155 117.5859
19190.183985 -50.625 153.2539
19190.916407 -47.208 123.5469
19191.648829 -46.158 117.4414
19192.381250 -44.197 78.3281
19193.113672 -55.430 125.7852
19193.846094 -48.434 121.8945
19194.578516 -48.714 124.4766
19195.310938 -58.945 82.4961
19196.043359 -53.966 -97.5938
19196.775781 -46.623 102.1172
19197.508203 -51.095 -85.9141
19198.240625 -49.202 -52.7031
19198.973047 -50.642 -156.5195
19199.705468 -48.128 174.9453
19200.437890 -44.280 -138.7891
19201.170312 -47.383 -156.4805
19201.902734 -47.069 -138.0859
19202.635156 -44.928 -141.5156
19203.367578 -44.168 -176.0664
19204.099999 -41.709 -175.4180
19204.832421 -43.281 -164.4766
19205.564843 -42.384 159.5508
19206.297265 -41.132 167.1953
19207.029687 -41.075 162.3281
19207.762108 -38.558 170.6172
19208.494530 -40.527 165.8711
19209.226952 -41.054 152.3359
19209.959374 -41.235 164.2969
19210.691796 -39.515 154.7930
19211.424218 -37.618 124.4062
19212.156639 -39.268 133.9570
19212.889061 -40.888 121.6641
19213.621483 -38.565 121.1094
19214.353905 -43.312 115.3711
19215.086327 -40.466 120.4102
19215.818748 -40.207 115.8984
19216.551170 -42.374 120.1016
19217.283592 -41.656 89.5312
19218.016014 -40.449 96.8008
19218.748436 -41.573 97.7617
19219.480857 -41.142 97.0586
19220.213279 -44.591 80.8398
19220.945701 -41.916 93.9453
19221.678123 -45.134 67.7734
19222.410545 -46.331 73.3203
19223.142967 -45.243 78.7969
19223.875388 -45.752 81.0742
19224.607810 -44.112 101.4688
19225.340232 -42.169 82.0273
19226.072654 -48.733 80.9297
19226.805076 -50.082 40.8047
19227.537497 -49.484 60.7969
19228.269919 -52.282 138.6133
19229.002341 -52.056 83.3555
19229.734763 -49.533 91.0000
19230.467185 -54.289 49.2188
19231.199607 -48.654 129.2969
19231.932028 -61.751 97.5820
19232.664450 -47.947 128.0742
19233.396872 -50.229 162.7383
19234.129294 -51.990 -168.6211
19234.861716 -46.945 162.8867
19235.594137 -43.972 155.5625
19236.326559 -45.053 150.9531
19237.058981 -41.050 146.6641
19237.791403 -43.914 149.5547
19238.523825 -42.432 142.9727
19239.256247 -44.173 123.1797
19239.988668 -40.080 133.8281
19240.721090 -40.924 130.5078
19241.453512 -39.513 115.9922
19242.185934 -39.007 118.0586
19242.918356 -38.006 119.0508
19243.650777 -39.704 112.3242
19244.383199 -38.177 100.0039
19245.115621 -38.890 102.1602
19245.848043 -36.887 98.6992
19246.580465 -36.619 88.6875
19247.312886 -36.556 83.8789
19248.045308 -36.431 78.8086
19248.777730 -37.630 73.3477
19249.510152 -36.721 67.0000
19250.242574 -36.195 54.1953
19250.974996 -37.105 49.6406
19251.707417 -38.418 53.6367
19252.439839 -36.304 48.1016
19253.172261 -36.327 36.0898
19253.904683 -36.891 26.0625
19254.637105 -37.377 30.9414
19255.369526 -37.337 12.7812
19256.101948 -38.015 3.1250
19256.834370 -38.788 0.2656
19257.566792 -38.559 1.6914
19258.299214 -38.338 -18.8711
19259.031636 -37.144 -3.8906
19259.764057 -37.252 -29.5508
19260.496479 -37.847 -19.3867
19261.228901 -39.996 -42.2188
19261.961323 -38.722 -39.7461
19262.693745 -39.999 -50.9258
19263.426166 -42.206 -74.6094
19264.158588 -40.098 -65.2852
19264.891010 -40.387 -72.2578
19265.623432 -40.588 -83.2773
19266.355854 -41.890 -88.5508
19267.088275 -40.048 -111.9453
19267.820697 -40.706 -130.5430
19268.553119 -40.002 -138.5781
19269.285541 -42.654 -146.6133
19270.017963 -40.884 -134.6836
19270.750385 -45.042 -130.4297
19271.482806 -42.532 -159.0156
19272.215228 -42.265 -164.3398
19272.947650 -43.687 179.4531
19273.680072 -44.035 -179.7383
19274.412494 -43.917 -162.0352
19275.144915 -42.265 154.0312
19275.877337 -45.557 156.7695
19276.609759 -47.656 -178.8086
19277.342181 -48.002 149.2383
19278.074603 -45.093 109.6953
19278.807025 -48.438 125.2148
19279.539446 -47.162 88.5391
19280.271868 -46.840 116.7031
19281.004290 -50.736 179.5938
19281.736712 -62.696 173.0352
19282.469134 -57.603 -59.3945
19283.201555 -61.771 163.0781
19283.933977 -63.752 -111.3008
19284.666399 -57.189 6.6992
19285.398821 -64.372 -56.0391
19286.131243 -43.494 -116.3438
19286.863665 -61.547 -122.8086
19287.596086 -46.863 -149.5742
19288.328508 -45.658 -107.7617
19289.060930 -45.386 -160.6367
19289.793352 -52.925 137.7227
19290.525774 -45.032 -141.5117
19291.258195 -46.161 173.7227
19291.990617 -43.660 177.2344
19292.723039 -45.437 151.1016
19293.455461 -49.569 164.1641
19294.187883 -47.919 137.2930
19294.920304 -41.900 160.6055
19295.652726 -41.004 133.5273
19296.385148 -44.547 134.4258
19297.117570 -44.850 133.1250
19297.849992 -42.632 115.2422
19298.582414 -38.936 107.7578
19299.314835 -40.573 105.7539
19300.047257 -43.583 105.6484
19300.779679 -42.147 111.2539
19301.512101 -39.618 72.3867
19302.244523 -42.403 94.8828
19302.976944 -42.415 79.4688
19303.709366 -41.952 71.6836
19304.441788 -39.791 59.4219
19305.174210 -43.911 57.6836
19305.906632 -43.277 24.9336
19306.639054 -46.394 49.6953
19307.371475 -48.646 35.2617
19308.103897 -44.649 35.4805
19308.836319 -46.574 6.4414
19309.568741 -45.526 13.2656
19310.301163 -42.206 14.6367
19311.033584 -45.353 -4.6562
19311.766006 -46.279 6.4805
19312.498428 -45.816 -23.5156
19313.230850 -43.378 -31.0391
19313.963272 -44.061 -55.2578
19314.695693 -45.007 -42.9883
19315.428115 -46.629 -36.2344
19316.160537 -50.056 -57.3125
19316.892959 -48.685 -50.5586
19317.625381 -44.318 -80.7344
19318.357803 -43.904 -80.7578
19319.090224 -46.948 -91.4062
19319.822646 -47.493 -103.5898
19320.555068 -44.879 -117.1914
19321.287490 -46.844 -143.7812
19322.019912 -49.115 -108.1641
19322.752333 -56.904 -100.3984
19323.484755 -44.627 -127.9805
19324.217177 -46.695 -148.6602
19324.949599 -45.941 -118.1133
19325.682021 -51.043 171.9023
19326.414443 -46.014 -137.3242
19327.146864 -48.789 -171.6758
19327.879286 -45.580 -175.7617
19328.611708 -55.059 -163.9805
19329.344130 -46.022 -151.0664
19330.076552 -47.765 174.0586
19330.808973 -46.369 -134.2812
19331.541395 -47.065 162.9805
19332.273817 -47.209 -155.6680
19333.006239 -46.770 175.0352
19333.738661 -47.380 -145.7383
19334.471083 -48.835 179.8047
19335.203504 -45.619 175.8320
19335.935926 -49.286 161.8320
19336.668348 -54.926 -145.0352
19337.400770 -48.762 -164.6211
19338.133192 -42.572 -171.0117
19338.865613 -45.431 153.9727
19339.598035 -49.072 -168.0000
19340.330457 -50.358 147.9922
19341.062879 -43.371 173.8242
19341.795301 -41.836 148.6562
19342.527722 -45.224 150.4297
19343.260144 -42.482 156.2227
19343.992566 -40.238 137.7344
19344.724988 -40.588 122.2148
19345.457410 -44.712 123.2969
19346.189832 -45.381 102.9297
19346.922253 -44.178 124.2109
19347.654675 -39.747 116.8555
19348.387097 -44.861 92.5664
19349.119519 -38.857 104.4297
19349.851941 -39.717 111.5781
19350.584362 -40.778 85.4727
19351.316784 -40.220 92.2227
19352.049206 -40.696 69.1953
19352.781628 -42.498 78.1172
19353.514050 -40.804 88.9961
19354.246472 -41.417 86.3750
19354.978893 -39.909 52.4062
19355.711315 -43.407 58.7227
19356.443737 -41.843 55.3047
19357.176159 -42.932 15.3516
19357.908581 -40.849 16.3789
19358.641002 -46.047 38.1172
19359.373424 -41.979 18.2930
19360.105846 -43.763 1.9492
19360.838268 -44.004 -0.3125
19361.570690 -41.831 11.8086
19362.303111 -41.145 -16.1719
19363.035533 -45.106 -41.1094
19363.767955 -41.167 -38.0039
19364.500377 -50.928 -64.8438
19365.232799 -46.797 -50.7891
19365.965221 -42.861 -68.8047
19366.697642 -45.590 -91.7969
19367.430064 -51.402 -113.4453
19368.162486 -45.751 -96.0273
19368.894908 -42.509 -115.8281
19369.627330 -46.320 -101.8125
19370.359751 -47.780 -128.9023
19371.092173 -46.853 -148.4883
19371.824595 -40.525 -146.7891
19372.557017 -43.773 -176.1836
19373.289439 -45.112 177.3398
19374.021861 -46.565 -171.9961
19374.754282 -41.421 159.6016
19375.486704 -46.802 -175.0195
19376.219126 -40.492 162.8281
19376.951548 -41.835 143.0352
19377.683970 -41.779 130.8203
19378.416391 -40.577 140.7188
19379.148813 -42.194 127.2930
19379.881235 -42.192 135.4375
19380.613657 -44.832 127.9141
19381.346079 -44.614 133.9648
19382.078501 -41.796 95.2148
19382.810922 -43.950 78.0898
19383.543344 -44.401 108.1836
19384.275766 -42.095 69.3203
19385.008188 -42.670 88.9219
19385.740610 -45.623 57.2773
19386.473031 -43.953 73.8711
19387.205453 -43.139 55.3086
19387.937875 -43.403 71.3359
19388.670297 -39.602 55.7109
19389.402719 -44.706 45.0430
19390.135140 -44.994 52.6641
19390.867562 -43.585 42.8945
19391.599984 -46.697 69.1016
19392.332406 -46.944 56.3594
19393.064828 -43.821 7.0000
19393.797250 -41.964 31.2422
19394.529671 -45.298 37.8633
19395.262093 -48.796 29.2148
19395.994515 -45.417 15.0273
19396.726937 -46.454 59.8906
19397.459359 -53.689 -29.7461
19398.191780 -53.221 12.3398
19398.924202 -59.928 14.1289
19399.656624 -57.184 14.1602
19400.389046 -50.690 -3.0742
19401.121468 -48.850 -7.8711
19401.853890 -59.089 -104.4023
19402.586311 -59.823 66.5195
19403.318733 -55.566 -159.4219
19404.051155 -45.694 153.0430
19404.783577 -49.372 -118.2109
19405.515999 -41.620 158.2969
19406.248420 -44.988 174.9453
19406.980842 -43.638 121.6094
19407.713264 -43.457 160.9531
19408.445686 -42.446 137.9141
19409.178108 -39.489 128.7734
19409.910529 -39.628 139.8867
19410.642951 -38.484 130.1055
19411.375373 -37.194 115.4844
19412.107795 -37.938 124.9258
19412.840217 -37.297 117.9844
19413.572639 -36.808 116.3828
19414.305060 -35.422 101.0352
19415.037482 -38.503 95.8750
19415.769904 -35.653 77.6836
19416.502326 -37.042 74.3125
19417.234748 -36.017 54.7227
19417.967169 -37.337 61.2656
19418.699591 -34.275 69.9336
19419.432013 -35.786 44.7500
19420.164435 -36.760 55.4336
19420.896857 -37.065 47.8594
19421.629279 -32.471 30.6406
19422.361700 -36.054 37.1328
19423.094122 -34.651 24.3789
19423.826544 -34.765 12.7930
19424.558966 -34.549 22.2930
19425.291388 -35.909 13.9062
19426.023809 -34.439 5.0000
19426.756231 -38.133 18.6055
19427.488653 -36.798 -6.5391
19428.221075 -40.076 -9.7383
19428.953497 -39.305 -8.9844
19429.685919 -38.317 -0.0625
19430.418340 -37.287 -30.1875
19431.150762 -40.494 -9.0352
19431.883184 -41.640 -31.9258
19432.615606 -42.175 -28.2852
19433.348028 -43.766 -31.8594
19434.080449 -39.791 -65.7539
19434.812871 -46.333 -44.2695
19435.545293 -51.748 -48.9727
19436.277715 -52.453 -36.7266
19437.010137 -51.399 -59.0195
19437.742558 -44.864 -41.5820
19438.474980 -44.646 -26.6992
19439.207402 -46.666 70.1719
19439.939824 -44.110 -34.5664
19440.672246 -44.235 -24.4570
19441.404668 -43.241 58.9141
19442.137089 -52.929 62.0078
19442.869511 -49.812 -0.9336
19443.601933 -46.633 -22.9531
19444.334355 -44.702 5.7422
19445.066777 -58.295 76.1445
19445.799198 -49.204 62.3086
19446.531620 -40.211 -9.5625
19447.264042 -45.541 30.3008
19447.996464 -43.482 -5.4727
19448.728886 -40.486 -24.3164
19449.461308 -42.029 -24.7852
19450.193729 -44.633 -40.4102
19450.926151 -45.999 -60.4648
19451.658573 -42.923 -68.2383
19452.390995 -41.673 19.0508
19453.123417 -47.910 -40.2812
19453.855838 -41.935 -21.5078
19454.588260 -43.624 -53.2344
19455.320682 -44.913 -62.8516
19456.053104 -45.610 -45.6758
19456.785526 -59.103 -69.9805
19457.517947 -42.612 -76.8906
19458.250369 -44.685 -69.3828
19458.982791 -38.445 -49.0820
19459.715213 -57.749 148.1367
19460.447635 -42.630 -98.2266
19461.180057 -51.551 -42.1719
19461.912478 -41.121 -110.4570
19462.644900 -43.780 -76.0234
19463.377322 -47.087 -171.0352
19464.109744 -43.953 -35.6328
19464.842166 -42.829 -112.9375
19465.574587 -40.859 -102.4727
19466.307009 -40.324 -75.6406
19467.039431 -48.728 -71.6406
19467.771853 -43.840 -102.2773
19468.504275 -41.887 -122.8281
19469.236697 -42.855 -40.3242
19469.969118 -45.176 -95.2773
19470.701540 -42.329 -103.4844
19471.433962 -40.718 -105.6914
19472.166384 -37.030 -129.2578
19472.898806 -38.580 -109.9883
19473.631227 -40.503 -169.8672
19474.363649 -41.050 -119.9492
19475.096071 -39.612 -153.0195
19475.828493 -37.969 -177.6797
19476.560915 -38.859 -168.8125
19477.293337 -39.944 -174.6172
19478.025758 -39.081 -164.6953
19478.758180 -40.036 177.3945
19479.490602 -42.267 121.5742
19480.223024 -41.483 146.0156
19480.955446 -38.234 162.1055
19481.687867 -40.112 150.8906
19482.420289 -43.756 -171.1250
19483.152711 -38.177 127.1602
19483.885133 -38.798 116.3047
19484.617555 -36.024 150.9688
19485.349976 -46.685 89.1289
19486.082398 -36.745 110.5352
19486.814820 -36.150 107.8438
19487.547242 -40.185 128.3984
19488.279664 -41.892 88.0898
19489.012086 -40.340 94.3711
19489.744507 -40.268 102.1250
19490.476929 -41.483 66.5195
19491.209351 -40.291 107.0391
19491.941773 -43.649 58.7266
19492.674195 -37.169 28.8359
19493.406616 -47.200 84.7305
19494.139038 -49.326 59.3203
19494.871460 -41.916 29.9062
19495.603882 -41.466 -15.8633
19496.336304 -39.188 56.2969
19497.068726 -44.928 98.7422
19497.801147 -45.011 37.2109
19498.533569 -39.045 25.5586
19499.265991 -53.265 -11.9258
19499.998413 -47.607 46.8047
19500.730835 -46.055 43.1445
19501.463256 -56.423 30.8555
19502.195678 -40.884 22.7695
19502.928100 -44.251 68.1641
19503.660522 -50.925 54.7109
19504.392944 -45.070 -37.7656
19505.125365 -46.966 18.5703
19505.857787 -55.826 77.8008
19506.590209 -49.419 85.1641
19507.322631 -44.524 -18.2031
19508.055053 -46.063 -3.3164
19508.787475 -46.883 132.1719
19509.519896 -42.987 103.7109
19510.252318 -51.391 104.2539
19510.984740 -42.971 61.7188
19511.717162 -58.230 -172.2734
19512.449584 -42.760 8.3398
19513.182005 -44.857 115.6992
19513.914427 -40.950 -15.8906
19514.646849 -50.164 48.4805
19515.379271 -41.650 106.6172
19516.111693 -44.860 17.0039
19516.844115 -41.972 -36.3477
19517.576536 -46.272 44.5820
19518.308958 -45.366 -4.3984
19519.041380 -47.875 20.8789
19519.773802 -48.242 -6.4414
19520.506224 -42.453 -34.8203
19521.238645 -41.904 33.2695
19521.971067 -45.537 -33.8906
19522.703489 -43.734 -15.5156
19523.435911 -46.538 56.6016
19524.168333 -46.706 -6.9180
19524.900755 -53.851 34.3945
19525.633176 -46.754 -58.1445
19526.365598 -43.581 -48.3555
19527.098020 -41.992 -10.1172
19527.830442 -52.104 24.4062
19528.562864 -41.259 -60.6133
19529.295285 -52.106 -72.9688
19530.027707 -43.196 -37.6875
19530.760129 -41.550 -115.5352
19531.492551 -41.123 -44.1758
19532.224973 -54.178 13.4648
19532.957394 -44.929 -125.5234
19533.689816 -48.575 -110.0195
19534.422238 -55.851 128.4062
19535.154660 -49.072 -119.3047
19535.887082 -47.313 31.4102
19536.619504 -52.501 72.5039
19537.351925 -54.888 -64.7383
19538.084347 -45.178 -20.8477
19538.816769 -45.676 -4.5469
19539.549191 -54.181 -44.3906
19540.281613 -45.980 -111.3711
19541.014034 -54.162 -122.4492
19541.746456 -51.833 94.9844
19542.478878 -47.009 -113.4844
19543.211300 -46.263 -119.1992
19543.943722 -47.586 -150.8477
19544.676144 -58.723 125.2422
19545.408565 -51.314 156.8281
19546.140987 -42.909 -73.6445
19546.873409 -43.088 -165.5977
19547.605831 -43.450 -115.9648
19548.338253 -52.480 156.9375
19549.070674 -46.522 150.0938
19549.803096 -42.980 -163.4844
19550.535518 -48.667 84.8438
19551.267940 -52.588 160.2148
19552.000362 -46.453 146.2695
19552.732783 -50.769 118.4102
19553.465205 -40.674 148.8086
19554.197627 -46.017 87.4570
19554.930049 -53.900 79.1406
19555.662471 -43.340 112.6211
19556.394893 -47.382 148.2773
19557.127314 -41.564 146.4453
19557.859736 -56.977 89.6445
19558.592158 -48.743 83.1172
19559.324580 -44.386 65.0234
19560.057002 -37.946 73.9766
19560.789423 -58.248 65.8398
19561.521845 -38.183 47.7773
19562.254267 -44.639 2.7266
19562.986689 -39.155 82.7344
19563.719111 -43.362 63.5000
19564.451533 -42.434 38.8398
19565.183954 -39.528 29.8789
19565.916376 -37.664 32.0898
19566.648798 -43.154 60.1211
19567.381220 -41.313 11.6094
19568.113642 -42.161 3.5195
19568.846063 -40.523 44.4531
19569.578485 -39.938 -1.4492
19570.310907 -40.725 6.4102
19571.043329 -39.158 -10.4648
19571.775751 -39.371 -10.2109
19572.508173 -37.911 -30.1875
19573.240594 -40.042 -19.9336
19573.973016 -37.766 -37.3008
19574.705438 -39.687 -21.8438
19575.437860 -37.598 -39.3008
19576.170282 -39.742 -28.0781
19576.902703 -37.306 -51.1719
19577.635125 -37.199 -63.0859
19578.367547 -38.922 -63.6680
19579.099969 -38.230 -77.2461
19579.832391 -41.366 -94.0430
19580.564812 -41.382 -81.9961
19581.297234 -41.948 -75.0898
19582.029656 -39.181 -100.1992
19582.762078 -39.494 -80.2969
19583.494500 -41.841 -102.0742
19584.226922 -41.962 -118.1523
19584.959343 -39.898 -122.9648
19585.691765 -39.683 -125.7500
19586.424187 -42.986 -144.9023
19587.156609 -44.280 -120.9336
19587.889031 -45.932 -149.3281
19588.621452 -48.902 167.4727
19589.353874 -47.713 -159.2969
19590.086296 -47.225 -171.6797
19590.818718 -53.105 175.0469
19591.551140 -53.889 102.0547
19592.283562 -48.145 98.8125
19593.015983 -53.233 -116.5703
19593.748405 -66.945 -108.4727
19594.480827 -52.360 -84.9219
19595.213249 -54.506 -16.9570
19595.945671 -52.060 -53.5820
19596.678092 -49.420 -2.0273
19597.410514 -45.387 -60.9453
19598.142936 -47.204 4.9258
19598.875358 -41.136 -60.0312
19599.607780 -43.118 -49.7422
19600.340201 -43.247 -51.1523
19601.072623 -43.003 -81.0977
19601.805045 -40.307 -100.2422
19602.537467 -42.285 -85.0312
19603.269889 -45.829 -101.2344
19604.002311 -46.445 -75.5273
19604.734732 -40.097 -104.4180
19605.467154 -40.446 -120.1211
19606.199576 -39.619 -137.9062
19606.931998 -40.327 -104.5078
19607.664420 -38.325 -151.5938
19608.396841 -39.038 -135.9375
19609.129263 -39.599 -144.5586
19609.861685 -42.849 -155.2773
19610.594107 -41.525 -159.5898
19611.326529 -42.016 175.1602
19612.058951 -42.179 156.6406
19612.791372 -46.601 165.1367
19613.523794 -42.966 159.1836
19614.256216 -43.074 138.9492
19614.988638 -42.116 137.2070
19615.721060 -45.731 83.0234
19616.453481 -45.109 116.1133
19617.185903 -46.443 114.0547
19617.918325 -47.365 99.7266
19618.650747 -44.866 93.5859
19619.383169 -47.285 103.1250
19620.115591 -49.486 95.0234
19620.848012 -51.691 101.7578
19621.580434 -47.652 6.6289
19622.312856 -55.166 -79.0508
19623.045278 -52.067 9.2500
19623.777700 -43.357 16.6055
19624.510121 -46.243 -42.7188
19625.242543 -45.871 -43.1055
19625.974965 -47.121 -22.3516
19626.707387 -46.557 -10.4336
19627.439809 -43.817 -54.9453
19628.172230 -47.516 -56.0234
19628.904652 -45.566 -75.2383
19629.637074 -41.882 -89.5547
19630.369496 -43.079 -82.5469
19631.101918 -43.635 -105.6133
19631.834340 -44.181 -105.6641
19632.566761 -46.696 -130.1289
19633.299183 -45.787 -100.9102
19634.031605 -41.228 -122.9375
19634.764027 -44.488 -128.4219
19635.496449 -41.084 -101.1914
19636.228870 -41.535 -119.6055
19636.961292 -42.763 -179.5703
19637.693714 -42.434 -127.9023
19638.426136 -45.832 -134.4180
19639.158558 -45.287 -127.3281
19639.890980 -46.889 -139.5117
19640.623401 -42.189 -163.5117
19641.355823 -44.069 -148.2852
19642.088245 -45.725 -151.6680
19642.820667 -42.261 -175.7891
19643.553089 -42.341 176.5430
19644.285510 -41.070 -166.9492
19645.017932 -46.660 -150.1875
19645.750354 -42.939 -177.2070
19646.482776 -42.731 169.9141
19647.215198 -47.978 -151.5117
19647.947619 -44.631 177.0781
19648.680041 -42.125 162.8203
19649.412463 -45.258 -168.2461
19650.144885 -55.300 -114.1289
19650.877307 -53.312 -91.4688
19651.609729 -48.930 168.4492
19652.342150 -49.199 -172.8672
19653.074572 -49.550 173.3086
19653.806994 -44.626 -141.2617
19654.539416 -47.527 89.4492
19655.271838 -50.024 165.4922
19656.004259 -48.556 141.7188
19656.736681 -42.487 -104.5000
19657.469103 -46.065 -112.7539
19658.201525 -50.973 -111.9688
19658.933947 -45.241 -133.7344
19659.666369 -41.215 -100.8398
19660.398790 -44.469 -149.4297
19661.131212 -45.643 -127.5195
19661.863634 -44.558 -94.4883
19662.596056 -38.955 -112.5625
19663.328478 -41.925 -144.3633
19664.060899 -42.809 -135.4766
19664.793321 -43.650 -133.1211
19665.525743 -41.781 -140.9375
19666.258165 -41.879 -160.8320
19666.990587 -42.690 -174.4062
19667.723009 -38.988 176.9414
19668.455430 -37.951 -157.2773
19669.187852 -37.621 173.9805
19669.920274 -39.076 -173.7031
19670.652696 -40.021 164.7812
19671.385118 -39.779 157.4414
19672.117539 -37.237 153.1445
19672.849961 -38.363 147.3750
19673.582383 -40.319 145.7031
19674.314805 -38.017 151.6758
19675.047227 -39.585 144.4727
19675.779648 -36.448 135.0820
19676.512070 -36.191 120.4961
19677.244492 -38.044 126.6641
19677.976914 -38.329 110.2539
19678.709336 -38.377 104.4258
19679.441758 -38.356 98.9922
19680.174179 -42.651 101.6211
19680.906601 -38.642 96.6914
19681.639023 -41.456 89.8086
19682.371445 -46.579 77.6914
19683.103867 -48.399 80.3828
19683.836288 -45.161 47.5312
19684.568710 -44.438 71.0898
19685.301132 -51.631 29.4961
19686.033554 -59.254 -135.6328
19686.765976 -49.931 138.3086
19687.498398 -58.432 -4.3672
19688.230819 -64.124 69.9336
19688.963241 -51.527 -123.2930
19689.695663 -56.891 -152.8984
19690.428085 -49.476 -168.9805
19691.160507 -47.999 176.7500
19691.892928 -42.762 -173.0742
19692.625350 -44.445 159.4062
19693.357772 -41.920 177.4844
19694.090194 -44.869 173.4375
19694.822616 -40.328 166.9375
19695.555037 -42.604 148.1445
19696.287459 -38.938 148.3750
19697.019881 -40.699 141.3672
19697.752303 -38.000 144.7891
19698.484725 -38.033 119.7305
19699.217147 -38.097 123.4219
19699.949568 -39.204 107.2695
19700.681990 -36.636 112.9844
19701.414412 -38.423 84.0039
19702.146834 -37.287 91.1523
19702.879256 -37.628 78.6172
19703.611677 -37.809 98.9336
19704.344099 -37.070 73.5391
19705.076521 -38.179 77.0234
19705.808943 -38.995 65.6953
19706.541365 -37.965 63.7031
19707.273787 -37.815 37.6719
19708.006208 -39.076 39.8086
19708.738630 -40.603 31.8008
19709.471052 -43.520 63.3789
19710.203474 -39.459 17.5117
19710.935896 -39.241 7.4648
19711.668317 -40.411 -1.8203
19712.400739 -41.485 -3.5234
19713.133161 -41.478 -25.6758
19713.865583 -42.277 -27.4102
19714.598005 -41.214 -11.4688
19715.330427 -46.040 -61.9766
19716.062848 -43.981 -33.9453
19716.795270 -43.038 -59.5586
19717.527692 -40.874 -87.1133
19718.260114 -44.540 -82.9219
19718.992536 -44.854 -104.0781
19719.724957 -43.412 -108.0156
19720.457379 -47.481 -92.2305
19721.189801 -46.855 -150.0352
19721.922223 -47.235 -139.4727
19722.654645 -46.445 -168.4297
19723.387066 -45.073 -170.7109
19724.119488 -44.355 -177.6953
19724.851910 -44.279 173.4414
19725.584332 -48.827 170.4102
19726.316754 -50.908 178.9023
19727.049176 -43.536 160.5898
19727.781597 -44.925 113.4570
19728.514019 -45.676 147.0000
19729.246441 -42.874 130.5312
19729.978863 -45.999 112.3828
19730.711285 -54.695 179.1562
19731.443706 -45.767 105.4336
19732.176128 -45.579 117.6211
19732.908550 -41.908 111.7539
19733.640972 -43.892 109.2656
19734.373394 -46.383 118.8125
19735.105816 -44.836 100.2227
19735.838237 -50.232 128.6328
19736.570659 -46.059 95.9180
19737.303081 -44.502 76.3750
19738.035503 -45.033 42.6758
19738.767925 -44.484 79.1484
19739.500346 -47.587 60.4375
19740.232768 -45.710 52.8516
19740.965190 -49.620 81.3242
19741.697612 -44.763 60.8281
19742.430034 -44.530 58.9141
19743.162455 -46.351 63.2266
19743.894877 -46.735 53.1133
19744.627299 -44.936 38.0977
19745.359721 -44.781 23.0820
19746.092143 -44.739 22.8203
19746.824565 -44.734 -4.7031
19747.556986 -46.824 44.4180
19748.289408 -47.395 -37.6211
19749.021830 -46.466 -10.1445
19749.754252 -44.368 -57.4258
19750.486674 -42.848 26.8086
19751.219095 -44.976 -21.5273
19751.951517 -47.313 -27.2500
19752.683939 -46.314 -27.5430
19753.416361 -50.538 -23.1094
19754.148783 -47.442 -65.0156
19754.881205 -45.302 -108.6406
19755.613626 -44.891 -112.8633
19756.346048 -64.943 -80.1523
19757.078470 -47.990 -135.6406
19757.810892 -48.753 -147.2305
19758.543314 -47.355 -143.6641
19759.275735 -46.669 175.3281
19760.008157 -45.421 -176.0312
19760.740579 -43.950 174.1797
19761.473001 -45.272 -168.5117
19762.205423 -47.964 160.4102
19762.937845 -48.676 136.6562
19763.670266 -45.995 139.8047
19764.402688 -43.857 133.2383
19765.135110 -45.747 139.4062
19765.867532 -59.143 96.3828
19766.599954 -47.856 100.4453
19767.332375 -49.363 114.3203
19768.064797 -46.984 39.1680
19768.797219 -47.723 30.9531
19769.529641 -48.608 53.0273
19770.262063 -45.510 13.8750
19770.994484 -45.205 -6.8281
19771.726906 -43.765 5.5000
19772.459328 -44.672 -29.2656
19773.191750 -46.099 -38.0586
19773.924172 -46.035 -33.7695
19774.656594 -39.523 -45.1445
19775.389015 -42.210 -63.1367
19776.121437 -43.328 -72.7773
19776.853859 -42.578 -101.6328
19777.586281 -40.551 -106.1484
19778.318703 -39.645 -103.5312
19779.051124 -39.007 -132.2969
19779.783546 -41.208 -133.1211
19780.515968 -38.914 -129.1094
19781.248390 -39.103 -135.0859
19781.980812 -37.048 -143.2422
19782.713234 -36.805 -163.6484
19783.445655 -38.780 -166.7734
19784.178077 -37.399 -168.7656
19784.910499 -36.581 -175.6328
19785.642921 -38.496 171.7852
19786.375343 -37.635 164.7344
19787.107764 -37.542 153.6172
19787.840186 -36.853 151.2539
19788.572608 -36.396 139.6797
19789.305030 -36.380 139.2344
19790.037452 -36.299 127.0508
19790.769873 -36.950 116.6758
19791.502295 -37.230 109.0430
19792.234717 -37.780 119.4297
19792.967139 -36.624 97.9805
19793.699561 -37.453 104.4531
19794.431983 -37.400 87.1562
19795.164404 -37.955 80.8555
19795.896826 -38.573 80.4102
19796.629248 -41.340 86.7305
19797.361670 -39.834 40.6133
19798.094092 -40.994 51.7031
19798.826513 -39.992 48.4219
19799.558935 -42.811 52.1914
19800.291357 -43.880 31.3906
19801.023779 -43.405 24.5508
19801.756201 -46.770 39.4336
19802.488623 -49.720 10.3594
19803.221044 -43.550 12.5469
19803.953466 -48.919 9.5547
19804.685888 -49.666 5.8359
19805.418310 -59.390 170.9375
19806.150732 -52.818 136.2148
19806.883153 -55.487 -122.8516
19807.615575 -51.038 136.1133
19808.347997 -44.726 -174.0117
19809.080419 -52.256 165.7227
19809.812841 -47.411 -177.0898
19810.545263 -44.978 92.8438
19811.277684 -43.782 99.8867
19812.010106 -40.981 98.1328
19812.742528 -41.631 97.3320
19813.474950 -40.714 75.2930
19814.207372 -42.235 107.4219
19814.939793 -41.907 73.1484
19815.672215 -43.700 96.5586
19816.404637 -39.251 66.3594
19817.137059 -43.197 64.8945
19817.869481 -41.256 58.9961
19818.601902 -40.195 42.5078
19819.334324 -40.737 36.5234
19820.066746 -42.058 51.9688
19820.799168 -40.856 26.1289
19821.531590 -47.635 5.2773
19822.264012 -40.569 2.7656
19822.996433 -42.727 -24.0781
19823.728855 -41.052 31.7188
19824.461277 -44.716 3.9102
19825.193699 -45.849 -13.3633
19825.926121 -38.721 -3.3906
19826.658542 -42.987 10.4648
19827.390964 -41.051 -21.1992
19828.123386 -41.357 -20.0859
19828.855808 -44.734 -18.5078
19829.588230 -42.044 2.9180
19830.320652 -41.975 -49.4141
19831.053073 -45.682 -57.6719
19831.785495 -49.701 -23.3125
19832.517917 -48.410 -37.2773
19833.250339 -49.288 -89.8438
19833.982761 -50.356 -47.5625
19834.715182 -58.000 157.6797
19835.447604 -49.454 23.1953
19836.180026 -48.922 -121.5312
19836.912448 -50.371 34.1445
19837.644870 -53.990 63.6094
19838.377292 -51.543 -94.9180
19839.109713 -54.182 -168.0078
19839.842135 -54.599 -39.0039
19840.574557 -50.480 -59.7930
19841.306979 -50.988 59.3359
19842.039401 -46.700 -144.5234
19842.771822 -55.421 -161.9766
19843.504244 -52.079 110.3516
19844.236666 -50.981 -131.6172
19844.969088 -49.562 167.5781
19845.701510 -53.513 86.5195
19846.433931 -59.067 102.9883
19847.166353 -62.650 146.2812
19847.898775 -49.948 133.5195
19848.631197 -50.996 27.6211
19849.363619 -51.490 19.1562
19850.096041 -53.168 16.0742
19850.828462 -53.247 165.6719
19851.560884 -48.810 123.7930
19852.293306 -57.641 -99.1875
19853.025728 -51.749 131.9453
19853.758150 -47.697 -144.5664
19854.490571 -46.941 -103.2461
19855.222993 -46.128 137.1133
19855.955415 -72.110 91.6562
19856.687837 -41.379 -178.5000
19857.420259 -49.333 111.7773
19858.152681 -55.021 76.8594
19858.885102 -49.109 175.3008
19859.617524 -44.035 159.2148
19860.349946 -67.673 -152.3047
19861.082368 -51.506 155.0078
19861.814790 -51.416 -171.3516
19862.547211 -42.738 127.9805
19863.279633 -58.499 -178.4062
19864.012055 -49.493 -172.6172
19864.744477 -46.765 158.9531
19865.476899 -42.270 169.2422
19866.209320 -44.608 174.0781
19866.941742 -41.382 151.3477
19867.674164 -45.629 163.4297
19868.406586 -38.281 143.4961
19869.139008 -46.638 149.0664
19869.871430 -42.328 153.7266
19870.603851 -45.399 -176.2500
19871.336273 -38.889 125.3516
19872.068695 -41.847 95.1094
19872.801117 -45.080 125.1680
19873.533539 -42.186 109.3906
19874.265960 -41.259 94.9336
19874.998382 -44.542 95.5820
19875.730804 -42.433 62.1953
19876.463226 -43.099 49.1641
19877.195648 -44.253 86.7930
19877.928070 -42.417 63.3320
19878.660491 -41.736 75.2773
19879.392913 -42.208 47.2188
19880.125335 -41.050 80.2070
19880.857757 -42.813 34.9648
19881.590179 -40.181 47.3984
19882.322600 -43.412 18.3594
19883.055022 -43.247 51.8203
19883.787444 -41.141 21.9570
19884.519866 -44.340 36.6211
19885.252288 -46.477 40.2344
19885.984710 -40.451 18.2773
19886.717131 -45.227 25.5195
19887.449553 -46.277 12.0312
19888.181975 -45.663 -19.0977
19888.914397 -50.073 29.7891
19889.646819 -51.033 -45.7773
19890.379240 -51.625 13.2812
19891.111662 -52.076 -66.1562
19891.844084 -61.566 105.9336
19892.576506 -49.977 -94.5352
19893.308928 -63.448 -128.1641
19894.041349 -49.204 -70.3320
19894.773771 -51.482 65.6367
19895.506193 -50.947 -161.7109
19896.238615 -61.210 106.2891
19896.971037 -58.008 102.1484
19897.703459 -52.483 107.8594
19898.435880 -47.884 72.7617
19899.168302 -46.307 117.6367
19899.900724 -51.374 31.9805
19900.633146 -40.992 67.1836
19901.365568 -46.206 86.9961
19902.097989 -42.717 57.0391
19902.830411 -45.201 69.6797
19903.562833 -39.801 81.1289
19904.295255 -44.053 86.5000
19905.027677 -43.076 49.3555
19905.760099 -45.878 82.3516
19906.492520 -46.176 45.0938
19907.224942 -48.507 42.3203
19907.957364 -44.667 20.2500
19908.689786 -49.664 52.3789
19909.422208 -41.791 47.4844
19910.154629 -45.975 29.1367
19910.887051 -47.788 43.2539
19911.619473 -46.105 65.2773
19912.351895 -43.522 22.3594
19913.084317 -46.643 47.6172
19913.816738 -43.784 42.2578
19914.549160 -44.091 4.8906
19915.281582 -43.123 8.0430
19916.014004 -46.205 33.9844
19916.746426 -50.289 73.7188
19917.478848 -44.929 22.9062
19918.211269 -46.444 -0.0469
19918.943691 -45.767 17.8711
19919.676113 -47.388 -10.0938
19920.408535 -51.268 -4.7422
19921.140957 -47.381 -19.8125
19921.873378 -48.221 43.7500
19922.605800 -43.813 -8.0977
19923.338222 -47.220 -20.4453
19924.070644 -43.467 38.6406
19924.803066 -48.252 45.7656
19925.535488 -47.902 3.3281
19926.267909 -48.580 22.3984
19927.000331 -45.364 -8.7812
19927.732753 -51.758 -24.0039
19928.465175 -46.776 -14.3125
19929.197597 -47.506 -22.3203
19929.930018 -54.210 11.8750
19930.662440 -55.080 -30.5586
19931.394862 -50.664 30.4219
19932.127284 -52.573 -56.7188
19932.859706 -51.557 21.4570
19933.592128 -65.576 35.5117
19934.324549 -42.789 69.9805
19935.056971 -51.195 61.7656
19935.789393 -46.628 26.6250
19936.521815 -48.717 36.9688
19937.254237 -52.912 118.2617
19937.986658 -44.903 102.2344
19938.719080 -42.530 51.9531
19939.451502 -43.579 90.7266
19940.183924 -44.716 64.6562
19940.916346 -46.557 58.3828
19941.648767 -44.247 30.6016
19942.381189 -41.405 55.6445
19943.113611 -41.567 40.0195
19943.846033 -42.267 40.3555
19944.578455 -37.683 34.2227
19945.310877 -40.436 38.5938
19946.043298 -40.020 19.6055
19946.775720 -41.595 3.4844
19947.508142 -40.979 10.4258
19948.240564 -40.431 10.3203
19948.972986 -41.712 -26.1680
19949.705407 -42.939 -18.4961
19950.437829 -39.382 -6.9609
19951.170251 -41.592 -37.3711
19951.902673 -42.005 -11.5820
19952.635095 -46.876 -34.4805
19953.367517 -41.482 -30.6367
19954.099938 -46.112 -11.1094
19954.832360 -42.460 -57.3633
19955.564782 -46.585 -48.7969
19956.297204 -46.675 -57.1875
19957.029626 -43.730 -80.0195
19957.762047 -47.435 -86.3164
19958.494469 -44.938 -106.6367
19959.226891 -45.447 -75.9062
19959.959313 -48.973 -84.7852
19960.691735 -49.220 -121.3828
19961.424156 -58.554 -171.7227
19962.156578 -56.256 -109.8281
19962.889000 -48.640 138.9141
19963.621422 -55.617 111.6055
19964.353844 -53.451 88.8945
19965.086266 -48.287 102.1758
19965.818687 -53.464 53.7656
19966.551109 -55.030 170.4102
19967.283531 -49.312 90.3867
19968.015953 -47.618 76.4727
19968.748375 -50.776 51.9023
19969.480796 -49.550 29.8242
19970.213218 -51.518 72.7344
19970.945640 -45.531 8.5508
19971.678062 -47.944 39.4609
19972.410484 -49.559 52.2461
19973.142906 -48.911 16.2891
19973.875327 -50.577 26.7109
19974.607749 -46.273 34.5977
19975.340171 -51.150 -32.9609
19976.072593 -50.323 36.1172
19976.805015 -51.412 -5.4219
19977.537436 -50.819 39.7188
19978.269858 -52.428 -16.0742
19979.002280 -49.918 -1.3164
19979.734702 -52.973 12.0352
19980.467124 -48.929 35.9609
19981.199546 -47.677 3.1016
19981.931967 -50.045 49.9688
19982.664389 -52.645 10.8281
19983.396811 -50.365 17.0391
19984.129233 -50.686 57.3711
19984.861655 -46.975 19.9688
19985.594076 -48.645 23.2461
19986.326498 -42.108 38.4414
19987.058920 -44.402 36.0078
19987.791342 -42.304 21.8320
19988.523764 -44.670 17.6172
19989.256185 -41.891 26.1953
19989.988607 -45.037 -13.5508
19990.721029 -43.018 8.0820
19991.453451 -41.165 1.4570
19992.185873 -42.092 -2.3125
19992.918295 -41.807 3.1875
19993.650716 -44.184 16.3281
19994.383138 -43.983 -3.0078
19995.115560 -40.721 -0.2578
19995.847982 -44.413 -17.4648
19996.580404 -42.046 -2.2227
19997.312825 -42.051 -25.7930
19998.045247 -42.091 -12.7227
19998.777669 -41.826 -20.6680
19999.510091 -40.117 -5.9688
20000.242513 -42.225 -27.0195
